RTEMS 6.1-rc1
ata_internal.h
1/*
2 * ata_internal.h
3 *
4 * ATA RTEMS driver internal header file
5 *
6 * Copyright (C) 2001 OKTET Ltd., St.-Petersburg, Russia
7 * Authors: Eugeny S. Mints <Eugeny.Mints@oktet.ru>
8 * Alexandra Kossovsky <sasha@oktet.ru>
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 *
14 */
15#ifndef __ATA_INTERNAL_H__
16#define __ATA_INTERNAL_H__
17
18#include <sys/param.h>
19#include <sys/endian.h>
20#include <rtems.h>
21#include <sys/types.h>
22#include <rtems/libio.h>
23#include <stdlib.h>
24
25#include <rtems/blkdev.h>
26#include <rtems/diskdevs.h>
27
28#ifdef __cplusplus
29extern "C" {
30#endif
31
32/*
33 * Conversion from and to little-endian byte order. (no-op on i386/i486)
34 *
35 * Naming: Ca_b_c, where a: F = from, T = to, b: LE = little-endian,
36 * BE = big-endian, c: W = word (16 bits), L = longword (32 bits)
37 */
38#define CF_LE_W(v) le16toh(v)
39#define CF_LE_L(v) le32toh(v)
40#define CT_LE_W(v) htole16(v)
41#define CT_LE_L(v) htole32(v)
42
43#define ATA_UNDEFINED_VALUE (-1)
44
45/* Sector size for all ATA devices */
46#define ATA_SECTOR_SIZE 512
47
48
49#define ATA_MAX_CMD_REG_OFFSET 8
50
51
52/* ATA Commands */
53
54/* Types of ATA commands */
55#define ATA_COMMAND_TYPE_NON_DATA 0
56#define ATA_COMMAND_TYPE_PIO_IN 1
57#define ATA_COMMAND_TYPE_PIO_OUT 2
58#define ATA_COMMAND_TYPE_DMA 3
59
60/* ATA commands opcodes */
61/*
62 * Commands present in both ATA-2 and ATA-4 specs.
63 * Some commands have two values in ATA-2,
64 * in such case value from ATA-4 used.
65 * Some commands have slightly different names in these specifications,
66 * so names from ATA-4 are used.
67 */
68#define ATA_COMMAND_NOP 0x00
69#define ATA_COMMAND_READ_SECTORS 0x20
70#define ATA_COMMAND_WRITE_SECTORS 0x30
71#define ATA_COMMAND_READ_VERIFY_SECTORS 0x40
72#define ATA_COMMAND_SEEK 0x70 /* or 0x7. */
73#define ATA_COMMAND_EXECUTE_DEVICE_DIAGNOSTIC 0x90
74#define ATA_COMMAND_INITIALIZE_DEVICE_PARAMETERS 0x91
75#define ATA_COMMAND_DOWNLOAD_MICROCODE 0x92
76#define ATA_COMMAND_READ_MULTIPLE 0xc4
77#define ATA_COMMAND_WRITE_MULTIPLE 0xc5
78#define ATA_COMMAND_SET_MULTIPLE_MODE 0xc6
79#define ATA_COMMAND_READ_DMA 0xc8
80#define ATA_COMMAND_WRITE_DMA 0xca
81#define ATA_COMMAND_STANDBY_IMMEDIATE 0xe0 /* or 0x94 */
82#define ATA_COMMAND_IDLE_IMMEDIATE 0xe1 /* or 0x95 */
83#define ATA_COMMAND_STANDBY 0xe2 /* or 0x96 */
84#define ATA_COMMAND_IDLE 0xe3 /* or 0x97 */
85#define ATA_COMMAND_READ_BUFFER 0xe4
86#define ATA_COMMAND_CHECK_POWER_MODE 0xe5 /* or 0x98 in ATA-2 */
87#define ATA_COMMAND_SLEEP 0xe6 /* or 0x99 */
88#define ATA_COMMAND_WRITE_BUFFER 0xe8
89#define ATA_COMMAND_IDENTIFY_DEVICE 0xec
90#define ATA_COMMAND_SET_FEATURES 0xef
91
92/* Commands present in both ATA-2 and ATA-4 specs: removable media */
93#define ATA_COMMAND_MEDIA_LOCK 0xde
94#define ATA_COMMAND_MEDIA_UNLOCK 0xdf
95#define ATA_COMMAND_MEDIA_EJECT 0xed
96
97
98/* Commands present in ATA-2, but not in ATA-4 (not used) */
99#define ATA_COMMAND_RECALIBRATE 0x10 /* or 0x1. */
100#define ATA_COMMAND_READ_SECTOR_NON_RETRY 0x21
101#define ATA_COMMAND_READ_LONG_RETRY 0x22
102#define ATA_COMMAND_READ_LONG_NON_RETRY 0x23
103#define ATA_COMMAND_WRITE_SECTOR_NON_RETRY 0x31
104#define ATA_COMMAND_WRITE_LONG_RETRY 0x32
105#define ATA_COMMAND_WRITE_LONG_NON_RETRY 0x33
106#define ATA_COMMAND_WRITE_VERIFY 0x3c
107#define ATA_COMMAND_READ_VERIFY_SECTOR_NON_RETRY 0x41
108#define ATA_COMMAND_FORMAT_TRACK 0x50
109#define ATA_COMMAND_READ_DMA_NON_RETRY 0xc9
110#define ATA_COMMAND_WRITE_DMA_NON_RETRY 0xcb
111#define ATA_COMMAND_ACKNOWLEGE_MEDIA_CHANGE 0xdb
112#define ATA_COMMAND_BOOT_POST_BOOT 0xdc
113#define ATA_COMMAND_BOOT_PRE_BOOT 0xdd
114#define ATA_COMMAND_WRITE_SAME 0xe9
115
116/* Commands from ATA-4 specification: CFA feature set */
117#define ATA_COMMAND_CFA_REQUEST_EXTENDED_ERROR_CODE 0x03
118#define ATA_COMMAND_CFA_WRITE_SECTORS_WITHOUT_ERASE 0x38
119#define ATA_COMMAND_CFA_TRANSLATE_SECTOR 0x87
120#define ATA_COMMAND_CFA_ERASE_SECTORS 0xc0
121#define ATA_COMMAND_CFA_WRITE_MULTIPLE_WITHOUT_ERASE 0xcd
122
123/* Commands from ATA-4 specification: commands to use with PACKET command */
124#define ATA_COMMAND_DEVICE_RESET 0x08
125#define ATA_COMMAND_PACKET 0xa0
126#define ATA_COMMAND_IDENTIFY_PACKET_DEVICE 0xa1
127#define ATA_COMMAND_SERVICE 0xa2
128
129/* Commands from ATA-4 specification: SECURITY commands */
130#define ATA_COMMAND_SECURITY_SET_PASSWORD 0xf1
131#define ATA_COMMAND_SECURITY_UNLOCK 0xf2
132#define ATA_COMMAND_SECURITY_ERASE_PREPARE 0xf3
133#define ATA_COMMAND_SECURITY_ERASE_UNIT 0xf4
134#define ATA_COMMAND_SECURITY_FREEZE_LOCK 0xf5
135#define ATA_COMMAND_SECURITY_DISABLE_PASSWORD 0xf6
136
137/* Commands from ATA-4 specification: other commands */
138#define ATA_COMMAND_SMART 0xb0
139#define ATA_COMMAND_READ_DMA_QUEUED 0xc7
140#define ATA_COMMAND_WRITE_DMA_QUEUED 0xcc
141#define ATA_COMMAND_GET_MEDIA_STATUS 0xda
142#define ATA_COMMAND_FLUSH_CACHE 0xe7
143#define ATA_COMMAND_READ_NATIVE_MAX_ADDRESS 0xf8
144#define ATA_COMMAND_SET_MAX_ADDRESS 0xf9
145
146#define ATA_REGISTERS_VALUE(reg) (1 << (reg))
147
148/* ATA IDENTIFY DEVICE command words and bits */
149#define ATA_IDENT_WORD_RW_MULT 47
150#define ATA_IDENT_WORD_CAPABILITIES 49
151#define ATA_IDENT_WORD_FIELD_VALIDITY 53
152#define ATA_IDENT_WORD_NUM_OF_CURR_LOG_CLNDS 54
153#define ATA_IDENT_WORD_NUM_OF_CURR_LOG_HEADS 55
154#define ATA_IDENT_WORD_NUM_OF_CURR_LOG_SECS 56
155#define ATA_IDENT_WORD_MULT_SECS 59
156#define ATA_IDENT_WORD_NUM_OF_USR_SECS0 60
157#define ATA_IDENT_WORD_NUM_OF_USR_SECS1 61
158#define ATA_IDENT_WORD_PIO_SPPRTD 64
159
160#define ATA_IDENT_BIT_VALID 0x02
161
162/*
163 * It is OR for all ATA_REGISTERS_VALUE(reg), where reg is neccessary
164 * for setting block position
165 */
166#define ATA_REGISTERS_POSITION 0xfc
167
168#define ATA_MAX_RTEMS_INT_VEC_NUMBER 255
169
170#define ATA_MAX_NAME_LENGTH 10
171
172/* diagnostic codes */
173#define ATA_DEV0_PASSED_DEV1_PASSED_OR_NOT_PRSNT 0x01
174#define ATA_DEV0_PASSED_DEV1_FAILED 0x81
175#define ATA_DEV1_PASSED_DEV0_FAILED 0x80
176
177/*
178 * Obtain ata device parameters by controller minor number and device number
179 */
180#define ATA_DEV_INFO(controller_minor, dev) \
181 ata_ide_ctrls[controller_minor].device[dev]
182
183/* ATA RTEMS driver internal data stuctures */
184
185/* Command block registers */
186typedef struct ata_registers_s {
187 uint16_t regs[8]; /* command block registers */
188 uint16_t to_read; /* mask: which ata registers should be read */
189 uint16_t to_write; /* mask: which ata registers should be written */
191
192/* ATA request */
193typedef struct ata_req_s {
194 rtems_chain_node link; /* link in requests chain */
195 char type; /* request type */
196 ata_registers_t regs; /* ATA command */
197 uint32_t cnt; /* Number of sectors to be exchanged */
198 uint32_t cbuf; /* number of current buffer from breq in use */
199 uint32_t pos; /* current position in 'cbuf' */
200 rtems_blkdev_request *breq; /* blkdev_request which corresponds to the
201 * ata request
202 */
203 rtems_id sema; /* semaphore which is used if synchronous
204 * processing of the ata request is required
205 */
206 rtems_status_code status; /* status of ata request processing */
207 int info; /* device info code */
208} ata_req_t;
209
210/* call callback provided by block device request if it is defined */
211#define ATA_EXEC_CALLBACK(areq, status) \
212 do {\
213 if ((areq)->breq != NULL) \
214 rtems_blkdev_request_done((areq)->breq, status); \
215 } while (0)
216
217/* ATA RTEMS driver events types */
218typedef enum ata_msg_type_s {
219 ATA_MSG_GEN_EVT = 1, /* general event */
220 ATA_MSG_SUCCESS_EVT, /* success event */
221 ATA_MSG_ERROR_EVT, /* error event */
222 ATA_MSG_PROCESS_NEXT_EVT /* process next request event */
223} ata_msg_type_t;
224
225/* ATA RTEMS driver message */
226typedef struct ata_queue_msg_s {
227 ata_msg_type_t type; /* message type */
228 rtems_device_minor_number ctrl_minor; /* IDE controller minor number */
229 int error; /* error code */
231
232/* macros for messages processing */
233#define ATA_FILL_MSG(msg, evt_type, ctrl, err)\
234 do {\
235 msg.type = evt_type;\
236 msg.ctrl_minor = ctrl;\
237 msg.error = err;\
238 } while (0)
239
240#define ATA_SEND_EVT(msg, type, ctrl, err)\
241 do {\
242 rtems_status_code rc;\
243 ATA_FILL_MSG(msg, type, ctrl, err);\
244 rc = rtems_message_queue_send(ata_queue_id, &msg,\
245 sizeof(ata_queue_msg_t));\
246 if (rc != RTEMS_SUCCESSFUL)\
247 rtems_fatal_error_occurred(RTEMS_INTERNAL_ERROR);\
248 } while (0)
249
250/*
251 * Array of such structures is indexed by interrupt vecotrs and used for
252 * mapping of IDE controllers and interrupt vectors
253 */
254typedef struct ata_int_st_s {
255 rtems_chain_node link;
256 rtems_device_minor_number ctrl_minor;
258
259/*
260 * Mapping of rtems ATA devices to the following pairs:
261 * (IDE controller number served the device, device number on the controller)
262 */
263typedef struct ata_ide_dev_s {
264 int ctrl_minor;/* minor number of IDE controller served rtems ATA device */
265 int device; /* device number on IDE controller (0 or 1) */
267
268/*
269 * ATA device description
270 */
271typedef struct ata_dev_s {
272 int8_t present; /* 1 -- present, 0 -- not present, */
273 /* -1 -- non-initialized */
274 uint16_t cylinders;
275 uint16_t heads;
276 uint16_t sectors;
277 uint32_t lba_sectors; /* for small disk */
278 /* == cylinders * heads * sectors */
279
280 uint8_t lba_avaible; /* 0 - CHS mode, 1 - LBA mode */
281
282 uint16_t modes_available; /* OR of values for this modes */
283 uint16_t mode_active;
284} ata_dev_t;
285
286/*
287 * This structure describes controller state, devices configuration on the
288 * controller and chain of ATA requests to the controller. Array of such
289 * structures is indexed by controller minor number
290 */
291typedef struct ata_ide_ctrl_s {
292 bool present; /* controller state */
293 ata_dev_t device[2]; /* ata diveces description */
294 rtems_chain_control reqs; /* requests chain */
296
297/* Block device request with a single buffer provided */
298typedef struct blkdev_request1 {
302
303void ata_breq_init(blkdev_request1 *breq, uint16_t *sector_buffer);
304
305rtems_status_code ata_identify_device(
306 rtems_device_minor_number ctrl_minor,
307 int dev,
308 uint16_t *sector_buffer,
309 ata_dev_t *device_entry
310);
311
312void ata_process_request_on_init_phase(
313 rtems_device_minor_number ctrl_minor,
314 ata_req_t *areq
315);
316
317#ifdef __cplusplus
318}
319#endif
320
321#endif /* __ATA_INTERNAL_H__ */
Block Device Management.
Block Device Disk Management API.
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition: io.h:115
rtems_status_code
Definition: status.h:85
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
Basic IO API.
This structure represents a chain node.
Definition: chain.h:78
Definition: ata_internal.h:271
Definition: ata_internal.h:291
Definition: ata_internal.h:263
Definition: ata_internal.h:254
Definition: ata_internal.h:226
Definition: ata_internal.h:186
Definition: ata_internal.h:193
Definition: ata_internal.h:298
The block device transfer request is used to read or write a number of blocks from or to the device.
Definition: blkdev.h:102
Block device scatter or gather buffer structure.
Definition: blkdev.h:68
This header file provides interfaces of the system endianness support.
This union represents a chain control block.
Definition: chain.h:96
