RTEMS 6.1-rc1
cadence-i2c.h
1/*
2 * SPDX-License-Identifier: BSD-2-Clause
3 *
4 * Copyright (C) 2014 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef LIBBSP_ARM_XILINX_ZYNQ_CADENCE_I2C_H
29#define LIBBSP_ARM_XILINX_ZYNQ_CADENCE_I2C_H
30
31#include <rtems.h>
32
33#ifdef __cplusplus
34extern "C" {
35#endif /* __cplusplus */
36
37int i2c_bus_register_cadence(
38 const char *bus_path,
39 uintptr_t register_base,
40 uint32_t input_clock,
42);
43
44#ifdef __cplusplus
45}
46#endif /* __cplusplus */
47
48#endif /* LIBBSP_ARM_XILINX_ZYNQ_CADENCE_I2C_H */
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
