39#ifndef __ALTERA_ALT_CLKMGR_H__
40#define __ALTERA_ALT_CLKMGR_H__
89#define ALT_CLKMGR_CTL_SAFEMOD_LSB 0
91#define ALT_CLKMGR_CTL_SAFEMOD_MSB 0
93#define ALT_CLKMGR_CTL_SAFEMOD_WIDTH 1
95#define ALT_CLKMGR_CTL_SAFEMOD_SET_MSK 0x00000001
97#define ALT_CLKMGR_CTL_SAFEMOD_CLR_MSK 0xfffffffe
99#define ALT_CLKMGR_CTL_SAFEMOD_RESET 0x1
101#define ALT_CLKMGR_CTL_SAFEMOD_GET(value) (((value) & 0x00000001) >> 0)
103#define ALT_CLKMGR_CTL_SAFEMOD_SET(value) (((value) << 0) & 0x00000001)
117#define ALT_CLKMGR_CTL_ENSFMDWR_LSB 2
119#define ALT_CLKMGR_CTL_ENSFMDWR_MSB 2
121#define ALT_CLKMGR_CTL_ENSFMDWR_WIDTH 1
123#define ALT_CLKMGR_CTL_ENSFMDWR_SET_MSK 0x00000004
125#define ALT_CLKMGR_CTL_ENSFMDWR_CLR_MSK 0xfffffffb
127#define ALT_CLKMGR_CTL_ENSFMDWR_RESET 0x1
129#define ALT_CLKMGR_CTL_ENSFMDWR_GET(value) (((value) & 0x00000004) >> 2)
131#define ALT_CLKMGR_CTL_ENSFMDWR_SET(value) (((value) << 2) & 0x00000004)
146 uint32_t safemode : 1;
148 uint32_t ensfmdwr : 1;
157#define ALT_CLKMGR_CTL_OFST 0x0
190#define ALT_CLKMGR_BYPASS_MAINPLL_LSB 0
192#define ALT_CLKMGR_BYPASS_MAINPLL_MSB 0
194#define ALT_CLKMGR_BYPASS_MAINPLL_WIDTH 1
196#define ALT_CLKMGR_BYPASS_MAINPLL_SET_MSK 0x00000001
198#define ALT_CLKMGR_BYPASS_MAINPLL_CLR_MSK 0xfffffffe
200#define ALT_CLKMGR_BYPASS_MAINPLL_RESET 0x1
202#define ALT_CLKMGR_BYPASS_MAINPLL_GET(value) (((value) & 0x00000001) >> 0)
204#define ALT_CLKMGR_BYPASS_MAINPLL_SET(value) (((value) << 0) & 0x00000001)
223#define ALT_CLKMGR_BYPASS_SDRPLL_LSB 1
225#define ALT_CLKMGR_BYPASS_SDRPLL_MSB 1
227#define ALT_CLKMGR_BYPASS_SDRPLL_WIDTH 1
229#define ALT_CLKMGR_BYPASS_SDRPLL_SET_MSK 0x00000002
231#define ALT_CLKMGR_BYPASS_SDRPLL_CLR_MSK 0xfffffffd
233#define ALT_CLKMGR_BYPASS_SDRPLL_RESET 0x1
235#define ALT_CLKMGR_BYPASS_SDRPLL_GET(value) (((value) & 0x00000002) >> 1)
237#define ALT_CLKMGR_BYPASS_SDRPLL_SET(value) (((value) << 1) & 0x00000002)
265#define ALT_CLKMGR_BYPASS_SDRPLLSRC_E_SELECT_EOSC1 0x0
271#define ALT_CLKMGR_BYPASS_SDRPLLSRC_E_SELECT_INPUT_MUX 0x1
274#define ALT_CLKMGR_BYPASS_SDRPLLSRC_LSB 2
276#define ALT_CLKMGR_BYPASS_SDRPLLSRC_MSB 2
278#define ALT_CLKMGR_BYPASS_SDRPLLSRC_WIDTH 1
280#define ALT_CLKMGR_BYPASS_SDRPLLSRC_SET_MSK 0x00000004
282#define ALT_CLKMGR_BYPASS_SDRPLLSRC_CLR_MSK 0xfffffffb
284#define ALT_CLKMGR_BYPASS_SDRPLLSRC_RESET 0x0
286#define ALT_CLKMGR_BYPASS_SDRPLLSRC_GET(value) (((value) & 0x00000004) >> 2)
288#define ALT_CLKMGR_BYPASS_SDRPLLSRC_SET(value) (((value) << 2) & 0x00000004)
307#define ALT_CLKMGR_BYPASS_PERPLL_LSB 3
309#define ALT_CLKMGR_BYPASS_PERPLL_MSB 3
311#define ALT_CLKMGR_BYPASS_PERPLL_WIDTH 1
313#define ALT_CLKMGR_BYPASS_PERPLL_SET_MSK 0x00000008
315#define ALT_CLKMGR_BYPASS_PERPLL_CLR_MSK 0xfffffff7
317#define ALT_CLKMGR_BYPASS_PERPLL_RESET 0x1
319#define ALT_CLKMGR_BYPASS_PERPLL_GET(value) (((value) & 0x00000008) >> 3)
321#define ALT_CLKMGR_BYPASS_PERPLL_SET(value) (((value) << 3) & 0x00000008)
349#define ALT_CLKMGR_BYPASS_PERPLLSRC_E_SELECT_EOSC1 0x0
355#define ALT_CLKMGR_BYPASS_PERPLLSRC_E_SELECT_INPUT_MUX 0x1
358#define ALT_CLKMGR_BYPASS_PERPLLSRC_LSB 4
360#define ALT_CLKMGR_BYPASS_PERPLLSRC_MSB 4
362#define ALT_CLKMGR_BYPASS_PERPLLSRC_WIDTH 1
364#define ALT_CLKMGR_BYPASS_PERPLLSRC_SET_MSK 0x00000010
366#define ALT_CLKMGR_BYPASS_PERPLLSRC_CLR_MSK 0xffffffef
368#define ALT_CLKMGR_BYPASS_PERPLLSRC_RESET 0x0
370#define ALT_CLKMGR_BYPASS_PERPLLSRC_GET(value) (((value) & 0x00000010) >> 4)
372#define ALT_CLKMGR_BYPASS_PERPLLSRC_SET(value) (((value) << 4) & 0x00000010)
387 uint32_t mainpll : 1;
389 uint32_t sdrpllsrc : 1;
391 uint32_t perpllsrc : 1;
400#define ALT_CLKMGR_BYPASS_OFST 0x4
435#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_LSB 0
437#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_MSB 0
439#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_WIDTH 1
441#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_SET_MSK 0x00000001
443#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_CLR_MSK 0xfffffffe
445#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_RESET 0x0
447#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_GET(value) (((value) & 0x00000001) >> 0)
449#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_SET(value) (((value) << 0) & 0x00000001)
462#define ALT_CLKMGR_INTER_PERPLLACHIEVED_LSB 1
464#define ALT_CLKMGR_INTER_PERPLLACHIEVED_MSB 1
466#define ALT_CLKMGR_INTER_PERPLLACHIEVED_WIDTH 1
468#define ALT_CLKMGR_INTER_PERPLLACHIEVED_SET_MSK 0x00000002
470#define ALT_CLKMGR_INTER_PERPLLACHIEVED_CLR_MSK 0xfffffffd
472#define ALT_CLKMGR_INTER_PERPLLACHIEVED_RESET 0x0
474#define ALT_CLKMGR_INTER_PERPLLACHIEVED_GET(value) (((value) & 0x00000002) >> 1)
476#define ALT_CLKMGR_INTER_PERPLLACHIEVED_SET(value) (((value) << 1) & 0x00000002)
488#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_LSB 2
490#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_MSB 2
492#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_WIDTH 1
494#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_SET_MSK 0x00000004
496#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_CLR_MSK 0xfffffffb
498#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_RESET 0x0
500#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_GET(value) (((value) & 0x00000004) >> 2)
502#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_SET(value) (((value) << 2) & 0x00000004)
514#define ALT_CLKMGR_INTER_MAINPLLLOST_LSB 3
516#define ALT_CLKMGR_INTER_MAINPLLLOST_MSB 3
518#define ALT_CLKMGR_INTER_MAINPLLLOST_WIDTH 1
520#define ALT_CLKMGR_INTER_MAINPLLLOST_SET_MSK 0x00000008
522#define ALT_CLKMGR_INTER_MAINPLLLOST_CLR_MSK 0xfffffff7
524#define ALT_CLKMGR_INTER_MAINPLLLOST_RESET 0x0
526#define ALT_CLKMGR_INTER_MAINPLLLOST_GET(value) (((value) & 0x00000008) >> 3)
528#define ALT_CLKMGR_INTER_MAINPLLLOST_SET(value) (((value) << 3) & 0x00000008)
540#define ALT_CLKMGR_INTER_PERPLLLOST_LSB 4
542#define ALT_CLKMGR_INTER_PERPLLLOST_MSB 4
544#define ALT_CLKMGR_INTER_PERPLLLOST_WIDTH 1
546#define ALT_CLKMGR_INTER_PERPLLLOST_SET_MSK 0x00000010
548#define ALT_CLKMGR_INTER_PERPLLLOST_CLR_MSK 0xffffffef
550#define ALT_CLKMGR_INTER_PERPLLLOST_RESET 0x0
552#define ALT_CLKMGR_INTER_PERPLLLOST_GET(value) (((value) & 0x00000010) >> 4)
554#define ALT_CLKMGR_INTER_PERPLLLOST_SET(value) (((value) << 4) & 0x00000010)
566#define ALT_CLKMGR_INTER_SDRPLLLOST_LSB 5
568#define ALT_CLKMGR_INTER_SDRPLLLOST_MSB 5
570#define ALT_CLKMGR_INTER_SDRPLLLOST_WIDTH 1
572#define ALT_CLKMGR_INTER_SDRPLLLOST_SET_MSK 0x00000020
574#define ALT_CLKMGR_INTER_SDRPLLLOST_CLR_MSK 0xffffffdf
576#define ALT_CLKMGR_INTER_SDRPLLLOST_RESET 0x0
578#define ALT_CLKMGR_INTER_SDRPLLLOST_GET(value) (((value) & 0x00000020) >> 5)
580#define ALT_CLKMGR_INTER_SDRPLLLOST_SET(value) (((value) << 5) & 0x00000020)
592#define ALT_CLKMGR_INTER_MAINPLLLOCKED_LSB 6
594#define ALT_CLKMGR_INTER_MAINPLLLOCKED_MSB 6
596#define ALT_CLKMGR_INTER_MAINPLLLOCKED_WIDTH 1
598#define ALT_CLKMGR_INTER_MAINPLLLOCKED_SET_MSK 0x00000040
600#define ALT_CLKMGR_INTER_MAINPLLLOCKED_CLR_MSK 0xffffffbf
602#define ALT_CLKMGR_INTER_MAINPLLLOCKED_RESET 0x0
604#define ALT_CLKMGR_INTER_MAINPLLLOCKED_GET(value) (((value) & 0x00000040) >> 6)
606#define ALT_CLKMGR_INTER_MAINPLLLOCKED_SET(value) (((value) << 6) & 0x00000040)
618#define ALT_CLKMGR_INTER_PERPLLLOCKED_LSB 7
620#define ALT_CLKMGR_INTER_PERPLLLOCKED_MSB 7
622#define ALT_CLKMGR_INTER_PERPLLLOCKED_WIDTH 1
624#define ALT_CLKMGR_INTER_PERPLLLOCKED_SET_MSK 0x00000080
626#define ALT_CLKMGR_INTER_PERPLLLOCKED_CLR_MSK 0xffffff7f
628#define ALT_CLKMGR_INTER_PERPLLLOCKED_RESET 0x0
630#define ALT_CLKMGR_INTER_PERPLLLOCKED_GET(value) (((value) & 0x00000080) >> 7)
632#define ALT_CLKMGR_INTER_PERPLLLOCKED_SET(value) (((value) << 7) & 0x00000080)
644#define ALT_CLKMGR_INTER_SDRPLLLOCKED_LSB 8
646#define ALT_CLKMGR_INTER_SDRPLLLOCKED_MSB 8
648#define ALT_CLKMGR_INTER_SDRPLLLOCKED_WIDTH 1
650#define ALT_CLKMGR_INTER_SDRPLLLOCKED_SET_MSK 0x00000100
652#define ALT_CLKMGR_INTER_SDRPLLLOCKED_CLR_MSK 0xfffffeff
654#define ALT_CLKMGR_INTER_SDRPLLLOCKED_RESET 0x0
656#define ALT_CLKMGR_INTER_SDRPLLLOCKED_GET(value) (((value) & 0x00000100) >> 8)
658#define ALT_CLKMGR_INTER_SDRPLLLOCKED_SET(value) (((value) << 8) & 0x00000100)
673 uint32_t mainpllachieved : 1;
674 uint32_t perpllachieved : 1;
675 uint32_t sdrpllachieved : 1;
676 uint32_t mainplllost : 1;
677 uint32_t perplllost : 1;
678 uint32_t sdrplllost : 1;
679 const uint32_t mainplllocked : 1;
680 const uint32_t perplllocked : 1;
681 const uint32_t sdrplllocked : 1;
690#define ALT_CLKMGR_INTER_OFST 0x8
723#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_LSB 0
725#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_MSB 0
727#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_WIDTH 1
729#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_SET_MSK 0x00000001
731#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_CLR_MSK 0xfffffffe
733#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_RESET 0x0
735#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_GET(value) (((value) & 0x00000001) >> 0)
737#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_SET(value) (((value) << 0) & 0x00000001)
750#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_LSB 1
752#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_MSB 1
754#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_WIDTH 1
756#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_SET_MSK 0x00000002
758#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_CLR_MSK 0xfffffffd
760#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_RESET 0x0
762#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_GET(value) (((value) & 0x00000002) >> 1)
764#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_SET(value) (((value) << 1) & 0x00000002)
777#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_LSB 2
779#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_MSB 2
781#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_WIDTH 1
783#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_SET_MSK 0x00000004
785#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_CLR_MSK 0xfffffffb
787#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_RESET 0x0
789#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_GET(value) (((value) & 0x00000004) >> 2)
791#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_SET(value) (((value) << 2) & 0x00000004)
804#define ALT_CLKMGR_INTREN_MAINPLLLOST_LSB 3
806#define ALT_CLKMGR_INTREN_MAINPLLLOST_MSB 3
808#define ALT_CLKMGR_INTREN_MAINPLLLOST_WIDTH 1
810#define ALT_CLKMGR_INTREN_MAINPLLLOST_SET_MSK 0x00000008
812#define ALT_CLKMGR_INTREN_MAINPLLLOST_CLR_MSK 0xfffffff7
814#define ALT_CLKMGR_INTREN_MAINPLLLOST_RESET 0x0
816#define ALT_CLKMGR_INTREN_MAINPLLLOST_GET(value) (((value) & 0x00000008) >> 3)
818#define ALT_CLKMGR_INTREN_MAINPLLLOST_SET(value) (((value) << 3) & 0x00000008)
831#define ALT_CLKMGR_INTREN_PERPLLLOST_LSB 4
833#define ALT_CLKMGR_INTREN_PERPLLLOST_MSB 4
835#define ALT_CLKMGR_INTREN_PERPLLLOST_WIDTH 1
837#define ALT_CLKMGR_INTREN_PERPLLLOST_SET_MSK 0x00000010
839#define ALT_CLKMGR_INTREN_PERPLLLOST_CLR_MSK 0xffffffef
841#define ALT_CLKMGR_INTREN_PERPLLLOST_RESET 0x0
843#define ALT_CLKMGR_INTREN_PERPLLLOST_GET(value) (((value) & 0x00000010) >> 4)
845#define ALT_CLKMGR_INTREN_PERPLLLOST_SET(value) (((value) << 4) & 0x00000010)
858#define ALT_CLKMGR_INTREN_SDRPLLLOST_LSB 5
860#define ALT_CLKMGR_INTREN_SDRPLLLOST_MSB 5
862#define ALT_CLKMGR_INTREN_SDRPLLLOST_WIDTH 1
864#define ALT_CLKMGR_INTREN_SDRPLLLOST_SET_MSK 0x00000020
866#define ALT_CLKMGR_INTREN_SDRPLLLOST_CLR_MSK 0xffffffdf
868#define ALT_CLKMGR_INTREN_SDRPLLLOST_RESET 0x0
870#define ALT_CLKMGR_INTREN_SDRPLLLOST_GET(value) (((value) & 0x00000020) >> 5)
872#define ALT_CLKMGR_INTREN_SDRPLLLOST_SET(value) (((value) << 5) & 0x00000020)
887 uint32_t mainpllachieved : 1;
888 uint32_t perpllachieved : 1;
889 uint32_t sdrpllachieved : 1;
890 uint32_t mainplllost : 1;
891 uint32_t perplllost : 1;
892 uint32_t sdrplllost : 1;
901#define ALT_CLKMGR_INTREN_OFST 0xc
933#define ALT_CLKMGR_DBCTL_STAYOSC1_LSB 0
935#define ALT_CLKMGR_DBCTL_STAYOSC1_MSB 0
937#define ALT_CLKMGR_DBCTL_STAYOSC1_WIDTH 1
939#define ALT_CLKMGR_DBCTL_STAYOSC1_SET_MSK 0x00000001
941#define ALT_CLKMGR_DBCTL_STAYOSC1_CLR_MSK 0xfffffffe
943#define ALT_CLKMGR_DBCTL_STAYOSC1_RESET 0x1
945#define ALT_CLKMGR_DBCTL_STAYOSC1_GET(value) (((value) & 0x00000001) >> 0)
947#define ALT_CLKMGR_DBCTL_STAYOSC1_SET(value) (((value) << 0) & 0x00000001)
966#define ALT_CLKMGR_DBCTL_ENSFMDWR_LSB 1
968#define ALT_CLKMGR_DBCTL_ENSFMDWR_MSB 1
970#define ALT_CLKMGR_DBCTL_ENSFMDWR_WIDTH 1
972#define ALT_CLKMGR_DBCTL_ENSFMDWR_SET_MSK 0x00000002
974#define ALT_CLKMGR_DBCTL_ENSFMDWR_CLR_MSK 0xfffffffd
976#define ALT_CLKMGR_DBCTL_ENSFMDWR_RESET 0x1
978#define ALT_CLKMGR_DBCTL_ENSFMDWR_GET(value) (((value) & 0x00000002) >> 1)
980#define ALT_CLKMGR_DBCTL_ENSFMDWR_SET(value) (((value) << 1) & 0x00000002)
995 uint32_t stayosc1 : 1;
996 uint32_t ensfmdwr : 1;
1005#define ALT_CLKMGR_DBCTL_OFST 0x10
1048#define ALT_CLKMGR_STAT_BUSY_E_IDLE 0x0
1054#define ALT_CLKMGR_STAT_BUSY_E_BUSY 0x1
1057#define ALT_CLKMGR_STAT_BUSY_LSB 0
1059#define ALT_CLKMGR_STAT_BUSY_MSB 0
1061#define ALT_CLKMGR_STAT_BUSY_WIDTH 1
1063#define ALT_CLKMGR_STAT_BUSY_SET_MSK 0x00000001
1065#define ALT_CLKMGR_STAT_BUSY_CLR_MSK 0xfffffffe
1067#define ALT_CLKMGR_STAT_BUSY_RESET 0x0
1069#define ALT_CLKMGR_STAT_BUSY_GET(value) (((value) & 0x00000001) >> 0)
1071#define ALT_CLKMGR_STAT_BUSY_SET(value) (((value) << 0) & 0x00000001)
1086 const uint32_t busy : 1;
1095#define ALT_CLKMGR_STAT_OFST 0x14
1137#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_LSB 0
1139#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_MSB 0
1141#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_WIDTH 1
1143#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_SET_MSK 0x00000001
1145#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_CLR_MSK 0xfffffffe
1147#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_RESET 0x1
1149#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_GET(value) (((value) & 0x00000001) >> 0)
1151#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_SET(value) (((value) << 0) & 0x00000001)
1162#define ALT_CLKMGR_MAINPLL_VCO_EN_LSB 1
1164#define ALT_CLKMGR_MAINPLL_VCO_EN_MSB 1
1166#define ALT_CLKMGR_MAINPLL_VCO_EN_WIDTH 1
1168#define ALT_CLKMGR_MAINPLL_VCO_EN_SET_MSK 0x00000002
1170#define ALT_CLKMGR_MAINPLL_VCO_EN_CLR_MSK 0xfffffffd
1172#define ALT_CLKMGR_MAINPLL_VCO_EN_RESET 0x0
1174#define ALT_CLKMGR_MAINPLL_VCO_EN_GET(value) (((value) & 0x00000002) >> 1)
1176#define ALT_CLKMGR_MAINPLL_VCO_EN_SET(value) (((value) << 1) & 0x00000002)
1187#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_LSB 2
1189#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_MSB 2
1191#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_WIDTH 1
1193#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_SET_MSK 0x00000004
1195#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_CLR_MSK 0xfffffffb
1197#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_RESET 0x1
1199#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_GET(value) (((value) & 0x00000004) >> 2)
1201#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_SET(value) (((value) << 2) & 0x00000004)
1215#define ALT_CLKMGR_MAINPLL_VCO_NUMER_LSB 3
1217#define ALT_CLKMGR_MAINPLL_VCO_NUMER_MSB 15
1219#define ALT_CLKMGR_MAINPLL_VCO_NUMER_WIDTH 13
1221#define ALT_CLKMGR_MAINPLL_VCO_NUMER_SET_MSK 0x0000fff8
1223#define ALT_CLKMGR_MAINPLL_VCO_NUMER_CLR_MSK 0xffff0007
1225#define ALT_CLKMGR_MAINPLL_VCO_NUMER_RESET 0x1
1227#define ALT_CLKMGR_MAINPLL_VCO_NUMER_GET(value) (((value) & 0x0000fff8) >> 3)
1229#define ALT_CLKMGR_MAINPLL_VCO_NUMER_SET(value) (((value) << 3) & 0x0000fff8)
1243#define ALT_CLKMGR_MAINPLL_VCO_DENOM_LSB 16
1245#define ALT_CLKMGR_MAINPLL_VCO_DENOM_MSB 21
1247#define ALT_CLKMGR_MAINPLL_VCO_DENOM_WIDTH 6
1249#define ALT_CLKMGR_MAINPLL_VCO_DENOM_SET_MSK 0x003f0000
1251#define ALT_CLKMGR_MAINPLL_VCO_DENOM_CLR_MSK 0xffc0ffff
1253#define ALT_CLKMGR_MAINPLL_VCO_DENOM_RESET 0x1
1255#define ALT_CLKMGR_MAINPLL_VCO_DENOM_GET(value) (((value) & 0x003f0000) >> 16)
1257#define ALT_CLKMGR_MAINPLL_VCO_DENOM_SET(value) (((value) << 16) & 0x003f0000)
1275#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_LSB 24
1277#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_MSB 24
1279#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_WIDTH 1
1281#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_SET_MSK 0x01000000
1283#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_CLR_MSK 0xfeffffff
1285#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_RESET 0x0
1287#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_GET(value) (((value) & 0x01000000) >> 24)
1289#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_SET(value) (((value) << 24) & 0x01000000)
1316#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_LSB 25
1318#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_MSB 30
1320#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_WIDTH 6
1322#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_SET_MSK 0x7e000000
1324#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_CLR_MSK 0x81ffffff
1326#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_RESET 0x0
1328#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_GET(value) (((value) & 0x7e000000) >> 25)
1330#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_SET(value) (((value) << 25) & 0x7e000000)
1353#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_LSB 31
1355#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_MSB 31
1357#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_WIDTH 1
1359#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_SET_MSK 0x80000000
1361#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_CLR_MSK 0x7fffffff
1363#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_RESET 0x1
1365#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_GET(value) (((value) & 0x80000000) >> 31)
1367#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_SET(value) (((value) << 31) & 0x80000000)
1382 uint32_t bgpwrdn : 1;
1385 uint32_t numer : 13;
1388 uint32_t outresetall : 1;
1389 uint32_t outreset : 6;
1390 uint32_t regextsel : 1;
1398#define ALT_CLKMGR_MAINPLL_VCO_OFST 0x0
1433#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_LSB 0
1435#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_MSB 0
1437#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_WIDTH 1
1439#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_SET_MSK 0x00000001
1441#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_CLR_MSK 0xfffffffe
1443#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_RESET 0x0
1445#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_GET(value) (((value) & 0x00000001) >> 0)
1447#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_SET(value) (((value) << 0) & 0x00000001)
1458#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_LSB 1
1460#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_MSB 12
1462#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_WIDTH 12
1464#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_SET_MSK 0x00001ffe
1466#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_CLR_MSK 0xffffe001
1468#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_RESET 0x1
1470#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_GET(value) (((value) & 0x00001ffe) >> 1)
1472#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_SET(value) (((value) << 1) & 0x00001ffe)
1483#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_LSB 13
1485#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_MSB 13
1487#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_WIDTH 1
1489#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_SET_MSK 0x00002000
1491#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_CLR_MSK 0xffffdfff
1493#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_RESET 0x0
1495#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_GET(value) (((value) & 0x00002000) >> 13)
1497#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_SET(value) (((value) << 13) & 0x00002000)
1508#define ALT_CLKMGR_MAINPLL_MISC_SATEN_LSB 14
1510#define ALT_CLKMGR_MAINPLL_MISC_SATEN_MSB 14
1512#define ALT_CLKMGR_MAINPLL_MISC_SATEN_WIDTH 1
1514#define ALT_CLKMGR_MAINPLL_MISC_SATEN_SET_MSK 0x00004000
1516#define ALT_CLKMGR_MAINPLL_MISC_SATEN_CLR_MSK 0xffffbfff
1518#define ALT_CLKMGR_MAINPLL_MISC_SATEN_RESET 0x1
1520#define ALT_CLKMGR_MAINPLL_MISC_SATEN_GET(value) (((value) & 0x00004000) >> 14)
1522#define ALT_CLKMGR_MAINPLL_MISC_SATEN_SET(value) (((value) << 14) & 0x00004000)
1537 uint32_t bwadjen : 1;
1538 uint32_t bwadj : 12;
1539 uint32_t fasten : 1;
1549#define ALT_CLKMGR_MAINPLL_MISC_OFST 0x4
1576#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_LSB 0
1578#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_MSB 8
1580#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_WIDTH 9
1582#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_SET_MSK 0x000001ff
1584#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_CLR_MSK 0xfffffe00
1586#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_RESET 0x0
1588#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
1590#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
1614#define ALT_CLKMGR_MAINPLL_MPUCLK_OFST 0x8
1641#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_LSB 0
1643#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_MSB 8
1645#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_WIDTH 9
1647#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_SET_MSK 0x000001ff
1649#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_CLR_MSK 0xfffffe00
1651#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_RESET 0x0
1653#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
1655#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
1679#define ALT_CLKMGR_MAINPLL_MAINCLK_OFST 0xc
1706#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_LSB 0
1708#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_MSB 8
1710#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_WIDTH 9
1712#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_SET_MSK 0x000001ff
1714#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_CLR_MSK 0xfffffe00
1716#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_RESET 0x0
1718#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
1720#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
1744#define ALT_CLKMGR_MAINPLL_DBGATCLK_OFST 0x10
1771#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_LSB 0
1773#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_MSB 8
1775#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_WIDTH 9
1777#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_SET_MSK 0x000001ff
1779#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_CLR_MSK 0xfffffe00
1781#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_RESET 0x3
1783#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
1785#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
1809#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_OFST 0x14
1836#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_LSB 0
1838#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_MSB 8
1840#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_WIDTH 9
1842#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_SET_MSK 0x000001ff
1844#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_CLR_MSK 0xfffffe00
1846#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_RESET 0x3
1848#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
1850#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
1874#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_OFST 0x18
1903#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_LSB 0
1905#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_MSB 8
1907#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_WIDTH 9
1909#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_SET_MSK 0x000001ff
1911#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_CLR_MSK 0xfffffe00
1913#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_RESET 0xf
1915#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
1917#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
1941#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_OFST 0x1c
1980#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_LSB 0
1982#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_MSB 0
1984#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_WIDTH 1
1986#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_SET_MSK 0x00000001
1988#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_CLR_MSK 0xfffffffe
1990#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_RESET 0x1
1992#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_GET(value) (((value) & 0x00000001) >> 0)
1994#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_SET(value) (((value) << 0) & 0x00000001)
2005#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_LSB 1
2007#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_MSB 1
2009#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_WIDTH 1
2011#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_SET_MSK 0x00000002
2013#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_CLR_MSK 0xfffffffd
2015#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_RESET 0x1
2017#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_GET(value) (((value) & 0x00000002) >> 1)
2019#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_SET(value) (((value) << 1) & 0x00000002)
2030#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_LSB 2
2032#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_MSB 2
2034#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_WIDTH 1
2036#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_SET_MSK 0x00000004
2038#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_CLR_MSK 0xfffffffb
2040#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_RESET 0x1
2042#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_GET(value) (((value) & 0x00000004) >> 2)
2044#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_SET(value) (((value) << 2) & 0x00000004)
2055#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_LSB 3
2057#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_MSB 3
2059#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_WIDTH 1
2061#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_SET_MSK 0x00000008
2063#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_CLR_MSK 0xfffffff7
2065#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_RESET 0x1
2067#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_GET(value) (((value) & 0x00000008) >> 3)
2069#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_SET(value) (((value) << 3) & 0x00000008)
2080#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_LSB 4
2082#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_MSB 4
2084#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_WIDTH 1
2086#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_SET_MSK 0x00000010
2088#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_CLR_MSK 0xffffffef
2090#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_RESET 0x1
2092#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_GET(value) (((value) & 0x00000010) >> 4)
2094#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_SET(value) (((value) << 4) & 0x00000010)
2105#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_LSB 5
2107#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_MSB 5
2109#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_WIDTH 1
2111#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_SET_MSK 0x00000020
2113#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_CLR_MSK 0xffffffdf
2115#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_RESET 0x1
2117#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_GET(value) (((value) & 0x00000020) >> 5)
2119#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_SET(value) (((value) << 5) & 0x00000020)
2130#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_LSB 6
2132#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_MSB 6
2134#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_WIDTH 1
2136#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_SET_MSK 0x00000040
2138#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_CLR_MSK 0xffffffbf
2140#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_RESET 0x1
2142#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_GET(value) (((value) & 0x00000040) >> 6)
2144#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_SET(value) (((value) << 6) & 0x00000040)
2155#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_LSB 7
2157#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_MSB 7
2159#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_WIDTH 1
2161#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_SET_MSK 0x00000080
2163#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_CLR_MSK 0xffffff7f
2165#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_RESET 0x1
2167#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_GET(value) (((value) & 0x00000080) >> 7)
2169#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_SET(value) (((value) << 7) & 0x00000080)
2180#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_LSB 8
2182#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_MSB 8
2184#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_WIDTH 1
2186#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_SET_MSK 0x00000100
2188#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_CLR_MSK 0xfffffeff
2190#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_RESET 0x1
2192#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_GET(value) (((value) & 0x00000100) >> 8)
2194#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_SET(value) (((value) << 8) & 0x00000100)
2207#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_LSB 9
2209#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_MSB 9
2211#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_WIDTH 1
2213#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_SET_MSK 0x00000200
2215#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_CLR_MSK 0xfffffdff
2217#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_RESET 0x1
2219#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_GET(value) (((value) & 0x00000200) >> 9)
2221#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_SET(value) (((value) << 9) & 0x00000200)
2236 uint32_t l4mainclk : 1;
2237 uint32_t l3mpclk : 1;
2238 uint32_t l4mpclk : 1;
2239 uint32_t l4spclk : 1;
2240 uint32_t dbgatclk : 1;
2241 uint32_t dbgclk : 1;
2242 uint32_t dbgtraceclk : 1;
2243 uint32_t dbgtimerclk : 1;
2244 uint32_t cfgclk : 1;
2245 uint32_t s2fuser0clk : 1;
2254#define ALT_CLKMGR_MAINPLL_EN_OFST 0x20
2296#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_E_DIV1 0x0
2302#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_E_DIV2 0x1
2305#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_LSB 0
2307#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_MSB 1
2309#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_WIDTH 2
2311#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_SET_MSK 0x00000003
2313#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_CLR_MSK 0xfffffffc
2315#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_RESET 0x0
2317#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_GET(value) (((value) & 0x00000003) >> 0)
2319#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_SET(value) (((value) << 0) & 0x00000003)
2342#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_E_DIV1 0x0
2348#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_E_DIV2 0x1
2351#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_LSB 2
2353#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_MSB 3
2355#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_WIDTH 2
2357#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_SET_MSK 0x0000000c
2359#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_CLR_MSK 0xfffffff3
2361#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_RESET 0x0
2363#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_GET(value) (((value) & 0x0000000c) >> 2)
2365#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_SET(value) (((value) << 2) & 0x0000000c)
2394#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV1 0x0
2400#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV2 0x1
2406#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV4 0x2
2412#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV8 0x3
2418#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV16 0x4
2424#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_1 0x5
2430#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_2 0x6
2436#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_3 0x7
2439#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_LSB 4
2441#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_MSB 6
2443#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_WIDTH 3
2445#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_SET_MSK 0x00000070
2447#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_CLR_MSK 0xffffff8f
2449#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_RESET 0x0
2451#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_GET(value) (((value) & 0x00000070) >> 4)
2453#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_SET(value) (((value) << 4) & 0x00000070)
2482#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV1 0x0
2488#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV2 0x1
2494#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV4 0x2
2500#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV8 0x3
2506#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV16 0x4
2512#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_1 0x5
2518#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_2 0x6
2524#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_3 0x7
2527#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_LSB 7
2529#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_MSB 9
2531#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_WIDTH 3
2533#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_SET_MSK 0x00000380
2535#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_CLR_MSK 0xfffffc7f
2537#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_RESET 0x0
2539#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_GET(value) (((value) & 0x00000380) >> 7)
2541#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_SET(value) (((value) << 7) & 0x00000380)
2556 uint32_t l3mpclk : 2;
2557 uint32_t l3spclk : 2;
2558 uint32_t l4mpclk : 3;
2559 uint32_t l4spclk : 3;
2568#define ALT_CLKMGR_MAINPLL_MAINDIV_OFST 0x24
2609#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV1 0x0
2615#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV2 0x1
2621#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV4 0x2
2624#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_LSB 0
2626#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_MSB 1
2628#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_WIDTH 2
2630#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_SET_MSK 0x00000003
2632#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_CLR_MSK 0xfffffffc
2634#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_RESET 0x0
2636#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_GET(value) (((value) & 0x00000003) >> 0)
2638#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_SET(value) (((value) << 0) & 0x00000003)
2661#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_E_DIV2 0x1
2667#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_E_DIV4 0x2
2670#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_LSB 2
2672#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_MSB 3
2674#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_WIDTH 2
2676#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_SET_MSK 0x0000000c
2678#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_CLR_MSK 0xfffffff3
2680#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_RESET 0x1
2682#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_GET(value) (((value) & 0x0000000c) >> 2)
2684#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_SET(value) (((value) << 2) & 0x0000000c)
2699 uint32_t dbgatclk : 2;
2700 uint32_t dbgclk : 2;
2709#define ALT_CLKMGR_MAINPLL_DBGDIV_OFST 0x28
2754#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV1 0x0
2760#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV2 0x1
2766#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV4 0x2
2772#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV8 0x3
2778#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV16 0x4
2784#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_1 0x5
2790#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_2 0x6
2796#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_3 0x7
2799#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_LSB 0
2801#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_MSB 2
2803#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_WIDTH 3
2805#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_SET_MSK 0x00000007
2807#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_CLR_MSK 0xfffffff8
2809#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_RESET 0x0
2811#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_GET(value) (((value) & 0x00000007) >> 0)
2813#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_SET(value) (((value) << 0) & 0x00000007)
2828 uint32_t traceclk : 3;
2837#define ALT_CLKMGR_MAINPLL_TRACEDIV_OFST 0x2c
2875#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_E_MAINPLL 0x0
2881#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_E_PERIPHPLL 0x1
2884#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_LSB 0
2886#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_MSB 0
2888#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_WIDTH 1
2890#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_SET_MSK 0x00000001
2892#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_CLR_MSK 0xfffffffe
2894#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_RESET 0x0
2896#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_GET(value) (((value) & 0x00000001) >> 0)
2898#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_SET(value) (((value) << 0) & 0x00000001)
2920#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_E_MAINPLL 0x0
2926#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_E_PERIPHPLL 0x1
2929#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_LSB 1
2931#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_MSB 1
2933#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_WIDTH 1
2935#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_SET_MSK 0x00000002
2937#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_CLR_MSK 0xfffffffd
2939#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_RESET 0x0
2941#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_GET(value) (((value) & 0x00000002) >> 1)
2943#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_SET(value) (((value) << 1) & 0x00000002)
2968#define ALT_CLKMGR_MAINPLL_L4SRC_OFST 0x30
3015#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_E_IDLE 0x0
3021#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_E_ACK_RXD 0x1
3024#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_LSB 0
3026#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_MSB 5
3028#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_WIDTH 6
3030#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_SET_MSK 0x0000003f
3032#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_CLR_MSK 0xffffffc0
3034#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_RESET 0x0
3036#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_GET(value) (((value) & 0x0000003f) >> 0)
3038#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_SET(value) (((value) << 0) & 0x0000003f)
3053 const uint32_t outresetack : 6;
3062#define ALT_CLKMGR_MAINPLL_STAT_OFST 0x34
3091 volatile uint32_t _pad_0x38_0x40[2];
3099 volatile uint32_t vco;
3100 volatile uint32_t misc;
3101 volatile uint32_t mpuclk;
3102 volatile uint32_t mainclk;
3103 volatile uint32_t dbgatclk;
3104 volatile uint32_t mainqspiclk;
3105 volatile uint32_t mainnandsdmmcclk;
3106 volatile uint32_t cfgs2fuser0clk;
3107 volatile uint32_t en;
3108 volatile uint32_t maindiv;
3109 volatile uint32_t dbgdiv;
3110 volatile uint32_t tracediv;
3111 volatile uint32_t l4src;
3112 volatile uint32_t stat;
3113 volatile uint32_t _pad_0x38_0x40[2];
3161#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_LSB 0
3163#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_MSB 0
3165#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_WIDTH 1
3167#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_SET_MSK 0x00000001
3169#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_CLR_MSK 0xfffffffe
3171#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_RESET 0x1
3173#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_GET(value) (((value) & 0x00000001) >> 0)
3175#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_SET(value) (((value) << 0) & 0x00000001)
3186#define ALT_CLKMGR_PERPLL_VCO_EN_LSB 1
3188#define ALT_CLKMGR_PERPLL_VCO_EN_MSB 1
3190#define ALT_CLKMGR_PERPLL_VCO_EN_WIDTH 1
3192#define ALT_CLKMGR_PERPLL_VCO_EN_SET_MSK 0x00000002
3194#define ALT_CLKMGR_PERPLL_VCO_EN_CLR_MSK 0xfffffffd
3196#define ALT_CLKMGR_PERPLL_VCO_EN_RESET 0x0
3198#define ALT_CLKMGR_PERPLL_VCO_EN_GET(value) (((value) & 0x00000002) >> 1)
3200#define ALT_CLKMGR_PERPLL_VCO_EN_SET(value) (((value) << 1) & 0x00000002)
3211#define ALT_CLKMGR_PERPLL_VCO_PWRDN_LSB 2
3213#define ALT_CLKMGR_PERPLL_VCO_PWRDN_MSB 2
3215#define ALT_CLKMGR_PERPLL_VCO_PWRDN_WIDTH 1
3217#define ALT_CLKMGR_PERPLL_VCO_PWRDN_SET_MSK 0x00000004
3219#define ALT_CLKMGR_PERPLL_VCO_PWRDN_CLR_MSK 0xfffffffb
3221#define ALT_CLKMGR_PERPLL_VCO_PWRDN_RESET 0x1
3223#define ALT_CLKMGR_PERPLL_VCO_PWRDN_GET(value) (((value) & 0x00000004) >> 2)
3225#define ALT_CLKMGR_PERPLL_VCO_PWRDN_SET(value) (((value) << 2) & 0x00000004)
3239#define ALT_CLKMGR_PERPLL_VCO_NUMER_LSB 3
3241#define ALT_CLKMGR_PERPLL_VCO_NUMER_MSB 15
3243#define ALT_CLKMGR_PERPLL_VCO_NUMER_WIDTH 13
3245#define ALT_CLKMGR_PERPLL_VCO_NUMER_SET_MSK 0x0000fff8
3247#define ALT_CLKMGR_PERPLL_VCO_NUMER_CLR_MSK 0xffff0007
3249#define ALT_CLKMGR_PERPLL_VCO_NUMER_RESET 0x1
3251#define ALT_CLKMGR_PERPLL_VCO_NUMER_GET(value) (((value) & 0x0000fff8) >> 3)
3253#define ALT_CLKMGR_PERPLL_VCO_NUMER_SET(value) (((value) << 3) & 0x0000fff8)
3267#define ALT_CLKMGR_PERPLL_VCO_DENOM_LSB 16
3269#define ALT_CLKMGR_PERPLL_VCO_DENOM_MSB 21
3271#define ALT_CLKMGR_PERPLL_VCO_DENOM_WIDTH 6
3273#define ALT_CLKMGR_PERPLL_VCO_DENOM_SET_MSK 0x003f0000
3275#define ALT_CLKMGR_PERPLL_VCO_DENOM_CLR_MSK 0xffc0ffff
3277#define ALT_CLKMGR_PERPLL_VCO_DENOM_RESET 0x1
3279#define ALT_CLKMGR_PERPLL_VCO_DENOM_GET(value) (((value) & 0x003f0000) >> 16)
3281#define ALT_CLKMGR_PERPLL_VCO_DENOM_SET(value) (((value) << 16) & 0x003f0000)
3306#define ALT_CLKMGR_PERPLL_VCO_PSRC_E_EOSC1 0x0
3312#define ALT_CLKMGR_PERPLL_VCO_PSRC_E_EOSC2 0x1
3318#define ALT_CLKMGR_PERPLL_VCO_PSRC_E_F2S_PERIPH_REF 0x2
3321#define ALT_CLKMGR_PERPLL_VCO_PSRC_LSB 22
3323#define ALT_CLKMGR_PERPLL_VCO_PSRC_MSB 23
3325#define ALT_CLKMGR_PERPLL_VCO_PSRC_WIDTH 2
3327#define ALT_CLKMGR_PERPLL_VCO_PSRC_SET_MSK 0x00c00000
3329#define ALT_CLKMGR_PERPLL_VCO_PSRC_CLR_MSK 0xff3fffff
3331#define ALT_CLKMGR_PERPLL_VCO_PSRC_RESET 0x0
3333#define ALT_CLKMGR_PERPLL_VCO_PSRC_GET(value) (((value) & 0x00c00000) >> 22)
3335#define ALT_CLKMGR_PERPLL_VCO_PSRC_SET(value) (((value) << 22) & 0x00c00000)
3353#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_LSB 24
3355#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_MSB 24
3357#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_WIDTH 1
3359#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_SET_MSK 0x01000000
3361#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_CLR_MSK 0xfeffffff
3363#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_RESET 0x0
3365#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_GET(value) (((value) & 0x01000000) >> 24)
3367#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_SET(value) (((value) << 24) & 0x01000000)
3394#define ALT_CLKMGR_PERPLL_VCO_OUTRST_LSB 25
3396#define ALT_CLKMGR_PERPLL_VCO_OUTRST_MSB 30
3398#define ALT_CLKMGR_PERPLL_VCO_OUTRST_WIDTH 6
3400#define ALT_CLKMGR_PERPLL_VCO_OUTRST_SET_MSK 0x7e000000
3402#define ALT_CLKMGR_PERPLL_VCO_OUTRST_CLR_MSK 0x81ffffff
3404#define ALT_CLKMGR_PERPLL_VCO_OUTRST_RESET 0x0
3406#define ALT_CLKMGR_PERPLL_VCO_OUTRST_GET(value) (((value) & 0x7e000000) >> 25)
3408#define ALT_CLKMGR_PERPLL_VCO_OUTRST_SET(value) (((value) << 25) & 0x7e000000)
3431#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_LSB 31
3433#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_MSB 31
3435#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_WIDTH 1
3437#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_SET_MSK 0x80000000
3439#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_CLR_MSK 0x7fffffff
3441#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_RESET 0x1
3443#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_GET(value) (((value) & 0x80000000) >> 31)
3445#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_SET(value) (((value) << 31) & 0x80000000)
3460 uint32_t bgpwrdn : 1;
3463 uint32_t numer : 13;
3466 uint32_t outresetall : 1;
3467 uint32_t outreset : 6;
3468 uint32_t regextsel : 1;
3476#define ALT_CLKMGR_PERPLL_VCO_OFST 0x0
3511#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_LSB 0
3513#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_MSB 0
3515#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_WIDTH 1
3517#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_SET_MSK 0x00000001
3519#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_CLR_MSK 0xfffffffe
3521#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_RESET 0x0
3523#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_GET(value) (((value) & 0x00000001) >> 0)
3525#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_SET(value) (((value) << 0) & 0x00000001)
3536#define ALT_CLKMGR_PERPLL_MISC_BWADJ_LSB 1
3538#define ALT_CLKMGR_PERPLL_MISC_BWADJ_MSB 12
3540#define ALT_CLKMGR_PERPLL_MISC_BWADJ_WIDTH 12
3542#define ALT_CLKMGR_PERPLL_MISC_BWADJ_SET_MSK 0x00001ffe
3544#define ALT_CLKMGR_PERPLL_MISC_BWADJ_CLR_MSK 0xffffe001
3546#define ALT_CLKMGR_PERPLL_MISC_BWADJ_RESET 0x1
3548#define ALT_CLKMGR_PERPLL_MISC_BWADJ_GET(value) (((value) & 0x00001ffe) >> 1)
3550#define ALT_CLKMGR_PERPLL_MISC_BWADJ_SET(value) (((value) << 1) & 0x00001ffe)
3561#define ALT_CLKMGR_PERPLL_MISC_FASTEN_LSB 13
3563#define ALT_CLKMGR_PERPLL_MISC_FASTEN_MSB 13
3565#define ALT_CLKMGR_PERPLL_MISC_FASTEN_WIDTH 1
3567#define ALT_CLKMGR_PERPLL_MISC_FASTEN_SET_MSK 0x00002000
3569#define ALT_CLKMGR_PERPLL_MISC_FASTEN_CLR_MSK 0xffffdfff
3571#define ALT_CLKMGR_PERPLL_MISC_FASTEN_RESET 0x0
3573#define ALT_CLKMGR_PERPLL_MISC_FASTEN_GET(value) (((value) & 0x00002000) >> 13)
3575#define ALT_CLKMGR_PERPLL_MISC_FASTEN_SET(value) (((value) << 13) & 0x00002000)
3586#define ALT_CLKMGR_PERPLL_MISC_SATEN_LSB 14
3588#define ALT_CLKMGR_PERPLL_MISC_SATEN_MSB 14
3590#define ALT_CLKMGR_PERPLL_MISC_SATEN_WIDTH 1
3592#define ALT_CLKMGR_PERPLL_MISC_SATEN_SET_MSK 0x00004000
3594#define ALT_CLKMGR_PERPLL_MISC_SATEN_CLR_MSK 0xffffbfff
3596#define ALT_CLKMGR_PERPLL_MISC_SATEN_RESET 0x1
3598#define ALT_CLKMGR_PERPLL_MISC_SATEN_GET(value) (((value) & 0x00004000) >> 14)
3600#define ALT_CLKMGR_PERPLL_MISC_SATEN_SET(value) (((value) << 14) & 0x00004000)
3615 uint32_t bwadjen : 1;
3616 uint32_t bwadj : 12;
3617 uint32_t fasten : 1;
3627#define ALT_CLKMGR_PERPLL_MISC_OFST 0x4
3654#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_LSB 0
3656#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_MSB 8
3658#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_WIDTH 9
3660#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_SET_MSK 0x000001ff
3662#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_CLR_MSK 0xfffffe00
3664#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_RESET 0x1
3666#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
3668#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
3692#define ALT_CLKMGR_PERPLL_EMAC0CLK_OFST 0x8
3719#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_LSB 0
3721#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_MSB 8
3723#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_WIDTH 9
3725#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_SET_MSK 0x000001ff
3727#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_CLR_MSK 0xfffffe00
3729#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_RESET 0x1
3731#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
3733#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
3757#define ALT_CLKMGR_PERPLL_EMAC1CLK_OFST 0xc
3784#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_LSB 0
3786#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_MSB 8
3788#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_WIDTH 9
3790#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_SET_MSK 0x000001ff
3792#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_CLR_MSK 0xfffffe00
3794#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_RESET 0x1
3796#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
3798#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
3822#define ALT_CLKMGR_PERPLL_PERQSPICLK_OFST 0x10
3849#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_LSB 0
3851#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_MSB 8
3853#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_WIDTH 9
3855#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_SET_MSK 0x000001ff
3857#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_CLR_MSK 0xfffffe00
3859#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_RESET 0x1
3861#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
3863#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
3887#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_OFST 0x14
3914#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_LSB 0
3916#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_MSB 8
3918#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_WIDTH 9
3920#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_SET_MSK 0x000001ff
3922#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_CLR_MSK 0xfffffe00
3924#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_RESET 0x1
3926#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
3928#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
3952#define ALT_CLKMGR_PERPLL_PERBASECLK_OFST 0x18
3981#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_LSB 0
3983#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_MSB 8
3985#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_WIDTH 9
3987#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_SET_MSK 0x000001ff
3989#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_CLR_MSK 0xfffffe00
3991#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_RESET 0x1
3993#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
3995#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
4019#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_OFST 0x1c
4061#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_LSB 0
4063#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_MSB 0
4065#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_WIDTH 1
4067#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_SET_MSK 0x00000001
4069#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_CLR_MSK 0xfffffffe
4071#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_RESET 0x1
4073#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_GET(value) (((value) & 0x00000001) >> 0)
4075#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_SET(value) (((value) << 0) & 0x00000001)
4086#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_LSB 1
4088#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_MSB 1
4090#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_WIDTH 1
4092#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_SET_MSK 0x00000002
4094#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_CLR_MSK 0xfffffffd
4096#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_RESET 0x1
4098#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_GET(value) (((value) & 0x00000002) >> 1)
4100#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_SET(value) (((value) << 1) & 0x00000002)
4111#define ALT_CLKMGR_PERPLL_EN_USBCLK_LSB 2
4113#define ALT_CLKMGR_PERPLL_EN_USBCLK_MSB 2
4115#define ALT_CLKMGR_PERPLL_EN_USBCLK_WIDTH 1
4117#define ALT_CLKMGR_PERPLL_EN_USBCLK_SET_MSK 0x00000004
4119#define ALT_CLKMGR_PERPLL_EN_USBCLK_CLR_MSK 0xfffffffb
4121#define ALT_CLKMGR_PERPLL_EN_USBCLK_RESET 0x1
4123#define ALT_CLKMGR_PERPLL_EN_USBCLK_GET(value) (((value) & 0x00000004) >> 2)
4125#define ALT_CLKMGR_PERPLL_EN_USBCLK_SET(value) (((value) << 2) & 0x00000004)
4136#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_LSB 3
4138#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_MSB 3
4140#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_WIDTH 1
4142#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_SET_MSK 0x00000008
4144#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_CLR_MSK 0xfffffff7
4146#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_RESET 0x1
4148#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_GET(value) (((value) & 0x00000008) >> 3)
4150#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_SET(value) (((value) << 3) & 0x00000008)
4161#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_LSB 4
4163#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_MSB 4
4165#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_WIDTH 1
4167#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_SET_MSK 0x00000010
4169#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_CLR_MSK 0xffffffef
4171#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_RESET 0x1
4173#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_GET(value) (((value) & 0x00000010) >> 4)
4175#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_SET(value) (((value) << 4) & 0x00000010)
4186#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_LSB 5
4188#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_MSB 5
4190#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_WIDTH 1
4192#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_SET_MSK 0x00000020
4194#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_CLR_MSK 0xffffffdf
4196#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_RESET 0x1
4198#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_GET(value) (((value) & 0x00000020) >> 5)
4200#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_SET(value) (((value) << 5) & 0x00000020)
4211#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_LSB 6
4213#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_MSB 6
4215#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_WIDTH 1
4217#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_SET_MSK 0x00000040
4219#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_CLR_MSK 0xffffffbf
4221#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_RESET 0x1
4223#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_GET(value) (((value) & 0x00000040) >> 6)
4225#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_SET(value) (((value) << 6) & 0x00000040)
4238#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_LSB 7
4240#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_MSB 7
4242#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_WIDTH 1
4244#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_SET_MSK 0x00000080
4246#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_CLR_MSK 0xffffff7f
4248#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_RESET 0x1
4250#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_GET(value) (((value) & 0x00000080) >> 7)
4252#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_SET(value) (((value) << 7) & 0x00000080)
4263#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_LSB 8
4265#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_MSB 8
4267#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_WIDTH 1
4269#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_SET_MSK 0x00000100
4271#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_CLR_MSK 0xfffffeff
4273#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_RESET 0x1
4275#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_GET(value) (((value) & 0x00000100) >> 8)
4277#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_SET(value) (((value) << 8) & 0x00000100)
4293#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_LSB 9
4295#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_MSB 9
4297#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_WIDTH 1
4299#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_SET_MSK 0x00000200
4301#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_CLR_MSK 0xfffffdff
4303#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_RESET 0x1
4305#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_GET(value) (((value) & 0x00000200) >> 9)
4307#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_SET(value) (((value) << 9) & 0x00000200)
4323#define ALT_CLKMGR_PERPLL_EN_NANDCLK_LSB 10
4325#define ALT_CLKMGR_PERPLL_EN_NANDCLK_MSB 10
4327#define ALT_CLKMGR_PERPLL_EN_NANDCLK_WIDTH 1
4329#define ALT_CLKMGR_PERPLL_EN_NANDCLK_SET_MSK 0x00000400
4331#define ALT_CLKMGR_PERPLL_EN_NANDCLK_CLR_MSK 0xfffffbff
4333#define ALT_CLKMGR_PERPLL_EN_NANDCLK_RESET 0x1
4335#define ALT_CLKMGR_PERPLL_EN_NANDCLK_GET(value) (((value) & 0x00000400) >> 10)
4337#define ALT_CLKMGR_PERPLL_EN_NANDCLK_SET(value) (((value) << 10) & 0x00000400)
4348#define ALT_CLKMGR_PERPLL_EN_QSPICLK_LSB 11
4350#define ALT_CLKMGR_PERPLL_EN_QSPICLK_MSB 11
4352#define ALT_CLKMGR_PERPLL_EN_QSPICLK_WIDTH 1
4354#define ALT_CLKMGR_PERPLL_EN_QSPICLK_SET_MSK 0x00000800
4356#define ALT_CLKMGR_PERPLL_EN_QSPICLK_CLR_MSK 0xfffff7ff
4358#define ALT_CLKMGR_PERPLL_EN_QSPICLK_RESET 0x1
4360#define ALT_CLKMGR_PERPLL_EN_QSPICLK_GET(value) (((value) & 0x00000800) >> 11)
4362#define ALT_CLKMGR_PERPLL_EN_QSPICLK_SET(value) (((value) << 11) & 0x00000800)
4377 uint32_t emac0clk : 1;
4378 uint32_t emac1clk : 1;
4379 uint32_t usbclk : 1;
4380 uint32_t spimclk : 1;
4381 uint32_t can0clk : 1;
4382 uint32_t can1clk : 1;
4383 uint32_t gpioclk : 1;
4384 uint32_t s2fuser1clk : 1;
4385 uint32_t sdmmcclk : 1;
4386 uint32_t nandxclk : 1;
4387 uint32_t nandclk : 1;
4388 uint32_t qspiclk : 1;
4397#define ALT_CLKMGR_PERPLL_EN_OFST 0x20
4445#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV1 0x0
4451#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV2 0x1
4457#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV4 0x2
4463#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV8 0x3
4469#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV16 0x4
4475#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_1 0x5
4481#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_2 0x6
4487#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_3 0x7
4490#define ALT_CLKMGR_PERPLL_DIV_USBCLK_LSB 0
4492#define ALT_CLKMGR_PERPLL_DIV_USBCLK_MSB 2
4494#define ALT_CLKMGR_PERPLL_DIV_USBCLK_WIDTH 3
4496#define ALT_CLKMGR_PERPLL_DIV_USBCLK_SET_MSK 0x00000007
4498#define ALT_CLKMGR_PERPLL_DIV_USBCLK_CLR_MSK 0xfffffff8
4500#define ALT_CLKMGR_PERPLL_DIV_USBCLK_RESET 0x0
4502#define ALT_CLKMGR_PERPLL_DIV_USBCLK_GET(value) (((value) & 0x00000007) >> 0)
4504#define ALT_CLKMGR_PERPLL_DIV_USBCLK_SET(value) (((value) << 0) & 0x00000007)
4533#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV1 0x0
4539#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV2 0x1
4545#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV4 0x2
4551#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV8 0x3
4557#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV16 0x4
4563#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_1 0x5
4569#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_2 0x6
4575#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_3 0x7
4578#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_LSB 3
4580#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_MSB 5
4582#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_WIDTH 3
4584#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_SET_MSK 0x00000038
4586#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_CLR_MSK 0xffffffc7
4588#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_RESET 0x0
4590#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_GET(value) (((value) & 0x00000038) >> 3)
4592#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_SET(value) (((value) << 3) & 0x00000038)
4621#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV1 0x0
4627#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV2 0x1
4633#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV4 0x2
4639#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV8 0x3
4645#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV16 0x4
4651#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_1 0x5
4657#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_2 0x6
4663#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_3 0x7
4666#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_LSB 6
4668#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_MSB 8
4670#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_WIDTH 3
4672#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_SET_MSK 0x000001c0
4674#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_CLR_MSK 0xfffffe3f
4676#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_RESET 0x0
4678#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_GET(value) (((value) & 0x000001c0) >> 6)
4680#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_SET(value) (((value) << 6) & 0x000001c0)
4709#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV1 0x0
4715#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV2 0x1
4721#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV4 0x2
4727#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV8 0x3
4733#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV16 0x4
4739#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_1 0x5
4745#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_2 0x6
4751#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_3 0x7
4754#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_LSB 9
4756#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_MSB 11
4758#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_WIDTH 3
4760#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_SET_MSK 0x00000e00
4762#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_CLR_MSK 0xfffff1ff
4764#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_RESET 0x0
4766#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_GET(value) (((value) & 0x00000e00) >> 9)
4768#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_SET(value) (((value) << 9) & 0x00000e00)
4783 uint32_t usbclk : 3;
4784 uint32_t spimclk : 3;
4785 uint32_t can0clk : 3;
4786 uint32_t can1clk : 3;
4795#define ALT_CLKMGR_PERPLL_DIV_OFST 0x24
4823#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_LSB 0
4825#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_MSB 23
4827#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_WIDTH 24
4829#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_SET_MSK 0x00ffffff
4831#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_CLR_MSK 0xff000000
4833#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_RESET 0x1
4835#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_GET(value) (((value) & 0x00ffffff) >> 0)
4837#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_SET(value) (((value) << 0) & 0x00ffffff)
4852 uint32_t gpiodbclk : 24;
4861#define ALT_CLKMGR_PERPLL_GPIODIV_OFST 0x28
4903#define ALT_CLKMGR_PERPLL_SRC_SDMMC_E_F2S_PERIPH_REF_CLK 0x0
4909#define ALT_CLKMGR_PERPLL_SRC_SDMMC_E_MAIN_NAND_CLK 0x1
4915#define ALT_CLKMGR_PERPLL_SRC_SDMMC_E_PERIPH_NAND_CLK 0x2
4918#define ALT_CLKMGR_PERPLL_SRC_SDMMC_LSB 0
4920#define ALT_CLKMGR_PERPLL_SRC_SDMMC_MSB 1
4922#define ALT_CLKMGR_PERPLL_SRC_SDMMC_WIDTH 2
4924#define ALT_CLKMGR_PERPLL_SRC_SDMMC_SET_MSK 0x00000003
4926#define ALT_CLKMGR_PERPLL_SRC_SDMMC_CLR_MSK 0xfffffffc
4928#define ALT_CLKMGR_PERPLL_SRC_SDMMC_RESET 0x1
4930#define ALT_CLKMGR_PERPLL_SRC_SDMMC_GET(value) (((value) & 0x00000003) >> 0)
4932#define ALT_CLKMGR_PERPLL_SRC_SDMMC_SET(value) (((value) << 0) & 0x00000003)
4957#define ALT_CLKMGR_PERPLL_SRC_NAND_E_F2S_PERIPH_REF_CLK 0x0
4963#define ALT_CLKMGR_PERPLL_SRC_NAND_E_MAIN_NAND_CLK 0x1
4969#define ALT_CLKMGR_PERPLL_SRC_NAND_E_PERIPH_NAND_CLK 0x2
4972#define ALT_CLKMGR_PERPLL_SRC_NAND_LSB 2
4974#define ALT_CLKMGR_PERPLL_SRC_NAND_MSB 3
4976#define ALT_CLKMGR_PERPLL_SRC_NAND_WIDTH 2
4978#define ALT_CLKMGR_PERPLL_SRC_NAND_SET_MSK 0x0000000c
4980#define ALT_CLKMGR_PERPLL_SRC_NAND_CLR_MSK 0xfffffff3
4982#define ALT_CLKMGR_PERPLL_SRC_NAND_RESET 0x1
4984#define ALT_CLKMGR_PERPLL_SRC_NAND_GET(value) (((value) & 0x0000000c) >> 2)
4986#define ALT_CLKMGR_PERPLL_SRC_NAND_SET(value) (((value) << 2) & 0x0000000c)
5011#define ALT_CLKMGR_PERPLL_SRC_QSPI_E_F2S_PERIPH_REF_CLK 0x0
5017#define ALT_CLKMGR_PERPLL_SRC_QSPI_E_MAIN_QSPI_CLK 0x1
5023#define ALT_CLKMGR_PERPLL_SRC_QSPI_E_PERIPH_QSPI_CLK 0x2
5026#define ALT_CLKMGR_PERPLL_SRC_QSPI_LSB 4
5028#define ALT_CLKMGR_PERPLL_SRC_QSPI_MSB 5
5030#define ALT_CLKMGR_PERPLL_SRC_QSPI_WIDTH 2
5032#define ALT_CLKMGR_PERPLL_SRC_QSPI_SET_MSK 0x00000030
5034#define ALT_CLKMGR_PERPLL_SRC_QSPI_CLR_MSK 0xffffffcf
5036#define ALT_CLKMGR_PERPLL_SRC_QSPI_RESET 0x1
5038#define ALT_CLKMGR_PERPLL_SRC_QSPI_GET(value) (((value) & 0x00000030) >> 4)
5040#define ALT_CLKMGR_PERPLL_SRC_QSPI_SET(value) (((value) << 4) & 0x00000030)
5066#define ALT_CLKMGR_PERPLL_SRC_OFST 0x2c
5113#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_E_IDLE 0x0
5119#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_E_ACK_RXD 0x1
5122#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_LSB 0
5124#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_MSB 5
5126#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_WIDTH 6
5128#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_SET_MSK 0x0000003f
5130#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_CLR_MSK 0xffffffc0
5132#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_RESET 0x0
5134#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_GET(value) (((value) & 0x0000003f) >> 0)
5136#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_SET(value) (((value) << 0) & 0x0000003f)
5151 const uint32_t outresetack : 6;
5160#define ALT_CLKMGR_PERPLL_STAT_OFST 0x30
5188 volatile uint32_t _pad_0x34_0x40[3];
5196 volatile uint32_t vco;
5197 volatile uint32_t misc;
5198 volatile uint32_t emac0clk;
5199 volatile uint32_t emac1clk;
5200 volatile uint32_t perqspiclk;
5201 volatile uint32_t pernandsdmmcclk;
5202 volatile uint32_t perbaseclk;
5203 volatile uint32_t s2fuser1clk;
5204 volatile uint32_t en;
5205 volatile uint32_t div;
5206 volatile uint32_t gpiodiv;
5207 volatile uint32_t src;
5208 volatile uint32_t stat;
5209 volatile uint32_t _pad_0x34_0x40[3];
5257#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_LSB 0
5259#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_MSB 0
5261#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_WIDTH 1
5263#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_SET_MSK 0x00000001
5265#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_CLR_MSK 0xfffffffe
5267#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_RESET 0x1
5269#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_GET(value) (((value) & 0x00000001) >> 0)
5271#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_SET(value) (((value) << 0) & 0x00000001)
5282#define ALT_CLKMGR_SDRPLL_VCO_EN_LSB 1
5284#define ALT_CLKMGR_SDRPLL_VCO_EN_MSB 1
5286#define ALT_CLKMGR_SDRPLL_VCO_EN_WIDTH 1
5288#define ALT_CLKMGR_SDRPLL_VCO_EN_SET_MSK 0x00000002
5290#define ALT_CLKMGR_SDRPLL_VCO_EN_CLR_MSK 0xfffffffd
5292#define ALT_CLKMGR_SDRPLL_VCO_EN_RESET 0x0
5294#define ALT_CLKMGR_SDRPLL_VCO_EN_GET(value) (((value) & 0x00000002) >> 1)
5296#define ALT_CLKMGR_SDRPLL_VCO_EN_SET(value) (((value) << 1) & 0x00000002)
5307#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_LSB 2
5309#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_MSB 2
5311#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_WIDTH 1
5313#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_SET_MSK 0x00000004
5315#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_CLR_MSK 0xfffffffb
5317#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_RESET 0x1
5319#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_GET(value) (((value) & 0x00000004) >> 2)
5321#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_SET(value) (((value) << 2) & 0x00000004)
5335#define ALT_CLKMGR_SDRPLL_VCO_NUMER_LSB 3
5337#define ALT_CLKMGR_SDRPLL_VCO_NUMER_MSB 15
5339#define ALT_CLKMGR_SDRPLL_VCO_NUMER_WIDTH 13
5341#define ALT_CLKMGR_SDRPLL_VCO_NUMER_SET_MSK 0x0000fff8
5343#define ALT_CLKMGR_SDRPLL_VCO_NUMER_CLR_MSK 0xffff0007
5345#define ALT_CLKMGR_SDRPLL_VCO_NUMER_RESET 0x1
5347#define ALT_CLKMGR_SDRPLL_VCO_NUMER_GET(value) (((value) & 0x0000fff8) >> 3)
5349#define ALT_CLKMGR_SDRPLL_VCO_NUMER_SET(value) (((value) << 3) & 0x0000fff8)
5363#define ALT_CLKMGR_SDRPLL_VCO_DENOM_LSB 16
5365#define ALT_CLKMGR_SDRPLL_VCO_DENOM_MSB 21
5367#define ALT_CLKMGR_SDRPLL_VCO_DENOM_WIDTH 6
5369#define ALT_CLKMGR_SDRPLL_VCO_DENOM_SET_MSK 0x003f0000
5371#define ALT_CLKMGR_SDRPLL_VCO_DENOM_CLR_MSK 0xffc0ffff
5373#define ALT_CLKMGR_SDRPLL_VCO_DENOM_RESET 0x1
5375#define ALT_CLKMGR_SDRPLL_VCO_DENOM_GET(value) (((value) & 0x003f0000) >> 16)
5377#define ALT_CLKMGR_SDRPLL_VCO_DENOM_SET(value) (((value) << 16) & 0x003f0000)
5403#define ALT_CLKMGR_SDRPLL_VCO_SSRC_E_EOSC1 0x0
5409#define ALT_CLKMGR_SDRPLL_VCO_SSRC_E_EOSC2 0x1
5415#define ALT_CLKMGR_SDRPLL_VCO_SSRC_E_F2S_SDRAM_REF 0x2
5418#define ALT_CLKMGR_SDRPLL_VCO_SSRC_LSB 22
5420#define ALT_CLKMGR_SDRPLL_VCO_SSRC_MSB 23
5422#define ALT_CLKMGR_SDRPLL_VCO_SSRC_WIDTH 2
5424#define ALT_CLKMGR_SDRPLL_VCO_SSRC_SET_MSK 0x00c00000
5426#define ALT_CLKMGR_SDRPLL_VCO_SSRC_CLR_MSK 0xff3fffff
5428#define ALT_CLKMGR_SDRPLL_VCO_SSRC_RESET 0x0
5430#define ALT_CLKMGR_SDRPLL_VCO_SSRC_GET(value) (((value) & 0x00c00000) >> 22)
5432#define ALT_CLKMGR_SDRPLL_VCO_SSRC_SET(value) (((value) << 22) & 0x00c00000)
5450#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_LSB 24
5452#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_MSB 24
5454#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_WIDTH 1
5456#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_SET_MSK 0x01000000
5458#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_CLR_MSK 0xfeffffff
5460#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_RESET 0x0
5462#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_GET(value) (((value) & 0x01000000) >> 24)
5464#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_SET(value) (((value) << 24) & 0x01000000)
5491#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_LSB 25
5493#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_MSB 30
5495#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_WIDTH 6
5497#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_SET_MSK 0x7e000000
5499#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_CLR_MSK 0x81ffffff
5501#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_RESET 0x0
5503#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_GET(value) (((value) & 0x7e000000) >> 25)
5505#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_SET(value) (((value) << 25) & 0x7e000000)
5528#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_LSB 31
5530#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_MSB 31
5532#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_WIDTH 1
5534#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_SET_MSK 0x80000000
5536#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_CLR_MSK 0x7fffffff
5538#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_RESET 0x1
5540#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_GET(value) (((value) & 0x80000000) >> 31)
5542#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_SET(value) (((value) << 31) & 0x80000000)
5557 uint32_t bgpwrdn : 1;
5560 uint32_t numer : 13;
5563 uint32_t outresetall : 1;
5564 uint32_t outreset : 6;
5565 uint32_t regextsel : 1;
5573#define ALT_CLKMGR_SDRPLL_VCO_OFST 0x0
5608#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_LSB 0
5610#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_MSB 0
5612#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_WIDTH 1
5614#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_SET_MSK 0x00000001
5616#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_CLR_MSK 0xfffffffe
5618#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_RESET 0x0
5620#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_GET(value) (((value) & 0x00000001) >> 0)
5622#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_SET(value) (((value) << 0) & 0x00000001)
5633#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_LSB 1
5635#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_MSB 12
5637#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_WIDTH 12
5639#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_SET_MSK 0x00001ffe
5641#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_CLR_MSK 0xffffe001
5643#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_RESET 0x1
5645#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_GET(value) (((value) & 0x00001ffe) >> 1)
5647#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_SET(value) (((value) << 1) & 0x00001ffe)
5658#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_LSB 13
5660#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_MSB 13
5662#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_WIDTH 1
5664#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_SET_MSK 0x00002000
5666#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_CLR_MSK 0xffffdfff
5668#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_RESET 0x0
5670#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_GET(value) (((value) & 0x00002000) >> 13)
5672#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_SET(value) (((value) << 13) & 0x00002000)
5683#define ALT_CLKMGR_SDRPLL_CTL_SATEN_LSB 14
5685#define ALT_CLKMGR_SDRPLL_CTL_SATEN_MSB 14
5687#define ALT_CLKMGR_SDRPLL_CTL_SATEN_WIDTH 1
5689#define ALT_CLKMGR_SDRPLL_CTL_SATEN_SET_MSK 0x00004000
5691#define ALT_CLKMGR_SDRPLL_CTL_SATEN_CLR_MSK 0xffffbfff
5693#define ALT_CLKMGR_SDRPLL_CTL_SATEN_RESET 0x1
5695#define ALT_CLKMGR_SDRPLL_CTL_SATEN_GET(value) (((value) & 0x00004000) >> 14)
5697#define ALT_CLKMGR_SDRPLL_CTL_SATEN_SET(value) (((value) << 14) & 0x00004000)
5712 uint32_t bwadjen : 1;
5713 uint32_t bwadj : 12;
5714 uint32_t fasten : 1;
5724#define ALT_CLKMGR_SDRPLL_CTL_OFST 0x4
5752#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_LSB 0
5754#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_MSB 8
5756#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_WIDTH 9
5758#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_SET_MSK 0x000001ff
5760#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_CLR_MSK 0xfffffe00
5762#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_RESET 0x1
5764#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
5766#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
5785#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_LSB 9
5787#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_MSB 20
5789#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_WIDTH 12
5791#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_SET_MSK 0x001ffe00
5793#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_CLR_MSK 0xffe001ff
5795#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_RESET 0x0
5797#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_GET(value) (((value) & 0x001ffe00) >> 9)
5799#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_SET(value) (((value) << 9) & 0x001ffe00)
5815 uint32_t phase : 12;
5824#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_OFST 0x8
5852#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_LSB 0
5854#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_MSB 8
5856#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_WIDTH 9
5858#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_SET_MSK 0x000001ff
5860#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_CLR_MSK 0xfffffe00
5862#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_RESET 0x1
5864#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
5866#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
5885#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_LSB 9
5887#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_MSB 20
5889#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_WIDTH 12
5891#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_SET_MSK 0x001ffe00
5893#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_CLR_MSK 0xffe001ff
5895#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_RESET 0x0
5897#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_GET(value) (((value) & 0x001ffe00) >> 9)
5899#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_SET(value) (((value) << 9) & 0x001ffe00)
5915 uint32_t phase : 12;
5924#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_OFST 0xc
5952#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_LSB 0
5954#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_MSB 8
5956#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_WIDTH 9
5958#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_SET_MSK 0x000001ff
5960#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_CLR_MSK 0xfffffe00
5962#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_RESET 0x1
5964#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
5966#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
5985#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_LSB 9
5987#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_MSB 20
5989#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_WIDTH 12
5991#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_SET_MSK 0x001ffe00
5993#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_CLR_MSK 0xffe001ff
5995#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_RESET 0x0
5997#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_GET(value) (((value) & 0x001ffe00) >> 9)
5999#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_SET(value) (((value) << 9) & 0x001ffe00)
6015 uint32_t phase : 12;
6024#define ALT_CLKMGR_SDRPLL_DDRDQCLK_OFST 0x10
6054#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_LSB 0
6056#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_MSB 8
6058#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_WIDTH 9
6060#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_SET_MSK 0x000001ff
6062#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_CLR_MSK 0xfffffe00
6064#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_RESET 0x1
6066#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
6068#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
6087#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_LSB 9
6089#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_MSB 20
6091#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_WIDTH 12
6093#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_SET_MSK 0x001ffe00
6095#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_CLR_MSK 0xffe001ff
6097#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_RESET 0x0
6099#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_GET(value) (((value) & 0x001ffe00) >> 9)
6101#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_SET(value) (((value) << 9) & 0x001ffe00)
6117 uint32_t phase : 12;
6126#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_OFST 0x14
6160#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_LSB 0
6162#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_MSB 0
6164#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_WIDTH 1
6166#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_SET_MSK 0x00000001
6168#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_CLR_MSK 0xfffffffe
6170#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_RESET 0x1
6172#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_GET(value) (((value) & 0x00000001) >> 0)
6174#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_SET(value) (((value) << 0) & 0x00000001)
6185#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_LSB 1
6187#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_MSB 1
6189#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_WIDTH 1
6191#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_SET_MSK 0x00000002
6193#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_CLR_MSK 0xfffffffd
6195#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_RESET 0x1
6197#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_GET(value) (((value) & 0x00000002) >> 1)
6199#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_SET(value) (((value) << 1) & 0x00000002)
6210#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_LSB 2
6212#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_MSB 2
6214#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_WIDTH 1
6216#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_SET_MSK 0x00000004
6218#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_CLR_MSK 0xfffffffb
6220#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_RESET 0x1
6222#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_GET(value) (((value) & 0x00000004) >> 2)
6224#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_SET(value) (((value) << 2) & 0x00000004)
6237#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_LSB 3
6239#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_MSB 3
6241#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_WIDTH 1
6243#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_SET_MSK 0x00000008
6245#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_CLR_MSK 0xfffffff7
6247#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_RESET 0x1
6249#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_GET(value) (((value) & 0x00000008) >> 3)
6251#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_SET(value) (((value) << 3) & 0x00000008)
6266 uint32_t ddrdqsclk : 1;
6267 uint32_t ddr2xdqsclk : 1;
6268 uint32_t ddrdqclk : 1;
6269 uint32_t s2fuser2clk : 1;
6278#define ALT_CLKMGR_SDRPLL_EN_OFST 0x18
6325#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_E_IDLE 0x0
6331#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_E_ACK_RXD 0x1
6334#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_LSB 0
6336#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_MSB 5
6338#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_WIDTH 6
6340#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_SET_MSK 0x0000003f
6342#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_CLR_MSK 0xffffffc0
6344#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_RESET 0x0
6346#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_GET(value) (((value) & 0x0000003f) >> 0)
6348#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_SET(value) (((value) << 0) & 0x0000003f)
6363 const uint32_t outresetack : 6;
6372#define ALT_CLKMGR_SDRPLL_STAT_OFST 0x1c
6402 volatile uint32_t vco;
6403 volatile uint32_t ctrl;
6404 volatile uint32_t ddrdqsclk;
6405 volatile uint32_t ddr2xdqsclk;
6406 volatile uint32_t ddrdqclk;
6407 volatile uint32_t s2fuser2clk;
6408 volatile uint32_t en;
6409 volatile uint32_t stat;
6436 volatile uint32_t _pad_0x18_0x3f[10];
6440 volatile uint32_t _pad_0xe0_0x200[72];
6448 volatile uint32_t ctrl;
6449 volatile uint32_t bypass;
6450 volatile uint32_t inter;
6451 volatile uint32_t intren;
6452 volatile uint32_t dbctrl;
6453 volatile uint32_t stat;
6454 volatile uint32_t _pad_0x18_0x3f[10];
6458 volatile uint32_t _pad_0xe0_0x200[72];
Definition: alt_clkmgr.h:386
Definition: alt_clkmgr.h:145
Definition: alt_clkmgr.h:994
Definition: alt_clkmgr.h:672
Definition: alt_clkmgr.h:886
Definition: alt_clkmgr.h:1931
Definition: alt_clkmgr.h:1734
Definition: alt_clkmgr.h:2698
Definition: alt_clkmgr.h:2235
Definition: alt_clkmgr.h:2957
Definition: alt_clkmgr.h:1669
Definition: alt_clkmgr.h:2555
Definition: alt_clkmgr.h:1864
Definition: alt_clkmgr.h:1799
Definition: alt_clkmgr.h:1536
Definition: alt_clkmgr.h:1604
Definition: alt_clkmgr.h:3052
Definition: alt_clkmgr.h:2827
Definition: alt_clkmgr.h:1381
Definition: alt_clkmgr.h:3098
Definition: alt_clkmgr.h:3076
Definition: alt_clkmgr.h:4782
Definition: alt_clkmgr.h:3682
Definition: alt_clkmgr.h:3747
Definition: alt_clkmgr.h:4376
Definition: alt_clkmgr.h:4851
Definition: alt_clkmgr.h:3614
Definition: alt_clkmgr.h:3942
Definition: alt_clkmgr.h:3877
Definition: alt_clkmgr.h:3812
Definition: alt_clkmgr.h:4009
Definition: alt_clkmgr.h:5054
Definition: alt_clkmgr.h:5150
Definition: alt_clkmgr.h:3459
Definition: alt_clkmgr.h:5195
Definition: alt_clkmgr.h:5174
Definition: alt_clkmgr.h:5711
Definition: alt_clkmgr.h:5913
Definition: alt_clkmgr.h:6013
Definition: alt_clkmgr.h:5813
Definition: alt_clkmgr.h:6265
Definition: alt_clkmgr.h:6115
Definition: alt_clkmgr.h:6362
Definition: alt_clkmgr.h:5556
Definition: alt_clkmgr.h:6401
Definition: alt_clkmgr.h:6386
Definition: alt_clkmgr.h:1085
Definition: alt_clkmgr.h:6447
Definition: alt_clkmgr.h:6429
