RTEMS
6.1-rc1
include
extensiondata.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
* COPYRIGHT (c) 1989-2008.
14
* On-Line Applications Research Corporation (OAR).
15
16
17
* modification, are permitted provided that the following conditions
18
* are met:
19
* 1. Redistributions of source code must retain the above copyright
20
* notice, this list of conditions and the following disclaimer.
21
* 2. Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in the
23
* documentation and/or other materials provided with the distribution.
24
25
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
* POSSIBILITY OF SUCH DAMAGE.
36
37
38
#ifndef _RTEMS_EXTENSIONDATA_H
39
#define _RTEMS_EXTENSIONDATA_H
40
41
rtems/extension.h
42
rtems/score/objectdata.h
43
rtems/score/userextdata.h
44
45
#ifdef __cplusplus
46
extern
"C"
47
#endif
48
55
typedef
struct
56
Objects_Control
Object;
57
User_extensions_Control
Extension;
58
Extension_Control
59
63
extern
Objects_Information
_Extension_Information
64
74
#define EXTENSION_INFORMATION_DEFINE( max ) \
75
OBJECTS_INFORMATION_DEFINE( \
76
_Extension, \
77
OBJECTS_CLASSIC_API, \
78
OBJECTS_RTEMS_EXTENSIONS, \
79
Extension_Control, \
80
max, \
81
OBJECTS_NO_STRING_NAME, \
82
NULL \
83
84
87
#ifdef __cplusplus
88
89
#endif
90
91
#endif
92
/* end of include file */
extension.h
This header file defines the User Extensions Manager API.
Objects_Information _Extension_Information
The Classic Extensions objects information.
objectdata.h
This header file provides data structures used by the implementation and the Application Configuratio...
Extension_Control
Definition:
extensiondata.h:55
Objects_Control
Definition:
objectdata.h:61
Objects_Information
The information structure used to manage each API class of objects.
Definition:
objectdata.h:198
Manages each user extension set.
Definition:
userextdata.h:72
userextdata.h
