RTEMS 6.1-rc1
This source file contains the default implementation of bsp_interrupt_vector_enable(), bsp_interrupt_vector_disable(), and bsp_interrupt_facility_initialize(). More...
#include <bsp/irq-generic.h>
rtems_status_code | bsp_interrupt_get_attributes (rtems_vector_number vector, rtems_interrupt_attributes *attributes) |
Gets the attributes of the interrupt vector. More... | |
rtems_status_code | bsp_interrupt_is_pending (rtems_vector_number vector, bool *pending) |
Checks if the interrupt is pending. More... | |
rtems_status_code | bsp_interrupt_raise (rtems_vector_number vector) |
Causes the interrupt vector. More... | |
rtems_status_code | bsp_interrupt_clear (rtems_vector_number vector) |
Clears the interrupt vector. More... | |
rtems_status_code | bsp_interrupt_vector_is_enabled (rtems_vector_number vector, bool *enabled) |
Checks if the interrupt is enabled. More... | |
rtems_status_code | bsp_interrupt_vector_enable (rtems_vector_number vector) |
Enables the interrupt vector. More... | |
rtems_status_code | bsp_interrupt_vector_disable (rtems_vector_number vector) |
Disables the interrupt vector. More... | |
void | bsp_interrupt_facility_initialize (void) |
BSP specific initialization. More... | |
