RTEMS 6.1-rc1
This header file defines the Barrier Manager API. More...
#include <stdint.h>
#include <rtems/rtems/attr.h>
rtems_status_code | rtems_barrier_create (rtems_name name, rtems_attribute attribute_set, uint32_t maximum_waiters, rtems_id *id) |
Creates a barrier. More... | |
rtems_status_code | rtems_barrier_ident (rtems_name name, rtems_id *id) |
Identifies a barrier by the object name. More... | |
rtems_status_code | rtems_barrier_delete (rtems_id id) |
Deletes the barrier. More... | |
rtems_status_code | rtems_barrier_wait (rtems_id id, rtems_interval timeout) |
Waits at the barrier. More... | |
rtems_status_code | rtems_barrier_release (rtems_id id, uint32_t *released) |
Releases the barrier. More... | |
