RTEMS 6.1-rc1
_kernel_param.h
2
12/*
13 * Copyright (C) 2017 embedded brains GmbH & Co. KG
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#include <sys/cdefs.h>
38#include <sys/errno.h>
39#include <sys/time.h>
40#include <sys/priority.h>
41
42#if defined(_SYS_PARAM_H_) && defined(_KERNEL)
43
44#ifndef FALSE
45#define FALSE 0
46#endif
47#ifndef TRUE
48#define TRUE 1
49#endif
50
51#ifndef _BYTEORDER_PROTOTYPED
52#define _BYTEORDER_PROTOTYPED
53__BEGIN_DECLS
54__uint32_t htonl(__uint32_t);
55__uint16_t htons(__uint16_t);
56__uint32_t ntohl(__uint32_t);
57__uint16_t ntohs(__uint16_t);
58__END_DECLS
59#endif
60
61#ifndef _BYTEORDER_FUNC_DEFINED
62#define _BYTEORDER_FUNC_DEFINED
63#define htonl(x) __htonl(x)
64#define htons(x) __htons(x)
65#define ntohl(x) __ntohl(x)
66#define ntohs(x) __ntohs(x)
67#endif /* !_BYTEORDER_FUNC_DEFINED */
68
69#else /* !_SYS_PARAM_H_ || !_KERNEL */
70#error "must be included via <sys/param.h> in kernel space"
71#endif /* _SYS_PARAM_H_ && _KERNEL */
This header file provides interfaces of the process priority support.
