RTEMS 6.1-rc1
gr_tmtc_1553.h
2
3/* GR-TMTC-1553 PCI Target driver.
4 *
5 * COPYRIGHT (c) 2010.
6 * Cobham Gaisler AB.
7 *
8 * Configures the GR-TMTC-1553 interface PCI board.
9 * This driver provides a AMBA PnP bus by using the general part
10 * of the AMBA PnP bus driver (ambapp_bus.c).
11 *
12 * Driver resources for the AMBA PnP bus provided can be set using
13 * gr_tmtc_1553_set_resources().
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef __GR_TMTC_1553_H__
38#define __GR_TMTC_1553_H__
39
40#include <drvmgr/drvmgr.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif
45
46/* An array of pointers to GR-TMTC-1553 resources. The resources will be
47 * used by the drivers controlling the cores on the GR-TMTC-1553 target AMBA bus.
48 *
49 * The gr_rasta_io_resources is declared weak so that the user can override the
50 * default configuration. The array must be terminated with a NULL resource.
51 */
52extern struct drvmgr_bus_res *gr_tmtc_1553_resources[];
53
54/* Options to gr_rasta_io_print function */
55#define TMTC_1553_OPTIONS_AMBA 0x01 /* Print AMBA bus devices */
56#define TMTC_1553_OPTIONS_IRQ 0x02 /* Print current IRQ setup */
57
58/* Print information about GR-RASTA-IO PCI board */
59void gr_tmtc_1553_print(int options);
60
61/* Register GR-RASTA-IO driver */
62void gr_tmtc_1553_register_drv(void);
63
64/* Print information about all GR-TMTC-1553 devices registered to this driver */
65void gr_tmtc_1553_print(int options);
66
67/* Print information about one GR-TMTC-1553 device */
68void gr_tmtc_1553_print_dev(struct drvmgr_dev *dev, int options);
69
70#ifdef __cplusplus
71}
72#endif
73
74#endif
Driver Manager Interface.
Definition: drvmgr.h:238
Definition: drvmgr.h:297
