RTEMS 6.1-rc1
irqamp.h
2
11/*
12 * Copyright (C) 2021 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36/*
37 * This file is part of the RTEMS quality process and was automatically
38 * generated. If you find something that needs to be fixed or
39 * worded better please post a report or patch to an RTEMS mailing list
40 * or raise a bug report:
41 *
42 * https://www.rtems.org/bugs.html
43 *
44 * For information on updating and regenerating please refer to the How-To
45 * section in the Software Requirements Engineering chapter of the
46 * RTEMS Software Engineering manual. The manual is provided as a part of
47 * a release. For development sources please refer to the online
48 * documentation at:
49 *
50 * https://docs.rtems.org
51 */
52
53/* Generated from spec:/dev/grlib/if/irqamp-header-2 */
54
55#ifndef _GRLIB_IRQAMP_H
56#define _GRLIB_IRQAMP_H
57
58#include <stddef.h>
59#include <grlib/io.h>
60#include <grlib/irqamp-regs.h>
61
62#ifdef __cplusplus
63extern "C" {
64#endif
65
66/* Generated from spec:/dev/grlib/if/irqamp-get-timestamp */
67
80static inline irqamp_timestamp *irqamp_get_timestamp_registers(
81 irqamp *irqamp_regs
82)
83{
84 irqamp_timestamp *timestamp_regs;
85 uint32_t itstmpc;
86
87 timestamp_regs = &irqamp_regs->itstmp[ 0 ];
88 itstmpc = grlib_load_32( &timestamp_regs->itstmpc );
89
90 if ( IRQAMP_ITSTMPC_TSTAMP_GET( itstmpc ) == 0 ) {
91 return NULL;
92 }
93
94 return timestamp_regs;
95}
96
97#ifdef __cplusplus
98}
99#endif
100
101#endif /* _GRLIB_IRQAMP_H */
#define NULL
Requests a GPIO pin group configuration.
Definition: xil_types.h:54
This header file defines the IRQAMP register block interface.
This structure defines the IRQ(A)MP Timestamp register block memory map.
Definition: irqamp-regs.h:195
uint32_t itstmpc
See Interrupt timestamp n control register (ITSTMPC).
Definition: irqamp-regs.h:204
This structure defines the IRQ(A)MP register block memory map.
Definition: irqamp-regs.h:780
irqamp_timestamp itstmp[16]
See IRQ(A)MP Timestamp.
Definition: irqamp-regs.h:851
