RTEMS 6.1-rc1
Macros | Typedefs | Enumerations | Functions
alt_cache.h File Reference
#include "hwlib.h"
#define ALT_CACHE_SUPPORT_NON_FLAT_VIRTUAL_MEMORY   (0)
#define ALT_CACHE_LINE_SIZE   32
typedef enum ALT_CACHE_L2_INTERRUPT_e ALT_CACHE_L2_INTERRUPT_t
enum  ALT_CACHE_L2_INTERRUPT_e {
  ALT_CACHE_L2_INTERRUPT_DECERR = 1 << 8 , ALT_CACHE_L2_INTERRUPT_SLVERR = 1 << 7 , ALT_CACHE_L2_INTERRUPT_ERRRD = 1 << 6 , ALT_CACHE_L2_INTERRUPT_ERRRT = 1 << 5 ,
  ALT_CACHE_L2_INTERRUPT_ERRWD = 1 << 4 , ALT_CACHE_L2_INTERRUPT_ERRWT = 1 << 3 , ALT_CACHE_L2_INTERRUPT_PARRD = 1 << 2 , ALT_CACHE_L2_INTERRUPT_PARRT = 1 << 1 ,
  ALT_CACHE_L2_INTERRUPT_ECNTR = 1 << 0
ALT_STATUS_CODE alt_cache_system_enable (void)
ALT_STATUS_CODE alt_cache_system_disable (void)
ALT_STATUS_CODE alt_cache_system_invalidate (void *vaddress, size_t length)
ALT_STATUS_CODE alt_cache_system_clean (void *vaddress, size_t length)
ALT_STATUS_CODE alt_cache_system_purge (void *vaddress, size_t length)
ALT_STATUS_CODE alt_cache_l1_enable_all (void)
ALT_STATUS_CODE alt_cache_l1_disable_all (void)
ALT_STATUS_CODE alt_cache_l1_instruction_enable (void)
ALT_STATUS_CODE alt_cache_l1_instruction_disable (void)
bool alt_cache_l1_instruction_is_enabled (void)
ALT_STATUS_CODE alt_cache_l1_instruction_invalidate (void)
ALT_STATUS_CODE alt_cache_l1_data_enable (void)
ALT_STATUS_CODE alt_cache_l1_data_disable (void)
bool alt_cache_l1_data_is_enabled (void)
ALT_STATUS_CODE alt_cache_l1_data_invalidate (void *vaddress, size_t length)
ALT_STATUS_CODE alt_cache_l1_data_invalidate_all (void)
ALT_STATUS_CODE alt_cache_l1_data_clean (void *vaddress, size_t length)
ALT_STATUS_CODE alt_cache_l1_data_clean_all (void)
ALT_STATUS_CODE alt_cache_l1_data_purge (void *vaddress, size_t length)
ALT_STATUS_CODE alt_cache_l1_data_purge_all (void)
ALT_STATUS_CODE alt_cache_l1_parity_enable (void)
ALT_STATUS_CODE alt_cache_l1_parity_disable (void)
bool alt_cache_l1_parity_is_enabled (void)
ALT_STATUS_CODE alt_cache_l1_branch_enable (void)
ALT_STATUS_CODE alt_cache_l1_branch_disable (void)
bool alt_cache_l1_branch_is_enabled (void)
ALT_STATUS_CODE alt_cache_l1_branch_invalidate (void)
ALT_STATUS_CODE alt_cache_l1_prefetch_enable (void)
ALT_STATUS_CODE alt_cache_l1_prefetch_disable (void)
bool alt_cache_l1_prefetch_is_enabled (void)
ALT_STATUS_CODE alt_cache_l2_init (void)
ALT_STATUS_CODE alt_cache_l2_uninit (void)
ALT_STATUS_CODE alt_cache_l2_prefetch_enable (void)
ALT_STATUS_CODE alt_cache_l2_prefetch_disable (void)
bool alt_cache_l2_prefetch_is_enabled (void)
ALT_STATUS_CODE alt_cache_l2_parity_enable (void)
ALT_STATUS_CODE alt_cache_l2_parity_disable (void)
bool alt_cache_l2_parity_is_enabled (void)
ALT_STATUS_CODE alt_cache_l2_enable (void)
ALT_STATUS_CODE alt_cache_l2_disable (void)
bool alt_cache_l2_is_enabled (void)
ALT_STATUS_CODE alt_cache_l2_sync (void)
ALT_STATUS_CODE alt_cache_l2_invalidate (void *paddress, size_t length)
ALT_STATUS_CODE alt_cache_l2_invalidate_all (void)
ALT_STATUS_CODE alt_cache_l2_clean (void *paddress, size_t length)
ALT_STATUS_CODE alt_cache_l2_clean_all (void)
ALT_STATUS_CODE alt_cache_l2_purge (void *paddress, size_t length)
ALT_STATUS_CODE alt_cache_l2_purge_all (void)
ALT_STATUS_CODE alt_cache_l2_int_enable (uint32_t interrupt)
ALT_STATUS_CODE alt_cache_l2_int_disable (uint32_t interrupt)
uint32_t alt_cache_l2_int_status_get (void)
ALT_STATUS_CODE alt_cache_l2_int_status_clear (uint32_t interrupt)
