RTEMS
6.1-rc1
bsps
shared
dev
serial
mc68681_p.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
5
* COPYRIGHT (c) 1989-1999.
6
* On-Line Applications Research Corporation (OAR).
7
8
9
* modification, are permitted provided that the following conditions
10
* are met:
11
* 1. Redistributions of source code must retain the above copyright
12
* notice, this list of conditions and the following disclaimer.
13
* 2. Redistributions in binary form must reproduce the above copyright
14
* notice, this list of conditions and the following disclaimer in the
15
* documentation and/or other materials provided with the distribution.
16
17
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
18
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
21
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
22
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
23
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
24
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
25
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
26
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
27
* POSSIBILITY OF SUCH DAMAGE.
28
29
30
#ifndef _MC68681_P_H_
31
#define _MC68681_P_H_
32
33
#ifdef __cplusplus
34
extern
"C"
35
#endif
36
37
38
* Define MC68681_STATIC to nothing while debugging so the entry points
39
* will show up in the symbol table.
40
41
42
#define MC68681_STATIC
43
44
/* #define MC68681_STATIC static */
45
46
47
* mc68681 register offsets Read/Write Addresses
48
49
50
#define MC68681_MODE_REG_1A 0
/* MR1A-MR Prior to Read */
51
#define MC68681_MODE_REG_2A 0
/* MR2A-MR After Read */
52
53
#define MC68681_COUNT_MODE_CURRENT_MSB 6
/* CTU */
54
#define MC68681_COUNTER_TIMER_UPPER_REG 6
/* CTU */
55
#define MC68681_COUNT_MODE_CURRENT_LSB 7
/* CTL */
56
#define MC68681_COUNTER_TIMER_LOWER_REG 7
/* CTL */
57
#define MC68681_INTERRUPT_VECTOR_REG 12
/* IVR */
58
59
#define MC68681_MODE_REG_1B 8
/* MR1B-MR Prior to Read */
60
#define MC68681_MODE_REG_2B 8
/* MR2BA-MR After Read */
61
62
63
* mc68681 register offsets Read Only Addresses
64
65
66
#define MC68681_STATUS_REG_A 1
/* SRA */
67
#define MC68681_MASK_ISR_REG 2
/* MISR */
68
#define MC68681_RECEIVE_BUFFER_A 3
/* RHRA */
69
#define MC68681_INPUT_PORT_CHANGE_REG 4
/* IPCR */
70
#define MC68681_INTERRUPT_STATUS_REG 5
/* ISR */
71
#define MC68681_STATUS_REG_B 9
/* SRB */
72
#define MC68681_RECEIVE_BUFFER_B 11
/* RHRB */
73
#define MC68681_INPUT_PORT 13
/* IP */
74
#define MC68681_START_COUNT_CMD 14
/* SCC */
75
#define MC68681_STOP_COUNT_CMD 15
/* STC */
76
77
78
* mc68681 register offsets Write Only Addresses
79
80
81
#define MC68681_CLOCK_SELECT_REG_A 1
/* CSRA */
82
#define MC68681_COMMAND_REG_A 2
/* CRA */
83
#define MC68681_TRANSMIT_BUFFER_A 3
/* THRA */
84
#define MC68681_AUX_CTRL_REG 4
/* ACR */
85
#define MC68681_INTERRUPT_MASK_REG 5
/* IMR */
86
#define MC68681_CLOCK_SELECT_REG_B 9
/* CSRB */
87
#define MC68681_COMMAND_REG_B 10
/* CRB */
88
#define MC68681_TRANSMIT_BUFFER_B 11
/* THRB */
89
#define MC68681_OUTPUT_PORT_CONFIG_REG 13
/* OPCR */
90
#define MC68681_OUTPUT_PORT_SET_REG 14
/* SOPBC */
91
#define MC68681_OUTPUT_PORT_RESET_BITS 15
/* COPBC */
92
93
94
* DUART Command Register Definitions:
95
96
* MC68681_COMMAND_REG_A,MC68681_COMMAND_REG_B
97
98
99
#define MC68681_MODE_REG_ENABLE_RX 0x01
100
#define MC68681_MODE_REG_DISABLE_RX 0x02
101
#define MC68681_MODE_REG_ENABLE_TX 0x04
102
#define MC68681_MODE_REG_DISABLE_TX 0x08
103
#define MC68681_MODE_REG_RESET_MR_PTR 0x10
104
#define MC68681_MODE_REG_RESET_RX 0x20
105
#define MC68681_MODE_REG_RESET_TX 0x30
106
#define MC68681_MODE_REG_RESET_ERROR 0x40
107
#define MC68681_MODE_REG_RESET_BREAK 0x50
108
#define MC68681_MODE_REG_START_BREAK 0x60
109
#define MC68681_MODE_REG_STOP_BREAK 0x70
110
#define MC68681_MODE_REG_SET_RX_BRG 0x80
111
#define MC68681_MODE_REG_CLEAR_RX_BRG 0x90
112
#define MC68681_MODE_REG_SET_TX_BRG 0xa0
113
#define MC68681_MODE_REG_CLEAR_TX_BRG 0xb0
114
#define MC68681_MODE_REG_SET_STANDBY 0xc0
115
#define MC68681_MODE_REG_SET_ACTIVE 0xd0
116
117
118
* Mode Register Definitions
119
120
* MC68681_MODE_REG_1A
121
* MC68681_MODE_REG_1B
122
123
124
#define MC68681_5BIT_CHARS 0x00
125
#define MC68681_6BIT_CHARS 0x01
126
#define MC68681_7BIT_CHARS 0x02
127
#define MC68681_8BIT_CHARS 0x03
128
129
#define MC68681_ODD_PARITY 0x00
130
#define MC68681_EVEN_PARITY 0x04
131
132
#define MC68681_WITH_PARITY 0x00
133
#define MC68681_FORCE_PARITY 0x08
134
#define MC68681_NO_PARITY 0x10
135
#define MC68681_MULTI_DROP 0x18
136
137
#define MC68681_ERR_MODE_CHAR 0x00
138
#define MC68681_ERR_MODE_BLOCK 0x20
139
140
#define MC68681_RX_INTR_RX_READY 0x00
141
#define MC68681_RX_INTR_FFULL 0x40
142
143
#define MC68681_NO_RX_RTS_CTL 0x00
144
#define MC68681_RX_RTS_CTRL 0x80
145
146
147
148
149
* MC68681_MODE_REG_2A
150
* MC68681_MODE_REG_2B
151
152
153
#define MC68681_STOP_BIT_LENGTH__563 0x00
154
#define MC68681_STOP_BIT_LENGTH__625 0x01
155
#define MC68681_STOP_BIT_LENGTH__688 0x02
156
#define MC68681_STOP_BIT_LENGTH__75 0x03
157
#define MC68681_STOP_BIT_LENGTH__813 0x04
158
#define MC68681_STOP_BIT_LENGTH__875 0x05
159
#define MC68681_STOP_BIT_LENGTH__938 0x06
160
#define MC68681_STOP_BIT_LENGTH_1 0x07
161
#define MC68681_STOP_BIT_LENGTH_1_563 0x08
162
#define MC68681_STOP_BIT_LENGTH_1_625 0x09
163
#define MC68681_STOP_BIT_LENGTH_1_688 0x0a
164
#define MC68681_STOP_BIT_LENGTH_1_75 0x0b
165
#define MC68681_STOP_BIT_LENGTH_1_813 0x0c
166
#define MC68681_STOP_BIT_LENGTH_1_875 0x0d
167
#define MC68681_STOP_BIT_LENGTH_1_938 0x0e
168
#define MC68681_STOP_BIT_LENGTH_2 0x0f
169
170
#define MC68681_CTS_ENABLE_TX 0x10
171
#define MC68681_TX_RTS_CTRL 0x20
172
173
#define MC68681_CHANNEL_MODE_NORMAL 0x00
174
#define MC68681_CHANNEL_MODE_ECHO 0x40
175
#define MC68681_CHANNEL_MODE_LOCAL_LOOP 0x80
176
#define MC68681_CHANNEL_MODE_REMOTE_LOOP 0xc0
177
178
179
* Status Register Definitions
180
181
* MC68681_STATUS_REG_A, MC68681_STATUS_REG_B
182
183
184
#define MC68681_RX_READY 0x01
185
#define MC68681_FFULL 0x02
186
#define MC68681_TX_READY 0x04
187
#define MC68681_TX_EMPTY 0x08
188
#define MC68681_OVERRUN_ERROR 0x10
189
#define MC68681_PARITY_ERROR 0x20
190
#define MC68681_FRAMING_ERROR 0x40
191
#define MC68681_RECEIVED_BREAK 0x80
192
193
#define MC68681_RX_ERRORS \
194
(MC68681_OVERRUN_ERROR|MC68681_PARITY_ERROR| \
195
MC68681_FRAMING_ERROR|MC68681_RECEIVED_BREAK)
196
197
198
* Interupt Status Register Definitions.
199
200
* MC68681_INTERRUPT_STATUS_REG
201
202
203
204
* Interupt Mask Register Definitions
205
206
* MC68681_INTERRUPT_MASK_REG
207
208
209
/* These are passed to mc68681_build_imr */
210
#define MC68681_IR_TX_READY 0x01
211
#define MC68681_IR_RX_READY 0x02
212
#define MC68681_IR_BREAK 0x04
213
#define MC68681_IMR_ENABLE_ALL 0x07
214
#define MC68681_IMR_DISABLE_ALL 0x00
215
#define MC68681_IMR_ENABLE_ALL_EXCEPT_TX 0x06
216
217
#define MC68681_IR_TX_READY_A 0x01
218
#define MC68681_IR_RX_READY_A 0x02
219
#define MC68681_IR_BREAK_A 0x04
220
#define MC68681_IR_COUNTER_READY 0x08
221
#define MC68681_IR_TX_READY_B 0x10
222
#define MC68681_IR_RX_READY_B 0x20
223
#define MC68681_IR_BREAK_B 0x40
224
#define MC68681_IR_INPUT_PORT_CHANGE 0x80
225
226
227
* Status Register Definitions.
228
229
* MC68681_STATUS_REG_A,MC68681_STATUS_REG_B
230
231
232
#define MC68681_STATUS_RXRDY 0x01
233
#define MC68681_STATUS_FFULL 0x02
234
#define MC68681_STATUS_TXRDY 0x04
235
#define MC68681_STATUS_TXEMT 0x08
236
#define MC68681_STATUS_OVERRUN_ERROR 0x10
237
#define MC68681_STATUS_PARITY_ERROR 0x20
238
#define MC68681_STATUS_FRAMING_ERROR 0x40
239
#define MC68681_STATUS_RECEIVED_BREAK 0x80
240
241
242
* Definitions for the Interrupt Vector Register:
243
244
* MC68681_INTERRUPT_VECTOR_REG
245
246
247
#define MC68681_INTERRUPT_VECTOR_INIT 0x0f
248
249
250
* Definitions for the Auxiliary Control Register
251
252
* MC68681_AUX_CTRL_REG
253
254
255
#define MC68681_AUX_BRG_SET1 0x00
256
#define MC68681_AUX_BRG_SET2 0x80
257
258
259
* Per chip context control
260
261
262
typedef
struct
_mc68681_context
263
264
int
mate;
265
unsigned
char
imr;
266
mc68681_context
267
268
269
* Driver functions
270
271
MC68681_STATIC
void
mc68681_initialize_context(
272
int
minor,
273
mc68681_context
*pmc68681Context
274
275
276
MC68681_STATIC
bool
mc68681_probe(
int
minor);
277
278
MC68681_STATIC
int
mc68681_set_attributes(
279
int
minor,
280
const
struct
termios *t
281
282
283
MC68681_STATIC
void
mc68681_init(
int
minor);
284
285
MC68681_STATIC
int
mc68681_open(
286
int
major,
287
int
minor,
288
void
* arg
289
290
291
MC68681_STATIC
int
mc68681_close(
292
int
major,
293
int
minor,
294
void
* arg
295
296
297
MC68681_STATIC
void
mc68681_write_polled(
298
int
minor,
299
char
cChar
300
301
302
MC68681_STATIC
void
mc68681_initialize_interrupts(
int
minor);
303
304
MC68681_STATIC ssize_t mc68681_write_support_int(
305
int
minor,
306
const
char
*buf,
307
size_t
len
308
309
310
MC68681_STATIC ssize_t mc68681_write_support_polled(
311
int
minor,
312
const
char
*buf,
313
size_t
len
314
315
316
MC68681_STATIC
int
mc68681_inbyte_nonblocking_polled(
317
int
minor
318
319
320
MC68681_STATIC
unsigned
int
mc68681_build_imr(
321
int
minor,
322
int
enable_flag
323
324
325
MC68681_STATIC
void
mc68681_process(
326
int
minor
327
328
329
MC68681_STATIC
void
mc68681_enable_interrupts(
330
int
minor,
331
int
imr_mask
332
333
334
MC68681_STATIC
rtems_isr
mc68681_isr(
335
rtems_vector_number
vector
336
337
338
#ifdef __cplusplus
339
340
#endif
341
342
#endif
/* _MC68681_P_H_ */
rtems_isr
ISR_Handler rtems_isr
This type defines the return type of interrupt service routines.
Definition:
intr.h:123
rtems_vector_number
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition:
intr.h:102
_mc68681_context
Definition:
mc68681_p.h:263
