8#ifndef _FSL_LPSPI_EDMA_H_
9#define _FSL_LPSPI_EDMA_H_
25#define FSL_LPSPI_EDMA_DRIVER_VERSION (MAKE_VERSION(2, 3, 1))
154#if defined(__cplusplus)
295#if defined(__cplusplus)
int32_t status_t
Type used for all status and error return values.
Definition: fsl_common.h:225
status_t LPSPI_MasterTransferGetCountEDMA(LPSPI_Type *base, lpspi_master_edma_handle_t *handle, size_t *count)
Gets the master eDMA transfer remaining bytes.
Definition: fsl_lpspi_edma.c:594
volatile bool isByteSwap
Definition: fsl_lpspi_edma.h:111
edma_handle_t * edmaTxDataToTxRegHandle
Definition: fsl_lpspi_edma.h:146
edma_tcd_t lpspiSoftwareTCD[3]
Definition: fsl_lpspi_edma.h:105
uint8_t nbytes
Definition: fsl_lpspi_edma.h:123
lpspi_master_edma_transfer_callback_t callback
Definition: fsl_lpspi_edma.h:99
void LPSPI_MasterTransferCreateHandleEDMA(LPSPI_Type *base, lpspi_master_edma_handle_t *handle, lpspi_master_edma_transfer_callback_t callback, void *userData, edma_handle_t *edmaRxRegToRxDataHandle, edma_handle_t *edmaTxDataToTxRegHandle)
Initializes the LPSPI master eDMA handle.
Definition: fsl_lpspi_edma.c:149
volatile uint8_t fifoSize
Definition: fsl_lpspi_edma.h:70
uint32_t txBuffIfNull
Definition: fsl_lpspi_edma.h:135
volatile uint8_t state
Definition: fsl_lpspi_edma.h:95
Definition: fsl_lpspi_edma.h:90
volatile uint8_t bytesEachWrite
Definition: fsl_lpspi_edma.h:74
volatile uint8_t bytesEachRead
Definition: fsl_lpspi_edma.h:118
Definition: fsl_lpspi_edma.h:68
edma_tcd_t lpspiSoftwareTCD[2]
Definition: fsl_lpspi_edma.h:148
edma_handle_t * edmaRxRegToRxDataHandle
Definition: fsl_lpspi_edma.h:145
volatile uint32_t readRegRemainingTimes
Definition: fsl_lpspi_edma.h:86
void(* lpspi_master_edma_transfer_callback_t)(LPSPI_Type *base, lpspi_master_edma_handle_t *handle, status_t status, void *userData)
Completion callback function pointer type.
Definition: fsl_lpspi_edma.h:46
volatile uint32_t writeRegRemainingTimes
Definition: fsl_lpspi_edma.h:85
uint8_t *volatile txData
Definition: fsl_lpspi_edma.h:80
uint32_t rxBuffIfNull
Definition: fsl_lpspi_edma.h:136
uint8_t *volatile rxData
Definition: fsl_lpspi_edma.h:126
uint32_t transmitCommand
Definition: fsl_lpspi_edma.h:93
void * userData
Definition: fsl_lpspi_edma.h:143
void LPSPI_SlaveTransferAbortEDMA(LPSPI_Type *base, lpspi_slave_edma_handle_t *handle)
LPSPI slave aborts a transfer which is using eDMA.
Definition: fsl_lpspi_edma.c:1005
volatile uint8_t bytesLastRead
Definition: fsl_lpspi_edma.h:77
Definition: fsl_lpspi_edma.h:138
volatile uint8_t rxWatermark
Definition: fsl_lpspi_edma.h:115
Definition: fsl_lpspi_edma.h:125
Definition: fsl_lpspi_edma.h:117
volatile size_t rxRemainingByteCount
Definition: fsl_lpspi_edma.h:83
Definition: fsl_lpspi_edma.h:72
lpspi_slave_edma_transfer_callback_t callback
Definition: fsl_lpspi_edma.h:142
uint32_t errorCount
Definition: fsl_lpspi_edma.h:140
Definition: fsl_lpspi_edma.h:113
Definition: fsl_lpspi_edma.h:75
Definition: fsl_lpspi_edma.h:130
volatile bool isThereExtraRxBytes
Definition: fsl_lpspi_edma.h:78
Definition: fsl_lpspi_edma.h:81
Definition: fsl_lpspi_edma.h:103
volatile bool isPcsContinuous
Definition: fsl_lpspi_edma.h:66
Definition: fsl_lpspi_edma.h:91
status_t LPSPI_MasterTransferEDMA(LPSPI_Type *base, lpspi_master_edma_handle_t *handle, lpspi_transfer_t *transfer)
LPSPI master transfer data using eDMA.
Definition: fsl_lpspi_edma.c:201
void LPSPI_MasterTransferAbortEDMA(LPSPI_Type *base, lpspi_master_edma_handle_t *handle)
LPSPI master aborts a transfer which is using eDMA.
Definition: fsl_lpspi_edma.c:572
Definition: fsl_lpspi_edma.h:128
void LPSPI_SlaveTransferCreateHandleEDMA(LPSPI_Type *base, lpspi_slave_edma_handle_t *handle, lpspi_slave_edma_transfer_callback_t callback, void *userData, edma_handle_t *edmaRxRegToRxDataHandle, edma_handle_t *edmaTxDataToTxRegHandle)
Initializes the LPSPI slave eDMA handle.
Definition: fsl_lpspi_edma.c:641
status_t LPSPI_SlaveTransferEDMA(LPSPI_Type *base, lpspi_slave_edma_handle_t *handle, lpspi_transfer_t *transfer)
LPSPI slave transfers data using eDMA.
Definition: fsl_lpspi_edma.c:684
Definition: fsl_lpspi_edma.h:102
uint8_t nbytes
Definition: fsl_lpspi_edma.h:97
volatile size_t txRemainingByteCount
Definition: fsl_lpspi_edma.h:82
Definition: fsl_lpspi_edma.h:131
void * userData
Definition: fsl_lpspi_edma.h:100
status_t LPSPI_SlaveTransferGetCountEDMA(LPSPI_Type *base, lpspi_slave_edma_handle_t *handle, size_t *count)
Gets the slave eDMA transfer remaining bytes.
Definition: fsl_lpspi_edma.c:1027
Definition: fsl_lpspi_edma.h:127
Definition: fsl_lpspi_edma.h:121
uint32_t totalByteCount
Definition: fsl_lpspi_edma.h:88
Definition: fsl_lpspi_edma.h:133
Definition: fsl_lpspi_edma.h:120
void(* lpspi_slave_edma_transfer_callback_t)(LPSPI_Type *base, lpspi_slave_edma_handle_t *handle, status_t status, void *userData)
Definition: fsl_lpspi_edma.h:58
Definition: MIMXRT1052.h:30457
eDMA transfer handle structure
Definition: fsl_edma.h:244
eDMA TCD.
Definition: fsl_edma.h:205
LPSPI master eDMA transfer handle structure used for transactional API.
Definition: fsl_lpspi_edma.h:65
LPSPI slave eDMA transfer handle structure used for transactional API.
Definition: fsl_lpspi_edma.h:110
LPSPI master/slave transfer structure.
Definition: fsl_lpspi.h:344
