RTEMS 6.1-rc1
This header file defines the GRCLKGATE register block interface. More...
#include <stdint.h>
struct | grclkgate |
This structure defines the GRCLKGATE register block memory map. More... | |
#define | GRCLKGATE_UNLOCK_UNLOCK_SHIFT 0 |
#define | GRCLKGATE_UNLOCK_UNLOCK_MASK 0xffffffffU |
#define | GRCLKGATE_UNLOCK_UNLOCK_GET(_reg) |
#define | GRCLKGATE_UNLOCK_UNLOCK_SET(_reg, _val) |
#define | GRCLKGATE_UNLOCK_UNLOCK(_val) |
#define | GRCLKGATE_CLKEN_ENABLE_SHIFT 0 |
#define | GRCLKGATE_CLKEN_ENABLE_MASK 0xffffffffU |
#define | GRCLKGATE_CLKEN_ENABLE_GET(_reg) |
#define | GRCLKGATE_CLKEN_ENABLE_SET(_reg, _val) |
#define | GRCLKGATE_CLKEN_ENABLE(_val) |
#define | GRCLKGATE_RESET_RESET_SHIFT 0 |
#define | GRCLKGATE_RESET_RESET_MASK 0xffffffffU |
#define | GRCLKGATE_RESET_RESET_GET(_reg) |
#define | GRCLKGATE_RESET_RESET_SET(_reg, _val) |
#define | GRCLKGATE_RESET_RESET(_val) |
#define | GRCLKGATE_OVERRIDE_FOVERRIDE_SHIFT 16 |
#define | GRCLKGATE_OVERRIDE_FOVERRIDE_MASK 0xf0000U |
#define | GRCLKGATE_OVERRIDE_FOVERRIDE_GET(_reg) |
#define | GRCLKGATE_OVERRIDE_FOVERRIDE_SET(_reg, _val) |
#define | GRCLKGATE_OVERRIDE_FOVERRIDE(_val) |
#define | GRCLKGATE_OVERRIDE_OVERRIDE_SHIFT 0 |
#define | GRCLKGATE_OVERRIDE_OVERRIDE_MASK 0xfU |
#define | GRCLKGATE_OVERRIDE_OVERRIDE_GET(_reg) |
#define | GRCLKGATE_OVERRIDE_OVERRIDE_SET(_reg, _val) |
#define | GRCLKGATE_OVERRIDE_OVERRIDE(_val) |
Typedefs | |
typedef struct grclkgate | grclkgate |
This structure defines the GRCLKGATE register block memory map. | |
