RTEMS 6.1-rc1
bspcmdline.h
2
17/*
18 * COPYRIGHT (c) 1989-2009.
19 * On-Line Applications Research Corporation (OAR).
20 *
21 * Redistribution and use in source and binary forms, with or without
22 * modification, are permitted provided that the following conditions
23 * are met:
24 * 1. Redistributions of source code must retain the above copyright
25 * notice, this list of conditions and the following disclaimer.
26 * 2. Redistributions in binary form must reproduce the above copyright
27 * notice, this list of conditions and the following disclaimer in the
28 * documentation and/or other materials provided with the distribution.
29 *
30 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
31 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
32 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
33 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
34 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
35 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
36 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
37 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
38 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
39 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
40 * POSSIBILITY OF SUCH DAMAGE.
41 */
42
43#ifndef __BSP_COMMAND_LINE_h
44#define __BSP_COMMAND_LINE_h
45
57#include <stddef.h> /* for size_t */
58
59#ifdef __cplusplus
60extern "C" {
61#endif
62
63
73const char *rtems_bsp_cmdline_get(void);
74
94 const char *name,
95 char *value,
96 size_t length
97);
98
99
119 const char *name,
120 char *value,
121 size_t length
122);
123
143 const char *name
144);
145
146#ifdef __cplusplus
147}
148#endif
149
151#endif
const char * rtems_bsp_cmdline_get(void)
Obtain Pointer to BSP Boot Command String.
Definition: bspcmdline_get.c:45
const char * rtems_bsp_cmdline_get_param(const char *name, char *value, size_t length)
Obtain COPY of the Entire Matching Argument.
Definition: bspcmdline_getparam.c:65
const char * rtems_bsp_cmdline_get_param_raw(const char *name)
Obtain Pointer to the Entire Matching Argument.
Definition: bspcmdline_getparamraw.c:47
const char * rtems_bsp_cmdline_get_param_rhs(const char *name, char *value, size_t length)
Obtain COPY of the Right Hand Side of the Matching Argument.
Definition: bspcmdline_getparamrhs.c:45
