RTEMS 6.1-rc1
HAL ADC Aliased Macros maintained for legacy purpose
#define __ADC_ENABLE   __HAL_ADC_ENABLE
#define __ADC_DISABLE   __HAL_ADC_DISABLE
#define __HAL_ADC_ENABLING_CONDITIONS   ADC_ENABLING_CONDITIONS
#define __HAL_ADC_DISABLING_CONDITIONS   ADC_DISABLING_CONDITIONS
#define __HAL_ADC_IS_ENABLED   ADC_IS_ENABLE
#define __ADC_IS_ENABLED   ADC_IS_ENABLE
#define __HAL_ADC_IS_SOFTWARE_START_REGULAR   ADC_IS_SOFTWARE_START_REGULAR
#define __HAL_ADC_IS_SOFTWARE_START_INJECTED   ADC_IS_SOFTWARE_START_INJECTED
#define __HAL_ADC_IS_CONVERSION_ONGOING_REGULAR_INJECTED   ADC_IS_CONVERSION_ONGOING_REGULAR_INJECTED
#define __HAL_ADC_IS_CONVERSION_ONGOING_REGULAR   ADC_IS_CONVERSION_ONGOING_REGULAR
#define __HAL_ADC_IS_CONVERSION_ONGOING_INJECTED   ADC_IS_CONVERSION_ONGOING_INJECTED
#define __HAL_ADC_IS_CONVERSION_ONGOING   ADC_IS_CONVERSION_ONGOING
#define __HAL_ADC_CLEAR_ERRORCODE   ADC_CLEAR_ERRORCODE
#define __HAL_ADC_GET_RESOLUTION   ADC_GET_RESOLUTION
#define __HAL_ADC_JSQR_RK   ADC_JSQR_RK
#define __HAL_ADC_CFGR_AWD1CH   ADC_CFGR_AWD1CH_SHIFT
#define __HAL_ADC_CFGR_AWD23CR   ADC_CFGR_AWD23CR
#define __HAL_ADC_CFGR_INJECT_AUTO_CONVERSION   ADC_CFGR_INJECT_AUTO_CONVERSION
#define __HAL_ADC_CFGR_INJECT_CONTEXT_QUEUE   ADC_CFGR_INJECT_CONTEXT_QUEUE
#define __HAL_ADC_CFGR_INJECT_DISCCONTINUOUS   ADC_CFGR_INJECT_DISCCONTINUOUS
#define __HAL_ADC_CFGR_REG_DISCCONTINUOUS   ADC_CFGR_REG_DISCCONTINUOUS
#define __HAL_ADC_CFGR_DISCONTINUOUS_NUM   ADC_CFGR_DISCONTINUOUS_NUM
#define __HAL_ADC_CFGR_AUTOWAIT   ADC_CFGR_AUTOWAIT
#define __HAL_ADC_CFGR_CONTINUOUS   ADC_CFGR_CONTINUOUS
#define __HAL_ADC_CFGR_OVERRUN   ADC_CFGR_OVERRUN
#define __HAL_ADC_CFGR_DMACONTREQ   ADC_CFGR_DMACONTREQ
#define __HAL_ADC_CFGR_EXTSEL   ADC_CFGR_EXTSEL_SET
#define __HAL_ADC_JSQR_JEXTSEL   ADC_JSQR_JEXTSEL_SET
#define __HAL_ADC_OFR_CHANNEL   ADC_OFR_CHANNEL
#define __HAL_ADC_DIFSEL_CHANNEL   ADC_DIFSEL_CHANNEL
#define __HAL_ADC_CALFACT_DIFF_SET   ADC_CALFACT_DIFF_SET
#define __HAL_ADC_CALFACT_DIFF_GET   ADC_CALFACT_DIFF_GET
#define __HAL_ADC_TRX_HIGHTHRESHOLD   ADC_TRX_HIGHTHRESHOLD
#define __HAL_ADC_OFFSET_SHIFT_RESOLUTION   ADC_OFFSET_SHIFT_RESOLUTION
#define __HAL_ADC_AWD1THRESHOLD_SHIFT_RESOLUTION   ADC_AWD1THRESHOLD_SHIFT_RESOLUTION
#define __HAL_ADC_AWD23THRESHOLD_SHIFT_RESOLUTION   ADC_AWD23THRESHOLD_SHIFT_RESOLUTION
#define __HAL_ADC_COMMON_REGISTER   ADC_COMMON_REGISTER
#define __HAL_ADC_COMMON_CCR_MULTI   ADC_COMMON_CCR_MULTI
#define __HAL_ADC_MULTIMODE_IS_ENABLED   ADC_MULTIMODE_IS_ENABLE
#define __ADC_MULTIMODE_IS_ENABLED   ADC_MULTIMODE_IS_ENABLE
#define __HAL_ADC_NONMULTIMODE_OR_MULTIMODEMASTER   ADC_NONMULTIMODE_OR_MULTIMODEMASTER
#define __HAL_ADC_COMMON_ADC_OTHER   ADC_COMMON_ADC_OTHER
#define __HAL_ADC_MULTI_SLAVE   ADC_MULTI_SLAVE
#define __HAL_ADC_SQR1_L   ADC_SQR1_L_SHIFT
#define __HAL_ADC_JSQR_JL   ADC_JSQR_JL_SHIFT
#define __HAL_ADC_JSQR_RK_JL   ADC_JSQR_RK_JL
#define __HAL_ADC_CR1_DISCONTINUOUS_NUM   ADC_CR1_DISCONTINUOUS_NUM
#define __HAL_ADC_CR1_SCAN   ADC_CR1_SCAN_SET
#define __HAL_ADC_CONVCYCLES_MAX_RANGE   ADC_CONVCYCLES_MAX_RANGE
#define __HAL_ADC_CLOCK_PRESCALER_RANGE   ADC_CLOCK_PRESCALER_RANGE
#define __HAL_ADC_GET_CLOCK_PRESCALER   ADC_GET_CLOCK_PRESCALER
#define __HAL_ADC_SQR1   ADC_SQR1
#define __HAL_ADC_SMPR1   ADC_SMPR1
#define __HAL_ADC_SMPR2   ADC_SMPR2
#define __HAL_ADC_SQR3_RK   ADC_SQR3_RK
#define __HAL_ADC_SQR2_RK   ADC_SQR2_RK
#define __HAL_ADC_SQR1_RK   ADC_SQR1_RK
#define __HAL_ADC_CR2_CONTINUOUS   ADC_CR2_CONTINUOUS
#define __HAL_ADC_CR1_DISCONTINUOUS   ADC_CR1_DISCONTINUOUS
#define __HAL_ADC_CR1_SCANCONV   ADC_CR1_SCANCONV
#define __HAL_ADC_CR2_EOCSelection   ADC_CR2_EOCSelection
#define __HAL_ADC_CR2_DMAContReq   ADC_CR2_DMAContReq
#define __HAL_ADC_JSQR   ADC_JSQR
#define __HAL_ADC_CHSELR_CHANNEL   ADC_CHSELR_CHANNEL
#define __HAL_ADC_CFGR1_REG_DISCCONTINUOUS   ADC_CFGR1_REG_DISCCONTINUOUS
#define __HAL_ADC_CFGR1_AUTOOFF   ADC_CFGR1_AUTOOFF
#define __HAL_ADC_CFGR1_AUTOWAIT   ADC_CFGR1_AUTOWAIT
#define __HAL_ADC_CFGR1_CONTINUOUS   ADC_CFGR1_CONTINUOUS
#define __HAL_ADC_CFGR1_OVERRUN   ADC_CFGR1_OVERRUN
#define __HAL_ADC_CFGR1_SCANDIR   ADC_CFGR1_SCANDIR
#define __HAL_ADC_CFGR1_DMACONTREQ   ADC_CFGR1_DMACONTREQ
