RTEMS 6.1-rc1
This group contains the Scheduler Manager implementation. More...
Files | |
file | scheduler.h |
This header file defines the main parts of the Scheduler Manager API. | |
file | scheduleraddprocessor.c |
This source file contains the implementation of rtems_scheduler_add_processor(). | |
file | schedulergetmaxprio.c |
This source file contains the implementation of rtems_scheduler_get_maximum_priority(). | |
file | schedulergetprocessor.c |
This source file contains the implementation of rtems_scheduler_get_processor() which may be used by binding for languages other than C/C++. | |
file | schedulergetprocessormax.c |
This source file contains the implementation of rtems_scheduler_get_processor_maximum() which may be used by binding for languages other than C/C++. | |
file | schedulergetprocessorset.c |
This source file contains the implementation of rtems_scheduler_get_processor_set(). | |
file | schedulerident.c |
This source file contains the implementation of rtems_scheduler_ident(). | |
file | scheduleridentbyprocessor.c |
This source file contains the implementation of rtems_scheduler_ident_by_processor(). | |
file | scheduleridentbyprocessorset.c |
This source file contains the implementation of rtems_scheduler_ident_by_processor_set(). | |
file | schedulermapfromposix.c |
This source file contains the implementation of rtems_scheduler_map_priority_from_posix(). | |
file | schedulermaptoposix.c |
This source file contains the implementation of rtems_scheduler_map_priority_to_posix(). | |
file | schedulerremoveprocessor.c |
This source file contains the implementation of rtems_scheduler_remove_processor(). | |
