RTEMS 6.1-rc1
This general purpose validation test suite provides enough resources to run basic tests for all specified managers and functions. More...
Modules | |
spec:/acfg/val/appl-needs-clock-driver | |
Tests the effect of the CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER application configuration option. | |
spec:/rtems/event/req/send-receive | |
spec:/rtems/event/val/send-receive | |
Tests the rtems_event_send() and rtems_event_receive() directives. | |
spec:/rtems/event/val/system-send-receive | |
Tests the rtems_event_system_send() and rtems_event_system_receive() directives. | |
spec:/score/thread/val/idle-body-no-return | |
Tests thread idle body behaviour. | |
Files | |
file | ts-validation-0.c |
#define | CONFIGURE_MAXIMUM_PROCESSORS 5 |
const char | rtems_test_name [] = "TestsuitesValidation0" |
Each test must define a test name string. | |
In SMP configurations, up to three scheduler instances using the SMP EDF scheduler are provided using up to four processors.
