The pin function ID is a tuple of <muxRegister muxMode inputRegister inputDaisy configRegister>
enum | _iomuxc_gpr_mode {
kIOMUXC_GPR_GlobalInterruptRequest = IOMUXC_GPR_GPR1_GINT_MASK
, kIOMUXC_GPR_ENET1RefClkMode = IOMUXC_GPR_GPR1_ENET_TX_CLK_SEL_MASK
, kIOMUXC_GPR_ENET1TxClkOutputDir = IOMUXC_GPR_GPR1_ENET_REF_CLK_DIR_MASK
, kIOMUXC_GPR_SAI1MClkOutputDir = IOMUXC_GPR_GPR1_SAI1_MCLK_DIR_MASK
kIOMUXC_GPR_SAI2MClkOutputDir = IOMUXC_GPR_GPR1_SAI2_MCLK_DIR_MASK
, kIOMUXC_GPR_SAI3MClkOutputDir = IOMUXC_GPR_GPR1_SAI3_MCLK_DIR_MASK
, kIOMUXC_GPR_ExcMonitorSlavErrResponse = IOMUXC_GPR_GPR1_EXC_MON_MASK
, kIOMUXC_GPR_AHBClockEnable = (int)IOMUXC_GPR_GPR1_CM7_FORCE_HCLK_EN_MASK
enum | _iomuxc_gpr_saimclk {
kIOMUXC_GPR_SAI1MClk1Sel = IOMUXC_GPR_GPR1_SAI1_MCLK1_SEL_SHIFT
, kIOMUXC_GPR_SAI1MClk2Sel = IOMUXC_GPR_GPR1_SAI1_MCLK2_SEL_SHIFT
, kIOMUXC_GPR_SAI1MClk3Sel = IOMUXC_GPR_GPR1_SAI1_MCLK3_SEL_SHIFT
, kIOMUXC_GPR_SAI2MClk3Sel = IOMUXC_GPR_GPR1_SAI2_MCLK3_SEL_SHIFT
kIOMUXC_GPR_SAI3MClk3Sel = IOMUXC_GPR_GPR1_SAI3_MCLK3_SEL_SHIFT
, kIOMUXC_GPR_SAI1MClk1Sel = IOMUXC_GPR_GPR0_SAI1_MCLK1_SEL_SHIFT
, kIOMUXC_GPR_SAI1MClk2Sel = IOMUXC_GPR_GPR0_SAI1_MCLK2_SEL_SHIFT
, kIOMUXC_GPR_SAI1MClk3Sel = IOMUXC_GPR_GPR0_SAI1_MCLK3_SEL_SHIFT
kIOMUXC_GPR_SAI2MClk3Sel = IOMUXC_GPR_GPR1_SAI2_MCLK3_SEL_SHIFT + 8U
, kIOMUXC_GPR_SAI3MClk3Sel = IOMUXC_GPR_GPR2_SAI3_MCLK3_SEL_SHIFT + 10U
enum | _iomuxc_mqs_pwm_oversample_rate { kIOMUXC_MqsPwmOverSampleRate32 = 0
, kIOMUXC_MqsPwmOverSampleRate64 = 1
, kIOMUXC_MqsPwmOverSampleRate32 = 0
typedef enum _iomuxc_gpr_mode | iomuxc_gpr_mode_t |
typedef enum _iomuxc_gpr_saimclk | iomuxc_gpr_saimclk_t |
typedef enum _iomuxc_mqs_pwm_oversample_rate | iomuxc_mqs_pwm_oversample_rate_t |
#define | IOMUXC_GPIO_EMC_00_SEMC_DA00 0x401F8014U, 0x0U, 0, 0, 0x401F8204U |
#define | IOMUXC_GPIO_EMC_00_FLEXPWM4_PWM0_A 0x401F8014U, 0x1U, 0x401F8494U, 0x0U, 0x401F8204U |
#define | IOMUXC_GPIO_EMC_00_LPSPI2_SCK 0x401F8014U, 0x2U, 0x401F8500U, 0x1U, 0x401F8204U |
#define | IOMUXC_GPIO_EMC_00_XBAR1_IN02 0x401F8014U, 0x3U, 0x401F860CU, 0x0U, 0x401F8204U |
#define | IOMUXC_GPIO_EMC_00_FLEXIO1_D00 0x401F8014U, 0x4U, 0, 0, 0x401F8204U |
#define | IOMUXC_GPIO_EMC_00_GPIO4_IO00 0x401F8014U, 0x5U, 0, 0, 0x401F8204U |
#define | IOMUXC_GPIO_EMC_01_SEMC_DA01 0x401F8018U, 0x0U, 0, 0, 0x401F8208U |
#define | IOMUXC_GPIO_EMC_01_FLEXPWM4_PWM0_B 0x401F8018U, 0x1U, 0, 0, 0x401F8208U |
#define | IOMUXC_GPIO_EMC_01_LPSPI2_PCS0 0x401F8018U, 0x2U, 0x401F84FCU, 0x1U, 0x401F8208U |
#define | IOMUXC_GPIO_EMC_01_XBAR1_IN03 0x401F8018U, 0x3U, 0x401F8610U, 0x0U, 0x401F8208U |
#define | IOMUXC_GPIO_EMC_01_FLEXIO1_D01 0x401F8018U, 0x4U, 0, 0, 0x401F8208U |
#define | IOMUXC_GPIO_EMC_01_GPIO4_IO01 0x401F8018U, 0x5U, 0, 0, 0x401F8208U |
#define | IOMUXC_GPIO_EMC_02_SEMC_DA02 0x401F801CU, 0x0U, 0, 0, 0x401F820CU |
#define | IOMUXC_GPIO_EMC_02_FLEXPWM4_PWM1_A 0x401F801CU, 0x1U, 0x401F8498U, 0x0U, 0x401F820CU |
#define | IOMUXC_GPIO_EMC_02_LPSPI2_SDO 0x401F801CU, 0x2U, 0x401F8508U, 0x1U, 0x401F820CU |
#define | IOMUXC_GPIO_EMC_02_XBAR1_INOUT04 0x401F801CU, 0x3U, 0x401F8614U, 0x0U, 0x401F820CU |
#define | IOMUXC_GPIO_EMC_02_FLEXIO1_D02 0x401F801CU, 0x4U, 0, 0, 0x401F820CU |
#define | IOMUXC_GPIO_EMC_02_GPIO4_IO02 0x401F801CU, 0x5U, 0, 0, 0x401F820CU |
#define | IOMUXC_GPIO_EMC_03_SEMC_DA03 0x401F8020U, 0x0U, 0, 0, 0x401F8210U |
#define | IOMUXC_GPIO_EMC_03_FLEXPWM4_PWM1_B 0x401F8020U, 0x1U, 0, 0, 0x401F8210U |
#define | IOMUXC_GPIO_EMC_03_LPSPI2_SDI 0x401F8020U, 0x2U, 0x401F8504U, 0x1U, 0x401F8210U |
#define | IOMUXC_GPIO_EMC_03_XBAR1_INOUT05 0x401F8020U, 0x3U, 0x401F8618U, 0x0U, 0x401F8210U |
#define | IOMUXC_GPIO_EMC_03_FLEXIO1_D03 0x401F8020U, 0x4U, 0, 0, 0x401F8210U |
#define | IOMUXC_GPIO_EMC_03_GPIO4_IO03 0x401F8020U, 0x5U, 0, 0, 0x401F8210U |
#define | IOMUXC_GPIO_EMC_04_SEMC_DA04 0x401F8024U, 0x0U, 0, 0, 0x401F8214U |
#define | IOMUXC_GPIO_EMC_04_FLEXPWM4_PWM2_A 0x401F8024U, 0x1U, 0x401F849CU, 0x0U, 0x401F8214U |
#define | IOMUXC_GPIO_EMC_04_SAI2_TX_DATA 0x401F8024U, 0x2U, 0, 0, 0x401F8214U |
#define | IOMUXC_GPIO_EMC_04_XBAR1_INOUT06 0x401F8024U, 0x3U, 0x401F861CU, 0x0U, 0x401F8214U |
#define | IOMUXC_GPIO_EMC_04_FLEXIO1_D04 0x401F8024U, 0x4U, 0, 0, 0x401F8214U |
#define | IOMUXC_GPIO_EMC_04_GPIO4_IO04 0x401F8024U, 0x5U, 0, 0, 0x401F8214U |
#define | IOMUXC_GPIO_EMC_05_SEMC_DA05 0x401F8028U, 0x0U, 0, 0, 0x401F8218U |
#define | IOMUXC_GPIO_EMC_05_FLEXPWM4_PWM2_B 0x401F8028U, 0x1U, 0, 0, 0x401F8218U |
#define | IOMUXC_GPIO_EMC_05_SAI2_TX_SYNC 0x401F8028U, 0x2U, 0x401F85C4U, 0x0U, 0x401F8218U |
#define | IOMUXC_GPIO_EMC_05_XBAR1_INOUT07 0x401F8028U, 0x3U, 0x401F8620U, 0x0U, 0x401F8218U |
#define | IOMUXC_GPIO_EMC_05_FLEXIO1_D05 0x401F8028U, 0x4U, 0, 0, 0x401F8218U |
#define | IOMUXC_GPIO_EMC_05_GPIO4_IO05 0x401F8028U, 0x5U, 0, 0, 0x401F8218U |
#define | IOMUXC_GPIO_EMC_06_SEMC_DA06 0x401F802CU, 0x0U, 0, 0, 0x401F821CU |
#define | IOMUXC_GPIO_EMC_06_FLEXPWM2_PWM0_A 0x401F802CU, 0x1U, 0x401F8478U, 0x0U, 0x401F821CU |
#define | IOMUXC_GPIO_EMC_06_SAI2_TX_BCLK 0x401F802CU, 0x2U, 0x401F85C0U, 0x0U, 0x401F821CU |
#define | IOMUXC_GPIO_EMC_06_XBAR1_INOUT08 0x401F802CU, 0x3U, 0x401F8624U, 0x0U, 0x401F821CU |
#define | IOMUXC_GPIO_EMC_06_FLEXIO1_D06 0x401F802CU, 0x4U, 0, 0, 0x401F821CU |
#define | IOMUXC_GPIO_EMC_06_GPIO4_IO06 0x401F802CU, 0x5U, 0, 0, 0x401F821CU |
#define | IOMUXC_GPIO_EMC_07_SEMC_DA07 0x401F8030U, 0x0U, 0, 0, 0x401F8220U |
#define | IOMUXC_GPIO_EMC_07_FLEXPWM2_PWM0_B 0x401F8030U, 0x1U, 0x401F8488U, 0x0U, 0x401F8220U |
#define | IOMUXC_GPIO_EMC_07_SAI2_MCLK 0x401F8030U, 0x2U, 0x401F85B0U, 0x0U, 0x401F8220U |
#define | IOMUXC_GPIO_EMC_07_XBAR1_INOUT09 0x401F8030U, 0x3U, 0x401F8628U, 0x0U, 0x401F8220U |
#define | IOMUXC_GPIO_EMC_07_FLEXIO1_D07 0x401F8030U, 0x4U, 0, 0, 0x401F8220U |
#define | IOMUXC_GPIO_EMC_07_GPIO4_IO07 0x401F8030U, 0x5U, 0, 0, 0x401F8220U |
#define | IOMUXC_GPIO_EMC_08_SEMC_DM00 0x401F8034U, 0x0U, 0, 0, 0x401F8224U |
#define | IOMUXC_GPIO_EMC_08_FLEXPWM2_PWM1_A 0x401F8034U, 0x1U, 0x401F847CU, 0x0U, 0x401F8224U |
#define | IOMUXC_GPIO_EMC_08_SAI2_RX_DATA 0x401F8034U, 0x2U, 0x401F85B8U, 0x0U, 0x401F8224U |
#define | IOMUXC_GPIO_EMC_08_XBAR1_INOUT17 0x401F8034U, 0x3U, 0x401F862CU, 0x0U, 0x401F8224U |
#define | IOMUXC_GPIO_EMC_08_FLEXIO1_D08 0x401F8034U, 0x4U, 0, 0, 0x401F8224U |
#define | IOMUXC_GPIO_EMC_08_GPIO4_IO08 0x401F8034U, 0x5U, 0, 0, 0x401F8224U |
#define | IOMUXC_GPIO_EMC_09_SEMC_ADDR00 0x401F8038U, 0x0U, 0, 0, 0x401F8228U |
#define | IOMUXC_GPIO_EMC_09_FLEXPWM2_PWM1_B 0x401F8038U, 0x1U, 0x401F848CU, 0x0U, 0x401F8228U |
#define | IOMUXC_GPIO_EMC_09_SAI2_RX_SYNC 0x401F8038U, 0x2U, 0x401F85BCU, 0x0U, 0x401F8228U |
#define | IOMUXC_GPIO_EMC_09_FLEXCAN2_TX 0x401F8038U, 0x3U, 0, 0, 0x401F8228U |
#define | IOMUXC_GPIO_EMC_09_FLEXIO1_D09 0x401F8038U, 0x4U, 0, 0, 0x401F8228U |
#define | IOMUXC_GPIO_EMC_09_GPIO4_IO09 0x401F8038U, 0x5U, 0, 0, 0x401F8228U |
#define | IOMUXC_GPIO_EMC_10_SEMC_ADDR01 0x401F803CU, 0x0U, 0, 0, 0x401F822CU |
#define | IOMUXC_GPIO_EMC_10_FLEXPWM2_PWM2_A 0x401F803CU, 0x1U, 0x401F8480U, 0x0U, 0x401F822CU |
#define | IOMUXC_GPIO_EMC_10_SAI2_RX_BCLK 0x401F803CU, 0x2U, 0x401F85B4U, 0x0U, 0x401F822CU |
#define | IOMUXC_GPIO_EMC_10_FLEXCAN2_RX 0x401F803CU, 0x3U, 0x401F8450U, 0x0U, 0x401F822CU |
#define | IOMUXC_GPIO_EMC_10_FLEXIO1_D10 0x401F803CU, 0x4U, 0, 0, 0x401F822CU |
#define | IOMUXC_GPIO_EMC_10_GPIO4_IO10 0x401F803CU, 0x5U, 0, 0, 0x401F822CU |
#define | IOMUXC_GPIO_EMC_11_SEMC_ADDR02 0x401F8040U, 0x0U, 0, 0, 0x401F8230U |
#define | IOMUXC_GPIO_EMC_11_FLEXPWM2_PWM2_B 0x401F8040U, 0x1U, 0x401F8490U, 0x0U, 0x401F8230U |
#define | IOMUXC_GPIO_EMC_11_LPI2C4_SDA 0x401F8040U, 0x2U, 0x401F84E8U, 0x0U, 0x401F8230U |
#define | IOMUXC_GPIO_EMC_11_USDHC2_RESET_B 0x401F8040U, 0x3U, 0, 0, 0x401F8230U |
#define | IOMUXC_GPIO_EMC_11_FLEXIO1_D11 0x401F8040U, 0x4U, 0, 0, 0x401F8230U |
#define | IOMUXC_GPIO_EMC_11_GPIO4_IO11 0x401F8040U, 0x5U, 0, 0, 0x401F8230U |
#define | IOMUXC_GPIO_EMC_12_SEMC_ADDR03 0x401F8044U, 0x0U, 0, 0, 0x401F8234U |
#define | IOMUXC_GPIO_EMC_12_XBAR1_IN24 0x401F8044U, 0x1U, 0x401F8640U, 0x0U, 0x401F8234U |
#define | IOMUXC_GPIO_EMC_12_LPI2C4_SCL 0x401F8044U, 0x2U, 0x401F84E4U, 0x0U, 0x401F8234U |
#define | IOMUXC_GPIO_EMC_12_USDHC1_WP 0x401F8044U, 0x3U, 0x401F85D8U, 0x0U, 0x401F8234U |
#define | IOMUXC_GPIO_EMC_12_FLEXPWM1_PWM3_A 0x401F8044U, 0x4U, 0x401F8454U, 0x1U, 0x401F8234U |
#define | IOMUXC_GPIO_EMC_12_GPIO4_IO12 0x401F8044U, 0x5U, 0, 0, 0x401F8234U |
#define | IOMUXC_GPIO_EMC_13_SEMC_ADDR04 0x401F8048U, 0x0U, 0, 0, 0x401F8238U |
#define | IOMUXC_GPIO_EMC_13_XBAR1_IN25 0x401F8048U, 0x1U, 0x401F8650U, 0x1U, 0x401F8238U |
#define | IOMUXC_GPIO_EMC_13_LPUART3_TXD 0x401F8048U, 0x2U, 0x401F853CU, 0x1U, 0x401F8238U |
#define | IOMUXC_GPIO_EMC_13_MQS_RIGHT 0x401F8048U, 0x3U, 0, 0, 0x401F8238U |
#define | IOMUXC_GPIO_EMC_13_FLEXPWM1_PWM3_B 0x401F8048U, 0x4U, 0x401F8464U, 0x1U, 0x401F8238U |
#define | IOMUXC_GPIO_EMC_13_GPIO4_IO13 0x401F8048U, 0x5U, 0, 0, 0x401F8238U |
#define | IOMUXC_GPIO_EMC_14_SEMC_ADDR05 0x401F804CU, 0x0U, 0, 0, 0x401F823CU |
#define | IOMUXC_GPIO_EMC_14_XBAR1_INOUT19 0x401F804CU, 0x1U, 0x401F8654U, 0x0U, 0x401F823CU |
#define | IOMUXC_GPIO_EMC_14_LPUART3_RXD 0x401F804CU, 0x2U, 0x401F8538U, 0x1U, 0x401F823CU |
#define | IOMUXC_GPIO_EMC_14_MQS_LEFT 0x401F804CU, 0x3U, 0, 0, 0x401F823CU |
#define | IOMUXC_GPIO_EMC_14_LPSPI2_PCS1 0x401F804CU, 0x4U, 0, 0, 0x401F823CU |
#define | IOMUXC_GPIO_EMC_14_GPIO4_IO14 0x401F804CU, 0x5U, 0, 0, 0x401F823CU |
#define | IOMUXC_GPIO_EMC_15_SEMC_ADDR06 0x401F8050U, 0x0U, 0, 0, 0x401F8240U |
#define | IOMUXC_GPIO_EMC_15_XBAR1_IN20 0x401F8050U, 0x1U, 0x401F8634U, 0x0U, 0x401F8240U |
#define | IOMUXC_GPIO_EMC_15_LPUART3_CTS_B 0x401F8050U, 0x2U, 0x401F8534U, 0x0U, 0x401F8240U |
#define | IOMUXC_GPIO_EMC_15_SPDIF_OUT 0x401F8050U, 0x3U, 0, 0, 0x401F8240U |
#define | IOMUXC_GPIO_EMC_15_TMR3_TIMER0 0x401F8050U, 0x4U, 0x401F857CU, 0x0U, 0x401F8240U |
#define | IOMUXC_GPIO_EMC_15_GPIO4_IO15 0x401F8050U, 0x5U, 0, 0, 0x401F8240U |
#define | IOMUXC_GPIO_EMC_16_SEMC_ADDR07 0x401F8054U, 0x0U, 0, 0, 0x401F8244U |
#define | IOMUXC_GPIO_EMC_16_XBAR1_IN21 0x401F8054U, 0x1U, 0x401F8658U, 0x0U, 0x401F8244U |
#define | IOMUXC_GPIO_EMC_16_LPUART3_RTS_B 0x401F8054U, 0x2U, 0, 0, 0x401F8244U |
#define | IOMUXC_GPIO_EMC_16_SPDIF_IN 0x401F8054U, 0x3U, 0x401F85C8U, 0x1U, 0x401F8244U |
#define | IOMUXC_GPIO_EMC_16_TMR3_TIMER1 0x401F8054U, 0x4U, 0x401F8580U, 0x1U, 0x401F8244U |
#define | IOMUXC_GPIO_EMC_16_GPIO4_IO16 0x401F8054U, 0x5U, 0, 0, 0x401F8244U |
#define | IOMUXC_GPIO_EMC_17_SEMC_ADDR08 0x401F8058U, 0x0U, 0, 0, 0x401F8248U |
#define | IOMUXC_GPIO_EMC_17_FLEXPWM4_PWM3_A 0x401F8058U, 0x1U, 0x401F84A0U, 0x0U, 0x401F8248U |
#define | IOMUXC_GPIO_EMC_17_LPUART4_CTS_B 0x401F8058U, 0x2U, 0, 0, 0x401F8248U |
#define | IOMUXC_GPIO_EMC_17_FLEXCAN1_TX 0x401F8058U, 0x3U, 0, 0, 0x401F8248U |
#define | IOMUXC_GPIO_EMC_17_TMR3_TIMER2 0x401F8058U, 0x4U, 0x401F8584U, 0x0U, 0x401F8248U |
#define | IOMUXC_GPIO_EMC_17_GPIO4_IO17 0x401F8058U, 0x5U, 0, 0, 0x401F8248U |
#define | IOMUXC_GPIO_EMC_18_SEMC_ADDR09 0x401F805CU, 0x0U, 0, 0, 0x401F824CU |
#define | IOMUXC_GPIO_EMC_18_FLEXPWM4_PWM3_B 0x401F805CU, 0x1U, 0, 0, 0x401F824CU |
#define | IOMUXC_GPIO_EMC_18_LPUART4_RTS_B 0x401F805CU, 0x2U, 0, 0, 0x401F824CU |
#define | IOMUXC_GPIO_EMC_18_FLEXCAN1_RX 0x401F805CU, 0x3U, 0x401F844CU, 0x1U, 0x401F824CU |
#define | IOMUXC_GPIO_EMC_18_TMR3_TIMER3 0x401F805CU, 0x4U, 0x401F8588U, 0x0U, 0x401F824CU |
#define | IOMUXC_GPIO_EMC_18_GPIO4_IO18 0x401F805CU, 0x5U, 0, 0, 0x401F824CU |
#define | IOMUXC_GPIO_EMC_18_SNVS_VIO_5_CTL 0x401F805CU, 0x6U, 0, 0, 0x401F824CU |
#define | IOMUXC_GPIO_EMC_19_SEMC_ADDR11 0x401F8060U, 0x0U, 0, 0, 0x401F8250U |
#define | IOMUXC_GPIO_EMC_19_FLEXPWM2_PWM3_A 0x401F8060U, 0x1U, 0x401F8474U, 0x1U, 0x401F8250U |
#define | IOMUXC_GPIO_EMC_19_LPUART4_TXD 0x401F8060U, 0x2U, 0x401F8544U, 0x1U, 0x401F8250U |
#define | IOMUXC_GPIO_EMC_19_ENET_RX_DATA01 0x401F8060U, 0x3U, 0x401F8438U, 0x0U, 0x401F8250U |
#define | IOMUXC_GPIO_EMC_19_TMR2_TIMER0 0x401F8060U, 0x4U, 0x401F856CU, 0x0U, 0x401F8250U |
#define | IOMUXC_GPIO_EMC_19_GPIO4_IO19 0x401F8060U, 0x5U, 0, 0, 0x401F8250U |
#define | IOMUXC_GPIO_EMC_19_SNVS_VIO_5 0x401F8060U, 0x6U, 0, 0, 0x401F8250U |
#define | IOMUXC_GPIO_EMC_20_SEMC_ADDR12 0x401F8064U, 0x0U, 0, 0, 0x401F8254U |
#define | IOMUXC_GPIO_EMC_20_FLEXPWM2_PWM3_B 0x401F8064U, 0x1U, 0x401F8484U, 0x1U, 0x401F8254U |
#define | IOMUXC_GPIO_EMC_20_LPUART4_RXD 0x401F8064U, 0x2U, 0x401F8540U, 0x1U, 0x401F8254U |
#define | IOMUXC_GPIO_EMC_20_ENET_RX_DATA00 0x401F8064U, 0x3U, 0x401F8434U, 0x0U, 0x401F8254U |
#define | IOMUXC_GPIO_EMC_20_TMR2_TIMER1 0x401F8064U, 0x4U, 0x401F8570U, 0x0U, 0x401F8254U |
#define | IOMUXC_GPIO_EMC_20_GPIO4_IO20 0x401F8064U, 0x5U, 0, 0, 0x401F8254U |
#define | IOMUXC_GPIO_EMC_21_SEMC_BA0 0x401F8068U, 0x0U, 0, 0, 0x401F8258U |
#define | IOMUXC_GPIO_EMC_21_FLEXPWM3_PWM3_A 0x401F8068U, 0x1U, 0, 0, 0x401F8258U |
#define | IOMUXC_GPIO_EMC_21_LPI2C3_SDA 0x401F8068U, 0x2U, 0x401F84E0U, 0x0U, 0x401F8258U |
#define | IOMUXC_GPIO_EMC_21_ENET_TX_DATA01 0x401F8068U, 0x3U, 0, 0, 0x401F8258U |
#define | IOMUXC_GPIO_EMC_21_TMR2_TIMER2 0x401F8068U, 0x4U, 0x401F8574U, 0x0U, 0x401F8258U |
#define | IOMUXC_GPIO_EMC_21_GPIO4_IO21 0x401F8068U, 0x5U, 0, 0, 0x401F8258U |
#define | IOMUXC_GPIO_EMC_22_SEMC_BA1 0x401F806CU, 0x0U, 0, 0, 0x401F825CU |
#define | IOMUXC_GPIO_EMC_22_FLEXPWM3_PWM3_B 0x401F806CU, 0x1U, 0, 0, 0x401F825CU |
#define | IOMUXC_GPIO_EMC_22_LPI2C3_SCL 0x401F806CU, 0x2U, 0x401F84DCU, 0x0U, 0x401F825CU |
#define | IOMUXC_GPIO_EMC_22_ENET_TX_DATA00 0x401F806CU, 0x3U, 0, 0, 0x401F825CU |
#define | IOMUXC_GPIO_EMC_22_TMR2_TIMER3 0x401F806CU, 0x4U, 0x401F8578U, 0x0U, 0x401F825CU |
#define | IOMUXC_GPIO_EMC_22_GPIO4_IO22 0x401F806CU, 0x5U, 0, 0, 0x401F825CU |
#define | IOMUXC_GPIO_EMC_23_SEMC_ADDR10 0x401F8070U, 0x0U, 0, 0, 0x401F8260U |
#define | IOMUXC_GPIO_EMC_23_FLEXPWM1_PWM0_A 0x401F8070U, 0x1U, 0x401F8458U, 0x0U, 0x401F8260U |
#define | IOMUXC_GPIO_EMC_23_LPUART5_TXD 0x401F8070U, 0x2U, 0x401F854CU, 0x0U, 0x401F8260U |
#define | IOMUXC_GPIO_EMC_23_ENET_RX_EN 0x401F8070U, 0x3U, 0x401F843CU, 0x0U, 0x401F8260U |
#define | IOMUXC_GPIO_EMC_23_GPT1_CAPTURE2 0x401F8070U, 0x4U, 0, 0, 0x401F8260U |
#define | IOMUXC_GPIO_EMC_23_GPIO4_IO23 0x401F8070U, 0x5U, 0, 0, 0x401F8260U |
#define | IOMUXC_GPIO_EMC_24_SEMC_CAS 0x401F8074U, 0x0U, 0, 0, 0x401F8264U |
#define | IOMUXC_GPIO_EMC_24_FLEXPWM1_PWM0_B 0x401F8074U, 0x1U, 0x401F8468U, 0x0U, 0x401F8264U |
#define | IOMUXC_GPIO_EMC_24_LPUART5_RXD 0x401F8074U, 0x2U, 0x401F8548U, 0x0U, 0x401F8264U |
#define | IOMUXC_GPIO_EMC_24_ENET_TX_EN 0x401F8074U, 0x3U, 0, 0, 0x401F8264U |
#define | IOMUXC_GPIO_EMC_24_GPT1_CAPTURE1 0x401F8074U, 0x4U, 0, 0, 0x401F8264U |
#define | IOMUXC_GPIO_EMC_24_GPIO4_IO24 0x401F8074U, 0x5U, 0, 0, 0x401F8264U |
#define | IOMUXC_GPIO_EMC_25_SEMC_RAS 0x401F8078U, 0x0U, 0, 0, 0x401F8268U |
#define | IOMUXC_GPIO_EMC_25_FLEXPWM1_PWM1_A 0x401F8078U, 0x1U, 0x401F845CU, 0x0U, 0x401F8268U |
#define | IOMUXC_GPIO_EMC_25_LPUART6_TXD 0x401F8078U, 0x2U, 0x401F8554U, 0x0U, 0x401F8268U |
#define | IOMUXC_GPIO_EMC_25_ENET_TX_CLK 0x401F8078U, 0x3U, 0x401F8448U, 0x0U, 0x401F8268U |
#define | IOMUXC_GPIO_EMC_25_ENET_REF_CLK 0x401F8078U, 0x4U, 0x401F842CU, 0x0U, 0x401F8268U |
#define | IOMUXC_GPIO_EMC_25_GPIO4_IO25 0x401F8078U, 0x5U, 0, 0, 0x401F8268U |
#define | IOMUXC_GPIO_EMC_26_SEMC_CLK 0x401F807CU, 0x0U, 0, 0, 0x401F826CU |
#define | IOMUXC_GPIO_EMC_26_FLEXPWM1_PWM1_B 0x401F807CU, 0x1U, 0x401F846CU, 0x0U, 0x401F826CU |
#define | IOMUXC_GPIO_EMC_26_LPUART6_RXD 0x401F807CU, 0x2U, 0x401F8550U, 0x0U, 0x401F826CU |
#define | IOMUXC_GPIO_EMC_26_ENET_RX_ER 0x401F807CU, 0x3U, 0x401F8440U, 0x0U, 0x401F826CU |
#define | IOMUXC_GPIO_EMC_26_FLEXIO1_D12 0x401F807CU, 0x4U, 0, 0, 0x401F826CU |
#define | IOMUXC_GPIO_EMC_26_GPIO4_IO26 0x401F807CU, 0x5U, 0, 0, 0x401F826CU |
#define | IOMUXC_GPIO_EMC_27_SEMC_CKE 0x401F8080U, 0x0U, 0, 0, 0x401F8270U |
#define | IOMUXC_GPIO_EMC_27_FLEXPWM1_PWM2_A 0x401F8080U, 0x1U, 0x401F8460U, 0x0U, 0x401F8270U |
#define | IOMUXC_GPIO_EMC_27_LPUART5_RTS_B 0x401F8080U, 0x2U, 0, 0, 0x401F8270U |
#define | IOMUXC_GPIO_EMC_27_LPSPI1_SCK 0x401F8080U, 0x3U, 0x401F84F0U, 0x0U, 0x401F8270U |
#define | IOMUXC_GPIO_EMC_27_FLEXIO1_D13 0x401F8080U, 0x4U, 0, 0, 0x401F8270U |
#define | IOMUXC_GPIO_EMC_27_GPIO4_IO27 0x401F8080U, 0x5U, 0, 0, 0x401F8270U |
#define | IOMUXC_GPIO_EMC_28_SEMC_WE 0x401F8084U, 0x0U, 0, 0, 0x401F8274U |
#define | IOMUXC_GPIO_EMC_28_FLEXPWM1_PWM2_B 0x401F8084U, 0x1U, 0x401F8470U, 0x0U, 0x401F8274U |
#define | IOMUXC_GPIO_EMC_28_LPUART5_CTS_B 0x401F8084U, 0x2U, 0, 0, 0x401F8274U |
#define | IOMUXC_GPIO_EMC_28_LPSPI1_SDO 0x401F8084U, 0x3U, 0x401F84F8U, 0x0U, 0x401F8274U |
#define | IOMUXC_GPIO_EMC_28_FLEXIO1_D14 0x401F8084U, 0x4U, 0, 0, 0x401F8274U |
#define | IOMUXC_GPIO_EMC_28_GPIO4_IO28 0x401F8084U, 0x5U, 0, 0, 0x401F8274U |
#define | IOMUXC_GPIO_EMC_29_SEMC_CS0 0x401F8088U, 0x0U, 0, 0, 0x401F8278U |
#define | IOMUXC_GPIO_EMC_29_FLEXPWM3_PWM0_A 0x401F8088U, 0x1U, 0, 0, 0x401F8278U |
#define | IOMUXC_GPIO_EMC_29_LPUART6_RTS_B 0x401F8088U, 0x2U, 0, 0, 0x401F8278U |
#define | IOMUXC_GPIO_EMC_29_LPSPI1_SDI 0x401F8088U, 0x3U, 0x401F84F4U, 0x0U, 0x401F8278U |
#define | IOMUXC_GPIO_EMC_29_FLEXIO1_D15 0x401F8088U, 0x4U, 0, 0, 0x401F8278U |
#define | IOMUXC_GPIO_EMC_29_GPIO4_IO29 0x401F8088U, 0x5U, 0, 0, 0x401F8278U |
#define | IOMUXC_GPIO_EMC_30_SEMC_DA08 0x401F808CU, 0x0U, 0, 0, 0x401F827CU |
#define | IOMUXC_GPIO_EMC_30_FLEXPWM3_PWM0_B 0x401F808CU, 0x1U, 0, 0, 0x401F827CU |
#define | IOMUXC_GPIO_EMC_30_LPUART6_CTS_B 0x401F808CU, 0x2U, 0, 0, 0x401F827CU |
#define | IOMUXC_GPIO_EMC_30_LPSPI1_PCS0 0x401F808CU, 0x3U, 0x401F84ECU, 0x1U, 0x401F827CU |
#define | IOMUXC_GPIO_EMC_30_CSI_DATA23 0x401F808CU, 0x4U, 0, 0, 0x401F827CU |
#define | IOMUXC_GPIO_EMC_30_GPIO4_IO30 0x401F808CU, 0x5U, 0, 0, 0x401F827CU |
#define | IOMUXC_GPIO_EMC_31_SEMC_DA09 0x401F8090U, 0x0U, 0, 0, 0x401F8280U |
#define | IOMUXC_GPIO_EMC_31_FLEXPWM3_PWM1_A 0x401F8090U, 0x1U, 0, 0, 0x401F8280U |
#define | IOMUXC_GPIO_EMC_31_LPUART7_TXD 0x401F8090U, 0x2U, 0x401F855CU, 0x1U, 0x401F8280U |
#define | IOMUXC_GPIO_EMC_31_LPSPI1_PCS1 0x401F8090U, 0x3U, 0, 0, 0x401F8280U |
#define | IOMUXC_GPIO_EMC_31_CSI_DATA22 0x401F8090U, 0x4U, 0, 0, 0x401F8280U |
#define | IOMUXC_GPIO_EMC_31_GPIO4_IO31 0x401F8090U, 0x5U, 0, 0, 0x401F8280U |
#define | IOMUXC_GPIO_EMC_32_SEMC_DA10 0x401F8094U, 0x0U, 0, 0, 0x401F8284U |
#define | IOMUXC_GPIO_EMC_32_FLEXPWM3_PWM1_B 0x401F8094U, 0x1U, 0, 0, 0x401F8284U |
#define | IOMUXC_GPIO_EMC_32_LPUART7_RXD 0x401F8094U, 0x2U, 0x401F8558U, 0x1U, 0x401F8284U |
#define | IOMUXC_GPIO_EMC_32_CCM_PMIC_READY 0x401F8094U, 0x3U, 0x401F83FCU, 0x4U, 0x401F8284U |
#define | IOMUXC_GPIO_EMC_32_CSI_DATA21 0x401F8094U, 0x4U, 0, 0, 0x401F8284U |
#define | IOMUXC_GPIO_EMC_32_GPIO3_IO18 0x401F8094U, 0x5U, 0, 0, 0x401F8284U |
#define | IOMUXC_GPIO_EMC_33_SEMC_DA11 0x401F8098U, 0x0U, 0, 0, 0x401F8288U |
#define | IOMUXC_GPIO_EMC_33_FLEXPWM3_PWM2_A 0x401F8098U, 0x1U, 0, 0, 0x401F8288U |
#define | IOMUXC_GPIO_EMC_33_USDHC1_RESET_B 0x401F8098U, 0x2U, 0, 0, 0x401F8288U |
#define | IOMUXC_GPIO_EMC_33_SAI3_RX_DATA 0x401F8098U, 0x3U, 0, 0, 0x401F8288U |
#define | IOMUXC_GPIO_EMC_33_CSI_DATA20 0x401F8098U, 0x4U, 0, 0, 0x401F8288U |
#define | IOMUXC_GPIO_EMC_33_GPIO3_IO19 0x401F8098U, 0x5U, 0, 0, 0x401F8288U |
#define | IOMUXC_GPIO_EMC_34_SEMC_DA12 0x401F809CU, 0x0U, 0, 0, 0x401F828CU |
#define | IOMUXC_GPIO_EMC_34_FLEXPWM3_PWM2_B 0x401F809CU, 0x1U, 0, 0, 0x401F828CU |
#define | IOMUXC_GPIO_EMC_34_USDHC1_VSELECT 0x401F809CU, 0x2U, 0, 0, 0x401F828CU |
#define | IOMUXC_GPIO_EMC_34_SAI3_RX_SYNC 0x401F809CU, 0x3U, 0, 0, 0x401F828CU |
#define | IOMUXC_GPIO_EMC_34_CSI_DATA19 0x401F809CU, 0x4U, 0, 0, 0x401F828CU |
#define | IOMUXC_GPIO_EMC_34_GPIO3_IO20 0x401F809CU, 0x5U, 0, 0, 0x401F828CU |
#define | IOMUXC_GPIO_EMC_35_SEMC_DA13 0x401F80A0U, 0x0U, 0, 0, 0x401F8290U |
#define | IOMUXC_GPIO_EMC_35_XBAR1_INOUT18 0x401F80A0U, 0x1U, 0x401F8630U, 0x0U, 0x401F8290U |
#define | IOMUXC_GPIO_EMC_35_GPT1_COMPARE1 0x401F80A0U, 0x2U, 0, 0, 0x401F8290U |
#define | IOMUXC_GPIO_EMC_35_SAI3_RX_BCLK 0x401F80A0U, 0x3U, 0, 0, 0x401F8290U |
#define | IOMUXC_GPIO_EMC_35_CSI_DATA18 0x401F80A0U, 0x4U, 0, 0, 0x401F8290U |
#define | IOMUXC_GPIO_EMC_35_GPIO3_IO21 0x401F80A0U, 0x5U, 0, 0, 0x401F8290U |
#define | IOMUXC_GPIO_EMC_35_USDHC1_CD_B 0x401F80A0U, 0x6U, 0x401F85D4U, 0x0U, 0x401F8290U |
#define | IOMUXC_GPIO_EMC_36_SEMC_DA14 0x401F80A4U, 0x0U, 0, 0, 0x401F8294U |
#define | IOMUXC_GPIO_EMC_36_XBAR1_IN22 0x401F80A4U, 0x1U, 0x401F8638U, 0x0U, 0x401F8294U |
#define | IOMUXC_GPIO_EMC_36_GPT1_COMPARE2 0x401F80A4U, 0x2U, 0, 0, 0x401F8294U |
#define | IOMUXC_GPIO_EMC_36_SAI3_TX_DATA 0x401F80A4U, 0x3U, 0, 0, 0x401F8294U |
#define | IOMUXC_GPIO_EMC_36_CSI_DATA17 0x401F80A4U, 0x4U, 0, 0, 0x401F8294U |
#define | IOMUXC_GPIO_EMC_36_GPIO3_IO22 0x401F80A4U, 0x5U, 0, 0, 0x401F8294U |
#define | IOMUXC_GPIO_EMC_36_USDHC1_WP 0x401F80A4U, 0x6U, 0x401F85D8U, 0x1U, 0x401F8294U |
#define | IOMUXC_GPIO_EMC_37_SEMC_DA15 0x401F80A8U, 0x0U, 0, 0, 0x401F8298U |
#define | IOMUXC_GPIO_EMC_37_XBAR1_IN23 0x401F80A8U, 0x1U, 0x401F863CU, 0x0U, 0x401F8298U |
#define | IOMUXC_GPIO_EMC_37_GPT1_COMPARE3 0x401F80A8U, 0x2U, 0, 0, 0x401F8298U |
#define | IOMUXC_GPIO_EMC_37_SAI3_MCLK 0x401F80A8U, 0x3U, 0, 0, 0x401F8298U |
#define | IOMUXC_GPIO_EMC_37_CSI_DATA16 0x401F80A8U, 0x4U, 0, 0, 0x401F8298U |
#define | IOMUXC_GPIO_EMC_37_GPIO3_IO23 0x401F80A8U, 0x5U, 0, 0, 0x401F8298U |
#define | IOMUXC_GPIO_EMC_37_USDHC2_WP 0x401F80A8U, 0x6U, 0x401F8608U, 0x0U, 0x401F8298U |
#define | IOMUXC_GPIO_EMC_38_SEMC_DM01 0x401F80ACU, 0x0U, 0, 0, 0x401F829CU |
#define | IOMUXC_GPIO_EMC_38_FLEXPWM1_PWM3_A 0x401F80ACU, 0x1U, 0x401F8454U, 0x2U, 0x401F829CU |
#define | IOMUXC_GPIO_EMC_38_LPUART8_TXD 0x401F80ACU, 0x2U, 0x401F8564U, 0x2U, 0x401F829CU |
#define | IOMUXC_GPIO_EMC_38_SAI3_TX_BCLK 0x401F80ACU, 0x3U, 0, 0, 0x401F829CU |
#define | IOMUXC_GPIO_EMC_38_CSI_FIELD 0x401F80ACU, 0x4U, 0, 0, 0x401F829CU |
#define | IOMUXC_GPIO_EMC_38_GPIO3_IO24 0x401F80ACU, 0x5U, 0, 0, 0x401F829CU |
#define | IOMUXC_GPIO_EMC_38_USDHC2_VSELECT 0x401F80ACU, 0x6U, 0, 0, 0x401F829CU |
#define | IOMUXC_GPIO_EMC_39_SEMC_DQS 0x401F80B0U, 0x0U, 0, 0, 0x401F82A0U |
#define | IOMUXC_GPIO_EMC_39_FLEXPWM1_PWM3_B 0x401F80B0U, 0x1U, 0x401F8464U, 0x2U, 0x401F82A0U |
#define | IOMUXC_GPIO_EMC_39_LPUART8_RXD 0x401F80B0U, 0x2U, 0x401F8560U, 0x2U, 0x401F82A0U |
#define | IOMUXC_GPIO_EMC_39_SAI3_TX_SYNC 0x401F80B0U, 0x3U, 0, 0, 0x401F82A0U |
#define | IOMUXC_GPIO_EMC_39_WDOG1_B 0x401F80B0U, 0x4U, 0, 0, 0x401F82A0U |
#define | IOMUXC_GPIO_EMC_39_GPIO3_IO25 0x401F80B0U, 0x5U, 0, 0, 0x401F82A0U |
#define | IOMUXC_GPIO_EMC_39_USDHC2_CD_B 0x401F80B0U, 0x6U, 0x401F85E0U, 0x1U, 0x401F82A0U |
#define | IOMUXC_GPIO_EMC_40_SEMC_RDY 0x401F80B4U, 0x0U, 0, 0, 0x401F82A4U |
#define | IOMUXC_GPIO_EMC_40_GPT2_CAPTURE2 0x401F80B4U, 0x1U, 0, 0, 0x401F82A4U |
#define | IOMUXC_GPIO_EMC_40_LPSPI1_PCS2 0x401F80B4U, 0x2U, 0, 0, 0x401F82A4U |
#define | IOMUXC_GPIO_EMC_40_USB_OTG2_OC 0x401F80B4U, 0x3U, 0x401F85CCU, 0x1U, 0x401F82A4U |
#define | IOMUXC_GPIO_EMC_40_ENET_MDC 0x401F80B4U, 0x4U, 0, 0, 0x401F82A4U |
#define | IOMUXC_GPIO_EMC_40_GPIO3_IO26 0x401F80B4U, 0x5U, 0, 0, 0x401F82A4U |
#define | IOMUXC_GPIO_EMC_40_USDHC2_RESET_B 0x401F80B4U, 0x6U, 0, 0, 0x401F82A4U |
#define | IOMUXC_GPIO_EMC_41_SEMC_CSX0 0x401F80B8U, 0x0U, 0, 0, 0x401F82A8U |
#define | IOMUXC_GPIO_EMC_41_GPT2_CAPTURE1 0x401F80B8U, 0x1U, 0, 0, 0x401F82A8U |
#define | IOMUXC_GPIO_EMC_41_LPSPI1_PCS3 0x401F80B8U, 0x2U, 0, 0, 0x401F82A8U |
#define | IOMUXC_GPIO_EMC_41_USB_OTG2_PWR 0x401F80B8U, 0x3U, 0, 0, 0x401F82A8U |
#define | IOMUXC_GPIO_EMC_41_ENET_MDIO 0x401F80B8U, 0x4U, 0x401F8430U, 0x1U, 0x401F82A8U |
#define | IOMUXC_GPIO_EMC_41_GPIO3_IO27 0x401F80B8U, 0x5U, 0, 0, 0x401F82A8U |
#define | IOMUXC_GPIO_EMC_41_USDHC1_VSELECT 0x401F80B8U, 0x6U, 0, 0, 0x401F82A8U |
#define | IOMUXC_GPIO_AD_B0_00_FLEXPWM2_PWM3_A 0x401F80BCU, 0x0U, 0x401F8474U, 0x2U, 0x401F82ACU |
#define | IOMUXC_GPIO_AD_B0_00_XBAR1_INOUT14 0x401F80BCU, 0x1U, 0x401F8644U, 0x0U, 0x401F82ACU |
#define | IOMUXC_GPIO_AD_B0_00_REF_CLK_32K 0x401F80BCU, 0x2U, 0, 0, 0x401F82ACU |
#define | IOMUXC_GPIO_AD_B0_00_USB_OTG2_ID 0x401F80BCU, 0x3U, 0x401F83F8U, 0x0U, 0x401F82ACU |
#define | IOMUXC_GPIO_AD_B0_00_LPI2C1_SCLS 0x401F80BCU, 0x4U, 0, 0, 0x401F82ACU |
#define | IOMUXC_GPIO_AD_B0_00_GPIO1_IO00 0x401F80BCU, 0x5U, 0, 0, 0x401F82ACU |
#define | IOMUXC_GPIO_AD_B0_00_USDHC1_RESET_B 0x401F80BCU, 0x6U, 0, 0, 0x401F82ACU |
#define | IOMUXC_GPIO_AD_B0_00_LPSPI3_SCK 0x401F80BCU, 0x7U, 0x401F8510U, 0x0U, 0x401F82ACU |
#define | IOMUXC_GPIO_AD_B0_01_FLEXPWM2_PWM3_B 0x401F80C0U, 0x0U, 0x401F8484U, 0x2U, 0x401F82B0U |
#define | IOMUXC_GPIO_AD_B0_01_XBAR1_INOUT15 0x401F80C0U, 0x1U, 0x401F8648U, 0x0U, 0x401F82B0U |
#define | IOMUXC_GPIO_AD_B0_01_REF_CLK_24M 0x401F80C0U, 0x2U, 0, 0, 0x401F82B0U |
#define | IOMUXC_GPIO_AD_B0_01_USB_OTG1_ID 0x401F80C0U, 0x3U, 0x401F83F4U, 0x0U, 0x401F82B0U |
#define | IOMUXC_GPIO_AD_B0_01_LPI2C1_SDAS 0x401F80C0U, 0x4U, 0, 0, 0x401F82B0U |
#define | IOMUXC_GPIO_AD_B0_01_GPIO1_IO01 0x401F80C0U, 0x5U, 0, 0, 0x401F82B0U |
#define | IOMUXC_GPIO_AD_B0_01_EWM_OUT_B 0x401F80C0U, 0x6U, 0, 0, 0x401F82B0U |
#define | IOMUXC_GPIO_AD_B0_01_LPSPI3_SDO 0x401F80C0U, 0x7U, 0x401F8518U, 0x0U, 0x401F82B0U |
#define | IOMUXC_GPIO_AD_B0_02_FLEXCAN2_TX 0x401F80C4U, 0x0U, 0, 0, 0x401F82B4U |
#define | IOMUXC_GPIO_AD_B0_02_XBAR1_INOUT16 0x401F80C4U, 0x1U, 0x401F864CU, 0x0U, 0x401F82B4U |
#define | IOMUXC_GPIO_AD_B0_02_LPUART6_TXD 0x401F80C4U, 0x2U, 0x401F8554U, 0x1U, 0x401F82B4U |
#define | IOMUXC_GPIO_AD_B0_02_USB_OTG1_PWR 0x401F80C4U, 0x3U, 0, 0, 0x401F82B4U |
#define | IOMUXC_GPIO_AD_B0_02_FLEXPWM1_PWM0_X 0x401F80C4U, 0x4U, 0, 0, 0x401F82B4U |
#define | IOMUXC_GPIO_AD_B0_02_GPIO1_IO02 0x401F80C4U, 0x5U, 0, 0, 0x401F82B4U |
#define | IOMUXC_GPIO_AD_B0_02_LPI2C1_HREQ 0x401F80C4U, 0x6U, 0, 0, 0x401F82B4U |
#define | IOMUXC_GPIO_AD_B0_02_LPSPI3_SDI 0x401F80C4U, 0x7U, 0x401F8514U, 0x0U, 0x401F82B4U |
#define | IOMUXC_GPIO_AD_B0_03_FLEXCAN2_RX 0x401F80C8U, 0x0U, 0x401F8450U, 0x1U, 0x401F82B8U |
#define | IOMUXC_GPIO_AD_B0_03_XBAR1_INOUT17 0x401F80C8U, 0x1U, 0x401F862CU, 0x1U, 0x401F82B8U |
#define | IOMUXC_GPIO_AD_B0_03_LPUART6_RXD 0x401F80C8U, 0x2U, 0x401F8550U, 0x1U, 0x401F82B8U |
#define | IOMUXC_GPIO_AD_B0_03_USB_OTG1_OC 0x401F80C8U, 0x3U, 0x401F85D0U, 0x0U, 0x401F82B8U |
#define | IOMUXC_GPIO_AD_B0_03_FLEXPWM1_PWM1_X 0x401F80C8U, 0x4U, 0, 0, 0x401F82B8U |
#define | IOMUXC_GPIO_AD_B0_03_GPIO1_IO03 0x401F80C8U, 0x5U, 0, 0, 0x401F82B8U |
#define | IOMUXC_GPIO_AD_B0_03_REF_CLK_24M 0x401F80C8U, 0x6U, 0, 0, 0x401F82B8U |
#define | IOMUXC_GPIO_AD_B0_03_LPSPI3_PCS0 0x401F80C8U, 0x7U, 0x401F850CU, 0x0U, 0x401F82B8U |
#define | IOMUXC_GPIO_AD_B0_04_SRC_BOOT_MODE00 0x401F80CCU, 0x0U, 0, 0, 0x401F82BCU |
#define | IOMUXC_GPIO_AD_B0_04_MQS_RIGHT 0x401F80CCU, 0x1U, 0, 0, 0x401F82BCU |
#define | IOMUXC_GPIO_AD_B0_04_ENET_TX_DATA03 0x401F80CCU, 0x2U, 0, 0, 0x401F82BCU |
#define | IOMUXC_GPIO_AD_B0_04_SAI2_TX_SYNC 0x401F80CCU, 0x3U, 0x401F85C4U, 0x1U, 0x401F82BCU |
#define | IOMUXC_GPIO_AD_B0_04_CSI_DATA09 0x401F80CCU, 0x4U, 0x401F841CU, 0x1U, 0x401F82BCU |
#define | IOMUXC_GPIO_AD_B0_04_GPIO1_IO04 0x401F80CCU, 0x5U, 0, 0, 0x401F82BCU |
#define | IOMUXC_GPIO_AD_B0_04_PIT_TRIGGER00 0x401F80CCU, 0x6U, 0, 0, 0x401F82BCU |
#define | IOMUXC_GPIO_AD_B0_04_LPSPI3_PCS1 0x401F80CCU, 0x7U, 0, 0, 0x401F82BCU |
#define | IOMUXC_GPIO_AD_B0_05_SRC_BOOT_MODE01 0x401F80D0U, 0x0U, 0, 0, 0x401F82C0U |
#define | IOMUXC_GPIO_AD_B0_05_MQS_LEFT 0x401F80D0U, 0x1U, 0, 0, 0x401F82C0U |
#define | IOMUXC_GPIO_AD_B0_05_ENET_TX_DATA02 0x401F80D0U, 0x2U, 0, 0, 0x401F82C0U |
#define | IOMUXC_GPIO_AD_B0_05_SAI2_TX_BCLK 0x401F80D0U, 0x3U, 0x401F85C0U, 0x1U, 0x401F82C0U |
#define | IOMUXC_GPIO_AD_B0_05_CSI_DATA08 0x401F80D0U, 0x4U, 0x401F8418U, 0x1U, 0x401F82C0U |
#define | IOMUXC_GPIO_AD_B0_05_GPIO1_IO05 0x401F80D0U, 0x5U, 0, 0, 0x401F82C0U |
#define | IOMUXC_GPIO_AD_B0_05_XBAR1_INOUT17 0x401F80D0U, 0x6U, 0x401F862CU, 0x2U, 0x401F82C0U |
#define | IOMUXC_GPIO_AD_B0_05_LPSPI3_PCS2 0x401F80D0U, 0x7U, 0, 0, 0x401F82C0U |
#define | IOMUXC_GPIO_AD_B0_06_JTAG_TMS 0x401F80D4U, 0x0U, 0, 0, 0x401F82C4U |
#define | IOMUXC_GPIO_AD_B0_06_GPT2_COMPARE1 0x401F80D4U, 0x1U, 0, 0, 0x401F82C4U |
#define | IOMUXC_GPIO_AD_B0_06_ENET_RX_CLK 0x401F80D4U, 0x2U, 0, 0, 0x401F82C4U |
#define | IOMUXC_GPIO_AD_B0_06_SAI2_RX_BCLK 0x401F80D4U, 0x3U, 0x401F85B4U, 0x1U, 0x401F82C4U |
#define | IOMUXC_GPIO_AD_B0_06_CSI_DATA07 0x401F80D4U, 0x4U, 0x401F8414U, 0x1U, 0x401F82C4U |
#define | IOMUXC_GPIO_AD_B0_06_GPIO1_IO06 0x401F80D4U, 0x5U, 0, 0, 0x401F82C4U |
#define | IOMUXC_GPIO_AD_B0_06_XBAR1_INOUT18 0x401F80D4U, 0x6U, 0x401F8630U, 0x1U, 0x401F82C4U |
#define | IOMUXC_GPIO_AD_B0_06_LPSPI3_PCS3 0x401F80D4U, 0x7U, 0, 0, 0x401F82C4U |
#define | IOMUXC_GPIO_AD_B0_07_JTAG_TCK 0x401F80D8U, 0x0U, 0, 0, 0x401F82C8U |
#define | IOMUXC_GPIO_AD_B0_07_GPT2_COMPARE2 0x401F80D8U, 0x1U, 0, 0, 0x401F82C8U |
#define | IOMUXC_GPIO_AD_B0_07_ENET_TX_ER 0x401F80D8U, 0x2U, 0, 0, 0x401F82C8U |
#define | IOMUXC_GPIO_AD_B0_07_SAI2_RX_SYNC 0x401F80D8U, 0x3U, 0x401F85BCU, 0x1U, 0x401F82C8U |
#define | IOMUXC_GPIO_AD_B0_07_CSI_DATA06 0x401F80D8U, 0x4U, 0x401F8410U, 0x1U, 0x401F82C8U |
#define | IOMUXC_GPIO_AD_B0_07_GPIO1_IO07 0x401F80D8U, 0x5U, 0, 0, 0x401F82C8U |
#define | IOMUXC_GPIO_AD_B0_07_XBAR1_INOUT19 0x401F80D8U, 0x6U, 0x401F8654U, 0x1U, 0x401F82C8U |
#define | IOMUXC_GPIO_AD_B0_07_ENET_1588_EVENT3_OUT 0x401F80D8U, 0x7U, 0, 0, 0x401F82C8U |
#define | IOMUXC_GPIO_AD_B0_08_JTAG_MOD 0x401F80DCU, 0x0U, 0, 0, 0x401F82CCU |
#define | IOMUXC_GPIO_AD_B0_08_GPT2_COMPARE3 0x401F80DCU, 0x1U, 0, 0, 0x401F82CCU |
#define | IOMUXC_GPIO_AD_B0_08_ENET_RX_DATA03 0x401F80DCU, 0x2U, 0, 0, 0x401F82CCU |
#define | IOMUXC_GPIO_AD_B0_08_SAI2_RX_DATA 0x401F80DCU, 0x3U, 0x401F85B8U, 0x1U, 0x401F82CCU |
#define | IOMUXC_GPIO_AD_B0_08_CSI_DATA05 0x401F80DCU, 0x4U, 0x401F840CU, 0x1U, 0x401F82CCU |
#define | IOMUXC_GPIO_AD_B0_08_GPIO1_IO08 0x401F80DCU, 0x5U, 0, 0, 0x401F82CCU |
#define | IOMUXC_GPIO_AD_B0_08_XBAR1_IN20 0x401F80DCU, 0x6U, 0x401F8634U, 0x1U, 0x401F82CCU |
#define | IOMUXC_GPIO_AD_B0_08_ENET_1588_EVENT3_IN 0x401F80DCU, 0x7U, 0, 0, 0x401F82CCU |
#define | IOMUXC_GPIO_AD_B0_09_JTAG_TDI 0x401F80E0U, 0x0U, 0, 0, 0x401F82D0U |
#define | IOMUXC_GPIO_AD_B0_09_FLEXPWM2_PWM3_A 0x401F80E0U, 0x1U, 0x401F8474U, 0x3U, 0x401F82D0U |
#define | IOMUXC_GPIO_AD_B0_09_ENET_RX_DATA02 0x401F80E0U, 0x2U, 0, 0, 0x401F82D0U |
#define | IOMUXC_GPIO_AD_B0_09_SAI2_TX_DATA 0x401F80E0U, 0x3U, 0, 0, 0x401F82D0U |
#define | IOMUXC_GPIO_AD_B0_09_CSI_DATA04 0x401F80E0U, 0x4U, 0x401F8408U, 0x1U, 0x401F82D0U |
#define | IOMUXC_GPIO_AD_B0_09_GPIO1_IO09 0x401F80E0U, 0x5U, 0, 0, 0x401F82D0U |
#define | IOMUXC_GPIO_AD_B0_09_XBAR1_IN21 0x401F80E0U, 0x6U, 0x401F8658U, 0x1U, 0x401F82D0U |
#define | IOMUXC_GPIO_AD_B0_09_GPT2_CLK 0x401F80E0U, 0x7U, 0, 0, 0x401F82D0U |
#define | IOMUXC_GPIO_AD_B0_10_JTAG_TDO 0x401F80E4U, 0x0U, 0, 0, 0x401F82D4U |
#define | IOMUXC_GPIO_AD_B0_10_FLEXPWM1_PWM3_A 0x401F80E4U, 0x1U, 0x401F8454U, 0x3U, 0x401F82D4U |
#define | IOMUXC_GPIO_AD_B0_10_ENET_CRS 0x401F80E4U, 0x2U, 0, 0, 0x401F82D4U |
#define | IOMUXC_GPIO_AD_B0_10_SAI2_MCLK 0x401F80E4U, 0x3U, 0x401F85B0U, 0x1U, 0x401F82D4U |
#define | IOMUXC_GPIO_AD_B0_10_CSI_DATA03 0x401F80E4U, 0x4U, 0x401F8404U, 0x1U, 0x401F82D4U |
#define | IOMUXC_GPIO_AD_B0_10_GPIO1_IO10 0x401F80E4U, 0x5U, 0, 0, 0x401F82D4U |
#define | IOMUXC_GPIO_AD_B0_10_XBAR1_IN22 0x401F80E4U, 0x6U, 0x401F8638U, 0x1U, 0x401F82D4U |
#define | IOMUXC_GPIO_AD_B0_10_ENET_1588_EVENT0_OUT 0x401F80E4U, 0x7U, 0, 0, 0x401F82D4U |
#define | IOMUXC_GPIO_AD_B0_11_JTAG_TRSTB 0x401F80E8U, 0x0U, 0, 0, 0x401F82D8U |
#define | IOMUXC_GPIO_AD_B0_11_FLEXPWM1_PWM3_B 0x401F80E8U, 0x1U, 0x401F8464U, 0x3U, 0x401F82D8U |
#define | IOMUXC_GPIO_AD_B0_11_ENET_COL 0x401F80E8U, 0x2U, 0, 0, 0x401F82D8U |
#define | IOMUXC_GPIO_AD_B0_11_WDOG1_B 0x401F80E8U, 0x3U, 0, 0, 0x401F82D8U |
#define | IOMUXC_GPIO_AD_B0_11_CSI_DATA02 0x401F80E8U, 0x4U, 0x401F8400U, 0x1U, 0x401F82D8U |
#define | IOMUXC_GPIO_AD_B0_11_GPIO1_IO11 0x401F80E8U, 0x5U, 0, 0, 0x401F82D8U |
#define | IOMUXC_GPIO_AD_B0_11_XBAR1_IN23 0x401F80E8U, 0x6U, 0x401F863CU, 0x1U, 0x401F82D8U |
#define | IOMUXC_GPIO_AD_B0_11_ENET_1588_EVENT0_IN 0x401F80E8U, 0x7U, 0x401F8444U, 0x1U, 0x401F82D8U |
#define | IOMUXC_GPIO_AD_B0_12_LPI2C4_SCL 0x401F80ECU, 0x0U, 0x401F84E4U, 0x1U, 0x401F82DCU |
#define | IOMUXC_GPIO_AD_B0_12_CCM_PMIC_READY 0x401F80ECU, 0x1U, 0x401F83FCU, 0x1U, 0x401F82DCU |
#define | IOMUXC_GPIO_AD_B0_12_LPUART1_TXD 0x401F80ECU, 0x2U, 0, 0, 0x401F82DCU |
#define | IOMUXC_GPIO_AD_B0_12_WDOG2_B 0x401F80ECU, 0x3U, 0, 0, 0x401F82DCU |
#define | IOMUXC_GPIO_AD_B0_12_FLEXPWM1_PWM2_X 0x401F80ECU, 0x4U, 0, 0, 0x401F82DCU |
#define | IOMUXC_GPIO_AD_B0_12_GPIO1_IO12 0x401F80ECU, 0x5U, 0, 0, 0x401F82DCU |
#define | IOMUXC_GPIO_AD_B0_12_ENET_1588_EVENT1_OUT 0x401F80ECU, 0x6U, 0, 0, 0x401F82DCU |
#define | IOMUXC_GPIO_AD_B0_12_NMI 0x401F80ECU, 0x7U, 0x401F8568U, 0x0U, 0x401F82DCU |
#define | IOMUXC_GPIO_AD_B0_13_LPI2C4_SDA 0x401F80F0U, 0x0U, 0x401F84E8U, 0x1U, 0x401F82E0U |
#define | IOMUXC_GPIO_AD_B0_13_GPT1_CLK 0x401F80F0U, 0x1U, 0, 0, 0x401F82E0U |
#define | IOMUXC_GPIO_AD_B0_13_LPUART1_RXD 0x401F80F0U, 0x2U, 0, 0, 0x401F82E0U |
#define | IOMUXC_GPIO_AD_B0_13_EWM_OUT_B 0x401F80F0U, 0x3U, 0, 0, 0x401F82E0U |
#define | IOMUXC_GPIO_AD_B0_13_FLEXPWM1_PWM3_X 0x401F80F0U, 0x4U, 0, 0, 0x401F82E0U |
#define | IOMUXC_GPIO_AD_B0_13_GPIO1_IO13 0x401F80F0U, 0x5U, 0, 0, 0x401F82E0U |
#define | IOMUXC_GPIO_AD_B0_13_ENET_1588_EVENT1_IN 0x401F80F0U, 0x6U, 0, 0, 0x401F82E0U |
#define | IOMUXC_GPIO_AD_B0_13_REF_CLK_24M 0x401F80F0U, 0x7U, 0, 0, 0x401F82E0U |
#define | IOMUXC_GPIO_AD_B0_14_USB_OTG2_OC 0x401F80F4U, 0x0U, 0x401F85CCU, 0x0U, 0x401F82E4U |
#define | IOMUXC_GPIO_AD_B0_14_XBAR1_IN24 0x401F80F4U, 0x1U, 0x401F8640U, 0x1U, 0x401F82E4U |
#define | IOMUXC_GPIO_AD_B0_14_LPUART1_CTS_B 0x401F80F4U, 0x2U, 0, 0, 0x401F82E4U |
#define | IOMUXC_GPIO_AD_B0_14_ENET_1588_EVENT0_OUT 0x401F80F4U, 0x3U, 0, 0, 0x401F82E4U |
#define | IOMUXC_GPIO_AD_B0_14_CSI_VSYNC 0x401F80F4U, 0x4U, 0x401F8428U, 0x0U, 0x401F82E4U |
#define | IOMUXC_GPIO_AD_B0_14_GPIO1_IO14 0x401F80F4U, 0x5U, 0, 0, 0x401F82E4U |
#define | IOMUXC_GPIO_AD_B0_14_FLEXCAN2_TX 0x401F80F4U, 0x6U, 0, 0, 0x401F82E4U |
#define | IOMUXC_GPIO_AD_B0_15_USB_OTG2_PWR 0x401F80F8U, 0x0U, 0, 0, 0x401F82E8U |
#define | IOMUXC_GPIO_AD_B0_15_XBAR1_IN25 0x401F80F8U, 0x1U, 0x401F8650U, 0x0U, 0x401F82E8U |
#define | IOMUXC_GPIO_AD_B0_15_LPUART1_RTS_B 0x401F80F8U, 0x2U, 0, 0, 0x401F82E8U |
#define | IOMUXC_GPIO_AD_B0_15_ENET_1588_EVENT0_IN 0x401F80F8U, 0x3U, 0x401F8444U, 0x0U, 0x401F82E8U |
#define | IOMUXC_GPIO_AD_B0_15_CSI_HSYNC 0x401F80F8U, 0x4U, 0x401F8420U, 0x0U, 0x401F82E8U |
#define | IOMUXC_GPIO_AD_B0_15_GPIO1_IO15 0x401F80F8U, 0x5U, 0, 0, 0x401F82E8U |
#define | IOMUXC_GPIO_AD_B0_15_FLEXCAN2_RX 0x401F80F8U, 0x6U, 0x401F8450U, 0x2U, 0x401F82E8U |
#define | IOMUXC_GPIO_AD_B0_15_WDOG1_WDOG_RST_B_DEB 0x401F80F8U, 0x7U, 0, 0, 0x401F82E8U |
#define | IOMUXC_GPIO_AD_B1_00_USB_OTG2_ID 0x401F80FCU, 0x0U, 0x401F83F8U, 0x1U, 0x401F82ECU |
#define | IOMUXC_GPIO_AD_B1_00_TMR3_TIMER0 0x401F80FCU, 0x1U, 0x401F857CU, 0x1U, 0x401F82ECU |
#define | IOMUXC_GPIO_AD_B1_00_LPUART2_CTS_B 0x401F80FCU, 0x2U, 0, 0, 0x401F82ECU |
#define | IOMUXC_GPIO_AD_B1_00_LPI2C1_SCL 0x401F80FCU, 0x3U, 0x401F84CCU, 0x1U, 0x401F82ECU |
#define | IOMUXC_GPIO_AD_B1_00_WDOG1_B 0x401F80FCU, 0x4U, 0, 0, 0x401F82ECU |
#define | IOMUXC_GPIO_AD_B1_00_GPIO1_IO16 0x401F80FCU, 0x5U, 0, 0, 0x401F82ECU |
#define | IOMUXC_GPIO_AD_B1_00_USDHC1_WP 0x401F80FCU, 0x6U, 0x401F85D8U, 0x2U, 0x401F82ECU |
#define | IOMUXC_GPIO_AD_B1_00_KPP_ROW07 0x401F80FCU, 0x7U, 0, 0, 0x401F82ECU |
#define | IOMUXC_GPIO_AD_B1_01_USB_OTG1_PWR 0x401F8100U, 0x0U, 0, 0, 0x401F82F0U |
#define | IOMUXC_GPIO_AD_B1_01_TMR3_TIMER1 0x401F8100U, 0x1U, 0x401F8580U, 0x0U, 0x401F82F0U |
#define | IOMUXC_GPIO_AD_B1_01_LPUART2_RTS_B 0x401F8100U, 0x2U, 0, 0, 0x401F82F0U |
#define | IOMUXC_GPIO_AD_B1_01_LPI2C1_SDA 0x401F8100U, 0x3U, 0x401F84D0U, 0x1U, 0x401F82F0U |
#define | IOMUXC_GPIO_AD_B1_01_CCM_PMIC_READY 0x401F8100U, 0x4U, 0x401F83FCU, 0x2U, 0x401F82F0U |
#define | IOMUXC_GPIO_AD_B1_01_GPIO1_IO17 0x401F8100U, 0x5U, 0, 0, 0x401F82F0U |
#define | IOMUXC_GPIO_AD_B1_01_USDHC1_VSELECT 0x401F8100U, 0x6U, 0, 0, 0x401F82F0U |
#define | IOMUXC_GPIO_AD_B1_01_KPP_COL07 0x401F8100U, 0x7U, 0, 0, 0x401F82F0U |
#define | IOMUXC_GPIO_AD_B1_02_USB_OTG1_ID 0x401F8104U, 0x0U, 0x401F83F4U, 0x1U, 0x401F82F4U |
#define | IOMUXC_GPIO_AD_B1_02_TMR3_TIMER2 0x401F8104U, 0x1U, 0x401F8584U, 0x1U, 0x401F82F4U |
#define | IOMUXC_GPIO_AD_B1_02_LPUART2_TXD 0x401F8104U, 0x2U, 0x401F8530U, 0x1U, 0x401F82F4U |
#define | IOMUXC_GPIO_AD_B1_02_SPDIF_OUT 0x401F8104U, 0x3U, 0, 0, 0x401F82F4U |
#define | IOMUXC_GPIO_AD_B1_02_ENET_1588_EVENT2_OUT 0x401F8104U, 0x4U, 0, 0, 0x401F82F4U |
#define | IOMUXC_GPIO_AD_B1_02_GPIO1_IO18 0x401F8104U, 0x5U, 0, 0, 0x401F82F4U |
#define | IOMUXC_GPIO_AD_B1_02_USDHC1_CD_B 0x401F8104U, 0x6U, 0x401F85D4U, 0x1U, 0x401F82F4U |
#define | IOMUXC_GPIO_AD_B1_02_KPP_ROW06 0x401F8104U, 0x7U, 0, 0, 0x401F82F4U |
#define | IOMUXC_GPIO_AD_B1_03_USB_OTG1_OC 0x401F8108U, 0x0U, 0x401F85D0U, 0x1U, 0x401F82F8U |
#define | IOMUXC_GPIO_AD_B1_03_TMR3_TIMER3 0x401F8108U, 0x1U, 0x401F8588U, 0x1U, 0x401F82F8U |
#define | IOMUXC_GPIO_AD_B1_03_LPUART2_RXD 0x401F8108U, 0x2U, 0x401F852CU, 0x1U, 0x401F82F8U |
#define | IOMUXC_GPIO_AD_B1_03_SPDIF_IN 0x401F8108U, 0x3U, 0x401F85C8U, 0x0U, 0x401F82F8U |
#define | IOMUXC_GPIO_AD_B1_03_ENET_1588_EVENT2_IN 0x401F8108U, 0x4U, 0, 0, 0x401F82F8U |
#define | IOMUXC_GPIO_AD_B1_03_GPIO1_IO19 0x401F8108U, 0x5U, 0, 0, 0x401F82F8U |
#define | IOMUXC_GPIO_AD_B1_03_USDHC2_CD_B 0x401F8108U, 0x6U, 0x401F85E0U, 0x0U, 0x401F82F8U |
#define | IOMUXC_GPIO_AD_B1_03_KPP_COL06 0x401F8108U, 0x7U, 0, 0, 0x401F82F8U |
#define | IOMUXC_GPIO_AD_B1_04_FLEXSPI_B_DATA3 0x401F810CU, 0x0U, 0x401F84C4U, 0x1U, 0x401F82FCU |
#define | IOMUXC_GPIO_AD_B1_04_ENET_MDC 0x401F810CU, 0x1U, 0, 0, 0x401F82FCU |
#define | IOMUXC_GPIO_AD_B1_04_LPUART3_CTS_B 0x401F810CU, 0x2U, 0x401F8534U, 0x1U, 0x401F82FCU |
#define | IOMUXC_GPIO_AD_B1_04_SPDIF_SR_CLK 0x401F810CU, 0x3U, 0, 0, 0x401F82FCU |
#define | IOMUXC_GPIO_AD_B1_04_CSI_PIXCLK 0x401F810CU, 0x4U, 0x401F8424U, 0x0U, 0x401F82FCU |
#define | IOMUXC_GPIO_AD_B1_04_GPIO1_IO20 0x401F810CU, 0x5U, 0, 0, 0x401F82FCU |
#define | IOMUXC_GPIO_AD_B1_04_USDHC2_DATA0 0x401F810CU, 0x6U, 0x401F85E8U, 0x1U, 0x401F82FCU |
#define | IOMUXC_GPIO_AD_B1_04_KPP_ROW05 0x401F810CU, 0x7U, 0, 0, 0x401F82FCU |
#define | IOMUXC_GPIO_AD_B1_05_FLEXSPI_B_DATA2 0x401F8110U, 0x0U, 0x401F84C0U, 0x1U, 0x401F8300U |
#define | IOMUXC_GPIO_AD_B1_05_ENET_MDIO 0x401F8110U, 0x1U, 0x401F8430U, 0x0U, 0x401F8300U |
#define | IOMUXC_GPIO_AD_B1_05_LPUART3_RTS_B 0x401F8110U, 0x2U, 0, 0, 0x401F8300U |
#define | IOMUXC_GPIO_AD_B1_05_SPDIF_OUT 0x401F8110U, 0x3U, 0, 0, 0x401F8300U |
#define | IOMUXC_GPIO_AD_B1_05_CSI_MCLK 0x401F8110U, 0x4U, 0, 0, 0x401F8300U |
#define | IOMUXC_GPIO_AD_B1_05_GPIO1_IO21 0x401F8110U, 0x5U, 0, 0, 0x401F8300U |
#define | IOMUXC_GPIO_AD_B1_05_USDHC2_DATA1 0x401F8110U, 0x6U, 0x401F85ECU, 0x1U, 0x401F8300U |
#define | IOMUXC_GPIO_AD_B1_05_KPP_COL05 0x401F8110U, 0x7U, 0, 0, 0x401F8300U |
#define | IOMUXC_GPIO_AD_B1_06_FLEXSPI_B_DATA1 0x401F8114U, 0x0U, 0x401F84BCU, 0x1U, 0x401F8304U |
#define | IOMUXC_GPIO_AD_B1_06_LPI2C3_SDA 0x401F8114U, 0x1U, 0x401F84E0U, 0x2U, 0x401F8304U |
#define | IOMUXC_GPIO_AD_B1_06_LPUART3_TXD 0x401F8114U, 0x2U, 0x401F853CU, 0x0U, 0x401F8304U |
#define | IOMUXC_GPIO_AD_B1_06_SPDIF_LOCK 0x401F8114U, 0x3U, 0, 0, 0x401F8304U |
#define | IOMUXC_GPIO_AD_B1_06_CSI_VSYNC 0x401F8114U, 0x4U, 0x401F8428U, 0x1U, 0x401F8304U |
#define | IOMUXC_GPIO_AD_B1_06_GPIO1_IO22 0x401F8114U, 0x5U, 0, 0, 0x401F8304U |
#define | IOMUXC_GPIO_AD_B1_06_USDHC2_DATA2 0x401F8114U, 0x6U, 0x401F85F0U, 0x1U, 0x401F8304U |
#define | IOMUXC_GPIO_AD_B1_06_KPP_ROW04 0x401F8114U, 0x7U, 0, 0, 0x401F8304U |
#define | IOMUXC_GPIO_AD_B1_07_FLEXSPI_B_DATA0 0x401F8118U, 0x0U, 0x401F84B8U, 0x1U, 0x401F8308U |
#define | IOMUXC_GPIO_AD_B1_07_LPI2C3_SCL 0x401F8118U, 0x1U, 0x401F84DCU, 0x2U, 0x401F8308U |
#define | IOMUXC_GPIO_AD_B1_07_LPUART3_RXD 0x401F8118U, 0x2U, 0x401F8538U, 0x0U, 0x401F8308U |
#define | IOMUXC_GPIO_AD_B1_07_SPDIF_EXT_CLK 0x401F8118U, 0x3U, 0, 0, 0x401F8308U |
#define | IOMUXC_GPIO_AD_B1_07_CSI_HSYNC 0x401F8118U, 0x4U, 0x401F8420U, 0x1U, 0x401F8308U |
#define | IOMUXC_GPIO_AD_B1_07_GPIO1_IO23 0x401F8118U, 0x5U, 0, 0, 0x401F8308U |
#define | IOMUXC_GPIO_AD_B1_07_USDHC2_DATA3 0x401F8118U, 0x6U, 0x401F85F4U, 0x1U, 0x401F8308U |
#define | IOMUXC_GPIO_AD_B1_07_KPP_COL04 0x401F8118U, 0x7U, 0, 0, 0x401F8308U |
#define | IOMUXC_GPIO_AD_B1_08_FLEXSPI_A_SS1_B 0x401F811CU, 0x0U, 0, 0, 0x401F830CU |
#define | IOMUXC_GPIO_AD_B1_08_FLEXPWM4_PWM0_A 0x401F811CU, 0x1U, 0x401F8494U, 0x1U, 0x401F830CU |
#define | IOMUXC_GPIO_AD_B1_08_FLEXCAN1_TX 0x401F811CU, 0x2U, 0, 0, 0x401F830CU |
#define | IOMUXC_GPIO_AD_B1_08_CCM_PMIC_READY 0x401F811CU, 0x3U, 0x401F83FCU, 0x3U, 0x401F830CU |
#define | IOMUXC_GPIO_AD_B1_08_CSI_DATA09 0x401F811CU, 0x4U, 0x401F841CU, 0x0U, 0x401F830CU |
#define | IOMUXC_GPIO_AD_B1_08_GPIO1_IO24 0x401F811CU, 0x5U, 0, 0, 0x401F830CU |
#define | IOMUXC_GPIO_AD_B1_08_USDHC2_CMD 0x401F811CU, 0x6U, 0x401F85E4U, 0x1U, 0x401F830CU |
#define | IOMUXC_GPIO_AD_B1_08_KPP_ROW03 0x401F811CU, 0x7U, 0, 0, 0x401F830CU |
#define | IOMUXC_GPIO_AD_B1_09_FLEXSPI_A_DQS 0x401F8120U, 0x0U, 0x401F84A4U, 0x1U, 0x401F8310U |
#define | IOMUXC_GPIO_AD_B1_09_FLEXPWM4_PWM1_A 0x401F8120U, 0x1U, 0x401F8498U, 0x1U, 0x401F8310U |
#define | IOMUXC_GPIO_AD_B1_09_FLEXCAN1_RX 0x401F8120U, 0x2U, 0x401F844CU, 0x2U, 0x401F8310U |
#define | IOMUXC_GPIO_AD_B1_09_SAI1_MCLK 0x401F8120U, 0x3U, 0x401F858CU, 0x1U, 0x401F8310U |
#define | IOMUXC_GPIO_AD_B1_09_CSI_DATA08 0x401F8120U, 0x4U, 0x401F8418U, 0x0U, 0x401F8310U |
#define | IOMUXC_GPIO_AD_B1_09_GPIO1_IO25 0x401F8120U, 0x5U, 0, 0, 0x401F8310U |
#define | IOMUXC_GPIO_AD_B1_09_USDHC2_CLK 0x401F8120U, 0x6U, 0x401F85DCU, 0x1U, 0x401F8310U |
#define | IOMUXC_GPIO_AD_B1_09_KPP_COL03 0x401F8120U, 0x7U, 0, 0, 0x401F8310U |
#define | IOMUXC_GPIO_AD_B1_10_FLEXSPI_A_DATA3 0x401F8124U, 0x0U, 0x401F84B4U, 0x1U, 0x401F8314U |
#define | IOMUXC_GPIO_AD_B1_10_WDOG1_B 0x401F8124U, 0x1U, 0, 0, 0x401F8314U |
#define | IOMUXC_GPIO_AD_B1_10_LPUART8_TXD 0x401F8124U, 0x2U, 0x401F8564U, 0x1U, 0x401F8314U |
#define | IOMUXC_GPIO_AD_B1_10_SAI1_RX_SYNC 0x401F8124U, 0x3U, 0x401F85A4U, 0x1U, 0x401F8314U |
#define | IOMUXC_GPIO_AD_B1_10_CSI_DATA07 0x401F8124U, 0x4U, 0x401F8414U, 0x0U, 0x401F8314U |
#define | IOMUXC_GPIO_AD_B1_10_GPIO1_IO26 0x401F8124U, 0x5U, 0, 0, 0x401F8314U |
#define | IOMUXC_GPIO_AD_B1_10_USDHC2_WP 0x401F8124U, 0x6U, 0x401F8608U, 0x1U, 0x401F8314U |
#define | IOMUXC_GPIO_AD_B1_10_KPP_ROW02 0x401F8124U, 0x7U, 0, 0, 0x401F8314U |
#define | IOMUXC_GPIO_AD_B1_11_FLEXSPI_A_DATA2 0x401F8128U, 0x0U, 0x401F84B0U, 0x1U, 0x401F8318U |
#define | IOMUXC_GPIO_AD_B1_11_EWM_OUT_B 0x401F8128U, 0x1U, 0, 0, 0x401F8318U |
#define | IOMUXC_GPIO_AD_B1_11_LPUART8_RXD 0x401F8128U, 0x2U, 0x401F8560U, 0x1U, 0x401F8318U |
#define | IOMUXC_GPIO_AD_B1_11_SAI1_RX_BCLK 0x401F8128U, 0x3U, 0x401F8590U, 0x1U, 0x401F8318U |
#define | IOMUXC_GPIO_AD_B1_11_CSI_DATA06 0x401F8128U, 0x4U, 0x401F8410U, 0x0U, 0x401F8318U |
#define | IOMUXC_GPIO_AD_B1_11_GPIO1_IO27 0x401F8128U, 0x5U, 0, 0, 0x401F8318U |
#define | IOMUXC_GPIO_AD_B1_11_USDHC2_RESET_B 0x401F8128U, 0x6U, 0, 0, 0x401F8318U |
#define | IOMUXC_GPIO_AD_B1_11_KPP_COL02 0x401F8128U, 0x7U, 0, 0, 0x401F8318U |
#define | IOMUXC_GPIO_AD_B1_12_FLEXSPI_A_DATA1 0x401F812CU, 0x0U, 0x401F84ACU, 0x1U, 0x401F831CU |
#define | IOMUXC_GPIO_AD_B1_12_ACMP1_OUT 0x401F812CU, 0x1U, 0, 0, 0x401F831CU |
#define | IOMUXC_GPIO_AD_B1_12_LPSPI3_PCS0 0x401F812CU, 0x2U, 0x401F850CU, 0x1U, 0x401F831CU |
#define | IOMUXC_GPIO_AD_B1_12_SAI1_RX_DATA00 0x401F812CU, 0x3U, 0x401F8594U, 0x1U, 0x401F831CU |
#define | IOMUXC_GPIO_AD_B1_12_CSI_DATA05 0x401F812CU, 0x4U, 0x401F840CU, 0x0U, 0x401F831CU |
#define | IOMUXC_GPIO_AD_B1_12_GPIO1_IO28 0x401F812CU, 0x5U, 0, 0, 0x401F831CU |
#define | IOMUXC_GPIO_AD_B1_12_USDHC2_DATA4 0x401F812CU, 0x6U, 0x401F85F8U, 0x1U, 0x401F831CU |
#define | IOMUXC_GPIO_AD_B1_12_KPP_ROW01 0x401F812CU, 0x7U, 0, 0, 0x401F831CU |
#define | IOMUXC_GPIO_AD_B1_13_FLEXSPI_A_DATA00 0x401F8130U, 0x0U, 0x401F84A8U, 0x1U, 0x401F8320U |
#define | IOMUXC_GPIO_AD_B1_13_ACMP2_OUT 0x401F8130U, 0x1U, 0, 0, 0x401F8320U |
#define | IOMUXC_GPIO_AD_B1_13_LPSPI3_SDI 0x401F8130U, 0x2U, 0x401F8514U, 0x1U, 0x401F8320U |
#define | IOMUXC_GPIO_AD_B1_13_SAI1_TX_DATA00 0x401F8130U, 0x3U, 0, 0, 0x401F8320U |
#define | IOMUXC_GPIO_AD_B1_13_CSI_DATA04 0x401F8130U, 0x4U, 0x401F8408U, 0x0U, 0x401F8320U |
#define | IOMUXC_GPIO_AD_B1_13_GPIO1_IO29 0x401F8130U, 0x5U, 0, 0, 0x401F8320U |
#define | IOMUXC_GPIO_AD_B1_13_USDHC2_DATA5 0x401F8130U, 0x6U, 0x401F85FCU, 0x1U, 0x401F8320U |
#define | IOMUXC_GPIO_AD_B1_13_KPP_COL01 0x401F8130U, 0x7U, 0, 0, 0x401F8320U |
#define | IOMUXC_GPIO_AD_B1_14_FLEXSPI_A_SCLK 0x401F8134U, 0x0U, 0x401F84C8U, 0x1U, 0x401F8324U |
#define | IOMUXC_GPIO_AD_B1_14_ACMP3_OUT 0x401F8134U, 0x1U, 0, 0, 0x401F8324U |
#define | IOMUXC_GPIO_AD_B1_14_LPSPI3_SDO 0x401F8134U, 0x2U, 0x401F8518U, 0x1U, 0x401F8324U |
#define | IOMUXC_GPIO_AD_B1_14_SAI1_TX_BCLK 0x401F8134U, 0x3U, 0x401F85A8U, 0x1U, 0x401F8324U |
#define | IOMUXC_GPIO_AD_B1_14_CSI_DATA03 0x401F8134U, 0x4U, 0x401F8404U, 0x0U, 0x401F8324U |
#define | IOMUXC_GPIO_AD_B1_14_GPIO1_IO30 0x401F8134U, 0x5U, 0, 0, 0x401F8324U |
#define | IOMUXC_GPIO_AD_B1_14_USDHC2_DATA6 0x401F8134U, 0x6U, 0x401F8600U, 0x1U, 0x401F8324U |
#define | IOMUXC_GPIO_AD_B1_14_KPP_ROW00 0x401F8134U, 0x7U, 0, 0, 0x401F8324U |
#define | IOMUXC_GPIO_AD_B1_15_FLEXSPI_A_SS0_B 0x401F8138U, 0x0U, 0, 0, 0x401F8328U |
#define | IOMUXC_GPIO_AD_B1_15_ACMP4_OUT 0x401F8138U, 0x1U, 0, 0, 0x401F8328U |
#define | IOMUXC_GPIO_AD_B1_15_LPSPI3_SCK 0x401F8138U, 0x2U, 0, 0, 0x401F8328U |
#define | IOMUXC_GPIO_AD_B1_15_SAI1_TX_SYNC 0x401F8138U, 0x3U, 0x401F85ACU, 0x1U, 0x401F8328U |
#define | IOMUXC_GPIO_AD_B1_15_CSI_DATA02 0x401F8138U, 0x4U, 0x401F8400U, 0x0U, 0x401F8328U |
#define | IOMUXC_GPIO_AD_B1_15_GPIO1_IO31 0x401F8138U, 0x5U, 0, 0, 0x401F8328U |
#define | IOMUXC_GPIO_AD_B1_15_USDHC2_DATA7 0x401F8138U, 0x6U, 0x401F8604U, 0x1U, 0x401F8328U |
#define | IOMUXC_GPIO_AD_B1_15_KPP_COL00 0x401F8138U, 0x7U, 0, 0, 0x401F8328U |
#define | IOMUXC_GPIO_B0_00_LCD_CLK 0x401F813CU, 0x0U, 0, 0, 0x401F832CU |
#define | IOMUXC_GPIO_B0_00_TMR1_TIMER0 0x401F813CU, 0x1U, 0, 0, 0x401F832CU |
#define | IOMUXC_GPIO_B0_00_MQS_RIGHT 0x401F813CU, 0x2U, 0, 0, 0x401F832CU |
#define | IOMUXC_GPIO_B0_00_LPSPI4_PCS0 0x401F813CU, 0x3U, 0x401F851CU, 0x0U, 0x401F832CU |
#define | IOMUXC_GPIO_B0_00_FLEXIO2_D00 0x401F813CU, 0x4U, 0, 0, 0x401F832CU |
#define | IOMUXC_GPIO_B0_00_GPIO2_IO00 0x401F813CU, 0x5U, 0, 0, 0x401F832CU |
#define | IOMUXC_GPIO_B0_00_SEMC_CSX1 0x401F813CU, 0x6U, 0, 0, 0x401F832CU |
#define | IOMUXC_GPIO_B0_01_LCD_ENABLE 0x401F8140U, 0x0U, 0, 0, 0x401F8330U |
#define | IOMUXC_GPIO_B0_01_TMR1_TIMER1 0x401F8140U, 0x1U, 0, 0, 0x401F8330U |
#define | IOMUXC_GPIO_B0_01_MQS_LEFT 0x401F8140U, 0x2U, 0, 0, 0x401F8330U |
#define | IOMUXC_GPIO_B0_01_LPSPI4_SDI 0x401F8140U, 0x3U, 0x401F8524U, 0x0U, 0x401F8330U |
#define | IOMUXC_GPIO_B0_01_FLEXIO2_D01 0x401F8140U, 0x4U, 0, 0, 0x401F8330U |
#define | IOMUXC_GPIO_B0_01_GPIO2_IO01 0x401F8140U, 0x5U, 0, 0, 0x401F8330U |
#define | IOMUXC_GPIO_B0_01_SEMC_CSX2 0x401F8140U, 0x6U, 0, 0, 0x401F8330U |
#define | IOMUXC_GPIO_B0_02_LCD_HSYNC 0x401F8144U, 0x0U, 0, 0, 0x401F8334U |
#define | IOMUXC_GPIO_B0_02_TMR1_TIMER2 0x401F8144U, 0x1U, 0, 0, 0x401F8334U |
#define | IOMUXC_GPIO_B0_02_FLEXCAN1_TX 0x401F8144U, 0x2U, 0, 0, 0x401F8334U |
#define | IOMUXC_GPIO_B0_02_LPSPI4_SDO 0x401F8144U, 0x3U, 0x401F8528U, 0x0U, 0x401F8334U |
#define | IOMUXC_GPIO_B0_02_FLEXIO2_D02 0x401F8144U, 0x4U, 0, 0, 0x401F8334U |
#define | IOMUXC_GPIO_B0_02_GPIO2_IO02 0x401F8144U, 0x5U, 0, 0, 0x401F8334U |
#define | IOMUXC_GPIO_B0_02_SEMC_CSX3 0x401F8144U, 0x6U, 0, 0, 0x401F8334U |
#define | IOMUXC_GPIO_B0_03_LCD_VSYNC 0x401F8148U, 0x0U, 0, 0, 0x401F8338U |
#define | IOMUXC_GPIO_B0_03_TMR2_TIMER0 0x401F8148U, 0x1U, 0x401F856CU, 0x1U, 0x401F8338U |
#define | IOMUXC_GPIO_B0_03_FLEXCAN1_RX 0x401F8148U, 0x2U, 0x401F844CU, 0x3U, 0x401F8338U |
#define | IOMUXC_GPIO_B0_03_LPSPI4_SCK 0x401F8148U, 0x3U, 0x401F8520U, 0x0U, 0x401F8338U |
#define | IOMUXC_GPIO_B0_03_FLEXIO2_D03 0x401F8148U, 0x4U, 0, 0, 0x401F8338U |
#define | IOMUXC_GPIO_B0_03_GPIO2_IO03 0x401F8148U, 0x5U, 0, 0, 0x401F8338U |
#define | IOMUXC_GPIO_B0_03_WDOG2_RESET_B_DEB 0x401F8148U, 0x6U, 0, 0, 0x401F8338U |
#define | IOMUXC_GPIO_B0_04_LCD_DATA00 0x401F814CU, 0x0U, 0, 0, 0x401F833CU |
#define | IOMUXC_GPIO_B0_04_TMR2_TIMER1 0x401F814CU, 0x1U, 0x401F8570U, 0x1U, 0x401F833CU |
#define | IOMUXC_GPIO_B0_04_LPI2C2_SCL 0x401F814CU, 0x2U, 0x401F84D4U, 0x1U, 0x401F833CU |
#define | IOMUXC_GPIO_B0_04_ARM_TRACE00 0x401F814CU, 0x3U, 0, 0, 0x401F833CU |
#define | IOMUXC_GPIO_B0_04_FLEXIO2_D04 0x401F814CU, 0x4U, 0, 0, 0x401F833CU |
#define | IOMUXC_GPIO_B0_04_GPIO2_IO04 0x401F814CU, 0x5U, 0, 0, 0x401F833CU |
#define | IOMUXC_GPIO_B0_04_SRC_BT_CFG00 0x401F814CU, 0x6U, 0, 0, 0x401F833CU |
#define | IOMUXC_GPIO_B0_05_LCD_DATA01 0x401F8150U, 0x0U, 0, 0, 0x401F8340U |
#define | IOMUXC_GPIO_B0_05_TMR2_TIMER2 0x401F8150U, 0x1U, 0x401F8574U, 0x1U, 0x401F8340U |
#define | IOMUXC_GPIO_B0_05_LPI2C2_SDA 0x401F8150U, 0x2U, 0x401F84D8U, 0x1U, 0x401F8340U |
#define | IOMUXC_GPIO_B0_05_ARM_TRACE01 0x401F8150U, 0x3U, 0, 0, 0x401F8340U |
#define | IOMUXC_GPIO_B0_05_FLEXIO2_D05 0x401F8150U, 0x4U, 0, 0, 0x401F8340U |
#define | IOMUXC_GPIO_B0_05_GPIO2_IO05 0x401F8150U, 0x5U, 0, 0, 0x401F8340U |
#define | IOMUXC_GPIO_B0_05_SRC_BT_CFG01 0x401F8150U, 0x6U, 0, 0, 0x401F8340U |
#define | IOMUXC_GPIO_B0_06_LCD_DATA02 0x401F8154U, 0x0U, 0, 0, 0x401F8344U |
#define | IOMUXC_GPIO_B0_06_TMR3_TIMER0 0x401F8154U, 0x1U, 0x401F857CU, 0x2U, 0x401F8344U |
#define | IOMUXC_GPIO_B0_06_FLEXPWM2_PWM0_A 0x401F8154U, 0x2U, 0x401F8478U, 0x1U, 0x401F8344U |
#define | IOMUXC_GPIO_B0_06_ARM_TRACE02 0x401F8154U, 0x3U, 0, 0, 0x401F8344U |
#define | IOMUXC_GPIO_B0_06_FLEXIO2_D06 0x401F8154U, 0x4U, 0, 0, 0x401F8344U |
#define | IOMUXC_GPIO_B0_06_GPIO2_IO06 0x401F8154U, 0x5U, 0, 0, 0x401F8344U |
#define | IOMUXC_GPIO_B0_06_SRC_BT_CFG02 0x401F8154U, 0x6U, 0, 0, 0x401F8344U |
#define | IOMUXC_GPIO_B0_07_LCD_DATA03 0x401F8158U, 0x0U, 0, 0, 0x401F8348U |
#define | IOMUXC_GPIO_B0_07_TMR3_TIMER1 0x401F8158U, 0x1U, 0x401F8580U, 0x2U, 0x401F8348U |
#define | IOMUXC_GPIO_B0_07_FLEXPWM2_PWM0_B 0x401F8158U, 0x2U, 0x401F8488U, 0x1U, 0x401F8348U |
#define | IOMUXC_GPIO_B0_07_ARM_TRACE03 0x401F8158U, 0x3U, 0, 0, 0x401F8348U |
#define | IOMUXC_GPIO_B0_07_FLEXIO2_D07 0x401F8158U, 0x4U, 0, 0, 0x401F8348U |
#define | IOMUXC_GPIO_B0_07_GPIO2_IO07 0x401F8158U, 0x5U, 0, 0, 0x401F8348U |
#define | IOMUXC_GPIO_B0_07_SRC_BT_CFG03 0x401F8158U, 0x6U, 0, 0, 0x401F8348U |
#define | IOMUXC_GPIO_B0_08_LCD_DATA04 0x401F815CU, 0x0U, 0, 0, 0x401F834CU |
#define | IOMUXC_GPIO_B0_08_TMR3_TIMER2 0x401F815CU, 0x1U, 0x401F8584U, 0x2U, 0x401F834CU |
#define | IOMUXC_GPIO_B0_08_FLEXPWM2_PWM1_A 0x401F815CU, 0x2U, 0x401F847CU, 0x1U, 0x401F834CU |
#define | IOMUXC_GPIO_B0_08_LPUART3_TXD 0x401F815CU, 0x3U, 0x401F853CU, 0x2U, 0x401F834CU |
#define | IOMUXC_GPIO_B0_08_FLEXIO2_D08 0x401F815CU, 0x4U, 0, 0, 0x401F834CU |
#define | IOMUXC_GPIO_B0_08_GPIO2_IO08 0x401F815CU, 0x5U, 0, 0, 0x401F834CU |
#define | IOMUXC_GPIO_B0_08_SRC_BT_CFG04 0x401F815CU, 0x6U, 0, 0, 0x401F834CU |
#define | IOMUXC_GPIO_B0_09_LCD_DATA05 0x401F8160U, 0x0U, 0, 0, 0x401F8350U |
#define | IOMUXC_GPIO_B0_09_TMR4_TIMER0 0x401F8160U, 0x1U, 0, 0, 0x401F8350U |
#define | IOMUXC_GPIO_B0_09_FLEXPWM2_PWM1_B 0x401F8160U, 0x2U, 0x401F848CU, 0x1U, 0x401F8350U |
#define | IOMUXC_GPIO_B0_09_LPUART3_RXD 0x401F8160U, 0x3U, 0x401F8538U, 0x2U, 0x401F8350U |
#define | IOMUXC_GPIO_B0_09_FLEXIO2_D09 0x401F8160U, 0x4U, 0, 0, 0x401F8350U |
#define | IOMUXC_GPIO_B0_09_GPIO2_IO09 0x401F8160U, 0x5U, 0, 0, 0x401F8350U |
#define | IOMUXC_GPIO_B0_09_SRC_BT_CFG05 0x401F8160U, 0x6U, 0, 0, 0x401F8350U |
#define | IOMUXC_GPIO_B0_10_LCD_DATA06 0x401F8164U, 0x0U, 0, 0, 0x401F8354U |
#define | IOMUXC_GPIO_B0_10_TMR4_TIMER1 0x401F8164U, 0x1U, 0, 0, 0x401F8354U |
#define | IOMUXC_GPIO_B0_10_FLEXPWM2_PWM2_A 0x401F8164U, 0x2U, 0x401F8480U, 0x1U, 0x401F8354U |
#define | IOMUXC_GPIO_B0_10_SAI1_TX_DATA03 0x401F8164U, 0x3U, 0x401F8598U, 0x1U, 0x401F8354U |
#define | IOMUXC_GPIO_B0_10_FLEXIO2_D10 0x401F8164U, 0x4U, 0, 0, 0x401F8354U |
#define | IOMUXC_GPIO_B0_10_GPIO2_IO10 0x401F8164U, 0x5U, 0, 0, 0x401F8354U |
#define | IOMUXC_GPIO_B0_10_SRC_BT_CFG06 0x401F8164U, 0x6U, 0, 0, 0x401F8354U |
#define | IOMUXC_GPIO_B0_11_LCD_DATA07 0x401F8168U, 0x0U, 0, 0, 0x401F8358U |
#define | IOMUXC_GPIO_B0_11_TMR4_TIMER2 0x401F8168U, 0x1U, 0, 0, 0x401F8358U |
#define | IOMUXC_GPIO_B0_11_FLEXPWM2_PWM2_B 0x401F8168U, 0x2U, 0x401F8490U, 0x1U, 0x401F8358U |
#define | IOMUXC_GPIO_B0_11_SAI1_TX_DATA02 0x401F8168U, 0x3U, 0x401F859CU, 0x1U, 0x401F8358U |
#define | IOMUXC_GPIO_B0_11_FLEXIO2_D11 0x401F8168U, 0x4U, 0, 0, 0x401F8358U |
#define | IOMUXC_GPIO_B0_11_GPIO2_IO11 0x401F8168U, 0x5U, 0, 0, 0x401F8358U |
#define | IOMUXC_GPIO_B0_11_SRC_BT_CFG07 0x401F8168U, 0x6U, 0, 0, 0x401F8358U |
#define | IOMUXC_GPIO_B0_12_LCD_DATA08 0x401F816CU, 0x0U, 0, 0, 0x401F835CU |
#define | IOMUXC_GPIO_B0_12_XBAR1_INOUT10 0x401F816CU, 0x1U, 0, 0, 0x401F835CU |
#define | IOMUXC_GPIO_B0_12_ARM_TRACE_CLK 0x401F816CU, 0x2U, 0, 0, 0x401F835CU |
#define | IOMUXC_GPIO_B0_12_SAI1_TX_DATA01 0x401F816CU, 0x3U, 0x401F85A0U, 0x1U, 0x401F835CU |
#define | IOMUXC_GPIO_B0_12_FLEXIO2_D12 0x401F816CU, 0x4U, 0, 0, 0x401F835CU |
#define | IOMUXC_GPIO_B0_12_GPIO2_IO12 0x401F816CU, 0x5U, 0, 0, 0x401F835CU |
#define | IOMUXC_GPIO_B0_12_SRC_BT_CFG08 0x401F816CU, 0x6U, 0, 0, 0x401F835CU |
#define | IOMUXC_GPIO_B0_13_LCD_DATA09 0x401F8170U, 0x0U, 0, 0, 0x401F8360U |
#define | IOMUXC_GPIO_B0_13_XBAR1_INOUT11 0x401F8170U, 0x1U, 0, 0, 0x401F8360U |
#define | IOMUXC_GPIO_B0_13_ARM_TRACE_SWO 0x401F8170U, 0x2U, 0, 0, 0x401F8360U |
#define | IOMUXC_GPIO_B0_13_SAI1_MCLK 0x401F8170U, 0x3U, 0x401F858CU, 0x2U, 0x401F8360U |
#define | IOMUXC_GPIO_B0_13_FLEXIO2_D13 0x401F8170U, 0x4U, 0, 0, 0x401F8360U |
#define | IOMUXC_GPIO_B0_13_GPIO2_IO13 0x401F8170U, 0x5U, 0, 0, 0x401F8360U |
#define | IOMUXC_GPIO_B0_13_SRC_BT_CFG09 0x401F8170U, 0x6U, 0, 0, 0x401F8360U |
#define | IOMUXC_GPIO_B0_14_LCD_DATA10 0x401F8174U, 0x0U, 0, 0, 0x401F8364U |
#define | IOMUXC_GPIO_B0_14_XBAR1_INOUT12 0x401F8174U, 0x1U, 0, 0, 0x401F8364U |
#define | IOMUXC_GPIO_B0_14_ARM_CM7_TXEV 0x401F8174U, 0x2U, 0, 0, 0x401F8364U |
#define | IOMUXC_GPIO_B0_14_SAI1_RX_SYNC 0x401F8174U, 0x3U, 0x401F85A4U, 0x2U, 0x401F8364U |
#define | IOMUXC_GPIO_B0_14_FLEXIO2_D14 0x401F8174U, 0x4U, 0, 0, 0x401F8364U |
#define | IOMUXC_GPIO_B0_14_GPIO2_IO14 0x401F8174U, 0x5U, 0, 0, 0x401F8364U |
#define | IOMUXC_GPIO_B0_14_SRC_BT_CFG10 0x401F8174U, 0x6U, 0, 0, 0x401F8364U |
#define | IOMUXC_GPIO_B0_15_LCD_DATA11 0x401F8178U, 0x0U, 0, 0, 0x401F8368U |
#define | IOMUXC_GPIO_B0_15_XBAR1_INOUT13 0x401F8178U, 0x1U, 0, 0, 0x401F8368U |
#define | IOMUXC_GPIO_B0_15_ARM_CM7_RXEV 0x401F8178U, 0x2U, 0, 0, 0x401F8368U |
#define | IOMUXC_GPIO_B0_15_SAI1_RX_BCLK 0x401F8178U, 0x3U, 0x401F8590U, 0x2U, 0x401F8368U |
#define | IOMUXC_GPIO_B0_15_FLEXIO2_D15 0x401F8178U, 0x4U, 0, 0, 0x401F8368U |
#define | IOMUXC_GPIO_B0_15_GPIO2_IO15 0x401F8178U, 0x5U, 0, 0, 0x401F8368U |
#define | IOMUXC_GPIO_B0_15_SRC_BT_CFG11 0x401F8178U, 0x6U, 0, 0, 0x401F8368U |
#define | IOMUXC_GPIO_B1_00_LCD_DATA12 0x401F817CU, 0x0U, 0, 0, 0x401F836CU |
#define | IOMUXC_GPIO_B1_00_XBAR1_INOUT14 0x401F817CU, 0x1U, 0x401F8644U, 0x1U, 0x401F836CU |
#define | IOMUXC_GPIO_B1_00_LPUART4_TXD 0x401F817CU, 0x2U, 0x401F8544U, 0x2U, 0x401F836CU |
#define | IOMUXC_GPIO_B1_00_SAI1_RX_DATA00 0x401F817CU, 0x3U, 0x401F8594U, 0x2U, 0x401F836CU |
#define | IOMUXC_GPIO_B1_00_FLEXIO2_D16 0x401F817CU, 0x4U, 0, 0, 0x401F836CU |
#define | IOMUXC_GPIO_B1_00_GPIO2_IO16 0x401F817CU, 0x5U, 0, 0, 0x401F836CU |
#define | IOMUXC_GPIO_B1_00_FLEXPWM1_PWM3_A 0x401F817CU, 0x6U, 0x401F8454U, 0x4U, 0x401F836CU |
#define | IOMUXC_GPIO_B1_01_LCD_DATA13 0x401F8180U, 0x0U, 0, 0, 0x401F8370U |
#define | IOMUXC_GPIO_B1_01_XBAR1_INOUT15 0x401F8180U, 0x1U, 0x401F8648U, 0x1U, 0x401F8370U |
#define | IOMUXC_GPIO_B1_01_LPUART4_RXD 0x401F8180U, 0x2U, 0x401F8540U, 0x2U, 0x401F8370U |
#define | IOMUXC_GPIO_B1_01_SAI1_TX_DATA00 0x401F8180U, 0x3U, 0, 0, 0x401F8370U |
#define | IOMUXC_GPIO_B1_01_FLEXIO2_D17 0x401F8180U, 0x4U, 0, 0, 0x401F8370U |
#define | IOMUXC_GPIO_B1_01_GPIO2_IO17 0x401F8180U, 0x5U, 0, 0, 0x401F8370U |
#define | IOMUXC_GPIO_B1_01_FLEXPWM1_PWM3_B 0x401F8180U, 0x6U, 0x401F8464U, 0x4U, 0x401F8370U |
#define | IOMUXC_GPIO_B1_02_LCD_DATA14 0x401F8184U, 0x0U, 0, 0, 0x401F8374U |
#define | IOMUXC_GPIO_B1_02_XBAR1_INOUT16 0x401F8184U, 0x1U, 0x401F864CU, 0x1U, 0x401F8374U |
#define | IOMUXC_GPIO_B1_02_LPSPI4_PCS2 0x401F8184U, 0x2U, 0, 0, 0x401F8374U |
#define | IOMUXC_GPIO_B1_02_SAI1_TX_BCLK 0x401F8184U, 0x3U, 0x401F85A8U, 0x2U, 0x401F8374U |
#define | IOMUXC_GPIO_B1_02_FLEXIO2_D18 0x401F8184U, 0x4U, 0, 0, 0x401F8374U |
#define | IOMUXC_GPIO_B1_02_GPIO2_IO18 0x401F8184U, 0x5U, 0, 0, 0x401F8374U |
#define | IOMUXC_GPIO_B1_02_FLEXPWM2_PWM3_A 0x401F8184U, 0x6U, 0x401F8474U, 0x4U, 0x401F8374U |
#define | IOMUXC_GPIO_B1_03_LCD_DATA15 0x401F8188U, 0x0U, 0, 0, 0x401F8378U |
#define | IOMUXC_GPIO_B1_03_XBAR1_INOUT17 0x401F8188U, 0x1U, 0x401F862CU, 0x3U, 0x401F8378U |
#define | IOMUXC_GPIO_B1_03_LPSPI4_PCS1 0x401F8188U, 0x2U, 0, 0, 0x401F8378U |
#define | IOMUXC_GPIO_B1_03_SAI1_TX_SYNC 0x401F8188U, 0x3U, 0x401F85ACU, 0x2U, 0x401F8378U |
#define | IOMUXC_GPIO_B1_03_FLEXIO2_D19 0x401F8188U, 0x4U, 0, 0, 0x401F8378U |
#define | IOMUXC_GPIO_B1_03_GPIO2_IO19 0x401F8188U, 0x5U, 0, 0, 0x401F8378U |
#define | IOMUXC_GPIO_B1_03_FLEXPWM2_PWM3_B 0x401F8188U, 0x6U, 0x401F8484U, 0x3U, 0x401F8378U |
#define | IOMUXC_GPIO_B1_04_LCD_DATA16 0x401F818CU, 0x0U, 0, 0, 0x401F837CU |
#define | IOMUXC_GPIO_B1_04_LPSPI4_PCS0 0x401F818CU, 0x1U, 0x401F851CU, 0x1U, 0x401F837CU |
#define | IOMUXC_GPIO_B1_04_CSI_DATA15 0x401F818CU, 0x2U, 0, 0, 0x401F837CU |
#define | IOMUXC_GPIO_B1_04_ENET_RX_DATA00 0x401F818CU, 0x3U, 0x401F8434U, 0x1U, 0x401F837CU |
#define | IOMUXC_GPIO_B1_04_FLEXIO2_D20 0x401F818CU, 0x4U, 0, 0, 0x401F837CU |
#define | IOMUXC_GPIO_B1_04_GPIO2_IO20 0x401F818CU, 0x5U, 0, 0, 0x401F837CU |
#define | IOMUXC_GPIO_B1_05_LCD_DATA17 0x401F8190U, 0x0U, 0, 0, 0x401F8380U |
#define | IOMUXC_GPIO_B1_05_LPSPI4_SDI 0x401F8190U, 0x1U, 0x401F8524U, 0x1U, 0x401F8380U |
#define | IOMUXC_GPIO_B1_05_CSI_DATA14 0x401F8190U, 0x2U, 0, 0, 0x401F8380U |
#define | IOMUXC_GPIO_B1_05_ENET_RX_DATA01 0x401F8190U, 0x3U, 0x401F8438U, 0x1U, 0x401F8380U |
#define | IOMUXC_GPIO_B1_05_FLEXIO2_D21 0x401F8190U, 0x4U, 0, 0, 0x401F8380U |
#define | IOMUXC_GPIO_B1_05_GPIO2_IO21 0x401F8190U, 0x5U, 0, 0, 0x401F8380U |
#define | IOMUXC_GPIO_B1_06_LCD_DATA18 0x401F8194U, 0x0U, 0, 0, 0x401F8384U |
#define | IOMUXC_GPIO_B1_06_LPSPI4_SDO 0x401F8194U, 0x1U, 0x401F8528U, 0x1U, 0x401F8384U |
#define | IOMUXC_GPIO_B1_06_CSI_DATA13 0x401F8194U, 0x2U, 0, 0, 0x401F8384U |
#define | IOMUXC_GPIO_B1_06_ENET_RX_EN 0x401F8194U, 0x3U, 0x401F843CU, 0x1U, 0x401F8384U |
#define | IOMUXC_GPIO_B1_06_FLEXIO2_D22 0x401F8194U, 0x4U, 0, 0, 0x401F8384U |
#define | IOMUXC_GPIO_B1_06_GPIO2_IO22 0x401F8194U, 0x5U, 0, 0, 0x401F8384U |
#define | IOMUXC_GPIO_B1_07_LCD_DATA19 0x401F8198U, 0x0U, 0, 0, 0x401F8388U |
#define | IOMUXC_GPIO_B1_07_LPSPI4_SCK 0x401F8198U, 0x1U, 0x401F8520U, 0x1U, 0x401F8388U |
#define | IOMUXC_GPIO_B1_07_CSI_DATA12 0x401F8198U, 0x2U, 0, 0, 0x401F8388U |
#define | IOMUXC_GPIO_B1_07_ENET_TX_DATA00 0x401F8198U, 0x3U, 0, 0, 0x401F8388U |
#define | IOMUXC_GPIO_B1_07_FLEXIO2_D23 0x401F8198U, 0x4U, 0, 0, 0x401F8388U |
#define | IOMUXC_GPIO_B1_07_GPIO2_IO23 0x401F8198U, 0x5U, 0, 0, 0x401F8388U |
#define | IOMUXC_GPIO_B1_08_LCD_DATA20 0x401F819CU, 0x0U, 0, 0, 0x401F838CU |
#define | IOMUXC_GPIO_B1_08_TMR1_TIMER3 0x401F819CU, 0x1U, 0, 0, 0x401F838CU |
#define | IOMUXC_GPIO_B1_08_CSI_DATA11 0x401F819CU, 0x2U, 0, 0, 0x401F838CU |
#define | IOMUXC_GPIO_B1_08_ENET_TX_DATA01 0x401F819CU, 0x3U, 0, 0, 0x401F838CU |
#define | IOMUXC_GPIO_B1_08_FLEXIO2_D24 0x401F819CU, 0x4U, 0, 0, 0x401F838CU |
#define | IOMUXC_GPIO_B1_08_GPIO2_IO24 0x401F819CU, 0x5U, 0, 0, 0x401F838CU |
#define | IOMUXC_GPIO_B1_08_FLEXCAN2_TX 0x401F819CU, 0x6U, 0, 0, 0x401F838CU |
#define | IOMUXC_GPIO_B1_09_LCD_DATA21 0x401F81A0U, 0x0U, 0, 0, 0x401F8390U |
#define | IOMUXC_GPIO_B1_09_TMR2_TIMER3 0x401F81A0U, 0x1U, 0x401F8578U, 0x1U, 0x401F8390U |
#define | IOMUXC_GPIO_B1_09_CSI_DATA10 0x401F81A0U, 0x2U, 0, 0, 0x401F8390U |
#define | IOMUXC_GPIO_B1_09_ENET_TX_EN 0x401F81A0U, 0x3U, 0, 0, 0x401F8390U |
#define | IOMUXC_GPIO_B1_09_FLEXIO2_D25 0x401F81A0U, 0x4U, 0, 0, 0x401F8390U |
#define | IOMUXC_GPIO_B1_09_GPIO2_IO25 0x401F81A0U, 0x5U, 0, 0, 0x401F8390U |
#define | IOMUXC_GPIO_B1_09_FLEXCAN2_RX 0x401F81A0U, 0x6U, 0x401F8450U, 0x3U, 0x401F8390U |
#define | IOMUXC_GPIO_B1_10_LCD_DATA22 0x401F81A4U, 0x0U, 0, 0, 0x401F8394U |
#define | IOMUXC_GPIO_B1_10_TMR3_TIMER3 0x401F81A4U, 0x1U, 0x401F8588U, 0x2U, 0x401F8394U |
#define | IOMUXC_GPIO_B1_10_CSI_DATA00 0x401F81A4U, 0x2U, 0, 0, 0x401F8394U |
#define | IOMUXC_GPIO_B1_10_ENET_TX_CLK 0x401F81A4U, 0x3U, 0x401F8448U, 0x1U, 0x401F8394U |
#define | IOMUXC_GPIO_B1_10_FLEXIO2_D26 0x401F81A4U, 0x4U, 0, 0, 0x401F8394U |
#define | IOMUXC_GPIO_B1_10_GPIO2_IO26 0x401F81A4U, 0x5U, 0, 0, 0x401F8394U |
#define | IOMUXC_GPIO_B1_10_ENET_REF_CLK 0x401F81A4U, 0x6U, 0x401F842CU, 0x1U, 0x401F8394U |
#define | IOMUXC_GPIO_B1_11_LCD_DATA23 0x401F81A8U, 0x0U, 0, 0, 0x401F8398U |
#define | IOMUXC_GPIO_B1_11_TMR4_TIMER3 0x401F81A8U, 0x1U, 0, 0, 0x401F8398U |
#define | IOMUXC_GPIO_B1_11_CSI_DATA01 0x401F81A8U, 0x2U, 0, 0, 0x401F8398U |
#define | IOMUXC_GPIO_B1_11_ENET_RX_ER 0x401F81A8U, 0x3U, 0x401F8440U, 0x1U, 0x401F8398U |
#define | IOMUXC_GPIO_B1_11_FLEXIO2_D27 0x401F81A8U, 0x4U, 0, 0, 0x401F8398U |
#define | IOMUXC_GPIO_B1_11_GPIO2_IO27 0x401F81A8U, 0x5U, 0, 0, 0x401F8398U |
#define | IOMUXC_GPIO_B1_11_LPSPI4_PCS3 0x401F81A8U, 0x6U, 0, 0, 0x401F8398U |
#define | IOMUXC_GPIO_B1_12_LPUART5_TXD 0x401F81ACU, 0x1U, 0x401F854CU, 0x1U, 0x401F839CU |
#define | IOMUXC_GPIO_B1_12_CSI_PIXCLK 0x401F81ACU, 0x2U, 0x401F8424U, 0x1U, 0x401F839CU |
#define | IOMUXC_GPIO_B1_12_ENET_1588_EVENT0_IN 0x401F81ACU, 0x3U, 0x401F8444U, 0x2U, 0x401F839CU |
#define | IOMUXC_GPIO_B1_12_FLEXIO2_D28 0x401F81ACU, 0x4U, 0, 0, 0x401F839CU |
#define | IOMUXC_GPIO_B1_12_GPIO2_IO28 0x401F81ACU, 0x5U, 0, 0, 0x401F839CU |
#define | IOMUXC_GPIO_B1_12_USDHC1_CD_B 0x401F81ACU, 0x6U, 0x401F85D4U, 0x2U, 0x401F839CU |
#define | IOMUXC_GPIO_B1_13_WDOG1_B 0x401F81B0U, 0x0U, 0, 0, 0x401F83A0U |
#define | IOMUXC_GPIO_B1_13_LPUART5_RXD 0x401F81B0U, 0x1U, 0x401F8548U, 0x1U, 0x401F83A0U |
#define | IOMUXC_GPIO_B1_13_CSI_VSYNC 0x401F81B0U, 0x2U, 0x401F8428U, 0x2U, 0x401F83A0U |
#define | IOMUXC_GPIO_B1_13_ENET_1588_EVENT0_OUT 0x401F81B0U, 0x3U, 0, 0, 0x401F83A0U |
#define | IOMUXC_GPIO_B1_13_FLEXIO2_D29 0x401F81B0U, 0x4U, 0, 0, 0x401F83A0U |
#define | IOMUXC_GPIO_B1_13_GPIO2_IO29 0x401F81B0U, 0x5U, 0, 0, 0x401F83A0U |
#define | IOMUXC_GPIO_B1_13_USDHC1_WP 0x401F81B0U, 0x6U, 0x401F85D8U, 0x3U, 0x401F83A0U |
#define | IOMUXC_GPIO_B1_14_ENET_MDC 0x401F81B4U, 0x0U, 0, 0, 0x401F83A4U |
#define | IOMUXC_GPIO_B1_14_FLEXPWM4_PWM2_A 0x401F81B4U, 0x1U, 0x401F849CU, 0x1U, 0x401F83A4U |
#define | IOMUXC_GPIO_B1_14_CSI_HSYNC 0x401F81B4U, 0x2U, 0x401F8420U, 0x2U, 0x401F83A4U |
#define | IOMUXC_GPIO_B1_14_XBAR1_IN02 0x401F81B4U, 0x3U, 0x401F860CU, 0x1U, 0x401F83A4U |
#define | IOMUXC_GPIO_B1_14_FLEXIO2_D30 0x401F81B4U, 0x4U, 0, 0, 0x401F83A4U |
#define | IOMUXC_GPIO_B1_14_GPIO2_IO30 0x401F81B4U, 0x5U, 0, 0, 0x401F83A4U |
#define | IOMUXC_GPIO_B1_14_USDHC1_VSELECT 0x401F81B4U, 0x6U, 0, 0, 0x401F83A4U |
#define | IOMUXC_GPIO_B1_15_ENET_MDIO 0x401F81B8U, 0x0U, 0x401F8430U, 0x2U, 0x401F83A8U |
#define | IOMUXC_GPIO_B1_15_FLEXPWM4_PWM3_A 0x401F81B8U, 0x1U, 0x401F84A0U, 0x1U, 0x401F83A8U |
#define | IOMUXC_GPIO_B1_15_CSI_MCLK 0x401F81B8U, 0x2U, 0, 0, 0x401F83A8U |
#define | IOMUXC_GPIO_B1_15_XBAR1_IN03 0x401F81B8U, 0x3U, 0x401F8610U, 0x1U, 0x401F83A8U |
#define | IOMUXC_GPIO_B1_15_FLEXIO2_D31 0x401F81B8U, 0x4U, 0, 0, 0x401F83A8U |
#define | IOMUXC_GPIO_B1_15_GPIO2_IO31 0x401F81B8U, 0x5U, 0, 0, 0x401F83A8U |
#define | IOMUXC_GPIO_B1_15_USDHC1_RESET_B 0x401F81B8U, 0x6U, 0, 0, 0x401F83A8U |
#define | IOMUXC_GPIO_SD_B0_00_USDHC1_CMD 0x401F81BCU, 0x0U, 0, 0, 0x401F83ACU |
#define | IOMUXC_GPIO_SD_B0_00_FLEXPWM1_PWM0_A 0x401F81BCU, 0x1U, 0x401F8458U, 0x1U, 0x401F83ACU |
#define | IOMUXC_GPIO_SD_B0_00_LPI2C3_SCL 0x401F81BCU, 0x2U, 0x401F84DCU, 0x1U, 0x401F83ACU |
#define | IOMUXC_GPIO_SD_B0_00_XBAR1_INOUT04 0x401F81BCU, 0x3U, 0x401F8614U, 0x1U, 0x401F83ACU |
#define | IOMUXC_GPIO_SD_B0_00_LPSPI1_SCK 0x401F81BCU, 0x4U, 0x401F84F0U, 0x1U, 0x401F83ACU |
#define | IOMUXC_GPIO_SD_B0_00_GPIO3_IO12 0x401F81BCU, 0x5U, 0, 0, 0x401F83ACU |
#define | IOMUXC_GPIO_SD_B0_00_FLEXSPI_A_SS1_B 0x401F81BCU, 0x6U, 0, 0, 0x401F83ACU |
#define | IOMUXC_GPIO_SD_B0_01_USDHC1_CLK 0x401F81C0U, 0x0U, 0, 0, 0x401F83B0U |
#define | IOMUXC_GPIO_SD_B0_01_FLEXPWM1_PWM0_B 0x401F81C0U, 0x1U, 0x401F8468U, 0x1U, 0x401F83B0U |
#define | IOMUXC_GPIO_SD_B0_01_LPI2C3_SDA 0x401F81C0U, 0x2U, 0x401F84E0U, 0x1U, 0x401F83B0U |
#define | IOMUXC_GPIO_SD_B0_01_XBAR1_INOUT05 0x401F81C0U, 0x3U, 0x401F8618U, 0x1U, 0x401F83B0U |
#define | IOMUXC_GPIO_SD_B0_01_LPSPI1_PCS0 0x401F81C0U, 0x4U, 0x401F84ECU, 0x0U, 0x401F83B0U |
#define | IOMUXC_GPIO_SD_B0_01_GPIO3_IO13 0x401F81C0U, 0x5U, 0, 0, 0x401F83B0U |
#define | IOMUXC_GPIO_SD_B0_01_FLEXSPI_B_SS1_B 0x401F81C0U, 0x6U, 0, 0, 0x401F83B0U |
#define | IOMUXC_GPIO_SD_B0_02_USDHC1_DATA0 0x401F81C4U, 0x0U, 0, 0, 0x401F83B4U |
#define | IOMUXC_GPIO_SD_B0_02_FLEXPWM1_PWM1_A 0x401F81C4U, 0x1U, 0x401F845CU, 0x1U, 0x401F83B4U |
#define | IOMUXC_GPIO_SD_B0_02_LPUART8_CTS_B 0x401F81C4U, 0x2U, 0, 0, 0x401F83B4U |
#define | IOMUXC_GPIO_SD_B0_02_XBAR1_INOUT06 0x401F81C4U, 0x3U, 0x401F861CU, 0x1U, 0x401F83B4U |
#define | IOMUXC_GPIO_SD_B0_02_LPSPI1_SDO 0x401F81C4U, 0x4U, 0x401F84F8U, 0x1U, 0x401F83B4U |
#define | IOMUXC_GPIO_SD_B0_02_GPIO3_IO14 0x401F81C4U, 0x5U, 0, 0, 0x401F83B4U |
#define | IOMUXC_GPIO_SD_B0_03_USDHC1_DATA1 0x401F81C8U, 0x0U, 0, 0, 0x401F83B8U |
#define | IOMUXC_GPIO_SD_B0_03_FLEXPWM1_PWM1_B 0x401F81C8U, 0x1U, 0x401F846CU, 0x1U, 0x401F83B8U |
#define | IOMUXC_GPIO_SD_B0_03_LPUART8_RTS_B 0x401F81C8U, 0x2U, 0, 0, 0x401F83B8U |
#define | IOMUXC_GPIO_SD_B0_03_XBAR1_INOUT07 0x401F81C8U, 0x3U, 0x401F8620U, 0x1U, 0x401F83B8U |
#define | IOMUXC_GPIO_SD_B0_03_LPSPI1_SDI 0x401F81C8U, 0x4U, 0x401F84F4U, 0x1U, 0x401F83B8U |
#define | IOMUXC_GPIO_SD_B0_03_GPIO3_IO15 0x401F81C8U, 0x5U, 0, 0, 0x401F83B8U |
#define | IOMUXC_GPIO_SD_B0_04_USDHC1_DATA2 0x401F81CCU, 0x0U, 0, 0, 0x401F83BCU |
#define | IOMUXC_GPIO_SD_B0_04_FLEXPWM1_PWM2_A 0x401F81CCU, 0x1U, 0x401F8460U, 0x1U, 0x401F83BCU |
#define | IOMUXC_GPIO_SD_B0_04_LPUART8_TXD 0x401F81CCU, 0x2U, 0x401F8564U, 0x0U, 0x401F83BCU |
#define | IOMUXC_GPIO_SD_B0_04_XBAR1_INOUT08 0x401F81CCU, 0x3U, 0x401F8624U, 0x1U, 0x401F83BCU |
#define | IOMUXC_GPIO_SD_B0_04_FLEXSPI_B_SS0_B 0x401F81CCU, 0x4U, 0, 0, 0x401F83BCU |
#define | IOMUXC_GPIO_SD_B0_04_GPIO3_IO16 0x401F81CCU, 0x5U, 0, 0, 0x401F83BCU |
#define | IOMUXC_GPIO_SD_B0_04_CCM_CLKO1 0x401F81CCU, 0x6U, 0, 0, 0x401F83BCU |
#define | IOMUXC_GPIO_SD_B0_05_USDHC1_DATA3 0x401F81D0U, 0x0U, 0, 0, 0x401F83C0U |
#define | IOMUXC_GPIO_SD_B0_05_FLEXPWM1_PWM2_B 0x401F81D0U, 0x1U, 0x401F8470U, 0x1U, 0x401F83C0U |
#define | IOMUXC_GPIO_SD_B0_05_LPUART8_RXD 0x401F81D0U, 0x2U, 0x401F8560U, 0x0U, 0x401F83C0U |
#define | IOMUXC_GPIO_SD_B0_05_XBAR1_INOUT09 0x401F81D0U, 0x3U, 0x401F8628U, 0x1U, 0x401F83C0U |
#define | IOMUXC_GPIO_SD_B0_05_FLEXSPI_B_DQS 0x401F81D0U, 0x4U, 0, 0, 0x401F83C0U |
#define | IOMUXC_GPIO_SD_B0_05_GPIO3_IO17 0x401F81D0U, 0x5U, 0, 0, 0x401F83C0U |
#define | IOMUXC_GPIO_SD_B0_05_CCM_CLKO2 0x401F81D0U, 0x6U, 0, 0, 0x401F83C0U |
#define | IOMUXC_GPIO_SD_B1_00_USDHC2_DATA3 0x401F81D4U, 0x0U, 0x401F85F4U, 0x0U, 0x401F83C4U |
#define | IOMUXC_GPIO_SD_B1_00_FLEXSPI_B_DATA3 0x401F81D4U, 0x1U, 0x401F84C4U, 0x0U, 0x401F83C4U |
#define | IOMUXC_GPIO_SD_B1_00_FLEXPWM1_PWM3_A 0x401F81D4U, 0x2U, 0x401F8454U, 0x0U, 0x401F83C4U |
#define | IOMUXC_GPIO_SD_B1_00_SAI1_TX_DATA03 0x401F81D4U, 0x3U, 0x401F8598U, 0x0U, 0x401F83C4U |
#define | IOMUXC_GPIO_SD_B1_00_LPUART4_TXD 0x401F81D4U, 0x4U, 0x401F8544U, 0x0U, 0x401F83C4U |
#define | IOMUXC_GPIO_SD_B1_00_GPIO3_IO00 0x401F81D4U, 0x5U, 0, 0, 0x401F83C4U |
#define | IOMUXC_GPIO_SD_B1_01_USDHC2_DATA2 0x401F81D8U, 0x0U, 0x401F85F0U, 0x0U, 0x401F83C8U |
#define | IOMUXC_GPIO_SD_B1_01_FLEXSPI_B_DATA2 0x401F81D8U, 0x1U, 0x401F84C0U, 0x0U, 0x401F83C8U |
#define | IOMUXC_GPIO_SD_B1_01_FLEXPWM1_PWM3_B 0x401F81D8U, 0x2U, 0x401F8464U, 0x0U, 0x401F83C8U |
#define | IOMUXC_GPIO_SD_B1_01_SAI1_TX_DATA02 0x401F81D8U, 0x3U, 0x401F859CU, 0x0U, 0x401F83C8U |
#define | IOMUXC_GPIO_SD_B1_01_LPUART4_RXD 0x401F81D8U, 0x4U, 0x401F8540U, 0x0U, 0x401F83C8U |
#define | IOMUXC_GPIO_SD_B1_01_GPIO3_IO01 0x401F81D8U, 0x5U, 0, 0, 0x401F83C8U |
#define | IOMUXC_GPIO_SD_B1_02_USDHC2_DATA1 0x401F81DCU, 0x0U, 0x401F85ECU, 0x0U, 0x401F83CCU |
#define | IOMUXC_GPIO_SD_B1_02_FLEXSPI_B_DATA1 0x401F81DCU, 0x1U, 0x401F84BCU, 0x0U, 0x401F83CCU |
#define | IOMUXC_GPIO_SD_B1_02_FLEXPWM2_PWM3_A 0x401F81DCU, 0x2U, 0x401F8474U, 0x0U, 0x401F83CCU |
#define | IOMUXC_GPIO_SD_B1_02_SAI1_TX_DATA01 0x401F81DCU, 0x3U, 0x401F85A0U, 0x0U, 0x401F83CCU |
#define | IOMUXC_GPIO_SD_B1_02_FLEXCAN1_TX 0x401F81DCU, 0x4U, 0, 0, 0x401F83CCU |
#define | IOMUXC_GPIO_SD_B1_02_GPIO3_IO02 0x401F81DCU, 0x5U, 0, 0, 0x401F83CCU |
#define | IOMUXC_GPIO_SD_B1_02_CCM_WAIT 0x401F81DCU, 0x6U, 0, 0, 0x401F83CCU |
#define | IOMUXC_GPIO_SD_B1_03_USDHC2_DATA0 0x401F81E0U, 0x0U, 0x401F85E8U, 0x0U, 0x401F83D0U |
#define | IOMUXC_GPIO_SD_B1_03_FLEXSPI_B_DATA0 0x401F81E0U, 0x1U, 0x401F84B8U, 0x0U, 0x401F83D0U |
#define | IOMUXC_GPIO_SD_B1_03_FLEXPWM2_PWM3_B 0x401F81E0U, 0x2U, 0x401F8484U, 0x0U, 0x401F83D0U |
#define | IOMUXC_GPIO_SD_B1_03_SAI1_MCLK 0x401F81E0U, 0x3U, 0x401F858CU, 0x0U, 0x401F83D0U |
#define | IOMUXC_GPIO_SD_B1_03_FLEXCAN1_RX 0x401F81E0U, 0x4U, 0x401F844CU, 0x0U, 0x401F83D0U |
#define | IOMUXC_GPIO_SD_B1_03_GPIO3_IO03 0x401F81E0U, 0x5U, 0, 0, 0x401F83D0U |
#define | IOMUXC_GPIO_SD_B1_03_CCM_PMIC_READY 0x401F81E0U, 0x6U, 0x401F83FCU, 0x0U, 0x401F83D0U |
#define | IOMUXC_GPIO_SD_B1_04_USDHC2_CLK 0x401F81E4U, 0x0U, 0x401F85DCU, 0x0U, 0x401F83D4U |
#define | IOMUXC_GPIO_SD_B1_04_FLEXSPI_B_SCLK 0x401F81E4U, 0x1U, 0, 0, 0x401F83D4U |
#define | IOMUXC_GPIO_SD_B1_04_LPI2C1_SCL 0x401F81E4U, 0x2U, 0x401F84CCU, 0x0U, 0x401F83D4U |
#define | IOMUXC_GPIO_SD_B1_04_SAI1_RX_SYNC 0x401F81E4U, 0x3U, 0x401F85A4U, 0x0U, 0x401F83D4U |
#define | IOMUXC_GPIO_SD_B1_04_FLEXSPI_A_SS1_B 0x401F81E4U, 0x4U, 0, 0, 0x401F83D4U |
#define | IOMUXC_GPIO_SD_B1_04_GPIO3_IO04 0x401F81E4U, 0x5U, 0, 0, 0x401F83D4U |
#define | IOMUXC_GPIO_SD_B1_04_CCM_STOP 0x401F81E4U, 0x6U, 0, 0, 0x401F83D4U |
#define | IOMUXC_GPIO_SD_B1_05_USDHC2_CMD 0x401F81E8U, 0x0U, 0x401F85E4U, 0x0U, 0x401F83D8U |
#define | IOMUXC_GPIO_SD_B1_05_FLEXSPI_A_DQS 0x401F81E8U, 0x1U, 0x401F84A4U, 0x0U, 0x401F83D8U |
#define | IOMUXC_GPIO_SD_B1_05_LPI2C1_SDA 0x401F81E8U, 0x2U, 0x401F84D0U, 0x0U, 0x401F83D8U |
#define | IOMUXC_GPIO_SD_B1_05_SAI1_RX_BCLK 0x401F81E8U, 0x3U, 0x401F8590U, 0x0U, 0x401F83D8U |
#define | IOMUXC_GPIO_SD_B1_05_FLEXSPI_B_SS0_B 0x401F81E8U, 0x4U, 0, 0, 0x401F83D8U |
#define | IOMUXC_GPIO_SD_B1_05_GPIO3_IO05 0x401F81E8U, 0x5U, 0, 0, 0x401F83D8U |
#define | IOMUXC_GPIO_SD_B1_06_USDHC2_RESET_B 0x401F81ECU, 0x0U, 0, 0, 0x401F83DCU |
#define | IOMUXC_GPIO_SD_B1_06_FLEXSPI_A_SS0_B 0x401F81ECU, 0x1U, 0, 0, 0x401F83DCU |
#define | IOMUXC_GPIO_SD_B1_06_LPUART7_CTS_B 0x401F81ECU, 0x2U, 0, 0, 0x401F83DCU |
#define | IOMUXC_GPIO_SD_B1_06_SAI1_RX_DATA00 0x401F81ECU, 0x3U, 0x401F8594U, 0x0U, 0x401F83DCU |
#define | IOMUXC_GPIO_SD_B1_06_LPSPI2_PCS0 0x401F81ECU, 0x4U, 0x401F84FCU, 0x0U, 0x401F83DCU |
#define | IOMUXC_GPIO_SD_B1_06_GPIO3_IO06 0x401F81ECU, 0x5U, 0, 0, 0x401F83DCU |
#define | IOMUXC_GPIO_SD_B1_07_SEMC_CSX1 0x401F81F0U, 0x0U, 0, 0, 0x401F83E0U |
#define | IOMUXC_GPIO_SD_B1_07_FLEXSPI_A_SCLK 0x401F81F0U, 0x1U, 0x401F84C8U, 0x0U, 0x401F83E0U |
#define | IOMUXC_GPIO_SD_B1_07_LPUART7_RTS_B 0x401F81F0U, 0x2U, 0, 0, 0x401F83E0U |
#define | IOMUXC_GPIO_SD_B1_07_SAI1_TX_DATA00 0x401F81F0U, 0x3U, 0, 0, 0x401F83E0U |
#define | IOMUXC_GPIO_SD_B1_07_LPSPI2_SCK 0x401F81F0U, 0x4U, 0x401F8500U, 0x0U, 0x401F83E0U |
#define | IOMUXC_GPIO_SD_B1_07_GPIO3_IO07 0x401F81F0U, 0x5U, 0, 0, 0x401F83E0U |
#define | IOMUXC_GPIO_SD_B1_07_CCM_REF_EN_B 0x401F81F0U, 0x6U, 0, 0, 0x401F83E0U |
#define | IOMUXC_GPIO_SD_B1_08_USDHC2_DATA4 0x401F81F4U, 0x0U, 0x401F85F8U, 0x0U, 0x401F83E4U |
#define | IOMUXC_GPIO_SD_B1_08_FLEXSPI_A_DATA00 0x401F81F4U, 0x1U, 0x401F84A8U, 0x0U, 0x401F83E4U |
#define | IOMUXC_GPIO_SD_B1_08_LPUART7_TXD 0x401F81F4U, 0x2U, 0x401F855CU, 0x0U, 0x401F83E4U |
#define | IOMUXC_GPIO_SD_B1_08_SAI1_TX_BCLK 0x401F81F4U, 0x3U, 0x401F85A8U, 0x0U, 0x401F83E4U |
#define | IOMUXC_GPIO_SD_B1_08_LPSPI2_SD0 0x401F81F4U, 0x4U, 0x401F8508U, 0x0U, 0x401F83E4U |
#define | IOMUXC_GPIO_SD_B1_08_GPIO3_IO08 0x401F81F4U, 0x5U, 0, 0, 0x401F83E4U |
#define | IOMUXC_GPIO_SD_B1_08_SEMC_CSX2 0x401F81F4U, 0x6U, 0, 0, 0x401F83E4U |
#define | IOMUXC_GPIO_SD_B1_09_USDHC2_DATA5 0x401F81F8U, 0x0U, 0x401F85FCU, 0x0U, 0x401F83E8U |
#define | IOMUXC_GPIO_SD_B1_09_FLEXSPI_A_DATA1 0x401F81F8U, 0x1U, 0x401F84ACU, 0x0U, 0x401F83E8U |
#define | IOMUXC_GPIO_SD_B1_09_LPUART7_RXD 0x401F81F8U, 0x2U, 0x401F8558U, 0x0U, 0x401F83E8U |
#define | IOMUXC_GPIO_SD_B1_09_SAI1_TX_SYNC 0x401F81F8U, 0x3U, 0x401F85ACU, 0x0U, 0x401F83E8U |
#define | IOMUXC_GPIO_SD_B1_09_LPSPI2_SDI 0x401F81F8U, 0x4U, 0x401F8504U, 0x0U, 0x401F83E8U |
#define | IOMUXC_GPIO_SD_B1_09_GPIO3_IO09 0x401F81F8U, 0x5U, 0, 0, 0x401F83E8U |
#define | IOMUXC_GPIO_SD_B1_10_USDHC2_DATA6 0x401F81FCU, 0x0U, 0x401F8600U, 0x0U, 0x401F83ECU |
#define | IOMUXC_GPIO_SD_B1_10_FLEXSPI_A_DATA2 0x401F81FCU, 0x1U, 0x401F84B0U, 0x0U, 0x401F83ECU |
#define | IOMUXC_GPIO_SD_B1_10_LPUART2_RXD 0x401F81FCU, 0x2U, 0x401F852CU, 0x0U, 0x401F83ECU |
#define | IOMUXC_GPIO_SD_B1_10_LPI2C2_SDA 0x401F81FCU, 0x3U, 0x401F84D8U, 0x0U, 0x401F83ECU |
#define | IOMUXC_GPIO_SD_B1_10_LPSPI2_PCS2 0x401F81FCU, 0x4U, 0, 0, 0x401F83ECU |
#define | IOMUXC_GPIO_SD_B1_10_GPIO3_IO10 0x401F81FCU, 0x5U, 0, 0, 0x401F83ECU |
#define | IOMUXC_GPIO_SD_B1_11_USDHC2_DATA7 0x401F8200U, 0x0U, 0x401F8604U, 0x0U, 0x401F83F0U |
#define | IOMUXC_GPIO_SD_B1_11_FLEXSPI_A_DATA3 0x401F8200U, 0x1U, 0x401F84B4U, 0x0U, 0x401F83F0U |
#define | IOMUXC_GPIO_SD_B1_11_LPUART2_TXD 0x401F8200U, 0x2U, 0x401F8530U, 0x0U, 0x401F83F0U |
#define | IOMUXC_GPIO_SD_B1_11_LPI2C2_SCL 0x401F8200U, 0x3U, 0x401F84D4U, 0x0U, 0x401F83F0U |
#define | IOMUXC_GPIO_SD_B1_11_LPSPI2_PCS3 0x401F8200U, 0x4U, 0, 0, 0x401F83F0U |
#define | IOMUXC_GPIO_SD_B1_11_GPIO3_IO11 0x401F8200U, 0x5U, 0, 0, 0x401F83F0U |
#define | IOMUXC_SNVS_WAKEUP_GPIO5_IO00 0x400A8000U, 0x5U, 0, 0, 0x400A8018U |
#define | IOMUXC_SNVS_WAKEUP_NMI 0x400A8000U, 0x7U, 0x401F8568U, 0x1U, 0x400A8018U |
#define | IOMUXC_SNVS_PMIC_ON_REQ_SNVS_PMIC_ON_REQ 0x400A8004U, 0x0U, 0, 0, 0x400A801CU |
#define | IOMUXC_SNVS_PMIC_ON_REQ_GPIO5_IO01 0x400A8004U, 0x5U, 0, 0, 0x400A801CU |
#define | IOMUXC_SNVS_PMIC_STBY_REQ_CCM_PMIC_STBY_REQ 0x400A8008U, 0x0U, 0, 0, 0x400A8020U |
#define | IOMUXC_SNVS_PMIC_STBY_REQ_GPIO5_IO02 0x400A8008U, 0x5U, 0, 0, 0x400A8020U |
#define | IOMUXC_SNVS_TEST_MODE 0, 0, 0, 0, 0x400A800CU |
#define | IOMUXC_SNVS_POR_B 0, 0, 0, 0, 0x400A8010U |
#define | IOMUXC_SNVS_ONOFF 0, 0, 0, 0, 0x400A8014U |
#define | IOMUXC_GPR_SAIMCLK_LOWBITMASK (0x7U) |
#define | IOMUXC_GPR_SAIMCLK_HIGHBITMASK (0x3U) |
The pin function ID is a tuple of <muxRegister muxMode inputRegister inputDaisy configRegister>
enum | _iomuxc_gpr_saimclk {
kIOMUXC_GPR_SAI1MClk1Sel = IOMUXC_GPR_GPR1_SAI1_MCLK1_SEL_SHIFT
, kIOMUXC_GPR_SAI1MClk2Sel = IOMUXC_GPR_GPR1_SAI1_MCLK2_SEL_SHIFT
, kIOMUXC_GPR_SAI1MClk3Sel = IOMUXC_GPR_GPR1_SAI1_MCLK3_SEL_SHIFT
, kIOMUXC_GPR_SAI2MClk3Sel = IOMUXC_GPR_GPR1_SAI2_MCLK3_SEL_SHIFT
kIOMUXC_GPR_SAI3MClk3Sel = IOMUXC_GPR_GPR1_SAI3_MCLK3_SEL_SHIFT
, kIOMUXC_GPR_SAI1MClk1Sel = IOMUXC_GPR_GPR0_SAI1_MCLK1_SEL_SHIFT
, kIOMUXC_GPR_SAI1MClk2Sel = IOMUXC_GPR_GPR0_SAI1_MCLK2_SEL_SHIFT
, kIOMUXC_GPR_SAI1MClk3Sel = IOMUXC_GPR_GPR0_SAI1_MCLK3_SEL_SHIFT
kIOMUXC_GPR_SAI2MClk3Sel = IOMUXC_GPR_GPR1_SAI2_MCLK3_SEL_SHIFT + 8U
, kIOMUXC_GPR_SAI3MClk3Sel = IOMUXC_GPR_GPR2_SAI3_MCLK3_SEL_SHIFT + 10U
enum | _iomuxc_mqs_pwm_oversample_rate { kIOMUXC_MqsPwmOverSampleRate32 = 0
, kIOMUXC_MqsPwmOverSampleRate64 = 1
, kIOMUXC_MqsPwmOverSampleRate32 = 0
typedef enum _iomuxc_gpr_saimclk | iomuxc_gpr_saimclk_t |
typedef enum _iomuxc_mqs_pwm_oversample_rate | iomuxc_mqs_pwm_oversample_rate_t |
#define | IOMUXC_GPIO_LPSR_00_FLEXCAN3_TX 0x40C08000U, 0x0U, 0, 0, 0x40C08040U |
#define | IOMUXC_GPIO_LPSR_00_MIC_CLK 0x40C08000U, 0x1U, 0, 0, 0x40C08040U |
#define | IOMUXC_GPIO_LPSR_00_MQS_RIGHT 0x40C08000U, 0x2U, 0, 0, 0x40C08040U |
#define | IOMUXC_GPIO_LPSR_00_ARM_CM4_EVENTO 0x40C08000U, 0x3U, 0, 0, 0x40C08040U |
#define | IOMUXC_GPIO_LPSR_00_GPIO_MUX6_IO00 0x40C08000U, 0x5U, 0, 0, 0x40C08040U |
#define | IOMUXC_GPIO_LPSR_00_LPUART12_TXD 0x40C08000U, 0x6U, 0x40C080B0U, 0x0U, 0x40C08040U |
#define | IOMUXC_GPIO_LPSR_00_SAI4_MCLK 0x40C08000U, 0x7U, 0x40C080C8U, 0x0U, 0x40C08040U |
#define | IOMUXC_GPIO_LPSR_00_GPIO12_IO00 0x40C08000U, 0xAU, 0, 0, 0x40C08040U |
#define | IOMUXC_GPIO_LPSR_01_FLEXCAN3_RX 0x40C08004U, 0x0U, 0x40C08080U, 0x0U, 0x40C08044U |
#define | IOMUXC_GPIO_LPSR_01_MIC_BITSTREAM0 0x40C08004U, 0x1U, 0x40C080B4U, 0x0U, 0x40C08044U |
#define | IOMUXC_GPIO_LPSR_01_MQS_LEFT 0x40C08004U, 0x2U, 0, 0, 0x40C08044U |
#define | IOMUXC_GPIO_LPSR_01_ARM_CM4_EVENTI 0x40C08004U, 0x3U, 0, 0, 0x40C08044U |
#define | IOMUXC_GPIO_LPSR_01_GPIO_MUX6_IO01 0x40C08004U, 0x5U, 0, 0, 0x40C08044U |
#define | IOMUXC_GPIO_LPSR_01_LPUART12_RXD 0x40C08004U, 0x6U, 0x40C080ACU, 0x0U, 0x40C08044U |
#define | IOMUXC_GPIO_LPSR_01_GPIO12_IO01 0x40C08004U, 0xAU, 0, 0, 0x40C08044U |
#define | IOMUXC_GPIO_LPSR_02_GPIO12_IO02 0x40C08008U, 0xAU, 0, 0, 0x40C08048U |
#define | IOMUXC_GPIO_LPSR_02_SRC_BOOT_MODE00 0x40C08008U, 0x0U, 0, 0, 0x40C08048U |
#define | IOMUXC_GPIO_LPSR_02_LPSPI5_SCK 0x40C08008U, 0x1U, 0x40C08098U, 0x0U, 0x40C08048U |
#define | IOMUXC_GPIO_LPSR_02_SAI4_TX_DATA 0x40C08008U, 0x2U, 0, 0, 0x40C08048U |
#define | IOMUXC_GPIO_LPSR_02_MQS_RIGHT 0x40C08008U, 0x3U, 0, 0, 0x40C08048U |
#define | IOMUXC_GPIO_LPSR_02_GPIO_MUX6_IO02 0x40C08008U, 0x5U, 0, 0, 0x40C08048U |
#define | IOMUXC_GPIO_LPSR_03_SRC_BOOT_MODE01 0x40C0800CU, 0x0U, 0, 0, 0x40C0804CU |
#define | IOMUXC_GPIO_LPSR_03_LPSPI5_PCS0 0x40C0800CU, 0x1U, 0x40C08094U, 0x0U, 0x40C0804CU |
#define | IOMUXC_GPIO_LPSR_03_SAI4_TX_SYNC 0x40C0800CU, 0x2U, 0x40C080DCU, 0x0U, 0x40C0804CU |
#define | IOMUXC_GPIO_LPSR_03_MQS_LEFT 0x40C0800CU, 0x3U, 0, 0, 0x40C0804CU |
#define | IOMUXC_GPIO_LPSR_03_GPIO_MUX6_IO03 0x40C0800CU, 0x5U, 0, 0, 0x40C0804CU |
#define | IOMUXC_GPIO_LPSR_03_GPIO12_IO03 0x40C0800CU, 0xAU, 0, 0, 0x40C0804CU |
#define | IOMUXC_GPIO_LPSR_04_LPI2C5_SDA 0x40C08010U, 0x0U, 0x40C08088U, 0x0U, 0x40C08050U |
#define | IOMUXC_GPIO_LPSR_04_LPSPI5_SOUT 0x40C08010U, 0x1U, 0x40C080A0U, 0x0U, 0x40C08050U |
#define | IOMUXC_GPIO_LPSR_04_SAI4_TX_BCLK 0x40C08010U, 0x2U, 0x40C080D8U, 0x0U, 0x40C08050U |
#define | IOMUXC_GPIO_LPSR_04_LPUART12_RTS_B 0x40C08010U, 0x3U, 0, 0, 0x40C08050U |
#define | IOMUXC_GPIO_LPSR_04_GPIO_MUX6_IO04 0x40C08010U, 0x5U, 0, 0, 0x40C08050U |
#define | IOMUXC_GPIO_LPSR_04_LPUART11_TXD 0x40C08010U, 0x6U, 0x40C080A8U, 0x0U, 0x40C08050U |
#define | IOMUXC_GPIO_LPSR_04_GPIO12_IO04 0x40C08010U, 0xAU, 0, 0, 0x40C08050U |
#define | IOMUXC_GPIO_LPSR_05_GPIO12_IO05 0x40C08014U, 0xAU, 0, 0, 0x40C08054U |
#define | IOMUXC_GPIO_LPSR_05_LPI2C5_SCL 0x40C08014U, 0x0U, 0x40C08084U, 0x0U, 0x40C08054U |
#define | IOMUXC_GPIO_LPSR_05_LPSPI5_SIN 0x40C08014U, 0x1U, 0x40C0809CU, 0x0U, 0x40C08054U |
#define | IOMUXC_GPIO_LPSR_05_SAI4_MCLK 0x40C08014U, 0x2U, 0x40C080C8U, 0x1U, 0x40C08054U |
#define | IOMUXC_GPIO_LPSR_05_LPUART12_CTS_B 0x40C08014U, 0x3U, 0, 0, 0x40C08054U |
#define | IOMUXC_GPIO_LPSR_05_GPIO_MUX6_IO05 0x40C08014U, 0x5U, 0, 0, 0x40C08054U |
#define | IOMUXC_GPIO_LPSR_05_LPUART11_RXD 0x40C08014U, 0x6U, 0x40C080A4U, 0x0U, 0x40C08054U |
#define | IOMUXC_GPIO_LPSR_05_NMI_GLUE_NMI 0x40C08014U, 0x7U, 0x40C080C4U, 0x0U, 0x40C08054U |
#define | IOMUXC_GPIO_LPSR_06_LPI2C6_SDA 0x40C08018U, 0x0U, 0x40C08090U, 0x0U, 0x40C08058U |
#define | IOMUXC_GPIO_LPSR_06_SAI4_RX_DATA 0x40C08018U, 0x2U, 0x40C080D0U, 0x0U, 0x40C08058U |
#define | IOMUXC_GPIO_LPSR_06_LPUART12_TXD 0x40C08018U, 0x3U, 0x40C080B0U, 0x1U, 0x40C08058U |
#define | IOMUXC_GPIO_LPSR_06_LPSPI6_PCS3 0x40C08018U, 0x4U, 0, 0, 0x40C08058U |
#define | IOMUXC_GPIO_LPSR_06_GPIO_MUX6_IO06 0x40C08018U, 0x5U, 0, 0, 0x40C08058U |
#define | IOMUXC_GPIO_LPSR_06_FLEXCAN3_TX 0x40C08018U, 0x6U, 0, 0, 0x40C08058U |
#define | IOMUXC_GPIO_LPSR_06_PIT2_TRIGGER3 0x40C08018U, 0x7U, 0, 0, 0x40C08058U |
#define | IOMUXC_GPIO_LPSR_06_LPSPI5_PCS1 0x40C08018U, 0x8U, 0, 0, 0x40C08058U |
#define | IOMUXC_GPIO_LPSR_06_GPIO12_IO06 0x40C08018U, 0xAU, 0, 0, 0x40C08058U |
#define | IOMUXC_GPIO_LPSR_07_LPI2C6_SCL 0x40C0801CU, 0x0U, 0x40C0808CU, 0x0U, 0x40C0805CU |
#define | IOMUXC_GPIO_LPSR_07_SAI4_RX_BCLK 0x40C0801CU, 0x2U, 0x40C080CCU, 0x0U, 0x40C0805CU |
#define | IOMUXC_GPIO_LPSR_07_LPUART12_RXD 0x40C0801CU, 0x3U, 0x40C080ACU, 0x1U, 0x40C0805CU |
#define | IOMUXC_GPIO_LPSR_07_LPSPI6_PCS2 0x40C0801CU, 0x4U, 0, 0, 0x40C0805CU |
#define | IOMUXC_GPIO_LPSR_07_GPIO_MUX6_IO07 0x40C0801CU, 0x5U, 0, 0, 0x40C0805CU |
#define | IOMUXC_GPIO_LPSR_07_FLEXCAN3_RX 0x40C0801CU, 0x6U, 0x40C08080U, 0x1U, 0x40C0805CU |
#define | IOMUXC_GPIO_LPSR_07_PIT2_TRIGGER2 0x40C0801CU, 0x7U, 0, 0, 0x40C0805CU |
#define | IOMUXC_GPIO_LPSR_07_LPSPI5_PCS2 0x40C0801CU, 0x8U, 0, 0, 0x40C0805CU |
#define | IOMUXC_GPIO_LPSR_07_GPIO12_IO07 0x40C0801CU, 0xAU, 0, 0, 0x40C0805CU |
#define | IOMUXC_GPIO_LPSR_08_GPIO12_IO08 0x40C08020U, 0xAU, 0, 0, 0x40C08060U |
#define | IOMUXC_GPIO_LPSR_08_LPUART11_TXD 0x40C08020U, 0x0U, 0x40C080A8U, 0x1U, 0x40C08060U |
#define | IOMUXC_GPIO_LPSR_08_FLEXCAN3_TX 0x40C08020U, 0x1U, 0, 0, 0x40C08060U |
#define | IOMUXC_GPIO_LPSR_08_SAI4_RX_SYNC 0x40C08020U, 0x2U, 0x40C080D4U, 0x0U, 0x40C08060U |
#define | IOMUXC_GPIO_LPSR_08_MIC_CLK 0x40C08020U, 0x3U, 0, 0, 0x40C08060U |
#define | IOMUXC_GPIO_LPSR_08_LPSPI6_PCS1 0x40C08020U, 0x4U, 0, 0, 0x40C08060U |
#define | IOMUXC_GPIO_LPSR_08_GPIO_MUX6_IO08 0x40C08020U, 0x5U, 0, 0, 0x40C08060U |
#define | IOMUXC_GPIO_LPSR_08_LPI2C5_SDA 0x40C08020U, 0x6U, 0x40C08088U, 0x1U, 0x40C08060U |
#define | IOMUXC_GPIO_LPSR_08_PIT2_TRIGGER1 0x40C08020U, 0x7U, 0, 0, 0x40C08060U |
#define | IOMUXC_GPIO_LPSR_08_LPSPI5_PCS3 0x40C08020U, 0x8U, 0, 0, 0x40C08060U |
#define | IOMUXC_GPIO_LPSR_09_GPIO12_IO09 0x40C08024U, 0xAU, 0, 0, 0x40C08064U |
#define | IOMUXC_GPIO_LPSR_09_LPUART11_RXD 0x40C08024U, 0x0U, 0x40C080A4U, 0x1U, 0x40C08064U |
#define | IOMUXC_GPIO_LPSR_09_FLEXCAN3_RX 0x40C08024U, 0x1U, 0x40C08080U, 0x2U, 0x40C08064U |
#define | IOMUXC_GPIO_LPSR_09_PIT2_TRIGGER0 0x40C08024U, 0x2U, 0, 0, 0x40C08064U |
#define | IOMUXC_GPIO_LPSR_09_MIC_BITSTREAM0 0x40C08024U, 0x3U, 0x40C080B4U, 0x1U, 0x40C08064U |
#define | IOMUXC_GPIO_LPSR_09_LPSPI6_PCS0 0x40C08024U, 0x4U, 0, 0, 0x40C08064U |
#define | IOMUXC_GPIO_LPSR_09_GPIO_MUX6_IO09 0x40C08024U, 0x5U, 0, 0, 0x40C08064U |
#define | IOMUXC_GPIO_LPSR_09_LPI2C5_SCL 0x40C08024U, 0x6U, 0x40C08084U, 0x1U, 0x40C08064U |
#define | IOMUXC_GPIO_LPSR_09_SAI4_TX_DATA 0x40C08024U, 0x7U, 0, 0, 0x40C08064U |
#define | IOMUXC_GPIO_LPSR_10_GPIO12_IO10 0x40C08028U, 0xAU, 0, 0, 0x40C08068U |
#define | IOMUXC_GPIO_LPSR_10_JTAG_MUX_TRSTB 0x40C08028U, 0x0U, 0, 0, 0x40C08068U |
#define | IOMUXC_GPIO_LPSR_10_LPUART11_CTS_B 0x40C08028U, 0x1U, 0, 0, 0x40C08068U |
#define | IOMUXC_GPIO_LPSR_10_LPI2C6_SDA 0x40C08028U, 0x2U, 0x40C08090U, 0x1U, 0x40C08068U |
#define | IOMUXC_GPIO_LPSR_10_MIC_BITSTREAM1 0x40C08028U, 0x3U, 0x40C080B8U, 0x0U, 0x40C08068U |
#define | IOMUXC_GPIO_LPSR_10_LPSPI6_SCK 0x40C08028U, 0x4U, 0, 0, 0x40C08068U |
#define | IOMUXC_GPIO_LPSR_10_GPIO_MUX6_IO10 0x40C08028U, 0x5U, 0, 0, 0x40C08068U |
#define | IOMUXC_GPIO_LPSR_10_LPI2C5_SCLS 0x40C08028U, 0x6U, 0, 0, 0x40C08068U |
#define | IOMUXC_GPIO_LPSR_10_SAI4_TX_SYNC 0x40C08028U, 0x7U, 0x40C080DCU, 0x1U, 0x40C08068U |
#define | IOMUXC_GPIO_LPSR_10_LPUART12_TXD 0x40C08028U, 0x8U, 0x40C080B0U, 0x2U, 0x40C08068U |
#define | IOMUXC_GPIO_LPSR_11_JTAG_MUX_TDO 0x40C0802CU, 0x0U, 0, 0, 0x40C0806CU |
#define | IOMUXC_GPIO_LPSR_11_LPUART11_RTS_B 0x40C0802CU, 0x1U, 0, 0, 0x40C0806CU |
#define | IOMUXC_GPIO_LPSR_11_LPI2C6_SCL 0x40C0802CU, 0x2U, 0x40C0808CU, 0x1U, 0x40C0806CU |
#define | IOMUXC_GPIO_LPSR_11_MIC_BITSTREAM2 0x40C0802CU, 0x3U, 0x40C080BCU, 0x0U, 0x40C0806CU |
#define | IOMUXC_GPIO_LPSR_11_LPSPI6_SOUT 0x40C0802CU, 0x4U, 0, 0, 0x40C0806CU |
#define | IOMUXC_GPIO_LPSR_11_GPIO_MUX6_IO11 0x40C0802CU, 0x5U, 0, 0, 0x40C0806CU |
#define | IOMUXC_GPIO_LPSR_11_LPI2C5_SDAS 0x40C0802CU, 0x6U, 0, 0, 0x40C0806CU |
#define | IOMUXC_GPIO_LPSR_11_ARM_TRACE_SWO 0x40C0802CU, 0x7U, 0, 0, 0x40C0806CU |
#define | IOMUXC_GPIO_LPSR_11_LPUART12_RXD 0x40C0802CU, 0x8U, 0x40C080ACU, 0x2U, 0x40C0806CU |
#define | IOMUXC_GPIO_LPSR_11_GPIO12_IO11 0x40C0802CU, 0xAU, 0, 0, 0x40C0806CU |
#define | IOMUXC_GPIO_LPSR_12_GPIO12_IO12 0x40C08030U, 0xAU, 0, 0, 0x40C08070U |
#define | IOMUXC_GPIO_LPSR_12_JTAG_MUX_TDI 0x40C08030U, 0x0U, 0, 0, 0x40C08070U |
#define | IOMUXC_GPIO_LPSR_12_PIT2_TRIGGER0 0x40C08030U, 0x1U, 0, 0, 0x40C08070U |
#define | IOMUXC_GPIO_LPSR_12_MIC_BITSTREAM3 0x40C08030U, 0x3U, 0x40C080C0U, 0x0U, 0x40C08070U |
#define | IOMUXC_GPIO_LPSR_12_LPSPI6_SIN 0x40C08030U, 0x4U, 0, 0, 0x40C08070U |
#define | IOMUXC_GPIO_LPSR_12_GPIO_MUX6_IO12 0x40C08030U, 0x5U, 0, 0, 0x40C08070U |
#define | IOMUXC_GPIO_LPSR_12_LPI2C5_HREQ 0x40C08030U, 0x6U, 0, 0, 0x40C08070U |
#define | IOMUXC_GPIO_LPSR_12_SAI4_TX_BCLK 0x40C08030U, 0x7U, 0x40C080D8U, 0x1U, 0x40C08070U |
#define | IOMUXC_GPIO_LPSR_12_LPSPI5_SCK 0x40C08030U, 0x8U, 0x40C08098U, 0x1U, 0x40C08070U |
#define | IOMUXC_GPIO_LPSR_13_GPIO12_IO13 0x40C08034U, 0xAU, 0, 0, 0x40C08074U |
#define | IOMUXC_GPIO_LPSR_13_JTAG_MUX_MOD 0x40C08034U, 0x0U, 0, 0, 0x40C08074U |
#define | IOMUXC_GPIO_LPSR_13_MIC_BITSTREAM1 0x40C08034U, 0x1U, 0x40C080B8U, 0x1U, 0x40C08074U |
#define | IOMUXC_GPIO_LPSR_13_PIT2_TRIGGER1 0x40C08034U, 0x2U, 0, 0, 0x40C08074U |
#define | IOMUXC_GPIO_LPSR_13_GPIO_MUX6_IO13 0x40C08034U, 0x5U, 0, 0, 0x40C08074U |
#define | IOMUXC_GPIO_LPSR_13_SAI4_RX_DATA 0x40C08034U, 0x7U, 0x40C080D0U, 0x1U, 0x40C08074U |
#define | IOMUXC_GPIO_LPSR_13_LPSPI5_PCS0 0x40C08034U, 0x8U, 0x40C08094U, 0x1U, 0x40C08074U |
#define | IOMUXC_GPIO_LPSR_14_JTAG_MUX_TCK 0x40C08038U, 0x0U, 0, 0, 0x40C08078U |
#define | IOMUXC_GPIO_LPSR_14_MIC_BITSTREAM2 0x40C08038U, 0x1U, 0x40C080BCU, 0x1U, 0x40C08078U |
#define | IOMUXC_GPIO_LPSR_14_PIT2_TRIGGER2 0x40C08038U, 0x2U, 0, 0, 0x40C08078U |
#define | IOMUXC_GPIO_LPSR_14_GPIO_MUX6_IO14 0x40C08038U, 0x5U, 0, 0, 0x40C08078U |
#define | IOMUXC_GPIO_LPSR_14_SAI4_RX_BCLK 0x40C08038U, 0x7U, 0x40C080CCU, 0x1U, 0x40C08078U |
#define | IOMUXC_GPIO_LPSR_14_LPSPI5_SOUT 0x40C08038U, 0x8U, 0x40C080A0U, 0x1U, 0x40C08078U |
#define | IOMUXC_GPIO_LPSR_14_GPIO12_IO14 0x40C08038U, 0xAU, 0, 0, 0x40C08078U |
#define | IOMUXC_GPIO_LPSR_15_GPIO12_IO15 0x40C0803CU, 0xAU, 0, 0, 0x40C0807CU |
#define | IOMUXC_GPIO_LPSR_15_JTAG_MUX_TMS 0x40C0803CU, 0x0U, 0, 0, 0x40C0807CU |
#define | IOMUXC_GPIO_LPSR_15_MIC_BITSTREAM3 0x40C0803CU, 0x1U, 0x40C080C0U, 0x1U, 0x40C0807CU |
#define | IOMUXC_GPIO_LPSR_15_PIT2_TRIGGER3 0x40C0803CU, 0x2U, 0, 0, 0x40C0807CU |
#define | IOMUXC_GPIO_LPSR_15_GPIO_MUX6_IO15 0x40C0803CU, 0x5U, 0, 0, 0x40C0807CU |
#define | IOMUXC_GPIO_LPSR_15_SAI4_RX_SYNC 0x40C0803CU, 0x7U, 0x40C080D4U, 0x1U, 0x40C0807CU |
#define | IOMUXC_GPIO_LPSR_15_LPSPI5_SIN 0x40C0803CU, 0x8U, 0x40C0809CU, 0x1U, 0x40C0807CU |
#define | IOMUXC_WAKEUP_DIG_GPIO13_IO00 0x40C94000U, 0x5U, 0, 0, 0x40C94040U |
#define | IOMUXC_WAKEUP_DIG_NMI_GLUE_NMI 0x40C94000U, 0x7U, 0x40C080C4U, 0x1U, 0x40C94040U |
#define | IOMUXC_PMIC_ON_REQ_DIG_SNVS_LP_PMIC_ON_REQ 0x40C94004U, 0x0U, 0, 0, 0x40C94044U |
#define | IOMUXC_PMIC_ON_REQ_DIG_GPIO13_IO01 0x40C94004U, 0x5U, 0, 0, 0x40C94044U |
#define | IOMUXC_PMIC_STBY_REQ_DIG_CCM_PMIC_VSTBY_REQ 0x40C94008U, 0x0U, 0, 0, 0x40C94048U |
#define | IOMUXC_PMIC_STBY_REQ_DIG_GPIO13_IO02 0x40C94008U, 0x5U, 0, 0, 0x40C94048U |
#define | IOMUXC_GPIO_SNVS_00_DIG_SNVS_TAMPER0 0x40C9400CU, 0x0U, 0, 0, 0x40C9404CU |
#define | IOMUXC_GPIO_SNVS_00_DIG_GPIO13_IO03 0x40C9400CU, 0x5U, 0, 0, 0x40C9404CU |
#define | IOMUXC_GPIO_SNVS_01_DIG_SNVS_TAMPER1 0x40C94010U, 0x0U, 0, 0, 0x40C94050U |
#define | IOMUXC_GPIO_SNVS_01_DIG_GPIO13_IO04 0x40C94010U, 0x5U, 0, 0, 0x40C94050U |
#define | IOMUXC_GPIO_SNVS_02_DIG_SNVS_TAMPER2 0x40C94014U, 0x0U, 0, 0, 0x40C94054U |
#define | IOMUXC_GPIO_SNVS_02_DIG_GPIO13_IO05 0x40C94014U, 0x5U, 0, 0, 0x40C94054U |
#define | IOMUXC_GPIO_SNVS_03_DIG_SNVS_TAMPER3 0x40C94018U, 0x0U, 0, 0, 0x40C94058U |
#define | IOMUXC_GPIO_SNVS_03_DIG_GPIO13_IO06 0x40C94018U, 0x5U, 0, 0, 0x40C94058U |
#define | IOMUXC_GPIO_SNVS_04_DIG_SNVS_TAMPER4 0x40C9401CU, 0x0U, 0, 0, 0x40C9405CU |
#define | IOMUXC_GPIO_SNVS_04_DIG_GPIO13_IO07 0x40C9401CU, 0x5U, 0, 0, 0x40C9405CU |
#define | IOMUXC_GPIO_SNVS_05_DIG_SNVS_TAMPER5 0x40C94020U, 0x0U, 0, 0, 0x40C94060U |
#define | IOMUXC_GPIO_SNVS_05_DIG_GPIO13_IO08 0x40C94020U, 0x5U, 0, 0, 0x40C94060U |
#define | IOMUXC_GPIO_SNVS_06_DIG_SNVS_TAMPER6 0x40C94024U, 0x0U, 0, 0, 0x40C94064U |
#define | IOMUXC_GPIO_SNVS_06_DIG_GPIO13_IO09 0x40C94024U, 0x5U, 0, 0, 0x40C94064U |
#define | IOMUXC_GPIO_SNVS_07_DIG_SNVS_TAMPER7 0x40C94028U, 0x0U, 0, 0, 0x40C94068U |
#define | IOMUXC_GPIO_SNVS_07_DIG_GPIO13_IO10 0x40C94028U, 0x5U, 0, 0, 0x40C94068U |
#define | IOMUXC_GPIO_SNVS_08_DIG_SNVS_TAMPER8 0x40C9402CU, 0x0U, 0, 0, 0x40C9406CU |
#define | IOMUXC_GPIO_SNVS_08_DIG_GPIO13_IO11 0x40C9402CU, 0x5U, 0, 0, 0x40C9406CU |
#define | IOMUXC_GPIO_SNVS_09_DIG_SNVS_TAMPER9 0x40C94030U, 0x0U, 0, 0, 0x40C94070U |
#define | IOMUXC_GPIO_SNVS_09_DIG_GPIO13_IO12 0x40C94030U, 0x5U, 0, 0, 0x40C94070U |
#define | IOMUXC_TEST_MODE_DIG 0, 0, 0, 0, 0x40C94034U |
#define | IOMUXC_POR_B_DIG 0, 0, 0, 0, 0x40C94038U |
#define | IOMUXC_ONOFF_DIG 0, 0, 0, 0, 0x40C9403CU |
#define | IOMUXC_GPIO_EMC_B1_00_SEMC_DATA00 0x400E8010U, 0x0U, 0, 0, 0x400E8254U |
#define | IOMUXC_GPIO_EMC_B1_00_FLEXPWM4_PWM0_A 0x400E8010U, 0x1U, 0, 0, 0x400E8254U |
#define | IOMUXC_GPIO_EMC_B1_00_GPIO_MUX1_IO00 0x400E8010U, 0x5U, 0, 0, 0x400E8254U |
#define | IOMUXC_GPIO_EMC_B1_00_FLEXIO1_D00 0x400E8010U, 0x8U, 0, 0, 0x400E8254U |
#define | IOMUXC_GPIO_EMC_B1_00_GPIO7_IO00 0x400E8010U, 0xAU, 0, 0, 0x400E8254U |
#define | IOMUXC_GPIO_EMC_B1_01_GPIO7_IO01 0x400E8014U, 0xAU, 0, 0, 0x400E8258U |
#define | IOMUXC_GPIO_EMC_B1_01_SEMC_DATA01 0x400E8014U, 0x0U, 0, 0, 0x400E8258U |
#define | IOMUXC_GPIO_EMC_B1_01_FLEXPWM4_PWM0_B 0x400E8014U, 0x1U, 0, 0, 0x400E8258U |
#define | IOMUXC_GPIO_EMC_B1_01_GPIO_MUX1_IO01 0x400E8014U, 0x5U, 0, 0, 0x400E8258U |
#define | IOMUXC_GPIO_EMC_B1_01_FLEXIO1_D01 0x400E8014U, 0x8U, 0, 0, 0x400E8258U |
#define | IOMUXC_GPIO_EMC_B1_02_SEMC_DATA02 0x400E8018U, 0x0U, 0, 0, 0x400E825CU |
#define | IOMUXC_GPIO_EMC_B1_02_FLEXPWM4_PWM1_A 0x400E8018U, 0x1U, 0, 0, 0x400E825CU |
#define | IOMUXC_GPIO_EMC_B1_02_GPIO_MUX1_IO02 0x400E8018U, 0x5U, 0, 0, 0x400E825CU |
#define | IOMUXC_GPIO_EMC_B1_02_FLEXIO1_D02 0x400E8018U, 0x8U, 0, 0, 0x400E825CU |
#define | IOMUXC_GPIO_EMC_B1_02_GPIO7_IO02 0x400E8018U, 0xAU, 0, 0, 0x400E825CU |
#define | IOMUXC_GPIO_EMC_B1_03_SEMC_DATA03 0x400E801CU, 0x0U, 0, 0, 0x400E8260U |
#define | IOMUXC_GPIO_EMC_B1_03_FLEXPWM4_PWM1_B 0x400E801CU, 0x1U, 0, 0, 0x400E8260U |
#define | IOMUXC_GPIO_EMC_B1_03_GPIO_MUX1_IO03 0x400E801CU, 0x5U, 0, 0, 0x400E8260U |
#define | IOMUXC_GPIO_EMC_B1_03_FLEXIO1_D03 0x400E801CU, 0x8U, 0, 0, 0x400E8260U |
#define | IOMUXC_GPIO_EMC_B1_03_GPIO7_IO03 0x400E801CU, 0xAU, 0, 0, 0x400E8260U |
#define | IOMUXC_GPIO_EMC_B1_04_GPIO7_IO04 0x400E8020U, 0xAU, 0, 0, 0x400E8264U |
#define | IOMUXC_GPIO_EMC_B1_04_SEMC_DATA04 0x400E8020U, 0x0U, 0, 0, 0x400E8264U |
#define | IOMUXC_GPIO_EMC_B1_04_FLEXPWM4_PWM2_A 0x400E8020U, 0x1U, 0, 0, 0x400E8264U |
#define | IOMUXC_GPIO_EMC_B1_04_GPIO_MUX1_IO04 0x400E8020U, 0x5U, 0, 0, 0x400E8264U |
#define | IOMUXC_GPIO_EMC_B1_04_FLEXIO1_D04 0x400E8020U, 0x8U, 0, 0, 0x400E8264U |
#define | IOMUXC_GPIO_EMC_B1_05_SEMC_DATA05 0x400E8024U, 0x0U, 0, 0, 0x400E8268U |
#define | IOMUXC_GPIO_EMC_B1_05_FLEXPWM4_PWM2_B 0x400E8024U, 0x1U, 0, 0, 0x400E8268U |
#define | IOMUXC_GPIO_EMC_B1_05_GPIO_MUX1_IO05 0x400E8024U, 0x5U, 0, 0, 0x400E8268U |
#define | IOMUXC_GPIO_EMC_B1_05_FLEXIO1_D05 0x400E8024U, 0x8U, 0, 0, 0x400E8268U |
#define | IOMUXC_GPIO_EMC_B1_05_GPIO7_IO05 0x400E8024U, 0xAU, 0, 0, 0x400E8268U |
#define | IOMUXC_GPIO_EMC_B1_06_SEMC_DATA06 0x400E8028U, 0x0U, 0, 0, 0x400E826CU |
#define | IOMUXC_GPIO_EMC_B1_06_FLEXPWM2_PWM0_A 0x400E8028U, 0x1U, 0x400E8518U, 0x0U, 0x400E826CU |
#define | IOMUXC_GPIO_EMC_B1_06_GPIO_MUX1_IO06 0x400E8028U, 0x5U, 0, 0, 0x400E826CU |
#define | IOMUXC_GPIO_EMC_B1_06_FLEXIO1_D06 0x400E8028U, 0x8U, 0, 0, 0x400E826CU |
#define | IOMUXC_GPIO_EMC_B1_06_GPIO7_IO06 0x400E8028U, 0xAU, 0, 0, 0x400E826CU |
#define | IOMUXC_GPIO_EMC_B1_07_GPIO7_IO07 0x400E802CU, 0xAU, 0, 0, 0x400E8270U |
#define | IOMUXC_GPIO_EMC_B1_07_SEMC_DATA07 0x400E802CU, 0x0U, 0, 0, 0x400E8270U |
#define | IOMUXC_GPIO_EMC_B1_07_FLEXPWM2_PWM0_B 0x400E802CU, 0x1U, 0x400E8524U, 0x0U, 0x400E8270U |
#define | IOMUXC_GPIO_EMC_B1_07_GPIO_MUX1_IO07 0x400E802CU, 0x5U, 0, 0, 0x400E8270U |
#define | IOMUXC_GPIO_EMC_B1_07_FLEXIO1_D07 0x400E802CU, 0x8U, 0, 0, 0x400E8270U |
#define | IOMUXC_GPIO_EMC_B1_08_SEMC_DM00 0x400E8030U, 0x0U, 0, 0, 0x400E8274U |
#define | IOMUXC_GPIO_EMC_B1_08_FLEXPWM2_PWM1_A 0x400E8030U, 0x1U, 0x400E851CU, 0x0U, 0x400E8274U |
#define | IOMUXC_GPIO_EMC_B1_08_GPIO_MUX1_IO08 0x400E8030U, 0x5U, 0, 0, 0x400E8274U |
#define | IOMUXC_GPIO_EMC_B1_08_FLEXIO1_D08 0x400E8030U, 0x8U, 0, 0, 0x400E8274U |
#define | IOMUXC_GPIO_EMC_B1_08_GPIO7_IO08 0x400E8030U, 0xAU, 0, 0, 0x400E8274U |
#define | IOMUXC_GPIO_EMC_B1_09_SEMC_ADDR00 0x400E8034U, 0x0U, 0, 0, 0x400E8278U |
#define | IOMUXC_GPIO_EMC_B1_09_FLEXPWM2_PWM1_B 0x400E8034U, 0x1U, 0x400E8528U, 0x0U, 0x400E8278U |
#define | IOMUXC_GPIO_EMC_B1_09_GPT5_CAPTURE1 0x400E8034U, 0x2U, 0, 0, 0x400E8278U |
#define | IOMUXC_GPIO_EMC_B1_09_GPIO_MUX1_IO09 0x400E8034U, 0x5U, 0, 0, 0x400E8278U |
#define | IOMUXC_GPIO_EMC_B1_09_FLEXIO1_D09 0x400E8034U, 0x8U, 0, 0, 0x400E8278U |
#define | IOMUXC_GPIO_EMC_B1_09_GPIO7_IO09 0x400E8034U, 0xAU, 0, 0, 0x400E8278U |
#define | IOMUXC_GPIO_EMC_B1_10_SEMC_ADDR01 0x400E8038U, 0x0U, 0, 0, 0x400E827CU |
#define | IOMUXC_GPIO_EMC_B1_10_FLEXPWM2_PWM2_A 0x400E8038U, 0x1U, 0x400E8520U, 0x0U, 0x400E827CU |
#define | IOMUXC_GPIO_EMC_B1_10_GPT5_CAPTURE2 0x400E8038U, 0x2U, 0, 0, 0x400E827CU |
#define | IOMUXC_GPIO_EMC_B1_10_GPIO_MUX1_IO10 0x400E8038U, 0x5U, 0, 0, 0x400E827CU |
#define | IOMUXC_GPIO_EMC_B1_10_FLEXIO1_D10 0x400E8038U, 0x8U, 0, 0, 0x400E827CU |
#define | IOMUXC_GPIO_EMC_B1_10_GPIO7_IO10 0x400E8038U, 0xAU, 0, 0, 0x400E827CU |
#define | IOMUXC_GPIO_EMC_B1_11_GPIO7_IO11 0x400E803CU, 0xAU, 0, 0, 0x400E8280U |
#define | IOMUXC_GPIO_EMC_B1_11_SEMC_ADDR02 0x400E803CU, 0x0U, 0, 0, 0x400E8280U |
#define | IOMUXC_GPIO_EMC_B1_11_FLEXPWM2_PWM2_B 0x400E803CU, 0x1U, 0x400E852CU, 0x0U, 0x400E8280U |
#define | IOMUXC_GPIO_EMC_B1_11_GPT5_COMPARE1 0x400E803CU, 0x2U, 0, 0, 0x400E8280U |
#define | IOMUXC_GPIO_EMC_B1_11_GPIO_MUX1_IO11 0x400E803CU, 0x5U, 0, 0, 0x400E8280U |
#define | IOMUXC_GPIO_EMC_B1_11_FLEXIO1_D11 0x400E803CU, 0x8U, 0, 0, 0x400E8280U |
#define | IOMUXC_GPIO_EMC_B1_12_SEMC_ADDR03 0x400E8040U, 0x0U, 0, 0, 0x400E8284U |
#define | IOMUXC_GPIO_EMC_B1_12_XBAR1_INOUT04 0x400E8040U, 0x1U, 0, 0, 0x400E8284U |
#define | IOMUXC_GPIO_EMC_B1_12_GPT5_COMPARE2 0x400E8040U, 0x2U, 0, 0, 0x400E8284U |
#define | IOMUXC_GPIO_EMC_B1_12_GPIO_MUX1_IO12 0x400E8040U, 0x5U, 0, 0, 0x400E8284U |
#define | IOMUXC_GPIO_EMC_B1_12_FLEXIO1_D12 0x400E8040U, 0x8U, 0, 0, 0x400E8284U |
#define | IOMUXC_GPIO_EMC_B1_12_GPIO7_IO12 0x400E8040U, 0xAU, 0, 0, 0x400E8284U |
#define | IOMUXC_GPIO_EMC_B1_13_SEMC_ADDR04 0x400E8044U, 0x0U, 0, 0, 0x400E8288U |
#define | IOMUXC_GPIO_EMC_B1_13_XBAR1_INOUT05 0x400E8044U, 0x1U, 0, 0, 0x400E8288U |
#define | IOMUXC_GPIO_EMC_B1_13_GPT5_COMPARE3 0x400E8044U, 0x2U, 0, 0, 0x400E8288U |
#define | IOMUXC_GPIO_EMC_B1_13_GPIO_MUX1_IO13 0x400E8044U, 0x5U, 0, 0, 0x400E8288U |
#define | IOMUXC_GPIO_EMC_B1_13_FLEXIO1_D13 0x400E8044U, 0x8U, 0, 0, 0x400E8288U |
#define | IOMUXC_GPIO_EMC_B1_13_GPIO7_IO13 0x400E8044U, 0xAU, 0, 0, 0x400E8288U |
#define | IOMUXC_GPIO_EMC_B1_14_GPIO7_IO14 0x400E8048U, 0xAU, 0, 0, 0x400E828CU |
#define | IOMUXC_GPIO_EMC_B1_14_SEMC_ADDR05 0x400E8048U, 0x0U, 0, 0, 0x400E828CU |
#define | IOMUXC_GPIO_EMC_B1_14_XBAR1_INOUT06 0x400E8048U, 0x1U, 0, 0, 0x400E828CU |
#define | IOMUXC_GPIO_EMC_B1_14_GPT5_CLK 0x400E8048U, 0x2U, 0, 0, 0x400E828CU |
#define | IOMUXC_GPIO_EMC_B1_14_GPIO_MUX1_IO14 0x400E8048U, 0x5U, 0, 0, 0x400E828CU |
#define | IOMUXC_GPIO_EMC_B1_14_FLEXIO1_D14 0x400E8048U, 0x8U, 0, 0, 0x400E828CU |
#define | IOMUXC_GPIO_EMC_B1_15_SEMC_ADDR06 0x400E804CU, 0x0U, 0, 0, 0x400E8290U |
#define | IOMUXC_GPIO_EMC_B1_15_XBAR1_INOUT07 0x400E804CU, 0x1U, 0, 0, 0x400E8290U |
#define | IOMUXC_GPIO_EMC_B1_15_GPIO_MUX1_IO15 0x400E804CU, 0x5U, 0, 0, 0x400E8290U |
#define | IOMUXC_GPIO_EMC_B1_15_FLEXIO1_D15 0x400E804CU, 0x8U, 0, 0, 0x400E8290U |
#define | IOMUXC_GPIO_EMC_B1_15_GPIO7_IO15 0x400E804CU, 0xAU, 0, 0, 0x400E8290U |
#define | IOMUXC_GPIO_EMC_B1_16_SEMC_ADDR07 0x400E8050U, 0x0U, 0, 0, 0x400E8294U |
#define | IOMUXC_GPIO_EMC_B1_16_XBAR1_INOUT08 0x400E8050U, 0x1U, 0, 0, 0x400E8294U |
#define | IOMUXC_GPIO_EMC_B1_16_GPIO_MUX1_IO16 0x400E8050U, 0x5U, 0, 0, 0x400E8294U |
#define | IOMUXC_GPIO_EMC_B1_16_FLEXIO1_D16 0x400E8050U, 0x8U, 0, 0, 0x400E8294U |
#define | IOMUXC_GPIO_EMC_B1_16_GPIO7_IO16 0x400E8050U, 0xAU, 0, 0, 0x400E8294U |
#define | IOMUXC_GPIO_EMC_B1_17_GPIO7_IO17 0x400E8054U, 0xAU, 0, 0, 0x400E8298U |
#define | IOMUXC_GPIO_EMC_B1_17_SEMC_ADDR08 0x400E8054U, 0x0U, 0, 0, 0x400E8298U |
#define | IOMUXC_GPIO_EMC_B1_17_FLEXPWM4_PWM3_A 0x400E8054U, 0x1U, 0, 0, 0x400E8298U |
#define | IOMUXC_GPIO_EMC_B1_17_TMR1_TIMER0 0x400E8054U, 0x2U, 0x400E863CU, 0x0U, 0x400E8298U |
#define | IOMUXC_GPIO_EMC_B1_17_GPIO_MUX1_IO17 0x400E8054U, 0x5U, 0, 0, 0x400E8298U |
#define | IOMUXC_GPIO_EMC_B1_17_FLEXIO1_D17 0x400E8054U, 0x8U, 0, 0, 0x400E8298U |
#define | IOMUXC_GPIO_EMC_B1_18_SEMC_ADDR09 0x400E8058U, 0x0U, 0, 0, 0x400E829CU |
#define | IOMUXC_GPIO_EMC_B1_18_FLEXPWM4_PWM3_B 0x400E8058U, 0x1U, 0, 0, 0x400E829CU |
#define | IOMUXC_GPIO_EMC_B1_18_TMR2_TIMER0 0x400E8058U, 0x2U, 0x400E8648U, 0x0U, 0x400E829CU |
#define | IOMUXC_GPIO_EMC_B1_18_GPIO_MUX1_IO18 0x400E8058U, 0x5U, 0, 0, 0x400E829CU |
#define | IOMUXC_GPIO_EMC_B1_18_FLEXIO1_D18 0x400E8058U, 0x8U, 0, 0, 0x400E829CU |
#define | IOMUXC_GPIO_EMC_B1_18_GPIO7_IO18 0x400E8058U, 0xAU, 0, 0, 0x400E829CU |
#define | IOMUXC_GPIO_EMC_B1_19_SEMC_ADDR11 0x400E805CU, 0x0U, 0, 0, 0x400E82A0U |
#define | IOMUXC_GPIO_EMC_B1_19_FLEXPWM2_PWM3_A 0x400E805CU, 0x1U, 0, 0, 0x400E82A0U |
#define | IOMUXC_GPIO_EMC_B1_19_TMR3_TIMER0 0x400E805CU, 0x2U, 0x400E8654U, 0x0U, 0x400E82A0U |
#define | IOMUXC_GPIO_EMC_B1_19_GPIO_MUX1_IO19 0x400E805CU, 0x5U, 0, 0, 0x400E82A0U |
#define | IOMUXC_GPIO_EMC_B1_19_FLEXIO1_D19 0x400E805CU, 0x8U, 0, 0, 0x400E82A0U |
#define | IOMUXC_GPIO_EMC_B1_19_GPIO7_IO19 0x400E805CU, 0xAU, 0, 0, 0x400E82A0U |
#define | IOMUXC_GPIO_EMC_B1_20_SEMC_ADDR12 0x400E8060U, 0x0U, 0, 0, 0x400E82A4U |
#define | IOMUXC_GPIO_EMC_B1_20_FLEXPWM2_PWM3_B 0x400E8060U, 0x1U, 0, 0, 0x400E82A4U |
#define | IOMUXC_GPIO_EMC_B1_20_TMR4_TIMER0 0x400E8060U, 0x2U, 0x400E8660U, 0x0U, 0x400E82A4U |
#define | IOMUXC_GPIO_EMC_B1_20_GPIO_MUX1_IO20 0x400E8060U, 0x5U, 0, 0, 0x400E82A4U |
#define | IOMUXC_GPIO_EMC_B1_20_FLEXIO1_D20 0x400E8060U, 0x8U, 0, 0, 0x400E82A4U |
#define | IOMUXC_GPIO_EMC_B1_20_GPIO7_IO20 0x400E8060U, 0xAU, 0, 0, 0x400E82A4U |
#define | IOMUXC_GPIO_EMC_B1_21_GPIO7_IO21 0x400E8064U, 0xAU, 0, 0, 0x400E82A8U |
#define | IOMUXC_GPIO_EMC_B1_21_SEMC_BA0 0x400E8064U, 0x0U, 0, 0, 0x400E82A8U |
#define | IOMUXC_GPIO_EMC_B1_21_FLEXPWM3_PWM3_A 0x400E8064U, 0x1U, 0x400E853CU, 0x0U, 0x400E82A8U |
#define | IOMUXC_GPIO_EMC_B1_21_GPIO_MUX1_IO21 0x400E8064U, 0x5U, 0, 0, 0x400E82A8U |
#define | IOMUXC_GPIO_EMC_B1_21_FLEXIO1_D21 0x400E8064U, 0x8U, 0, 0, 0x400E82A8U |
#define | IOMUXC_GPIO_EMC_B1_22_GPIO7_IO22 0x400E8068U, 0xAU, 0, 0, 0x400E82ACU |
#define | IOMUXC_GPIO_EMC_B1_22_SEMC_BA1 0x400E8068U, 0x0U, 0, 0, 0x400E82ACU |
#define | IOMUXC_GPIO_EMC_B1_22_FLEXPWM3_PWM3_B 0x400E8068U, 0x1U, 0x400E854CU, 0x0U, 0x400E82ACU |
#define | IOMUXC_GPIO_EMC_B1_22_GPIO_MUX1_IO22 0x400E8068U, 0x5U, 0, 0, 0x400E82ACU |
#define | IOMUXC_GPIO_EMC_B1_22_FLEXIO1_D22 0x400E8068U, 0x8U, 0, 0, 0x400E82ACU |
#define | IOMUXC_GPIO_EMC_B1_23_SEMC_ADDR10 0x400E806CU, 0x0U, 0, 0, 0x400E82B0U |
#define | IOMUXC_GPIO_EMC_B1_23_FLEXPWM1_PWM0_A 0x400E806CU, 0x1U, 0x400E8500U, 0x0U, 0x400E82B0U |
#define | IOMUXC_GPIO_EMC_B1_23_GPIO_MUX1_IO23 0x400E806CU, 0x5U, 0, 0, 0x400E82B0U |
#define | IOMUXC_GPIO_EMC_B1_23_FLEXIO1_D23 0x400E806CU, 0x8U, 0, 0, 0x400E82B0U |
#define | IOMUXC_GPIO_EMC_B1_23_GPIO7_IO23 0x400E806CU, 0xAU, 0, 0, 0x400E82B0U |
#define | IOMUXC_GPIO_EMC_B1_24_GPIO7_IO24 0x400E8070U, 0xAU, 0, 0, 0x400E82B4U |
#define | IOMUXC_GPIO_EMC_B1_24_SEMC_CAS 0x400E8070U, 0x0U, 0, 0, 0x400E82B4U |
#define | IOMUXC_GPIO_EMC_B1_24_FLEXPWM1_PWM0_B 0x400E8070U, 0x1U, 0x400E850CU, 0x0U, 0x400E82B4U |
#define | IOMUXC_GPIO_EMC_B1_24_GPIO_MUX1_IO24 0x400E8070U, 0x5U, 0, 0, 0x400E82B4U |
#define | IOMUXC_GPIO_EMC_B1_24_FLEXIO1_D24 0x400E8070U, 0x8U, 0, 0, 0x400E82B4U |
#define | IOMUXC_GPIO_EMC_B1_25_GPIO7_IO25 0x400E8074U, 0xAU, 0, 0, 0x400E82B8U |
#define | IOMUXC_GPIO_EMC_B1_25_SEMC_RAS 0x400E8074U, 0x0U, 0, 0, 0x400E82B8U |
#define | IOMUXC_GPIO_EMC_B1_25_FLEXPWM1_PWM1_A 0x400E8074U, 0x1U, 0x400E8504U, 0x0U, 0x400E82B8U |
#define | IOMUXC_GPIO_EMC_B1_25_GPIO_MUX1_IO25 0x400E8074U, 0x5U, 0, 0, 0x400E82B8U |
#define | IOMUXC_GPIO_EMC_B1_25_FLEXIO1_D25 0x400E8074U, 0x8U, 0, 0, 0x400E82B8U |
#define | IOMUXC_GPIO_EMC_B1_26_SEMC_CLK 0x400E8078U, 0x0U, 0, 0, 0x400E82BCU |
#define | IOMUXC_GPIO_EMC_B1_26_FLEXPWM1_PWM1_B 0x400E8078U, 0x1U, 0x400E8510U, 0x0U, 0x400E82BCU |
#define | IOMUXC_GPIO_EMC_B1_26_GPIO_MUX1_IO26 0x400E8078U, 0x5U, 0, 0, 0x400E82BCU |
#define | IOMUXC_GPIO_EMC_B1_26_FLEXIO1_D26 0x400E8078U, 0x8U, 0, 0, 0x400E82BCU |
#define | IOMUXC_GPIO_EMC_B1_26_GPIO7_IO26 0x400E8078U, 0xAU, 0, 0, 0x400E82BCU |
#define | IOMUXC_GPIO_EMC_B1_27_GPIO7_IO27 0x400E807CU, 0xAU, 0, 0, 0x400E82C0U |
#define | IOMUXC_GPIO_EMC_B1_27_SEMC_CKE 0x400E807CU, 0x0U, 0, 0, 0x400E82C0U |
#define | IOMUXC_GPIO_EMC_B1_27_FLEXPWM1_PWM2_A 0x400E807CU, 0x1U, 0x400E8508U, 0x0U, 0x400E82C0U |
#define | IOMUXC_GPIO_EMC_B1_27_GPIO_MUX1_IO27 0x400E807CU, 0x5U, 0, 0, 0x400E82C0U |
#define | IOMUXC_GPIO_EMC_B1_27_FLEXIO1_D27 0x400E807CU, 0x8U, 0, 0, 0x400E82C0U |
#define | IOMUXC_GPIO_EMC_B1_28_GPIO7_IO28 0x400E8080U, 0xAU, 0, 0, 0x400E82C4U |
#define | IOMUXC_GPIO_EMC_B1_28_SEMC_WE 0x400E8080U, 0x0U, 0, 0, 0x400E82C4U |
#define | IOMUXC_GPIO_EMC_B1_28_FLEXPWM1_PWM2_B 0x400E8080U, 0x1U, 0x400E8514U, 0x0U, 0x400E82C4U |
#define | IOMUXC_GPIO_EMC_B1_28_GPIO_MUX1_IO28 0x400E8080U, 0x5U, 0, 0, 0x400E82C4U |
#define | IOMUXC_GPIO_EMC_B1_28_FLEXIO1_D28 0x400E8080U, 0x8U, 0, 0, 0x400E82C4U |
#define | IOMUXC_GPIO_EMC_B1_29_SEMC_CS0 0x400E8084U, 0x0U, 0, 0, 0x400E82C8U |
#define | IOMUXC_GPIO_EMC_B1_29_FLEXPWM3_PWM0_A 0x400E8084U, 0x1U, 0x400E8530U, 0x0U, 0x400E82C8U |
#define | IOMUXC_GPIO_EMC_B1_29_GPIO_MUX1_IO29 0x400E8084U, 0x5U, 0, 0, 0x400E82C8U |
#define | IOMUXC_GPIO_EMC_B1_29_FLEXIO1_D29 0x400E8084U, 0x8U, 0, 0, 0x400E82C8U |
#define | IOMUXC_GPIO_EMC_B1_29_GPIO7_IO29 0x400E8084U, 0xAU, 0, 0, 0x400E82C8U |
#define | IOMUXC_GPIO_EMC_B1_30_SEMC_DATA08 0x400E8088U, 0x0U, 0, 0, 0x400E82CCU |
#define | IOMUXC_GPIO_EMC_B1_30_FLEXPWM3_PWM0_B 0x400E8088U, 0x1U, 0x400E8540U, 0x0U, 0x400E82CCU |
#define | IOMUXC_GPIO_EMC_B1_30_GPIO_MUX1_IO30 0x400E8088U, 0x5U, 0, 0, 0x400E82CCU |
#define | IOMUXC_GPIO_EMC_B1_30_FLEXIO1_D30 0x400E8088U, 0x8U, 0, 0, 0x400E82CCU |
#define | IOMUXC_GPIO_EMC_B1_30_GPIO7_IO30 0x400E8088U, 0xAU, 0, 0, 0x400E82CCU |
#define | IOMUXC_GPIO_EMC_B1_31_GPIO7_IO31 0x400E808CU, 0xAU, 0, 0, 0x400E82D0U |
#define | IOMUXC_GPIO_EMC_B1_31_SEMC_DATA09 0x400E808CU, 0x0U, 0, 0, 0x400E82D0U |
#define | IOMUXC_GPIO_EMC_B1_31_FLEXPWM3_PWM1_A 0x400E808CU, 0x1U, 0x400E8534U, 0x0U, 0x400E82D0U |
#define | IOMUXC_GPIO_EMC_B1_31_GPIO_MUX1_IO31 0x400E808CU, 0x5U, 0, 0, 0x400E82D0U |
#define | IOMUXC_GPIO_EMC_B1_31_FLEXIO1_D31 0x400E808CU, 0x8U, 0, 0, 0x400E82D0U |
#define | IOMUXC_GPIO_EMC_B1_32_GPIO8_IO00 0x400E8090U, 0xAU, 0, 0, 0x400E82D4U |
#define | IOMUXC_GPIO_EMC_B1_32_SEMC_DATA10 0x400E8090U, 0x0U, 0, 0, 0x400E82D4U |
#define | IOMUXC_GPIO_EMC_B1_32_FLEXPWM3_PWM1_B 0x400E8090U, 0x1U, 0x400E8544U, 0x0U, 0x400E82D4U |
#define | IOMUXC_GPIO_EMC_B1_32_GPIO_MUX2_IO00 0x400E8090U, 0x5U, 0, 0, 0x400E82D4U |
#define | IOMUXC_GPIO_EMC_B1_33_SEMC_DATA11 0x400E8094U, 0x0U, 0, 0, 0x400E82D8U |
#define | IOMUXC_GPIO_EMC_B1_33_FLEXPWM3_PWM2_A 0x400E8094U, 0x1U, 0x400E8538U, 0x0U, 0x400E82D8U |
#define | IOMUXC_GPIO_EMC_B1_33_GPIO_MUX2_IO01 0x400E8094U, 0x5U, 0, 0, 0x400E82D8U |
#define | IOMUXC_GPIO_EMC_B1_33_GPIO8_IO01 0x400E8094U, 0xAU, 0, 0, 0x400E82D8U |
#define | IOMUXC_GPIO_EMC_B1_34_GPIO8_IO02 0x400E8098U, 0xAU, 0, 0, 0x400E82DCU |
#define | IOMUXC_GPIO_EMC_B1_34_SEMC_DATA12 0x400E8098U, 0x0U, 0, 0, 0x400E82DCU |
#define | IOMUXC_GPIO_EMC_B1_34_FLEXPWM3_PWM2_B 0x400E8098U, 0x1U, 0x400E8548U, 0x0U, 0x400E82DCU |
#define | IOMUXC_GPIO_EMC_B1_34_GPIO_MUX2_IO02 0x400E8098U, 0x5U, 0, 0, 0x400E82DCU |
#define | IOMUXC_GPIO_EMC_B1_35_GPIO8_IO03 0x400E809CU, 0xAU, 0, 0, 0x400E82E0U |
#define | IOMUXC_GPIO_EMC_B1_35_SEMC_DATA13 0x400E809CU, 0x0U, 0, 0, 0x400E82E0U |
#define | IOMUXC_GPIO_EMC_B1_35_XBAR1_INOUT09 0x400E809CU, 0x1U, 0, 0, 0x400E82E0U |
#define | IOMUXC_GPIO_EMC_B1_35_GPIO_MUX2_IO03 0x400E809CU, 0x5U, 0, 0, 0x400E82E0U |
#define | IOMUXC_GPIO_EMC_B1_36_SEMC_DATA14 0x400E80A0U, 0x0U, 0, 0, 0x400E82E4U |
#define | IOMUXC_GPIO_EMC_B1_36_XBAR1_INOUT10 0x400E80A0U, 0x1U, 0, 0, 0x400E82E4U |
#define | IOMUXC_GPIO_EMC_B1_36_GPIO_MUX2_IO04 0x400E80A0U, 0x5U, 0, 0, 0x400E82E4U |
#define | IOMUXC_GPIO_EMC_B1_36_GPIO8_IO04 0x400E80A0U, 0xAU, 0, 0, 0x400E82E4U |
#define | IOMUXC_GPIO_EMC_B1_37_GPIO8_IO05 0x400E80A4U, 0xAU, 0, 0, 0x400E82E8U |
#define | IOMUXC_GPIO_EMC_B1_37_SEMC_DATA15 0x400E80A4U, 0x0U, 0, 0, 0x400E82E8U |
#define | IOMUXC_GPIO_EMC_B1_37_XBAR1_INOUT11 0x400E80A4U, 0x1U, 0, 0, 0x400E82E8U |
#define | IOMUXC_GPIO_EMC_B1_37_GPIO_MUX2_IO05 0x400E80A4U, 0x5U, 0, 0, 0x400E82E8U |
#define | IOMUXC_GPIO_EMC_B1_38_GPIO8_IO06 0x400E80A8U, 0xAU, 0, 0, 0x400E82ECU |
#define | IOMUXC_GPIO_EMC_B1_38_SEMC_DM01 0x400E80A8U, 0x0U, 0, 0, 0x400E82ECU |
#define | IOMUXC_GPIO_EMC_B1_38_FLEXPWM1_PWM3_A 0x400E80A8U, 0x1U, 0, 0, 0x400E82ECU |
#define | IOMUXC_GPIO_EMC_B1_38_TMR1_TIMER1 0x400E80A8U, 0x2U, 0x400E8640U, 0x0U, 0x400E82ECU |
#define | IOMUXC_GPIO_EMC_B1_38_GPIO_MUX2_IO06 0x400E80A8U, 0x5U, 0, 0, 0x400E82ECU |
#define | IOMUXC_GPIO_EMC_B1_39_SEMC_DQS 0x400E80ACU, 0x0U, 0, 0, 0x400E82F0U |
#define | IOMUXC_GPIO_EMC_B1_39_FLEXPWM1_PWM3_B 0x400E80ACU, 0x1U, 0, 0, 0x400E82F0U |
#define | IOMUXC_GPIO_EMC_B1_39_TMR2_TIMER1 0x400E80ACU, 0x2U, 0x400E864CU, 0x0U, 0x400E82F0U |
#define | IOMUXC_GPIO_EMC_B1_39_GPIO_MUX2_IO07 0x400E80ACU, 0x5U, 0, 0, 0x400E82F0U |
#define | IOMUXC_GPIO_EMC_B1_39_GPIO8_IO07 0x400E80ACU, 0xAU, 0, 0, 0x400E82F0U |
#define | IOMUXC_GPIO_EMC_B1_40_SEMC_RDY 0x400E80B0U, 0x0U, 0, 0, 0x400E82F4U |
#define | IOMUXC_GPIO_EMC_B1_40_XBAR1_INOUT12 0x400E80B0U, 0x1U, 0, 0, 0x400E82F4U |
#define | IOMUXC_GPIO_EMC_B1_40_MQS_RIGHT 0x400E80B0U, 0x2U, 0, 0, 0x400E82F4U |
#define | IOMUXC_GPIO_EMC_B1_40_LPUART6_TXD 0x400E80B0U, 0x3U, 0, 0, 0x400E82F4U |
#define | IOMUXC_GPIO_EMC_B1_40_GPIO_MUX2_IO08 0x400E80B0U, 0x5U, 0, 0, 0x400E82F4U |
#define | IOMUXC_GPIO_EMC_B1_40_ENET_1G_MDC 0x400E80B0U, 0x7U, 0, 0, 0x400E82F4U |
#define | IOMUXC_GPIO_EMC_B1_40_CCM_CLKO1 0x400E80B0U, 0x9U, 0, 0, 0x400E82F4U |
#define | IOMUXC_GPIO_EMC_B1_40_GPIO8_IO08 0x400E80B0U, 0xAU, 0, 0, 0x400E82F4U |
#define | IOMUXC_GPIO_EMC_B1_41_GPIO8_IO09 0x400E80B4U, 0xAU, 0, 0, 0x400E82F8U |
#define | IOMUXC_GPIO_EMC_B1_41_SEMC_CSX00 0x400E80B4U, 0x0U, 0, 0, 0x400E82F8U |
#define | IOMUXC_GPIO_EMC_B1_41_XBAR1_INOUT13 0x400E80B4U, 0x1U, 0, 0, 0x400E82F8U |
#define | IOMUXC_GPIO_EMC_B1_41_MQS_LEFT 0x400E80B4U, 0x2U, 0, 0, 0x400E82F8U |
#define | IOMUXC_GPIO_EMC_B1_41_LPUART6_RXD 0x400E80B4U, 0x3U, 0, 0, 0x400E82F8U |
#define | IOMUXC_GPIO_EMC_B1_41_FLEXSPI2_B_DATA07 0x400E80B4U, 0x4U, 0, 0, 0x400E82F8U |
#define | IOMUXC_GPIO_EMC_B1_41_GPIO_MUX2_IO09 0x400E80B4U, 0x5U, 0, 0, 0x400E82F8U |
#define | IOMUXC_GPIO_EMC_B1_41_ENET_1G_MDIO 0x400E80B4U, 0x7U, 0x400E84C8U, 0x0U, 0x400E82F8U |
#define | IOMUXC_GPIO_EMC_B1_41_CCM_CLKO2 0x400E80B4U, 0x9U, 0, 0, 0x400E82F8U |
#define | IOMUXC_GPIO_EMC_B2_00_SEMC_DATA16 0x400E80B8U, 0x0U, 0, 0, 0x400E82FCU |
#define | IOMUXC_GPIO_EMC_B2_00_CCM_ENET_REF_CLK_25M 0x400E80B8U, 0x1U, 0, 0, 0x400E82FCU |
#define | IOMUXC_GPIO_EMC_B2_00_TMR3_TIMER1 0x400E80B8U, 0x2U, 0x400E8658U, 0x0U, 0x400E82FCU |
#define | IOMUXC_GPIO_EMC_B2_00_LPUART6_CTS_B 0x400E80B8U, 0x3U, 0, 0, 0x400E82FCU |
#define | IOMUXC_GPIO_EMC_B2_00_FLEXSPI2_B_DATA06 0x400E80B8U, 0x4U, 0, 0, 0x400E82FCU |
#define | IOMUXC_GPIO_EMC_B2_00_GPIO_MUX2_IO10 0x400E80B8U, 0x5U, 0, 0, 0x400E82FCU |
#define | IOMUXC_GPIO_EMC_B2_00_XBAR1_INOUT20 0x400E80B8U, 0x6U, 0x400E86D8U, 0x0U, 0x400E82FCU |
#define | IOMUXC_GPIO_EMC_B2_00_ENET_QOS_1588_EVENT1_OUT 0x400E80B8U, 0x7U, 0, 0, 0x400E82FCU |
#define | IOMUXC_GPIO_EMC_B2_00_LPSPI1_SCK 0x400E80B8U, 0x8U, 0x400E85D0U, 0x0U, 0x400E82FCU |
#define | IOMUXC_GPIO_EMC_B2_00_LPI2C2_SCL 0x400E80B8U, 0x9U, 0x400E85B4U, 0x0U, 0x400E82FCU |
#define | IOMUXC_GPIO_EMC_B2_00_GPIO8_IO10 0x400E80B8U, 0xAU, 0, 0, 0x400E82FCU |
#define | IOMUXC_GPIO_EMC_B2_00_FLEXPWM3_PWM0_A 0x400E80B8U, 0xBU, 0x400E8530U, 0x1U, 0x400E82FCU |
#define | IOMUXC_GPIO_EMC_B2_01_SEMC_DATA17 0x400E80BCU, 0x0U, 0, 0, 0x400E8300U |
#define | IOMUXC_GPIO_EMC_B2_01_USDHC2_CD_B 0x400E80BCU, 0x1U, 0x400E86D0U, 0x0U, 0x400E8300U |
#define | IOMUXC_GPIO_EMC_B2_01_TMR4_TIMER1 0x400E80BCU, 0x2U, 0x400E8664U, 0x0U, 0x400E8300U |
#define | IOMUXC_GPIO_EMC_B2_01_LPUART6_RTS_B 0x400E80BCU, 0x3U, 0, 0, 0x400E8300U |
#define | IOMUXC_GPIO_EMC_B2_01_FLEXSPI2_B_DATA05 0x400E80BCU, 0x4U, 0, 0, 0x400E8300U |
#define | IOMUXC_GPIO_EMC_B2_01_GPIO_MUX2_IO11 0x400E80BCU, 0x5U, 0, 0, 0x400E8300U |
#define | IOMUXC_GPIO_EMC_B2_01_XBAR1_INOUT21 0x400E80BCU, 0x6U, 0x400E86DCU, 0x0U, 0x400E8300U |
#define | IOMUXC_GPIO_EMC_B2_01_ENET_QOS_1588_EVENT1_IN 0x400E80BCU, 0x7U, 0, 0, 0x400E8300U |
#define | IOMUXC_GPIO_EMC_B2_01_LPSPI1_PCS0 0x400E80BCU, 0x8U, 0x400E85CCU, 0x0U, 0x400E8300U |
#define | IOMUXC_GPIO_EMC_B2_01_LPI2C2_SDA 0x400E80BCU, 0x9U, 0x400E85B8U, 0x0U, 0x400E8300U |
#define | IOMUXC_GPIO_EMC_B2_01_GPIO8_IO11 0x400E80BCU, 0xAU, 0, 0, 0x400E8300U |
#define | IOMUXC_GPIO_EMC_B2_01_FLEXPWM3_PWM0_B 0x400E80BCU, 0xBU, 0x400E8540U, 0x1U, 0x400E8300U |
#define | IOMUXC_GPIO_EMC_B2_02_SEMC_DATA18 0x400E80C0U, 0x0U, 0, 0, 0x400E8304U |
#define | IOMUXC_GPIO_EMC_B2_02_USDHC2_WP 0x400E80C0U, 0x1U, 0x400E86D4U, 0x0U, 0x400E8304U |
#define | IOMUXC_GPIO_EMC_B2_02_VIDEO_MUX_CSI_DATA23 0x400E80C0U, 0x3U, 0, 0, 0x400E8304U |
#define | IOMUXC_GPIO_EMC_B2_02_FLEXSPI2_B_DATA04 0x400E80C0U, 0x4U, 0, 0, 0x400E8304U |
#define | IOMUXC_GPIO_EMC_B2_02_GPIO_MUX2_IO12 0x400E80C0U, 0x5U, 0, 0, 0x400E8304U |
#define | IOMUXC_GPIO_EMC_B2_02_XBAR1_INOUT22 0x400E80C0U, 0x6U, 0x400E86E0U, 0x0U, 0x400E8304U |
#define | IOMUXC_GPIO_EMC_B2_02_ENET_QOS_1588_EVENT1_AUX_IN 0x400E80C0U, 0x7U, 0, 0, 0x400E8304U |
#define | IOMUXC_GPIO_EMC_B2_02_LPSPI1_SOUT 0x400E80C0U, 0x8U, 0x400E85D8U, 0x0U, 0x400E8304U |
#define | IOMUXC_GPIO_EMC_B2_02_GPIO8_IO12 0x400E80C0U, 0xAU, 0, 0, 0x400E8304U |
#define | IOMUXC_GPIO_EMC_B2_02_FLEXPWM3_PWM1_A 0x400E80C0U, 0xBU, 0x400E8534U, 0x1U, 0x400E8304U |
#define | IOMUXC_GPIO_EMC_B2_03_SEMC_DATA19 0x400E80C4U, 0x0U, 0, 0, 0x400E8308U |
#define | IOMUXC_GPIO_EMC_B2_03_USDHC2_VSELECT 0x400E80C4U, 0x1U, 0, 0, 0x400E8308U |
#define | IOMUXC_GPIO_EMC_B2_03_VIDEO_MUX_CSI_DATA22 0x400E80C4U, 0x3U, 0, 0, 0x400E8308U |
#define | IOMUXC_GPIO_EMC_B2_03_FLEXSPI2_B_DATA03 0x400E80C4U, 0x4U, 0, 0, 0x400E8308U |
#define | IOMUXC_GPIO_EMC_B2_03_GPIO_MUX2_IO13 0x400E80C4U, 0x5U, 0, 0, 0x400E8308U |
#define | IOMUXC_GPIO_EMC_B2_03_XBAR1_INOUT23 0x400E80C4U, 0x6U, 0x400E86E4U, 0x0U, 0x400E8308U |
#define | IOMUXC_GPIO_EMC_B2_03_ENET_1G_TX_DATA03 0x400E80C4U, 0x7U, 0, 0, 0x400E8308U |
#define | IOMUXC_GPIO_EMC_B2_03_LPSPI1_SIN 0x400E80C4U, 0x8U, 0x400E85D4U, 0x0U, 0x400E8308U |
#define | IOMUXC_GPIO_EMC_B2_03_GPIO8_IO13 0x400E80C4U, 0xAU, 0, 0, 0x400E8308U |
#define | IOMUXC_GPIO_EMC_B2_03_FLEXPWM3_PWM1_B 0x400E80C4U, 0xBU, 0x400E8544U, 0x1U, 0x400E8308U |
#define | IOMUXC_GPIO_EMC_B2_04_SEMC_DATA20 0x400E80C8U, 0x0U, 0, 0, 0x400E830CU |
#define | IOMUXC_GPIO_EMC_B2_04_USDHC2_RESET_B 0x400E80C8U, 0x1U, 0, 0, 0x400E830CU |
#define | IOMUXC_GPIO_EMC_B2_04_SAI2_MCLK 0x400E80C8U, 0x2U, 0, 0, 0x400E830CU |
#define | IOMUXC_GPIO_EMC_B2_04_VIDEO_MUX_CSI_DATA21 0x400E80C8U, 0x3U, 0, 0, 0x400E830CU |
#define | IOMUXC_GPIO_EMC_B2_04_FLEXSPI2_B_DATA02 0x400E80C8U, 0x4U, 0, 0, 0x400E830CU |
#define | IOMUXC_GPIO_EMC_B2_04_GPIO_MUX2_IO14 0x400E80C8U, 0x5U, 0, 0, 0x400E830CU |
#define | IOMUXC_GPIO_EMC_B2_04_XBAR1_INOUT24 0x400E80C8U, 0x6U, 0x400E86E8U, 0x0U, 0x400E830CU |
#define | IOMUXC_GPIO_EMC_B2_04_ENET_1G_TX_DATA02 0x400E80C8U, 0x7U, 0, 0, 0x400E830CU |
#define | IOMUXC_GPIO_EMC_B2_04_LPSPI3_SCK 0x400E80C8U, 0x8U, 0x400E8600U, 0x0U, 0x400E830CU |
#define | IOMUXC_GPIO_EMC_B2_04_GPIO8_IO14 0x400E80C8U, 0xAU, 0, 0, 0x400E830CU |
#define | IOMUXC_GPIO_EMC_B2_04_FLEXPWM3_PWM2_A 0x400E80C8U, 0xBU, 0x400E8538U, 0x1U, 0x400E830CU |
#define | IOMUXC_GPIO_EMC_B2_05_SEMC_DATA21 0x400E80CCU, 0x0U, 0, 0, 0x400E8310U |
#define | IOMUXC_GPIO_EMC_B2_05_GPT3_CLK 0x400E80CCU, 0x1U, 0x400E8598U, 0x0U, 0x400E8310U |
#define | IOMUXC_GPIO_EMC_B2_05_SAI2_RX_SYNC 0x400E80CCU, 0x2U, 0, 0, 0x400E8310U |
#define | IOMUXC_GPIO_EMC_B2_05_VIDEO_MUX_CSI_DATA20 0x400E80CCU, 0x3U, 0, 0, 0x400E8310U |
#define | IOMUXC_GPIO_EMC_B2_05_FLEXSPI2_B_DATA01 0x400E80CCU, 0x4U, 0, 0, 0x400E8310U |
#define | IOMUXC_GPIO_EMC_B2_05_GPIO_MUX2_IO15 0x400E80CCU, 0x5U, 0, 0, 0x400E8310U |
#define | IOMUXC_GPIO_EMC_B2_05_XBAR1_INOUT25 0x400E80CCU, 0x6U, 0x400E86ECU, 0x0U, 0x400E8310U |
#define | IOMUXC_GPIO_EMC_B2_05_ENET_1G_RX_CLK 0x400E80CCU, 0x7U, 0x400E84CCU, 0x0U, 0x400E8310U |
#define | IOMUXC_GPIO_EMC_B2_05_LPSPI3_PCS0 0x400E80CCU, 0x8U, 0x400E85F0U, 0x0U, 0x400E8310U |
#define | IOMUXC_GPIO_EMC_B2_05_PIT1_TRIGGER0 0x400E80CCU, 0x9U, 0, 0, 0x400E8310U |
#define | IOMUXC_GPIO_EMC_B2_05_GPIO8_IO15 0x400E80CCU, 0xAU, 0, 0, 0x400E8310U |
#define | IOMUXC_GPIO_EMC_B2_05_FLEXPWM3_PWM2_B 0x400E80CCU, 0xBU, 0x400E8548U, 0x1U, 0x400E8310U |
#define | IOMUXC_GPIO_EMC_B2_06_SEMC_DATA22 0x400E80D0U, 0x0U, 0, 0, 0x400E8314U |
#define | IOMUXC_GPIO_EMC_B2_06_GPT3_CAPTURE1 0x400E80D0U, 0x1U, 0x400E8590U, 0x0U, 0x400E8314U |
#define | IOMUXC_GPIO_EMC_B2_06_GPIO8_IO16 0x400E80D0U, 0xAU, 0, 0, 0x400E8314U |
#define | IOMUXC_GPIO_EMC_B2_06_SAI2_RX_BCLK 0x400E80D0U, 0x2U, 0, 0, 0x400E8314U |
#define | IOMUXC_GPIO_EMC_B2_06_FLEXPWM3_PWM3_A 0x400E80D0U, 0xBU, 0x400E853CU, 0x1U, 0x400E8314U |
#define | IOMUXC_GPIO_EMC_B2_06_VIDEO_MUX_CSI_DATA19 0x400E80D0U, 0x3U, 0, 0, 0x400E8314U |
#define | IOMUXC_GPIO_EMC_B2_06_FLEXSPI2_B_DATA00 0x400E80D0U, 0x4U, 0, 0, 0x400E8314U |
#define | IOMUXC_GPIO_EMC_B2_06_GPIO_MUX2_IO16 0x400E80D0U, 0x5U, 0, 0, 0x400E8314U |
#define | IOMUXC_GPIO_EMC_B2_06_XBAR1_INOUT26 0x400E80D0U, 0x6U, 0x400E86F0U, 0x0U, 0x400E8314U |
#define | IOMUXC_GPIO_EMC_B2_06_ENET_1G_TX_ER 0x400E80D0U, 0x7U, 0, 0, 0x400E8314U |
#define | IOMUXC_GPIO_EMC_B2_06_LPSPI3_SOUT 0x400E80D0U, 0x8U, 0x400E8608U, 0x0U, 0x400E8314U |
#define | IOMUXC_GPIO_EMC_B2_06_PIT1_TRIGGER1 0x400E80D0U, 0x9U, 0, 0, 0x400E8314U |
#define | IOMUXC_GPIO_EMC_B2_07_SEMC_DATA23 0x400E80D4U, 0x0U, 0, 0, 0x400E8318U |
#define | IOMUXC_GPIO_EMC_B2_07_GPT3_CAPTURE2 0x400E80D4U, 0x1U, 0x400E8594U, 0x0U, 0x400E8318U |
#define | IOMUXC_GPIO_EMC_B2_07_SAI2_RX_DATA 0x400E80D4U, 0x2U, 0, 0, 0x400E8318U |
#define | IOMUXC_GPIO_EMC_B2_07_VIDEO_MUX_CSI_DATA18 0x400E80D4U, 0x3U, 0, 0, 0x400E8318U |
#define | IOMUXC_GPIO_EMC_B2_07_FLEXSPI2_B_DQS 0x400E80D4U, 0x4U, 0, 0, 0x400E8318U |
#define | IOMUXC_GPIO_EMC_B2_07_GPIO_MUX2_IO17 0x400E80D4U, 0x5U, 0, 0, 0x400E8318U |
#define | IOMUXC_GPIO_EMC_B2_07_XBAR1_INOUT27 0x400E80D4U, 0x6U, 0x400E86F4U, 0x0U, 0x400E8318U |
#define | IOMUXC_GPIO_EMC_B2_07_ENET_1G_RX_DATA03 0x400E80D4U, 0x7U, 0x400E84DCU, 0x0U, 0x400E8318U |
#define | IOMUXC_GPIO_EMC_B2_07_LPSPI3_SIN 0x400E80D4U, 0x8U, 0x400E8604U, 0x0U, 0x400E8318U |
#define | IOMUXC_GPIO_EMC_B2_07_PIT1_TRIGGER2 0x400E80D4U, 0x9U, 0, 0, 0x400E8318U |
#define | IOMUXC_GPIO_EMC_B2_07_GPIO8_IO17 0x400E80D4U, 0xAU, 0, 0, 0x400E8318U |
#define | IOMUXC_GPIO_EMC_B2_07_FLEXPWM3_PWM3_B 0x400E80D4U, 0xBU, 0x400E854CU, 0x1U, 0x400E8318U |
#define | IOMUXC_GPIO_EMC_B2_08_SEMC_DM02 0x400E80D8U, 0x0U, 0, 0, 0x400E831CU |
#define | IOMUXC_GPIO_EMC_B2_08_GPT3_COMPARE1 0x400E80D8U, 0x1U, 0, 0, 0x400E831CU |
#define | IOMUXC_GPIO_EMC_B2_08_SAI2_TX_DATA 0x400E80D8U, 0x2U, 0, 0, 0x400E831CU |
#define | IOMUXC_GPIO_EMC_B2_08_VIDEO_MUX_CSI_DATA17 0x400E80D8U, 0x3U, 0, 0, 0x400E831CU |
#define | IOMUXC_GPIO_EMC_B2_08_FLEXSPI2_B_SS0_B 0x400E80D8U, 0x4U, 0, 0, 0x400E831CU |
#define | IOMUXC_GPIO_EMC_B2_08_GPIO_MUX2_IO18 0x400E80D8U, 0x5U, 0, 0, 0x400E831CU |
#define | IOMUXC_GPIO_EMC_B2_08_XBAR1_INOUT28 0x400E80D8U, 0x6U, 0x400E86F8U, 0x0U, 0x400E831CU |
#define | IOMUXC_GPIO_EMC_B2_08_ENET_1G_RX_DATA02 0x400E80D8U, 0x7U, 0x400E84D8U, 0x0U, 0x400E831CU |
#define | IOMUXC_GPIO_EMC_B2_08_LPSPI3_PCS1 0x400E80D8U, 0x8U, 0x400E85F4U, 0x0U, 0x400E831CU |
#define | IOMUXC_GPIO_EMC_B2_08_PIT1_TRIGGER3 0x400E80D8U, 0x9U, 0, 0, 0x400E831CU |
#define | IOMUXC_GPIO_EMC_B2_08_GPIO8_IO18 0x400E80D8U, 0xAU, 0, 0, 0x400E831CU |
#define | IOMUXC_GPIO_EMC_B2_09_GPIO8_IO19 0x400E80DCU, 0xAU, 0, 0, 0x400E8320U |
#define | IOMUXC_GPIO_EMC_B2_09_SEMC_DATA24 0x400E80DCU, 0x0U, 0, 0, 0x400E8320U |
#define | IOMUXC_GPIO_EMC_B2_09_GPT3_COMPARE2 0x400E80DCU, 0x1U, 0, 0, 0x400E8320U |
#define | IOMUXC_GPIO_EMC_B2_09_SAI2_TX_BCLK 0x400E80DCU, 0x2U, 0, 0, 0x400E8320U |
#define | IOMUXC_GPIO_EMC_B2_09_VIDEO_MUX_CSI_DATA16 0x400E80DCU, 0x3U, 0, 0, 0x400E8320U |
#define | IOMUXC_GPIO_EMC_B2_09_FLEXSPI2_B_SCLK 0x400E80DCU, 0x4U, 0, 0, 0x400E8320U |
#define | IOMUXC_GPIO_EMC_B2_09_GPIO_MUX2_IO19 0x400E80DCU, 0x5U, 0, 0, 0x400E8320U |
#define | IOMUXC_GPIO_EMC_B2_09_XBAR1_INOUT29 0x400E80DCU, 0x6U, 0x400E86FCU, 0x0U, 0x400E8320U |
#define | IOMUXC_GPIO_EMC_B2_09_ENET_1G_CRS 0x400E80DCU, 0x7U, 0, 0, 0x400E8320U |
#define | IOMUXC_GPIO_EMC_B2_09_LPSPI3_PCS2 0x400E80DCU, 0x8U, 0x400E85F8U, 0x0U, 0x400E8320U |
#define | IOMUXC_GPIO_EMC_B2_09_TMR1_TIMER0 0x400E80DCU, 0x9U, 0x400E863CU, 0x1U, 0x400E8320U |
#define | IOMUXC_GPIO_EMC_B2_10_GPIO8_IO20 0x400E80E0U, 0xAU, 0, 0, 0x400E8324U |
#define | IOMUXC_GPIO_EMC_B2_10_SEMC_DATA25 0x400E80E0U, 0x0U, 0, 0, 0x400E8324U |
#define | IOMUXC_GPIO_EMC_B2_10_GPT3_COMPARE3 0x400E80E0U, 0x1U, 0, 0, 0x400E8324U |
#define | IOMUXC_GPIO_EMC_B2_10_SAI2_TX_SYNC 0x400E80E0U, 0x2U, 0, 0, 0x400E8324U |
#define | IOMUXC_GPIO_EMC_B2_10_VIDEO_MUX_CSI_FIELD 0x400E80E0U, 0x3U, 0, 0, 0x400E8324U |
#define | IOMUXC_GPIO_EMC_B2_10_FLEXSPI2_A_SCLK 0x400E80E0U, 0x4U, 0x400E858CU, 0x0U, 0x400E8324U |
#define | IOMUXC_GPIO_EMC_B2_10_GPIO_MUX2_IO20 0x400E80E0U, 0x5U, 0, 0, 0x400E8324U |
#define | IOMUXC_GPIO_EMC_B2_10_XBAR1_INOUT30 0x400E80E0U, 0x6U, 0x400E8700U, 0x0U, 0x400E8324U |
#define | IOMUXC_GPIO_EMC_B2_10_ENET_1G_COL 0x400E80E0U, 0x7U, 0, 0, 0x400E8324U |
#define | IOMUXC_GPIO_EMC_B2_10_LPSPI3_PCS3 0x400E80E0U, 0x8U, 0x400E85FCU, 0x0U, 0x400E8324U |
#define | IOMUXC_GPIO_EMC_B2_10_TMR1_TIMER1 0x400E80E0U, 0x9U, 0x400E8640U, 0x1U, 0x400E8324U |
#define | IOMUXC_GPIO_EMC_B2_11_SEMC_DATA26 0x400E80E4U, 0x0U, 0, 0, 0x400E8328U |
#define | IOMUXC_GPIO_EMC_B2_11_SPDIF_IN 0x400E80E4U, 0x1U, 0x400E86B4U, 0x0U, 0x400E8328U |
#define | IOMUXC_GPIO_EMC_B2_11_ENET_1G_TX_DATA00 0x400E80E4U, 0x2U, 0, 0, 0x400E8328U |
#define | IOMUXC_GPIO_EMC_B2_11_SAI3_RX_SYNC 0x400E80E4U, 0x3U, 0, 0, 0x400E8328U |
#define | IOMUXC_GPIO_EMC_B2_11_FLEXSPI2_A_SS0_B 0x400E80E4U, 0x4U, 0, 0, 0x400E8328U |
#define | IOMUXC_GPIO_EMC_B2_11_GPIO_MUX2_IO21 0x400E80E4U, 0x5U, 0, 0, 0x400E8328U |
#define | IOMUXC_GPIO_EMC_B2_11_XBAR1_INOUT31 0x400E80E4U, 0x6U, 0x400E8704U, 0x0U, 0x400E8328U |
#define | IOMUXC_GPIO_EMC_B2_11_EMVSIM1_IO 0x400E80E4U, 0x8U, 0x400E869CU, 0x0U, 0x400E8328U |
#define | IOMUXC_GPIO_EMC_B2_11_TMR1_TIMER2 0x400E80E4U, 0x9U, 0x400E8644U, 0x0U, 0x400E8328U |
#define | IOMUXC_GPIO_EMC_B2_11_GPIO8_IO21 0x400E80E4U, 0xAU, 0, 0, 0x400E8328U |
#define | IOMUXC_GPIO_EMC_B2_12_SEMC_DATA27 0x400E80E8U, 0x0U, 0, 0, 0x400E832CU |
#define | IOMUXC_GPIO_EMC_B2_12_SPDIF_OUT 0x400E80E8U, 0x1U, 0, 0, 0x400E832CU |
#define | IOMUXC_GPIO_EMC_B2_12_ENET_1G_TX_DATA01 0x400E80E8U, 0x2U, 0, 0, 0x400E832CU |
#define | IOMUXC_GPIO_EMC_B2_12_SAI3_RX_BCLK 0x400E80E8U, 0x3U, 0, 0, 0x400E832CU |
#define | IOMUXC_GPIO_EMC_B2_12_FLEXSPI2_A_DQS 0x400E80E8U, 0x4U, 0, 0, 0x400E832CU |
#define | IOMUXC_GPIO_EMC_B2_12_GPIO_MUX2_IO22 0x400E80E8U, 0x5U, 0, 0, 0x400E832CU |
#define | IOMUXC_GPIO_EMC_B2_12_XBAR1_INOUT32 0x400E80E8U, 0x6U, 0x400E8708U, 0x0U, 0x400E832CU |
#define | IOMUXC_GPIO_EMC_B2_12_EMVSIM1_CLK 0x400E80E8U, 0x8U, 0, 0, 0x400E832CU |
#define | IOMUXC_GPIO_EMC_B2_12_TMR1_TIMER3 0x400E80E8U, 0x9U, 0, 0, 0x400E832CU |
#define | IOMUXC_GPIO_EMC_B2_12_GPIO8_IO22 0x400E80E8U, 0xAU, 0, 0, 0x400E832CU |
#define | IOMUXC_GPIO_EMC_B2_13_GPIO8_IO23 0x400E80ECU, 0xAU, 0, 0, 0x400E8330U |
#define | IOMUXC_GPIO_EMC_B2_13_SEMC_DATA28 0x400E80ECU, 0x0U, 0, 0, 0x400E8330U |
#define | IOMUXC_GPIO_EMC_B2_13_ENET_1G_TX_EN 0x400E80ECU, 0x2U, 0, 0, 0x400E8330U |
#define | IOMUXC_GPIO_EMC_B2_13_SAI3_RX_DATA 0x400E80ECU, 0x3U, 0, 0, 0x400E8330U |
#define | IOMUXC_GPIO_EMC_B2_13_FLEXSPI2_A_DATA00 0x400E80ECU, 0x4U, 0x400E857CU, 0x0U, 0x400E8330U |
#define | IOMUXC_GPIO_EMC_B2_13_GPIO_MUX2_IO23 0x400E80ECU, 0x5U, 0, 0, 0x400E8330U |
#define | IOMUXC_GPIO_EMC_B2_13_XBAR1_INOUT33 0x400E80ECU, 0x6U, 0x400E870CU, 0x0U, 0x400E8330U |
#define | IOMUXC_GPIO_EMC_B2_13_EMVSIM1_RST 0x400E80ECU, 0x8U, 0, 0, 0x400E8330U |
#define | IOMUXC_GPIO_EMC_B2_13_TMR2_TIMER0 0x400E80ECU, 0x9U, 0x400E8648U, 0x1U, 0x400E8330U |
#define | IOMUXC_GPIO_EMC_B2_14_SEMC_DATA29 0x400E80F0U, 0x0U, 0, 0, 0x400E8334U |
#define | IOMUXC_GPIO_EMC_B2_14_ENET_1G_TX_CLK_IO 0x400E80F0U, 0x2U, 0x400E84E8U, 0x0U, 0x400E8334U |
#define | IOMUXC_GPIO_EMC_B2_14_SAI3_TX_DATA 0x400E80F0U, 0x3U, 0, 0, 0x400E8334U |
#define | IOMUXC_GPIO_EMC_B2_14_FLEXSPI2_A_DATA01 0x400E80F0U, 0x4U, 0x400E8580U, 0x0U, 0x400E8334U |
#define | IOMUXC_GPIO_EMC_B2_14_GPIO_MUX2_IO24 0x400E80F0U, 0x5U, 0, 0, 0x400E8334U |
#define | IOMUXC_GPIO_EMC_B2_14_XBAR1_INOUT34 0x400E80F0U, 0x6U, 0x400E8710U, 0x0U, 0x400E8334U |
#define | IOMUXC_GPIO_EMC_B2_14_SFA_ipp_do_atx_clk_under_test 0x400E80F0U, 0x7U, 0, 0, 0x400E8334U |
#define | IOMUXC_GPIO_EMC_B2_14_EMVSIM1_SVEN 0x400E80F0U, 0x8U, 0, 0, 0x400E8334U |
#define | IOMUXC_GPIO_EMC_B2_14_TMR2_TIMER1 0x400E80F0U, 0x9U, 0x400E864CU, 0x1U, 0x400E8334U |
#define | IOMUXC_GPIO_EMC_B2_14_GPIO8_IO24 0x400E80F0U, 0xAU, 0, 0, 0x400E8334U |
#define | IOMUXC_GPIO_EMC_B2_15_SEMC_DATA30 0x400E80F4U, 0x0U, 0, 0, 0x400E8338U |
#define | IOMUXC_GPIO_EMC_B2_15_ENET_1G_RX_DATA00 0x400E80F4U, 0x2U, 0x400E84D0U, 0x0U, 0x400E8338U |
#define | IOMUXC_GPIO_EMC_B2_15_SAI3_TX_BCLK 0x400E80F4U, 0x3U, 0, 0, 0x400E8338U |
#define | IOMUXC_GPIO_EMC_B2_15_FLEXSPI2_A_DATA02 0x400E80F4U, 0x4U, 0x400E8584U, 0x0U, 0x400E8338U |
#define | IOMUXC_GPIO_EMC_B2_15_GPIO_MUX2_IO25 0x400E80F4U, 0x5U, 0, 0, 0x400E8338U |
#define | IOMUXC_GPIO_EMC_B2_15_XBAR1_INOUT35 0x400E80F4U, 0x6U, 0x400E8714U, 0x0U, 0x400E8338U |
#define | IOMUXC_GPIO_EMC_B2_15_EMVSIM1_PD 0x400E80F4U, 0x8U, 0x400E86A0U, 0x0U, 0x400E8338U |
#define | IOMUXC_GPIO_EMC_B2_15_TMR2_TIMER2 0x400E80F4U, 0x9U, 0x400E8650U, 0x0U, 0x400E8338U |
#define | IOMUXC_GPIO_EMC_B2_15_GPIO8_IO25 0x400E80F4U, 0xAU, 0, 0, 0x400E8338U |
#define | IOMUXC_GPIO_EMC_B2_16_GPIO8_IO26 0x400E80F8U, 0xAU, 0, 0, 0x400E833CU |
#define | IOMUXC_GPIO_EMC_B2_16_SEMC_DATA31 0x400E80F8U, 0x0U, 0, 0, 0x400E833CU |
#define | IOMUXC_GPIO_EMC_B2_16_XBAR1_INOUT14 0x400E80F8U, 0x1U, 0, 0, 0x400E833CU |
#define | IOMUXC_GPIO_EMC_B2_16_ENET_1G_RX_DATA01 0x400E80F8U, 0x2U, 0x400E84D4U, 0x0U, 0x400E833CU |
#define | IOMUXC_GPIO_EMC_B2_16_SAI3_TX_SYNC 0x400E80F8U, 0x3U, 0, 0, 0x400E833CU |
#define | IOMUXC_GPIO_EMC_B2_16_FLEXSPI2_A_DATA03 0x400E80F8U, 0x4U, 0x400E8588U, 0x0U, 0x400E833CU |
#define | IOMUXC_GPIO_EMC_B2_16_GPIO_MUX2_IO26 0x400E80F8U, 0x5U, 0, 0, 0x400E833CU |
#define | IOMUXC_GPIO_EMC_B2_16_EMVSIM1_POWER_FAIL 0x400E80F8U, 0x8U, 0x400E86A4U, 0x0U, 0x400E833CU |
#define | IOMUXC_GPIO_EMC_B2_16_TMR2_TIMER3 0x400E80F8U, 0x9U, 0, 0, 0x400E833CU |
#define | IOMUXC_GPIO_EMC_B2_17_SEMC_DM03 0x400E80FCU, 0x0U, 0, 0, 0x400E8340U |
#define | IOMUXC_GPIO_EMC_B2_17_XBAR1_INOUT15 0x400E80FCU, 0x1U, 0, 0, 0x400E8340U |
#define | IOMUXC_GPIO_EMC_B2_17_ENET_1G_RX_EN 0x400E80FCU, 0x2U, 0x400E84E0U, 0x0U, 0x400E8340U |
#define | IOMUXC_GPIO_EMC_B2_17_SAI3_MCLK 0x400E80FCU, 0x3U, 0, 0, 0x400E8340U |
#define | IOMUXC_GPIO_EMC_B2_17_FLEXSPI2_A_DATA04 0x400E80FCU, 0x4U, 0, 0, 0x400E8340U |
#define | IOMUXC_GPIO_EMC_B2_17_GPIO_MUX2_IO27 0x400E80FCU, 0x5U, 0, 0, 0x400E8340U |
#define | IOMUXC_GPIO_EMC_B2_17_WDOG1_ANY 0x400E80FCU, 0x8U, 0, 0, 0x400E8340U |
#define | IOMUXC_GPIO_EMC_B2_17_TMR3_TIMER0 0x400E80FCU, 0x9U, 0x400E8654U, 0x1U, 0x400E8340U |
#define | IOMUXC_GPIO_EMC_B2_17_GPIO8_IO27 0x400E80FCU, 0xAU, 0, 0, 0x400E8340U |
#define | IOMUXC_GPIO_EMC_B2_18_SEMC_DQS4 0x400E8100U, 0x0U, 0, 0, 0x400E8344U |
#define | IOMUXC_GPIO_EMC_B2_18_XBAR1_INOUT16 0x400E8100U, 0x1U, 0, 0, 0x400E8344U |
#define | IOMUXC_GPIO_EMC_B2_18_ENET_1G_RX_ER 0x400E8100U, 0x2U, 0x400E84E4U, 0x0U, 0x400E8344U |
#define | IOMUXC_GPIO_EMC_B2_18_EWM_OUT_B 0x400E8100U, 0x3U, 0, 0, 0x400E8344U |
#define | IOMUXC_GPIO_EMC_B2_18_FLEXSPI2_A_DATA05 0x400E8100U, 0x4U, 0, 0, 0x400E8344U |
#define | IOMUXC_GPIO_EMC_B2_18_GPIO_MUX2_IO28 0x400E8100U, 0x5U, 0, 0, 0x400E8344U |
#define | IOMUXC_GPIO_EMC_B2_18_FLEXSPI1_A_DQS 0x400E8100U, 0x6U, 0x400E8550U, 0x0U, 0x400E8344U |
#define | IOMUXC_GPIO_EMC_B2_18_WDOG1_B 0x400E8100U, 0x8U, 0, 0, 0x400E8344U |
#define | IOMUXC_GPIO_EMC_B2_18_TMR3_TIMER1 0x400E8100U, 0x9U, 0x400E8658U, 0x1U, 0x400E8344U |
#define | IOMUXC_GPIO_EMC_B2_18_GPIO8_IO28 0x400E8100U, 0xAU, 0, 0, 0x400E8344U |
#define | IOMUXC_GPIO_EMC_B2_19_GPIO8_IO29 0x400E8104U, 0xAU, 0, 0, 0x400E8348U |
#define | IOMUXC_GPIO_EMC_B2_19_SEMC_CLKX00 0x400E8104U, 0x0U, 0, 0, 0x400E8348U |
#define | IOMUXC_GPIO_EMC_B2_19_ENET_MDC 0x400E8104U, 0x1U, 0, 0, 0x400E8348U |
#define | IOMUXC_GPIO_EMC_B2_19_ENET_1G_MDC 0x400E8104U, 0x2U, 0, 0, 0x400E8348U |
#define | IOMUXC_GPIO_EMC_B2_19_ENET_1G_REF_CLK 0x400E8104U, 0x3U, 0x400E84C4U, 0x0U, 0x400E8348U |
#define | IOMUXC_GPIO_EMC_B2_19_FLEXSPI2_A_DATA06 0x400E8104U, 0x4U, 0, 0, 0x400E8348U |
#define | IOMUXC_GPIO_EMC_B2_19_GPIO_MUX2_IO29 0x400E8104U, 0x5U, 0, 0, 0x400E8348U |
#define | IOMUXC_GPIO_EMC_B2_19_ENET_QOS_MDC 0x400E8104U, 0x8U, 0, 0, 0x400E8348U |
#define | IOMUXC_GPIO_EMC_B2_19_TMR3_TIMER2 0x400E8104U, 0x9U, 0x400E865CU, 0x0U, 0x400E8348U |
#define | IOMUXC_GPIO_EMC_B2_20_GPIO8_IO30 0x400E8108U, 0xAU, 0, 0, 0x400E834CU |
#define | IOMUXC_GPIO_EMC_B2_20_SEMC_CLKX01 0x400E8108U, 0x0U, 0, 0, 0x400E834CU |
#define | IOMUXC_GPIO_EMC_B2_20_ENET_MDIO 0x400E8108U, 0x1U, 0x400E84ACU, 0x0U, 0x400E834CU |
#define | IOMUXC_GPIO_EMC_B2_20_ENET_1G_MDIO 0x400E8108U, 0x2U, 0x400E84C8U, 0x1U, 0x400E834CU |
#define | IOMUXC_GPIO_EMC_B2_20_ENET_QOS_REF_CLK 0x400E8108U, 0x3U, 0x400E84A0U, 0x0U, 0x400E834CU |
#define | IOMUXC_GPIO_EMC_B2_20_FLEXSPI2_A_DATA07 0x400E8108U, 0x4U, 0, 0, 0x400E834CU |
#define | IOMUXC_GPIO_EMC_B2_20_GPIO_MUX2_IO30 0x400E8108U, 0x5U, 0, 0, 0x400E834CU |
#define | IOMUXC_GPIO_EMC_B2_20_ENET_QOS_MDIO 0x400E8108U, 0x8U, 0x400E84ECU, 0x0U, 0x400E834CU |
#define | IOMUXC_GPIO_EMC_B2_20_TMR3_TIMER3 0x400E8108U, 0x9U, 0, 0, 0x400E834CU |
#define | IOMUXC_GPIO_AD_00_GPIO8_IO31 0x400E810CU, 0xAU, 0, 0, 0x400E8350U |
#define | IOMUXC_GPIO_AD_00_EMVSIM1_IO 0x400E810CU, 0x0U, 0x400E869CU, 0x1U, 0x400E8350U |
#define | IOMUXC_GPIO_AD_00_FLEXCAN2_TX 0x400E810CU, 0x1U, 0, 0, 0x400E8350U |
#define | IOMUXC_GPIO_AD_00_ENET_1G_1588_EVENT1_IN 0x400E810CU, 0x2U, 0, 0, 0x400E8350U |
#define | IOMUXC_GPIO_AD_00_GPT2_CAPTURE1 0x400E810CU, 0x3U, 0, 0, 0x400E8350U |
#define | IOMUXC_GPIO_AD_00_FLEXPWM1_PWM0_A 0x400E810CU, 0x4U, 0x400E8500U, 0x1U, 0x400E8350U |
#define | IOMUXC_GPIO_AD_00_GPIO_MUX2_IO31 0x400E810CU, 0x5U, 0, 0, 0x400E8350U |
#define | IOMUXC_GPIO_AD_00_LPUART7_TXD 0x400E810CU, 0x6U, 0x400E8630U, 0x0U, 0x400E8350U |
#define | IOMUXC_GPIO_AD_00_FLEXIO2_D00 0x400E810CU, 0x8U, 0, 0, 0x400E8350U |
#define | IOMUXC_GPIO_AD_00_FLEXSPI2_B_SS1_B 0x400E810CU, 0x9U, 0, 0, 0x400E8350U |
#define | IOMUXC_GPIO_AD_01_GPIO9_IO00 0x400E8110U, 0xAU, 0, 0, 0x400E8354U |
#define | IOMUXC_GPIO_AD_01_EMVSIM1_CLK 0x400E8110U, 0x0U, 0, 0, 0x400E8354U |
#define | IOMUXC_GPIO_AD_01_FLEXCAN2_RX 0x400E8110U, 0x1U, 0x400E849CU, 0x0U, 0x400E8354U |
#define | IOMUXC_GPIO_AD_01_ENET_1G_1588_EVENT1_OUT 0x400E8110U, 0x2U, 0, 0, 0x400E8354U |
#define | IOMUXC_GPIO_AD_01_GPT2_CAPTURE2 0x400E8110U, 0x3U, 0, 0, 0x400E8354U |
#define | IOMUXC_GPIO_AD_01_FLEXPWM1_PWM0_B 0x400E8110U, 0x4U, 0x400E850CU, 0x1U, 0x400E8354U |
#define | IOMUXC_GPIO_AD_01_GPIO_MUX3_IO00 0x400E8110U, 0x5U, 0, 0, 0x400E8354U |
#define | IOMUXC_GPIO_AD_01_LPUART7_RXD 0x400E8110U, 0x6U, 0x400E862CU, 0x0U, 0x400E8354U |
#define | IOMUXC_GPIO_AD_01_FLEXIO2_D01 0x400E8110U, 0x8U, 0, 0, 0x400E8354U |
#define | IOMUXC_GPIO_AD_01_FLEXSPI2_A_SS1_B 0x400E8110U, 0x9U, 0, 0, 0x400E8354U |
#define | IOMUXC_GPIO_AD_02_GPIO9_IO01 0x400E8114U, 0xAU, 0, 0, 0x400E8358U |
#define | IOMUXC_GPIO_AD_02_EMVSIM1_RST 0x400E8114U, 0x0U, 0, 0, 0x400E8358U |
#define | IOMUXC_GPIO_AD_02_LPUART7_CTS_B 0x400E8114U, 0x1U, 0, 0, 0x400E8358U |
#define | IOMUXC_GPIO_AD_02_ENET_1G_1588_EVENT2_IN 0x400E8114U, 0x2U, 0, 0, 0x400E8358U |
#define | IOMUXC_GPIO_AD_02_GPT2_COMPARE1 0x400E8114U, 0x3U, 0, 0, 0x400E8358U |
#define | IOMUXC_GPIO_AD_02_FLEXPWM1_PWM1_A 0x400E8114U, 0x4U, 0x400E8504U, 0x1U, 0x400E8358U |
#define | IOMUXC_GPIO_AD_02_GPIO_MUX3_IO01 0x400E8114U, 0x5U, 0, 0, 0x400E8358U |
#define | IOMUXC_GPIO_AD_02_LPUART8_TXD 0x400E8114U, 0x6U, 0x400E8638U, 0x0U, 0x400E8358U |
#define | IOMUXC_GPIO_AD_02_FLEXIO2_D02 0x400E8114U, 0x8U, 0, 0, 0x400E8358U |
#define | IOMUXC_GPIO_AD_02_VIDEO_MUX_EXT_DCIC1 0x400E8114U, 0x9U, 0, 0, 0x400E8358U |
#define | IOMUXC_GPIO_AD_03_GPIO9_IO02 0x400E8118U, 0xAU, 0, 0, 0x400E835CU |
#define | IOMUXC_GPIO_AD_03_EMVSIM1_SVEN 0x400E8118U, 0x0U, 0, 0, 0x400E835CU |
#define | IOMUXC_GPIO_AD_03_LPUART7_RTS_B 0x400E8118U, 0x1U, 0, 0, 0x400E835CU |
#define | IOMUXC_GPIO_AD_03_ENET_1G_1588_EVENT2_OUT 0x400E8118U, 0x2U, 0, 0, 0x400E835CU |
#define | IOMUXC_GPIO_AD_03_GPT2_COMPARE2 0x400E8118U, 0x3U, 0, 0, 0x400E835CU |
#define | IOMUXC_GPIO_AD_03_FLEXPWM1_PWM1_B 0x400E8118U, 0x4U, 0x400E8510U, 0x1U, 0x400E835CU |
#define | IOMUXC_GPIO_AD_03_GPIO_MUX3_IO02 0x400E8118U, 0x5U, 0, 0, 0x400E835CU |
#define | IOMUXC_GPIO_AD_03_LPUART8_RXD 0x400E8118U, 0x6U, 0x400E8634U, 0x0U, 0x400E835CU |
#define | IOMUXC_GPIO_AD_03_FLEXIO2_D03 0x400E8118U, 0x8U, 0, 0, 0x400E835CU |
#define | IOMUXC_GPIO_AD_03_VIDEO_MUX_EXT_DCIC2 0x400E8118U, 0x9U, 0, 0, 0x400E835CU |
#define | IOMUXC_GPIO_AD_04_EMVSIM1_PD 0x400E811CU, 0x0U, 0x400E86A0U, 0x1U, 0x400E8360U |
#define | IOMUXC_GPIO_AD_04_LPUART8_CTS_B 0x400E811CU, 0x1U, 0, 0, 0x400E8360U |
#define | IOMUXC_GPIO_AD_04_ENET_1G_1588_EVENT3_IN 0x400E811CU, 0x2U, 0, 0, 0x400E8360U |
#define | IOMUXC_GPIO_AD_04_GPT2_COMPARE3 0x400E811CU, 0x3U, 0, 0, 0x400E8360U |
#define | IOMUXC_GPIO_AD_04_FLEXPWM1_PWM2_A 0x400E811CU, 0x4U, 0x400E8508U, 0x1U, 0x400E8360U |
#define | IOMUXC_GPIO_AD_04_GPIO_MUX3_IO03 0x400E811CU, 0x5U, 0, 0, 0x400E8360U |
#define | IOMUXC_GPIO_AD_04_WDOG1_B 0x400E811CU, 0x6U, 0, 0, 0x400E8360U |
#define | IOMUXC_GPIO_AD_04_FLEXIO2_D04 0x400E811CU, 0x8U, 0, 0, 0x400E8360U |
#define | IOMUXC_GPIO_AD_04_TMR4_TIMER0 0x400E811CU, 0x9U, 0x400E8660U, 0x1U, 0x400E8360U |
#define | IOMUXC_GPIO_AD_04_GPIO9_IO03 0x400E811CU, 0xAU, 0, 0, 0x400E8360U |
#define | IOMUXC_GPIO_AD_05_EMVSIM1_POWER_FAIL 0x400E8120U, 0x0U, 0x400E86A4U, 0x1U, 0x400E8364U |
#define | IOMUXC_GPIO_AD_05_LPUART8_RTS_B 0x400E8120U, 0x1U, 0, 0, 0x400E8364U |
#define | IOMUXC_GPIO_AD_05_ENET_1G_1588_EVENT3_OUT 0x400E8120U, 0x2U, 0, 0, 0x400E8364U |
#define | IOMUXC_GPIO_AD_05_GPT2_CLK 0x400E8120U, 0x3U, 0, 0, 0x400E8364U |
#define | IOMUXC_GPIO_AD_05_FLEXPWM1_PWM2_B 0x400E8120U, 0x4U, 0x400E8514U, 0x1U, 0x400E8364U |
#define | IOMUXC_GPIO_AD_05_GPIO_MUX3_IO04 0x400E8120U, 0x5U, 0, 0, 0x400E8364U |
#define | IOMUXC_GPIO_AD_05_WDOG2_B 0x400E8120U, 0x6U, 0, 0, 0x400E8364U |
#define | IOMUXC_GPIO_AD_05_FLEXIO2_D05 0x400E8120U, 0x8U, 0, 0, 0x400E8364U |
#define | IOMUXC_GPIO_AD_05_TMR4_TIMER1 0x400E8120U, 0x9U, 0x400E8664U, 0x1U, 0x400E8364U |
#define | IOMUXC_GPIO_AD_05_GPIO9_IO04 0x400E8120U, 0xAU, 0, 0, 0x400E8364U |
#define | IOMUXC_GPIO_AD_06_USB_OTG2_OC 0x400E8124U, 0x0U, 0x400E86B8U, 0x0U, 0x400E8368U |
#define | IOMUXC_GPIO_AD_06_FLEXCAN1_TX 0x400E8124U, 0x1U, 0, 0, 0x400E8368U |
#define | IOMUXC_GPIO_AD_06_EMVSIM2_IO 0x400E8124U, 0x2U, 0x400E86A8U, 0x0U, 0x400E8368U |
#define | IOMUXC_GPIO_AD_06_GPT3_CAPTURE1 0x400E8124U, 0x3U, 0x400E8590U, 0x1U, 0x400E8368U |
#define | IOMUXC_GPIO_AD_06_VIDEO_MUX_CSI_DATA15 0x400E8124U, 0x4U, 0, 0, 0x400E8368U |
#define | IOMUXC_GPIO_AD_06_GPIO_MUX3_IO05 0x400E8124U, 0x5U, 0, 0, 0x400E8368U |
#define | IOMUXC_GPIO_AD_06_ENET_1588_EVENT1_IN 0x400E8124U, 0x6U, 0, 0, 0x400E8368U |
#define | IOMUXC_GPIO_AD_06_FLEXIO2_D06 0x400E8124U, 0x8U, 0, 0, 0x400E8368U |
#define | IOMUXC_GPIO_AD_06_TMR4_TIMER2 0x400E8124U, 0x9U, 0x400E8668U, 0x0U, 0x400E8368U |
#define | IOMUXC_GPIO_AD_06_GPIO9_IO05 0x400E8124U, 0xAU, 0, 0, 0x400E8368U |
#define | IOMUXC_GPIO_AD_06_FLEXPWM1_PWM0_X 0x400E8124U, 0xBU, 0, 0, 0x400E8368U |
#define | IOMUXC_GPIO_AD_07_USB_OTG2_PWR 0x400E8128U, 0x0U, 0, 0, 0x400E836CU |
#define | IOMUXC_GPIO_AD_07_FLEXCAN1_RX 0x400E8128U, 0x1U, 0x400E8498U, 0x0U, 0x400E836CU |
#define | IOMUXC_GPIO_AD_07_EMVSIM2_CLK 0x400E8128U, 0x2U, 0, 0, 0x400E836CU |
#define | IOMUXC_GPIO_AD_07_GPT3_CAPTURE2 0x400E8128U, 0x3U, 0x400E8594U, 0x1U, 0x400E836CU |
#define | IOMUXC_GPIO_AD_07_VIDEO_MUX_CSI_DATA14 0x400E8128U, 0x4U, 0, 0, 0x400E836CU |
#define | IOMUXC_GPIO_AD_07_GPIO_MUX3_IO06 0x400E8128U, 0x5U, 0, 0, 0x400E836CU |
#define | IOMUXC_GPIO_AD_07_ENET_1588_EVENT1_OUT 0x400E8128U, 0x6U, 0, 0, 0x400E836CU |
#define | IOMUXC_GPIO_AD_07_FLEXIO2_D07 0x400E8128U, 0x8U, 0, 0, 0x400E836CU |
#define | IOMUXC_GPIO_AD_07_TMR4_TIMER3 0x400E8128U, 0x9U, 0, 0, 0x400E836CU |
#define | IOMUXC_GPIO_AD_07_GPIO9_IO06 0x400E8128U, 0xAU, 0, 0, 0x400E836CU |
#define | IOMUXC_GPIO_AD_07_FLEXPWM1_PWM1_X 0x400E8128U, 0xBU, 0, 0, 0x400E836CU |
#define | IOMUXC_GPIO_AD_08_USBPHY2_OTG_ID 0x400E812CU, 0x0U, 0x400E86C4U, 0x0U, 0x400E8370U |
#define | IOMUXC_GPIO_AD_08_LPI2C1_SCL 0x400E812CU, 0x1U, 0x400E85ACU, 0x0U, 0x400E8370U |
#define | IOMUXC_GPIO_AD_08_EMVSIM2_RST 0x400E812CU, 0x2U, 0, 0, 0x400E8370U |
#define | IOMUXC_GPIO_AD_08_GPT3_COMPARE1 0x400E812CU, 0x3U, 0, 0, 0x400E8370U |
#define | IOMUXC_GPIO_AD_08_VIDEO_MUX_CSI_DATA13 0x400E812CU, 0x4U, 0, 0, 0x400E8370U |
#define | IOMUXC_GPIO_AD_08_GPIO_MUX3_IO07 0x400E812CU, 0x5U, 0, 0, 0x400E8370U |
#define | IOMUXC_GPIO_AD_08_ENET_1588_EVENT2_IN 0x400E812CU, 0x6U, 0, 0, 0x400E8370U |
#define | IOMUXC_GPIO_AD_08_FLEXIO2_D08 0x400E812CU, 0x8U, 0, 0, 0x400E8370U |
#define | IOMUXC_GPIO_AD_08_GPIO9_IO07 0x400E812CU, 0xAU, 0, 0, 0x400E8370U |
#define | IOMUXC_GPIO_AD_08_FLEXPWM1_PWM2_X 0x400E812CU, 0xBU, 0, 0, 0x400E8370U |
#define | IOMUXC_GPIO_AD_09_USBPHY1_OTG_ID 0x400E8130U, 0x0U, 0x400E86C0U, 0x0U, 0x400E8374U |
#define | IOMUXC_GPIO_AD_09_LPI2C1_SDA 0x400E8130U, 0x1U, 0x400E85B0U, 0x0U, 0x400E8374U |
#define | IOMUXC_GPIO_AD_09_EMVSIM2_SVEN 0x400E8130U, 0x2U, 0, 0, 0x400E8374U |
#define | IOMUXC_GPIO_AD_09_GPT3_COMPARE2 0x400E8130U, 0x3U, 0, 0, 0x400E8374U |
#define | IOMUXC_GPIO_AD_09_VIDEO_MUX_CSI_DATA12 0x400E8130U, 0x4U, 0, 0, 0x400E8374U |
#define | IOMUXC_GPIO_AD_09_GPIO_MUX3_IO08 0x400E8130U, 0x5U, 0, 0, 0x400E8374U |
#define | IOMUXC_GPIO_AD_09_ENET_1588_EVENT2_OUT 0x400E8130U, 0x6U, 0, 0, 0x400E8374U |
#define | IOMUXC_GPIO_AD_09_FLEXIO2_D09 0x400E8130U, 0x8U, 0, 0, 0x400E8374U |
#define | IOMUXC_GPIO_AD_09_GPIO9_IO08 0x400E8130U, 0xAU, 0, 0, 0x400E8374U |
#define | IOMUXC_GPIO_AD_09_FLEXPWM1_PWM3_X 0x400E8130U, 0xBU, 0, 0, 0x400E8374U |
#define | IOMUXC_GPIO_AD_10_USB_OTG1_PWR 0x400E8134U, 0x0U, 0, 0, 0x400E8378U |
#define | IOMUXC_GPIO_AD_10_LPI2C1_SCLS 0x400E8134U, 0x1U, 0, 0, 0x400E8378U |
#define | IOMUXC_GPIO_AD_10_EMVSIM2_PD 0x400E8134U, 0x2U, 0x400E86ACU, 0x0U, 0x400E8378U |
#define | IOMUXC_GPIO_AD_10_GPT3_COMPARE3 0x400E8134U, 0x3U, 0, 0, 0x400E8378U |
#define | IOMUXC_GPIO_AD_10_VIDEO_MUX_CSI_DATA11 0x400E8134U, 0x4U, 0, 0, 0x400E8378U |
#define | IOMUXC_GPIO_AD_10_GPIO_MUX3_IO09 0x400E8134U, 0x5U, 0, 0, 0x400E8378U |
#define | IOMUXC_GPIO_AD_10_ENET_1588_EVENT3_IN 0x400E8134U, 0x6U, 0, 0, 0x400E8378U |
#define | IOMUXC_GPIO_AD_10_FLEXIO2_D10 0x400E8134U, 0x8U, 0, 0, 0x400E8378U |
#define | IOMUXC_GPIO_AD_10_GPIO9_IO09 0x400E8134U, 0xAU, 0, 0, 0x400E8378U |
#define | IOMUXC_GPIO_AD_10_FLEXPWM2_PWM0_X 0x400E8134U, 0xBU, 0, 0, 0x400E8378U |
#define | IOMUXC_GPIO_AD_11_USB_OTG1_OC 0x400E8138U, 0x0U, 0x400E86BCU, 0x0U, 0x400E837CU |
#define | IOMUXC_GPIO_AD_11_LPI2C1_SDAS 0x400E8138U, 0x1U, 0, 0, 0x400E837CU |
#define | IOMUXC_GPIO_AD_11_EMVSIM2_POWER_FAIL 0x400E8138U, 0x2U, 0x400E86B0U, 0x0U, 0x400E837CU |
#define | IOMUXC_GPIO_AD_11_GPT3_CLK 0x400E8138U, 0x3U, 0x400E8598U, 0x1U, 0x400E837CU |
#define | IOMUXC_GPIO_AD_11_VIDEO_MUX_CSI_DATA10 0x400E8138U, 0x4U, 0, 0, 0x400E837CU |
#define | IOMUXC_GPIO_AD_11_GPIO_MUX3_IO10 0x400E8138U, 0x5U, 0, 0, 0x400E837CU |
#define | IOMUXC_GPIO_AD_11_ENET_1588_EVENT3_OUT 0x400E8138U, 0x6U, 0, 0, 0x400E837CU |
#define | IOMUXC_GPIO_AD_11_FLEXIO2_D11 0x400E8138U, 0x8U, 0, 0, 0x400E837CU |
#define | IOMUXC_GPIO_AD_11_GPIO9_IO10 0x400E8138U, 0xAU, 0, 0, 0x400E837CU |
#define | IOMUXC_GPIO_AD_11_FLEXPWM2_PWM1_X 0x400E8138U, 0xBU, 0, 0, 0x400E837CU |
#define | IOMUXC_GPIO_AD_12_SPDIF_LOCK 0x400E813CU, 0x0U, 0, 0, 0x400E8380U |
#define | IOMUXC_GPIO_AD_12_LPI2C1_HREQ 0x400E813CU, 0x1U, 0, 0, 0x400E8380U |
#define | IOMUXC_GPIO_AD_12_GPT1_CAPTURE1 0x400E813CU, 0x2U, 0, 0, 0x400E8380U |
#define | IOMUXC_GPIO_AD_12_FLEXSPI1_B_DATA03 0x400E813CU, 0x3U, 0x400E8570U, 0x0U, 0x400E8380U |
#define | IOMUXC_GPIO_AD_12_VIDEO_MUX_CSI_PIXCLK 0x400E813CU, 0x4U, 0, 0, 0x400E8380U |
#define | IOMUXC_GPIO_AD_12_GPIO_MUX3_IO11 0x400E813CU, 0x5U, 0, 0, 0x400E8380U |
#define | IOMUXC_GPIO_AD_12_ENET_TX_DATA03 0x400E813CU, 0x6U, 0, 0, 0x400E8380U |
#define | IOMUXC_GPIO_AD_12_FLEXIO2_D12 0x400E813CU, 0x8U, 0, 0, 0x400E8380U |
#define | IOMUXC_GPIO_AD_12_EWM_OUT_B 0x400E813CU, 0x9U, 0, 0, 0x400E8380U |
#define | IOMUXC_GPIO_AD_12_GPIO9_IO11 0x400E813CU, 0xAU, 0, 0, 0x400E8380U |
#define | IOMUXC_GPIO_AD_12_FLEXPWM2_PWM2_X 0x400E813CU, 0xBU, 0, 0, 0x400E8380U |
#define | IOMUXC_GPIO_AD_13_SPDIF_SR_CLK 0x400E8140U, 0x0U, 0, 0, 0x400E8384U |
#define | IOMUXC_GPIO_AD_13_PIT1_TRIGGER0 0x400E8140U, 0x1U, 0, 0, 0x400E8384U |
#define | IOMUXC_GPIO_AD_13_GPT1_CAPTURE2 0x400E8140U, 0x2U, 0, 0, 0x400E8384U |
#define | IOMUXC_GPIO_AD_13_FLEXSPI1_B_DATA02 0x400E8140U, 0x3U, 0x400E856CU, 0x0U, 0x400E8384U |
#define | IOMUXC_GPIO_AD_13_VIDEO_MUX_CSI_MCLK 0x400E8140U, 0x4U, 0, 0, 0x400E8384U |
#define | IOMUXC_GPIO_AD_13_GPIO_MUX3_IO12 0x400E8140U, 0x5U, 0, 0, 0x400E8384U |
#define | IOMUXC_GPIO_AD_13_ENET_TX_DATA02 0x400E8140U, 0x6U, 0, 0, 0x400E8384U |
#define | IOMUXC_GPIO_AD_13_FLEXIO2_D13 0x400E8140U, 0x8U, 0, 0, 0x400E8384U |
#define | IOMUXC_GPIO_AD_13_REF_CLK_32K 0x400E8140U, 0x9U, 0, 0, 0x400E8384U |
#define | IOMUXC_GPIO_AD_13_GPIO9_IO12 0x400E8140U, 0xAU, 0, 0, 0x400E8384U |
#define | IOMUXC_GPIO_AD_13_FLEXPWM2_PWM3_X 0x400E8140U, 0xBU, 0, 0, 0x400E8384U |
#define | IOMUXC_GPIO_AD_14_SPDIF_EXT_CLK 0x400E8144U, 0x0U, 0, 0, 0x400E8388U |
#define | IOMUXC_GPIO_AD_14_REF_CLK_24M 0x400E8144U, 0x1U, 0, 0, 0x400E8388U |
#define | IOMUXC_GPIO_AD_14_GPT1_COMPARE1 0x400E8144U, 0x2U, 0, 0, 0x400E8388U |
#define | IOMUXC_GPIO_AD_14_FLEXSPI1_B_DATA01 0x400E8144U, 0x3U, 0x400E8568U, 0x0U, 0x400E8388U |
#define | IOMUXC_GPIO_AD_14_VIDEO_MUX_CSI_VSYNC 0x400E8144U, 0x4U, 0, 0, 0x400E8388U |
#define | IOMUXC_GPIO_AD_14_GPIO_MUX3_IO13 0x400E8144U, 0x5U, 0, 0, 0x400E8388U |
#define | IOMUXC_GPIO_AD_14_ENET_RX_CLK 0x400E8144U, 0x6U, 0, 0, 0x400E8388U |
#define | IOMUXC_GPIO_AD_14_FLEXIO2_D14 0x400E8144U, 0x8U, 0, 0, 0x400E8388U |
#define | IOMUXC_GPIO_AD_14_CCM_ENET_REF_CLK_25M 0x400E8144U, 0x9U, 0, 0, 0x400E8388U |
#define | IOMUXC_GPIO_AD_14_GPIO9_IO13 0x400E8144U, 0xAU, 0, 0, 0x400E8388U |
#define | IOMUXC_GPIO_AD_14_FLEXPWM3_PWM0_X 0x400E8144U, 0xBU, 0, 0, 0x400E8388U |
#define | IOMUXC_GPIO_AD_15_GPIO9_IO14 0x400E8148U, 0xAU, 0, 0, 0x400E838CU |
#define | IOMUXC_GPIO_AD_15_FLEXPWM3_PWM1_X 0x400E8148U, 0xBU, 0, 0, 0x400E838CU |
#define | IOMUXC_GPIO_AD_15_SPDIF_IN 0x400E8148U, 0x0U, 0x400E86B4U, 0x1U, 0x400E838CU |
#define | IOMUXC_GPIO_AD_15_LPUART10_TXD 0x400E8148U, 0x1U, 0x400E8628U, 0x0U, 0x400E838CU |
#define | IOMUXC_GPIO_AD_15_GPT1_COMPARE2 0x400E8148U, 0x2U, 0, 0, 0x400E838CU |
#define | IOMUXC_GPIO_AD_15_FLEXSPI1_B_DATA00 0x400E8148U, 0x3U, 0x400E8564U, 0x0U, 0x400E838CU |
#define | IOMUXC_GPIO_AD_15_VIDEO_MUX_CSI_HSYNC 0x400E8148U, 0x4U, 0, 0, 0x400E838CU |
#define | IOMUXC_GPIO_AD_15_GPIO_MUX3_IO14 0x400E8148U, 0x5U, 0, 0, 0x400E838CU |
#define | IOMUXC_GPIO_AD_15_ENET_TX_ER 0x400E8148U, 0x6U, 0, 0, 0x400E838CU |
#define | IOMUXC_GPIO_AD_15_FLEXIO2_D15 0x400E8148U, 0x8U, 0, 0, 0x400E838CU |
#define | IOMUXC_GPIO_AD_16_SPDIF_OUT 0x400E814CU, 0x0U, 0, 0, 0x400E8390U |
#define | IOMUXC_GPIO_AD_16_LPUART10_RXD 0x400E814CU, 0x1U, 0x400E8624U, 0x0U, 0x400E8390U |
#define | IOMUXC_GPIO_AD_16_GPT1_COMPARE3 0x400E814CU, 0x2U, 0, 0, 0x400E8390U |
#define | IOMUXC_GPIO_AD_16_FLEXSPI1_B_SCLK 0x400E814CU, 0x3U, 0x400E8578U, 0x0U, 0x400E8390U |
#define | IOMUXC_GPIO_AD_16_VIDEO_MUX_CSI_DATA09 0x400E814CU, 0x4U, 0, 0, 0x400E8390U |
#define | IOMUXC_GPIO_AD_16_GPIO_MUX3_IO15 0x400E814CU, 0x5U, 0, 0, 0x400E8390U |
#define | IOMUXC_GPIO_AD_16_ENET_RX_DATA03 0x400E814CU, 0x6U, 0, 0, 0x400E8390U |
#define | IOMUXC_GPIO_AD_16_FLEXIO2_D16 0x400E814CU, 0x8U, 0, 0, 0x400E8390U |
#define | IOMUXC_GPIO_AD_16_ENET_1G_MDC 0x400E814CU, 0x9U, 0, 0, 0x400E8390U |
#define | IOMUXC_GPIO_AD_16_GPIO9_IO15 0x400E814CU, 0xAU, 0, 0, 0x400E8390U |
#define | IOMUXC_GPIO_AD_16_FLEXPWM3_PWM2_X 0x400E814CU, 0xBU, 0, 0, 0x400E8390U |
#define | IOMUXC_GPIO_AD_17_SAI1_MCLK 0x400E8150U, 0x0U, 0x400E866CU, 0x0U, 0x400E8394U |
#define | IOMUXC_GPIO_AD_17_ACMP1_OUT 0x400E8150U, 0x1U, 0, 0, 0x400E8394U |
#define | IOMUXC_GPIO_AD_17_GPT1_CLK 0x400E8150U, 0x2U, 0, 0, 0x400E8394U |
#define | IOMUXC_GPIO_AD_17_FLEXSPI1_A_DQS 0x400E8150U, 0x3U, 0x400E8550U, 0x1U, 0x400E8394U |
#define | IOMUXC_GPIO_AD_17_VIDEO_MUX_CSI_DATA08 0x400E8150U, 0x4U, 0, 0, 0x400E8394U |
#define | IOMUXC_GPIO_AD_17_GPIO_MUX3_IO16 0x400E8150U, 0x5U, 0, 0, 0x400E8394U |
#define | IOMUXC_GPIO_AD_17_ENET_RX_DATA02 0x400E8150U, 0x6U, 0, 0, 0x400E8394U |
#define | IOMUXC_GPIO_AD_17_FLEXIO2_D17 0x400E8150U, 0x8U, 0, 0, 0x400E8394U |
#define | IOMUXC_GPIO_AD_17_ENET_1G_MDIO 0x400E8150U, 0x9U, 0x400E84C8U, 0x2U, 0x400E8394U |
#define | IOMUXC_GPIO_AD_17_GPIO9_IO16 0x400E8150U, 0xAU, 0, 0, 0x400E8394U |
#define | IOMUXC_GPIO_AD_17_FLEXPWM3_PWM3_X 0x400E8150U, 0xBU, 0, 0, 0x400E8394U |
#define | IOMUXC_GPIO_AD_18_GPIO9_IO17 0x400E8154U, 0xAU, 0, 0, 0x400E8398U |
#define | IOMUXC_GPIO_AD_18_FLEXPWM4_PWM0_X 0x400E8154U, 0xBU, 0, 0, 0x400E8398U |
#define | IOMUXC_GPIO_AD_18_SAI1_RX_SYNC 0x400E8154U, 0x0U, 0x400E8678U, 0x0U, 0x400E8398U |
#define | IOMUXC_GPIO_AD_18_ACMP2_OUT 0x400E8154U, 0x1U, 0, 0, 0x400E8398U |
#define | IOMUXC_GPIO_AD_18_LPSPI1_PCS1 0x400E8154U, 0x2U, 0, 0, 0x400E8398U |
#define | IOMUXC_GPIO_AD_18_FLEXSPI1_A_SS0_B 0x400E8154U, 0x3U, 0, 0, 0x400E8398U |
#define | IOMUXC_GPIO_AD_18_VIDEO_MUX_CSI_DATA07 0x400E8154U, 0x4U, 0, 0, 0x400E8398U |
#define | IOMUXC_GPIO_AD_18_GPIO_MUX3_IO17 0x400E8154U, 0x5U, 0, 0, 0x400E8398U |
#define | IOMUXC_GPIO_AD_18_ENET_CRS 0x400E8154U, 0x6U, 0, 0, 0x400E8398U |
#define | IOMUXC_GPIO_AD_18_FLEXIO2_D18 0x400E8154U, 0x8U, 0, 0, 0x400E8398U |
#define | IOMUXC_GPIO_AD_18_LPI2C2_SCL 0x400E8154U, 0x9U, 0x400E85B4U, 0x1U, 0x400E8398U |
#define | IOMUXC_GPIO_AD_19_SAI1_RX_BCLK 0x400E8158U, 0x0U, 0x400E8670U, 0x0U, 0x400E839CU |
#define | IOMUXC_GPIO_AD_19_ACMP3_OUT 0x400E8158U, 0x1U, 0, 0, 0x400E839CU |
#define | IOMUXC_GPIO_AD_19_LPSPI1_PCS2 0x400E8158U, 0x2U, 0, 0, 0x400E839CU |
#define | IOMUXC_GPIO_AD_19_FLEXSPI1_A_SCLK 0x400E8158U, 0x3U, 0x400E8574U, 0x0U, 0x400E839CU |
#define | IOMUXC_GPIO_AD_19_VIDEO_MUX_CSI_DATA06 0x400E8158U, 0x4U, 0, 0, 0x400E839CU |
#define | IOMUXC_GPIO_AD_19_GPIO_MUX3_IO18 0x400E8158U, 0x5U, 0, 0, 0x400E839CU |
#define | IOMUXC_GPIO_AD_19_ENET_COL 0x400E8158U, 0x6U, 0, 0, 0x400E839CU |
#define | IOMUXC_GPIO_AD_19_FLEXIO2_D19 0x400E8158U, 0x8U, 0, 0, 0x400E839CU |
#define | IOMUXC_GPIO_AD_19_LPI2C2_SDA 0x400E8158U, 0x9U, 0x400E85B8U, 0x1U, 0x400E839CU |
#define | IOMUXC_GPIO_AD_19_GPIO9_IO18 0x400E8158U, 0xAU, 0, 0, 0x400E839CU |
#define | IOMUXC_GPIO_AD_19_FLEXPWM4_PWM1_X 0x400E8158U, 0xBU, 0, 0, 0x400E839CU |
#define | IOMUXC_GPIO_AD_20_SAI1_RX_DATA00 0x400E815CU, 0x0U, 0x400E8674U, 0x0U, 0x400E83A0U |
#define | IOMUXC_GPIO_AD_20_ACMP4_OUT 0x400E815CU, 0x1U, 0, 0, 0x400E83A0U |
#define | IOMUXC_GPIO_AD_20_LPSPI1_PCS3 0x400E815CU, 0x2U, 0, 0, 0x400E83A0U |
#define | IOMUXC_GPIO_AD_20_FLEXSPI1_A_DATA00 0x400E815CU, 0x3U, 0x400E8554U, 0x0U, 0x400E83A0U |
#define | IOMUXC_GPIO_AD_20_VIDEO_MUX_CSI_DATA05 0x400E815CU, 0x4U, 0, 0, 0x400E83A0U |
#define | IOMUXC_GPIO_AD_20_GPIO_MUX3_IO19 0x400E815CU, 0x5U, 0, 0, 0x400E83A0U |
#define | IOMUXC_GPIO_AD_20_KPP_ROW07 0x400E815CU, 0x6U, 0x400E85A8U, 0x0U, 0x400E83A0U |
#define | IOMUXC_GPIO_AD_20_FLEXIO2_D20 0x400E815CU, 0x8U, 0, 0, 0x400E83A0U |
#define | IOMUXC_GPIO_AD_20_ENET_QOS_1588_EVENT2_OUT 0x400E815CU, 0x9U, 0, 0, 0x400E83A0U |
#define | IOMUXC_GPIO_AD_20_GPIO9_IO19 0x400E815CU, 0xAU, 0, 0, 0x400E83A0U |
#define | IOMUXC_GPIO_AD_20_FLEXPWM4_PWM2_X 0x400E815CU, 0xBU, 0, 0, 0x400E83A0U |
#define | IOMUXC_GPIO_AD_21_SAI1_TX_DATA00 0x400E8160U, 0x0U, 0, 0, 0x400E83A4U |
#define | IOMUXC_GPIO_AD_21_LPSPI2_PCS1 0x400E8160U, 0x2U, 0x400E85E0U, 0x0U, 0x400E83A4U |
#define | IOMUXC_GPIO_AD_21_FLEXSPI1_A_DATA01 0x400E8160U, 0x3U, 0x400E8558U, 0x0U, 0x400E83A4U |
#define | IOMUXC_GPIO_AD_21_VIDEO_MUX_CSI_DATA04 0x400E8160U, 0x4U, 0, 0, 0x400E83A4U |
#define | IOMUXC_GPIO_AD_21_GPIO_MUX3_IO20 0x400E8160U, 0x5U, 0, 0, 0x400E83A4U |
#define | IOMUXC_GPIO_AD_21_KPP_COL07 0x400E8160U, 0x6U, 0x400E85A0U, 0x0U, 0x400E83A4U |
#define | IOMUXC_GPIO_AD_21_FLEXIO2_D21 0x400E8160U, 0x8U, 0, 0, 0x400E83A4U |
#define | IOMUXC_GPIO_AD_21_ENET_QOS_1588_EVENT2_IN 0x400E8160U, 0x9U, 0, 0, 0x400E83A4U |
#define | IOMUXC_GPIO_AD_21_GPIO9_IO20 0x400E8160U, 0xAU, 0, 0, 0x400E83A4U |
#define | IOMUXC_GPIO_AD_21_FLEXPWM4_PWM3_X 0x400E8160U, 0xBU, 0, 0, 0x400E83A4U |
#define | IOMUXC_GPIO_AD_22_GPIO9_IO21 0x400E8164U, 0xAU, 0, 0, 0x400E83A8U |
#define | IOMUXC_GPIO_AD_22_SAI1_TX_BCLK 0x400E8164U, 0x0U, 0x400E867CU, 0x0U, 0x400E83A8U |
#define | IOMUXC_GPIO_AD_22_LPSPI2_PCS2 0x400E8164U, 0x2U, 0, 0, 0x400E83A8U |
#define | IOMUXC_GPIO_AD_22_FLEXSPI1_A_DATA02 0x400E8164U, 0x3U, 0x400E855CU, 0x0U, 0x400E83A8U |
#define | IOMUXC_GPIO_AD_22_VIDEO_MUX_CSI_DATA03 0x400E8164U, 0x4U, 0, 0, 0x400E83A8U |
#define | IOMUXC_GPIO_AD_22_GPIO_MUX3_IO21 0x400E8164U, 0x5U, 0, 0, 0x400E83A8U |
#define | IOMUXC_GPIO_AD_22_KPP_ROW06 0x400E8164U, 0x6U, 0x400E85A4U, 0x0U, 0x400E83A8U |
#define | IOMUXC_GPIO_AD_22_FLEXIO2_D22 0x400E8164U, 0x8U, 0, 0, 0x400E83A8U |
#define | IOMUXC_GPIO_AD_22_ENET_QOS_1588_EVENT3_OUT 0x400E8164U, 0x9U, 0, 0, 0x400E83A8U |
#define | IOMUXC_GPIO_AD_23_SAI1_TX_SYNC 0x400E8168U, 0x0U, 0x400E8680U, 0x0U, 0x400E83ACU |
#define | IOMUXC_GPIO_AD_23_LPSPI2_PCS3 0x400E8168U, 0x2U, 0, 0, 0x400E83ACU |
#define | IOMUXC_GPIO_AD_23_FLEXSPI1_A_DATA03 0x400E8168U, 0x3U, 0x400E8560U, 0x0U, 0x400E83ACU |
#define | IOMUXC_GPIO_AD_23_VIDEO_MUX_CSI_DATA02 0x400E8168U, 0x4U, 0, 0, 0x400E83ACU |
#define | IOMUXC_GPIO_AD_23_GPIO_MUX3_IO22 0x400E8168U, 0x5U, 0, 0, 0x400E83ACU |
#define | IOMUXC_GPIO_AD_23_KPP_COL06 0x400E8168U, 0x6U, 0x400E859CU, 0x0U, 0x400E83ACU |
#define | IOMUXC_GPIO_AD_23_FLEXIO2_D23 0x400E8168U, 0x8U, 0, 0, 0x400E83ACU |
#define | IOMUXC_GPIO_AD_23_ENET_QOS_1588_EVENT3_IN 0x400E8168U, 0x9U, 0, 0, 0x400E83ACU |
#define | IOMUXC_GPIO_AD_23_GPIO9_IO22 0x400E8168U, 0xAU, 0, 0, 0x400E83ACU |
#define | IOMUXC_GPIO_AD_24_LPUART1_TXD 0x400E816CU, 0x0U, 0x400E8620U, 0x0U, 0x400E83B0U |
#define | IOMUXC_GPIO_AD_24_LPSPI2_SCK 0x400E816CU, 0x1U, 0x400E85E4U, 0x0U, 0x400E83B0U |
#define | IOMUXC_GPIO_AD_24_VIDEO_MUX_CSI_DATA00 0x400E816CU, 0x2U, 0, 0, 0x400E83B0U |
#define | IOMUXC_GPIO_AD_24_ENET_RX_EN 0x400E816CU, 0x3U, 0x400E84B8U, 0x0U, 0x400E83B0U |
#define | IOMUXC_GPIO_AD_24_FLEXPWM2_PWM0_A 0x400E816CU, 0x4U, 0x400E8518U, 0x1U, 0x400E83B0U |
#define | IOMUXC_GPIO_AD_24_GPIO_MUX3_IO23 0x400E816CU, 0x5U, 0, 0, 0x400E83B0U |
#define | IOMUXC_GPIO_AD_24_KPP_ROW05 0x400E816CU, 0x6U, 0, 0, 0x400E83B0U |
#define | IOMUXC_GPIO_AD_24_FLEXIO2_D24 0x400E816CU, 0x8U, 0, 0, 0x400E83B0U |
#define | IOMUXC_GPIO_AD_24_LPI2C4_SCL 0x400E816CU, 0x9U, 0x400E85C4U, 0x0U, 0x400E83B0U |
#define | IOMUXC_GPIO_AD_24_GPIO9_IO23 0x400E816CU, 0xAU, 0, 0, 0x400E83B0U |
#define | IOMUXC_GPIO_AD_25_GPIO9_IO24 0x400E8170U, 0xAU, 0, 0, 0x400E83B4U |
#define | IOMUXC_GPIO_AD_25_LPUART1_RXD 0x400E8170U, 0x0U, 0x400E861CU, 0x0U, 0x400E83B4U |
#define | IOMUXC_GPIO_AD_25_LPSPI2_PCS0 0x400E8170U, 0x1U, 0x400E85DCU, 0x0U, 0x400E83B4U |
#define | IOMUXC_GPIO_AD_25_VIDEO_MUX_CSI_DATA01 0x400E8170U, 0x2U, 0, 0, 0x400E83B4U |
#define | IOMUXC_GPIO_AD_25_ENET_RX_ER 0x400E8170U, 0x3U, 0x400E84BCU, 0x0U, 0x400E83B4U |
#define | IOMUXC_GPIO_AD_25_FLEXPWM2_PWM0_B 0x400E8170U, 0x4U, 0x400E8524U, 0x1U, 0x400E83B4U |
#define | IOMUXC_GPIO_AD_25_GPIO_MUX3_IO24 0x400E8170U, 0x5U, 0, 0, 0x400E83B4U |
#define | IOMUXC_GPIO_AD_25_KPP_COL05 0x400E8170U, 0x6U, 0, 0, 0x400E83B4U |
#define | IOMUXC_GPIO_AD_25_FLEXIO2_D25 0x400E8170U, 0x8U, 0, 0, 0x400E83B4U |
#define | IOMUXC_GPIO_AD_25_LPI2C4_SDA 0x400E8170U, 0x9U, 0x400E85C8U, 0x0U, 0x400E83B4U |
#define | IOMUXC_GPIO_AD_26_LPUART1_CTS_B 0x400E8174U, 0x0U, 0, 0, 0x400E83B8U |
#define | IOMUXC_GPIO_AD_26_LPSPI2_SOUT 0x400E8174U, 0x1U, 0x400E85ECU, 0x0U, 0x400E83B8U |
#define | IOMUXC_GPIO_AD_26_SEMC_CSX01 0x400E8174U, 0x2U, 0, 0, 0x400E83B8U |
#define | IOMUXC_GPIO_AD_26_ENET_RX_DATA00 0x400E8174U, 0x3U, 0x400E84B0U, 0x0U, 0x400E83B8U |
#define | IOMUXC_GPIO_AD_26_FLEXPWM2_PWM1_A 0x400E8174U, 0x4U, 0x400E851CU, 0x1U, 0x400E83B8U |
#define | IOMUXC_GPIO_AD_26_GPIO_MUX3_IO25 0x400E8174U, 0x5U, 0, 0, 0x400E83B8U |
#define | IOMUXC_GPIO_AD_26_KPP_ROW04 0x400E8174U, 0x6U, 0, 0, 0x400E83B8U |
#define | IOMUXC_GPIO_AD_26_FLEXIO2_D26 0x400E8174U, 0x8U, 0, 0, 0x400E83B8U |
#define | IOMUXC_GPIO_AD_26_ENET_QOS_MDC 0x400E8174U, 0x9U, 0, 0, 0x400E83B8U |
#define | IOMUXC_GPIO_AD_26_GPIO9_IO25 0x400E8174U, 0xAU, 0, 0, 0x400E83B8U |
#define | IOMUXC_GPIO_AD_26_USDHC2_CD_B 0x400E8174U, 0xBU, 0x400E86D0U, 0x1U, 0x400E83B8U |
#define | IOMUXC_GPIO_AD_27_LPUART1_RTS_B 0x400E8178U, 0x0U, 0, 0, 0x400E83BCU |
#define | IOMUXC_GPIO_AD_27_LPSPI2_SIN 0x400E8178U, 0x1U, 0x400E85E8U, 0x0U, 0x400E83BCU |
#define | IOMUXC_GPIO_AD_27_SEMC_CSX02 0x400E8178U, 0x2U, 0, 0, 0x400E83BCU |
#define | IOMUXC_GPIO_AD_27_ENET_RX_DATA01 0x400E8178U, 0x3U, 0x400E84B4U, 0x0U, 0x400E83BCU |
#define | IOMUXC_GPIO_AD_27_FLEXPWM2_PWM1_B 0x400E8178U, 0x4U, 0x400E8528U, 0x1U, 0x400E83BCU |
#define | IOMUXC_GPIO_AD_27_GPIO_MUX3_IO26 0x400E8178U, 0x5U, 0, 0, 0x400E83BCU |
#define | IOMUXC_GPIO_AD_27_KPP_COL04 0x400E8178U, 0x6U, 0, 0, 0x400E83BCU |
#define | IOMUXC_GPIO_AD_27_FLEXIO2_D27 0x400E8178U, 0x8U, 0, 0, 0x400E83BCU |
#define | IOMUXC_GPIO_AD_27_ENET_QOS_MDIO 0x400E8178U, 0x9U, 0x400E84ECU, 0x1U, 0x400E83BCU |
#define | IOMUXC_GPIO_AD_27_GPIO9_IO26 0x400E8178U, 0xAU, 0, 0, 0x400E83BCU |
#define | IOMUXC_GPIO_AD_27_USDHC2_WP 0x400E8178U, 0xBU, 0x400E86D4U, 0x1U, 0x400E83BCU |
#define | IOMUXC_GPIO_AD_28_GPIO9_IO27 0x400E817CU, 0xAU, 0, 0, 0x400E83C0U |
#define | IOMUXC_GPIO_AD_28_USDHC2_VSELECT 0x400E817CU, 0xBU, 0, 0, 0x400E83C0U |
#define | IOMUXC_GPIO_AD_28_LPSPI1_SCK 0x400E817CU, 0x0U, 0x400E85D0U, 0x1U, 0x400E83C0U |
#define | IOMUXC_GPIO_AD_28_LPUART5_TXD 0x400E817CU, 0x1U, 0, 0, 0x400E83C0U |
#define | IOMUXC_GPIO_AD_28_SEMC_CSX03 0x400E817CU, 0x2U, 0, 0, 0x400E83C0U |
#define | IOMUXC_GPIO_AD_28_ENET_TX_EN 0x400E817CU, 0x3U, 0, 0, 0x400E83C0U |
#define | IOMUXC_GPIO_AD_28_FLEXPWM2_PWM2_A 0x400E817CU, 0x4U, 0x400E8520U, 0x1U, 0x400E83C0U |
#define | IOMUXC_GPIO_AD_28_GPIO_MUX3_IO27 0x400E817CU, 0x5U, 0, 0, 0x400E83C0U |
#define | IOMUXC_GPIO_AD_28_KPP_ROW03 0x400E817CU, 0x6U, 0, 0, 0x400E83C0U |
#define | IOMUXC_GPIO_AD_28_FLEXIO2_D28 0x400E817CU, 0x8U, 0, 0, 0x400E83C0U |
#define | IOMUXC_GPIO_AD_28_VIDEO_MUX_EXT_DCIC1 0x400E817CU, 0x9U, 0, 0, 0x400E83C0U |
#define | IOMUXC_GPIO_AD_29_LPSPI1_PCS0 0x400E8180U, 0x0U, 0x400E85CCU, 0x1U, 0x400E83C4U |
#define | IOMUXC_GPIO_AD_29_LPUART5_RXD 0x400E8180U, 0x1U, 0, 0, 0x400E83C4U |
#define | IOMUXC_GPIO_AD_29_ENET_REF_CLK 0x400E8180U, 0x2U, 0x400E84A8U, 0x0U, 0x400E83C4U |
#define | IOMUXC_GPIO_AD_29_ENET_TX_CLK 0x400E8180U, 0x3U, 0x400E84C0U, 0x0U, 0x400E83C4U |
#define | IOMUXC_GPIO_AD_29_FLEXPWM2_PWM2_B 0x400E8180U, 0x4U, 0x400E852CU, 0x1U, 0x400E83C4U |
#define | IOMUXC_GPIO_AD_29_GPIO_MUX3_IO28 0x400E8180U, 0x5U, 0, 0, 0x400E83C4U |
#define | IOMUXC_GPIO_AD_29_KPP_COL03 0x400E8180U, 0x6U, 0, 0, 0x400E83C4U |
#define | IOMUXC_GPIO_AD_29_FLEXIO2_D29 0x400E8180U, 0x8U, 0, 0, 0x400E83C4U |
#define | IOMUXC_GPIO_AD_29_VIDEO_MUX_EXT_DCIC2 0x400E8180U, 0x9U, 0, 0, 0x400E83C4U |
#define | IOMUXC_GPIO_AD_29_GPIO9_IO28 0x400E8180U, 0xAU, 0, 0, 0x400E83C4U |
#define | IOMUXC_GPIO_AD_29_USDHC2_RESET_B 0x400E8180U, 0xBU, 0, 0, 0x400E83C4U |
#define | IOMUXC_GPIO_AD_30_LPSPI1_SOUT 0x400E8184U, 0x0U, 0x400E85D8U, 0x1U, 0x400E83C8U |
#define | IOMUXC_GPIO_AD_30_USB_OTG2_OC 0x400E8184U, 0x1U, 0x400E86B8U, 0x1U, 0x400E83C8U |
#define | IOMUXC_GPIO_AD_30_FLEXCAN2_TX 0x400E8184U, 0x2U, 0, 0, 0x400E83C8U |
#define | IOMUXC_GPIO_AD_30_ENET_TX_DATA00 0x400E8184U, 0x3U, 0, 0, 0x400E83C8U |
#define | IOMUXC_GPIO_AD_30_LPUART3_TXD 0x400E8184U, 0x4U, 0, 0, 0x400E83C8U |
#define | IOMUXC_GPIO_AD_30_GPIO_MUX3_IO29 0x400E8184U, 0x5U, 0, 0, 0x400E83C8U |
#define | IOMUXC_GPIO_AD_30_KPP_ROW02 0x400E8184U, 0x6U, 0, 0, 0x400E83C8U |
#define | IOMUXC_GPIO_AD_30_FLEXIO2_D30 0x400E8184U, 0x8U, 0, 0, 0x400E83C8U |
#define | IOMUXC_GPIO_AD_30_WDOG2_RESET_B_DEB 0x400E8184U, 0x9U, 0, 0, 0x400E83C8U |
#define | IOMUXC_GPIO_AD_30_GPIO9_IO29 0x400E8184U, 0xAU, 0, 0, 0x400E83C8U |
#define | IOMUXC_GPIO_AD_31_LPSPI1_SIN 0x400E8188U, 0x0U, 0x400E85D4U, 0x1U, 0x400E83CCU |
#define | IOMUXC_GPIO_AD_31_USB_OTG2_PWR 0x400E8188U, 0x1U, 0, 0, 0x400E83CCU |
#define | IOMUXC_GPIO_AD_31_FLEXCAN2_RX 0x400E8188U, 0x2U, 0x400E849CU, 0x1U, 0x400E83CCU |
#define | IOMUXC_GPIO_AD_31_ENET_TX_DATA01 0x400E8188U, 0x3U, 0, 0, 0x400E83CCU |
#define | IOMUXC_GPIO_AD_31_LPUART3_RXD 0x400E8188U, 0x4U, 0, 0, 0x400E83CCU |
#define | IOMUXC_GPIO_AD_31_GPIO_MUX3_IO30 0x400E8188U, 0x5U, 0, 0, 0x400E83CCU |
#define | IOMUXC_GPIO_AD_31_KPP_COL02 0x400E8188U, 0x6U, 0, 0, 0x400E83CCU |
#define | IOMUXC_GPIO_AD_31_FLEXIO2_D31 0x400E8188U, 0x8U, 0, 0, 0x400E83CCU |
#define | IOMUXC_GPIO_AD_31_WDOG1_RESET_B_DEB 0x400E8188U, 0x9U, 0, 0, 0x400E83CCU |
#define | IOMUXC_GPIO_AD_31_GPIO9_IO30 0x400E8188U, 0xAU, 0, 0, 0x400E83CCU |
#define | IOMUXC_GPIO_AD_32_GPIO9_IO31 0x400E818CU, 0xAU, 0, 0, 0x400E83D0U |
#define | IOMUXC_GPIO_AD_32_LPI2C1_SCL 0x400E818CU, 0x0U, 0x400E85ACU, 0x1U, 0x400E83D0U |
#define | IOMUXC_GPIO_AD_32_USBPHY2_OTG_ID 0x400E818CU, 0x1U, 0x400E86C4U, 0x1U, 0x400E83D0U |
#define | IOMUXC_GPIO_AD_32_PGMC_PMIC_RDY 0x400E818CU, 0x2U, 0, 0, 0x400E83D0U |
#define | IOMUXC_GPIO_AD_32_ENET_MDC 0x400E818CU, 0x3U, 0, 0, 0x400E83D0U |
#define | IOMUXC_GPIO_AD_32_USDHC1_CD_B 0x400E818CU, 0x4U, 0x400E86C8U, 0x0U, 0x400E83D0U |
#define | IOMUXC_GPIO_AD_32_GPIO_MUX3_IO31 0x400E818CU, 0x5U, 0, 0, 0x400E83D0U |
#define | IOMUXC_GPIO_AD_32_KPP_ROW01 0x400E818CU, 0x6U, 0, 0, 0x400E83D0U |
#define | IOMUXC_GPIO_AD_32_LPUART10_TXD 0x400E818CU, 0x8U, 0x400E8628U, 0x1U, 0x400E83D0U |
#define | IOMUXC_GPIO_AD_32_ENET_1G_MDC 0x400E818CU, 0x9U, 0, 0, 0x400E83D0U |
#define | IOMUXC_GPIO_AD_33_LPI2C1_SDA 0x400E8190U, 0x0U, 0x400E85B0U, 0x1U, 0x400E83D4U |
#define | IOMUXC_GPIO_AD_33_USBPHY1_OTG_ID 0x400E8190U, 0x1U, 0x400E86C0U, 0x1U, 0x400E83D4U |
#define | IOMUXC_GPIO_AD_33_XBAR1_INOUT17 0x400E8190U, 0x2U, 0, 0, 0x400E83D4U |
#define | IOMUXC_GPIO_AD_33_ENET_MDIO 0x400E8190U, 0x3U, 0x400E84ACU, 0x1U, 0x400E83D4U |
#define | IOMUXC_GPIO_AD_33_USDHC1_WP 0x400E8190U, 0x4U, 0x400E86CCU, 0x0U, 0x400E83D4U |
#define | IOMUXC_GPIO_AD_33_GPIO_MUX4_IO00 0x400E8190U, 0x5U, 0, 0, 0x400E83D4U |
#define | IOMUXC_GPIO_AD_33_KPP_COL01 0x400E8190U, 0x6U, 0, 0, 0x400E83D4U |
#define | IOMUXC_GPIO_AD_33_LPUART10_RXD 0x400E8190U, 0x8U, 0x400E8624U, 0x1U, 0x400E83D4U |
#define | IOMUXC_GPIO_AD_33_ENET_1G_MDIO 0x400E8190U, 0x9U, 0x400E84C8U, 0x3U, 0x400E83D4U |
#define | IOMUXC_GPIO_AD_33_GPIO10_IO00 0x400E8190U, 0xAU, 0, 0, 0x400E83D4U |
#define | IOMUXC_GPIO_AD_34_ENET_1G_1588_EVENT0_IN 0x400E8194U, 0x0U, 0, 0, 0x400E83D8U |
#define | IOMUXC_GPIO_AD_34_USB_OTG1_PWR 0x400E8194U, 0x1U, 0, 0, 0x400E83D8U |
#define | IOMUXC_GPIO_AD_34_XBAR1_INOUT18 0x400E8194U, 0x2U, 0, 0, 0x400E83D8U |
#define | IOMUXC_GPIO_AD_34_ENET_1588_EVENT0_IN 0x400E8194U, 0x3U, 0, 0, 0x400E83D8U |
#define | IOMUXC_GPIO_AD_34_USDHC1_VSELECT 0x400E8194U, 0x4U, 0, 0, 0x400E83D8U |
#define | IOMUXC_GPIO_AD_34_GPIO_MUX4_IO01 0x400E8194U, 0x5U, 0, 0, 0x400E83D8U |
#define | IOMUXC_GPIO_AD_34_KPP_ROW00 0x400E8194U, 0x6U, 0, 0, 0x400E83D8U |
#define | IOMUXC_GPIO_AD_34_LPUART10_CTS_B 0x400E8194U, 0x8U, 0, 0, 0x400E83D8U |
#define | IOMUXC_GPIO_AD_34_WDOG1_ANY 0x400E8194U, 0x9U, 0, 0, 0x400E83D8U |
#define | IOMUXC_GPIO_AD_34_GPIO10_IO01 0x400E8194U, 0xAU, 0, 0, 0x400E83D8U |
#define | IOMUXC_GPIO_AD_35_GPIO10_IO02 0x400E8198U, 0xAU, 0, 0, 0x400E83DCU |
#define | IOMUXC_GPIO_AD_35_ENET_1G_1588_EVENT0_OUT 0x400E8198U, 0x0U, 0, 0, 0x400E83DCU |
#define | IOMUXC_GPIO_AD_35_USB_OTG1_OC 0x400E8198U, 0x1U, 0x400E86BCU, 0x1U, 0x400E83DCU |
#define | IOMUXC_GPIO_AD_35_XBAR1_INOUT19 0x400E8198U, 0x2U, 0, 0, 0x400E83DCU |
#define | IOMUXC_GPIO_AD_35_ENET_1588_EVENT0_OUT 0x400E8198U, 0x3U, 0, 0, 0x400E83DCU |
#define | IOMUXC_GPIO_AD_35_USDHC1_RESET_B 0x400E8198U, 0x4U, 0, 0, 0x400E83DCU |
#define | IOMUXC_GPIO_AD_35_GPIO_MUX4_IO02 0x400E8198U, 0x5U, 0, 0, 0x400E83DCU |
#define | IOMUXC_GPIO_AD_35_KPP_COL00 0x400E8198U, 0x6U, 0, 0, 0x400E83DCU |
#define | IOMUXC_GPIO_AD_35_LPUART10_RTS_B 0x400E8198U, 0x8U, 0, 0, 0x400E83DCU |
#define | IOMUXC_GPIO_AD_35_FLEXSPI1_B_SS1_B 0x400E8198U, 0x9U, 0, 0, 0x400E83DCU |
#define | IOMUXC_GPIO_SD_B1_00_USDHC1_CMD 0x400E819CU, 0x0U, 0, 0, 0x400E83E0U |
#define | IOMUXC_GPIO_SD_B1_00_XBAR1_INOUT20 0x400E819CU, 0x2U, 0x400E86D8U, 0x1U, 0x400E83E0U |
#define | IOMUXC_GPIO_SD_B1_00_GPT4_CAPTURE1 0x400E819CU, 0x3U, 0, 0, 0x400E83E0U |
#define | IOMUXC_GPIO_SD_B1_00_GPIO_MUX4_IO03 0x400E819CU, 0x5U, 0, 0, 0x400E83E0U |
#define | IOMUXC_GPIO_SD_B1_00_FLEXSPI2_A_SS0_B 0x400E819CU, 0x6U, 0, 0, 0x400E83E0U |
#define | IOMUXC_GPIO_SD_B1_00_KPP_ROW07 0x400E819CU, 0x8U, 0x400E85A8U, 0x1U, 0x400E83E0U |
#define | IOMUXC_GPIO_SD_B1_00_GPIO10_IO03 0x400E819CU, 0xAU, 0, 0, 0x400E83E0U |
#define | IOMUXC_GPIO_SD_B1_01_USDHC1_CLK 0x400E81A0U, 0x0U, 0, 0, 0x400E83E4U |
#define | IOMUXC_GPIO_SD_B1_01_XBAR1_INOUT21 0x400E81A0U, 0x2U, 0x400E86DCU, 0x1U, 0x400E83E4U |
#define | IOMUXC_GPIO_SD_B1_01_GPT4_CAPTURE2 0x400E81A0U, 0x3U, 0, 0, 0x400E83E4U |
#define | IOMUXC_GPIO_SD_B1_01_GPIO_MUX4_IO04 0x400E81A0U, 0x5U, 0, 0, 0x400E83E4U |
#define | IOMUXC_GPIO_SD_B1_01_FLEXSPI2_A_SCLK 0x400E81A0U, 0x6U, 0x400E858CU, 0x1U, 0x400E83E4U |
#define | IOMUXC_GPIO_SD_B1_01_KPP_COL07 0x400E81A0U, 0x8U, 0x400E85A0U, 0x1U, 0x400E83E4U |
#define | IOMUXC_GPIO_SD_B1_01_GPIO10_IO04 0x400E81A0U, 0xAU, 0, 0, 0x400E83E4U |
#define | IOMUXC_GPIO_SD_B1_02_GPIO10_IO05 0x400E81A4U, 0xAU, 0, 0, 0x400E83E8U |
#define | IOMUXC_GPIO_SD_B1_02_USDHC1_DATA0 0x400E81A4U, 0x0U, 0, 0, 0x400E83E8U |
#define | IOMUXC_GPIO_SD_B1_02_XBAR1_INOUT22 0x400E81A4U, 0x2U, 0x400E86E0U, 0x1U, 0x400E83E8U |
#define | IOMUXC_GPIO_SD_B1_02_GPT4_COMPARE1 0x400E81A4U, 0x3U, 0, 0, 0x400E83E8U |
#define | IOMUXC_GPIO_SD_B1_02_GPIO_MUX4_IO05 0x400E81A4U, 0x5U, 0, 0, 0x400E83E8U |
#define | IOMUXC_GPIO_SD_B1_02_FLEXSPI2_A_DATA00 0x400E81A4U, 0x6U, 0x400E857CU, 0x1U, 0x400E83E8U |
#define | IOMUXC_GPIO_SD_B1_02_KPP_ROW06 0x400E81A4U, 0x8U, 0x400E85A4U, 0x1U, 0x400E83E8U |
#define | IOMUXC_GPIO_SD_B1_02_FLEXSPI1_A_SS1_B 0x400E81A4U, 0x9U, 0, 0, 0x400E83E8U |
#define | IOMUXC_GPIO_SD_B1_03_USDHC1_DATA1 0x400E81A8U, 0x0U, 0, 0, 0x400E83ECU |
#define | IOMUXC_GPIO_SD_B1_03_XBAR1_INOUT23 0x400E81A8U, 0x2U, 0x400E86E4U, 0x1U, 0x400E83ECU |
#define | IOMUXC_GPIO_SD_B1_03_GPT4_COMPARE2 0x400E81A8U, 0x3U, 0, 0, 0x400E83ECU |
#define | IOMUXC_GPIO_SD_B1_03_GPIO_MUX4_IO06 0x400E81A8U, 0x5U, 0, 0, 0x400E83ECU |
#define | IOMUXC_GPIO_SD_B1_03_FLEXSPI2_A_DATA01 0x400E81A8U, 0x6U, 0x400E8580U, 0x1U, 0x400E83ECU |
#define | IOMUXC_GPIO_SD_B1_03_KPP_COL06 0x400E81A8U, 0x8U, 0x400E859CU, 0x1U, 0x400E83ECU |
#define | IOMUXC_GPIO_SD_B1_03_FLEXSPI1_B_SS1_B 0x400E81A8U, 0x9U, 0, 0, 0x400E83ECU |
#define | IOMUXC_GPIO_SD_B1_03_GPIO10_IO06 0x400E81A8U, 0xAU, 0, 0, 0x400E83ECU |
#define | IOMUXC_GPIO_SD_B1_04_USDHC1_DATA2 0x400E81ACU, 0x0U, 0, 0, 0x400E83F0U |
#define | IOMUXC_GPIO_SD_B1_04_XBAR1_INOUT24 0x400E81ACU, 0x2U, 0x400E86E8U, 0x1U, 0x400E83F0U |
#define | IOMUXC_GPIO_SD_B1_04_GPT4_COMPARE3 0x400E81ACU, 0x3U, 0, 0, 0x400E83F0U |
#define | IOMUXC_GPIO_SD_B1_04_GPIO_MUX4_IO07 0x400E81ACU, 0x5U, 0, 0, 0x400E83F0U |
#define | IOMUXC_GPIO_SD_B1_04_FLEXSPI2_A_DATA02 0x400E81ACU, 0x6U, 0x400E8584U, 0x1U, 0x400E83F0U |
#define | IOMUXC_GPIO_SD_B1_04_FLEXSPI1_B_SS0_B 0x400E81ACU, 0x8U, 0, 0, 0x400E83F0U |
#define | IOMUXC_GPIO_SD_B1_04_ENET_QOS_1588_EVENT2_AUX_IN 0x400E81ACU, 0x9U, 0, 0, 0x400E83F0U |
#define | IOMUXC_GPIO_SD_B1_04_GPIO10_IO07 0x400E81ACU, 0xAU, 0, 0, 0x400E83F0U |
#define | IOMUXC_GPIO_SD_B1_05_GPIO10_IO08 0x400E81B0U, 0xAU, 0, 0, 0x400E83F4U |
#define | IOMUXC_GPIO_SD_B1_05_USDHC1_DATA3 0x400E81B0U, 0x0U, 0, 0, 0x400E83F4U |
#define | IOMUXC_GPIO_SD_B1_05_XBAR1_INOUT25 0x400E81B0U, 0x2U, 0x400E86ECU, 0x1U, 0x400E83F4U |
#define | IOMUXC_GPIO_SD_B1_05_GPT4_CLK 0x400E81B0U, 0x3U, 0, 0, 0x400E83F4U |
#define | IOMUXC_GPIO_SD_B1_05_GPIO_MUX4_IO08 0x400E81B0U, 0x5U, 0, 0, 0x400E83F4U |
#define | IOMUXC_GPIO_SD_B1_05_FLEXSPI2_A_DATA03 0x400E81B0U, 0x6U, 0x400E8588U, 0x1U, 0x400E83F4U |
#define | IOMUXC_GPIO_SD_B1_05_FLEXSPI1_B_DQS 0x400E81B0U, 0x8U, 0, 0, 0x400E83F4U |
#define | IOMUXC_GPIO_SD_B1_05_ENET_QOS_1588_EVENT3_AUX_IN 0x400E81B0U, 0x9U, 0, 0, 0x400E83F4U |
#define | IOMUXC_GPIO_SD_B2_00_GPIO10_IO09 0x400E81B4U, 0xAU, 0, 0, 0x400E83F8U |
#define | IOMUXC_GPIO_SD_B2_00_USDHC2_DATA3 0x400E81B4U, 0x0U, 0, 0, 0x400E83F8U |
#define | IOMUXC_GPIO_SD_B2_00_FLEXSPI1_B_DATA03 0x400E81B4U, 0x1U, 0x400E8570U, 0x1U, 0x400E83F8U |
#define | IOMUXC_GPIO_SD_B2_00_ENET_1G_RX_EN 0x400E81B4U, 0x2U, 0x400E84E0U, 0x1U, 0x400E83F8U |
#define | IOMUXC_GPIO_SD_B2_00_LPUART9_TXD 0x400E81B4U, 0x3U, 0, 0, 0x400E83F8U |
#define | IOMUXC_GPIO_SD_B2_00_LPSPI4_SCK 0x400E81B4U, 0x4U, 0x400E8610U, 0x0U, 0x400E83F8U |
#define | IOMUXC_GPIO_SD_B2_00_GPIO_MUX4_IO09 0x400E81B4U, 0x5U, 0, 0, 0x400E83F8U |
#define | IOMUXC_GPIO_SD_B2_01_USDHC2_DATA2 0x400E81B8U, 0x0U, 0, 0, 0x400E83FCU |
#define | IOMUXC_GPIO_SD_B2_01_FLEXSPI1_B_DATA02 0x400E81B8U, 0x1U, 0x400E856CU, 0x1U, 0x400E83FCU |
#define | IOMUXC_GPIO_SD_B2_01_ENET_1G_RX_CLK 0x400E81B8U, 0x2U, 0x400E84CCU, 0x1U, 0x400E83FCU |
#define | IOMUXC_GPIO_SD_B2_01_LPUART9_RXD 0x400E81B8U, 0x3U, 0, 0, 0x400E83FCU |
#define | IOMUXC_GPIO_SD_B2_01_LPSPI4_PCS0 0x400E81B8U, 0x4U, 0x400E860CU, 0x0U, 0x400E83FCU |
#define | IOMUXC_GPIO_SD_B2_01_GPIO_MUX4_IO10 0x400E81B8U, 0x5U, 0, 0, 0x400E83FCU |
#define | IOMUXC_GPIO_SD_B2_01_GPIO10_IO10 0x400E81B8U, 0xAU, 0, 0, 0x400E83FCU |
#define | IOMUXC_GPIO_SD_B2_02_GPIO10_IO11 0x400E81BCU, 0xAU, 0, 0, 0x400E8400U |
#define | IOMUXC_GPIO_SD_B2_02_USDHC2_DATA1 0x400E81BCU, 0x0U, 0, 0, 0x400E8400U |
#define | IOMUXC_GPIO_SD_B2_02_FLEXSPI1_B_DATA01 0x400E81BCU, 0x1U, 0x400E8568U, 0x1U, 0x400E8400U |
#define | IOMUXC_GPIO_SD_B2_02_ENET_1G_RX_DATA00 0x400E81BCU, 0x2U, 0x400E84D0U, 0x1U, 0x400E8400U |
#define | IOMUXC_GPIO_SD_B2_02_LPUART9_CTS_B 0x400E81BCU, 0x3U, 0, 0, 0x400E8400U |
#define | IOMUXC_GPIO_SD_B2_02_LPSPI4_SOUT 0x400E81BCU, 0x4U, 0x400E8618U, 0x0U, 0x400E8400U |
#define | IOMUXC_GPIO_SD_B2_02_GPIO_MUX4_IO11 0x400E81BCU, 0x5U, 0, 0, 0x400E8400U |
#define | IOMUXC_GPIO_SD_B2_03_GPIO10_IO12 0x400E81C0U, 0xAU, 0, 0, 0x400E8404U |
#define | IOMUXC_GPIO_SD_B2_03_USDHC2_DATA0 0x400E81C0U, 0x0U, 0, 0, 0x400E8404U |
#define | IOMUXC_GPIO_SD_B2_03_FLEXSPI1_B_DATA00 0x400E81C0U, 0x1U, 0x400E8564U, 0x1U, 0x400E8404U |
#define | IOMUXC_GPIO_SD_B2_03_ENET_1G_RX_DATA01 0x400E81C0U, 0x2U, 0x400E84D4U, 0x1U, 0x400E8404U |
#define | IOMUXC_GPIO_SD_B2_03_LPUART9_RTS_B 0x400E81C0U, 0x3U, 0, 0, 0x400E8404U |
#define | IOMUXC_GPIO_SD_B2_03_LPSPI4_SIN 0x400E81C0U, 0x4U, 0x400E8614U, 0x0U, 0x400E8404U |
#define | IOMUXC_GPIO_SD_B2_03_GPIO_MUX4_IO12 0x400E81C0U, 0x5U, 0, 0, 0x400E8404U |
#define | IOMUXC_GPIO_SD_B2_04_USDHC2_CLK 0x400E81C4U, 0x0U, 0, 0, 0x400E8408U |
#define | IOMUXC_GPIO_SD_B2_04_FLEXSPI1_B_SCLK 0x400E81C4U, 0x1U, 0x400E8578U, 0x1U, 0x400E8408U |
#define | IOMUXC_GPIO_SD_B2_04_ENET_1G_RX_DATA02 0x400E81C4U, 0x2U, 0x400E84D8U, 0x1U, 0x400E8408U |
#define | IOMUXC_GPIO_SD_B2_04_FLEXSPI1_A_SS1_B 0x400E81C4U, 0x3U, 0, 0, 0x400E8408U |
#define | IOMUXC_GPIO_SD_B2_04_LPSPI4_PCS1 0x400E81C4U, 0x4U, 0, 0, 0x400E8408U |
#define | IOMUXC_GPIO_SD_B2_04_GPIO_MUX4_IO13 0x400E81C4U, 0x5U, 0, 0, 0x400E8408U |
#define | IOMUXC_GPIO_SD_B2_04_GPIO10_IO13 0x400E81C4U, 0xAU, 0, 0, 0x400E8408U |
#define | IOMUXC_GPIO_SD_B2_05_GPIO10_IO14 0x400E81C8U, 0xAU, 0, 0, 0x400E840CU |
#define | IOMUXC_GPIO_SD_B2_05_USDHC2_CMD 0x400E81C8U, 0x0U, 0, 0, 0x400E840CU |
#define | IOMUXC_GPIO_SD_B2_05_FLEXSPI1_A_DQS 0x400E81C8U, 0x1U, 0x400E8550U, 0x2U, 0x400E840CU |
#define | IOMUXC_GPIO_SD_B2_05_ENET_1G_RX_DATA03 0x400E81C8U, 0x2U, 0x400E84DCU, 0x1U, 0x400E840CU |
#define | IOMUXC_GPIO_SD_B2_05_FLEXSPI1_B_SS0_B 0x400E81C8U, 0x3U, 0, 0, 0x400E840CU |
#define | IOMUXC_GPIO_SD_B2_05_LPSPI4_PCS2 0x400E81C8U, 0x4U, 0, 0, 0x400E840CU |
#define | IOMUXC_GPIO_SD_B2_05_GPIO_MUX4_IO14 0x400E81C8U, 0x5U, 0, 0, 0x400E840CU |
#define | IOMUXC_GPIO_SD_B2_06_GPIO10_IO15 0x400E81CCU, 0xAU, 0, 0, 0x400E8410U |
#define | IOMUXC_GPIO_SD_B2_06_USDHC2_RESET_B 0x400E81CCU, 0x0U, 0, 0, 0x400E8410U |
#define | IOMUXC_GPIO_SD_B2_06_FLEXSPI1_A_SS0_B 0x400E81CCU, 0x1U, 0, 0, 0x400E8410U |
#define | IOMUXC_GPIO_SD_B2_06_ENET_1G_TX_DATA03 0x400E81CCU, 0x2U, 0, 0, 0x400E8410U |
#define | IOMUXC_GPIO_SD_B2_06_LPSPI4_PCS3 0x400E81CCU, 0x3U, 0, 0, 0x400E8410U |
#define | IOMUXC_GPIO_SD_B2_06_GPT6_CAPTURE1 0x400E81CCU, 0x4U, 0, 0, 0x400E8410U |
#define | IOMUXC_GPIO_SD_B2_06_GPIO_MUX4_IO15 0x400E81CCU, 0x5U, 0, 0, 0x400E8410U |
#define | IOMUXC_GPIO_SD_B2_07_USDHC2_STROBE 0x400E81D0U, 0x0U, 0, 0, 0x400E8414U |
#define | IOMUXC_GPIO_SD_B2_07_FLEXSPI1_A_SCLK 0x400E81D0U, 0x1U, 0x400E8574U, 0x1U, 0x400E8414U |
#define | IOMUXC_GPIO_SD_B2_07_ENET_1G_TX_DATA02 0x400E81D0U, 0x2U, 0, 0, 0x400E8414U |
#define | IOMUXC_GPIO_SD_B2_07_LPUART3_CTS_B 0x400E81D0U, 0x3U, 0, 0, 0x400E8414U |
#define | IOMUXC_GPIO_SD_B2_07_GPT6_CAPTURE2 0x400E81D0U, 0x4U, 0, 0, 0x400E8414U |
#define | IOMUXC_GPIO_SD_B2_07_GPIO_MUX4_IO16 0x400E81D0U, 0x5U, 0, 0, 0x400E8414U |
#define | IOMUXC_GPIO_SD_B2_07_LPSPI2_SCK 0x400E81D0U, 0x6U, 0x400E85E4U, 0x1U, 0x400E8414U |
#define | IOMUXC_GPIO_SD_B2_07_ENET_TX_ER 0x400E81D0U, 0x8U, 0, 0, 0x400E8414U |
#define | IOMUXC_GPIO_SD_B2_07_ENET_QOS_REF_CLK 0x400E81D0U, 0x9U, 0x400E84A0U, 0x1U, 0x400E8414U |
#define | IOMUXC_GPIO_SD_B2_07_GPIO10_IO16 0x400E81D0U, 0xAU, 0, 0, 0x400E8414U |
#define | IOMUXC_GPIO_SD_B2_08_GPIO10_IO17 0x400E81D4U, 0xAU, 0, 0, 0x400E8418U |
#define | IOMUXC_GPIO_SD_B2_08_USDHC2_DATA4 0x400E81D4U, 0x0U, 0, 0, 0x400E8418U |
#define | IOMUXC_GPIO_SD_B2_08_FLEXSPI1_A_DATA00 0x400E81D4U, 0x1U, 0x400E8554U, 0x1U, 0x400E8418U |
#define | IOMUXC_GPIO_SD_B2_08_ENET_1G_TX_DATA01 0x400E81D4U, 0x2U, 0, 0, 0x400E8418U |
#define | IOMUXC_GPIO_SD_B2_08_LPUART3_RTS_B 0x400E81D4U, 0x3U, 0, 0, 0x400E8418U |
#define | IOMUXC_GPIO_SD_B2_08_GPT6_COMPARE1 0x400E81D4U, 0x4U, 0, 0, 0x400E8418U |
#define | IOMUXC_GPIO_SD_B2_08_GPIO_MUX4_IO17 0x400E81D4U, 0x5U, 0, 0, 0x400E8418U |
#define | IOMUXC_GPIO_SD_B2_08_LPSPI2_PCS0 0x400E81D4U, 0x6U, 0x400E85DCU, 0x1U, 0x400E8418U |
#define | IOMUXC_GPIO_SD_B2_09_GPIO10_IO18 0x400E81D8U, 0xAU, 0, 0, 0x400E841CU |
#define | IOMUXC_GPIO_SD_B2_09_USDHC2_DATA5 0x400E81D8U, 0x0U, 0, 0, 0x400E841CU |
#define | IOMUXC_GPIO_SD_B2_09_FLEXSPI1_A_DATA01 0x400E81D8U, 0x1U, 0x400E8558U, 0x1U, 0x400E841CU |
#define | IOMUXC_GPIO_SD_B2_09_ENET_1G_TX_DATA00 0x400E81D8U, 0x2U, 0, 0, 0x400E841CU |
#define | IOMUXC_GPIO_SD_B2_09_LPUART5_CTS_B 0x400E81D8U, 0x3U, 0, 0, 0x400E841CU |
#define | IOMUXC_GPIO_SD_B2_09_GPT6_COMPARE2 0x400E81D8U, 0x4U, 0, 0, 0x400E841CU |
#define | IOMUXC_GPIO_SD_B2_09_GPIO_MUX4_IO18 0x400E81D8U, 0x5U, 0, 0, 0x400E841CU |
#define | IOMUXC_GPIO_SD_B2_09_LPSPI2_SOUT 0x400E81D8U, 0x6U, 0x400E85ECU, 0x1U, 0x400E841CU |
#define | IOMUXC_GPIO_SD_B2_10_GPIO10_IO19 0x400E81DCU, 0xAU, 0, 0, 0x400E8420U |
#define | IOMUXC_GPIO_SD_B2_10_USDHC2_DATA6 0x400E81DCU, 0x0U, 0, 0, 0x400E8420U |
#define | IOMUXC_GPIO_SD_B2_10_FLEXSPI1_A_DATA02 0x400E81DCU, 0x1U, 0x400E855CU, 0x1U, 0x400E8420U |
#define | IOMUXC_GPIO_SD_B2_10_ENET_1G_TX_EN 0x400E81DCU, 0x2U, 0, 0, 0x400E8420U |
#define | IOMUXC_GPIO_SD_B2_10_LPUART5_RTS_B 0x400E81DCU, 0x3U, 0, 0, 0x400E8420U |
#define | IOMUXC_GPIO_SD_B2_10_GPT6_COMPARE3 0x400E81DCU, 0x4U, 0, 0, 0x400E8420U |
#define | IOMUXC_GPIO_SD_B2_10_GPIO_MUX4_IO19 0x400E81DCU, 0x5U, 0, 0, 0x400E8420U |
#define | IOMUXC_GPIO_SD_B2_10_LPSPI2_SIN 0x400E81DCU, 0x6U, 0x400E85E8U, 0x1U, 0x400E8420U |
#define | IOMUXC_GPIO_SD_B2_11_USDHC2_DATA7 0x400E81E0U, 0x0U, 0, 0, 0x400E8424U |
#define | IOMUXC_GPIO_SD_B2_11_FLEXSPI1_A_DATA03 0x400E81E0U, 0x1U, 0x400E8560U, 0x1U, 0x400E8424U |
#define | IOMUXC_GPIO_SD_B2_11_ENET_1G_TX_CLK_IO 0x400E81E0U, 0x2U, 0x400E84E8U, 0x1U, 0x400E8424U |
#define | IOMUXC_GPIO_SD_B2_11_ENET_1G_REF_CLK 0x400E81E0U, 0x3U, 0x400E84C4U, 0x1U, 0x400E8424U |
#define | IOMUXC_GPIO_SD_B2_11_GPT6_CLK 0x400E81E0U, 0x4U, 0, 0, 0x400E8424U |
#define | IOMUXC_GPIO_SD_B2_11_GPIO_MUX4_IO20 0x400E81E0U, 0x5U, 0, 0, 0x400E8424U |
#define | IOMUXC_GPIO_SD_B2_11_LPSPI2_PCS1 0x400E81E0U, 0x6U, 0x400E85E0U, 0x1U, 0x400E8424U |
#define | IOMUXC_GPIO_SD_B2_11_GPIO10_IO20 0x400E81E0U, 0xAU, 0, 0, 0x400E8424U |
#define | IOMUXC_GPIO_DISP_B1_00_VIDEO_MUX_LCDIF_CLK 0x400E81E4U, 0x0U, 0, 0, 0x400E8428U |
#define | IOMUXC_GPIO_DISP_B1_00_ENET_1G_RX_EN 0x400E81E4U, 0x1U, 0x400E84E0U, 0x2U, 0x400E8428U |
#define | IOMUXC_GPIO_DISP_B1_00_TMR1_TIMER0 0x400E81E4U, 0x3U, 0x400E863CU, 0x2U, 0x400E8428U |
#define | IOMUXC_GPIO_DISP_B1_00_XBAR1_INOUT26 0x400E81E4U, 0x4U, 0x400E86F0U, 0x1U, 0x400E8428U |
#define | IOMUXC_GPIO_DISP_B1_00_GPIO_MUX4_IO21 0x400E81E4U, 0x5U, 0, 0, 0x400E8428U |
#define | IOMUXC_GPIO_DISP_B1_00_ENET_QOS_RX_EN 0x400E81E4U, 0x8U, 0x400E84F8U, 0x0U, 0x400E8428U |
#define | IOMUXC_GPIO_DISP_B1_00_GPIO10_IO21 0x400E81E4U, 0xAU, 0, 0, 0x400E8428U |
#define | IOMUXC_GPIO_DISP_B1_01_VIDEO_MUX_LCDIF_ENABLE 0x400E81E8U, 0x0U, 0, 0, 0x400E842CU |
#define | IOMUXC_GPIO_DISP_B1_01_ENET_1G_RX_CLK 0x400E81E8U, 0x1U, 0x400E84CCU, 0x2U, 0x400E842CU |
#define | IOMUXC_GPIO_DISP_B1_01_ENET_1G_RX_ER 0x400E81E8U, 0x2U, 0x400E84E4U, 0x1U, 0x400E842CU |
#define | IOMUXC_GPIO_DISP_B1_01_TMR1_TIMER1 0x400E81E8U, 0x3U, 0x400E8640U, 0x2U, 0x400E842CU |
#define | IOMUXC_GPIO_DISP_B1_01_XBAR1_INOUT27 0x400E81E8U, 0x4U, 0x400E86F4U, 0x1U, 0x400E842CU |
#define | IOMUXC_GPIO_DISP_B1_01_GPIO_MUX4_IO22 0x400E81E8U, 0x5U, 0, 0, 0x400E842CU |
#define | IOMUXC_GPIO_DISP_B1_01_ENET_QOS_RX_CLK 0x400E81E8U, 0x8U, 0, 0, 0x400E842CU |
#define | IOMUXC_GPIO_DISP_B1_01_ENET_QOS_RX_ER 0x400E81E8U, 0x9U, 0x400E84FCU, 0x0U, 0x400E842CU |
#define | IOMUXC_GPIO_DISP_B1_01_GPIO10_IO22 0x400E81E8U, 0xAU, 0, 0, 0x400E842CU |
#define | IOMUXC_GPIO_DISP_B1_02_GPIO10_IO23 0x400E81ECU, 0xAU, 0, 0, 0x400E8430U |
#define | IOMUXC_GPIO_DISP_B1_02_VIDEO_MUX_LCDIF_HSYNC 0x400E81ECU, 0x0U, 0, 0, 0x400E8430U |
#define | IOMUXC_GPIO_DISP_B1_02_ENET_1G_RX_DATA00 0x400E81ECU, 0x1U, 0x400E84D0U, 0x2U, 0x400E8430U |
#define | IOMUXC_GPIO_DISP_B1_02_LPI2C3_SCL 0x400E81ECU, 0x2U, 0x400E85BCU, 0x0U, 0x400E8430U |
#define | IOMUXC_GPIO_DISP_B1_02_TMR1_TIMER2 0x400E81ECU, 0x3U, 0x400E8644U, 0x1U, 0x400E8430U |
#define | IOMUXC_GPIO_DISP_B1_02_XBAR1_INOUT28 0x400E81ECU, 0x4U, 0x400E86F8U, 0x1U, 0x400E8430U |
#define | IOMUXC_GPIO_DISP_B1_02_GPIO_MUX4_IO23 0x400E81ECU, 0x5U, 0, 0, 0x400E8430U |
#define | IOMUXC_GPIO_DISP_B1_02_ENET_QOS_RX_DATA00 0x400E81ECU, 0x8U, 0x400E84F0U, 0x0U, 0x400E8430U |
#define | IOMUXC_GPIO_DISP_B1_02_LPUART1_TXD 0x400E81ECU, 0x9U, 0x400E8620U, 0x1U, 0x400E8430U |
#define | IOMUXC_GPIO_DISP_B1_03_VIDEO_MUX_LCDIF_VSYNC 0x400E81F0U, 0x0U, 0, 0, 0x400E8434U |
#define | IOMUXC_GPIO_DISP_B1_03_ENET_1G_RX_DATA01 0x400E81F0U, 0x1U, 0x400E84D4U, 0x2U, 0x400E8434U |
#define | IOMUXC_GPIO_DISP_B1_03_LPI2C3_SDA 0x400E81F0U, 0x2U, 0x400E85C0U, 0x0U, 0x400E8434U |
#define | IOMUXC_GPIO_DISP_B1_03_TMR2_TIMER0 0x400E81F0U, 0x3U, 0x400E8648U, 0x2U, 0x400E8434U |
#define | IOMUXC_GPIO_DISP_B1_03_XBAR1_INOUT29 0x400E81F0U, 0x4U, 0x400E86FCU, 0x1U, 0x400E8434U |
#define | IOMUXC_GPIO_DISP_B1_03_GPIO_MUX4_IO24 0x400E81F0U, 0x5U, 0, 0, 0x400E8434U |
#define | IOMUXC_GPIO_DISP_B1_03_ENET_QOS_RX_DATA01 0x400E81F0U, 0x8U, 0x400E84F4U, 0x0U, 0x400E8434U |
#define | IOMUXC_GPIO_DISP_B1_03_LPUART1_RXD 0x400E81F0U, 0x9U, 0x400E861CU, 0x1U, 0x400E8434U |
#define | IOMUXC_GPIO_DISP_B1_03_GPIO10_IO24 0x400E81F0U, 0xAU, 0, 0, 0x400E8434U |
#define | IOMUXC_GPIO_DISP_B1_04_VIDEO_MUX_LCDIF_DATA00 0x400E81F4U, 0x0U, 0, 0, 0x400E8438U |
#define | IOMUXC_GPIO_DISP_B1_04_ENET_1G_RX_DATA02 0x400E81F4U, 0x1U, 0x400E84D8U, 0x2U, 0x400E8438U |
#define | IOMUXC_GPIO_DISP_B1_04_LPUART4_RXD 0x400E81F4U, 0x2U, 0, 0, 0x400E8438U |
#define | IOMUXC_GPIO_DISP_B1_04_TMR2_TIMER1 0x400E81F4U, 0x3U, 0x400E864CU, 0x2U, 0x400E8438U |
#define | IOMUXC_GPIO_DISP_B1_04_XBAR1_INOUT30 0x400E81F4U, 0x4U, 0x400E8700U, 0x1U, 0x400E8438U |
#define | IOMUXC_GPIO_DISP_B1_04_GPIO_MUX4_IO25 0x400E81F4U, 0x5U, 0, 0, 0x400E8438U |
#define | IOMUXC_GPIO_DISP_B1_04_ENET_QOS_RX_DATA02 0x400E81F4U, 0x8U, 0, 0, 0x400E8438U |
#define | IOMUXC_GPIO_DISP_B1_04_LPSPI3_SCK 0x400E81F4U, 0x9U, 0x400E8600U, 0x1U, 0x400E8438U |
#define | IOMUXC_GPIO_DISP_B1_04_GPIO10_IO25 0x400E81F4U, 0xAU, 0, 0, 0x400E8438U |
#define | IOMUXC_GPIO_DISP_B1_05_GPIO10_IO26 0x400E81F8U, 0xAU, 0, 0, 0x400E843CU |
#define | IOMUXC_GPIO_DISP_B1_05_VIDEO_MUX_LCDIF_DATA01 0x400E81F8U, 0x0U, 0, 0, 0x400E843CU |
#define | IOMUXC_GPIO_DISP_B1_05_ENET_1G_RX_DATA03 0x400E81F8U, 0x1U, 0x400E84DCU, 0x2U, 0x400E843CU |
#define | IOMUXC_GPIO_DISP_B1_05_LPUART4_CTS_B 0x400E81F8U, 0x2U, 0, 0, 0x400E843CU |
#define | IOMUXC_GPIO_DISP_B1_05_TMR2_TIMER2 0x400E81F8U, 0x3U, 0x400E8650U, 0x1U, 0x400E843CU |
#define | IOMUXC_GPIO_DISP_B1_05_XBAR1_INOUT31 0x400E81F8U, 0x4U, 0x400E8704U, 0x1U, 0x400E843CU |
#define | IOMUXC_GPIO_DISP_B1_05_GPIO_MUX4_IO26 0x400E81F8U, 0x5U, 0, 0, 0x400E843CU |
#define | IOMUXC_GPIO_DISP_B1_05_ENET_QOS_RX_DATA03 0x400E81F8U, 0x8U, 0, 0, 0x400E843CU |
#define | IOMUXC_GPIO_DISP_B1_05_LPSPI3_SIN 0x400E81F8U, 0x9U, 0x400E8604U, 0x1U, 0x400E843CU |
#define | IOMUXC_GPIO_DISP_B1_06_VIDEO_MUX_LCDIF_DATA02 0x400E81FCU, 0x0U, 0, 0, 0x400E8440U |
#define | IOMUXC_GPIO_DISP_B1_06_ENET_1G_TX_DATA03 0x400E81FCU, 0x1U, 0, 0, 0x400E8440U |
#define | IOMUXC_GPIO_DISP_B1_06_LPUART4_TXD 0x400E81FCU, 0x2U, 0, 0, 0x400E8440U |
#define | IOMUXC_GPIO_DISP_B1_06_TMR3_TIMER0 0x400E81FCU, 0x3U, 0x400E8654U, 0x2U, 0x400E8440U |
#define | IOMUXC_GPIO_DISP_B1_06_XBAR1_INOUT32 0x400E81FCU, 0x4U, 0x400E8708U, 0x1U, 0x400E8440U |
#define | IOMUXC_GPIO_DISP_B1_06_GPIO_MUX4_IO27 0x400E81FCU, 0x5U, 0, 0, 0x400E8440U |
#define | IOMUXC_GPIO_DISP_B1_06_SRC_BT_CFG00 0x400E81FCU, 0x6U, 0, 0, 0x400E8440U |
#define | IOMUXC_GPIO_DISP_B1_06_ENET_QOS_TX_DATA03 0x400E81FCU, 0x8U, 0, 0, 0x400E8440U |
#define | IOMUXC_GPIO_DISP_B1_06_LPSPI3_SOUT 0x400E81FCU, 0x9U, 0x400E8608U, 0x1U, 0x400E8440U |
#define | IOMUXC_GPIO_DISP_B1_06_GPIO10_IO27 0x400E81FCU, 0xAU, 0, 0, 0x400E8440U |
#define | IOMUXC_GPIO_DISP_B1_07_VIDEO_MUX_LCDIF_DATA03 0x400E8200U, 0x0U, 0, 0, 0x400E8444U |
#define | IOMUXC_GPIO_DISP_B1_07_ENET_1G_TX_DATA02 0x400E8200U, 0x1U, 0, 0, 0x400E8444U |
#define | IOMUXC_GPIO_DISP_B1_07_LPUART4_RTS_B 0x400E8200U, 0x2U, 0, 0, 0x400E8444U |
#define | IOMUXC_GPIO_DISP_B1_07_TMR3_TIMER1 0x400E8200U, 0x3U, 0x400E8658U, 0x2U, 0x400E8444U |
#define | IOMUXC_GPIO_DISP_B1_07_XBAR1_INOUT33 0x400E8200U, 0x4U, 0x400E870CU, 0x1U, 0x400E8444U |
#define | IOMUXC_GPIO_DISP_B1_07_GPIO_MUX4_IO28 0x400E8200U, 0x5U, 0, 0, 0x400E8444U |
#define | IOMUXC_GPIO_DISP_B1_07_SRC_BT_CFG01 0x400E8200U, 0x6U, 0, 0, 0x400E8444U |
#define | IOMUXC_GPIO_DISP_B1_07_ENET_QOS_TX_DATA02 0x400E8200U, 0x8U, 0, 0, 0x400E8444U |
#define | IOMUXC_GPIO_DISP_B1_07_LPSPI3_PCS0 0x400E8200U, 0x9U, 0x400E85F0U, 0x1U, 0x400E8444U |
#define | IOMUXC_GPIO_DISP_B1_07_GPIO10_IO28 0x400E8200U, 0xAU, 0, 0, 0x400E8444U |
#define | IOMUXC_GPIO_DISP_B1_08_GPIO10_IO29 0x400E8204U, 0xAU, 0, 0, 0x400E8448U |
#define | IOMUXC_GPIO_DISP_B1_08_VIDEO_MUX_LCDIF_DATA04 0x400E8204U, 0x0U, 0, 0, 0x400E8448U |
#define | IOMUXC_GPIO_DISP_B1_08_ENET_1G_TX_DATA01 0x400E8204U, 0x1U, 0, 0, 0x400E8448U |
#define | IOMUXC_GPIO_DISP_B1_08_USDHC1_CD_B 0x400E8204U, 0x2U, 0x400E86C8U, 0x1U, 0x400E8448U |
#define | IOMUXC_GPIO_DISP_B1_08_TMR3_TIMER2 0x400E8204U, 0x3U, 0x400E865CU, 0x1U, 0x400E8448U |
#define | IOMUXC_GPIO_DISP_B1_08_XBAR1_INOUT34 0x400E8204U, 0x4U, 0x400E8710U, 0x1U, 0x400E8448U |
#define | IOMUXC_GPIO_DISP_B1_08_GPIO_MUX4_IO29 0x400E8204U, 0x5U, 0, 0, 0x400E8448U |
#define | IOMUXC_GPIO_DISP_B1_08_SRC_BT_CFG02 0x400E8204U, 0x6U, 0, 0, 0x400E8448U |
#define | IOMUXC_GPIO_DISP_B1_08_ENET_QOS_TX_DATA01 0x400E8204U, 0x8U, 0, 0, 0x400E8448U |
#define | IOMUXC_GPIO_DISP_B1_08_LPSPI3_PCS1 0x400E8204U, 0x9U, 0x400E85F4U, 0x1U, 0x400E8448U |
#define | IOMUXC_GPIO_DISP_B1_09_VIDEO_MUX_LCDIF_DATA05 0x400E8208U, 0x0U, 0, 0, 0x400E844CU |
#define | IOMUXC_GPIO_DISP_B1_09_ENET_1G_TX_DATA00 0x400E8208U, 0x1U, 0, 0, 0x400E844CU |
#define | IOMUXC_GPIO_DISP_B1_09_USDHC1_WP 0x400E8208U, 0x2U, 0x400E86CCU, 0x1U, 0x400E844CU |
#define | IOMUXC_GPIO_DISP_B1_09_TMR4_TIMER0 0x400E8208U, 0x3U, 0x400E8660U, 0x2U, 0x400E844CU |
#define | IOMUXC_GPIO_DISP_B1_09_XBAR1_INOUT35 0x400E8208U, 0x4U, 0x400E8714U, 0x1U, 0x400E844CU |
#define | IOMUXC_GPIO_DISP_B1_09_GPIO_MUX4_IO30 0x400E8208U, 0x5U, 0, 0, 0x400E844CU |
#define | IOMUXC_GPIO_DISP_B1_09_SRC_BT_CFG03 0x400E8208U, 0x6U, 0, 0, 0x400E844CU |
#define | IOMUXC_GPIO_DISP_B1_09_ENET_QOS_TX_DATA00 0x400E8208U, 0x8U, 0, 0, 0x400E844CU |
#define | IOMUXC_GPIO_DISP_B1_09_LPSPI3_PCS2 0x400E8208U, 0x9U, 0x400E85F8U, 0x1U, 0x400E844CU |
#define | IOMUXC_GPIO_DISP_B1_09_GPIO10_IO30 0x400E8208U, 0xAU, 0, 0, 0x400E844CU |
#define | IOMUXC_GPIO_DISP_B1_10_VIDEO_MUX_LCDIF_DATA06 0x400E820CU, 0x0U, 0, 0, 0x400E8450U |
#define | IOMUXC_GPIO_DISP_B1_10_ENET_1G_TX_EN 0x400E820CU, 0x1U, 0, 0, 0x400E8450U |
#define | IOMUXC_GPIO_DISP_B1_10_USDHC1_RESET_B 0x400E820CU, 0x2U, 0, 0, 0x400E8450U |
#define | IOMUXC_GPIO_DISP_B1_10_TMR4_TIMER1 0x400E820CU, 0x3U, 0x400E8664U, 0x2U, 0x400E8450U |
#define | IOMUXC_GPIO_DISP_B1_10_XBAR1_INOUT36 0x400E820CU, 0x4U, 0, 0, 0x400E8450U |
#define | IOMUXC_GPIO_DISP_B1_10_GPIO_MUX4_IO31 0x400E820CU, 0x5U, 0, 0, 0x400E8450U |
#define | IOMUXC_GPIO_DISP_B1_10_SRC_BT_CFG04 0x400E820CU, 0x6U, 0, 0, 0x400E8450U |
#define | IOMUXC_GPIO_DISP_B1_10_ENET_QOS_TX_EN 0x400E820CU, 0x8U, 0, 0, 0x400E8450U |
#define | IOMUXC_GPIO_DISP_B1_10_LPSPI3_PCS3 0x400E820CU, 0x9U, 0x400E85FCU, 0x1U, 0x400E8450U |
#define | IOMUXC_GPIO_DISP_B1_10_GPIO10_IO31 0x400E820CU, 0xAU, 0, 0, 0x400E8450U |
#define | IOMUXC_GPIO_DISP_B1_11_VIDEO_MUX_LCDIF_DATA07 0x400E8210U, 0x0U, 0, 0, 0x400E8454U |
#define | IOMUXC_GPIO_DISP_B1_11_ENET_1G_TX_CLK_IO 0x400E8210U, 0x1U, 0x400E84E8U, 0x2U, 0x400E8454U |
#define | IOMUXC_GPIO_DISP_B1_11_ENET_1G_REF_CLK 0x400E8210U, 0x2U, 0x400E84C4U, 0x2U, 0x400E8454U |
#define | IOMUXC_GPIO_DISP_B1_11_TMR4_TIMER2 0x400E8210U, 0x3U, 0x400E8668U, 0x1U, 0x400E8454U |
#define | IOMUXC_GPIO_DISP_B1_11_XBAR1_INOUT37 0x400E8210U, 0x4U, 0, 0, 0x400E8454U |
#define | IOMUXC_GPIO_DISP_B1_11_GPIO_MUX5_IO00 0x400E8210U, 0x5U, 0, 0, 0x400E8454U |
#define | IOMUXC_GPIO_DISP_B1_11_SRC_BT_CFG05 0x400E8210U, 0x6U, 0, 0, 0x400E8454U |
#define | IOMUXC_GPIO_DISP_B1_11_ENET_QOS_TX_CLK 0x400E8210U, 0x8U, 0x400E84A4U, 0x0U, 0x400E8454U |
#define | IOMUXC_GPIO_DISP_B1_11_ENET_QOS_REF_CLK 0x400E8210U, 0x9U, 0x400E84A0U, 0x2U, 0x400E8454U |
#define | IOMUXC_GPIO_DISP_B1_11_GPIO11_IO00 0x400E8210U, 0xAU, 0, 0, 0x400E8454U |
#define | IOMUXC_GPIO_DISP_B2_00_GPIO11_IO01 0x400E8214U, 0xAU, 0, 0, 0x400E8458U |
#define | IOMUXC_GPIO_DISP_B2_00_VIDEO_MUX_LCDIF_DATA08 0x400E8214U, 0x0U, 0, 0, 0x400E8458U |
#define | IOMUXC_GPIO_DISP_B2_00_WDOG1_B 0x400E8214U, 0x1U, 0, 0, 0x400E8458U |
#define | IOMUXC_GPIO_DISP_B2_00_MQS_RIGHT 0x400E8214U, 0x2U, 0, 0, 0x400E8458U |
#define | IOMUXC_GPIO_DISP_B2_00_ENET_1G_TX_ER 0x400E8214U, 0x3U, 0, 0, 0x400E8458U |
#define | IOMUXC_GPIO_DISP_B2_00_SAI1_TX_DATA03 0x400E8214U, 0x4U, 0, 0, 0x400E8458U |
#define | IOMUXC_GPIO_DISP_B2_00_GPIO_MUX5_IO01 0x400E8214U, 0x5U, 0, 0, 0x400E8458U |
#define | IOMUXC_GPIO_DISP_B2_00_SRC_BT_CFG06 0x400E8214U, 0x6U, 0, 0, 0x400E8458U |
#define | IOMUXC_GPIO_DISP_B2_00_ENET_QOS_TX_ER 0x400E8214U, 0x8U, 0, 0, 0x400E8458U |
#define | IOMUXC_GPIO_DISP_B2_01_VIDEO_MUX_LCDIF_DATA09 0x400E8218U, 0x0U, 0, 0, 0x400E845CU |
#define | IOMUXC_GPIO_DISP_B2_01_USDHC1_VSELECT 0x400E8218U, 0x1U, 0, 0, 0x400E845CU |
#define | IOMUXC_GPIO_DISP_B2_01_MQS_LEFT 0x400E8218U, 0x2U, 0, 0, 0x400E845CU |
#define | IOMUXC_GPIO_DISP_B2_01_WDOG2_B 0x400E8218U, 0x3U, 0, 0, 0x400E845CU |
#define | IOMUXC_GPIO_DISP_B2_01_SAI1_TX_DATA02 0x400E8218U, 0x4U, 0, 0, 0x400E845CU |
#define | IOMUXC_GPIO_DISP_B2_01_GPIO_MUX5_IO02 0x400E8218U, 0x5U, 0, 0, 0x400E845CU |
#define | IOMUXC_GPIO_DISP_B2_01_SRC_BT_CFG07 0x400E8218U, 0x6U, 0, 0, 0x400E845CU |
#define | IOMUXC_GPIO_DISP_B2_01_EWM_OUT_B 0x400E8218U, 0x8U, 0, 0, 0x400E845CU |
#define | IOMUXC_GPIO_DISP_B2_01_CCM_ENET_REF_CLK_25M 0x400E8218U, 0x9U, 0, 0, 0x400E845CU |
#define | IOMUXC_GPIO_DISP_B2_01_GPIO11_IO02 0x400E8218U, 0xAU, 0, 0, 0x400E845CU |
#define | IOMUXC_GPIO_DISP_B2_02_GPIO11_IO03 0x400E821CU, 0xAU, 0, 0, 0x400E8460U |
#define | IOMUXC_GPIO_DISP_B2_02_VIDEO_MUX_LCDIF_DATA10 0x400E821CU, 0x0U, 0, 0, 0x400E8460U |
#define | IOMUXC_GPIO_DISP_B2_02_ENET_TX_DATA00 0x400E821CU, 0x1U, 0, 0, 0x400E8460U |
#define | IOMUXC_GPIO_DISP_B2_02_PIT1_TRIGGER3 0x400E821CU, 0x2U, 0, 0, 0x400E8460U |
#define | IOMUXC_GPIO_DISP_B2_02_ARM_TRACE00 0x400E821CU, 0x3U, 0, 0, 0x400E8460U |
#define | IOMUXC_GPIO_DISP_B2_02_SAI1_TX_DATA01 0x400E821CU, 0x4U, 0, 0, 0x400E8460U |
#define | IOMUXC_GPIO_DISP_B2_02_GPIO_MUX5_IO03 0x400E821CU, 0x5U, 0, 0, 0x400E8460U |
#define | IOMUXC_GPIO_DISP_B2_02_SRC_BT_CFG08 0x400E821CU, 0x6U, 0, 0, 0x400E8460U |
#define | IOMUXC_GPIO_DISP_B2_02_ENET_QOS_TX_DATA00 0x400E821CU, 0x8U, 0, 0, 0x400E8460U |
#define | IOMUXC_GPIO_DISP_B2_03_GPIO11_IO04 0x400E8220U, 0xAU, 0, 0, 0x400E8464U |
#define | IOMUXC_GPIO_DISP_B2_03_VIDEO_MUX_LCDIF_DATA11 0x400E8220U, 0x0U, 0, 0, 0x400E8464U |
#define | IOMUXC_GPIO_DISP_B2_03_ENET_TX_DATA01 0x400E8220U, 0x1U, 0, 0, 0x400E8464U |
#define | IOMUXC_GPIO_DISP_B2_03_PIT1_TRIGGER2 0x400E8220U, 0x2U, 0, 0, 0x400E8464U |
#define | IOMUXC_GPIO_DISP_B2_03_ARM_TRACE01 0x400E8220U, 0x3U, 0, 0, 0x400E8464U |
#define | IOMUXC_GPIO_DISP_B2_03_SAI1_MCLK 0x400E8220U, 0x4U, 0x400E866CU, 0x1U, 0x400E8464U |
#define | IOMUXC_GPIO_DISP_B2_03_GPIO_MUX5_IO04 0x400E8220U, 0x5U, 0, 0, 0x400E8464U |
#define | IOMUXC_GPIO_DISP_B2_03_SRC_BT_CFG09 0x400E8220U, 0x6U, 0, 0, 0x400E8464U |
#define | IOMUXC_GPIO_DISP_B2_03_ENET_QOS_TX_DATA01 0x400E8220U, 0x8U, 0, 0, 0x400E8464U |
#define | IOMUXC_GPIO_DISP_B2_04_VIDEO_MUX_LCDIF_DATA12 0x400E8224U, 0x0U, 0, 0, 0x400E8468U |
#define | IOMUXC_GPIO_DISP_B2_04_ENET_TX_EN 0x400E8224U, 0x1U, 0, 0, 0x400E8468U |
#define | IOMUXC_GPIO_DISP_B2_04_PIT1_TRIGGER1 0x400E8224U, 0x2U, 0, 0, 0x400E8468U |
#define | IOMUXC_GPIO_DISP_B2_04_ARM_TRACE02 0x400E8224U, 0x3U, 0, 0, 0x400E8468U |
#define | IOMUXC_GPIO_DISP_B2_04_SAI1_RX_SYNC 0x400E8224U, 0x4U, 0x400E8678U, 0x1U, 0x400E8468U |
#define | IOMUXC_GPIO_DISP_B2_04_GPIO_MUX5_IO05 0x400E8224U, 0x5U, 0, 0, 0x400E8468U |
#define | IOMUXC_GPIO_DISP_B2_04_SRC_BT_CFG10 0x400E8224U, 0x6U, 0, 0, 0x400E8468U |
#define | IOMUXC_GPIO_DISP_B2_04_ENET_QOS_TX_EN 0x400E8224U, 0x8U, 0, 0, 0x400E8468U |
#define | IOMUXC_GPIO_DISP_B2_04_GPIO11_IO05 0x400E8224U, 0xAU, 0, 0, 0x400E8468U |
#define | IOMUXC_GPIO_DISP_B2_05_GPIO11_IO06 0x400E8228U, 0xAU, 0, 0, 0x400E846CU |
#define | IOMUXC_GPIO_DISP_B2_05_VIDEO_MUX_LCDIF_DATA13 0x400E8228U, 0x0U, 0, 0, 0x400E846CU |
#define | IOMUXC_GPIO_DISP_B2_05_ENET_TX_CLK 0x400E8228U, 0x1U, 0x400E84C0U, 0x1U, 0x400E846CU |
#define | IOMUXC_GPIO_DISP_B2_05_ENET_REF_CLK 0x400E8228U, 0x2U, 0x400E84A8U, 0x1U, 0x400E846CU |
#define | IOMUXC_GPIO_DISP_B2_05_ARM_TRACE03 0x400E8228U, 0x3U, 0, 0, 0x400E846CU |
#define | IOMUXC_GPIO_DISP_B2_05_SAI1_RX_BCLK 0x400E8228U, 0x4U, 0x400E8670U, 0x1U, 0x400E846CU |
#define | IOMUXC_GPIO_DISP_B2_05_GPIO_MUX5_IO06 0x400E8228U, 0x5U, 0, 0, 0x400E846CU |
#define | IOMUXC_GPIO_DISP_B2_05_SRC_BT_CFG11 0x400E8228U, 0x6U, 0, 0, 0x400E846CU |
#define | IOMUXC_GPIO_DISP_B2_05_ENET_QOS_TX_CLK 0x400E8228U, 0x8U, 0x400E84A4U, 0x1U, 0x400E846CU |
#define | IOMUXC_GPIO_DISP_B2_06_GPIO11_IO07 0x400E822CU, 0xAU, 0, 0, 0x400E8470U |
#define | IOMUXC_GPIO_DISP_B2_06_VIDEO_MUX_LCDIF_DATA14 0x400E822CU, 0x0U, 0, 0, 0x400E8470U |
#define | IOMUXC_GPIO_DISP_B2_06_ENET_RX_DATA00 0x400E822CU, 0x1U, 0x400E84B0U, 0x1U, 0x400E8470U |
#define | IOMUXC_GPIO_DISP_B2_06_LPUART7_TXD 0x400E822CU, 0x2U, 0x400E8630U, 0x1U, 0x400E8470U |
#define | IOMUXC_GPIO_DISP_B2_06_ARM_TRACE_CLK 0x400E822CU, 0x3U, 0, 0, 0x400E8470U |
#define | IOMUXC_GPIO_DISP_B2_06_SAI1_RX_DATA00 0x400E822CU, 0x4U, 0x400E8674U, 0x1U, 0x400E8470U |
#define | IOMUXC_GPIO_DISP_B2_06_GPIO_MUX5_IO07 0x400E822CU, 0x5U, 0, 0, 0x400E8470U |
#define | IOMUXC_GPIO_DISP_B2_06_ENET_QOS_RX_DATA00 0x400E822CU, 0x8U, 0x400E84F0U, 0x1U, 0x400E8470U |
#define | IOMUXC_GPIO_DISP_B2_07_VIDEO_MUX_LCDIF_DATA15 0x400E8230U, 0x0U, 0, 0, 0x400E8474U |
#define | IOMUXC_GPIO_DISP_B2_07_ENET_RX_DATA01 0x400E8230U, 0x1U, 0x400E84B4U, 0x1U, 0x400E8474U |
#define | IOMUXC_GPIO_DISP_B2_07_LPUART7_RXD 0x400E8230U, 0x2U, 0x400E862CU, 0x1U, 0x400E8474U |
#define | IOMUXC_GPIO_DISP_B2_07_ARM_TRACE_SWO 0x400E8230U, 0x3U, 0, 0, 0x400E8474U |
#define | IOMUXC_GPIO_DISP_B2_07_SAI1_TX_DATA00 0x400E8230U, 0x4U, 0, 0, 0x400E8474U |
#define | IOMUXC_GPIO_DISP_B2_07_GPIO_MUX5_IO08 0x400E8230U, 0x5U, 0, 0, 0x400E8474U |
#define | IOMUXC_GPIO_DISP_B2_07_ENET_QOS_RX_DATA01 0x400E8230U, 0x8U, 0x400E84F4U, 0x1U, 0x400E8474U |
#define | IOMUXC_GPIO_DISP_B2_07_GPIO11_IO08 0x400E8230U, 0xAU, 0, 0, 0x400E8474U |
#define | IOMUXC_GPIO_DISP_B2_08_GPIO11_IO09 0x400E8234U, 0xAU, 0, 0, 0x400E8478U |
#define | IOMUXC_GPIO_DISP_B2_08_VIDEO_MUX_LCDIF_DATA16 0x400E8234U, 0x0U, 0, 0, 0x400E8478U |
#define | IOMUXC_GPIO_DISP_B2_08_ENET_RX_EN 0x400E8234U, 0x1U, 0x400E84B8U, 0x1U, 0x400E8478U |
#define | IOMUXC_GPIO_DISP_B2_08_LPUART8_TXD 0x400E8234U, 0x2U, 0x400E8638U, 0x1U, 0x400E8478U |
#define | IOMUXC_GPIO_DISP_B2_08_ARM_CM7_EVENTO 0x400E8234U, 0x3U, 0, 0, 0x400E8478U |
#define | IOMUXC_GPIO_DISP_B2_08_SAI1_TX_BCLK 0x400E8234U, 0x4U, 0x400E867CU, 0x1U, 0x400E8478U |
#define | IOMUXC_GPIO_DISP_B2_08_GPIO_MUX5_IO09 0x400E8234U, 0x5U, 0, 0, 0x400E8478U |
#define | IOMUXC_GPIO_DISP_B2_08_ENET_QOS_RX_EN 0x400E8234U, 0x8U, 0x400E84F8U, 0x1U, 0x400E8478U |
#define | IOMUXC_GPIO_DISP_B2_08_LPUART1_TXD 0x400E8234U, 0x9U, 0x400E8620U, 0x2U, 0x400E8478U |
#define | IOMUXC_GPIO_DISP_B2_09_GPIO11_IO10 0x400E8238U, 0xAU, 0, 0, 0x400E847CU |
#define | IOMUXC_GPIO_DISP_B2_09_VIDEO_MUX_LCDIF_DATA17 0x400E8238U, 0x0U, 0, 0, 0x400E847CU |
#define | IOMUXC_GPIO_DISP_B2_09_ENET_RX_ER 0x400E8238U, 0x1U, 0x400E84BCU, 0x1U, 0x400E847CU |
#define | IOMUXC_GPIO_DISP_B2_09_LPUART8_RXD 0x400E8238U, 0x2U, 0x400E8634U, 0x1U, 0x400E847CU |
#define | IOMUXC_GPIO_DISP_B2_09_ARM_CM7_EVENTI 0x400E8238U, 0x3U, 0, 0, 0x400E847CU |
#define | IOMUXC_GPIO_DISP_B2_09_SAI1_TX_SYNC 0x400E8238U, 0x4U, 0x400E8680U, 0x1U, 0x400E847CU |
#define | IOMUXC_GPIO_DISP_B2_09_GPIO_MUX5_IO10 0x400E8238U, 0x5U, 0, 0, 0x400E847CU |
#define | IOMUXC_GPIO_DISP_B2_09_ENET_QOS_RX_ER 0x400E8238U, 0x8U, 0x400E84FCU, 0x1U, 0x400E847CU |
#define | IOMUXC_GPIO_DISP_B2_09_LPUART1_RXD 0x400E8238U, 0x9U, 0x400E861CU, 0x2U, 0x400E847CU |
#define | IOMUXC_GPIO_DISP_B2_10_GPIO11_IO11 0x400E823CU, 0xAU, 0, 0, 0x400E8480U |
#define | IOMUXC_GPIO_DISP_B2_10_VIDEO_MUX_LCDIF_DATA18 0x400E823CU, 0x0U, 0, 0, 0x400E8480U |
#define | IOMUXC_GPIO_DISP_B2_10_EMVSIM2_IO 0x400E823CU, 0x1U, 0x400E86A8U, 0x1U, 0x400E8480U |
#define | IOMUXC_GPIO_DISP_B2_10_LPUART2_TXD 0x400E823CU, 0x2U, 0, 0, 0x400E8480U |
#define | IOMUXC_GPIO_DISP_B2_10_WDOG2_RESET_B_DEB 0x400E823CU, 0x3U, 0, 0, 0x400E8480U |
#define | IOMUXC_GPIO_DISP_B2_10_XBAR1_INOUT38 0x400E823CU, 0x4U, 0, 0, 0x400E8480U |
#define | IOMUXC_GPIO_DISP_B2_10_GPIO_MUX5_IO11 0x400E823CU, 0x5U, 0, 0, 0x400E8480U |
#define | IOMUXC_GPIO_DISP_B2_10_LPI2C3_SCL 0x400E823CU, 0x6U, 0x400E85BCU, 0x1U, 0x400E8480U |
#define | IOMUXC_GPIO_DISP_B2_10_ENET_QOS_RX_ER 0x400E823CU, 0x8U, 0x400E84FCU, 0x2U, 0x400E8480U |
#define | IOMUXC_GPIO_DISP_B2_10_SPDIF_IN 0x400E823CU, 0x9U, 0x400E86B4U, 0x2U, 0x400E8480U |
#define | IOMUXC_GPIO_DISP_B2_11_VIDEO_MUX_LCDIF_DATA19 0x400E8240U, 0x0U, 0, 0, 0x400E8484U |
#define | IOMUXC_GPIO_DISP_B2_11_EMVSIM2_CLK 0x400E8240U, 0x1U, 0, 0, 0x400E8484U |
#define | IOMUXC_GPIO_DISP_B2_11_LPUART2_RXD 0x400E8240U, 0x2U, 0, 0, 0x400E8484U |
#define | IOMUXC_GPIO_DISP_B2_11_WDOG1_RESET_B_DEB 0x400E8240U, 0x3U, 0, 0, 0x400E8484U |
#define | IOMUXC_GPIO_DISP_B2_11_XBAR1_INOUT39 0x400E8240U, 0x4U, 0, 0, 0x400E8484U |
#define | IOMUXC_GPIO_DISP_B2_11_GPIO_MUX5_IO12 0x400E8240U, 0x5U, 0, 0, 0x400E8484U |
#define | IOMUXC_GPIO_DISP_B2_11_LPI2C3_SDA 0x400E8240U, 0x6U, 0x400E85C0U, 0x1U, 0x400E8484U |
#define | IOMUXC_GPIO_DISP_B2_11_ENET_QOS_CRS 0x400E8240U, 0x8U, 0, 0, 0x400E8484U |
#define | IOMUXC_GPIO_DISP_B2_11_SPDIF_OUT 0x400E8240U, 0x9U, 0, 0, 0x400E8484U |
#define | IOMUXC_GPIO_DISP_B2_11_GPIO11_IO12 0x400E8240U, 0xAU, 0, 0, 0x400E8484U |
#define | IOMUXC_GPIO_DISP_B2_12_GPIO11_IO13 0x400E8244U, 0xAU, 0, 0, 0x400E8488U |
#define | IOMUXC_GPIO_DISP_B2_12_VIDEO_MUX_LCDIF_DATA20 0x400E8244U, 0x0U, 0, 0, 0x400E8488U |
#define | IOMUXC_GPIO_DISP_B2_12_EMVSIM2_RST 0x400E8244U, 0x1U, 0, 0, 0x400E8488U |
#define | IOMUXC_GPIO_DISP_B2_12_FLEXCAN1_TX 0x400E8244U, 0x2U, 0, 0, 0x400E8488U |
#define | IOMUXC_GPIO_DISP_B2_12_LPUART2_CTS_B 0x400E8244U, 0x3U, 0, 0, 0x400E8488U |
#define | IOMUXC_GPIO_DISP_B2_12_XBAR1_INOUT40 0x400E8244U, 0x4U, 0, 0, 0x400E8488U |
#define | IOMUXC_GPIO_DISP_B2_12_GPIO_MUX5_IO13 0x400E8244U, 0x5U, 0, 0, 0x400E8488U |
#define | IOMUXC_GPIO_DISP_B2_12_LPI2C4_SCL 0x400E8244U, 0x6U, 0x400E85C4U, 0x1U, 0x400E8488U |
#define | IOMUXC_GPIO_DISP_B2_12_ENET_QOS_COL 0x400E8244U, 0x8U, 0, 0, 0x400E8488U |
#define | IOMUXC_GPIO_DISP_B2_12_LPSPI4_SCK 0x400E8244U, 0x9U, 0x400E8610U, 0x1U, 0x400E8488U |
#define | IOMUXC_GPIO_DISP_B2_13_GPIO11_IO14 0x400E8248U, 0xAU, 0, 0, 0x400E848CU |
#define | IOMUXC_GPIO_DISP_B2_13_VIDEO_MUX_LCDIF_DATA21 0x400E8248U, 0x0U, 0, 0, 0x400E848CU |
#define | IOMUXC_GPIO_DISP_B2_13_EMVSIM2_SVEN 0x400E8248U, 0x1U, 0, 0, 0x400E848CU |
#define | IOMUXC_GPIO_DISP_B2_13_FLEXCAN1_RX 0x400E8248U, 0x2U, 0x400E8498U, 0x1U, 0x400E848CU |
#define | IOMUXC_GPIO_DISP_B2_13_LPUART2_RTS_B 0x400E8248U, 0x3U, 0, 0, 0x400E848CU |
#define | IOMUXC_GPIO_DISP_B2_13_ENET_REF_CLK 0x400E8248U, 0x4U, 0x400E84A8U, 0x2U, 0x400E848CU |
#define | IOMUXC_GPIO_DISP_B2_13_GPIO_MUX5_IO14 0x400E8248U, 0x5U, 0, 0, 0x400E848CU |
#define | IOMUXC_GPIO_DISP_B2_13_LPI2C4_SDA 0x400E8248U, 0x6U, 0x400E85C8U, 0x1U, 0x400E848CU |
#define | IOMUXC_GPIO_DISP_B2_13_ENET_QOS_1588_EVENT0_OUT 0x400E8248U, 0x8U, 0, 0, 0x400E848CU |
#define | IOMUXC_GPIO_DISP_B2_13_LPSPI4_SIN 0x400E8248U, 0x9U, 0x400E8614U, 0x1U, 0x400E848CU |
#define | IOMUXC_GPIO_DISP_B2_14_GPIO_MUX5_IO15 0x400E824CU, 0x5U, 0, 0, 0x400E8490U |
#define | IOMUXC_GPIO_DISP_B2_14_FLEXCAN1_TX 0x400E824CU, 0x6U, 0, 0, 0x400E8490U |
#define | IOMUXC_GPIO_DISP_B2_14_ENET_QOS_1588_EVENT0_IN 0x400E824CU, 0x8U, 0, 0, 0x400E8490U |
#define | IOMUXC_GPIO_DISP_B2_14_LPSPI4_SOUT 0x400E824CU, 0x9U, 0x400E8618U, 0x1U, 0x400E8490U |
#define | IOMUXC_GPIO_DISP_B2_14_GPIO11_IO15 0x400E824CU, 0xAU, 0, 0, 0x400E8490U |
#define | IOMUXC_GPIO_DISP_B2_14_VIDEO_MUX_LCDIF_DATA22 0x400E824CU, 0x0U, 0, 0, 0x400E8490U |
#define | IOMUXC_GPIO_DISP_B2_14_EMVSIM2_PD 0x400E824CU, 0x1U, 0x400E86ACU, 0x1U, 0x400E8490U |
#define | IOMUXC_GPIO_DISP_B2_14_WDOG2_B 0x400E824CU, 0x2U, 0, 0, 0x400E8490U |
#define | IOMUXC_GPIO_DISP_B2_14_VIDEO_MUX_EXT_DCIC1 0x400E824CU, 0x3U, 0, 0, 0x400E8490U |
#define | IOMUXC_GPIO_DISP_B2_14_ENET_1G_REF_CLK 0x400E824CU, 0x4U, 0x400E84C4U, 0x3U, 0x400E8490U |
#define | IOMUXC_GPIO_DISP_B2_15_VIDEO_MUX_LCDIF_DATA23 0x400E8250U, 0x0U, 0, 0, 0x400E8494U |
#define | IOMUXC_GPIO_DISP_B2_15_EMVSIM2_POWER_FAIL 0x400E8250U, 0x1U, 0x400E86B0U, 0x1U, 0x400E8494U |
#define | IOMUXC_GPIO_DISP_B2_15_WDOG1_B 0x400E8250U, 0x2U, 0, 0, 0x400E8494U |
#define | IOMUXC_GPIO_DISP_B2_15_VIDEO_MUX_EXT_DCIC2 0x400E8250U, 0x3U, 0, 0, 0x400E8494U |
#define | IOMUXC_GPIO_DISP_B2_15_PIT1_TRIGGER0 0x400E8250U, 0x4U, 0, 0, 0x400E8494U |
#define | IOMUXC_GPIO_DISP_B2_15_GPIO_MUX5_IO16 0x400E8250U, 0x5U, 0, 0, 0x400E8494U |
#define | IOMUXC_GPIO_DISP_B2_15_FLEXCAN1_RX 0x400E8250U, 0x6U, 0x400E8498U, 0x2U, 0x400E8494U |
#define | IOMUXC_GPIO_DISP_B2_15_ENET_QOS_1588_EVENT0_AUX_IN 0x400E8250U, 0x8U, 0, 0, 0x400E8494U |
#define | IOMUXC_GPIO_DISP_B2_15_LPSPI4_PCS0 0x400E8250U, 0x9U, 0x400E860CU, 0x1U, 0x400E8494U |
#define | IOMUXC_GPIO_DISP_B2_15_GPIO11_IO16 0x400E8250U, 0xAU, 0, 0, 0x400E8494U |
#define | IOMUXC_GPR_SAIMCLK_LOWBITMASK (0x7U) |
#define | IOMUXC_GPR_SAIMCLK_HIGHBITMASK (0x3U) |
