RTEMS 6.1-rc1
AT91RM9200 GPIO definitions. More...
#include <bits.h>
#define | PIO_PER 0x00 /* PIO Enable Register */ |
#define | PIO_PDR 0x04 /* PIO Disable Register */ |
#define | PIO_PSR 0x08 /* PIO Status Register */ |
#define | PIO_OER 0x10 /* Output Enable Register */ |
#define | PIO_ODR 0x14 /* Output Disable Registerr */ |
#define | PIO_OSR 0x18 /* Output Status Register */ |
#define | PIO_IFER 0x20 /* Input Filter Enable Register */ |
#define | PIO_IFDR 0x24 /* Input Filter Disable Register */ |
#define | PIO_IFSR 0x28 /* Input Filter Status Register */ |
#define | PIO_SODR 0x30 /* Set Output Data Register */ |
#define | PIO_CODR 0x34 /* Clear Output Data Register */ |
#define | PIO_ODSR 0x38 /* Output Data Status Register */ |
#define | PIO_PDSR 0x3c /* Pin Data Status Register */ |
#define | PIO_IER 0x40 /* Interrupt Enable Register */ |
#define | PIO_IDR 0x44 /* Interrupt Disable Register */ |
#define | PIO_IMR 0x48 /* Interrupt Mask Register */ |
#define | PIO_ISR 0x4c /* Interrupt Status Register */ |
#define | PIO_MDER 0x50 /* Multi-driver Enable Register */ |
#define | PIO_MDDR 0x54 /* Multi-driver Disable Register */ |
#define | PIO_MDSR 0x58 /* Multi-driver Status Register */ |
#define | PIO_PUDR 0x60 /* Pull-up Disable Register */ |
#define | PIO_PUER 0x64 /* Pull-up Enable Register */ |
#define | PIO_PUSR 0x68 /* Pad Pull-up Status Register */ |
#define | PIO_ASR 0x70 /* Select A Register */ |
#define | PIO_BSR 0x74 /* Select B Register */ |
#define | PIO_ABSR 0x78 /* AB Select Status Register */ |
#define | PIO_OWER 0xA0 /* Output Write Enable Register */ |
#define | PIO_OWDR 0xA4 /* Output Write Disable Register */ |
#define | PIO_OWSR 0xA8 /* Output Write Status Register */ |
#define | GPIO_0 BIT0 |
#define | GPIO_1 BIT1 |
#define | GPIO_2 BIT2 |
#define | GPIO_3 BIT3 |
#define | GPIO_4 BIT4 |
#define | GPIO_5 BIT5 |
#define | GPIO_6 BIT6 |
#define | GPIO_7 BIT7 |
#define | GPIO_8 BIT8 |
#define | GPIO_9 BIT9 |
#define | GPIO_10 BIT10 |
#define | GPIO_11 BIT11 |
#define | GPIO_12 BIT12 |
#define | GPIO_13 BIT13 |
#define | GPIO_14 BIT14 |
#define | GPIO_15 BIT15 |
#define | GPIO_16 BIT16 |
#define | GPIO_17 BIT17 |
#define | GPIO_18 BIT18 |
#define | GPIO_19 BIT19 |
#define | GPIO_20 BIT20 |
#define | GPIO_21 BIT21 |
#define | GPIO_22 BIT22 |
#define | GPIO_23 BIT23 |
#define | GPIO_24 BIT24 |
#define | GPIO_25 BIT25 |
#define | GPIO_26 BIT26 |
#define | GPIO_27 BIT27 |
#define | GPIO_28 BIT28 |
#define | GPIO_29 BIT29 |
#define | GPIO_30 BIT30 |
#define | GPIO_31 BIT31 |
#define | GPIO_32 BIT0 |
#define | GPIO_33 BIT1 |
#define | GPIO_34 BIT2 |
#define | GPIO_35 BIT3 |
#define | GPIO_36 BIT4 |
#define | GPIO_37 BIT5 |
#define | GPIO_38 BIT6 |
#define | GPIO_39 BIT7 |
#define | GPIO_40 BIT8 |
#define | GPIO_41 BIT9 |
#define | GPIO_42 BIT10 |
#define | GPIO_43 BIT11 |
#define | GPIO_44 BIT12 |
#define | GPIO_45 BIT13 |
#define | GPIO_46 BIT14 |
#define | GPIO_47 BIT15 |
#define | GPIO_48 BIT16 |
#define | GPIO_49 BIT17 |
#define | GPIO_50 BIT18 |
#define | GPIO_51 BIT19 |
#define | GPIO_52 BIT20 |
#define | GPIO_53 BIT21 |
#define | GPIO_54 BIT22 |
#define | GPIO_55 BIT23 |
#define | GPIO_56 BIT24 |
#define | GPIO_57 BIT25 |
#define | GPIO_58 BIT26 |
#define | GPIO_59 BIT27 |
#define | GPIO_60 BIT28 |
#define | GPIO_61 BIT29 |
#define | GPIO_62 BIT30 |
#define | GPIO_63 BIT31 |
#define | GPIO_64 BIT0 |
#define | GPIO_65 BIT1 |
#define | GPIO_66 BIT2 |
#define | GPIO_67 BIT3 |
#define | GPIO_68 BIT4 |
#define | GPIO_69 BIT5 |
#define | GPIO_70 BIT6 |
#define | GPIO_71 BIT7 |
#define | GPIO_72 BIT8 |
#define | GPIO_73 BIT9 |
#define | GPIO_74 BIT10 |
#define | GPIO_75 BIT11 |
#define | GPIO_76 BIT12 |
#define | GPIO_77 BIT13 |
#define | GPIO_78 BIT14 |
#define | GPIO_79 BIT15 |
#define | GPIO_80 BIT16 |
#define | GPIO_81 BIT17 |
#define | GPIO_82 BIT18 |
#define | GPIO_83 BIT19 |
#define | GPIO_84 BIT20 |
#define | GPIO_85 BIT21 |
#define | GPIO_86 BIT22 |
#define | GPIO_87 BIT23 |
#define | GPIO_88 BIT24 |
#define | GPIO_89 BIT25 |
#define | GPIO_90 BIT26 |
#define | GPIO_91 BIT27 |
#define | GPIO_92 BIT28 |
#define | GPIO_93 BIT29 |
#define | GPIO_94 BIT30 |
#define | GPIO_95 BIT31 |
#define | GPIO_96 BIT0 |
#define | GPIO_97 BIT1 |
#define | GPIO_98 BIT2 |
#define | GPIO_99 BIT3 |
#define | GPIO_100 BIT4 |
#define | GPIO_101 BIT5 |
#define | GPIO_102 BIT6 |
#define | GPIO_103 BIT7 |
#define | GPIO_104 BIT8 |
#define | GPIO_105 BIT9 |
#define | GPIO_106 BIT10 |
#define | GPIO_107 BIT11 |
#define | GPIO_108 BIT12 |
#define | GPIO_109 BIT13 |
#define | GPIO_110 BIT14 |
#define | GPIO_111 BIT15 |
#define | GPIO_112 BIT16 |
#define | GPIO_113 BIT17 |
#define | GPIO_114 BIT18 |
#define | GPIO_115 BIT19 |
#define | GPIO_116 BIT20 |
#define | GPIO_117 BIT21 |
#define | GPIO_118 BIT22 |
#define | GPIO_119 BIT23 |
#define | GPIO_120 BIT24 |
#define | GPIO_121 BIT25 |
#define | GPIO_122 BIT26 |
#define | GPIO_123 BIT27 |
#define | GPIO_124 BIT28 |
#define | GPIO_125 BIT29 |
#define | GPIO_126 BIT30 |
#define | GPIO_127 BIT31 |
#define | PIOA_ASR_MISO BIT0 /* SPI Master In (RX), Slave out */ |
#define | PIOA_ASR_MOSI BIT1 /* SPI Master Out (TX), Slave In */ |
#define | PIOA_ASR_SPCK BIT2 /* SPI Clock */ |
#define | PIOA_ASR_NPCS0 BIT3 /* SPI Chip Select 0 */ |
#define | PIOA_ASR_NPCS1 BIT4 /* SPI Chip Select 1 */ |
#define | PIOA_ASR_NPCS2 BIT5 /* SPI Chip Select 2 */ |
#define | PIOA_ASR_NPCS3 BIT6 /* SPI Chip Select 3 */ |
#define | PIOA_ASR_ETXCK BIT7 /* EMAC TX Clock */ |
#define | PIOA_ASR_ETXEN BIT8 /* EMAC TXEN */ |
#define | PIOA_ASR_ETX0 BIT9 /* EMAC TXD0 */ |
#define | PIOA_ASR_ETX1 BIT10 /* EMAC TXD1 */ |
#define | PIOA_ASR_ECRS BIT11 /* EMAC CRS */ |
#define | PIOA_ASR_ERX0 BIT12 /* EMAC RXD0 */ |
#define | PIOA_ASR_ERX1 BIT13 /* EMAC RXD1 */ |
#define | PIOA_ASR_ERXER BIT14 /* EMAC RXER */ |
#define | PIOA_ASR_EMDC BIT15 /* EMAC MDC */ |
#define | PIOA_ASR_EMDIO BIT16 /* EMAC MDIO */ |
#define | PIOA_ASR_TXD0 BIT17 /* USART 0 Receive */ |
#define | PIOA_ASR_RXD0 BIT18 /* USART 0 Transmit */ |
#define | PIOA_ASR_SCK0 BIT19 /* USART 0 Clock */ |
#define | PIOA_ASR_CTS0 BIT20 /* USART 0 CTS */ |
#define | PIOA_ASR_RTS0 BIT21 /* USART 0 RTS */ |
#define | PIOA_ASR_RXD2 BIT22 /* USART 2 Receive */ |
#define | PIOA_ASR_TXD2 BIT23 /* USART 2 Transmit */ |
#define | PIOA_ASR_SCK2 BIT24 /* USART 2 Clock */ |
#define | PIOA_ASR_TWD BIT25 /* Two-Wire (I2C) Data */ |
#define | PIOA_ASR_TWCK BIT26 /* Two-Wire (I2C) Clock */ |
#define | PIOA_ASR_MCCK BIT27 /* MMC/SD Card Clock */ |
#define | PIOA_ASR_MCCDA BIT28 /* MMC/SD Card A Command */ |
#define | PIOA_ASR_MCDA0 BIT29 /* MMC/SD Card A Data 0 */ |
#define | PIOA_ASR_DRXD BIT30 /* Debug Uart Receive */ |
#define | PIOA_ASR_DTXD BIT31 /* Debug Uart Transmit */ |
#define | PIOA_BSR_PCK3 BIT0 /* Peripheral Clock 3 */ |
#define | PIOA_BSR_PCK0 BIT1 /* Peripheral Clock 0 */ |
#define | PIOA_BSR_IRQ4 BIT2 /* IRQ4 */ |
#define | PIOA_BSR_IRQ5 BIT3 /* IRQ5 */ |
#define | PIOA_BSR_TXD3 BIT5 /* USART 3 Transmit */ |
#define | PIOA_BSR_RXD3 BIT6 /* USART 3 Receive */ |
#define | PIOA_BSR_PCK2 BIT7 /* Peripheral Clock 2 */ |
#define | PIOA_BSR_MCCDB BIT8 /* MMC/SD Card B Command */ |
#define | PIOA_BSR_MCDB0 BIT9 /* MMC/SD Card B Data 0 */ |
#define | PIOA_BSR_MCDB1 BIT10 /* MMC/SD Card B Data 1 */ |
#define | PIOA_BSR_MCDB2 BIT11 /* MMC/SD Card B Data 2 */ |
#define | PIOA_BSR_MCDB3 BIT12 /* MMC/SD C ard B Data 3 */ |
#define | PIOA_BSR_TCLK0 BIT13 /* Timer 0 Clock */ |
#define | PIOA_BSR_TCLK1 BIT14 /* Timer 1 Clck */ |
#define | PIOA_BSR_TCLK2 BIT15 /* Timer 2 Clock */ |
#define | PIOA_BSR_IRQ6 BIT16 /* IRQ6 */ |
#define | PIOA_BSR_TIOA0 BIT17 /* Timer 0 I/O A */ |
#define | PIOA_BSR_TIOB0 BIT18 /* Timer 0 I/O B */ |
#define | PIOA_BSR_TIOA1 BIT19 /* Timer 1 I/O A */ |
#define | PIOA_BSR_TIOB1 BIT20 /* Timer 1 I/O B */ |
#define | PIOA_BSR_TIOA2 BIT21 /* Timer 2 I/O A */ |
#define | PIOA_BSR_TIOB2 BIT22 /* Timer 2 I/O B */ |
#define | PIOA_BSR_IRQ3 BIT23 /* IRQ3 */ |
#define | PIOA_BSR_PCK1 BIT24 /* Peripheral Clock 1 */ |
#define | PIOA_BSR_IRQ2 BIT25 /* IRQ2 */ |
#define | PIOA_BSR_IRQ1 BIT26 /* IRQ1 */ |
#define | PIOA_BSR_TCLK3 BIT27 /* Timer Block Clock 3 (docs only show 0-2?) */ |
#define | PIOA_BSR_TCLK4 BIT28 /* Timer Block Clock 4 */ |
#define | PIOA_BSR_TCLK5 BIT29 /* Timer Block Clock 5 */ |
#define | PIOA_BSR_CTS2 BIT30 /* USART 2 CTS */ |
#define | PIOA_BSR_RTS2 BIT31 /* USART 2 RTS */ |
#define | PIOB_ASR_TF0 BIT0 /* AC'97/I2S 0 Transmit Frame */ |
#define | PIOB_ASR_TK0 BIT1 /* AC'97/I2S 0 Transmit Clock */ |
#define | PIOB_ASR_TD0 BIT2 /* AC'97/I2S 0 Transmit Data */ |
#define | PIOB_ASR_RD0 BIT3 /* AC'97/I2S 0 Receive Data */ |
#define | PIOB_ASR_RK0 BIT4 /* AC'97/I2S 0 Receive Clock */ |
#define | PIOB_ASR_RF0 BIT5 /* AC'97/I2S 0 Receive Frame */ |
#define | PIOB_ASR_TF1 BIT6 /* AC'97/I2S 1 Transmit Frame */ |
#define | PIOB_ASR_TK1 BIT7 /* AC'97/I2S 1 Transmit Clock */ |
#define | PIOB_ASR_TD1 BIT8 /* AC'97/I2S 1 Transmit Data */ |
#define | PIOB_ASR_RD1 BIT9 /* AC'97/I2S 1 Receive Data */ |
#define | PIOB_ASR_RK1 BIT10 /* AC'97/I2S 1 Receive Clock */ |
#define | PIOB_ASR_RF1 BIT11 /* AC'97/I2S 1 Receive Frame */ |
#define | PIOB_ASR_TF2 BIT12 /* AC'97/I2S 1 Transmit Frame */ |
#define | PIOB_ASR_TK2 BIT13 /* AC'97/I2S 1 Transmit Clock */ |
#define | PIOB_ASR_TD2 BIT14 /* AC'97/I2S 1 Transmit Data */ |
#define | PIOB_ASR_RD2 BIT15 /* AC'97/I2S 1 Receive Data */ |
#define | PIOB_ASR_RK2 BIT16 /* AC'97/I2S 1 Receive Clock */ |
#define | PIOB_ASR_RF2 BIT17 /* AC'97/I2S 1 Receive Frame */ |
#define | PIOB_ASR_RI1 BIT18 /* USART 1 RI */ |
#define | PIOB_ASR_DTR1 BIT19 /* USART 1 DTR */ |
#define | PIOB_ASR_TXD1 BIT20 /* USART 1 TXD */ |
#define | PIOB_ASR_RXD1 BIT21 /* USART 1 RXD */ |
#define | PIOB_ASR_SCK1 BIT22 /* USART 1 SCK */ |
#define | PIOB_ASR_DCD1 BIT23 /* USART 1 DCD */ |
#define | PIOB_ASR_CTS1 BIT24 /* USART 1 CTS */ |
#define | PIOB_ASR_DSR1 BIT25 /* USART 1 DSR */ |
#define | PIOB_ASR_RTS1 BIT26 /* USART 1 RTS */ |
#define | PIOB_ASR_PCK0 BIT27 /* Peripheral Clock 0 */ |
#define | PIOB_ASR_FIQ BIT28 /* FIQ */ |
#define | PIOB_ASR_IRQ0 BIT29 /* IRQ0 */ |
#define | PIOB_BSR_RTS3 BIT0 /* USART 3 */ |
#define | PIOB_BSR_CTS3 BIT1 /* USART 3 */ |
#define | PIOB_BSR_SCK3 BIT2 /* USART 3 */ |
#define | PIOB_BSR_MCDA1 BIT3 /* MMC/SD Card A, Data 1 */ |
#define | PIOB_BSR_MCDA2 BIT4 /* MMC/SD Card A, Data 2 */ |
#define | PIOB_BSR_MCDA3 BIT5 /* MMC/SD Card A, Data 3 */ |
#define | PIOB_BSR_TIOA3 BIT6 /* Timer 3 IO A */ |
#define | PIOB_BSR_TIOB3 BIT7 /* Timer 3 IO B */ |
#define | PIOB_BSR_TIOA4 BIT8 /* Timer 4 IO A */ |
#define | PIOB_BSR_TIOB4 BIT9 /* Timer 4 IO B */ |
#define | PIOB_BSR_TIOA5 BIT10 /* Timer 5 IO A */ |
#define | PIOB_BSR_TIOB5 BIT11 /* Timer 5 IO B */ |
#define | PIOB_BSR_ETX2 BIT12 /* EMAC TXD2 */ |
#define | PIOB_BSR_ETX3 BIT13 /* EMAC TXD3 */ |
#define | PIOB_BSR_ETXER BIT14 /* EMAC TXER */ |
#define | PIOB_BSR_ERX2 BIT15 /* EMAC RXD2 */ |
#define | PIOB_BSR_ERX3 BIT16 /* EMAC RXD3 */ |
#define | PIOB_BSR_ERXDV BIT17 /* EMAC RXDV */ |
#define | PIOB_BSR_ECOL BIT18 /* EMAC COL */ |
#define | PIOB_BSR_ERXCK BIT19 /* EMAC RX Clock */ |
#define | PIOB_BSR_EF100 BIT25 /* EMAC Speed 100 (RMII Only) */ |
#define | PIOC_ASR_BFCK BIT0 /* Burst Flash Clock */ |
#define | PIOC_ASR_BFRDY BIT1 /* Burst Flash Ready or SMC Card OE */ |
#define | PIOC_ASR_BFAVD BIT2 /* Burst Flash Address Valid */ |
#define | PIOC_ASR_BFBAA BIT3 /* Burst Flash Address Advance or SMC Card WE */ |
#define | PIOC_ASR_BFOE BIT4 /* Burst Flash OE */ |
#define | PIOC_ASR_BFWE BIT5 /* Burst Flash WE */ |
#define | PIOC_ASR_NWAIT BIT6 /* WAIT Input */ |
#define | PIOC_ASR_A23 BIT7 /* A23 */ |
#define | PIOC_ASR_A24 BIT8 /* A24 */ |
#define | PIOC_ASR_A25 BIT9 /* A25 or Compact Flash R/W */ |
#define | PIOC_ASR_NCS4 BIT10 /* CS4 or Compact Flash CS */ |
#define | PIOC_ASR_NCS5 BIT11 /* CS5 or Compact Flash CE1 */ |
#define | PIOC_ASR_NCS6 BIT12 /* CS6 or Compact Flash CE2 */ |
#define | PIOC_ASR_NCS7 BIT13 /* CS7 */ |
#define | PIOC_ASR_D16 BIT16 /* Databus Bit 16 */ |
#define | PIOC_ASR_D17 BIT17 /* Databus Bit 17 */ |
#define | PIOC_ASR_D18 BIT18 /* Databus Bit 18 */ |
#define | PIOC_ASR_D19 BIT19 /* Databus Bit 19 */ |
#define | PIOC_ASR_D20 BIT20 /* Databus Bit 20 */ |
#define | PIOC_ASR_D21 BIT21 /* Databus Bit 21 */ |
#define | PIOC_ASR_D22 BIT22 /* Databus Bit 22 */ |
#define | PIOC_ASR_D23 BIT23 /* Databus Bit 23 */ |
#define | PIOC_ASR_D24 BIT24 /* Databus Bit 24 */ |
#define | PIOC_ASR_D25 BIT25 /* Databus Bit 25 */ |
#define | PIOC_ASR_D26 BIT26 /* Databus Bit 26 */ |
#define | PIOC_ASR_D27 BIT27 /* Databus Bit 27 */ |
#define | PIOC_ASR_D28 BIT28 /* Databus Bit 28 */ |
#define | PIOC_ASR_D29 BIT29 /* Databus Bit 29 */ |
#define | PIOC_ASR_D30 BIT30 /* Databus Bit 30 */ |
#define | PIOC_ASR_D31 BIT31 /* Databus Bit 31 */ |
#define | PIOD_ASR_ETX0 BIT0 /* EMAC TXD0 */ |
#define | PIOD_ASR_ETX1 BIT1 /* EMAC TXD1 */ |
#define | PIOD_ASR_ETX2 BIT2 /* EMAC TXD2 */ |
#define | PIOD_ASR_ETX3 BIT3 /* EMAC TXD3 */ |
#define | PIOD_ASR_ETXEN BIT4 /* EMAC TXEN */ |
#define | PIOD_ASR_ETXER BIT5 /* EMAC TXER */ |
#define | PIOD_ASR_DTXD BIT6 /* Debug UART Transmit */ |
#define | PIOD_ASR_PCK0 BIT7 /* Peripheral Clock 0 */ |
#define | PIOD_ASR_PCK1 BIT8 /* Peripheral Clock 1 */ |
#define | PIOD_ASR_PCK2 BIT9 /* Peripheral Clock 2 */ |
#define | PIOD_ASR_PCK3 BIT10 /* Peripheral Clock 3 */ |
#define | PIOD_ASR_TD0 BIT15 /* AC'97/I2S 0 Transmit Data */ |
#define | PIOD_ASR_TD1 BIT16 /* AC'97/I2S 1 Transmit Data */ |
#define | PIOD_ASR_TD2 BIT17 /* AC'97/I2S 2 Transmit Data */ |
#define | PIOD_ASR_NPCS1 BIT18 /* SPI Chip Select 1 */ |
#define | PIOD_ASR_NPCS2 BIT19 /* SPI Chip Select 2 */ |
#define | PIOD_ASR_NPCS3 BIT20 /* SPI Chip Select 3 */ |
#define | PIOD_ASR_RTS0 BIT21 /* USART 0 RTS */ |
#define | PIOD_ASR_RTS1 BIT22 /* USART 1 RTS */ |
#define | PIOD_ASR_RTS2 BIT23 /* USART 2 RTS */ |
#define | PIOD_ASR_RTS3 BIT24 /* USART 3 RTS */ |
#define | PIOD_ASR_DTR1 BIT25 /* USART 1 DTR */ |
#define | PIOC_ASR_TSYNC BIT7 /* ETM Sync */ |
#define | PIOC_ASR_TCLK BIT8 /* ETM Clock */ |
#define | PIOC_ASR_TPS0 BIT9 /* ETM Processor Status 0 */ |
#define | PIOC_ASR_TPS1 BIT10 /* ETM Processor Status 1 */ |
#define | PIOC_ASR_TPS2 BIT11 /* ETM Processor Status 2 */ |
#define | PIOC_ASR_TPK0 BIT12 /* ETM Packet Data 0 */ |
#define | PIOC_ASR_TPK1 BIT13 /* ETM Packet Data 1 */ |
#define | PIOC_ASR_TPK2 BIT14 /* ETM Packet Data 2 */ |
#define | PIOC_ASR_TPK3 BIT15 /* ETM Packet Data 3 */ |
#define | PIOC_ASR_TPK4 BIT16 /* ETM Packet Data 4 */ |
#define | PIOC_ASR_TPK5 BIT17 /* ETM Packet Data 5 */ |
#define | PIOC_ASR_TPK6 BIT18 /* ETM Packet Data 6 */ |
#define | PIOC_ASR_TPK7 BIT19 /* ETM Packet Data 7 */ |
#define | PIOC_ASR_TPK8 BIT20 /* ETM Packet Data 8 */ |
#define | PIOC_ASR_TPK9 BIT21 /* ETM Packet Data 9 */ |
#define | PIOC_ASR_TPK10 BIT22 /* ETM Packet Data 10 */ |
#define | PIOC_ASR_TPK11 BIT23 /* ETM Packet Data 11 */ |
#define | PIOC_ASR_TPK12 BIT24 /* ETM Packet Data 12 */ |
#define | PIOC_ASR_TPK13 BIT25 /* ETM Packet Data 13 */ |
#define | PIOC_ASR_TPK14 BIT26 /* ETM Packet Data 14 */ |
#define | PIOC_ASR_TPK15 BIT27 /* ETM Packet Data 15 */ |
