RTEMS
6.1-rc1
bsps
m68k
include
mcf548x
MCD_dma.h
1
2
* File: MCD_dma.h
3
* Purpose: Main header file for multi-channel DMA API.
4
5
* Notes:
6
7
#ifndef _MCD_API_H
8
#define _MCD_API_H
9
10
11
* Turn Execution Unit tasks ON (#define) or OFF (#undef)
12
13
#define MCD_INCLUDE_EU
14
15
16
* Number of DMA channels
17
18
#define NCHANNELS 16
19
20
21
* Total number of variants
22
23
#ifdef MCD_INCLUDE_EU
24
#define NUMOFVARIANTS 6
25
#else
26
#define NUMOFVARIANTS 4
27
#endif
28
29
30
* Define sizes of the various tables
31
32
#define TASK_TABLE_SIZE (NCHANNELS*32)
33
#define VAR_TAB_SIZE (128)
34
#define CONTEXT_SAVE_SIZE (128)
35
#define FUNCDESC_TAB_SIZE (256)
36
37
38
#define FUNCDESC_TAB_NUM 16
39
#else
40
41
#endif
42
43
44
#ifndef DEFINESONLY
45
46
47
* Portability typedefs
48
49
typedef
int
s32;
50
typedef
unsigned
int
u32;
51
typedef
short
s16;
52
typedef
unsigned
short
u16;
53
typedef
char
s8;
54
typedef
unsigned
char
u8;
55
56
57
* These structures represent the internal registers of the
58
* multi-channel DMA
59
60
struct
dmaRegs_s
61
u32 taskbar;
/* task table base address register */
62
u32 currPtr;
63
u32 endPtr;
64
u32 varTablePtr;
65
u16 dma_rsvd0;
66
u16 ptdControl;
/* ptd control */
67
u32 intPending;
/* interrupt pending register */
68
u32 intMask;
/* interrupt mask register */
69
u16 taskControl[16];
/* task control registers */
70
u8 priority[32];
/* priority registers */
71
u32 initiatorMux;
/* initiator mux control */
72
u32 taskSize0;
/* task size control register 0. */
73
u32 taskSize1;
/* task size control register 1. */
74
u32 dma_rsvd1;
/* reserved */
75
u32 dma_rsvd2;
/* reserved */
76
u32 debugComp1;
/* debug comparator 1 */
77
u32 debugComp2;
/* debug comparator 2 */
78
u32 debugControl;
/* debug control */
79
u32 debugStatus;
/* debug status */
80
u32 ptdDebug;
/* priority task decode debug */
81
u32 dma_rsvd3[31];
/* reserved */
82
83
typedef
volatile
struct
dmaRegs_s
dmaRegs
84
85
#endif
86
87
88
* PTD contrl reg bits
89
90
#define PTD_CTL_TSK_PRI 0x8000
91
#define PTD_CTL_COMM_PREFETCH 0x0001
92
93
94
* Task Control reg bits and field masks
95
96
#define TASK_CTL_EN 0x8000
97
#define TASK_CTL_VALID 0x4000
98
#define TASK_CTL_ALWAYS 0x2000
99
#define TASK_CTL_INIT_MASK 0x1f00
100
#define TASK_CTL_ASTRT 0x0080
101
#define TASK_CTL_HIPRITSKEN 0x0040
102
#define TASK_CTL_HLDINITNUM 0x0020
103
#define TASK_CTL_ASTSKNUM_MASK 0x000f
104
105
106
* Priority reg bits and field masks
107
108
#define PRIORITY_HLD 0x80
109
#define PRIORITY_PRI_MASK 0x07
110
111
112
* Debug Control reg bits and field masks
113
114
#define DBG_CTL_BLOCK_TASKS_MASK 0xffff0000
115
#define DBG_CTL_AUTO_ARM 0x00008000
116
#define DBG_CTL_BREAK 0x00004000
117
#define DBG_CTL_COMP1_TYP_MASK 0x00003800
118
#define DBG_CTL_COMP2_TYP_MASK 0x00000070
119
#define DBG_CTL_EXT_BREAK 0x00000004
120
#define DBG_CTL_INT_BREAK 0x00000002
121
122
123
* PTD Debug reg selector addresses
124
* This reg must be written with a value to show the contents of
125
* one of the desired internal register.
126
127
#define PTD_DBG_REQ 0x00
/* shows the state of 31 initiators */
128
#define PTD_DBG_TSK_VLD_INIT 0x01
/* shows which 16 tasks are valid and
129
have initiators asserted */
130
131
132
133
* General return values
134
135
#define MCD_OK 0
136
#define MCD_ERROR -1
137
#define MCD_TABLE_UNALIGNED -2
138
#define MCD_CHANNEL_INVALID -3
139
140
141
* MCD_initDma input flags
142
143
#define MCD_RELOC_TASKS 0x00000001
144
#define MCD_NO_RELOC_TASKS 0x00000000
145
#define MCD_COMM_PREFETCH_EN 0x00000002
/* Commbus Prefetching - MCF547x/548x ONLY */
146
147
148
* MCD_dmaStatus Status Values for each channel
149
150
#define MCD_NO_DMA 1
/* No DMA has been requested since reset */
151
#define MCD_IDLE 2
/* DMA active, but the initiator is currently inactive */
152
#define MCD_RUNNING 3
/* DMA active, and the initiator is currently active */
153
#define MCD_PAUSED 4
/* DMA active but it is currently paused */
154
#define MCD_HALTED 5
/* the most recent DMA has been killed with MCD_killTask() */
155
#define MCD_DONE 6
/* the most recent DMA has completed. */
156
157
158
159
* MCD_startDma parameter defines
160
161
162
163
* Constants for the funcDesc parameter
164
165
/* Byte swapping: */
166
#define MCD_NO_BYTE_SWAP 0x00045670
/* to disable byte swapping. */
167
#define MCD_BYTE_REVERSE 0x00076540
/* to reverse the bytes of each u32 of the DMAed data. */
168
#define MCD_U16_REVERSE 0x00067450
/* to reverse the 16-bit halves of
169
each 32-bit data value being DMAed.*/
170
#define MCD_U16_BYTE_REVERSE 0x00054760
/* to reverse the byte halves of each
171
16-bit half of each 32-bit data value DMAed */
172
#define MCD_NO_BIT_REV 0x00000000
/* do not reverse the bits of each byte DMAed. */
173
#define MCD_BIT_REV 0x00088880
/* reverse the bits of each byte DMAed */
174
/* CRCing: */
175
#define MCD_CRC16 0xc0100000
/* to perform CRC-16 on DMAed data. */
176
#define MCD_CRCCCITT 0xc0200000
/* to perform CRC-CCITT on DMAed data. */
177
#define MCD_CRC32 0xc0300000
/* to perform CRC-32 on DMAed data. */
178
#define MCD_CSUMINET 0xc0400000
/* to perform internet checksums on DMAed data.*/
179
#define MCD_NO_CSUM 0xa0000000
/* to perform no checksumming. */
180
181
#define MCD_FUNC_NOEU1 (MCD_NO_BYTE_SWAP | MCD_NO_BIT_REV | MCD_NO_CSUM)
182
#define MCD_FUNC_NOEU2 (MCD_NO_BYTE_SWAP | MCD_NO_CSUM)
183
184
185
* Constants for the flags parameter
186
187
#define MCD_TT_FLAGS_RL 0x00000001
/* Read line */
188
#define MCD_TT_FLAGS_CW 0x00000002
/* Combine Writes */
189
#define MCD_TT_FLAGS_SP 0x00000004
/* Speculative prefetch(XLB) MCF547x/548x ONLY */
190
#define MCD_TT_FLAGS_MASK 0x000000ff
191
#define MCD_TT_FLAGS_DEF (MCD_TT_FLAGS_RL | MCD_TT_FLAGS_CW)
192
193
#define MCD_SINGLE_DMA 0x00000100
/* Unchained DMA */
194
#define MCD_CHAIN_DMA
/* TBD */
195
#define MCD_EU_DMA
/* TBD */
196
#define MCD_FECTX_DMA 0x00001000
/* FEC TX ring DMA */
197
#define MCD_FECRX_DMA 0x00002000
/* FEC RX ring DMA */
198
199
200
/* these flags are valid for MCD_startDma and the chained buffer descriptors */
201
#define MCD_BUF_READY 0x80000000
/* indicates that this buffer is now under the DMA's control */
202
#define MCD_WRAP 0x20000000
/* to tell the FEC Dmas to wrap to the first BD */
203
#define MCD_INTERRUPT 0x10000000
/* to generate an interrupt after completion of the DMA. */
204
#define MCD_END_FRAME 0x08000000
/* tell the DMA to end the frame when transferring
205
last byte of data in buffer */
206
#define MCD_CRC_RESTART 0x40000000
/* to empty out the accumulated checksum
207
prior to performing the DMA. */
208
209
/* Defines for the FEC buffer descriptor control/status word*/
210
#define MCD_FEC_BUF_READY 0x8000
211
#define MCD_FEC_WRAP 0x2000
212
#define MCD_FEC_INTERRUPT 0x1000
213
#define MCD_FEC_END_FRAME 0x0800
214
215
216
217
* Defines for general intuitiveness
218
219
220
#define MCD_TRUE 1
221
#define MCD_FALSE 0
222
223
224
* Three different cases for destination and source.
225
226
#define MINUS1 -1
227
#define ZERO 0
228
#define PLUS1 1
229
230
#ifndef DEFINESONLY
231
232
/* Task Table Entry struct*/
233
typedef
struct
234
u32 TDTstart;
/* task descriptor table start */
235
u32 TDTend;
/* task descriptor table end */
236
u32 varTab;
/* variable table start */
237
u32 FDTandFlags;
/* function descriptor table start and flags */
238
volatile
u32 descAddrAndStatus;
239
volatile
u32 modifiedVarTab;
240
u32 contextSaveSpace;
/* context save space start */
241
u32 literalBases;
242
TaskTableEntry
243
244
245
/* Chained buffer descriptor */
246
typedef
volatile
struct
MCD_bufDesc_struct
MCD_bufDesc
247
struct
MCD_bufDesc_struct
248
u32 flags;
/* flags describing the DMA */
249
u32 csumResult;
/* checksum from checksumming performed since last checksum reset */
250
s8 *srcAddr;
/* the address to move data from */
251
s8 *destAddr;
/* the address to move data to */
252
s8 *lastDestAddr;
/* the last address written to */
253
u32 dmaSize;
/* the number of bytes to transfer independent of the transfer size */
254
MCD_bufDesc
*next;
/* next buffer descriptor in chain */
255
u32 info;
/* private information about this descriptor; DMA does not affect it */
256
257
258
/* Progress Query struct */
259
typedef
volatile
struct
MCD_XferProg_struct
260
s8 *lastSrcAddr;
/* the most-recent or last, post-increment source address */
261
s8 *lastDestAddr;
/* the most-recent or last, post-increment destination address */
262
u32 dmaSize;
/* the amount of data transferred for the current buffer */
263
MCD_bufDesc
*currBufDesc;
/* pointer to the current buffer descriptor being DMAed */
264
MCD_XferProg
265
266
267
/* FEC buffer descriptor */
268
typedef
volatile
struct
MCD_bufDescFec_struct
269
u16 statCtrl;
270
u16 length;
271
u32 dataPointer;
272
MCD_bufDescFec
273
274
275
276
277
* API function Prototypes - see MCD_dmaApi.c for further notes
278
279
280
281
* MCD_startDma starts a particular kind of DMA .
282
283
int
MCD_startDma (
284
int
channel,
/* the channel on which to run the DMA */
285
s8 *srcAddr,
/* the address to move data from, or buffer-descriptor address */
286
s16 srcIncr,
/* the amount to increment the source address per transfer */
287
s8 *destAddr,
288
s16 destIncr,
/* the amount to increment the destination address per transfer */
289
u32 dmaSize,
290
u32 xferSize,
/* the number bytes in of each data movement (1, 2, or 4) */
291
u32 initiator,
/* what device initiates the DMA */
292
int
priority,
/* priority of the DMA */
293
u32 flags,
294
u32 funcDesc
/* a description of byte swapping, bit swapping, and CRC actions */
295
296
297
298
* MCD_initDma() initializes the DMA API by setting up a pointer to the DMA
299
* registers, relocating and creating the appropriate task structures, and
300
* setting up some global settings
301
302
int
MCD_initDma (
dmaRegs
*sDmaBarAddr,
void
*taskTableDest, u32 flags);
303
304
305
* MCD_dmaStatus() returns the status of the DMA on the requested channel.
306
307
int
MCD_dmaStatus (
int
channel);
308
309
310
* MCD_XferProgrQuery() returns progress of DMA on requested channel
311
312
int
MCD_XferProgrQuery (
int
channel,
MCD_XferProg
*progRep);
313
314
315
* MCD_killDma() halts the DMA on the requested channel, without any
316
* intention of resuming the DMA.
317
318
int
MCD_killDma (
int
channel);
319
320
321
* MCD_continDma() continues a DMA which as stopped due to encountering an
322
* unready buffer descriptor.
323
324
int
MCD_continDma (
int
channel);
325
326
327
* MCD_pauseDma() pauses the DMA on the given channel ( if any DMA is
328
* running on that channel).
329
330
int
MCD_pauseDma (
int
channel);
331
332
333
* MCD_resumeDma() resumes the DMA on a given channel (if any DMA is
334
335
336
int
MCD_resumeDma (
int
channel);
337
338
339
* MCD_csumQuery provides the checksum/CRC after performing a non-chained DMA
340
341
int
MCD_csumQuery (
int
channel, u32 *csum);
342
343
344
* MCD_getCodeSize provides the packed size required by the microcoded task
345
* and structures.
346
347
int
MCD_getCodeSize(
void
348
349
350
* MCD_getVersion provides a pointer to a version string and returns a
351
* version number.
352
353
int
MCD_getVersion(
char
**longVersion);
354
355
/* macro for setting a location in the variable table */
356
#define MCD_SET_VAR(taskTab,idx,value) ((u32 *)(taskTab)->varTab)[idx] = value
357
/* Note that MCD_SET_VAR() is invoked many times in firing up a DMA function,
358
so I'm avoiding surrounding it with "do {} while(0)" */
359
360
#endif
/* DEFINESONLY */
361
362
#endif
/* _MCD_API_H */
MCD_XferProg_struct
Definition:
MCD_dma.h:254
Definition:
MCD_dma.h:263
MCD_bufDesc_struct
Definition:
MCD_dma.h:242
TaskTableEntry
Definition:
MCD_dma.h:228
dmaRegs_s
Definition:
MCD_dma.h:60
