RTEMS 6.1-rc1
imx_uartreg.h
2
3/*
4 * Copyright (c) 2017 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef IMX_UARTREG_H
29#define IMX_UARTREG_H
30
31#include <bsp/utility.h>
32
33typedef struct {
34 uint32_t urxd;
35#define IMX_UART_URXD_CHARRDY BSP_BIT32(15)
36#define IMX_UART_URXD_ERR BSP_BIT32(14)
37#define IMX_UART_URXD_OVRRUN BSP_BIT32(13)
38#define IMX_UART_URXD_FRMERR BSP_BIT32(12)
39#define IMX_UART_URXD_BRK BSP_BIT32(11)
40#define IMX_UART_URXD_PRERR BSP_BIT32(10)
41#define IMX_UART_URXD_RX_DATA(val) BSP_FLD32(val, 0, 7)
42#define IMX_UART_URXD_RX_DATA_GET(reg) BSP_FLD32GET(reg, 0, 7)
43#define IMX_UART_URXD_RX_DATA_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
44 uint32_t reserved_04[15];
45 uint32_t utxd;
46#define IMX_UART_UTXD_TX_DATA(val) BSP_FLD32(val, 0, 7)
47#define IMX_UART_UTXD_TX_DATA_GET(reg) BSP_FLD32GET(reg, 0, 7)
48#define IMX_UART_UTXD_TX_DATA_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
49 uint32_t reserved_44[15];
50 uint32_t ucr1;
51#define IMX_UART_UCR1_ADEN BSP_BIT32(15)
52#define IMX_UART_UCR1_ADBR BSP_BIT32(14)
53#define IMX_UART_UCR1_TRDYEN BSP_BIT32(13)
54#define IMX_UART_UCR1_IDEN BSP_BIT32(12)
55#define IMX_UART_UCR1_ICD(val) BSP_FLD32(val, 10, 11)
56#define IMX_UART_UCR1_ICD_GET(reg) BSP_FLD32GET(reg, 10, 11)
57#define IMX_UART_UCR1_ICD_SET(reg, val) BSP_FLD32SET(reg, val, 10, 11)
58#define IMX_UART_UCR1_RRDYEN BSP_BIT32(9)
59#define IMX_UART_UCR1_RXDMAEN BSP_BIT32(8)
60#define IMX_UART_UCR1_IREN BSP_BIT32(7)
61#define IMX_UART_UCR1_TXMPTYEN BSP_BIT32(6)
62#define IMX_UART_UCR1_RTSDEN BSP_BIT32(5)
63#define IMX_UART_UCR1_SNDBRK BSP_BIT32(4)
64#define IMX_UART_UCR1_TXDMAEN BSP_BIT32(3)
65#define IMX_UART_UCR1_ATDMAEN BSP_BIT32(2)
66#define IMX_UART_UCR1_DOZE BSP_BIT32(1)
67#define IMX_UART_UCR1_UARTEN BSP_BIT32(0)
68 uint32_t ucr2;
69#define IMX_UART_UCR2_ESCI BSP_BIT32(15)
70#define IMX_UART_UCR2_IRTS BSP_BIT32(14)
71#define IMX_UART_UCR2_CTSC BSP_BIT32(13)
72#define IMX_UART_UCR2_CTS BSP_BIT32(12)
73#define IMX_UART_UCR2_ESCEN BSP_BIT32(11)
74#define IMX_UART_UCR2_RTEC(val) BSP_FLD32(val, 9, 10)
75#define IMX_UART_UCR2_RTEC_GET(reg) BSP_FLD32GET(reg, 9, 10)
76#define IMX_UART_UCR2_RTEC_SET(reg, val) BSP_FLD32SET(reg, val, 9, 10)
77#define IMX_UART_UCR2_PREN BSP_BIT32(8)
78#define IMX_UART_UCR2_PROE BSP_BIT32(7)
79#define IMX_UART_UCR2_STPB BSP_BIT32(6)
80#define IMX_UART_UCR2_WS BSP_BIT32(5)
81#define IMX_UART_UCR2_RTSEN BSP_BIT32(4)
82#define IMX_UART_UCR2_ATEN BSP_BIT32(3)
83#define IMX_UART_UCR2_TXEN BSP_BIT32(2)
84#define IMX_UART_UCR2_RXEN BSP_BIT32(1)
85#define IMX_UART_UCR2_SRST BSP_BIT32(0)
86 uint32_t ucr3;
87#define IMX_UART_UCR3_DPEC(val) BSP_FLD32(val, 14, 15)
88#define IMX_UART_UCR3_DPEC_GET(reg) BSP_FLD32GET(reg, 14, 15)
89#define IMX_UART_UCR3_DPEC_SET(reg, val) BSP_FLD32SET(reg, val, 14, 15)
90#define IMX_UART_UCR3_DTREN BSP_BIT32(13)
91#define IMX_UART_UCR3_PARERREN BSP_BIT32(12)
92#define IMX_UART_UCR3_FRAERREN BSP_BIT32(11)
93#define IMX_UART_UCR3_DSR BSP_BIT32(10)
94#define IMX_UART_UCR3_DCD BSP_BIT32(9)
95#define IMX_UART_UCR3_RI BSP_BIT32(8)
96#define IMX_UART_UCR3_ADNIMP BSP_BIT32(7)
97#define IMX_UART_UCR3_RXDSEN BSP_BIT32(6)
98#define IMX_UART_UCR3_AIRINTEN BSP_BIT32(5)
99#define IMX_UART_UCR3_AWAKEN BSP_BIT32(4)
100#define IMX_UART_UCR3_DTRDEN BSP_BIT32(3)
101#define IMX_UART_UCR3_RXDMUXSEL BSP_BIT32(2)
102#define IMX_UART_UCR3_INVT BSP_BIT32(1)
103#define IMX_UART_UCR3_ACIEN BSP_BIT32(0)
104 uint32_t ucr4;
105#define IMX_UART_UCR4_CTSTL(val) BSP_FLD32(val, 10, 15)
106#define IMX_UART_UCR4_CTSTL_GET(reg) BSP_FLD32GET(reg, 10, 15)
107#define IMX_UART_UCR4_CTSTL_SET(reg, val) BSP_FLD32SET(reg, val, 10, 15)
108#define IMX_UART_UCR4_INVR BSP_BIT32(9)
109#define IMX_UART_UCR4_ENIRI BSP_BIT32(8)
110#define IMX_UART_UCR4_WKEN BSP_BIT32(7)
111#define IMX_UART_UCR4_IDDMAEN BSP_BIT32(6)
112#define IMX_UART_UCR4_IRSC BSP_BIT32(5)
113#define IMX_UART_UCR4_LPBYP BSP_BIT32(4)
114#define IMX_UART_UCR4_TCEN BSP_BIT32(3)
115#define IMX_UART_UCR4_BKEN BSP_BIT32(2)
116#define IMX_UART_UCR4_OREN BSP_BIT32(1)
117#define IMX_UART_UCR4_DREN BSP_BIT32(0)
118 uint32_t ufcr;
119#define IMX_UART_UFCR_TXTL(val) BSP_FLD32(val, 10, 15)
120#define IMX_UART_UFCR_TXTL_GET(reg) BSP_FLD32GET(reg, 10, 15)
121#define IMX_UART_UFCR_TXTL_SET(reg, val) BSP_FLD32SET(reg, val, 10, 15)
122#define IMX_UART_UFCR_RFDIV(val) BSP_FLD32(val, 7, 9)
123#define IMX_UART_UFCR_RFDIV_GET(reg) BSP_FLD32GET(reg, 7, 9)
124#define IMX_UART_UFCR_RFDIV_SET(reg, val) BSP_FLD32SET(reg, val, 7, 9)
125#define IMX_UART_UFCR_DCEDTE BSP_BIT32(6)
126#define IMX_UART_UFCR_RXTL(val) BSP_FLD32(val, 0, 5)
127#define IMX_UART_UFCR_RXTL_GET(reg) BSP_FLD32GET(reg, 0, 5)
128#define IMX_UART_UFCR_RXTL_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
129 uint32_t usr1;
130#define IMX_UART_USR1_PARITYERR BSP_BIT32(15)
131#define IMX_UART_USR1_RTSS BSP_BIT32(14)
132#define IMX_UART_USR1_TRDY BSP_BIT32(13)
133#define IMX_UART_USR1_RTSD BSP_BIT32(12)
134#define IMX_UART_USR1_ESCF BSP_BIT32(11)
135#define IMX_UART_USR1_FRAMERR BSP_BIT32(10)
136#define IMX_UART_USR1_RRDY BSP_BIT32(9)
137#define IMX_UART_USR1_AGTIM BSP_BIT32(8)
138#define IMX_UART_USR1_DTRD BSP_BIT32(7)
139#define IMX_UART_USR1_RXDS BSP_BIT32(6)
140#define IMX_UART_USR1_AIRINT BSP_BIT32(5)
141#define IMX_UART_USR1_AWAKE BSP_BIT32(4)
142#define IMX_UART_USR1_SAD BSP_BIT32(3)
143 uint32_t usr2;
144#define IMX_UART_USR2_ADET BSP_BIT32(15)
145#define IMX_UART_USR2_TXFE BSP_BIT32(14)
146#define IMX_UART_USR2_DTRF BSP_BIT32(13)
147#define IMX_UART_USR2_IDLE BSP_BIT32(12)
148#define IMX_UART_USR2_ACST BSP_BIT32(11)
149#define IMX_UART_USR2_RIDELT BSP_BIT32(10)
150#define IMX_UART_USR2_RIIN BSP_BIT32(9)
151#define IMX_UART_USR2_IRINT BSP_BIT32(8)
152#define IMX_UART_USR2_WAKE BSP_BIT32(7)
153#define IMX_UART_USR2_DCDDELT BSP_BIT32(6)
154#define IMX_UART_USR2_DCDIN BSP_BIT32(5)
155#define IMX_UART_USR2_RTSF BSP_BIT32(4)
156#define IMX_UART_USR2_TXDC BSP_BIT32(3)
157#define IMX_UART_USR2_BRCD BSP_BIT32(2)
158#define IMX_UART_USR2_ORE BSP_BIT32(1)
159#define IMX_UART_USR2_RDR BSP_BIT32(0)
160 uint32_t uesc;
161 uint32_t utim;
162 uint32_t ubir;
163 uint32_t ubmr;
164 uint32_t ubrc;
165 uint32_t onems;
166 uint32_t uts;
167#define IMX_UART_UTS_FRCPERR BSP_BIT32(13)
168#define IMX_UART_UTS_LOOP BSP_BIT32(12)
169#define IMX_UART_UTS_DBGEN BSP_BIT32(11)
170#define IMX_UART_UTS_LOOPIR BSP_BIT32(10)
171#define IMX_UART_UTS_RXDBG BSP_BIT32(9)
172#define IMX_UART_UTS_TXEMPTY BSP_BIT32(6)
173#define IMX_UART_UTS_RXEMPTY BSP_BIT32(5)
174#define IMX_UART_UTS_TXFULL BSP_BIT32(4)
175#define IMX_UART_UTS_RXFULL BSP_BIT32(3)
176#define IMX_UART_UTS_SOFTRST BSP_BIT32(0)
177 uint32_t umcr;
178#define IMX_UART_UMCR_SLADDR(val) BSP_FLD32(val, 8, 15)
179#define IMX_UART_UMCR_SLADDR_GET(reg) BSP_FLD32GET(reg, 8, 15)
180#define IMX_UART_UMCR_SLADDR_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
181#define IMX_UART_UMCR_SADEN BSP_BIT32(3)
182#define IMX_UART_UMCR_TXB8 BSP_BIT32(2)
183#define IMX_UART_UMCR_SLAM BSP_BIT32(1)
184#define IMX_UART_UMCR_MDEN BSP_BIT32(0)
185} imx_uart;
186
187#endif /* IMX_UARTREG_H */
This header file provides utility macros for BSPs.
Definition: imx_uartreg.h:33
