RTEMS 6.1-rc1
Modules | Files | Macros | Variables
spec:/testsuites/performance-no-clock-0
This general purpose performance test suite provides enough resources to run basic performance tests for all specified managers and functions. More...
 spec:/rtems/barrier/val/perf
 This test case provides a context to run Barrier Manager performance tests.
 spec:/rtems/event/val/perf
 This test case provides a context to run Event Manager performance tests.
 spec:/rtems/message/val/perf
 This test case provides a context to run Message Manager performance tests.
 spec:/rtems/part/val/perf
 This test case provides a context to run Partition Manager performance tests.
 spec:/rtems/sem/val/perf
 This test case provides a context to run Semaphore Manager performance tests.
 spec:/rtems/task/val/perf
 This test case provides a context to run Task Manager performance tests.
 spec:/score/cpu/val/perf
 This test case provides a context to run CPU port performance tests.
file  ts-performance-no-clock-0.c
#define CONFIGURE_MAXIMUM_PROCESSORS   4
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
const char rtems_test_name [] = "TestsuitesPerformanceNoClock0"
 Each test must define a test name string.
In SMP configurations, up to three scheduler instances using the SMP EDF scheduler are provided using up to four processors.
