RTEMS 6.1-rc1
efidevp.h
1/* $FreeBSD$ */
2#ifndef _DEVPATH_H
3#define _DEVPATH_H
4
5/*++
6
7Copyright (c) 1999 - 2002 Intel Corporation. All rights reserved
8This software and associated documentation (if any) is furnished
9under a license and may only be used or copied in accordance
10with the terms of the license. Except as permitted by such
11license, no part of this software or documentation may be
12reproduced, stored in a retrieval system, or transmitted in any
13form or by any means without the express written consent of
14Intel Corporation.
15
16Module Name:
17
18 devpath.h
19
20Abstract:
21
22 Defines for parsing the EFI Device Path structures
23
24
25
26Revision History
27
28--*/
29
30//
31// Device Path structures - Section C
32//
33
34#pragma pack(1)
35
36typedef struct _EFI_DEVICE_PATH {
37 UINT8 Type;
38 UINT8 SubType;
39 UINT8 Length[2];
41
42#define EFI_DP_TYPE_MASK 0x7F
43#define EFI_DP_TYPE_UNPACKED 0x80
44
45#define END_DEVICE_PATH_TYPE 0x7f
46
47#define END_ENTIRE_DEVICE_PATH_SUBTYPE 0xff
48#define END_INSTANCE_DEVICE_PATH_SUBTYPE 0x01
49#define END_DEVICE_PATH_LENGTH (sizeof(EFI_DEVICE_PATH))
50
51
52#define DP_IS_END_TYPE(a)
53#define DP_IS_END_SUBTYPE(a) ( ((a)->SubType == END_ENTIRE_DEVICE_PATH_SUBTYPE )
54
55#define DevicePathType(a) ( ((a)->Type) & EFI_DP_TYPE_MASK )
56#define DevicePathSubType(a) ( (a)->SubType )
57#define DevicePathNodeLength(a) ((size_t)(((a)->Length[0]) | ((a)->Length[1] << 8)))
58#define NextDevicePathNode(a) ( (EFI_DEVICE_PATH *) ( ((UINT8 *) (a)) + DevicePathNodeLength(a)))
59#define IsDevicePathType(a, t) ( DevicePathType(a) == t )
60#define IsDevicePathEndType(a) IsDevicePathType(a, END_DEVICE_PATH_TYPE)
61#define IsDevicePathEndSubType(a) ( (a)->SubType == END_ENTIRE_DEVICE_PATH_SUBTYPE )
62#define IsDevicePathEnd(a) ( IsDevicePathEndType(a) && IsDevicePathEndSubType(a) )
63#define IsDevicePathUnpacked(a) ( (a)->Type & EFI_DP_TYPE_UNPACKED )
64
65
66#define SetDevicePathNodeLength(a,l) { \
67 (a)->Length[0] = (UINT8) (l); \
68 (a)->Length[1] = (UINT8) ((l) >> 8); \
69 }
70
71#define SetDevicePathEndNode(a) { \
72 (a)->Type = END_DEVICE_PATH_TYPE; \
73 (a)->SubType = END_ENTIRE_DEVICE_PATH_SUBTYPE; \
74 (a)->Length[0] = sizeof(EFI_DEVICE_PATH); \
75 (a)->Length[1] = 0; \
76 }
77
78/*
79 *
80 */
81#define HARDWARE_DEVICE_PATH 0x01
82
83#define HW_PCI_DP 0x01
84typedef struct _PCI_DEVICE_PATH {
85 EFI_DEVICE_PATH Header;
86 UINT8 Function;
87 UINT8 Device;
89
90#define HW_PCCARD_DP 0x02
91typedef struct _PCCARD_DEVICE_PATH {
92 EFI_DEVICE_PATH Header;
93 UINT8 FunctionNumber;
95
96#define HW_MEMMAP_DP 0x03
97typedef struct _MEMMAP_DEVICE_PATH {
98 EFI_DEVICE_PATH Header;
99 UINT32 MemoryType;
100 EFI_PHYSICAL_ADDRESS StartingAddress;
101 EFI_PHYSICAL_ADDRESS EndingAddress;
103
104#define HW_VENDOR_DP 0x04
105typedef struct _VENDOR_DEVICE_PATH {
106 EFI_DEVICE_PATH Header;
107 EFI_GUID Guid;
109
110#define UNKNOWN_DEVICE_GUID \
111 { 0xcf31fac5, 0xc24e, 0x11d2, {0x85, 0xf3, 0x0, 0xa0, 0xc9, 0x3e, 0xc9, 0x3b} }
112
114 VENDOR_DEVICE_PATH DevicePath;
115 UINT8 LegacyDriveLetter;
117
118#define HW_CONTROLLER_DP 0x05
120 EFI_DEVICE_PATH Header;
121 UINT32 Controller;
123
124/*
125 *
126 */
127#define ACPI_DEVICE_PATH 0x02
128
129#define ACPI_DP 0x01
130typedef struct _ACPI_HID_DEVICE_PATH {
131 EFI_DEVICE_PATH Header;
132 UINT32 HID;
133 UINT32 UID;
135
136#define ACPI_EXTENDED_DP 0x02
138 EFI_DEVICE_PATH Header;
139 UINT32 HID;
140 UINT32 UID;
141 UINT32 CID;
143
144#define ACPI_ADR_DP 0x03
145/* ACPI_ADR_DEVICE_PATH not defined */
146
147//
148// EISA ID Macro
149// EISA ID Definition 32-bits
150// bits[15:0] - three character compressed ASCII EISA ID.
151// bits[31:16] - binary number
152// Compressed ASCII is 5 bits per character 0b00001 = 'A' 0b11010 = 'Z'
153//
154#define PNP_EISA_ID_CONST 0x41d0
155#define EISA_ID(_Name, _Num) ((UINT32) ((_Name) | (_Num) << 16))
156#define EISA_PNP_ID(_PNPId) (EISA_ID(PNP_EISA_ID_CONST, (_PNPId)))
157#define EFI_PNP_ID(_PNPId) (EISA_ID(PNP_EISA_ID_CONST, (_PNPId)))
158
159#define PNP_EISA_ID_MASK 0xffff
160#define EISA_ID_TO_NUM(_Id) ((_Id) >> 16)
161/*
162 *
163 */
164#define MESSAGING_DEVICE_PATH 0x03
165
166#define MSG_ATAPI_DP 0x01
167typedef struct _ATAPI_DEVICE_PATH {
168 EFI_DEVICE_PATH Header;
169 UINT8 PrimarySecondary;
170 UINT8 SlaveMaster;
171 UINT16 Lun;
173
174#define MSG_SCSI_DP 0x02
175typedef struct _SCSI_DEVICE_PATH {
176 EFI_DEVICE_PATH Header;
177 UINT16 Pun;
178 UINT16 Lun;
180
181#define MSG_FIBRECHANNEL_DP 0x03
183 EFI_DEVICE_PATH Header;
184 UINT32 Reserved;
185 UINT64 WWN;
186 UINT64 Lun;
188
189#define MSG_1394_DP 0x04
190typedef struct _F1394_DEVICE_PATH {
191 EFI_DEVICE_PATH Header;
192 UINT32 Reserved;
193 UINT64 Guid;
195
196#define MSG_USB_DP 0x05
197typedef struct _USB_DEVICE_PATH {
198 EFI_DEVICE_PATH Header;
199 UINT8 ParentPortNumber;
200 UINT8 InterfaceNumber;
202
203#define MSG_USB_CLASS_DP 0x0F
205 EFI_DEVICE_PATH Header;
206 UINT16 VendorId;
207 UINT16 ProductId;
208 UINT8 DeviceClass;
209 UINT8 DeviceSubClass;
210 UINT8 DeviceProtocol;
212
213#define MSG_I2O_DP 0x06
214typedef struct _I2O_DEVICE_PATH {
215 EFI_DEVICE_PATH Header;
216 UINT32 Tid;
218
219#define MSG_MAC_ADDR_DP 0x0b
220typedef struct _MAC_ADDR_DEVICE_PATH {
221 EFI_DEVICE_PATH Header;
222 EFI_MAC_ADDRESS MacAddress;
223 UINT8 IfType;
225
226#define MSG_IPv4_DP 0x0c
227typedef struct _IPv4_DEVICE_PATH {
228 EFI_DEVICE_PATH Header;
229 EFI_IPv4_ADDRESS LocalIpAddress;
230 EFI_IPv4_ADDRESS RemoteIpAddress;
231 UINT16 LocalPort;
232 UINT16 RemotePort;
233 UINT16 Protocol;
234 BOOLEAN StaticIpAddress;
235 EFI_IPv4_ADDRESS GatewayIpAddress;
236 EFI_IPv4_ADDRESS SubnetMask;
238
239#define MSG_IPv6_DP 0x0d
240typedef struct _IPv6_DEVICE_PATH {
241 EFI_DEVICE_PATH Header;
242 EFI_IPv6_ADDRESS LocalIpAddress;
243 EFI_IPv6_ADDRESS RemoteIpAddress;
244 UINT16 LocalPort;
245 UINT16 RemotePort;
246 UINT16 Protocol;
247 BOOLEAN StaticIpAddress;
249
250#define MSG_INFINIBAND_DP 0x09
252 EFI_DEVICE_PATH Header;
253 UINT32 ResourceFlags;
254 UINT8 PortGid[16];
255 UINT64 ServiceId;
256 UINT64 TargetPortId;
257 UINT64 DeviceId;
259
260#define INFINIBAND_RESOURCE_FLAG_IOC_SERVICE 0x01
261#define INFINIBAND_RESOURCE_FLAG_EXTENDED_BOOT_ENVIRONMENT 0x02
262#define INFINIBAND_RESOURCE_FLAG_CONSOLE_PROTOCOL 0x04
263#define INFINIBAND_RESOURCE_FLAG_STORAGE_PROTOCOL 0x08
264#define INFINIBAND_RESOURCE_FLAG_NETWORK_PROTOCOL 0x10
265
266#define MSG_UART_DP 0x0e
267typedef struct _UART_DEVICE_PATH {
268 EFI_DEVICE_PATH Header;
269 UINT32 Reserved;
270 UINT64 BaudRate;
271 UINT8 DataBits;
272 UINT8 Parity;
273 UINT8 StopBits;
275
276#define MSG_VENDOR_DP 0x0A
277/* Use VENDOR_DEVICE_PATH struct */
278
279#define DEVICE_PATH_MESSAGING_PC_ANSI \
280 { 0xe0c14753, 0xf9be, 0x11d2, {0x9a, 0x0c, 0x00, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
281
282#define DEVICE_PATH_MESSAGING_VT_100 \
283 { 0xdfa66065, 0xb419, 0x11d3, {0x9a, 0x2d, 0x00, 0x90, 0x27, 0x3f, 0xc1, 0x4d} }
284
285#define DEVICE_PATH_MESSAGING_VT_100_PLUS \
286 { 0x7baec70b, 0x57e0, 0x4c76, {0x8e, 0x87, 0x2f, 0x9e, 0x28, 0x08, 0x83, 0x43} }
287
288#define DEVICE_PATH_MESSAGING_VT_UTF8 \
289 { 0xad15a0d6, 0x8bec, 0x4acf, {0xa0, 0x73, 0xd0, 0x1d, 0xe7, 0x7e, 0x2d, 0x88} }
290
291/* Device Logical Unit SubType. */
292#define MSG_DEVICE_LOGICAL_UNIT_DP 0x11
293typedef struct {
294 EFI_DEVICE_PATH Header;
295 /* Logical Unit Number for the interface. */
296 UINT8 Lun;
298
299#define MSG_SATA_DP 0x12
300typedef struct _SATA_DEVICE_PATH {
301 EFI_DEVICE_PATH Header;
302 UINT16 HBAPortNumber;
303 UINT16 PortMultiplierPortNumber;
304 UINT16 Lun;
306
307
308/* DNS Device Path SubType */
309#define MSG_DNS_DP 0x1F
310typedef struct {
311 EFI_DEVICE_PATH Header;
312 /* Indicates the DNS server address is IPv4 or IPv6 address. */
313 UINT8 IsIPv6;
314 /* Instance of the DNS server address. */
315 /* XXX: actually EFI_IP_ADDRESS */
316 EFI_IPv4_ADDRESS DnsServerIp[];
318
319/* Uniform Resource Identifiers (URI) Device Path SubType */
320#define MSG_URI_DP 0x18
321typedef struct {
322 EFI_DEVICE_PATH Header;
323 /* Instance of the URI pursuant to RFC 3986. */
324 CHAR8 Uri[];
326
327#define MEDIA_DEVICE_PATH 0x04
328
329#define MEDIA_HARDDRIVE_DP 0x01
331 EFI_DEVICE_PATH Header;
332 UINT32 PartitionNumber;
333 UINT64 PartitionStart;
334 UINT64 PartitionSize;
335 UINT8 Signature[16];
336 UINT8 MBRType;
337 UINT8 SignatureType;
339
340#define MBR_TYPE_PCAT 0x01
341#define MBR_TYPE_EFI_PARTITION_TABLE_HEADER 0x02
342
343#define SIGNATURE_TYPE_MBR 0x01
344#define SIGNATURE_TYPE_GUID 0x02
345
346#define MEDIA_CDROM_DP 0x02
347typedef struct _CDROM_DEVICE_PATH {
348 EFI_DEVICE_PATH Header;
349 UINT32 BootEntry;
350 UINT64 PartitionStart;
351 UINT64 PartitionSize;
353
354#define MEDIA_VENDOR_DP 0x03
355/* Use VENDOR_DEVICE_PATH struct */
356
357#define MEDIA_FILEPATH_DP 0x04
358typedef struct _FILEPATH_DEVICE_PATH {
359 EFI_DEVICE_PATH Header;
360 CHAR16 PathName[1];
362
363#define SIZE_OF_FILEPATH_DEVICE_PATH EFI_FIELD_OFFSET(FILEPATH_DEVICE_PATH,PathName)
364
365#define MEDIA_PROTOCOL_DP 0x05
367 EFI_DEVICE_PATH Header;
368 EFI_GUID Protocol;
370
371
372#define BBS_DEVICE_PATH 0x05
373#define BBS_BBS_DP 0x01
374typedef struct _BBS_BBS_DEVICE_PATH {
375 EFI_DEVICE_PATH Header;
376 UINT16 DeviceType;
377 UINT16 StatusFlag;
378 CHAR8 String[1];
380
381/* DeviceType definitions - from BBS specification */
382#define BBS_TYPE_FLOPPY 0x01
383#define BBS_TYPE_HARDDRIVE 0x02
384#define BBS_TYPE_CDROM 0x03
385#define BBS_TYPE_PCMCIA 0x04
386#define BBS_TYPE_USB 0x05
387#define BBS_TYPE_EMBEDDED_NETWORK 0x06
388#define BBS_TYPE_DEV 0x80
389#define BBS_TYPE_UNKNOWN 0xFF
390
391typedef union {
392 EFI_DEVICE_PATH DevPath;
393 PCI_DEVICE_PATH Pci;
394 PCCARD_DEVICE_PATH PcCard;
395 MEMMAP_DEVICE_PATH MemMap;
396 VENDOR_DEVICE_PATH Vendor;
398 CONTROLLER_DEVICE_PATH Controller;
400
401 ATAPI_DEVICE_PATH Atapi;
402 SCSI_DEVICE_PATH Scsi;
403 FIBRECHANNEL_DEVICE_PATH FibreChannel;
404
405 F1394_DEVICE_PATH F1394;
406 USB_DEVICE_PATH Usb;
407 USB_CLASS_DEVICE_PATH UsbClass;
408 I2O_DEVICE_PATH I2O;
409 MAC_ADDR_DEVICE_PATH MacAddr;
410 IPv4_DEVICE_PATH Ipv4;
411 IPv6_DEVICE_PATH Ipv6;
412 INFINIBAND_DEVICE_PATH InfiniBand;
414
415 HARDDRIVE_DEVICE_PATH HardDrive;
417
418 FILEPATH_DEVICE_PATH FilePath;
419 MEDIA_PROTOCOL_DEVICE_PATH MediaProtocol;
420
422
424
425typedef union {
426 EFI_DEVICE_PATH *DevPath;
427 PCI_DEVICE_PATH *Pci;
428 PCCARD_DEVICE_PATH *PcCard;
429 MEMMAP_DEVICE_PATH *MemMap;
430 VENDOR_DEVICE_PATH *Vendor;
431 UNKNOWN_DEVICE_VENDOR_DEVICE_PATH *UnknownVendor;
432 CONTROLLER_DEVICE_PATH *Controller;
434 ACPI_EXTENDED_HID_DEVICE_PATH *ExtendedAcpi;
435
436 ATAPI_DEVICE_PATH *Atapi;
437 SCSI_DEVICE_PATH *Scsi;
438 FIBRECHANNEL_DEVICE_PATH *FibreChannel;
439
440 F1394_DEVICE_PATH *F1394;
441 USB_DEVICE_PATH *Usb;
442 USB_CLASS_DEVICE_PATH *UsbClass;
443 I2O_DEVICE_PATH *I2O;
444 MAC_ADDR_DEVICE_PATH *MacAddr;
445 IPv4_DEVICE_PATH *Ipv4;
446 IPv6_DEVICE_PATH *Ipv6;
447 INFINIBAND_DEVICE_PATH *InfiniBand;
449
450 HARDDRIVE_DEVICE_PATH *HardDrive;
451
452 FILEPATH_DEVICE_PATH *FilePath;
453 MEDIA_PROTOCOL_DEVICE_PATH *MediaProtocol;
454
457
459
460#define EFI_LOADED_IMAGE_DEVICE_PATH_PROTOCOL_GUID \
461 { 0xbc62157e, 0x3e33, 0x4fec, { 0x99, 0x20, 0x2d, 0x3b, 0x36, 0xd7, 0x50, 0xdf } }
462
463#define EFI_DEVICE_PATH_TO_TEXT_PROTOCOL_GUID \
464 { 0x8b843e20, 0x8132, 0x4852, { 0x90, 0xcc, 0x55, 0x1a, 0x4e, 0x4a, 0x7f, 0x1c } }
465
466#define EFI_DEVICE_PATH_FROM_TEXT_PROTOCOL_GUID \
467 { 0x05c99a21, 0xc70f, 0x4ad2, { 0x8a, 0x5f, 0x35, 0xdf, 0x33, 0x43, 0xf5, 0x1e } }
468
469INTERFACE_DECL(_EFI_DEVICE_PATH_PROTOCOL);
470
471typedef
472CHAR16*
473(EFIAPI *EFI_DEVICE_PATH_TO_TEXT_NODE) (
474 IN struct _EFI_DEVICE_PATH *This,
475 IN BOOLEAN DisplayOnly,
476 IN BOOLEAN AllowShortCuts
477 );
478
479typedef
480CHAR16*
481(EFIAPI *EFI_DEVICE_PATH_TO_TEXT_PATH) (
482 IN struct _EFI_DEVICE_PATH *This,
483 IN BOOLEAN DisplayOnly,
484 IN BOOLEAN AllowShortCuts
485 );
486
488 EFI_DEVICE_PATH_TO_TEXT_NODE ConvertDeviceNodeToText;
489 EFI_DEVICE_PATH_TO_TEXT_PATH ConvertDevicePathToText;
491
492typedef
493struct _EFI_DEVICE_PATH*
494(EFIAPI *EFI_DEVICE_PATH_FROM_TEXT_NODE) (
495 IN CONST CHAR16* TextDeviceNode
496 );
497typedef
498struct _EFI_DEVICE_PATH*
499(EFIAPI *EFI_DEVICE_PATH_FROM_TEXT_PATH) (
500 IN CONST CHAR16* TextDevicePath
501 );
502
503
505 EFI_DEVICE_PATH_FROM_TEXT_NODE ConvertTextToDeviceNode;
506 EFI_DEVICE_PATH_FROM_TEXT_PATH ConvertTextToDevicePath;
508
509#pragma pack()
510
511#endif
Definition: efidevp.h:293
Definition: efidevp.h:310
Definition: efidef.h:74
Definition: efidef.h:113
Definition: efidef.h:117
Definition: efidef.h:121
Definition: efidevp.h:321
Uart hardware registers.
Definition: component_uart.h:41
Definition: efidevp.h:137
Definition: efidevp.h:130
Definition: efidevp.h:167
Definition: efidevp.h:374
Definition: efidevp.h:347
Definition: efidevp.h:119
Definition: efidevp.h:504
Definition: efidevp.h:487
Definition: efidevp.h:36
Definition: efidevp.h:190
Definition: efidevp.h:182
Definition: efidevp.h:358
Definition: efidevp.h:330
Definition: efidevp.h:214
Definition: efidevp.h:251
Definition: efidevp.h:227
Definition: efidevp.h:240
Definition: efidevp.h:220
Definition: efidevp.h:366
Definition: efidevp.h:97
Definition: efidevp.h:91
Definition: efidevp.h:84
Definition: efidevp.h:300
Definition: efidevp.h:175
Definition: efidevp.h:267
Definition: efidevp.h:113
Definition: efidevp.h:204
Definition: efidevp.h:197
Definition: efidevp.h:105
Definition: efidevp.h:425
Definition: efidevp.h:391
