RTEMS 6.1-rc1
This group contains the GPTIMER interfaces. More...
Modules | |
Configuration register (CONFIG) | |
This group contains register bit definitions. | |
GPTIMER TIMER | |
This group contains the GPTIMER TIMER interfaces. | |
Scaler reload value register (SRELOAD) | |
Scaler value register (SCALER) | |
Timer latch configuration register (LATCHCFG) | |
Files | |
file | gptimer-regs.h |
This header file defines the GPTIMER register block interface. | |
struct | gptimer |
This structure defines the GPTIMER register block memory map. More... | |
Typedefs | |
typedef struct gptimer | gptimer |
This structure defines the GPTIMER register block memory map. | |
