RTEMS 6.1-rc1
gtintrreg.h
1/* $NetBSD: gtintrreg.h,v 1.3 2005/02/27 00:27:21 perry Exp $ */
2
3/*
4 * Copyright (c) 2002 Allegro Networks, Inc., Wasabi Systems, Inc.
5 * All rights reserved.
6 *
7 * Redistribution and use in source and binary forms, with or without
8 * modification, are permitted provided that the following conditions
9 * are met:
10 * 1. Redistributions of source code must retain the above copyright
11 * notice, this list of conditions and the following disclaimer.
12 * 2. Redistributions in binary form must reproduce the above copyright
13 * notice, this list of conditions and the following disclaimer in the
14 * documentation and/or other materials provided with the distribution.
15 * 3. All advertising materials mentioning features or use of this software
16 * must display the following acknowledgement:
17 * This product includes software developed for the NetBSD Project by
18 * Allegro Networks, Inc., and Wasabi Systems, Inc.
19 * 4. The name of Allegro Networks, Inc. may not be used to endorse
20 * or promote products derived from this software without specific prior
21 * written permission.
22 * 5. The name of Wasabi Systems, Inc. may not be used to endorse
23 * or promote products derived from this software without specific prior
24 * written permission.
25 *
26 * THIS SOFTWARE IS PROVIDED BY ALLEGRO NETWORKS, INC. AND
27 * WASABI SYSTEMS, INC. ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES,
28 * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
29 * AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
30 * IN NO EVENT SHALL EITHER ALLEGRO NETWORKS, INC. OR WASABI SYSTEMS, INC.
31 * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37 * POSSIBILITY OF SUCH DAMAGE.
38 */
39
40/*
41 * gt64260intr.h: defines for GT-64260 system controller interrupts
42 *
43 * creation Sun Jan 7 18:05:59 PST 2001 cliff
44 *
45 * NOTE:
46 * Galileo GT-64260 manual bit defines assume Little Endian
47 * ordering of bits within bytes, i.e.
48 * bit #0 --> 0x01
49 * vs. Motorola Big Endian bit numbering where
50 * bit #0 --> 0x80
51 * Consequently we define bits in Little Endian format and plan
52 * to swizzle bytes during programmed I/O by using lwbrx/swbrx
53 * to load/store GT-64260 registers.
54 */
55
56
57#ifndef _DISCOVERY_GT64260INTR_H
58#define _DISCOVERY_GT64260INTR_H
59
60#define BIT(n) (1<<(n))
61
62
63/*
64 * GT-64260 Interrupt Controller Register Map
65 */
66#define ICR_260_MIC_LO 0xc18 /* main interrupt cause low */
67#define ICR_260_MIC_HI 0xc68 /* main interrupt cause high */
68#define ICR_260_CIM_LO 0xc1c /* CPU interrupt mask low */
69#define ICR_260_CIM_HI 0xc6c /* CPU interrupt mask high */
70#define ICR_260_CSC 0xc70 /* CPU select cause */
71#define ICR_260_P0IM_LO 0xc24 /* PCI_0 interrupt mask low */
72#define ICR_260_P0IM_HI 0xc64 /* PCI_0 interrupt mask high */
73#define ICR_260_P0SC 0xc74 /* PCI_0 select cause */
74#define ICR_260_P1IM_LO 0xca4 /* PCI_1 interrupt mask low */
75#define ICR_260_P1IM_HI 0xce4 /* PCI_1 interrupt mask high */
76#define ICR_260_P1SC 0xcf4 /* PCI_1 select cause */
77#define ICR_260_CI0M 0xe60 /* CPU int[0] mask */
78#define ICR_260_CI1M 0xe64 /* CPU int[1] mask */
79#define ICR_260_CI2M 0xe68 /* CPU int[2] mask */
80#define ICR_260_CI3M 0xe6c /* CPU int[3] mask */
81
82/*
83 * MV64360 Interrupt Controller Register Map
84 */
85#define ICR_360_MIC_LO 0x004 /* main interrupt cause low */
86#define ICR_360_MIC_HI 0x00c /* main interrupt cause high */
87#define ICR_360_C0IM_LO 0x014 /* CPU 0 interrupt mask low */
88#define ICR_360_C0IM_HI 0x01c /* CPU 0 interrupt mask high */
89#define ICR_360_C0SC 0x024 /* CPU 0 select cause */
90#define ICR_360_C1IM_LO 0x034 /* CPU 1 interrupt mask low */
91#define ICR_360_C1IM_HI 0x03c /* CPU 1 interrupt mask high */
92#define ICR_360_C1SC 0x044 /* CPU 1 select cause */
93#define ICR_360_I0M_LO 0x014 /* Int 0 mask low */
94#define ICR_360_I0M_HI 0x01c /* Int 0 mask high */
95#define ICR_360_I0SC 0x024 /* Int 0 select cause */
96#define ICR_360_I1M_LO 0x034 /* Int 1 mask low */
97#define ICR_360_I1M_HI 0x03c /* Int 1 mask high */
98#define ICR_360_C1SC 0x044 /* Int 1 select cause */
99
100
101/*
102 * IRQs:
103 * we define IRQs based on bit number in the
104 * ICU_LEN dimensioned hardware portion of the imask_t bit vector
105 * which consists of 64 bits of Main Cause and Mask register pairs
106 * (ICR_MIC_LO, ICR_MIC_HI and ICR_CIM_LO, ICR_CIM_HI)
107 * as well as 32 bits in GPP registers (see intr.h):
108 *
109 * IRQs:
110 * 31.............................0 63.............................32
111 * | | |
112 * imask_t index: | | |
113 * | | | |
114 * ^--------- IM_PIC_LO ----------^ ^------ IM_PIC_HI ------------^
115 * | | |
116 * Bitmasks: | | |
117 * | | | |
118 * ^--------- IML_* --------------^ ^------ IMH_* ----------------^
119 * | | |
120 * Registers: | | |
121 * | | | |
122 * ^--------- ICR_MIC_LO ---------^ ^------ ICR_MIC_HI -----------^
123 * ^--------- ICR_CIM_LO ---------^ ^------ ICR_CIM_HI -----------^
124 *
125 * IRQs:
126 * 95............................64 127............................96
127 * | | |
128 * imask_t index: | | |
129 * | | | |
130 * ^-------- IMASK_GPP ----------^ ^----- IMASK_SOFTINT --------^
131 * | | |
132 * Bitmasks: | | |
133 * | | | |
134 * ^--------- GPP_* --------------^ ^------ SIBIT(irq) -----------^
135 * | | |
136 * Registers: | | |
137 * | | | |
138 * ^--- GT_GPP_Interrupt_Cause ---^ ^------- (none) -----------^
139 * ^--- GT_GPP_Interrupt_Mask ---^
140 *
141 *
142 * Note that GPP interrupts are summarized in the Main Cause Register.
143 *
144 * Some IRQs are "resvered" undefined due to gaps in HW register utilization.
145 */
146#define IRQ_DEV 1 /* device interface interrupt */
147#define IRQ_DMA 2 /* DMA addres error interrupt */
148#define IRQ_CPU 3 /* CPU interface interrupt */
149#define IRQ_IDMA0_1 4 /* IDMA ch. 0..1 complete interrupt */
150#define IRQ_IDMA2_3 5 /* IDMA ch. 2..3 complete interrupt */
151#define IRQ_IDMA4_5 6 /* IDMA ch. 4..5 complete interrupt */
152#define IRQ_IDMA6_7 7 /* IDMA ch. 6..7 complete interrupt */
153#define IRQ_TIME0_1 8 /* Timer 0..1 interrupt */
154#define IRQ_TIME2_3 9 /* Timer 2..3 interrupt */
155#define IRQ_TIME4_5 10 /* Timer 4..5 interrupt */
156#define IRQ_TIME6_7 11 /* Timer 6..7 interrupt */
157#define IRQ_PCI0_0 12 /* PCI 0 interrupt 0 summary */
158#define IRQ_PCI0_1 13 /* PCI 0 interrupt 1 summary */
159#define IRQ_PCI0_2 14 /* PCI 0 interrupt 2 summary */
160#define IRQ_PCI0_3 15 /* PCI 0 interrupt 3 summary */
161#define IRQ_PCI1_0 16 /* PCI 1 interrupt 0 summary */
162#define IRQ_ECC 17 /* ECC error interrupt */
163#define IRQ_PCI1_1 18 /* PCI 1 interrupt 1 summary */
164#define IRQ_PCI1_2 19 /* PCI 1 interrupt 2 summary */
165#define IRQ_PCI1_3 20 /* PCI 1 interrupt 3 summary */
166#define IRQ_PCI0OUT_LO 21 /* PCI 0 outbound interrupt summary */
167#define IRQ_PCI0OUT_HI 22 /* PCI 0 outbound interrupt summary */
168#define IRQ_PCI1OUT_LO 23 /* PCI 1 outbound interrupt summary */
169#define IRQ_PCI1OUT_HI 24 /* PCI 1 outbound interrupt summary */
170#define IRQ_PCI0IN_LO 26 /* PCI 0 inbound interrupt summary */
171#define IRQ_PCI0IN_HI 27 /* PCI 0 inbound interrupt summary */
172#define IRQ_PCI1IN_LO 28 /* PCI 1 inbound interrupt summary */
173#define IRQ_PCI1IN_HI 29 /* PCI 1 inbound interrupt summary */
174#define IRQ_ETH0 (32+0) /* Ethernet controller 0 interrupt */
175#define IRQ_ETH1 (32+1) /* Ethernet controller 1 interrupt */
176#define IRQ_ETH2 (32+2) /* Ethernet controller 2 interrupt */
177#define IRQ_SDMA (32+4) /* SDMA interrupt */
178#define IRQ_I2C (32+5) /* I2C interrupt */
179#define IRQ_BRG (32+7) /* Baud Rate Generator interrupt */
180#define IRQ_MPSC0 (32+8) /* MPSC 0 interrupt */
181#define IRQ_MPSC1 (32+10) /* MPSC 1 interrupt */
182#define IRQ_COMM (32+11) /* Comm unit interrupt */
183#define IRQ_GPP7_0 (32+24) /* GPP[7..0] interrupt */
184#define IRQ_GPP15_8 (32+25) /* GPP[15..8] interrupt */
185#define IRQ_GPP23_16 (32+26) /* GPP[23..16] interrupt */
186#define IRQ_GPP31_24 (32+27) /* GPP[31..24] interrupt */
187
188/*
189 * low word interrupt mask register bits
190 */
191#define IML_SUM BIT(0)
192#define IML_DEV BIT(IRQ_DEV)
193#define IML_DMA BIT(IRQ_DMA)
194#define IML_CPU BIT(IRQ_CPU)
195#define IML_IDMA0_1 BIT(IRQ_IDMA0_1)
196#define IML_IDMA2_3 BIT(IRQ_IDMA2_3)
197#define IML_IDMA4_5 BIT(IRQ_IDMA4_5)
198#define IML_IDMA6_7 BIT(IRQ_IDMA6_7)
199#define IML_TIME0_1 BIT(IRQ_TIME0_1)
200#define IML_TIME2_3 BIT(IRQ_TIME2_3)
201#define IML_TIME4_5 BIT(IRQ_TIME4_5)
202#define IML_TIME6_7 BIT(IRQ_TIME6_7)
203#define IML_PCI0_0 BIT(IRQ_PCI0_0)
204#define IML_PCI0_1 BIT(IRQ_PCI0_1)
205#define IML_PCI0_2 BIT(IRQ_PCI0_2)
206#define IML_PCI0_3 BIT(IRQ_PCI0_3)
207#define IML_PCI1_0 BIT(IRQ_PCI1_0)
208#define IML_ECC BIT(IRQ_ECC)
209#define IML_PCI1_1 BIT(IRQ_PCI1_1)
210#define IML_PCI1_2 BIT(IRQ_PCI1_2)
211#define IML_PCI1_3 BIT(IRQ_PCI1_3)
212#define IML_PCI0OUT_LO BIT(IRQ_PCI0OUT_LO)
213#define IML_PCI0OUT_HI BIT(IRQ_PCI0OUT_HI)
214#define IML_PCI1OUT_LO BIT(IRQ_PCI1OUT_LO)
215#define IML_PCI1OUT_HI BIT(IRQ_PCI1OUT_HI)
216#define IML_PCI0IN_LO BIT(IRQ_PCI0IN_LO)
217#define IML_PCI0IN_HI BIT(IRQ_PCI0IN_HI)
218#define IML_PCI1IN_LO BIT(IRQ_PCI1IN_LO)
219#define IML_PCI1IN_HI BIT(IRQ_PCI1IN_HI)
220#define IML_RES (BIT(25)|BIT(30)|BIT(31))
221
222/*
223 * high word interrupt mask register bits
224 */
225#define IMH_ETH0 BIT(IRQ_ETH0-32)
226#define IMH_ETH1 BIT(IRQ_ETH1-32)
227#define IMH_ETH2 BIT(IRQ_ETH2-32)
228#define IMH_SDMA BIT(IRQ_SDMA-32)
229#define IMH_I2C BIT(IRQ_I2C-32)
230#define IMH_BRG BIT(IRQ_BRG-32)
231#define IMH_MPSC0 BIT(IRQ_MPSC0-32)
232#define IMH_MPSC1 BIT(IRQ_MPSC1-32)
233#define IMH_COMM BIT(IRQ_COMM-32)
234#define IMH_GPP7_0 BIT(IRQ_GPP7_0-32)
235#define IMH_GPP15_8 BIT(IRQ_GPP15_8-32)
236#define IMH_GPP23_16 BIT(IRQ_GPP23_16-32)
237#define IMH_GPP31_24 BIT(IRQ_GPP31_24-32)
238#define IMH_GPP_SUM (IMH_GPP7_0|IMH_GPP15_8|IMH_GPP23_16|IMH_GPP31_24)
239#define IMH_RES (BIT(3) |BIT(6) |BIT(9) |BIT(12)|BIT(13)|BIT(14) \
240 |BIT(15)|BIT(16)|BIT(17)|BIT(18)|BIT(19)|BIT(20) \
241 |BIT(21)|BIT(22)|BIT(23)|BIT(28)|BIT(29)|BIT(30) \
242 |BIT(31))
243
244/*
245 * ICR_CSC "Select Cause" register bits
246 */
247#define CSC_SEL BIT(30) /* HI/LO select */
248#define CSC_STAT BIT(31) /* ? "irq active" : "irq none" */
249#define CSC_CAUSE ~(CSC_SEL|CSC_STAT)
250
251
252/*
253 * CPU Int[n] Mask bit(s)
254 */
255#define CPUINT_SEL 0x80000000 /* HI/LO select */
256
257#endif /* _DISCOVERY_GT64260INTR_H */
