12#include "fsl_common.h"
23#define FSL_XBARB_DRIVER_VERSION (MAKE_VERSION(2, 0, 2))
26#define XBARB_SELx(base, output) (((volatile uint16_t *)(&((base)->SEL0)))[(uint32_t)(output) / 2UL])
28#define XBARB_WR_SELx_SELx(base, input, output) XBARB_SetSignalsConnection((base), (input), (output))
34#if defined(__cplusplus)
74#if defined(__cplusplus)
void XBARB_SetSignalsConnection(XBARB_Type *base, xbar_input_signal_t input, xbar_output_signal_t output)
Configures a connection between the selected XBARB_IN[*] input and the XBARB_OUT[*] output signal.
Definition: fsl_xbarb.c:113
void XBARB_Deinit(XBARB_Type *base)
Shuts down the XBARB module.
Definition: fsl_xbarb.c:94
void XBARB_Init(XBARB_Type *base)
Initializes the XBARB module.
Definition: fsl_xbarb.c:79
Definition: MIMXRT1052.h:52224
