RTEMS 6.1-rc1
arm-generic-timer.h
2
11/*
12 * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
13 * Written by Kinsey Moore <kinsey.moore@oarcorp.com>
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
38
46
53void arm_gt_clock_set_compare_value(uint64_t cval);
54
60uint64_t arm_gt_clock_get_count(void);
61
67void arm_gt_clock_set_control(uint32_t ctl);
68
76void arm_generic_timer_get_config(uint32_t *frequency, uint32_t *irq);
Definition: arm-generic-timer-aarch64.c:85
uint64_t arm_gt_clock_get_compare_value(void)
Definition: arm-generic-timer-aarch64.c:40
Definition: arm-generic-timer-aarch64.c:100
Definition: arm-generic-timer-aarch64.c:71
Definition: arm-generic-timer-aarch64.c:56
This header file provides basic definitions used by the API and the implementation.
