RTEMS 6.1-rc1
fsl-mpc555x.h
1/*
2 * Modifications of the original file provided by Freescale are:
3 *
4 * Copyright (c) 2011 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
16 * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
17 * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
18 * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
19 * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
20 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
21 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
22 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
23 * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
24 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
25 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
26 */
27
28/**************************************************************************/
29/* FILE NAME: mpc5554.h COPYRIGHT (c) Freescale 2007 */
30/* VERSION: 1.7 All Rights Reserved */
31/* */
32/* DESCRIPTION: */
33/* This file contain all of the register and bit field definitions for */
34/* MPC5554. */
35/*========================================================================*/
36/* UPDATE HISTORY */
37/* REV AUTHOR DATE DESCRIPTION OF CHANGE */
38/* --- ----------- --------- --------------------- */
39/* 0.01 J. Loeliger 03/Mar/03 Initial version of file for MPC5554. */
40/* Based on SoC version 0.7. */
41/* 0.02 J. Loeliger 05/Mar/03 All registers and bit fields now */
42/* defined. */
43/* 0.03 J. Loeliger 05/May/03 Updated to current spec., fixed several*/
44/* bugs and naming/formating issues. */
45/* 0.04 J. Loeliger 16/May/03 More fixes and naming/formating issues.*/
46/* 0.05 J. Loeliger 19/Aug/03 Updated for latest documentation. */
47/* 0.06 J. Loeliger 03/Sep/03 Changed to include motint.h */
48/* Updated many register names. */
49/* 0.07 J. Loeliger 04/Nov/03 Changed to include typedefs.h and more */
50/* register name updates. */
51/* 0.08 J. Loeliger 25/Feb/04 Added MetroWerks #pragmas. */
52/* Updated for user manual 1.0 */
53/* 0.09 J. Loeliger 27/Feb/04 Updated eDMA tcd section and some more */
54/* bit field names to match user's man. */
55/* 0.10 J. Loeliger 01/Apr/04 Fixed register spacing in ADC and eTPU */
56/* 0.11 J. Loeliger 16/Jun/04 Many fixes and updated to user's */
57/* manual, also some testing done. */
58/* 0.12 J. Loeliger 25/Jun/04 Fixed problems in edma and eTPU. */
59/* 0.13 J. Loeliger 16/Jul/04 Fixed mistake in FlexCAN TIMER size and*/
60/* changed eTPU memory defs to start with*/
61/* ETPU_ */
62/* 0.14 J. Loeliger 17/Nov/04 Added ETPU_CODE_RAM definition. */
63/* All code moved to CVS repository. */
64/* Updated copyright to Freescale. */
65/* Added new SCMOFFDATAR register to eTPU*/
66/* Fixed REDCR_A&B bit fields in eTPU. */
67/* Added new DBR bit in CTAR for DSPI. */
68/* 0.15 J. Loeliger 29/Nov/04 Added support for new eTPU util funcs. */
69/* Added bit fields for FlexCAN buffer ID*/
70/* 0.16 J. Loeliger 01/Dec/04 Corrected comments in release 0.16. */
71/* 0.17 J. Loeliger 02/Dec/04 Moved eTPU variable definitions to a */
72/* seperate new file. */
73/* Removed SIU variable the GPIO */
74/* routines do not need it. */
75/* 1.0 G.Emerson 22/Feb/05 No real changes to this file. */
76/* Joint generation with mpc5553.h */
77/* 1.1 G. Emerson 6/Jun/05 Changes to SIU to allow for upward */
78/* expansion of PCR/GPDI/GPDO */
79/* Added #defines for memory sizes etc */
80/* 1.2 G. Emerson 21/Sep/05 PBRIDGES fixes */
81/* 1.3 G. Emerson 03/Jan/06 Pbridge MPCR/PACR/OPACR now generic */
82/* XBAR MPR now generic */
83/* ECSM has FSBMCR on all integrations */
84/* 1.4 G. Emerson 24/Jan/06 Make Pbridges, XBAR, Flash BIU */
85/* integration specific */
86/* 1.5 S. Mathieson 28/Jul/06 Split out unused bit to support build */
87/* process. No real change. */
88/* 1.6 S. Mathieson 30/Aug/06 SPR: L1SCR0, updated bit name from DPP */
89/* to DPB to align with documentation. */
90/* 1.7 S. Mathieson 26/Feb/07 eDMA TCD format updated to include */
91/* alternate configuration. INTC, */
92/* correction to the number of PSR */
93/* registers. */
94/**************************************************************************/
95/*>>>>NOTE! this file is auto-generated please do not edit it!<<<<*/
96
97#ifndef _MPC5554_H_
98#define _MPC5554_H_
99
100#ifndef ASM
101
102#include <stdint.h>
103
104#include <mpc55xx/regs-edma.h>
105
106#ifdef __cplusplus
107extern "C" {
108#endif
109
110#ifdef __MWERKS__
111#pragma push
112#pragma ANSI_strict off
113#endif
114
115/****************************************************************************/
116/* MODULE : PBRIDGE_A Peripheral Bridge */
117/****************************************************************************/
119 union {
120 uint32_t R;
121 struct {
122 uint32_t MBW0:1;
123 uint32_t MTR0:1;
124 uint32_t MTW0:1;
125 uint32_t MPL0:1;
126 uint32_t MBW1:1;
127 uint32_t MTR1:1;
128 uint32_t MTW1:1;
129 uint32_t MPL1:1;
130 uint32_t MBW2:1;
131 uint32_t MTR2:1;
132 uint32_t MTW2:1;
133 uint32_t MPL2:1;
134 uint32_t MBW3:1;
135 uint32_t MTR3:1;
136 uint32_t MTW3:1;
137 uint32_t MPL3:1;
138
139 uint32_t:4;
140
141 uint32_t:4;
142
143 uint32_t:4;
144
145 uint32_t:4;
146 } B;
147 } MPCR; /* Master Privilege Control Register */
148
149 uint32_t pbridge_a_reserved2[7];
150
151 union {
152 uint32_t R;
153 struct {
154 uint32_t BW0:1;
155 uint32_t SP0:1;
156 uint32_t WP0:1;
157 uint32_t TP0:1;
158 uint32_t:28;
159 } B;
160 } PACR0;
161
162 uint32_t pbridge_a_reserved3[7];
163
164 union {
165 uint32_t R;
166 struct {
167 uint32_t BW0:1;
168 uint32_t SP0:1;
169 uint32_t WP0:1;
170 uint32_t TP0:1;
171 uint32_t BW1:1;
172 uint32_t SP1:1;
173 uint32_t WP1:1;
174 uint32_t TP1:1;
175 uint32_t BW2:1;
176 uint32_t SP2:1;
177 uint32_t WP2:1;
178 uint32_t TP2:1;
179 uint32_t:4;
180 uint32_t BW4:1;
181 uint32_t SP4:1;
182 uint32_t WP4:1;
183 uint32_t TP4:1;
184 uint32_t:12;
185 } B;
186 } OPACR0;
187
188 union {
189 uint32_t R;
190 struct {
191
192 uint32_t BW0:1; /* EMIOS */
193 uint32_t SP0:1;
194 uint32_t WP0:1;
195 uint32_t TP0:1;
196
197 uint32_t:28;
198 } B;
199 } OPACR1;
200
201 union {
202 uint32_t R;
203 struct {
204 uint32_t BW0:1;
205 uint32_t SP0:1;
206 uint32_t WP0:1;
207 uint32_t TP0:1;
208 uint32_t:4;
209 uint32_t BW2:1;
210 uint32_t SP2:1;
211 uint32_t WP2:1;
212 uint32_t TP2:1;
213 uint32_t BW3:1;
214 uint32_t SP3:1;
215 uint32_t WP3:1;
216 uint32_t TP3:1;
217 uint32_t BW4:1;
218 uint32_t SP4:1;
219 uint32_t WP4:1;
220 uint32_t TP4:1;
221 uint32_t:12;
222 } B;
223 } OPACR2;
224
225 };
226
227/****************************************************************************/
228/* MODULE : PBRIDGE_B Peripheral Bridge */
229/****************************************************************************/
231 union {
232 uint32_t R;
233 struct {
234 uint32_t MBW0:1;
235 uint32_t MTR0:1;
236 uint32_t MTW0:1;
237 uint32_t MPL0:1;
238 uint32_t MBW1:1;
239 uint32_t MTR1:1;
240 uint32_t MTW1:1;
241 uint32_t MPL1:1;
242 uint32_t MBW2:1;
243 uint32_t MTR2:1;
244 uint32_t MTW2:1;
245 uint32_t MPL2:1;
246 uint32_t MBW3:1;
247 uint32_t MTR3:1;
248 uint32_t MTW3:1;
249 uint32_t MPL3:1;
250
251 uint32_t:4;
252
253 uint32_t:4;
254
255 uint32_t:4;
256
257 uint32_t:4;
258 } B;
259 } MPCR; /* Master Privilege Control Register */
260
261 uint32_t pbridge_b_reserved2[7];
262
263 union {
264 uint32_t R;
265 struct {
266 uint32_t BW0:1;
267 uint32_t SP0:1;
268 uint32_t WP0:1;
269 uint32_t TP0:1;
270 uint32_t BW1:1;
271 uint32_t SP1:1;
272 uint32_t WP1:1;
273 uint32_t TP1:1;
274 uint32_t:24;
275 } B;
276 } PACR0;
277
278 uint32_t pbridge_b_reserved3;
279
280 union {
281 uint32_t R;
282 struct {
283 uint32_t BW0:1;
284 uint32_t SP0:1;
285 uint32_t WP0:1;
286 uint32_t TP0:1;
287 uint32_t BW1:1;
288 uint32_t SP1:1;
289 uint32_t WP1:1;
290 uint32_t TP1:1;
291 uint32_t BW2:1;
292 uint32_t SP2:1;
293 uint32_t WP2:1;
294 uint32_t TP2:1;
295
296 uint32_t:4;
297
298 uint32_t:16;
299
300 } B;
301 } PACR2;
302
303 uint32_t pbridge_b_reserved4[5];
304
305 union {
306 uint32_t R;
307 struct {
308 uint32_t BW0:1;
309 uint32_t SP0:1;
310 uint32_t WP0:1;
311 uint32_t TP0:1;
312 uint32_t:12;
313
314 uint32_t BW4:1; /* DSPI_A */
315 uint32_t SP4:1;
316 uint32_t WP4:1;
317 uint32_t TP4:1;
318
319 uint32_t BW5:1; /* DSPI_B */
320 uint32_t SP5:1;
321 uint32_t WP5:1;
322 uint32_t TP5:1;
323
324 uint32_t BW6:1;
325 uint32_t SP6:1;
326 uint32_t WP6:1;
327 uint32_t TP6:1;
328 uint32_t BW7:1;
329 uint32_t SP7:1;
330 uint32_t WP7:1;
331 uint32_t TP7:1;
332 } B;
333 } OPACR0;
334
335 union {
336 uint32_t R;
337 struct {
338 uint32_t:16;
339 uint32_t BW4:1;
340 uint32_t SP4:1;
341 uint32_t WP4:1;
342 uint32_t TP4:1;
343
344 uint32_t BW5:1; /* ESCI_B */
345 uint32_t SP5:1;
346 uint32_t WP5:1;
347 uint32_t TP5:1;
348
349 uint32_t:8;
350 } B;
351 } OPACR1;
352
353 union {
354 uint32_t R;
355 struct {
356 uint32_t BW0:1;
357 uint32_t SP0:1;
358 uint32_t WP0:1;
359 uint32_t TP0:1;
360
361 uint32_t BW1:1; /* CAN_B */
362 uint32_t SP1:1;
363 uint32_t WP1:1;
364 uint32_t TP1:1;
365
366 uint32_t BW2:1;
367 uint32_t SP2:1;
368 uint32_t WP2:1;
369 uint32_t TP2:1;
370
371 uint32_t:4;
372
373 uint32_t:4;
374
375 uint32_t:12;
376 } B;
377 } OPACR2;
378
379 union {
380 uint32_t R;
381 struct {
382
383 uint32_t:4;
384
385 uint32_t:24;
386 uint32_t BW7:1;
387 uint32_t SP7:1;
388 uint32_t WP7:1;
389 uint32_t TP7:1;
390 } B;
391 } OPACR3;
392
393 };
394/****************************************************************************/
395/* MODULE : FMPLL */
396/****************************************************************************/
397 struct FMPLL_tag {
399 uint32_t R;
400 struct {
401 uint32_t:1;
402 uint32_t PREDIV:3;
403 uint32_t MFD:5;
404 uint32_t:1;
405 uint32_t RFD:3;
406 uint32_t LOCEN:1;
407 uint32_t LOLRE:1;
408 uint32_t LOCRE:1;
409 uint32_t DISCLK:1;
410 uint32_t LOLIRQ:1;
411 uint32_t LOCIRQ:1;
412 uint32_t RATE:1;
413 uint32_t DEPTH:2;
414 uint32_t EXP:10;
415 } B;
416 } SYNCR;
417
418 union FMPLL_SYNSR_tag {
419 uint32_t R;
420 struct {
421 uint32_t:22;
422 uint32_t LOLF:1;
423 uint32_t LOC:1;
424 uint32_t MODE:1;
425 uint32_t PLLSEL:1;
426 uint32_t PLLREF:1;
427 uint32_t LOCKS:1;
428 uint32_t LOCK:1;
429 uint32_t LOCF:1;
430 uint32_t CALDONE:1;
431 uint32_t CALPASS:1;
432 } B;
433 } SYNSR;
434
435 };
436/****************************************************************************/
437/* MODULE : External Bus Interface (EBI) */
438/****************************************************************************/
439 struct EBI_CS_tag {
440 union { /* Base Register Bank */
441 uint32_t R;
442 struct {
443 uint32_t BA:17;
444 uint32_t:3;
445 uint32_t PS:1;
446 uint32_t:4;
447 uint32_t BL:1;
448 uint32_t WEBS:1;
449 uint32_t TBDIP:1;
450 uint32_t:2;
451 uint32_t BI:1;
452 uint32_t V:1;
453 } B;
454 } BR;
455
456 union { /* Option Register Bank */
457 uint32_t R;
458 struct {
459 uint32_t AM:17;
460 uint32_t:7;
461 uint32_t SCY:4;
462 uint32_t:1;
463 uint32_t BSCY:2;
464 uint32_t:1;
465 } B;
466 } OR;
467 };
468
469 struct EBI_CAL_CS_tag {
470 uint32_t ebi_cal_cs_reserved [2];
471 };
472
473 struct EBI_tag {
474 union EBI_MCR_tag { /* Module Configuration Register */
475 uint32_t R;
476 struct {
477 uint32_t:5;
478 uint32_t SIZEEN:1;
479 uint32_t SIZE:2;
480 uint32_t:8;
481 uint32_t ACGE:1;
482 uint32_t EXTM:1;
483 uint32_t EARB:1;
484 uint32_t EARP:2;
485 uint32_t:4;
486 uint32_t MDIS:1;
487 uint32_t:5;
488 uint32_t DBM:1;
489 } B;
490 } MCR;
491
492 uint32_t EBI_reserved1;
493
494 union { /* Transfer Error Status Register */
495 uint32_t R;
496 struct {
497 uint32_t:30;
498 uint32_t TEAF:1;
499 uint32_t BMTF:1;
500 } B;
501 } TESR;
502
503 union { /* Bus Monitor Control Register */
504 uint32_t R;
505 struct {
506 uint32_t:16;
507 uint32_t BMT:8;
508 uint32_t BME:1;
509 uint32_t:7;
510 } B;
511 } BMCR;
512
513 struct EBI_CS_tag CS[4];
514
515 uint32_t EBI_reserved2[4];
516
517 struct EBI_CAL_CS_tag CAL_CS[4];
518 };
519/****************************************************************************/
520/* MODULE : FLASH */
521/****************************************************************************/
522 struct FLASH_tag {
523 union { /* Module Configuration Register */
524 uint32_t R;
525 struct {
526 uint32_t:4;
527 uint32_t SIZE:4;
528 uint32_t:1;
529 uint32_t LAS:3;
530 uint32_t:3;
531 uint32_t MAS:1;
532 uint32_t EER:1;
533 uint32_t RWE:1;
534 uint32_t BBEPE:1;
535 uint32_t EPE:1;
536 uint32_t PEAS:1;
537 uint32_t DONE:1;
538 uint32_t PEG:1;
539
540 uint32_t:2;
541
542 uint32_t STOP:1;
543 uint32_t:1;
544 uint32_t PGM:1;
545 uint32_t PSUS:1;
546 uint32_t ERS:1;
547 uint32_t ESUS:1;
548 uint32_t EHV:1;
549 } B;
550 } MCR;
551
552 union LMLR_tag { /* LML Register */
553 uint32_t R;
554 struct {
555 uint32_t LME:1;
556 uint32_t:10;
557 uint32_t SLOCK:1;
558 uint32_t MLOCK:4;
559 uint32_t LLOCK:16;
560 } B;
561 } LMLR;
562
563 union HLR_tag { /* HL Register */
564 uint32_t R;
565 struct {
566 uint32_t HBE:1;
567 uint32_t:3;
568 uint32_t HBLOCK:28;
569 } B;
570 } HLR;
571
572 union SLMLR_tag { /* SLML Register */
573 uint32_t R;
574 struct {
575 uint32_t SLE:1;
576 uint32_t:10;
577 uint32_t SSLOCK:1;
578 uint32_t SMLOCK:4;
579 uint32_t SLLOCK:16;
580 } B;
581 } SLMLR;
582
583 union { /* LMS Register */
584 uint32_t R;
585 struct {
586 uint32_t:12;
587 uint32_t MSEL:4;
588 uint32_t LSEL:16;
589 } B;
590 } LMSR;
591
592 union {
593 uint32_t R;
594 struct {
595 uint32_t:4;
596 uint32_t HBSEL:28;
597 } B;
598 } HSR;
599
600 union {
601 uint32_t R;
602 struct {
603 uint32_t:10;
604 uint32_t ADDR:19;
605 uint32_t:3;
606 } B;
607 } AR;
608
609 union {
610 uint32_t R;
611 struct {
612
613 uint32_t:11;
614
615 uint32_t:1;
616
617 uint32_t M3PFE:1;
618 uint32_t M2PFE:1;
619 uint32_t M1PFE:1;
620 uint32_t M0PFE:1;
621 uint32_t APC:3;
622 uint32_t WWSC:2;
623 uint32_t RWSC:3;
624
625 uint32_t DPFEN:2;
626 uint32_t IPFEN:2;
627
628 uint32_t PFLIM:3;
629 uint32_t BFEN:1;
630 } B;
631 } BIUCR;
632
633 union {
634 uint32_t R;
635 struct {
636
637 uint32_t:22;
638
639 uint32_t:2;
640
641 uint32_t M3AP:2;
642 uint32_t M2AP:2;
643 uint32_t M1AP:2;
644 uint32_t M0AP:2;
645 } B;
646 } BIUAPR;
647 };
648/****************************************************************************/
649/* MODULE : SIU */
650/****************************************************************************/
651 struct SIU_tag {
652 int32_t SIU_reserved0;
653
654 union { /* MCU ID Register */
655 uint32_t R;
656 struct {
657 uint32_t PARTNUM:16;
658 uint32_t MASKNUM:16;
659 } B;
660 } MIDR;
661 int32_t SIU_reserved00;
662
663 union { /* Reset Status Register */
664 uint32_t R;
665 struct {
666 uint32_t PORS:1;
667 uint32_t ERS:1;
668 uint32_t LLRS:1;
669 uint32_t LCRS:1;
670 uint32_t WDRS:1;
671 uint32_t CRS:1;
672 uint32_t:8;
673 uint32_t SSRS:1;
674 uint32_t SERF:1;
675 uint32_t WKPCFG:1;
676 uint32_t:12;
677 uint32_t BOOTCFG:2;
678 uint32_t RGF:1;
679 } B;
680 } RSR;
681
682 union { /* System Reset Control Register */
683 uint32_t R;
684 struct {
685 uint32_t SSR:1;
686 uint32_t SER:1;
687 uint32_t:14;
688 uint32_t CRE:1;
689 uint32_t:15;
690 } B;
691 } SRCR;
692
693 union SIU_EISR_tag { /* External Interrupt Status Register */
694 uint32_t R;
695 struct {
696 uint32_t:16;
697 uint32_t EIF15:1;
698 uint32_t EIF14:1;
699 uint32_t EIF13:1;
700 uint32_t EIF12:1;
701 uint32_t EIF11:1;
702 uint32_t EIF10:1;
703 uint32_t EIF9:1;
704 uint32_t EIF8:1;
705 uint32_t EIF7:1;
706 uint32_t EIF6:1;
707 uint32_t EIF5:1;
708 uint32_t EIF4:1;
709 uint32_t EIF3:1;
710 uint32_t EIF2:1;
711 uint32_t EIF1:1;
712 uint32_t EIF0:1;
713 } B;
714 } EISR;
715
716 union SIU_DIRER_tag { /* DMA/Interrupt Request Enable Register */
717 uint32_t R;
718 struct {
719 uint32_t:16;
720 uint32_t EIRE15:1;
721 uint32_t EIRE14:1;
722 uint32_t EIRE13:1;
723 uint32_t EIRE12:1;
724 uint32_t EIRE11:1;
725 uint32_t EIRE10:1;
726 uint32_t EIRE9:1;
727 uint32_t EIRE8:1;
728 uint32_t EIRE7:1;
729 uint32_t EIRE6:1;
730 uint32_t EIRE5:1;
731 uint32_t EIRE4:1;
732 uint32_t EIRE3:1;
733 uint32_t EIRE2:1;
734 uint32_t EIRE1:1;
735 uint32_t EIRE0:1;
736 } B;
737 } DIRER;
738
739 union SIU_DIRSR_tag { /* DMA/Interrupt Select Register */
740 uint32_t R;
741 struct {
742 uint32_t:28;
743 uint32_t DIRS3:1;
744 uint32_t DIRS2:1;
745 uint32_t DIRS1:1;
746 uint32_t DIRS0:1;
747 } B;
748 } DIRSR;
749
750 union { /* Overrun Status Register */
751 uint32_t R;
752 struct {
753 uint32_t:16;
754 uint32_t OVF15:1;
755 uint32_t OVF14:1;
756 uint32_t OVF13:1;
757 uint32_t OVF12:1;
758 uint32_t OVF11:1;
759 uint32_t OVF10:1;
760 uint32_t OVF9:1;
761 uint32_t OVF8:1;
762 uint32_t OVF7:1;
763 uint32_t OVF6:1;
764 uint32_t OVF5:1;
765 uint32_t OVF4:1;
766 uint32_t OVF3:1;
767 uint32_t OVF2:1;
768 uint32_t OVF1:1;
769 uint32_t OVF0:1;
770 } B;
771 } OSR;
772
773 union SIU_ORER_tag { /* Overrun Request Enable Register */
774 uint32_t R;
775 struct {
776 uint32_t:16;
777 uint32_t ORE15:1;
778 uint32_t ORE14:1;
779 uint32_t ORE13:1;
780 uint32_t ORE12:1;
781 uint32_t ORE11:1;
782 uint32_t ORE10:1;
783 uint32_t ORE9:1;
784 uint32_t ORE8:1;
785 uint32_t ORE7:1;
786 uint32_t ORE6:1;
787 uint32_t ORE5:1;
788 uint32_t ORE4:1;
789 uint32_t ORE3:1;
790 uint32_t ORE2:1;
791 uint32_t ORE1:1;
792 uint32_t ORE0:1;
793 } B;
794 } ORER;
795
796 union SIU_IREER_tag { /* External IRQ Rising-Edge Event Enable Register */
797 uint32_t R;
798 struct {
799 uint32_t:16;
800 uint32_t IREE15:1;
801 uint32_t IREE14:1;
802 uint32_t IREE13:1;
803 uint32_t IREE12:1;
804 uint32_t IREE11:1;
805 uint32_t IREE10:1;
806 uint32_t IREE9:1;
807 uint32_t IREE8:1;
808 uint32_t IREE7:1;
809 uint32_t IREE6:1;
810 uint32_t IREE5:1;
811 uint32_t IREE4:1;
812 uint32_t IREE3:1;
813 uint32_t IREE2:1;
814 uint32_t IREE1:1;
815 uint32_t IREE0:1;
816 } B;
817 } IREER;
818
819 union SIU_IFEER_tag { /* External IRQ Falling-Edge Event Enable Register */
820 uint32_t R;
821 struct {
822 uint32_t:16;
823 uint32_t IFEE15:1;
824 uint32_t IFEE14:1;
825 uint32_t IFEE13:1;
826 uint32_t IFEE12:1;
827 uint32_t IFEE11:1;
828 uint32_t IFEE10:1;
829 uint32_t IFEE9:1;
830 uint32_t IFEE8:1;
831 uint32_t IFEE7:1;
832 uint32_t IFEE6:1;
833 uint32_t IFEE5:1;
834 uint32_t IFEE4:1;
835 uint32_t IFEE3:1;
836 uint32_t IFEE2:1;
837 uint32_t IFEE1:1;
838 uint32_t IFEE0:1;
839 } B;
840 } IFEER;
841
842 union SIU_IDFR_tag { /* External IRQ Digital Filter Register */
843 uint32_t R;
844 struct {
845 uint32_t:28;
846 uint32_t DFL:4;
847 } B;
848 } IDFR;
849
850 int32_t SIU_reserved1[3];
851
852 union SIU_PCR_tag { /* Pad Configuration Registers */
853 uint16_t R;
854 struct {
855 uint16_t:3;
856 uint16_t PA:3;
857 uint16_t OBE:1;
858 uint16_t IBE:1;
859 uint16_t DSC:2;
860 uint16_t ODE:1;
861 uint16_t HYS:1;
862 uint16_t SRC:2;
863 uint16_t WPE:1;
864 uint16_t WPS:1;
865 } B;
866 } PCR[512];
867
868 int16_t SIU_reserved_0[224];
869
870 union { /* GPIO Pin Data Output Registers */
871 uint8_t R;
872 struct {
873 uint8_t:7;
874 uint8_t PDO:1;
875 } B;
876 } GPDO[256];
877
878 int32_t SIU_reserved_3[64];
879
880 union { /* GPIO Pin Data Input Registers */
881 uint8_t R;
882 struct {
883 uint8_t:7;
884 uint8_t PDI:1;
885 } B;
886 } GPDI[256];
887
888 union { /* IMUX Register */
889 uint32_t R;
890 struct {
891 uint32_t TSEL5:2;
892 uint32_t TSEL4:2;
893 uint32_t TSEL3:2;
894 uint32_t TSEL2:2;
895 uint32_t TSEL1:2;
896 uint32_t TSEL0:2;
897 uint32_t:20;
898 } B;
899 } ETISR;
900
901 union { /* IMUX Register */
902 uint32_t R;
903 struct {
904 uint32_t ESEL15:2;
905 uint32_t ESEL14:2;
906 uint32_t ESEL13:2;
907 uint32_t ESEL12:2;
908 uint32_t ESEL11:2;
909 uint32_t ESEL10:2;
910 uint32_t ESEL9:2;
911 uint32_t ESEL8:2;
912 uint32_t ESEL7:2;
913 uint32_t ESEL6:2;
914 uint32_t ESEL5:2;
915 uint32_t ESEL4:2;
916 uint32_t ESEL3:2;
917 uint32_t ESEL2:2;
918 uint32_t ESEL1:2;
919 uint32_t ESEL0:2;
920 } B;
921 } EIISR;
922
923 union { /* IMUX Register */
924 uint32_t R;
925 struct {
926 uint32_t SINSELA:2;
927 uint32_t SSSELA:2;
928 uint32_t SCKSELA:2;
929 uint32_t TRIGSELA:2;
930 uint32_t SINSELB:2;
931 uint32_t SSSELB:2;
932 uint32_t SCKSELB:2;
933 uint32_t TRIGSELB:2;
934 uint32_t SINSELC:2;
935 uint32_t SSSELC:2;
936 uint32_t SCKSELC:2;
937 uint32_t TRIGSELC:2;
938 uint32_t SINSELD:2;
939 uint32_t SSSELD:2;
940 uint32_t SCKSELD:2;
941 uint32_t TRIGSELD:2;
942 } B;
943 } DISR;
944
945 int32_t SIU_reserved2[29];
946
947 union { /* Chip Configuration Register Register */
948 uint32_t R;
949 struct {
950 uint32_t:14;
951 uint32_t MATCH:1;
952 uint32_t DISNEX:1;
953 uint32_t:16;
954 } B;
955 } CCR;
956
957 union { /* External Clock Configuration Register Register */
958 uint32_t R;
959 struct {
960 uint32_t:18;
961 uint32_t ENGDIV:6;
962 uint32_t:4;
963 uint32_t EBTS:1;
964 uint32_t:1;
965 uint32_t EBDF:2;
966 } B;
967 } ECCR;
968
969 union {
970 uint32_t R;
971 } CARH;
972
973 union {
974 uint32_t R;
975 } CARL;
976
977 union {
978 uint32_t R;
979 } CBRH;
980
981 union {
982 uint32_t R;
983 } CBRL;
984
985 };
986/****************************************************************************/
987/* MODULE : EMIOS */
988/****************************************************************************/
989 struct EMIOS_tag {
990 union EMIOS_MCR_tag {
991 uint32_t R;
992 struct {
993 uint32_t:1;
994 uint32_t MDIS:1;
995 uint32_t FRZ:1;
996 uint32_t GTBE:1;
997 uint32_t ETB:1;
998 uint32_t GPREN:1;
999 uint32_t:6;
1000 uint32_t SRV:4;
1001 uint32_t GPRE:8;
1002 uint32_t:8;
1003 } B;
1004 } MCR; /* Module Configuration Register */
1005
1006 union {
1007 uint32_t R;
1008 struct {
1009 uint32_t:8;
1010 uint32_t F23:1;
1011 uint32_t F22:1;
1012 uint32_t F21:1;
1013 uint32_t F20:1;
1014 uint32_t F19:1;
1015 uint32_t F18:1;
1016 uint32_t F17:1;
1017 uint32_t F16:1;
1018 uint32_t F15:1;
1019 uint32_t F14:1;
1020 uint32_t F13:1;
1021 uint32_t F12:1;
1022 uint32_t F11:1;
1023 uint32_t F10:1;
1024 uint32_t F9:1;
1025 uint32_t F8:1;
1026 uint32_t F7:1;
1027 uint32_t F6:1;
1028 uint32_t F5:1;
1029 uint32_t F4:1;
1030 uint32_t F3:1;
1031 uint32_t F2:1;
1032 uint32_t F1:1;
1033 uint32_t F0:1;
1034 } B;
1035 } GFR; /* Global FLAG Register */
1036
1037 union {
1038 uint32_t R;
1039 struct {
1040 uint32_t:8;
1041 uint32_t OU23:1;
1042 uint32_t OU22:1;
1043 uint32_t OU21:1;
1044 uint32_t OU20:1;
1045 uint32_t OU19:1;
1046 uint32_t OU18:1;
1047 uint32_t OU17:1;
1048 uint32_t OU16:1;
1049 uint32_t OU15:1;
1050 uint32_t OU14:1;
1051 uint32_t OU13:1;
1052 uint32_t OU12:1;
1053 uint32_t OU11:1;
1054 uint32_t OU10:1;
1055 uint32_t OU9:1;
1056 uint32_t OU8:1;
1057 uint32_t OU7:1;
1058 uint32_t OU6:1;
1059 uint32_t OU5:1;
1060 uint32_t OU4:1;
1061 uint32_t OU3:1;
1062 uint32_t OU2:1;
1063 uint32_t OU1:1;
1064 uint32_t OU0:1;
1065 } B;
1066 } OUDR; /* Output Update Disable Register */
1067
1068 uint32_t emios_reserved[5];
1069
1070 struct EMIOS_CH_tag {
1071 union {
1072 uint32_t R; /* Channel A Data Register */
1073 } CADR;
1074
1075 union {
1076 uint32_t R; /* Channel B Data Register */
1077 } CBDR;
1078
1079 union {
1080 uint32_t R; /* Channel Counter Register */
1081 } CCNTR;
1082
1083 union EMIOS_CCR_tag {
1084 uint32_t R;
1085 struct {
1086 uint32_t FREN:1;
1087 uint32_t ODIS:1;
1088 uint32_t ODISSL:2;
1089 uint32_t UCPRE:2;
1090 uint32_t UCPREN:1;
1091 uint32_t DMA:1;
1092 uint32_t:1;
1093 uint32_t IF:4;
1094 uint32_t FCK:1;
1095 uint32_t FEN:1;
1096 uint32_t:3;
1097 uint32_t FORCMA:1;
1098 uint32_t FORCMB:1;
1099 uint32_t:1;
1100 uint32_t BSL:2;
1101 uint32_t EDSEL:1;
1102 uint32_t EDPOL:1;
1103 uint32_t MODE:7;
1104 } B;
1105 } CCR; /* Channel Control Register */
1106
1107 union EMIOS_CSR_tag {
1108 uint32_t R;
1109 struct {
1110 uint32_t OVR:1;
1111 uint32_t:15;
1112 uint32_t OVFL:1;
1113 uint32_t:12;
1114 uint32_t UCIN:1;
1115 uint32_t UCOUT:1;
1116 uint32_t FLAG:1;
1117 } B;
1118 } CSR; /* Channel Status Register */
1119 uint32_t emios_channel_reserved[3];
1120
1121 } CH[24];
1122
1123 };
1124/****************************************************************************/
1125/* MODULE :ETPU */
1126/****************************************************************************/
1127
1128/***************************Configuration Registers**************************/
1129
1130 struct ETPU_tag {
1131 union { /* MODULE CONFIGURATION REGISTER */
1132 uint32_t R;
1133 struct {
1134 uint32_t GEC:1; /* Global Exception Clear */
1135 uint32_t:3;
1136 uint32_t MGE1:1; /* Microcode Global Exception-ETPU_A */
1137
1138 uint32_t MGE2:1; /* Microcode Global Exception-ETPU_B */
1139
1140 uint32_t ILF1:1; /* Illegal Instruction Flag-ETPU_A */
1141
1142 uint32_t ILF2:1; /* Illegal Instruction Flag-ETPU_B */
1143
1144 uint32_t:3;
1145 uint32_t SCMSIZE:5; /* Shared Code Memory size */
1146 uint32_t:5;
1147 uint32_t SCMMISF:1; /* SCM MISC Flag */
1148 uint32_t SCMMISEN:1; /* SCM MISC Enable */
1149 uint32_t:2;
1150 uint32_t VIS:1; /* SCM Visability */
1151 uint32_t:5;
1152 uint32_t GTBE:1; /* Global Time Base Enable */
1153 } B;
1154 } MCR;
1155
1156 union { /* COHERENT DUAL-PARAMETER CONTROL */
1157 uint32_t R;
1158 struct {
1159 uint32_t STS:1; /* Start Status bit */
1160 uint32_t CTBASE:5; /* Channel Transfer Base */
1161 uint32_t PBASE:10; /* Parameter Buffer Base Address */
1162 uint32_t PWIDTH:1; /* Parameter Width */
1163 uint32_t PARAM0:7; /* Channel Parameter 0 */
1164 uint32_t WR:1;
1165 uint32_t PARAM1:7; /* Channel Parameter 1 */
1166 } B;
1167 } CDCR;
1168
1169 uint32_t etpu_reserved1;
1170
1171 union { /* MISC Compare Register */
1172 uint32_t R;
1173 } MISCCMPR;
1174
1175 union { /* SCM off-range Date Register */
1176 uint32_t R;
1177 } SCMOFFDATAR;
1178
1179 union { /* ETPU_A Configuration Register */
1180 uint32_t R;
1181 struct {
1182 uint32_t FEND:1; /* Force END */
1183 uint32_t MDIS:1; /* Low power Stop */
1184 uint32_t:1;
1185 uint32_t STF:1; /* Stop Flag */
1186 uint32_t:4;
1187 uint32_t HLTF:1; /* Halt Mode Flag */
1188 uint32_t:4;
1189 uint32_t FPSCK:3; /* Filter Prescaler Clock Control */
1190 uint32_t CDFC:2;
1191 uint32_t:9;
1192 uint32_t ETB:5; /* Entry Table Base */
1193 } B;
1194 } ECR_A;
1195
1196 union { /* ETPU_B Configuration Register */
1197 uint32_t R;
1198 struct {
1199 uint32_t FEND:1; /* Force END */
1200 uint32_t MDIS:1; /* Low power Stop */
1201 uint32_t:1;
1202 uint32_t STF:1; /* Stop Flag */
1203 uint32_t:4;
1204 uint32_t HLTF:1; /* Halt Mode Flag */
1205 uint32_t:4;
1206 uint32_t FPSCK:3; /* Filter Prescaler Clock Control */
1207 uint32_t CDFC:2;
1208 uint32_t:9;
1209 uint32_t ETB:5; /* Entry Table Base */
1210 } B;
1211 } ECR_B;
1212
1213 uint32_t etpu_reserved4;
1214
1215 union { /* ETPU_A Timebase Configuration Register */
1216 uint32_t R;
1217 struct {
1218 uint32_t TCR2CTL:3; /* TCR2 Clock/Gate Control */
1219 uint32_t TCRCF:2; /* TCRCLK Signal Filter Control */
1220 uint32_t:1;
1221 uint32_t AM:1; /* Angle Mode */
1222 uint32_t:3;
1223 uint32_t TCR2P:6; /* TCR2 Prescaler Control */
1224 uint32_t TCR1CTL:2; /* TCR1 Clock/Gate Control */
1225 uint32_t:6;
1226 uint32_t TCR1P:8; /* TCR1 Prescaler Control */
1227 } B;
1228 } TBCR_A;
1229
1230 union { /* ETPU_A TCR1 Visibility Register */
1231 uint32_t R;
1232 } TB1R_A;
1233
1234 union { /* ETPU_A TCR2 Visibility Register */
1235 uint32_t R;
1236 } TB2R_A;
1237
1238 union { /* ETPU_A STAC Configuration Register */
1239 uint32_t R;
1240 struct {
1241 uint32_t REN1:1; /* Resource Enable TCR1 */
1242 uint32_t RSC1:1; /* Resource Control TCR1 */
1243 uint32_t:2;
1244 uint32_t SERVER_ID1:4;
1245 uint32_t:4;
1246 uint32_t SRV1:4; /* Resource Server Slot */
1247 uint32_t REN2:1; /* Resource Enable TCR2 */
1248 uint32_t RSC2:1; /* Resource Control TCR2 */
1249 uint32_t:2;
1250 uint32_t SERVER_ID2:4;
1251 uint32_t:4;
1252 uint32_t SRV2:4; /* Resource Server Slot */
1253 } B;
1254 } REDCR_A;
1255
1256 uint32_t etpu_reserved5[4];
1257
1258 union { /* ETPU_B Timebase Configuration Register */
1259 uint32_t R;
1260 struct {
1261 uint32_t TCR2CTL:3; /* TCR2 Clock/Gate Control */
1262 uint32_t TCRCF:2; /* TCRCLK Signal Filter Control */
1263 uint32_t:1;
1264 uint32_t AM:1; /* Angle Mode */
1265 uint32_t:3;
1266 uint32_t TCR2P:6; /* TCR2 Prescaler Control */
1267 uint32_t TCR1CTL:2; /* TCR1 Clock/Gate Control */
1268 uint32_t:6;
1269 uint32_t TCR1P:8; /* TCR1 Prescaler Control */
1270 } B;
1271 } TBCR_B;
1272
1273 union { /* ETPU_B TCR1 Visibility Register */
1274 uint32_t R;
1275 } TB1R_B;
1276
1277 union { /* ETPU_B TCR2 Visibility Register */
1278 uint32_t R;
1279 } TB2R_B;
1280
1281 union { /* ETPU_B STAC Configuration Register */
1282 uint32_t R;
1283 struct {
1284 uint32_t REN1:1; /* Resource Enable TCR1 */
1285 uint32_t RSC1:1; /* Resource Control TCR1 */
1286 uint32_t:2;
1287 uint32_t SERVER_ID1:4;
1288 uint32_t:4;
1289 uint32_t SRV1:4; /* Resource Server Slot */
1290 uint32_t REN2:1; /* Resource Enable TCR2 */
1291 uint32_t RSC2:1; /* Resource Control TCR2 */
1292 uint32_t:2;
1293 uint32_t SERVER_ID2:4;
1294 uint32_t:4;
1295 uint32_t SRV2:4; /* Resource Server Slot */
1296 } B;
1297 } REDCR_B;
1298
1299 uint32_t etpu_reserved7[108];
1300
1301/*****************************Status and Control Registers**************************/
1302
1303 union { /* ETPU_A Channel Interrut Status */
1304 uint32_t R;
1305 struct {
1306 uint32_t CIS31:1; /* Channel 31 Interrut Status */
1307 uint32_t CIS30:1; /* Channel 30 Interrut Status */
1308 uint32_t CIS29:1; /* Channel 29 Interrut Status */
1309 uint32_t CIS28:1; /* Channel 28 Interrut Status */
1310 uint32_t CIS27:1; /* Channel 27 Interrut Status */
1311 uint32_t CIS26:1; /* Channel 26 Interrut Status */
1312 uint32_t CIS25:1; /* Channel 25 Interrut Status */
1313 uint32_t CIS24:1; /* Channel 24 Interrut Status */
1314 uint32_t CIS23:1; /* Channel 23 Interrut Status */
1315 uint32_t CIS22:1; /* Channel 22 Interrut Status */
1316 uint32_t CIS21:1; /* Channel 21 Interrut Status */
1317 uint32_t CIS20:1; /* Channel 20 Interrut Status */
1318 uint32_t CIS19:1; /* Channel 19 Interrut Status */
1319 uint32_t CIS18:1; /* Channel 18 Interrut Status */
1320 uint32_t CIS17:1; /* Channel 17 Interrut Status */
1321 uint32_t CIS16:1; /* Channel 16 Interrut Status */
1322 uint32_t CIS15:1; /* Channel 15 Interrut Status */
1323 uint32_t CIS14:1; /* Channel 14 Interrut Status */
1324 uint32_t CIS13:1; /* Channel 13 Interrut Status */
1325 uint32_t CIS12:1; /* Channel 12 Interrut Status */
1326 uint32_t CIS11:1; /* Channel 11 Interrut Status */
1327 uint32_t CIS10:1; /* Channel 10 Interrut Status */
1328 uint32_t CIS9:1; /* Channel 9 Interrut Status */
1329 uint32_t CIS8:1; /* Channel 8 Interrut Status */
1330 uint32_t CIS7:1; /* Channel 7 Interrut Status */
1331 uint32_t CIS6:1; /* Channel 6 Interrut Status */
1332 uint32_t CIS5:1; /* Channel 5 Interrut Status */
1333 uint32_t CIS4:1; /* Channel 4 Interrut Status */
1334 uint32_t CIS3:1; /* Channel 3 Interrut Status */
1335 uint32_t CIS2:1; /* Channel 2 Interrut Status */
1336 uint32_t CIS1:1; /* Channel 1 Interrut Status */
1337 uint32_t CIS0:1; /* Channel 0 Interrut Status */
1338 } B;
1339 } CISR_A;
1340
1341 union { /* ETPU_B Channel Interruput Status */
1342 uint32_t R;
1343 struct {
1344 uint32_t CIS31:1; /* Channel 31 Interrut Status */
1345 uint32_t CIS30:1; /* Channel 30 Interrut Status */
1346 uint32_t CIS29:1; /* Channel 29 Interrut Status */
1347 uint32_t CIS28:1; /* Channel 28 Interrut Status */
1348 uint32_t CIS27:1; /* Channel 27 Interrut Status */
1349 uint32_t CIS26:1; /* Channel 26 Interrut Status */
1350 uint32_t CIS25:1; /* Channel 25 Interrut Status */
1351 uint32_t CIS24:1; /* Channel 24 Interrut Status */
1352 uint32_t CIS23:1; /* Channel 23 Interrut Status */
1353 uint32_t CIS22:1; /* Channel 22 Interrut Status */
1354 uint32_t CIS21:1; /* Channel 21 Interrut Status */
1355 uint32_t CIS20:1; /* Channel 20 Interrut Status */
1356 uint32_t CIS19:1; /* Channel 19 Interrut Status */
1357 uint32_t CIS18:1; /* Channel 18 Interrut Status */
1358 uint32_t CIS17:1; /* Channel 17 Interrut Status */
1359 uint32_t CIS16:1; /* Channel 16 Interrut Status */
1360 uint32_t CIS15:1; /* Channel 15 Interrut Status */
1361 uint32_t CIS14:1; /* Channel 14 Interrut Status */
1362 uint32_t CIS13:1; /* Channel 13 Interrut Status */
1363 uint32_t CIS12:1; /* Channel 12 Interrut Status */
1364 uint32_t CIS11:1; /* Channel 11 Interrut Status */
1365 uint32_t CIS10:1; /* Channel 10 Interrut Status */
1366 uint32_t CIS9:1; /* Channel 9 Interrut Status */
1367 uint32_t CIS8:1; /* Channel 8 Interrut Status */
1368 uint32_t CIS7:1; /* Channel 7 Interrut Status */
1369 uint32_t CIS6:1; /* Channel 6 Interrut Status */
1370 uint32_t CIS5:1; /* Channel 5 Interrut Status */
1371 uint32_t CIS4:1; /* Channel 4 Interrut Status */
1372 uint32_t CIS3:1; /* Channel 3 Interrut Status */
1373 uint32_t CIS2:1; /* Channel 2 Interrut Status */
1374 uint32_t CIS1:1; /* Channel 1 Interrupt Status */
1375 uint32_t CIS0:1; /* Channel 0 Interrupt Status */
1376 } B;
1377 } CISR_B;
1378
1379 uint32_t etpu_reserved9[2];
1380
1381 union { /* ETPU_A Data Transfer Request Status */
1382 uint32_t R;
1383 struct {
1384 uint32_t DTRS31:1; /* Channel 31 Data Transfer Request Status */
1385 uint32_t DTRS30:1; /* Channel 30 Data Transfer Request Status */
1386 uint32_t DTRS29:1; /* Channel 29 Data Transfer Request Status */
1387 uint32_t DTRS28:1; /* Channel 28 Data Transfer Request Status */
1388 uint32_t DTRS27:1; /* Channel 27 Data Transfer Request Status */
1389 uint32_t DTRS26:1; /* Channel 26 Data Transfer Request Status */
1390 uint32_t DTRS25:1; /* Channel 25 Data Transfer Request Status */
1391 uint32_t DTRS24:1; /* Channel 24 Data Transfer Request Status */
1392 uint32_t DTRS23:1; /* Channel 23 Data Transfer Request Status */
1393 uint32_t DTRS22:1; /* Channel 22 Data Transfer Request Status */
1394 uint32_t DTRS21:1; /* Channel 21 Data Transfer Request Status */
1395 uint32_t DTRS20:1; /* Channel 20 Data Transfer Request Status */
1396 uint32_t DTRS19:1; /* Channel 19 Data Transfer Request Status */
1397 uint32_t DTRS18:1; /* Channel 18 Data Transfer Request Status */
1398 uint32_t DTRS17:1; /* Channel 17 Data Transfer Request Status */
1399 uint32_t DTRS16:1; /* Channel 16 Data Transfer Request Status */
1400 uint32_t DTRS15:1; /* Channel 15 Data Transfer Request Status */
1401 uint32_t DTRS14:1; /* Channel 14 Data Transfer Request Status */
1402 uint32_t DTRS13:1; /* Channel 13 Data Transfer Request Status */
1403 uint32_t DTRS12:1; /* Channel 12 Data Transfer Request Status */
1404 uint32_t DTRS11:1; /* Channel 11 Data Transfer Request Status */
1405 uint32_t DTRS10:1; /* Channel 10 Data Transfer Request Status */
1406 uint32_t DTRS9:1; /* Channel 9 Data Transfer Request Status */
1407 uint32_t DTRS8:1; /* Channel 8 Data Transfer Request Status */
1408 uint32_t DTRS7:1; /* Channel 7 Data Transfer Request Status */
1409 uint32_t DTRS6:1; /* Channel 6 Data Transfer Request Status */
1410 uint32_t DTRS5:1; /* Channel 5 Data Transfer Request Status */
1411 uint32_t DTRS4:1; /* Channel 4 Data Transfer Request Status */
1412 uint32_t DTRS3:1; /* Channel 3 Data Transfer Request Status */
1413 uint32_t DTRS2:1; /* Channel 2 Data Transfer Request Status */
1414 uint32_t DTRS1:1; /* Channel 1 Data Transfer Request Status */
1415 uint32_t DTRS0:1; /* Channel 0 Data Transfer Request Status */
1416 } B;
1417 } CDTRSR_A;
1418
1419 union { /* ETPU_B Data Transfer Request Status */
1420 uint32_t R;
1421 struct {
1422 uint32_t DTRS31:1; /* Channel 31 Data Transfer Request Status */
1423 uint32_t DTRS30:1; /* Channel 30 Data Transfer Request Status */
1424 uint32_t DTRS29:1; /* Channel 29 Data Transfer Request Status */
1425 uint32_t DTRS28:1; /* Channel 28 Data Transfer Request Status */
1426 uint32_t DTRS27:1; /* Channel 27 Data Transfer Request Status */
1427 uint32_t DTRS26:1; /* Channel 26 Data Transfer Request Status */
1428 uint32_t DTRS25:1; /* Channel 25 Data Transfer Request Status */
1429 uint32_t DTRS24:1; /* Channel 24 Data Transfer Request Status */
1430 uint32_t DTRS23:1; /* Channel 23 Data Transfer Request Status */
1431 uint32_t DTRS22:1; /* Channel 22 Data Transfer Request Status */
1432 uint32_t DTRS21:1; /* Channel 21 Data Transfer Request Status */
1433 uint32_t DTRS20:1; /* Channel 20 Data Transfer Request Status */
1434 uint32_t DTRS19:1; /* Channel 19 Data Transfer Request Status */
1435 uint32_t DTRS18:1; /* Channel 18 Data Transfer Request Status */
1436 uint32_t DTRS17:1; /* Channel 17 Data Transfer Request Status */
1437 uint32_t DTRS16:1; /* Channel 16 Data Transfer Request Status */
1438 uint32_t DTRS15:1; /* Channel 15 Data Transfer Request Status */
1439 uint32_t DTRS14:1; /* Channel 14 Data Transfer Request Status */
1440 uint32_t DTRS13:1; /* Channel 13 Data Transfer Request Status */
1441 uint32_t DTRS12:1; /* Channel 12 Data Transfer Request Status */
1442 uint32_t DTRS11:1; /* Channel 11 Data Transfer Request Status */
1443 uint32_t DTRS10:1; /* Channel 10 Data Transfer Request Status */
1444 uint32_t DTRS9:1; /* Channel 9 Data Transfer Request Status */
1445 uint32_t DTRS8:1; /* Channel 8 Data Transfer Request Status */
1446 uint32_t DTRS7:1; /* Channel 7 Data Transfer Request Status */
1447 uint32_t DTRS6:1; /* Channel 6 Data Transfer Request Status */
1448 uint32_t DTRS5:1; /* Channel 5 Data Transfer Request Status */
1449 uint32_t DTRS4:1; /* Channel 4 Data Transfer Request Status */
1450 uint32_t DTRS3:1; /* Channel 3 Data Transfer Request Status */
1451 uint32_t DTRS2:1; /* Channel 2 Data Transfer Request Status */
1452 uint32_t DTRS1:1; /* Channel 1 Data Transfer Request Status */
1453 uint32_t DTRS0:1; /* Channel 0 Data Transfer Request Status */
1454 } B;
1455 } CDTRSR_B;
1456
1457 uint32_t etpu_reserved11[2];
1458
1459 union { /* ETPU_A Interruput Overflow Status */
1460 uint32_t R;
1461 struct {
1462 uint32_t CIOS31:1; /* Channel 31 Interruput Overflow Status */
1463 uint32_t CIOS30:1; /* Channel 30 Interruput Overflow Status */
1464 uint32_t CIOS29:1; /* Channel 29 Interruput Overflow Status */
1465 uint32_t CIOS28:1; /* Channel 28 Interruput Overflow Status */
1466 uint32_t CIOS27:1; /* Channel 27 Interruput Overflow Status */
1467 uint32_t CIOS26:1; /* Channel 26 Interruput Overflow Status */
1468 uint32_t CIOS25:1; /* Channel 25 Interruput Overflow Status */
1469 uint32_t CIOS24:1; /* Channel 24 Interruput Overflow Status */
1470 uint32_t CIOS23:1; /* Channel 23 Interruput Overflow Status */
1471 uint32_t CIOS22:1; /* Channel 22 Interruput Overflow Status */
1472 uint32_t CIOS21:1; /* Channel 21 Interruput Overflow Status */
1473 uint32_t CIOS20:1; /* Channel 20 Interruput Overflow Status */
1474 uint32_t CIOS19:1; /* Channel 19 Interruput Overflow Status */
1475 uint32_t CIOS18:1; /* Channel 18 Interruput Overflow Status */
1476 uint32_t CIOS17:1; /* Channel 17 Interruput Overflow Status */
1477 uint32_t CIOS16:1; /* Channel 16 Interruput Overflow Status */
1478 uint32_t CIOS15:1; /* Channel 15 Interruput Overflow Status */
1479 uint32_t CIOS14:1; /* Channel 14 Interruput Overflow Status */
1480 uint32_t CIOS13:1; /* Channel 13 Interruput Overflow Status */
1481 uint32_t CIOS12:1; /* Channel 12 Interruput Overflow Status */
1482 uint32_t CIOS11:1; /* Channel 11 Interruput Overflow Status */
1483 uint32_t CIOS10:1; /* Channel 10 Interruput Overflow Status */
1484 uint32_t CIOS9:1; /* Channel 9 Interruput Overflow Status */
1485 uint32_t CIOS8:1; /* Channel 8 Interruput Overflow Status */
1486 uint32_t CIOS7:1; /* Channel 7 Interruput Overflow Status */
1487 uint32_t CIOS6:1; /* Channel 6 Interruput Overflow Status */
1488 uint32_t CIOS5:1; /* Channel 5 Interruput Overflow Status */
1489 uint32_t CIOS4:1; /* Channel 4 Interruput Overflow Status */
1490 uint32_t CIOS3:1; /* Channel 3 Interruput Overflow Status */
1491 uint32_t CIOS2:1; /* Channel 2 Interruput Overflow Status */
1492 uint32_t CIOS1:1; /* Channel 1 Interruput Overflow Status */
1493 uint32_t CIOS0:1; /* Channel 0 Interruput Overflow Status */
1494 } B;
1495 } CIOSR_A;
1496
1497 union { /* ETPU_B Interruput Overflow Status */
1498 uint32_t R;
1499 struct {
1500 uint32_t CIOS31:1; /* Channel 31 Interruput Overflow Status */
1501 uint32_t CIOS30:1; /* Channel 30 Interruput Overflow Status */
1502 uint32_t CIOS29:1; /* Channel 29 Interruput Overflow Status */
1503 uint32_t CIOS28:1; /* Channel 28 Interruput Overflow Status */
1504 uint32_t CIOS27:1; /* Channel 27 Interruput Overflow Status */
1505 uint32_t CIOS26:1; /* Channel 26 Interruput Overflow Status */
1506 uint32_t CIOS25:1; /* Channel 25 Interruput Overflow Status */
1507 uint32_t CIOS24:1; /* Channel 24 Interruput Overflow Status */
1508 uint32_t CIOS23:1; /* Channel 23 Interruput Overflow Status */
1509 uint32_t CIOS22:1; /* Channel 22 Interruput Overflow Status */
1510 uint32_t CIOS21:1; /* Channel 21 Interruput Overflow Status */
1511 uint32_t CIOS20:1; /* Channel 20 Interruput Overflow Status */
1512 uint32_t CIOS19:1; /* Channel 19 Interruput Overflow Status */
1513 uint32_t CIOS18:1; /* Channel 18 Interruput Overflow Status */
1514 uint32_t CIOS17:1; /* Channel 17 Interruput Overflow Status */
1515 uint32_t CIOS16:1; /* Channel 16 Interruput Overflow Status */
1516 uint32_t CIOS15:1; /* Channel 15 Interruput Overflow Status */
1517 uint32_t CIOS14:1; /* Channel 14 Interruput Overflow Status */
1518 uint32_t CIOS13:1; /* Channel 13 Interruput Overflow Status */
1519 uint32_t CIOS12:1; /* Channel 12 Interruput Overflow Status */
1520 uint32_t CIOS11:1; /* Channel 11 Interruput Overflow Status */
1521 uint32_t CIOS10:1; /* Channel 10 Interruput Overflow Status */
1522 uint32_t CIOS9:1; /* Channel 9 Interruput Overflow Status */
1523 uint32_t CIOS8:1; /* Channel 8 Interruput Overflow Status */
1524 uint32_t CIOS7:1; /* Channel 7 Interruput Overflow Status */
1525 uint32_t CIOS6:1; /* Channel 6 Interruput Overflow Status */
1526 uint32_t CIOS5:1; /* Channel 5 Interruput Overflow Status */
1527 uint32_t CIOS4:1; /* Channel 4 Interruput Overflow Status */
1528 uint32_t CIOS3:1; /* Channel 3 Interruput Overflow Status */
1529 uint32_t CIOS2:1; /* Channel 2 Interruput Overflow Status */
1530 uint32_t CIOS1:1; /* Channel 1 Interruput Overflow Status */
1531 uint32_t CIOS0:1; /* Channel 0 Interruput Overflow Status */
1532 } B;
1533 } CIOSR_B;
1534
1535 uint32_t etpu_reserved13[2];
1536
1537 union { /* ETPU_A Data Transfer Overflow Status */
1538 uint32_t R;
1539 struct {
1540 uint32_t DTROS31:1; /* Channel 31 Data Transfer Overflow Status */
1541 uint32_t DTROS30:1; /* Channel 30 Data Transfer Overflow Status */
1542 uint32_t DTROS29:1; /* Channel 29 Data Transfer Overflow Status */
1543 uint32_t DTROS28:1; /* Channel 28 Data Transfer Overflow Status */
1544 uint32_t DTROS27:1; /* Channel 27 Data Transfer Overflow Status */
1545 uint32_t DTROS26:1; /* Channel 26 Data Transfer Overflow Status */
1546 uint32_t DTROS25:1; /* Channel 25 Data Transfer Overflow Status */
1547 uint32_t DTROS24:1; /* Channel 24 Data Transfer Overflow Status */
1548 uint32_t DTROS23:1; /* Channel 23 Data Transfer Overflow Status */
1549 uint32_t DTROS22:1; /* Channel 22 Data Transfer Overflow Status */
1550 uint32_t DTROS21:1; /* Channel 21 Data Transfer Overflow Status */
1551 uint32_t DTROS20:1; /* Channel 20 Data Transfer Overflow Status */
1552 uint32_t DTROS19:1; /* Channel 19 Data Transfer Overflow Status */
1553 uint32_t DTROS18:1; /* Channel 18 Data Transfer Overflow Status */
1554 uint32_t DTROS17:1; /* Channel 17 Data Transfer Overflow Status */
1555 uint32_t DTROS16:1; /* Channel 16 Data Transfer Overflow Status */
1556 uint32_t DTROS15:1; /* Channel 15 Data Transfer Overflow Status */
1557 uint32_t DTROS14:1; /* Channel 14 Data Transfer Overflow Status */
1558 uint32_t DTROS13:1; /* Channel 13 Data Transfer Overflow Status */
1559 uint32_t DTROS12:1; /* Channel 12 Data Transfer Overflow Status */
1560 uint32_t DTROS11:1; /* Channel 11 Data Transfer Overflow Status */
1561 uint32_t DTROS10:1; /* Channel 10 Data Transfer Overflow Status */
1562 uint32_t DTROS9:1; /* Channel 9 Data Transfer Overflow Status */
1563 uint32_t DTROS8:1; /* Channel 8 Data Transfer Overflow Status */
1564 uint32_t DTROS7:1; /* Channel 7 Data Transfer Overflow Status */
1565 uint32_t DTROS6:1; /* Channel 6 Data Transfer Overflow Status */
1566 uint32_t DTROS5:1; /* Channel 5 Data Transfer Overflow Status */
1567 uint32_t DTROS4:1; /* Channel 4 Data Transfer Overflow Status */
1568 uint32_t DTROS3:1; /* Channel 3 Data Transfer Overflow Status */
1569 uint32_t DTROS2:1; /* Channel 2 Data Transfer Overflow Status */
1570 uint32_t DTROS1:1; /* Channel 1 Data Transfer Overflow Status */
1571 uint32_t DTROS0:1; /* Channel 0 Data Transfer Overflow Status */
1572 } B;
1573 } CDTROSR_A;
1574
1575 union { /* ETPU_B Data Transfer Overflow Status */
1576 uint32_t R;
1577 struct {
1578 uint32_t DTROS31:1; /* Channel 31 Data Transfer Overflow Status */
1579 uint32_t DTROS30:1; /* Channel 30 Data Transfer Overflow Status */
1580 uint32_t DTROS29:1; /* Channel 29 Data Transfer Overflow Status */
1581 uint32_t DTROS28:1; /* Channel 28 Data Transfer Overflow Status */
1582 uint32_t DTROS27:1; /* Channel 27 Data Transfer Overflow Status */
1583 uint32_t DTROS26:1; /* Channel 26 Data Transfer Overflow Status */
1584 uint32_t DTROS25:1; /* Channel 25 Data Transfer Overflow Status */
1585 uint32_t DTROS24:1; /* Channel 24 Data Transfer Overflow Status */
1586 uint32_t DTROS23:1; /* Channel 23 Data Transfer Overflow Status */
1587 uint32_t DTROS22:1; /* Channel 22 Data Transfer Overflow Status */
1588 uint32_t DTROS21:1; /* Channel 21 Data Transfer Overflow Status */
1589 uint32_t DTROS20:1; /* Channel 20 Data Transfer Overflow Status */
1590 uint32_t DTROS19:1; /* Channel 19 Data Transfer Overflow Status */
1591 uint32_t DTROS18:1; /* Channel 18 Data Transfer Overflow Status */
1592 uint32_t DTROS17:1; /* Channel 17 Data Transfer Overflow Status */
1593 uint32_t DTROS16:1; /* Channel 16 Data Transfer Overflow Status */
1594 uint32_t DTROS15:1; /* Channel 15 Data Transfer Overflow Status */
1595 uint32_t DTROS14:1; /* Channel 14 Data Transfer Overflow Status */
1596 uint32_t DTROS13:1; /* Channel 13 Data Transfer Overflow Status */
1597 uint32_t DTROS12:1; /* Channel 12 Data Transfer Overflow Status */
1598 uint32_t DTROS11:1; /* Channel 11 Data Transfer Overflow Status */
1599 uint32_t DTROS10:1; /* Channel 10 Data Transfer Overflow Status */
1600 uint32_t DTROS9:1; /* Channel 9 Data Transfer Overflow Status */
1601 uint32_t DTROS8:1; /* Channel 8 Data Transfer Overflow Status */
1602 uint32_t DTROS7:1; /* Channel 7 Data Transfer Overflow Status */
1603 uint32_t DTROS6:1; /* Channel 6 Data Transfer Overflow Status */
1604 uint32_t DTROS5:1; /* Channel 5 Data Transfer Overflow Status */
1605 uint32_t DTROS4:1; /* Channel 4 Data Transfer Overflow Status */
1606 uint32_t DTROS3:1; /* Channel 3 Data Transfer Overflow Status */
1607 uint32_t DTROS2:1; /* Channel 2 Data Transfer Overflow Status */
1608 uint32_t DTROS1:1; /* Channel 1 Data Transfer Overflow Status */
1609 uint32_t DTROS0:1; /* Channel 0 Data Transfer Overflow Status */
1610 } B;
1611 } CDTROSR_B;
1612
1613 uint32_t etpu_reserved15[2];
1614
1615 union { /* ETPU_A Channel Interruput Enable */
1616 uint32_t R;
1617 struct {
1618 uint32_t CIE31:1; /* Channel 31 Interruput Enable */
1619 uint32_t CIE30:1; /* Channel 30 Interruput Enable */
1620 uint32_t CIE29:1; /* Channel 29 Interruput Enable */
1621 uint32_t CIE28:1; /* Channel 28 Interruput Enable */
1622 uint32_t CIE27:1; /* Channel 27 Interruput Enable */
1623 uint32_t CIE26:1; /* Channel 26 Interruput Enable */
1624 uint32_t CIE25:1; /* Channel 25 Interruput Enable */
1625 uint32_t CIE24:1; /* Channel 24 Interruput Enable */
1626 uint32_t CIE23:1; /* Channel 23 Interruput Enable */
1627 uint32_t CIE22:1; /* Channel 22 Interruput Enable */
1628 uint32_t CIE21:1; /* Channel 21 Interruput Enable */
1629 uint32_t CIE20:1; /* Channel 20 Interruput Enable */
1630 uint32_t CIE19:1; /* Channel 19 Interruput Enable */
1631 uint32_t CIE18:1; /* Channel 18 Interruput Enable */
1632 uint32_t CIE17:1; /* Channel 17 Interruput Enable */
1633 uint32_t CIE16:1; /* Channel 16 Interruput Enable */
1634 uint32_t CIE15:1; /* Channel 15 Interruput Enable */
1635 uint32_t CIE14:1; /* Channel 14 Interruput Enable */
1636 uint32_t CIE13:1; /* Channel 13 Interruput Enable */
1637 uint32_t CIE12:1; /* Channel 12 Interruput Enable */
1638 uint32_t CIE11:1; /* Channel 11 Interruput Enable */
1639 uint32_t CIE10:1; /* Channel 10 Interruput Enable */
1640 uint32_t CIE9:1; /* Channel 9 Interruput Enable */
1641 uint32_t CIE8:1; /* Channel 8 Interruput Enable */
1642 uint32_t CIE7:1; /* Channel 7 Interruput Enable */
1643 uint32_t CIE6:1; /* Channel 6 Interruput Enable */
1644 uint32_t CIE5:1; /* Channel 5 Interruput Enable */
1645 uint32_t CIE4:1; /* Channel 4 Interruput Enable */
1646 uint32_t CIE3:1; /* Channel 3 Interruput Enable */
1647 uint32_t CIE2:1; /* Channel 2 Interruput Enable */
1648 uint32_t CIE1:1; /* Channel 1 Interruput Enable */
1649 uint32_t CIE0:1; /* Channel 0 Interruput Enable */
1650 } B;
1651 } CIER_A;
1652
1653 union { /* ETPU_B Channel Interruput Enable */
1654 uint32_t R;
1655 struct {
1656 uint32_t CIE31:1; /* Channel 31 Interruput Enable */
1657 uint32_t CIE30:1; /* Channel 30 Interruput Enable */
1658 uint32_t CIE29:1; /* Channel 29 Interruput Enable */
1659 uint32_t CIE28:1; /* Channel 28 Interruput Enable */
1660 uint32_t CIE27:1; /* Channel 27 Interruput Enable */
1661 uint32_t CIE26:1; /* Channel 26 Interruput Enable */
1662 uint32_t CIE25:1; /* Channel 25 Interruput Enable */
1663 uint32_t CIE24:1; /* Channel 24 Interruput Enable */
1664 uint32_t CIE23:1; /* Channel 23 Interruput Enable */
1665 uint32_t CIE22:1; /* Channel 22 Interruput Enable */
1666 uint32_t CIE21:1; /* Channel 21 Interruput Enable */
1667 uint32_t CIE20:1; /* Channel 20 Interruput Enable */
1668 uint32_t CIE19:1; /* Channel 19 Interruput Enable */
1669 uint32_t CIE18:1; /* Channel 18 Interruput Enable */
1670 uint32_t CIE17:1; /* Channel 17 Interruput Enable */
1671 uint32_t CIE16:1; /* Channel 16 Interruput Enable */
1672 uint32_t CIE15:1; /* Channel 15 Interruput Enable */
1673 uint32_t CIE14:1; /* Channel 14 Interruput Enable */
1674 uint32_t CIE13:1; /* Channel 13 Interruput Enable */
1675 uint32_t CIE12:1; /* Channel 12 Interruput Enable */
1676 uint32_t CIE11:1; /* Channel 11 Interruput Enable */
1677 uint32_t CIE10:1; /* Channel 10 Interruput Enable */
1678 uint32_t CIE9:1; /* Channel 9 Interruput Enable */
1679 uint32_t CIE8:1; /* Channel 8 Interruput Enable */
1680 uint32_t CIE7:1; /* Channel 7 Interruput Enable */
1681 uint32_t CIE6:1; /* Channel 6 Interruput Enable */
1682 uint32_t CIE5:1; /* Channel 5 Interruput Enable */
1683 uint32_t CIE4:1; /* Channel 4 Interruput Enable */
1684 uint32_t CIE3:1; /* Channel 3 Interruput Enable */
1685 uint32_t CIE2:1; /* Channel 2 Interruput Enable */
1686 uint32_t CIE1:1; /* Channel 1 Interruput Enable */
1687 uint32_t CIE0:1; /* Channel 0 Interruput Enable */
1688 } B;
1689 } CIER_B;
1690
1691 uint32_t etpu_reserved17[2];
1692
1693 union { /* ETPU_A Channel Data Transfer Request Enable */
1694 uint32_t R;
1695 struct {
1696 uint32_t DTRE31:1; /* Channel 31 Data Transfer Request Enable */
1697 uint32_t DTRE30:1; /* Channel 30 Data Transfer Request Enable */
1698 uint32_t DTRE29:1; /* Channel 29 Data Transfer Request Enable */
1699 uint32_t DTRE28:1; /* Channel 28 Data Transfer Request Enable */
1700 uint32_t DTRE27:1; /* Channel 27 Data Transfer Request Enable */
1701 uint32_t DTRE26:1; /* Channel 26 Data Transfer Request Enable */
1702 uint32_t DTRE25:1; /* Channel 25 Data Transfer Request Enable */
1703 uint32_t DTRE24:1; /* Channel 24 Data Transfer Request Enable */
1704 uint32_t DTRE23:1; /* Channel 23 Data Transfer Request Enable */
1705 uint32_t DTRE22:1; /* Channel 22 Data Transfer Request Enable */
1706 uint32_t DTRE21:1; /* Channel 21 Data Transfer Request Enable */
1707 uint32_t DTRE20:1; /* Channel 20 Data Transfer Request Enable */
1708 uint32_t DTRE19:1; /* Channel 19 Data Transfer Request Enable */
1709 uint32_t DTRE18:1; /* Channel 18 Data Transfer Request Enable */
1710 uint32_t DTRE17:1; /* Channel 17 Data Transfer Request Enable */
1711 uint32_t DTRE16:1; /* Channel 16 Data Transfer Request Enable */
1712 uint32_t DTRE15:1; /* Channel 15 Data Transfer Request Enable */
1713 uint32_t DTRE14:1; /* Channel 14 Data Transfer Request Enable */
1714 uint32_t DTRE13:1; /* Channel 13 Data Transfer Request Enable */
1715 uint32_t DTRE12:1; /* Channel 12 Data Transfer Request Enable */
1716 uint32_t DTRE11:1; /* Channel 11 Data Transfer Request Enable */
1717 uint32_t DTRE10:1; /* Channel 10 Data Transfer Request Enable */
1718 uint32_t DTRE9:1; /* Channel 9 Data Transfer Request Enable */
1719 uint32_t DTRE8:1; /* Channel 8 Data Transfer Request Enable */
1720 uint32_t DTRE7:1; /* Channel 7 Data Transfer Request Enable */
1721 uint32_t DTRE6:1; /* Channel 6 Data Transfer Request Enable */
1722 uint32_t DTRE5:1; /* Channel 5 Data Transfer Request Enable */
1723 uint32_t DTRE4:1; /* Channel 4 Data Transfer Request Enable */
1724 uint32_t DTRE3:1; /* Channel 3 Data Transfer Request Enable */
1725 uint32_t DTRE2:1; /* Channel 2 Data Transfer Request Enable */
1726 uint32_t DTRE1:1; /* Channel 1 Data Transfer Request Enable */
1727 uint32_t DTRE0:1; /* Channel 0 Data Transfer Request Enable */
1728 } B;
1729 } CDTRER_A;
1730
1731 union { /* ETPU_B Channel Data Transfer Request Enable */
1732 uint32_t R;
1733 struct {
1734 uint32_t DTRE31:1; /* Channel 31 Data Transfer Request Enable */
1735 uint32_t DTRE30:1; /* Channel 30 Data Transfer Request Enable */
1736 uint32_t DTRE29:1; /* Channel 29 Data Transfer Request Enable */
1737 uint32_t DTRE28:1; /* Channel 28 Data Transfer Request Enable */
1738 uint32_t DTRE27:1; /* Channel 27 Data Transfer Request Enable */
1739 uint32_t DTRE26:1; /* Channel 26 Data Transfer Request Enable */
1740 uint32_t DTRE25:1; /* Channel 25 Data Transfer Request Enable */
1741 uint32_t DTRE24:1; /* Channel 24 Data Transfer Request Enable */
1742 uint32_t DTRE23:1; /* Channel 23 Data Transfer Request Enable */
1743 uint32_t DTRE22:1; /* Channel 22 Data Transfer Request Enable */
1744 uint32_t DTRE21:1; /* Channel 21 Data Transfer Request Enable */
1745 uint32_t DTRE20:1; /* Channel 20 Data Transfer Request Enable */
1746 uint32_t DTRE19:1; /* Channel 19 Data Transfer Request Enable */
1747 uint32_t DTRE18:1; /* Channel 18 Data Transfer Request Enable */
1748 uint32_t DTRE17:1; /* Channel 17 Data Transfer Request Enable */
1749 uint32_t DTRE16:1; /* Channel 16 Data Transfer Request Enable */
1750 uint32_t DTRE15:1; /* Channel 15 Data Transfer Request Enable */
1751 uint32_t DTRE14:1; /* Channel 14 Data Transfer Request Enable */
1752 uint32_t DTRE13:1; /* Channel 13 Data Transfer Request Enable */
1753 uint32_t DTRE12:1; /* Channel 12 Data Transfer Request Enable */
1754 uint32_t DTRE11:1; /* Channel 11 Data Transfer Request Enable */
1755 uint32_t DTRE10:1; /* Channel 10 Data Transfer Request Enable */
1756 uint32_t DTRE9:1; /* Channel 9 Data Transfer Request Enable */
1757 uint32_t DTRE8:1; /* Channel 8 Data Transfer Request Enable */
1758 uint32_t DTRE7:1; /* Channel 7 Data Transfer Request Enable */
1759 uint32_t DTRE6:1; /* Channel 6 Data Transfer Request Enable */
1760 uint32_t DTRE5:1; /* Channel 5 Data Transfer Request Enable */
1761 uint32_t DTRE4:1; /* Channel 4 Data Transfer Request Enable */
1762 uint32_t DTRE3:1; /* Channel 3 Data Transfer Request Enable */
1763 uint32_t DTRE2:1; /* Channel 2 Data Transfer Request Enable */
1764 uint32_t DTRE1:1; /* Channel 1 Data Transfer Request Enable */
1765 uint32_t DTRE0:1; /* Channel 0 Data Transfer Request Enable */
1766 } B;
1767 } CDTRER_B;
1768
1769 uint32_t etpu_reserved20[10];
1770 union { /* ETPU_A Channel Pending Service Status */
1771 uint32_t R;
1772 struct {
1773 uint32_t SR31:1; /* Channel 31 Pending Service Status */
1774 uint32_t SR30:1; /* Channel 30 Pending Service Status */
1775 uint32_t SR29:1; /* Channel 29 Pending Service Status */
1776 uint32_t SR28:1; /* Channel 28 Pending Service Status */
1777 uint32_t SR27:1; /* Channel 27 Pending Service Status */
1778 uint32_t SR26:1; /* Channel 26 Pending Service Status */
1779 uint32_t SR25:1; /* Channel 25 Pending Service Status */
1780 uint32_t SR24:1; /* Channel 24 Pending Service Status */
1781 uint32_t SR23:1; /* Channel 23 Pending Service Status */
1782 uint32_t SR22:1; /* Channel 22 Pending Service Status */
1783 uint32_t SR21:1; /* Channel 21 Pending Service Status */
1784 uint32_t SR20:1; /* Channel 20 Pending Service Status */
1785 uint32_t SR19:1; /* Channel 19 Pending Service Status */
1786 uint32_t SR18:1; /* Channel 18 Pending Service Status */
1787 uint32_t SR17:1; /* Channel 17 Pending Service Status */
1788 uint32_t SR16:1; /* Channel 16 Pending Service Status */
1789 uint32_t SR15:1; /* Channel 15 Pending Service Status */
1790 uint32_t SR14:1; /* Channel 14 Pending Service Status */
1791 uint32_t SR13:1; /* Channel 13 Pending Service Status */
1792 uint32_t SR12:1; /* Channel 12 Pending Service Status */
1793 uint32_t SR11:1; /* Channel 11 Pending Service Status */
1794 uint32_t SR10:1; /* Channel 10 Pending Service Status */
1795 uint32_t SR9:1; /* Channel 9 Pending Service Status */
1796 uint32_t SR8:1; /* Channel 8 Pending Service Status */
1797 uint32_t SR7:1; /* Channel 7 Pending Service Status */
1798 uint32_t SR6:1; /* Channel 6 Pending Service Status */
1799 uint32_t SR5:1; /* Channel 5 Pending Service Status */
1800 uint32_t SR4:1; /* Channel 4 Pending Service Status */
1801 uint32_t SR3:1; /* Channel 3 Pending Service Status */
1802 uint32_t SR2:1; /* Channel 2 Pending Service Status */
1803 uint32_t SR1:1; /* Channel 1 Pending Service Status */
1804 uint32_t SR0:1; /* Channel 0 Pending Service Status */
1805 } B;
1806 } CPSSR_A;
1807
1808 union { /* ETPU_B Channel Pending Service Status */
1809 uint32_t R;
1810 struct {
1811 uint32_t SR31:1; /* Channel 31 Pending Service Status */
1812 uint32_t SR30:1; /* Channel 30 Pending Service Status */
1813 uint32_t SR29:1; /* Channel 29 Pending Service Status */
1814 uint32_t SR28:1; /* Channel 28 Pending Service Status */
1815 uint32_t SR27:1; /* Channel 27 Pending Service Status */
1816 uint32_t SR26:1; /* Channel 26 Pending Service Status */
1817 uint32_t SR25:1; /* Channel 25 Pending Service Status */
1818 uint32_t SR24:1; /* Channel 24 Pending Service Status */
1819 uint32_t SR23:1; /* Channel 23 Pending Service Status */
1820 uint32_t SR22:1; /* Channel 22 Pending Service Status */
1821 uint32_t SR21:1; /* Channel 21 Pending Service Status */
1822 uint32_t SR20:1; /* Channel 20 Pending Service Status */
1823 uint32_t SR19:1; /* Channel 19 Pending Service Status */
1824 uint32_t SR18:1; /* Channel 18 Pending Service Status */
1825 uint32_t SR17:1; /* Channel 17 Pending Service Status */
1826 uint32_t SR16:1; /* Channel 16 Pending Service Status */
1827 uint32_t SR15:1; /* Channel 15 Pending Service Status */
1828 uint32_t SR14:1; /* Channel 14 Pending Service Status */
1829 uint32_t SR13:1; /* Channel 13 Pending Service Status */
1830 uint32_t SR12:1; /* Channel 12 Pending Service Status */
1831 uint32_t SR11:1; /* Channel 11 Pending Service Status */
1832 uint32_t SR10:1; /* Channel 10 Pending Service Status */
1833 uint32_t SR9:1; /* Channel 9 Pending Service Status */
1834 uint32_t SR8:1; /* Channel 8 Pending Service Status */
1835 uint32_t SR7:1; /* Channel 7 Pending Service Status */
1836 uint32_t SR6:1; /* Channel 6 Pending Service Status */
1837 uint32_t SR5:1; /* Channel 5 Pending Service Status */
1838 uint32_t SR4:1; /* Channel 4 Pending Service Status */
1839 uint32_t SR3:1; /* Channel 3 Pending Service Status */
1840 uint32_t SR2:1; /* Channel 2 Pending Service Status */
1841 uint32_t SR1:1; /* Channel 1 Pending Service Status */
1842 uint32_t SR0:1; /* Channel 0 Pending Service Status */
1843 } B;
1844 } CPSSR_B;
1845
1846 uint32_t etpu_reserved20a[2];
1847
1848 union { /* ETPU_A Channel Service Status */
1849 uint32_t R;
1850 struct {
1851 uint32_t SS31:1; /* Channel 31 Service Status */
1852 uint32_t SS30:1; /* Channel 30 Service Status */
1853 uint32_t SS29:1; /* Channel 29 Service Status */
1854 uint32_t SS28:1; /* Channel 28 Service Status */
1855 uint32_t SS27:1; /* Channel 27 Service Status */
1856 uint32_t SS26:1; /* Channel 26 Service Status */
1857 uint32_t SS25:1; /* Channel 25 Service Status */
1858 uint32_t SS24:1; /* Channel 24 Service Status */
1859 uint32_t SS23:1; /* Channel 23 Service Status */
1860 uint32_t SS22:1; /* Channel 22 Service Status */
1861 uint32_t SS21:1; /* Channel 21 Service Status */
1862 uint32_t SS20:1; /* Channel 20 Service Status */
1863 uint32_t SS19:1; /* Channel 19 Service Status */
1864 uint32_t SS18:1; /* Channel 18 Service Status */
1865 uint32_t SS17:1; /* Channel 17 Service Status */
1866 uint32_t SS16:1; /* Channel 16 Service Status */
1867 uint32_t SS15:1; /* Channel 15 Service Status */
1868 uint32_t SS14:1; /* Channel 14 Service Status */
1869 uint32_t SS13:1; /* Channel 13 Service Status */
1870 uint32_t SS12:1; /* Channel 12 Service Status */
1871 uint32_t SS11:1; /* Channel 11 Service Status */
1872 uint32_t SS10:1; /* Channel 10 Service Status */
1873 uint32_t SS9:1; /* Channel 9 Service Status */
1874 uint32_t SS8:1; /* Channel 8 Service Status */
1875 uint32_t SS7:1; /* Channel 7 Service Status */
1876 uint32_t SS6:1; /* Channel 6 Service Status */
1877 uint32_t SS5:1; /* Channel 5 Service Status */
1878 uint32_t SS4:1; /* Channel 4 Service Status */
1879 uint32_t SS3:1; /* Channel 3 Service Status */
1880 uint32_t SS2:1; /* Channel 2 Service Status */
1881 uint32_t SS1:1; /* Channel 1 Service Status */
1882 uint32_t SS0:1; /* Channel 0 Service Status */
1883 } B;
1884 } CSSR_A;
1885
1886 union { /* ETPU_B Channel Service Status */
1887 uint32_t R;
1888 struct {
1889 uint32_t SS31:1; /* Channel 31 Service Status */
1890 uint32_t SS30:1; /* Channel 30 Service Status */
1891 uint32_t SS29:1; /* Channel 29 Service Status */
1892 uint32_t SS28:1; /* Channel 28 Service Status */
1893 uint32_t SS27:1; /* Channel 27 Service Status */
1894 uint32_t SS26:1; /* Channel 26 Service Status */
1895 uint32_t SS25:1; /* Channel 25 Service Status */
1896 uint32_t SS24:1; /* Channel 24 Service Status */
1897 uint32_t SS23:1; /* Channel 23 Service Status */
1898 uint32_t SS22:1; /* Channel 22 Service Status */
1899 uint32_t SS21:1; /* Channel 21 Service Status */
1900 uint32_t SS20:1; /* Channel 20 Service Status */
1901 uint32_t SS19:1; /* Channel 19 Service Status */
1902 uint32_t SS18:1; /* Channel 18 Service Status */
1903 uint32_t SS17:1; /* Channel 17 Service Status */
1904 uint32_t SS16:1; /* Channel 16 Service Status */
1905 uint32_t SS15:1; /* Channel 15 Service Status */
1906 uint32_t SS14:1; /* Channel 14 Service Status */
1907 uint32_t SS13:1; /* Channel 13 Service Status */
1908 uint32_t SS12:1; /* Channel 12 Service Status */
1909 uint32_t SS11:1; /* Channel 11 Service Status */
1910 uint32_t SS10:1; /* Channel 10 Service Status */
1911 uint32_t SS9:1; /* Channel 9 Service Status */
1912 uint32_t SS8:1; /* Channel 8 Service Status */
1913 uint32_t SS7:1; /* Channel 7 Service Status */
1914 uint32_t SS6:1; /* Channel 6 Service Status */
1915 uint32_t SS5:1; /* Channel 5 Service Status */
1916 uint32_t SS4:1; /* Channel 4 Service Status */
1917 uint32_t SS3:1; /* Channel 3 Service Status */
1918 uint32_t SS2:1; /* Channel 2 Service Status */
1919 uint32_t SS1:1; /* Channel 1 Service Status */
1920 uint32_t SS0:1; /* Channel 0 Service Status */
1921 } B;
1922 } CSSR_B;
1923
1924 uint32_t etpu_reserved23[90];
1925
1926/*****************************Channels********************************/
1927
1928 struct {
1929 union {
1930 uint32_t R; /* Channel Configuration Register */
1931 struct {
1932 uint32_t CIE:1; /* Channel Interruput Enable */
1933 uint32_t DTRE:1; /* Data Transfer Request Enable */
1934 uint32_t CPR:2; /* Channel Priority */
1935 uint32_t:3;
1936 uint32_t ETCS:1; /* Entry Table Condition Select */
1937 uint32_t:3;
1938 uint32_t CFS:5; /* Channel Function Select */
1939 uint32_t ODIS:1; /* Output disable */
1940 uint32_t OPOL:1; /* output polarity */
1941 uint32_t:3;
1942 uint32_t CPBA:11; /* Channel Parameter Base Address */
1943 } B;
1944 } CR;
1945 union {
1946 uint32_t R; /* Channel Status Control Register */
1947 struct {
1948 uint32_t CIS:1; /* Channel Interruput Status */
1949 uint32_t CIOS:1; /* Channel Interruput Overflow Status */
1950 uint32_t:6;
1951 uint32_t DTRS:1; /* Data Transfer Status */
1952 uint32_t DTROS:1; /* Data Transfer Overflow Status */
1953 uint32_t:6;
1954 uint32_t IPS:1; /* Input Pin State */
1955 uint32_t OPS:1; /* Output Pin State */
1956 uint32_t OBE:1; /* Output Buffer Enable */
1957 uint32_t:11;
1958 uint32_t FM1:1; /* Function mode */
1959 uint32_t FM0:1; /* Function mode */
1960 } B;
1961 } SCR;
1962 union {
1963 uint32_t R; /* Channel Host Service Request Register */
1964 struct {
1965 uint32_t:29; /* Host Service Request */
1966 uint32_t HSR:3;
1967 } B;
1968 } HSRR;
1969 uint32_t etpu_reserved23;
1970 } CHAN[127];
1971
1972 };
1973/****************************************************************************/
1974/* MODULE : XBAR CrossBar */
1975/****************************************************************************/
1976 struct XBAR_tag {
1977 union {
1978 uint32_t R;
1979 struct {
1980 uint32_t:4;
1981
1982 uint32_t:4;
1983
1984 uint32_t:4;
1985
1986 uint32_t:4;
1987
1988 uint32_t:4;
1989
1990 uint32_t:1;
1991 uint32_t MSTR2:3;
1992 uint32_t:1;
1993 uint32_t MSTR1:3;
1994 uint32_t:1;
1995 uint32_t MSTR0:3;
1996 } B;
1997 } MPR0; /* Master Priority Register for Slave Port 0 */
1998
1999 uint32_t xbar_reserved1[3];
2000
2001 union {
2002 uint32_t R;
2003 struct {
2004 uint32_t RO:1;
2005 uint32_t:21;
2006 uint32_t ARB:2;
2007 uint32_t:2;
2008 uint32_t PCTL:2;
2009 uint32_t:1;
2010 uint32_t PARK:3;
2011 } B;
2012 } SGPCR0; /* General Purpose Control Register for Slave Port 0 */
2013
2014 uint32_t xbar_reserved2[59];
2015
2016 union {
2017 uint32_t R;
2018 struct {
2019 uint32_t:4;
2020
2021 uint32_t:4;
2022
2023 uint32_t:4;
2024
2025 uint32_t:4;
2026
2027 uint32_t:4;
2028
2029 uint32_t:1;
2030 uint32_t MSTR2:3;
2031 uint32_t:1;
2032 uint32_t MSTR1:3;
2033 uint32_t:1;
2034 uint32_t MSTR0:3;
2035 } B;
2036 } MPR1; /* Master Priority Register for Slave Port 1 */
2037
2038 uint32_t xbar_reserved3[3];
2039
2040 union {
2041 uint32_t R;
2042 struct {
2043 uint32_t RO:1;
2044 uint32_t:21;
2045 uint32_t ARB:2;
2046 uint32_t:2;
2047 uint32_t PCTL:2;
2048 uint32_t:1;
2049 uint32_t PARK:3;
2050 } B;
2051 } SGPCR1; /* General Purpose Control Register for Slave Port 1 */
2052
2053 uint32_t xbar_reserved4[123];
2054
2055 union {
2056 uint32_t R;
2057 struct {
2058 uint32_t:4;
2059
2060 uint32_t:4;
2061
2062 uint32_t:4;
2063
2064 uint32_t:4;
2065
2066 uint32_t:4;
2067
2068 uint32_t:1;
2069 uint32_t MSTR2:3;
2070 uint32_t:1;
2071 uint32_t MSTR1:3;
2072 uint32_t:1;
2073 uint32_t MSTR0:3;
2074 } B;
2075 } MPR3; /* Master Priority Register for Slave Port 3 */
2076
2077 uint32_t xbar_reserved5[3];
2078
2079 union {
2080 uint32_t R;
2081 struct {
2082 uint32_t RO:1;
2083 uint32_t:21;
2084 uint32_t ARB:2;
2085 uint32_t:2;
2086 uint32_t PCTL:2;
2087 uint32_t:1;
2088 uint32_t PARK:3;
2089 } B;
2090 } SGPCR3; /* General Purpose Control Register for Slave Port 3 */
2091 uint32_t xbar_reserved6[187];
2092
2093 union {
2094 uint32_t R;
2095 struct {
2096 uint32_t:4;
2097
2098 uint32_t:4;
2099
2100 uint32_t:4;
2101
2102 uint32_t:4;
2103
2104 uint32_t:4;
2105
2106 uint32_t:1;
2107 uint32_t MSTR2:3;
2108 uint32_t:1;
2109 uint32_t MSTR1:3;
2110 uint32_t:1;
2111 uint32_t MSTR0:3;
2112 } B;
2113 } MPR6; /* Master Priority Register for Slave Port 6 */
2114
2115 uint32_t xbar_reserved7[3];
2116
2117 union {
2118 uint32_t R;
2119 struct {
2120 uint32_t RO:1;
2121 uint32_t:21;
2122 uint32_t ARB:2;
2123 uint32_t:2;
2124 uint32_t PCTL:2;
2125 uint32_t:1;
2126 uint32_t PARK:3;
2127 } B;
2128 } SGPCR6; /* General Purpose Control Register for Slave Port 6 */
2129
2130 uint32_t xbar_reserved8[59];
2131
2132 union {
2133 uint32_t R;
2134 struct {
2135 uint32_t:4;
2136
2137 uint32_t:4;
2138
2139 uint32_t:4;
2140
2141 uint32_t:4;
2142
2143 uint32_t:4;
2144
2145 uint32_t:1;
2146 uint32_t MSTR2:3;
2147 uint32_t:1;
2148 uint32_t MSTR1:3;
2149 uint32_t:1;
2150 uint32_t MSTR0:3;
2151 } B;
2152 } MPR7; /* Master Priority Register for Slave Port 7 */
2153
2154 uint32_t xbar_reserved9[3];
2155
2156 union {
2157 uint32_t R;
2158 struct {
2159 uint32_t RO:1;
2160 uint32_t:21;
2161 uint32_t ARB:2;
2162 uint32_t:2;
2163 uint32_t PCTL:2;
2164 uint32_t:1;
2165 uint32_t PARK:3;
2166 } B;
2167 } SGPCR7; /* General Purpose Control Register for Slave Port 7 */
2168
2169 };
2170/****************************************************************************/
2171/* MODULE : ECSM */
2172/****************************************************************************/
2173 struct ECSM_tag {
2174
2175 uint32_t ecsm_reserved1[5];
2176
2177 uint16_t ecsm_reserved2;
2178
2179 union {
2180 uint16_t R;
2181 } SWTCR; //Software Watchdog Timer Control
2182
2183 uint8_t ecsm_reserved3[3];
2184
2185 union {
2186 uint8_t R;
2187 } SWTSR; //SWT Service Register
2188
2189 uint8_t ecsm_reserved4[3];
2190
2191 union {
2192 uint8_t R;
2193 } SWTIR; //SWT Interrupt Register
2194
2195 uint32_t ecsm_reserved5a[1];
2196 uint32_t ecsm_reserved5b[1];
2197
2198 uint32_t ecsm_reserved5c[6];
2199
2200 uint8_t ecsm_reserved6[3];
2201
2202 union {
2203 uint8_t R;
2204 struct {
2205 uint8_t:6;
2206 uint8_t ERNCR:1;
2207 uint8_t EFNCR:1;
2208 } B;
2209 } ECR; //ECC Configuration Register
2210
2211 uint8_t mcm_reserved8[3];
2212
2213 union {
2214 uint8_t R;
2215 struct {
2216 uint8_t:6;
2217 uint8_t RNCE:1;
2218 uint8_t FNCE:1;
2219 } B;
2220 } ESR; //ECC Status Register
2221
2222 uint16_t ecsm_reserved9;
2223
2224 union {
2225 uint16_t R;
2226 struct {
2227 uint16_t:6;
2228 uint16_t FRCNCI:1;
2229 uint16_t FR1NCI:1;
2230 uint16_t:1;
2231 uint16_t ERRBIT:7;
2232 } B;
2233 } EEGR; //ECC Error Generation Register
2234
2235 uint32_t ecsm_reserved10;
2236
2237 union {
2238 uint32_t R;
2239 struct {
2240 uint32_t FEAR:32;
2241 } B;
2242 } FEAR; //Flash ECC Address Register
2243
2244 uint16_t ecsm_reserved11;
2245
2246 union {
2247 uint8_t R;
2248 struct {
2249 uint8_t:4;
2250 uint8_t FEMR:4;
2251 } B;
2252 } FEMR; //Flash ECC Master Register
2253
2254 union {
2255 uint8_t R;
2256 struct {
2257 uint8_t WRITE:1;
2258 uint8_t SIZE:3;
2259 uint8_t PROT0:1;
2260 uint8_t PROT1:1;
2261 uint8_t PROT2:1;
2262 uint8_t PROT3:1;
2263 } B;
2264 } FEAT; //Flash ECC Attributes Register
2265
2266 union {
2267 uint32_t R;
2268 struct {
2269 uint32_t FEDH:32;
2270 } B;
2271 } FEDRH; //Flash ECC Data High Register
2272
2273 union {
2274 uint32_t R;
2275 struct {
2276 uint32_t FEDL:32;
2277 } B;
2278 } FEDRL; //Flash ECC Data Low Register
2279
2280 union {
2281 uint32_t R;
2282 struct {
2283 uint32_t REAR:32;
2284 } B;
2285 } REAR; //RAM ECC Address
2286
2287 uint8_t ecsm_reserved12[2];
2288
2289 union {
2290 uint8_t R;
2291 struct {
2292 uint8_t:4;
2293 uint8_t REMR:4;
2294 } B;
2295 } REMR; //RAM ECC Master
2296
2297 union {
2298 uint8_t R;
2299 struct {
2300 uint8_t WRITE:1;
2301 uint8_t SIZE:3;
2302 uint8_t PROT0:1;
2303 uint8_t PROT1:1;
2304 uint8_t PROT2:1;
2305 uint8_t PROT3:1;
2306 } B;
2307 } REAT; // RAM ECC Attributes Register
2308
2309 union {
2310 uint32_t R;
2311 struct {
2312 uint32_t REDH:32;
2313 } B;
2314 } REDRH; //RAM ECC Data High Register
2315
2316 union {
2317 uint32_t R;
2318 struct {
2319 uint32_t REDL:32;
2320 } B;
2321 } REDRL; //RAMECC Data Low Register
2322
2323 };
2324/****************************************************************************/
2325/* MODULE : INTC */
2326/****************************************************************************/
2327 struct INTC_tag {
2328 union {
2329 uint32_t R;
2330 struct {
2331 uint32_t:26;
2332 uint32_t VTES:1;
2333 uint32_t:4;
2334 uint32_t HVEN:1;
2335 } B;
2336 } MCR; /* Module Configuration Register */
2337
2338 int32_t INTC_reserved00;
2339
2340 union {
2341 uint32_t R;
2342 struct {
2343 uint32_t:28;
2344 uint32_t PRI:4;
2345 } B;
2346 } CPR; /* Current Priority Register */
2347
2348 uint32_t intc_reserved1;
2349
2350 union {
2351 uint32_t R;
2352 struct {
2353 uint32_t VTBA:21;
2354 uint32_t INTVEC:9;
2355 uint32_t:2;
2356 } B;
2357 } IACKR; /* Interrupt Acknowledge Register */
2358
2359 uint32_t intc_reserved2;
2360
2361 union {
2362 uint32_t R;
2363 struct {
2364 uint32_t:32;
2365 } B;
2366 } EOIR; /* End of Interrupt Register */
2367
2368 uint32_t intc_reserved3;
2369
2370 union {
2371 uint8_t R;
2372 struct {
2373 uint8_t:6;
2374 uint8_t SET:1;
2375 uint8_t CLR:1;
2376 } B;
2377 } SSCIR[8]; /* Software Set/Clear Interruput Register */
2378
2379 uint32_t intc_reserved4[6];
2380
2381 union {
2382 uint8_t R;
2383 struct {
2384 uint8_t:4;
2385 uint8_t PRI:4;
2386 } B;
2387 } PSR[358]; /* Software Set/Clear Interrupt Register */
2388
2389 };
2390/****************************************************************************/
2391/* MODULE : EQADC */
2392/****************************************************************************/
2393 struct EQADC_tag {
2394 union {
2395 uint32_t R;
2396 struct {
2397 uint32_t:27;
2398 uint32_t ESSIE:2;
2399 uint32_t:1;
2400 uint32_t DBG:2;
2401 } B;
2402 } MCR; /* Module Configuration Register */
2403
2404 int32_t EQADC_reserved00;
2405
2406 union {
2407 uint32_t R;
2408 struct {
2409 uint32_t:6;
2410 uint32_t NMF:26;
2411 } B;
2412 } NMSFR; /* Null Message Send Format Register */
2413
2414 union {
2415 uint32_t R;
2416 struct {
2417 uint32_t:28;
2418 uint32_t DFL:4;
2419 } B;
2420 } ETDFR; /* External Trigger Digital Filter Register */
2421
2422 union {
2423 uint32_t R;
2424 struct {
2425 uint32_t CFPUSH:32;
2426 } B;
2427 } CFPR[6]; /* CFIFO Push Registers */
2428
2429 uint32_t eqadc_reserved1;
2430
2431 uint32_t eqadc_reserved2;
2432
2433 union {
2434 uint32_t R;
2435 struct {
2436 uint32_t:16;
2437 uint32_t RFPOP:16;
2438 } B;
2439 } RFPR[6]; /* Result FIFO Pop Registers */
2440
2441 uint32_t eqadc_reserved3;
2442
2443 uint32_t eqadc_reserved4;
2444
2446 uint16_t R;
2447 struct {
2448 uint16_t:5;
2449 uint16_t SSE:1;
2450 uint16_t CFINV:1;
2451 uint16_t:1;
2452 uint16_t MODE:4;
2453 uint16_t:4;
2454 } B;
2455 } CFCR[6]; /* CFIFO Control Registers */
2456
2457 uint32_t eqadc_reserved5;
2458
2460 uint16_t R;
2461 struct {
2462 uint16_t NCIE:1;
2463 uint16_t TORIE:1;
2464 uint16_t PIE:1;
2465 uint16_t EOQIE:1;
2466 uint16_t CFUIE:1;
2467 uint16_t:1;
2468 uint16_t CFFE:1;
2469 uint16_t CFFS:1;
2470 uint16_t:4;
2471 uint16_t RFOIE:1;
2472 uint16_t:1;
2473 uint16_t RFDE:1;
2474 uint16_t RFDS:1;
2475 } B;
2476 } IDCR[6]; /* Interrupt and DMA Control Registers */
2477
2478 uint32_t eqadc_reserved6;
2479
2481 uint32_t R;
2482 struct {
2483 uint32_t NCF:1;
2484 uint32_t TORF:1;
2485 uint32_t PF:1;
2486 uint32_t EOQF:1;
2487 uint32_t CFUF:1;
2488 uint32_t SSS:1;
2489 uint32_t CFFF:1;
2490 uint32_t:5;
2491 uint32_t RFOF:1;
2492 uint32_t:1;
2493 uint32_t RFDF:1;
2494 uint32_t:1;
2495 uint32_t CFCTR:4;
2496 uint32_t TNXTPTR:4;
2497 uint32_t RFCTR:4;
2498 uint32_t POPNXTPTR:4;
2499 } B;
2500 } FISR[6]; /* FIFO and Interrupt Status Registers */
2501
2502 uint32_t eqadc_reserved7;
2503
2504 uint32_t eqadc_reserved8;
2505
2506 union {
2507 uint16_t R;
2508 struct {
2509 uint16_t:5;
2510 uint16_t TCCF:11;
2511 } B;
2512 } CFTCR[6]; /* CFIFO Transfer Counter Registers */
2513
2514 uint32_t eqadc_reserved9;
2515
2516 union {
2517 uint32_t R;
2518 struct {
2519 uint32_t CFS0:2;
2520 uint32_t CFS1:2;
2521 uint32_t CFS2:2;
2522 uint32_t CFS3:2;
2523 uint32_t CFS4:2;
2524 uint32_t CFS5:2;
2525 uint32_t:5;
2526 uint32_t LCFTCB0:4;
2527 uint32_t TC_LCFTCB0:11;
2528 } B;
2529 } CFSSR0; /* CFIFO Status Register 0 */
2530
2531 union {
2532 uint32_t R;
2533 struct {
2534 uint32_t CFS0:2;
2535 uint32_t CFS1:2;
2536 uint32_t CFS2:2;
2537 uint32_t CFS3:2;
2538 uint32_t CFS4:2;
2539 uint32_t CFS5:2;
2540 uint32_t:5;
2541 uint32_t LCFTCB1:4;
2542 uint32_t TC_LCFTCB1:11;
2543 } B;
2544 } CFSSR1; /* CFIFO Status Register 1 */
2545
2546 union {
2547 uint32_t R;
2548 struct {
2549 uint32_t CFS0:2;
2550 uint32_t CFS1:2;
2551 uint32_t CFS2:2;
2552 uint32_t CFS3:2;
2553 uint32_t CFS4:2;
2554 uint32_t CFS5:2;
2555 uint32_t:4;
2556 uint32_t ECBNI:1;
2557 uint32_t LCFTSSI:4;
2558 uint32_t TC_LCFTSSI:11;
2559 } B;
2560 } CFSSR2; /* CFIFO Status Register 2 */
2561
2562 union {
2563 uint32_t R;
2564 struct {
2565 uint32_t CFS0:2;
2566 uint32_t CFS1:2;
2567 uint32_t CFS2:2;
2568 uint32_t CFS3:2;
2569 uint32_t CFS4:2;
2570 uint32_t CFS5:2;
2571 uint32_t:20;
2572 } B;
2573 } CFSR;
2574
2575 uint32_t eqadc_reserved11;
2576
2577 union {
2578 uint32_t R;
2579 struct {
2580 uint32_t:21;
2581 uint32_t MDT:3;
2582 uint32_t:4;
2583 uint32_t BR:4;
2584 } B;
2585 } SSICR; /* SSI Control Register */
2586
2587 union {
2588 uint32_t R;
2589 struct {
2590 uint32_t RDV:1;
2591 uint32_t:5;
2592 uint32_t RDATA:26;
2593 } B;
2594 } SSIRDR; /* SSI Recieve Data Register */
2595
2596 uint32_t eqadc_reserved12[17];
2597
2598 struct {
2599 union {
2600 uint32_t R;
2601 struct {
2602 uint32_t:32;
2603 } B;
2604 } R[4];
2605
2606 uint32_t eqadc_reserved13[12];
2607
2608 } CF[6];
2609
2610 uint32_t eqadc_reserved14[32];
2611
2612 struct {
2613 union {
2614 uint32_t R;
2615 struct {
2616 uint32_t:32;
2617 } B;
2618 } R[4];
2619
2620 uint32_t eqadc_reserved15[12];
2621
2622 } RF[6];
2623
2624 };
2625
2626/* Message Formats for On-Chip ADC Operation
2627 */
2629 uint32_t R;
2630 struct {
2631 uint32_t EOQ:1;
2632 uint32_t PAUSE:1;
2633 uint32_t:3;
2634 uint32_t EB:1;
2635 uint32_t BN:1;
2636 uint32_t CAL:1;
2637 uint32_t MESSAGE_TAG:4;
2638 uint32_t LST:2;
2639 uint32_t TSR:1;
2640 uint32_t FMT:1;
2641 uint32_t CHANNEL_NUMBER:8;
2642 uint32_t:8;
2643 } B;
2644}; /* Conversion command */
2645
2647 uint32_t R;
2648 struct {
2649 uint32_t EOQ:1;
2650 uint32_t PAUSE:1;
2651 uint32_t:3;
2652 uint32_t EB:1;
2653 uint32_t BN:1;
2654 uint32_t RW:1;
2655 uint32_t VALUE:16;
2656 uint32_t ADDR:8;
2657 } B;
2658}; /* Write configuration command */
2659
2660/****************************************************************************/
2661/* MODULE : DSPI */
2662/****************************************************************************/
2663 struct DSPI_tag {
2664 union DSPI_MCR_tag {
2665 uint32_t R;
2666 struct {
2667 uint32_t MSTR:1;
2668 uint32_t CONT_SCKE:1;
2669 uint32_t DCONF:2;
2670 uint32_t FRZ:1;
2671 uint32_t MTFE:1;
2672 uint32_t PCSSE:1;
2673 uint32_t ROOE:1;
2674 uint32_t:2;
2675 uint32_t PCSIS5:1;
2676 uint32_t PCSIS4:1;
2677 uint32_t PCSIS3:1;
2678 uint32_t PCSIS2:1;
2679 uint32_t PCSIS1:1;
2680 uint32_t PCSIS0:1;
2681 uint32_t DOZE:1;
2682 uint32_t MDIS:1;
2683 uint32_t DIS_TXF:1;
2684 uint32_t DIS_RXF:1;
2685 uint32_t CLR_TXF:1;
2686 uint32_t CLR_RXF:1;
2687 uint32_t SMPL_PT:2;
2688 uint32_t:7;
2689 uint32_t HALT:1;
2690 } B;
2691 } MCR; /* Module Configuration Register */
2692
2693 uint32_t dspi_reserved1;
2694
2695 union {
2696 uint32_t R;
2697 struct {
2698 uint32_t TCNT:16;
2699 uint32_t:16;
2700 } B;
2701 } TCR;
2702
2703 union DSPI_CTAR_tag {
2704 uint32_t R;
2705 struct {
2706 uint32_t DBR:1;
2707 uint32_t FMSZ:4;
2708 uint32_t CPOL:1;
2709 uint32_t CPHA:1;
2710 uint32_t LSBFE:1;
2711 uint32_t PCSSCK:2;
2712 uint32_t PASC:2;
2713 uint32_t PDT:2;
2714 uint32_t PBR:2;
2715 uint32_t CSSCK:4;
2716 uint32_t ASC:4;
2717 uint32_t DT:4;
2718 uint32_t BR:4;
2719 } B;
2720 } CTAR[8]; /* Clock and Transfer Attributes Registers */
2721
2722 union DSPI_SR_tag {
2723 uint32_t R;
2724 struct {
2725 uint32_t TCF:1;
2726 uint32_t TXRXS:1;
2727 uint32_t:1;
2728 uint32_t EOQF:1;
2729 uint32_t TFUF:1;
2730 uint32_t:1;
2731 uint32_t TFFF:1;
2732 uint32_t:5;
2733 uint32_t RFOF:1;
2734 uint32_t:1;
2735 uint32_t RFDF:1;
2736 uint32_t:1;
2737 uint32_t TXCTR:4;
2738 uint32_t TXNXTPTR:4;
2739 uint32_t RXCTR:4;
2740 uint32_t POPNXTPTR:4;
2741 } B;
2742 } SR; /* Status Register */
2743
2744 union DSPI_RSER_tag {
2745 uint32_t R;
2746 struct {
2747 uint32_t TCFRE:1;
2748 uint32_t:2;
2749 uint32_t EOQFRE:1;
2750 uint32_t TFUFRE:1;
2751 uint32_t:1;
2752 uint32_t TFFFRE:1;
2753 uint32_t TFFFDIRS:1;
2754 uint32_t:4;
2755 uint32_t RFOFRE:1;
2756 uint32_t:1;
2757 uint32_t RFDFRE:1;
2758 uint32_t RFDFDIRS:1;
2759 uint32_t:16;
2760 } B;
2761 } RSER; /* DMA/Interrupt Request Select and Enable Register */
2762
2763 union DSPI_PUSHR_tag {
2764 uint32_t R;
2765 struct {
2766 uint32_t CONT:1;
2767 uint32_t CTAS:3;
2768 uint32_t EOQ:1;
2769 uint32_t CTCNT:1;
2770 uint32_t:4;
2771 uint32_t PCS5:1;
2772 uint32_t PCS4:1;
2773 uint32_t PCS3:1;
2774 uint32_t PCS2:1;
2775 uint32_t PCS1:1;
2776 uint32_t PCS0:1;
2777 uint32_t TXDATA:16;
2778 } B;
2779 } PUSHR; /* PUSH TX FIFO Register */
2780
2781 union DSPI_POPR_tag {
2782 uint32_t R;
2783 struct {
2784 uint32_t:16;
2785 uint32_t RXDATA:16;
2786 } B;
2787 } POPR; /* POP RX FIFO Register */
2788
2789 union {
2790 uint32_t R;
2791 struct {
2792 uint32_t TXCMD:16;
2793 uint32_t TXDATA:16;
2794 } B;
2795 } TXFR[4]; /* Transmit FIFO Registers */
2796
2797 uint32_t DSPI_reserved_txf[12];
2798
2799 union {
2800 uint32_t R;
2801 struct {
2802 uint32_t:16;
2803 uint32_t RXDATA:16;
2804 } B;
2805 } RXFR[4]; /* Transmit FIFO Registers */
2806
2807 uint32_t DSPI_reserved_rxf[12];
2808
2809 union {
2810 uint32_t R;
2811 struct {
2812 uint32_t MTOE:1;
2813 uint32_t:1;
2814 uint32_t MTOCNT:6;
2815 uint32_t:4;
2816 uint32_t TXSS:1;
2817 uint32_t TPOL:1;
2818 uint32_t TRRE:1;
2819 uint32_t CID:1;
2820 uint32_t DCONT:1;
2821 uint32_t DSICTAS:3;
2822 uint32_t:6;
2823 uint32_t DPCS5:1;
2824 uint32_t DPCS4:1;
2825 uint32_t DPCS3:1;
2826 uint32_t DPCS2:1;
2827 uint32_t DPCS1:1;
2828 uint32_t DPCS0:1;
2829 } B;
2830 } DSICR; /* DSI Configuration Register */
2831
2832 union {
2833 uint32_t R;
2834 struct {
2835 uint32_t:16;
2836 uint32_t SER_DATA:16;
2837 } B;
2838 } SDR; /* DSI Serialization Data Register */
2839
2840 union {
2841 uint32_t R;
2842 struct {
2843 uint32_t:16;
2844 uint32_t ASER_DATA:16;
2845 } B;
2846 } ASDR; /* DSI Alternate Serialization Data Register */
2847
2848 union {
2849 uint32_t R;
2850 struct {
2851 uint32_t:16;
2852 uint32_t COMP_DATA:16;
2853 } B;
2854 } COMPR; /* DSI Transmit Comparison Register */
2855
2856 union {
2857 uint32_t R;
2858 struct {
2859 uint32_t:16;
2860 uint32_t DESER_DATA:16;
2861 } B;
2862 } DDR; /* DSI deserialization Data Register */
2863
2864 };
2865/****************************************************************************/
2866/* MODULE : eSCI */
2867/****************************************************************************/
2868 struct ESCI_tag {
2869 union ESCI_CR1_tag {
2870 uint32_t R;
2871 struct {
2872 uint32_t:3;
2873 uint32_t SBR:13;
2874 uint32_t LOOPS:1;
2875 uint32_t SCISDOZ:1;
2876 uint32_t RSRC:1;
2877 uint32_t M:1;
2878 uint32_t WAKE:1;
2879 uint32_t ILT:1;
2880 uint32_t PE:1;
2881 uint32_t PT:1;
2882 uint32_t TIE:1;
2883 uint32_t TCIE:1;
2884 uint32_t RIE:1;
2885 uint32_t ILIE:1;
2886 uint32_t TE:1;
2887 uint32_t RE:1;
2888 uint32_t RWU:1;
2889 uint32_t SBK:1;
2890 } B;
2891 } CR1; /* Control Register 1 */
2892
2893 union ESCI_CR2_tag {
2894 uint16_t R;
2895 struct {
2896 uint16_t MDIS:1;
2897 uint16_t FBR:1;
2898 uint16_t BSTP:1;
2899 uint16_t IEBERR:1;
2900 uint16_t RXDMA:1;
2901 uint16_t TXDMA:1;
2902 uint16_t BRK13:1;
2903 uint16_t:1;
2904 uint16_t BESM13:1;
2905 uint16_t SBSTP:1;
2906 uint16_t:2;
2907 uint16_t ORIE:1;
2908 uint16_t NFIE:1;
2909 uint16_t FEIE:1;
2910 uint16_t PFIE:1;
2911 } B;
2912 } CR2; /* Control Register 2 */
2913
2914 union ESCI_DR_tag {
2915 uint16_t R;
2916 struct {
2917 uint16_t R8:1;
2918 uint16_t T8:1;
2919 uint16_t:6;
2920 uint8_t D;
2921 } B;
2922 } DR; /* Data Register */
2923
2924 union ESCI_SR_tag {
2925 uint32_t R;
2926 struct {
2927 uint32_t TDRE:1;
2928 uint32_t TC:1;
2929 uint32_t RDRF:1;
2930 uint32_t IDLE:1;
2931 uint32_t OR:1;
2932 uint32_t NF:1;
2933 uint32_t FE:1;
2934 uint32_t PF:1;
2935 uint32_t:3;
2936 uint32_t BERR:1;
2937 uint32_t:3;
2938 uint32_t RAF:1;
2939 uint32_t RXRDY:1;
2940 uint32_t TXRDY:1;
2941 uint32_t LWAKE:1;
2942 uint32_t STO:1;
2943 uint32_t PBERR:1;
2944 uint32_t CERR:1;
2945 uint32_t CKERR:1;
2946 uint32_t FRC:1;
2947 uint32_t:7;
2948 uint32_t OVFL:1;
2949 } B;
2950 } SR; /* Status Register */
2951
2952 union {
2953 uint32_t R;
2954 struct {
2955 uint32_t LRES:1;
2956 uint32_t WU:1;
2957 uint32_t WUD0:1;
2958 uint32_t WUD1:1;
2959 uint32_t LDBG:1;
2960 uint32_t DSF:1;
2961 uint32_t PRTY:1;
2962 uint32_t LIN:1;
2963 uint32_t RXIE:1;
2964 uint32_t TXIE:1;
2965 uint32_t WUIE:1;
2966 uint32_t STIE:1;
2967 uint32_t PBIE:1;
2968 uint32_t CIE:1;
2969 uint32_t CKIE:1;
2970 uint32_t FCIE:1;
2971 uint32_t:7;
2972 uint32_t OFIE:1;
2973 uint32_t:8;
2974 } B;
2975 } LCR; /* LIN Control Register */
2976
2977 union {
2978 uint32_t R;
2979 } LTR; /* LIN Transmit Register */
2980
2981 union {
2982 uint32_t R;
2983 } LRR; /* LIN Recieve Register */
2984
2985 union {
2986 uint32_t R;
2987 } LPR; /* LIN CRC Polynom Register */
2988
2989 };
2990/****************************************************************************/
2991/* MODULE : FlexCAN */
2992/****************************************************************************/
2994 union {
2995 uint32_t R;
2996 struct {
2997 uint32_t MDIS:1;
2998 uint32_t FRZ:1;
2999 uint32_t:1;
3000 uint32_t HALT:1;
3001 uint32_t NOTRDY:1;
3002 uint32_t:1;
3003 uint32_t SOFTRST:1;
3004 uint32_t FRZACK:1;
3005 uint32_t:1;
3006 uint32_t:1;
3007
3008 uint32_t:1;
3009
3010 uint32_t MDISACK:1;
3011 uint32_t:1;
3012 uint32_t:1;
3013
3014 uint32_t:12;
3015
3016 uint32_t MAXMB:6;
3017 } B;
3018 } MCR; /* Module Configuration Register */
3019
3020 union {
3021 uint32_t R;
3022 struct {
3023 uint32_t PRESDIV:8;
3024 uint32_t RJW:2;
3025 uint32_t PSEG1:3;
3026 uint32_t PSEG2:3;
3027 uint32_t BOFFMSK:1;
3028 uint32_t ERRMSK:1;
3029 uint32_t CLKSRC:1;
3030 uint32_t LPB:1;
3031
3032 uint32_t:4;
3033
3034 uint32_t SMP:1;
3035 uint32_t BOFFREC:1;
3036 uint32_t TSYN:1;
3037 uint32_t LBUF:1;
3038 uint32_t LOM:1;
3039 uint32_t PROPSEG:3;
3040 } B;
3041 } CR; /* Control Register */
3042
3043 union {
3044 uint32_t R;
3045 } TIMER; /* Free Running Timer */
3046 int32_t FLEXCAN_reserved00;
3047
3048 union {
3049 uint32_t R;
3050 struct {
3051 uint32_t:3;
3052 uint32_t MI:29;
3053 } B;
3054 } RXGMASK; /* RX Global Mask */
3055
3056 union {
3057 uint32_t R;
3058 struct {
3059 uint32_t:3;
3060 uint32_t MI:29;
3061 } B;
3062 } RX14MASK; /* RX 14 Mask */
3063
3064 union {
3065 uint32_t R;
3066 struct {
3067 uint32_t:3;
3068 uint32_t MI:29;
3069 } B;
3070 } RX15MASK; /* RX 15 Mask */
3071
3072 union {
3073 uint32_t R;
3074 struct {
3075 uint32_t:16;
3076 uint32_t RXECNT:8;
3077 uint32_t TXECNT:8;
3078 } B;
3079 } ECR; /* Error Counter Register */
3080
3081 union {
3082 uint32_t R;
3083 struct {
3084 uint32_t:14;
3085
3086 uint32_t:2;
3087
3088 uint32_t BIT1ERR:1;
3089 uint32_t BIT0ERR:1;
3090 uint32_t ACKERR:1;
3091 uint32_t CRCERR:1;
3092 uint32_t FRMERR:1;
3093 uint32_t STFERR:1;
3094 uint32_t TXWRN:1;
3095 uint32_t RXWRN:1;
3096 uint32_t IDLE:1;
3097 uint32_t TXRX:1;
3098 uint32_t FLTCONF:2;
3099 uint32_t:1;
3100 uint32_t BOFFINT:1;
3101 uint32_t ERRINT:1;
3102 uint32_t:1;
3103 } B;
3104 } ESR; /* Error and Status Register */
3105
3106 union {
3107 uint32_t R;
3108 struct {
3109 uint32_t BUF63M:1;
3110 uint32_t BUF62M:1;
3111 uint32_t BUF61M:1;
3112 uint32_t BUF60M:1;
3113 uint32_t BUF59M:1;
3114 uint32_t BUF58M:1;
3115 uint32_t BUF57M:1;
3116 uint32_t BUF56M:1;
3117 uint32_t BUF55M:1;
3118 uint32_t BUF54M:1;
3119 uint32_t BUF53M:1;
3120 uint32_t BUF52M:1;
3121 uint32_t BUF51M:1;
3122 uint32_t BUF50M:1;
3123 uint32_t BUF49M:1;
3124 uint32_t BUF48M:1;
3125 uint32_t BUF47M:1;
3126 uint32_t BUF46M:1;
3127 uint32_t BUF45M:1;
3128 uint32_t BUF44M:1;
3129 uint32_t BUF43M:1;
3130 uint32_t BUF42M:1;
3131 uint32_t BUF41M:1;
3132 uint32_t BUF40M:1;
3133 uint32_t BUF39M:1;
3134 uint32_t BUF38M:1;
3135 uint32_t BUF37M:1;
3136 uint32_t BUF36M:1;
3137 uint32_t BUF35M:1;
3138 uint32_t BUF34M:1;
3139 uint32_t BUF33M:1;
3140 uint32_t BUF32M:1;
3141 } B;
3142 } IMRH; /* Interruput Masks Register */
3143
3144 union {
3145 uint32_t R;
3146 struct {
3147 uint32_t BUF31M:1;
3148 uint32_t BUF30M:1;
3149 uint32_t BUF29M:1;
3150 uint32_t BUF28M:1;
3151 uint32_t BUF27M:1;
3152 uint32_t BUF26M:1;
3153 uint32_t BUF25M:1;
3154 uint32_t BUF24M:1;
3155 uint32_t BUF23M:1;
3156 uint32_t BUF22M:1;
3157 uint32_t BUF21M:1;
3158 uint32_t BUF20M:1;
3159 uint32_t BUF19M:1;
3160 uint32_t BUF18M:1;
3161 uint32_t BUF17M:1;
3162 uint32_t BUF16M:1;
3163 uint32_t BUF15M:1;
3164 uint32_t BUF14M:1;
3165 uint32_t BUF13M:1;
3166 uint32_t BUF12M:1;
3167 uint32_t BUF11M:1;
3168 uint32_t BUF10M:1;
3169 uint32_t BUF09M:1;
3170 uint32_t BUF08M:1;
3171 uint32_t BUF07M:1;
3172 uint32_t BUF06M:1;
3173 uint32_t BUF05M:1;
3174 uint32_t BUF04M:1;
3175 uint32_t BUF03M:1;
3176 uint32_t BUF02M:1;
3177 uint32_t BUF01M:1;
3178 uint32_t BUF00M:1;
3179 } B;
3180 } IMRL; /* Interruput Masks Register */
3181
3182 union {
3183 uint32_t R;
3184 struct {
3185 uint32_t BUF63I:1;
3186 uint32_t BUF62I:1;
3187 uint32_t BUF61I:1;
3188 uint32_t BUF60I:1;
3189 uint32_t BUF59I:1;
3190 uint32_t BUF58I:1;
3191 uint32_t BUF57I:1;
3192 uint32_t BUF56I:1;
3193 uint32_t BUF55I:1;
3194 uint32_t BUF54I:1;
3195 uint32_t BUF53I:1;
3196 uint32_t BUF52I:1;
3197 uint32_t BUF51I:1;
3198 uint32_t BUF50I:1;
3199 uint32_t BUF49I:1;
3200 uint32_t BUF48I:1;
3201 uint32_t BUF47I:1;
3202 uint32_t BUF46I:1;
3203 uint32_t BUF45I:1;
3204 uint32_t BUF44I:1;
3205 uint32_t BUF43I:1;
3206 uint32_t BUF42I:1;
3207 uint32_t BUF41I:1;
3208 uint32_t BUF40I:1;
3209 uint32_t BUF39I:1;
3210 uint32_t BUF38I:1;
3211 uint32_t BUF37I:1;
3212 uint32_t BUF36I:1;
3213 uint32_t BUF35I:1;
3214 uint32_t BUF34I:1;
3215 uint32_t BUF33I:1;
3216 uint32_t BUF32I:1;
3217 } B;
3218 } IFRH; /* Interruput Flag Register */
3219
3220 union {
3221 uint32_t R;
3222 struct {
3223 uint32_t BUF31I:1;
3224 uint32_t BUF30I:1;
3225 uint32_t BUF29I:1;
3226 uint32_t BUF28I:1;
3227 uint32_t BUF27I:1;
3228 uint32_t BUF26I:1;
3229 uint32_t BUF25I:1;
3230 uint32_t BUF24I:1;
3231 uint32_t BUF23I:1;
3232 uint32_t BUF22I:1;
3233 uint32_t BUF21I:1;
3234 uint32_t BUF20I:1;
3235 uint32_t BUF19I:1;
3236 uint32_t BUF18I:1;
3237 uint32_t BUF17I:1;
3238 uint32_t BUF16I:1;
3239 uint32_t BUF15I:1;
3240 uint32_t BUF14I:1;
3241 uint32_t BUF13I:1;
3242 uint32_t BUF12I:1;
3243 uint32_t BUF11I:1;
3244 uint32_t BUF10I:1;
3245 uint32_t BUF09I:1;
3246 uint32_t BUF08I:1;
3247 uint32_t BUF07I:1;
3248 uint32_t BUF06I:1;
3249 uint32_t BUF05I:1;
3250 uint32_t BUF04I:1;
3251 uint32_t BUF03I:1;
3252 uint32_t BUF02I:1;
3253 uint32_t BUF01I:1;
3254 uint32_t BUF00I:1;
3255 } B;
3256 } IFRL; /* Interruput Flag Register */
3257
3258 uint32_t flexcan2_reserved2[19];
3259
3260 struct canbuf_t {
3261 union {
3262 uint32_t R;
3263 struct {
3264 uint32_t:4;
3265 uint32_t CODE:4;
3266 uint32_t:1;
3267 uint32_t SRR:1;
3268 uint32_t IDE:1;
3269 uint32_t RTR:1;
3270 uint32_t LENGTH:4;
3271 uint32_t TIMESTAMP:16;
3272 } B;
3273 } CS;
3274
3275 union {
3276 uint32_t R;
3277 struct {
3278 uint32_t:3;
3279 uint32_t STD_ID:11;
3280 uint32_t EXT_ID:18;
3281 } B;
3282 } ID;
3283
3284 union {
3285 uint8_t B[8]; /* Data buffer in Bytes (8 bits) */
3286 uint16_t H[4]; /* Data buffer in Half-words (16 bits) */
3287 uint32_t W[2]; /* Data buffer in words (32 bits) */
3288 uint32_t R[2]; /* Data buffer in words (32 bits) */
3289 } DATA;
3290
3291 } BUF[64];
3292 };
3293
3294/* Define memories */
3295
3296#define SRAM_START 0x40000000
3297#define SRAM_SIZE 0x10000
3298#define SRAM_END 0x4000FFFF
3299
3300#define FLASH_START 0x0
3301#define FLASH_SIZE 0x200000
3302#define FLASH_END 0x1FFFFF
3303
3304/* Define instances of modules */
3305#define PBRIDGE_A (*(volatile struct PBRIDGE_A_tag *) 0xC3F00000)
3306#define FMPLL (*(volatile struct FMPLL_tag *) 0xC3F80000)
3307#define EBI (*(volatile struct EBI_tag *) 0xC3F84000)
3308#define FLASH (*(volatile struct FLASH_tag *) 0xC3F88000)
3309#define SIU (*(volatile struct SIU_tag *) 0xC3F90000)
3310
3311#define EMIOS (*(volatile struct EMIOS_tag *) 0xC3FA0000)
3312#define ETPU (*(volatile struct ETPU_tag *) 0xC3FC0000)
3313#define ETPU_DATA_RAM (*( uint32_t *) 0xC3FC8000)
3314#define ETPU_DATA_RAM_EXT (*( uint32_t *) 0xC3FCC000)
3315#define ETPU_DATA_RAM_END 0xC3FC8BFC
3316#define CODE_RAM (*( uint32_t *) 0xC3FD0000)
3317#define ETPU_CODE_RAM (*( uint32_t *) 0xC3FD0000)
3318
3319#define PBRIDGE_B (*(volatile struct PBRIDGE_B_tag *) 0xFFF00000)
3320#define XBAR (*(volatile struct XBAR_tag *) 0xFFF04000)
3321#define ECSM (*(volatile struct ECSM_tag *) 0xFFF40000)
3322#define EDMA (*(volatile struct EDMA_tag *) 0xFFF44000)
3323#define INTC (*(volatile struct INTC_tag *) 0xFFF48000)
3324
3325#define EQADC (*(volatile struct EQADC_tag *) 0xFFF80000)
3326
3327#define DSPI_A (*(volatile struct DSPI_tag *) 0xFFF90000)
3328#define DSPI_B (*(volatile struct DSPI_tag *) 0xFFF94000)
3329#define DSPI_C (*(volatile struct DSPI_tag *) 0xFFF98000)
3330#define DSPI_D (*(volatile struct DSPI_tag *) 0xFFF9C000)
3331
3332#define ESCI_A (*(volatile struct ESCI_tag *) 0xFFFB0000)
3333#define ESCI_B (*(volatile struct ESCI_tag *) 0xFFFB4000)
3334
3335#define CAN_A (*(volatile struct FLEXCAN2_tag *) 0xFFFC0000)
3336#define CAN_B (*(volatile struct FLEXCAN2_tag *) 0xFFFC4000)
3337#define CAN_C (*(volatile struct FLEXCAN2_tag *) 0xFFFC8000)
3338
3339#ifdef __MWERKS__
3340#pragma pop
3341#endif
3342
3343#ifdef __cplusplus
3344}
3345#endif
3346#endif /* ASM */
3347#endif /* ifdef _MPC5554_H */
3348/*********************************************************************
3349 *
3350 * Copyright:
3351 * Freescale Semiconductor, INC. All Rights Reserved.
3352 * You are hereby granted a copyright license to use, modify, and
3353 * distribute the SOFTWARE so long as this entire notice is
3354 * retained without alteration in any modified and/or redistributed
3355 * versions, and that such modified versions are clearly identified
3356 * as such. No licenses are granted by implication, estoppel or
3357 * otherwise under any patents or trademarks of Freescale
3358 * Semiconductor, Inc. This software is provided on an "AS IS"
3359 * basis and without warranty.
3360 *
3361 * To the maximum extent permitted by applicable law, Freescale
3362 * Semiconductor DISCLAIMS ALL WARRANTIES WHETHER EXPRESS OR IMPLIED,
3363 * INCLUDING IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A
3364 * PARTICULAR PURPOSE AND ANY WARRANTY AGAINST INFRINGEMENT WITH
3365 * REGARD TO THE SOFTWARE (INCLUDING ANY MODIFIED VERSIONS THEREOF)
3366 * AND ANY ACCOMPANYING WRITTEN MATERIALS.
3367 *
3368 * To the maximum extent permitted by applicable law, IN NO EVENT
3369 * SHALL Freescale Semiconductor BE LIABLE FOR ANY DAMAGES WHATSOEVER
3370 * (INCLUDING WITHOUT LIMITATION, DAMAGES FOR LOSS OF BUSINESS PROFITS,
3371 * BUSINESS INTERRUPTION, LOSS OF BUSINESS INFORMATION, OR OTHER
3372 * PECUNIARY LOSS) ARISING OF THE USE OR INABILITY TO USE THE SOFTWARE.
3373 *
3374 * Freescale Semiconductor assumes no responsibility for the
3375 * maintenance and support of this software
3376 *
3377 ********************************************************************/
Definition: fsl-mpc551x.h:238
Definition: fsl-mpc551x.h:473
Definition: fsl-mpc551x.h:441
Definition: fsl-mpc551x.h:477
Definition: fsl-mpc555x.h:2173
Definition: fsl-mpc551x.h:525
Definition: fsl-mpc551x.h:710
Definition: fsl-mpc551x.h:893
Definition: fsl-mpc555x.h:1130
Definition: fsl-mpc551x.h:1021
Definition: fsl-mpc555x.h:3260
Definition: fsl-mpc555x.h:2993
Definition: fsl-mpc551x.h:1478
Definition: fsl-mpc551x.h:1597
Definition: fsl-mpc555x.h:118
Definition: fsl-mpc555x.h:230
Definition: fsl-mpc551x.h:2215
Definition: fsl-mpc555x.h:1976
Definition: fsl-mpc564xL.h:16580
Definition: fsl-mpc564xL.h:16535
Definition: fsl-mpc564xL.h:16692
Definition: fsl-mpc564xL.h:16672
Definition: fsl-mpc564xL.h:16621
Definition: fsl-mpc564xL.h:16599
Definition: fsl-mpc555x.h:2628
Definition: fsl-mpc555x.h:2646
Definition: fsl-mpc555x.h:2445
Definition: fsl-mpc555x.h:2480
Definition: fsl-mpc555x.h:2459
Definition: fsl-mpc555x.h:398
Definition: fsl-mpc551x.h:1482
Definition: fsl-mpc564xL.h:960
