RTEMS 6.1-rc1
The DMA controller can handle the transfer between peripherals and memory and so receives the triggers from the peripherals. The hardware interface number are getting from DMAIF_Get_ChannelNumber().
DMAIF_IsValidatedPeripherOnDma() helps to check if the given DMAC has associated peripheral identifier coded by the given peripheral.
