RTEMS 6.1-rc1
 AHB Bus Matrix
 Advanced Encryption Standard
 Analog Comparator Controller
 Analog Front-End Controller
 Chip Identifier
 Controller Area Network
 Digital-to-Analog Converter Controller
 Embedded Flash Controller
 Extensible DMA Controller
 General Purpose Backup Registers
 Gigabit Ethernet MAC
 High Speed MultiMedia Card Interface
 Image Sensor Interface
 Integrity Check Monitor
 Parallel Input/Output Controller
 Power Management Controller
 Pulse Width Modulation Controller
 Quad Serial Peripheral Interface
 Real-time Clock
 Real-time Timer
 Reinforced Safety Watchdog Timer
 Reset Controller
 SAME70J19 definitions
 SAME70J20 definitions
 SAME70J21 definitions
 SAME70N19 definitions
 SAME70N20 definitions
 SAME70N21 definitions
 SAME70Q19 definitions
 SAME70Q20 definitions
 SAME70Q21 definitions
 SDRAM Controller
 Static Memory Controller
 Supply Controller
 Synchronous Serial Controller
 Timer Counter
 True Random Number Generator
 Two-wire Interface High Speed
 USB High-Speed Interface
 USB Transmitter Interface Macrocell
 Universal Asynchronous Receiver Transmitter
 Universal Synchronous Asynchronous Receiver Transmitter
 Watchdog Timer
