RTEMS 6.1-rc1
This validation test suite contains a test case which triggers a fatal error during system initialization. More...
Modules | |
spec:/score/smp/val/fatal-mandatory-processor-not-present | |
Tests a fatal error. | |
Files | |
file | ts-fatal-mandatory-processor-not-present.c |
#define | FATAL_SYSINIT_RUN ScoreSmpValFatalMandatoryProcessorNotPresent_Run |
#define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
#define | CONFIGURE_MAXIMUM_PROCESSORS 32 |
#define | CONFIGURE_SCHEDULER_EDF_SMP |
#define | CONFIGURE_SCHEDULER_TABLE_ENTRIES RTEMS_SCHEDULER_TABLE_EDF_SMP( a, TEST_SCHEDULER_A_NAME ) |
#define | CONFIGURE_SCHEDULER_ASSIGNMENTS |
RTEMS_SCHEDULER_EDF_SMP (a) | |
const char | rtems_test_name [] = "TestsuitesFatalMandatoryProcessorNotPresent" |
Each test must define a test name string. | |
