RTEMS 6.1-rc1
This group contains the GRIOMMU interfaces. More...
Modules | |
AHB failing access register (AHBFAS) | |
This group contains register bit definitions. | |
ASMP access control registers 0 - 3 (ASMPCTRL) | |
Capability register 0 (CAP0) | |
Capability register 1 (CAP1) | |
Capability register 2 (CAP2) | |
Control register (CTRL) | |
Data RAM error injection register (DERRI) | |
Diagnostic cache access data register 0 - 7 (DIAGD) | |
Diagnostic cache access register (DIAGCTRL) | |
Diagnostic cache access tag register (DIAGT) | |
Group control register 0 - 7 (GRPCTRL) | |
Interrupt mask register (IMASK) | |
Master configuration register 0 - 9 (MSTCFG) | |
Status register (STATUS) | |
TLB/cache flush register (FLUSH) | |
Tag RAM error injection register (TERRI) | |
Files | |
file | griommu-regs.h |
This header file defines the GRIOMMU register block interface. | |
struct | griommu |
This structure defines the GRIOMMU register block memory map. More... | |
Typedefs | |
typedef struct griommu | griommu |
This structure defines the GRIOMMU register block memory map. | |
