RTEMS
6.1-rc1
bsps
include
grlib
grlib.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
9
10
* COPYRIGHT (c) 2012
11
* Aeroflex Gaisler
12
13
14
* modification, are permitted provided that the following conditions
15
* are met:
16
* 1. Redistributions of source code must retain the above copyright
17
* notice, this list of conditions and the following disclaimer.
18
* 2. Redistributions in binary form must reproduce the above copyright
19
* notice, this list of conditions and the following disclaimer in the
20
* documentation and/or other materials provided with the distribution.
21
22
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
23
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
24
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
25
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
26
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
27
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
28
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
29
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
30
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
31
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
32
* POSSIBILITY OF SUCH DAMAGE.
33
34
35
#ifndef __GRLIB_H__
36
#define __GRLIB_H__
37
38
#include <stdbool.h>
39
40
#ifdef __cplusplus
41
extern
"C"
42
#endif
43
52
/* ESA MEMORY CONTROLLER */
53
struct
mctrl_regs
54
unsigned
int
mcfg1;
55
unsigned
int
mcfg2;
56
unsigned
int
mcfg3;
57
58
59
/* APB UART */
60
struct
apbuart_regs
61
volatile
unsigned
int
data;
62
volatile
unsigned
int
status;
63
volatile
unsigned
int
ctrl;
64
volatile
unsigned
int
scaler;
65
66
67
/* IRQMP and IRQAMP interrupt controller timestamps */
68
struct
irqmp_timestamp_regs
69
volatile
unsigned
int
counter;
/* 0x00 */
70
volatile
unsigned
int
control
/* 0x04 */
71
volatile
unsigned
int
assertion;
/* 0x08 */
72
volatile
unsigned
int
ack;
/* 0x0c */
73
74
75
static
inline
bool
irqmp_has_timestamp(
76
volatile
struct
*irqmp_ts
77
78
79
return
(irqmp_ts->control >> 27) > 0;
80
81
82
/* IRQMP and IRQAMP interrupt controllers */
83
struct
irqmp_regs
84
volatile
unsigned
int
ilevel;
/* 0x00 */
85
volatile
unsigned
int
ipend;
/* 0x04 */
86
volatile
unsigned
int
iforce;
/* 0x08 */
87
volatile
unsigned
int
iclear;
/* 0x0c */
88
volatile
unsigned
int
mpstat;
/* 0x10 */
89
volatile
unsigned
int
bcast;
/* 0x14 */
90
volatile
unsigned
int
notused02;
/* 0x18 */
91
volatile
unsigned
int
wdgctrl;
/* 0x1c */
92
volatile
unsigned
int
ampctrl;
/* 0x20 */
93
volatile
unsigned
int
icsel[2];
/* 0x24,0x28 */
94
volatile
unsigned
int
notused13;
/* 0x2c */
95
volatile
unsigned
int
notused20;
/* 0x30 */
96
volatile
unsigned
int
notused21;
/* 0x34 */
97
volatile
unsigned
int
notused22;
/* 0x38 */
98
volatile
unsigned
int
notused23;
/* 0x3c */
99
volatile
unsigned
int
mask[16];
/* 0x40 */
100
volatile
unsigned
int
force[16];
/* 0x80 */
101
/* Extended IRQ registers */
102
volatile
unsigned
int
intid[16];
/* 0xc0 */
103
volatile
struct
timestamp[16];
/* 0x100 */
104
volatile
unsigned
int
resetaddr[4];
/* 0x200 */
105
volatile
unsigned
int
resv0[12];
/* 0x210 - 0x23C */
106
volatile
unsigned
int
pboot;
/* 0x240 */
107
volatile
unsigned
int
resv1[47];
/* 0x244 - 0x2FC */
108
volatile
unsigned
int
irqmap[8];
/* 0x300 - 0x31C */
109
volatile
unsigned
int
resv2[824];
/* 0x320 - 0x1000 */
110
111
112
/* GPTIMER Timer instance */
113
struct
gptimer_timer_regs
114
volatile
unsigned
int
value;
115
volatile
unsigned
int
reload;
116
volatile
unsigned
int
ctrl;
117
volatile
unsigned
int
notused;
118
119
120
#define GPTIMER_TIMER_CTRL_EN 0x00000001U
121
#define GPTIMER_TIMER_CTRL_RS 0x00000002U
122
#define GPTIMER_TIMER_CTRL_LD 0x00000004U
123
#define GPTIMER_TIMER_CTRL_IE 0x00000008U
124
#define GPTIMER_TIMER_CTRL_IP 0x00000010U
125
#define GPTIMER_TIMER_CTRL_CH 0x00000020U
126
#define GPTIMER_TIMER_CTRL_DH 0x00000040U
127
128
/* GPTIMER common registers */
129
struct
gptimer_regs
130
volatile
unsigned
int
scaler_value;
/* common timer registers */
131
volatile
unsigned
int
scaler_reload;
132
volatile
unsigned
int
cfg;
133
volatile
unsigned
int
notused;
134
struct
gptimer_timer_regs
timer[7];
135
136
137
/* GRGPIO GPIO */
138
struct
grgpio_regs
139
volatile
unsigned
int
data;
/* 0x00 I/O port data register */
140
volatile
unsigned
int
output;
/* 0x04 I/O port output register */
141
volatile
unsigned
int
dir;
/* 0x08 I/O port direction register */
142
volatile
unsigned
int
imask;
/* 0x0C Interrupt mask register */
143
volatile
unsigned
int
ipol;
/* 0x10 Interrupt polarity register */
144
volatile
unsigned
int
iedge;
/* 0x14 Interrupt edge register */
145
volatile
unsigned
int
bypass;
/* 0x18 Bypass register */
146
volatile
unsigned
int
cap;
/* 0x1C Capability register */
147
volatile
unsigned
int
irqmap[4];
/* 0x20 - 0x2C Interrupt map registers */
148
volatile
unsigned
int
res_30;
/* 0x30 Reserved */
149
volatile
unsigned
int
res_34;
/* 0x34 Reserved */
150
volatile
unsigned
int
res_38;
/* 0x38 Reserved */
151
volatile
unsigned
int
res_3C;
/* 0x3C Reserved */
152
volatile
unsigned
int
iavail;
/* 0x40 Interrupt available register */
153
volatile
unsigned
int
iflag;
/* 0x44 Interrupt flag register */
154
volatile
unsigned
int
res_48;
/* 0x48 Reserved */
155
volatile
unsigned
int
pulse;
/* 0x4C Pulse register */
156
volatile
unsigned
int
res_50;
/* 0x50 Reserved */
157
volatile
unsigned
int
output_or;
/* 0x54 I/O port output register, logical-OR */
158
volatile
unsigned
int
dir_or;
/* 0x58 I/O port direction register, logical-OR */
159
volatile
unsigned
int
imask_or;
/* 0x5C Interrupt mask register, logical-OR */
160
volatile
unsigned
int
res_60;
/* 0x60 Reserved */
161
volatile
unsigned
int
output_and;
/* 0x64 I/O port output register, logical-AND */
162
volatile
unsigned
int
dir_and;
/* 0x68 I/O port direction register, logical-AND */
163
volatile
unsigned
int
imask_and;
/* 0x6C Interrupt mask register, logical-AND */
164
volatile
unsigned
int
res_70;
/* 0x70 Reserved */
165
volatile
unsigned
int
output_xor;
/* 0x74 I/O port output register, logical-XOR */
166
volatile
unsigned
int
dir_xor;
/* 0x78 I/O port direction register, logical-XOR */
167
volatile
unsigned
int
imask_xor;
/* 0x7C Interrupt mask register, logical-XOR */
168
169
170
/* L2C - Level 2 Cache Controller registers */
171
struct
l2c_regs
172
volatile
unsigned
int
control
/* 0x00 Control register */
173
volatile
unsigned
int
status;
/* 0x04 Status register */
174
volatile
unsigned
int
flush_mem_addr;
/* 0x08 Flush (Memory address) */
175
volatile
unsigned
int
flush_set_index;
/* 0x0c Flush (set, index) */
176
volatile
unsigned
int
access_counter;
/* 0x10 */
177
volatile
unsigned
int
hit_counter;
/* 0x14 */
178
volatile
unsigned
int
bus_cycle_counter;
/* 0x18 */
179
volatile
unsigned
int
bus_usage_counter;
/* 0x1c */
180
volatile
unsigned
int
error_status_control;
/* 0x20 Error status/control */
181
volatile
unsigned
int
error_addr;
/* 0x24 Error address */
182
volatile
unsigned
int
tag_check_bit;
/* 0x28 TAG-check-bit */
183
volatile
unsigned
int
data_check_bit;
/* 0x2c Data-check-bit */
184
volatile
unsigned
int
scrub_control_status;
/* 0x30 Scrub Control/Status */
185
volatile
unsigned
int
scrub_delay;
/* 0x34 Scrub Delay */
186
volatile
unsigned
int
error_injection;
/* 0x38 Error injection */
187
volatile
unsigned
int
access_control;
/* 0x3c Access control */
188
volatile
unsigned
int
reserved_40[16];
/* 0x40 Reserved */
189
volatile
unsigned
int
mtrr[32];
/* 0x80 - 0xFC MTRR registers */
190
volatile
unsigned
int
reserved_100[131008];
/* 0x100 Reserved */
191
volatile
unsigned
int
diag_iface_tag[16384];
/* 0x80000 - 0x8FFFC Diagnostic interface (Tag) */
192
volatile
unsigned
int
reserved_90000[376832];
/* 0x90000 Reserved */
193
volatile
unsigned
int
diag_iface_data[524288];
/* 0x200000 - 0x3FFFFC Diagnostic interface (Data) */
194
195
196
#ifdef __cplusplus
197
198
#endif
199
200
#endif
apbuart_regs
Definition:
grlib.h:60
control
Definition:
intercom.c:87
gptimer_regs
Definition:
grlib.h:129
gptimer_timer_regs
Definition:
grlib.h:113
grgpio_regs
Definition:
grlib.h:138
irqmp_regs
Definition:
grlib.h:83
Definition:
grlib.h:68
l2c_regs
Definition:
grlib.h:171
mctrl_regs
Definition:
grlib.h:53
