RTEMS 6.1-rc1
arm-pl011.h
2
11/*
12 * Copyright (C) 2013, 2014 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_SHARED_ARM_PL011_H
37#define LIBBSP_ARM_SHARED_ARM_PL011_H
38
39#include <rtems/termiostypes.h>
40
42
43#ifdef __cplusplus
44extern "C" {
45#endif /* __cplusplus */
46
47typedef struct {
49 volatile pl011 *regs;
51 uint32_t initial_baud;
53
54bool arm_pl011_probe(rtems_termios_device_context *base);
55
56void arm_pl011_write_polled(rtems_termios_device_context *base, char c);
57
58extern const rtems_termios_device_handler arm_pl011_fns;
59
60#ifdef __cplusplus
61}
62#endif /* __cplusplus */
63
64#endif /* LIBBSP_ARM_SHARED_ARM_PL011_H */
ARM PL011 Register definitions.
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
Definition: arm-pl011.h:47
Definition: arm-pl011-regs.h:41
Termios device context.
Definition: termiosdevice.h:68
Termios device handler.
Definition: termiosdevice.h:100
