RTEMS
6.1-rc1
bsps
powerpc
mvme5500
include
bsp
GT64260ethreg.h
1
/* $NetBSD: GT64260ethreg.h,v 1.2 2003/03/17 16:41:16 matt Exp $ */
2
3
4
* Copyright (c) 2002 Allegro Networks, Inc., Wasabi Systems, Inc.
5
* All rights reserved.
6
7
8
* modification, are permitted provided that the following conditions
9
* are met:
10
* 1. Redistributions of source code must retain the above copyright
11
* notice, this list of conditions and the following disclaimer.
12
* 2. Redistributions in binary form must reproduce the above copyright
13
* notice, this list of conditions and the following disclaimer in the
14
* documentation and/or other materials provided with the distribution.
15
* 3. All advertising materials mentioning features or use of this software
16
* must display the following acknowledgement:
17
* This product includes software developed for the NetBSD Project by
18
* Allegro Networks, Inc., and Wasabi Systems, Inc.
19
* 4. The name of Allegro Networks, Inc. may not be used to endorse
20
* or promote products derived from this software without specific prior
21
* written permission.
22
* 5. The name of Wasabi Systems, Inc. may not be used to endorse
23
24
25
26
* THIS SOFTWARE IS PROVIDED BY ALLEGRO NETWORKS, INC. AND
27
* WASABI SYSTEMS, INC. ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES,
28
* INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
29
* AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
30
* IN NO EVENT SHALL EITHER ALLEGRO NETWORKS, INC. OR WASABI SYSTEMS, INC.
31
* BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37
* POSSIBILITY OF SUCH DAMAGE.
38
39
40
#ifndef _DEV_GTETHREG_H_
41
#define _DEV_GTETHREG_H_
42
43
#define ETH__BIT(bit) (1U << (bit))
44
#define ETH__LLBIT(bit) (1ULL << (bit))
45
#define ETH__MASK(bit) (ETH__BIT(bit) - 1)
46
#define ETH__LLMASK(bit) (ETH__LLBIT(bit) - 1)
47
#define ETH__GEN(n, off) (0x2400+((n) << 10)+(ETH__ ## off))
48
#define ETH__EXT(data, bit, len) (((data) >> (bit)) & ETH__MASK(len))
49
#define ETH__LLEXT(data, bit, len) (((data) >> (bit)) & ETH__LLMASK(len))
50
#define ETH__CLR(data, bit, len) ((data) &= ~(ETH__MASK(len) << (bit)))
51
#define ETH__INS(new, bit) ((new) << (bit))
52
#define ETH__LLINS(new, bit) ((unsigned long long)(new) << (bit))
53
54
55
* Descriptors used for both receive & transmit data. Note that the descriptor
56
* must start on a 4LW boundary. Since the GT accesses the descriptor as
57
* two 64-bit quantities, we must present them 32bit quantities in the right
58
* order based on endianess.
59
60
61
struct
GTeth_desc
62
#if defined(BYTE_ORDER) && BYTE_ORDER == BIG_ENDIAN
/* for mvme5500 */
63
unsigned
ed_lencnt;
/* Buffer size is hi 16 bits; Byte count (rx) is lo 16 */
64
unsigned
ed_cmdsts;
/* command (hi16)/status (lo16) bits */
65
unsigned
ed_nxtptr;
/* next descriptor (must be 4LW aligned) */
66
unsigned
ed_bufptr;
/* pointer to packet buffer */
67
#endif
68
#if defined(BYTE_ORDER) && BYTE_ORDER == LITTLE_ENDIAN
69
unsigned
ed_cmdsts;
70
unsigned
ed_lencnt;
/* length is hi 16 bits; count (rx) is lo 16 */
71
unsigned
ed_bufptr;
72
unsigned
ed_nxtptr;
73
#endif
74
75
76
/* Ethernet 0 address control (Low), Offset: 0xf200 */
77
#define RxBSnoopEn ETH__BIT(6)
/* Rx buffer snoop enable,1=enable*/
78
#define TxBSnoopEn ETH__BIT(14)
/* Tx buffer snoop enable */
79
#define RxDSnoopEn ETH__BIT(22)
/* Rx descriptor snoop enable */
80
#define TxDSnoopEn ETH__BIT(30)
/* Tx descriptor snoop enable */
81
82
/* Ethernet 0 address control (High), Offset: 0xf204 */
83
#define HashSnoopEn ETH__BIT(6)
/* Hash Table snoop enable */
84
85
/* <skf> */
86
#define GT_CUU_Eth0_AddrCtrlLow 0xf200
87
#define GT_CUU_Eth0_AddrCtrlHigh 0xf204
88
89
/* Table 578: Ethernet TX Descriptor - Command/Status word
90
* All bits except F, EI, AM, O are only valid if TX_CMD_L is also set,
91
* otherwise should be 0 (tx).
92
93
94
#define TX_STS_LC ETH__BIT(5)
/* Late Collision */
95
#define TX_STS_UR ETH__BIT(6)
/* Underrun error */
96
#define TX_STS_RL ETH__BIT(8)
/* Retransmit Limit (excession coll) */
97
#define TX_STS_COL ETH__BIT(9)
/* Collision Occurred */
98
#define TX_STS_RC(v) ETH__GETBITS(v, 10, 4)
/* Retransmit Count */
99
#define TX_STS_ES ETH__BIT(15)
/* Error Summary (LC|UR|RL) */
100
#define TX_CMD_L ETH__BIT(16)
/* Last - End Of Packet */
101
#define TX_CMD_F ETH__BIT(17)
/* First - Start Of Packet */
102
#define TX_CMD_P ETH__BIT(18)
/* Pad Packet */
103
#define TX_CMD_GC ETH__BIT(22)
/* Generate CRC */
104
#define TX_CMD_EI ETH__BIT(23)
/* Enable Interrupt */
105
#define TX_CMD_AM ETH__BIT(30)
/* Auto Mode */
106
#define TX_CMD_O ETH__BIT(31)
/* Ownership (1=GT 0=CPU) */
107
108
#define TX_CMD_FIRST (TX_CMD_F|TX_CMD_O)
109
#define TX_CMD_LAST (TX_CMD_L|TX_CMD_GC|TX_CMD_P|TX_CMD_O)
110
111
/* Table 608: Ethernet RX Descriptor - Command/Status Word
112
* All bits except F, EI, AM, O are only valid if RX_CMD_L is also set,
113
* otherwise should be ignored (rx).
114
115
#define RX_STS_CE ETH__BIT(0)
/* CRC Error */
116
#define RX_STS_COL ETH__BIT(1)
/* Collision sensed during reception */
117
#define RX_STS_LC ETH__BIT(5)
/* Late Collision (Reserved) */
118
#define RX_STS_OR ETH__BIT(6)
/* Overrun Error */
119
#define RX_STS_MFL ETH__BIT(7)
/* Max Frame Len Error */
120
#define RX_STS_SF ETH__BIT(8)
/* Short Frame Error (< 64 bytes) */
121
#define RX_STS_FT ETH__BIT(11)
/* Frame Type (1 = 802.3) */
122
#define RX_STS_M ETH__BIT(12)
/* Missed Frame */
123
#define RX_STS_HE ETH__BIT(13)
/* Hash Expired (manual match) */
124
#define RX_STS_IGMP ETH__BIT(14)
/* IGMP Packet */
125
#define RX_STS_ES ETH__BIT(15)
/* Error Summary (CE|COL|LC|OR|MFL|SF) */
126
#define RX_CMD_L ETH__BIT(16)
127
#define RX_CMD_F ETH__BIT(17)
128
#define RX_CMD_EI ETH__BIT(23)
129
#define RX_CMD_AM ETH__BIT(30)
/* Auto Mode */
130
#define RX_CMD_O ETH__BIT(31)
131
132
/* Table 586: Hash Table Entry Fields
133
134
#define HSH_V ETH__LLBIT(0)
/* Entry is valid */
135
#define HSH_S ETH__LLBIT(1)
/* Skip this entry */
136
#define HSH_RD ETH__LLBIT(2)
/* Receive(1) / Discard (0) */
137
#define HSH_R ETH__LLBIT(2)
/* Receive(1) */
138
#define HSH_PRIO_GET(v) ETH__LLEXT(v, 51, 2)
139
#define HSH_PRIO_INS(v) ETH__LLINS(v, 51)
140
#define HSH_ADDR_MASK 0x7fffff8LLU
141
#define HSH_LIMIT 12
142
143
144
#define ETH_EPAR 0x2000
/* PHY Address Register */
145
#define ETH_ESMIR 0x2010
/* SMI Register */
146
147
#define ETH_BASE_ETH0 0x2400
/* Ethernet0 Register Base */
148
#define ETH_BASE_ETH1 0x2800
/* Ethernet1 Register Base */
149
#define ETH_BASE_ETH2 0x2c00
/* Ethernet2 Register Base */
150
#define ETH_SIZE 0x0400
/* Register Space */
151
152
#define ETH__EBASE 0x0000
/* Base of Registers */
153
#define ETH__EPCR 0x0000
/* Port Config. Register */
154
#define ETH__EPCXR 0x0008
/* Port Config. Extend Reg */
155
#define ETH__EPCMR 0x0010
/* Port Command Register */
156
#define ETH__EPSR 0x0018
/* Port Status Register */
157
#define ETH__ESPR 0x0020
/* Port Serial Parameters Reg */
158
#define ETH__EHTPR 0x0028
/* Port Hash Table Pointer Reg*/
159
#define ETH__EFCSAL 0x0030
/* Flow Control Src Addr Low */
160
#define ETH__EFCSAH 0x0038
/* Flow Control Src Addr High */
161
#define ETH__ESDCR 0x0040
/* SDMA Configuration Reg */
162
#define ETH__ESDCMR 0x0048
/* SDMA Command Register */
163
#define ETH__EICR 0x0050
/* Interrupt Cause Register */
164
#define ETH__EIMR 0x0058
/* Interrupt Mask Register */
165
#define ETH__EFRDP0 0x0080
/* First Rx Desc Pointer 0 */
166
#define ETH__EFRDP1 0x0084
/* First Rx Desc Pointer 1 */
167
#define ETH__EFRDP2 0x0088
/* First Rx Desc Pointer 2 */
168
#define ETH__EFRDP3 0x008c
/* First Rx Desc Pointer 3 */
169
#define ETH__ECRDP0 0x00a0
/* Current Rx Desc Pointer 0 */
170
#define ETH__ECRDP1 0x00a4
/* Current Rx Desc Pointer 1 */
171
#define ETH__ECRDP2 0x00a8
/* Current Rx Desc Pointer 2 */
172
#define ETH__ECRDP3 0x00ac
/* Current Rx Desc Pointer 3 */
173
#define ETH__ECTDP0 0x00e0
/* Current Tx Desc Pointer 0 */
174
#define ETH__ECTDP1 0x00e4
/* Current Tx Desc Pointer 1 */
175
#define ETH__EDSCP2P0L 0x0060
/* IP Differentiated Services
176
CodePoint to Priority0 low */
177
#define ETH__EDSCP2P0H 0x0064
178
CodePoint to Priority0 high*/
179
#define ETH__EDSCP2P1L 0x0068
180
CodePoint to Priority1 low */
181
#define ETH__EDSCP2P1H 0x006c
182
CodePoint to Priority1 high*/
183
#define ETH__EVPT2P 0x0068
/* VLAN Prio. Tag to Priority */
184
#define ETH__EMIBCTRS 0x0100
/* MIB Counters */
185
186
/* SKF : we are only concerned with the Ethernet0 for the mvme5500 board */
187
#define ETH0_EBASE 0x2400
188
#define ETH0_EPCR 0x2400
189
#define ETH0_EPCXR 0x2408
190
#define ETH0_EPCMR 0x2410
191
#define ETH0_EPSR 0x2418
192
#define ETH0_ESPR 0x2420
193
#define ETH0_EHTPR 0x2428
194
#define ETH0_EFCSAL 0x2430
195
#define ETH0_EFCSAH 0x2438
196
#define ETH0_ESDCR 0x2440
197
#define ETH0_ESDCMR 0x2448
198
#define ETH0_EICR 0x2450
199
#define ETH0_EIMR 0x2458
200
#define ETH0_EFRDP0 0x2480
201
#define ETH0_EFRDP1 0x2484
202
#define ETH0_EFRDP2 0x2488
203
#define ETH0_EFRDP3 0x248c
204
#define ETH0_ECRDP0 0x24a0
205
#define ETH0_ECRDP1 0x24a4
206
#define ETH0_ECRDP2 0x24a8
207
#define ETH0_ECRDP3 0x24ac
208
#define ETH0_ECTDP0 0x24e0
209
#define ETH0_ECTDP1 0x24e4
210
#define ETH0_EDSCP2P0L 0x2460
211
212
#define ETH0_EDSCP2P0H 0x2464
213
214
#define ETH0_EDSCP2P1L 0x2468
215
216
#define ETH0_EDSCP2P1H 0x246c
217
218
#define ETH0_EVPT2P 0x2468
219
#define ETH0_EMIBCTRS 0x2500
/* MIB Counters */
220
221
#define ETH_BASE(n) ETH__GEN(n, EBASE)
222
#define ETH_EPCR(n) ETH__GEN(n, EPCR)
223
#define ETH_EPCXR(n) ETH__GEN(n, EPCXR)
224
#define ETH_EPCMR(n) ETH__GEN(n, EPCMR)
225
#define ETH_EPSR(n) ETH__GEN(n, EPSR)
226
#define ETH_ESPR(n) ETH__GEN(n, ESPR)
227
#define ETH_EHTPR(n) ETH__GEN(n, EHPTR)
228
#define ETH_EFCSAL(n) ETH__GEN(n, EFCSAL)
229
#define ETH_EFCSAH(n) ETH__GEN(n, EFCSAH)
230
#define ETH_ESDCR(n) ETH__GEN(n, ESDCR)
231
#define ETH_ESDCMR(n) ETH__GEN(n, ESDCMR)
232
#define ETH_EICR(n) ETH__GEN(n, EICR)
233
#define ETH_EIMR(n) ETH__GEN(n, EIMR)
234
#define ETH_EFRDP0(n) ETH__GEN(n, EFRDP0)
235
#define ETH_EFRDP1(n) ETH__GEN(n, EFRDP1)
236
#define ETH_EFRDP2(n) ETH__GEN(n, EFRDP2)
237
#define ETH_EFRDP3(n) ETH__GEN(n, EFRDP3)
238
#define ETH_ECRDP0(n) ETH__GEN(n, ECRDP0)
239
#define ETH_ECRDP1(n) ETH__GEN(n, ECRDP1)
240
#define ETH_ECRDP2(n) ETH__GEN(n, ECRDP2)
241
#define ETH_ECRDP3(n) ETH__GEN(n, ECRDP3)
242
#define ETH_ECTDP0(n) ETH__GEN(n, ECTDP0)
243
#define ETH_ECTDP1(n) ETH__GEN(n, ECTDP1)
244
#define ETH_EDSCP2P0L(n) ETH__GEN(n, EDSCP2P0L)
245
246
#define ETH_EDSCP2P0H(n) ETH__GEN(n, EDSCP2P0H)
247
248
#define ETH_EDSCP2P1L(n) ETH__GEN(n, EDSCP2P1L)
249
250
#define ETH_EDSCP2P1H(n) ETH__GEN(n, EDSCP1P1H)
251
252
#define ETH_EVPT2P(n) ETH__GEN(n, EVPT2P)
253
#define ETH_EMIBCTRS(n) ETH__GEN(n, EMIBCTRS)
/* MIB Counters */
254
255
#define ETH_EPAR_PhyAD_GET(v, n) (((v) >> ((n) * 5)) & 0x1f)
256
257
#define ETH_ESMIR_READ(phy, reg) (ETH__INS(phy, 16)|\
258
ETH__INS(reg, 21)|\
259
ETH_ESMIR_ReadOpcode)
260
#define ETH_ESMIR_WRITE(phy, reg, val) (ETH__INS(phy, 16)|\
261
ETH__INS(reg, 21)|\
262
ETH__INS(val, 0)|\
263
ETH_ESMIR_WriteOpcode)
264
#define ETH_ESMIR_Value_GET(v) ETH__EXT(v, 0, 16)
265
#define ETH_ESMIR_WriteOpcode 0
266
#define ETH_ESMIR_ReadOpcode ETH__BIT(26)
267
#define ETH_ESMIR_ReadValid ETH__BIT(27)
268
#define ETH_ESMIR_Busy ETH__BIT(28)
269
270
271
* Table 597: Port Configuration Register (PCR)
272
* 00:00 PM Promiscuous mode
273
* 0: Normal mode (Frames are only received if the
274
* destination address is found in the hash
275
* table)
276
* 1: Promiscuous mode (Frames are received
277
* regardless of their destination address.
278
* Errored frames are discarded unless the Port
279
* Configuration register's PBF bit is set)
280
* 01:01 RBM Reject Broadcast Mode
281
* 0: Receive broadcast address
282
* 1: Reject frames with broadcast address
283
* Overridden by the promiscuous mode.
284
* 02:02 PBF Pass Bad Frames
285
* (0: Normal mode, 1: Pass bad Frames)
286
* The Ethernet receiver passes to the CPU errored
287
* frames (like fragments and collided packets)
288
* that are normally rejected.
289
* NOTE: Frames are only passed if they
290
* successfully pass address filtering.
291
* 06:03 Reserved
292
* 07:07 EN Enable (0: Disabled, 1: Enable)
293
* When enabled, the ethernet port is ready to
294
* transmit/receive.
295
* 09:08 LPBK Loop Back Mode
296
* 00: Normal mode
297
* 01: Internal loop back mode (TX data is looped
298
* back to the RX lines. No transition is seen
299
* on the interface pins)
300
* 10: External loop back mode (TX data is looped
301
* back to the RX lines and also transmitted
302
* out to the MII interface pins)
303
* 11: Reserved
304
* 10:10 FC Force Collision
305
* 0: Normal mode.
306
* 1: Force Collision on any TX frame.
307
* For RXM test (in Loopback mode).
308
* 11:11 Reserved.
309
* 12:12 HS Hash Size
310
* 0: 8K address filtering
311
* (256KB of memory space required).
312
* 1: 512 address filtering
313
* ( 16KB of memory space required).
314
* 13:13 HM Hash Mode (0: Hash Func. 0; 1: Hash Func. 1)
315
* 14:14 HDM Hash Default Mode
316
* 0: Discard addresses not found in address table
317
* 1: Pass addresses not found in address table
318
* 15:15 HD Duplex Mode (0: Half Duplex, 1: Full Duplex)
319
* NOTE: Valid only when auto-negotiation for
320
* duplex mode is disabled.
321
* 30:16 Reserved
322
* 31:31 ACCS Accelerate Slot Time
323
* (0: Normal mode, 1: Reserved)
324
325
#define ETH_EPCR_PM ETH__BIT(0)
326
#define ETH_EPCR_RBM ETH__BIT(1)
327
#define ETH_EPCR_PBF ETH__BIT(2)
328
#define ETH_EPCR_EN ETH__BIT(7)
329
#define ETH_EPCR_LPBK_GET(v) ETH__BIT(v, 8, 2)
330
#define ETH_EPCR_LPBK_Normal 0
331
#define ETH_EPCR_LPBK_Internal 1
332
#define ETH_EPCR_LPBK_External 2
333
#define ETH_EPCR_FC ETH__BIT(10)
334
335
#define ETH_EPCR_HS ETH__BIT(12)
336
#define ETH_EPCR_HS_8K 0
337
#define ETH_EPCR_HS_512 ETH_EPCR_HS
338
339
#define ETH_EPCR_HM ETH__BIT(13)
340
#define ETH_EPCR_HM_0 0
341
#define ETH_EPCR_HM_1 ETH_EPCR_HM
342
343
#define ETH_EPCR_HDM ETH__BIT(14)
344
#define ETH_EPCR_HDM_Discard 0
345
#define ETH_EPCR_HDM_Pass ETH_EPCR_HDM
346
347
#define ETH_EPCR_HD_Half 0
348
#define ETH_EPCR_HD_Full ETH_EPCR_HD_Full
349
350
#define ETH_EPCR_ACCS ETH__BIT(31)
351
352
353
354
355
* Table 598: Port Configuration Extend Register (PCXR)
356
* 00:00 IGMP IGMP Packets Capture Enable
357
* 0: IGMP packets are treated as normal Multicast
358
* packets.
359
* 1: IGMP packets on IPv4/Ipv6 over Ethernet/802.3
360
* are trapped and sent to high priority RX
361
* queue.
362
* 01:01 SPAN Spanning Tree Packets Capture Enable
363
* 0: BPDU (Bridge Protocol Data Unit) packets are
364
* treated as normal Multicast packets.
365
* 1: BPDU packets are trapped and sent to high
366
* priority RX queue.
367
* 02:02 PAR Partition Enable (0: Normal, 1: Partition)
368
* When more than 61 collisions occur while
369
* transmitting, the port enters Partition mode.
370
* It waits for the first good packet from the
371
* wire and then goes back to Normal mode. Under
372
* Partition mode it continues transmitting, but
373
* it does not receive.
374
* 05:03 PRIOtx Priority weight in the round-robin between high
375
* and low priority TX queues.
376
* 000: 1 pkt from HIGH, 1 pkt from LOW.
377
* 001: 2 pkt from HIGH, 1 pkt from LOW.
378
* 010: 4 pkt from HIGH, 1 pkt from LOW.
379
* 011: 6 pkt from HIGH, 1 pkt from LOW.
380
* 100: 8 pkt from HIGH, 1 pkt from LOW.
381
* 101: 10 pkt from HIGH, 1 pkt from LOW.
382
* 110: 12 pkt from HIGH, 1 pkt from LOW.
383
* 111: All pkt from HIGH, 0 pkt from LOW. LOW is
384
* served only if HIGH is empty.
385
* NOTE: If the HIGH queue is emptied before
386
* finishing the count, the count is reset
387
* until the next first HIGH comes in.
388
* 07:06 PRIOrx Default Priority for Packets Received on this
389
* Port (00: Lowest priority, 11: Highest priority)
390
* 08:08 PRIOrx_Override Override Priority for Packets Received on this
391
* Port (0: Do not override, 1: Override with
392
* <PRIOrx> field)
393
* 09:09 DPLXen Enable Auto-negotiation for Duplex Mode
394
* (0: Enable, 1: Disable)
395
* 11:10 FCTLen Enable Auto-negotiation for 802.3x Flow-control
396
* 0: Enable; When enabled, 1 is written (through
397
* SMI access) to the PHY's register 4 bit 10
398
* to advertise flow-control capability.
399
* 1: Disable; Only enables flow control after the
400
* PHY address is set by the CPU. When changing
401
* the PHY address the flow control
402
* auto-negotiation must be disabled.
403
* 11:11 FLP Force Link Pass
404
* (0: Force Link Pass, 1: Do NOT Force Link pass)
405
* 12:12 FCTL 802.3x Flow-Control Mode (0: Enable, 1: Disable)
406
* NOTE: Only valid when auto negotiation for flow
407
* control is disabled.
408
* 13:13 Reserved
409
* 15:14 MFL Max Frame Length
410
* Maximum packet allowed for reception (including
411
* CRC): 00: 1518 bytes, 01: 1536 bytes,
412
* 10: 2048 bytes, 11: 64K bytes
413
* 16:16 MIBclrMode MIB Counters Clear Mode (0: Clear, 1: No effect)
414
* 17:17 MIBctrMode Reserved. (MBZ)
415
* 18:18 Speed Port Speed (0: 10Mbit/Sec, 1: 100Mbit/Sec)
416
* NOTE: Only valid if SpeedEn bit is set.
417
* 19:19 SpeedEn Enable Auto-negotiation for Speed
418
419
* 20:20 RMIIen RMII enable
420
* 0: Port functions as MII port
421
* 1: Port functions as RMII port
422
* 21:21 DSCPen DSCP enable
423
* 0: IP DSCP field decoding is disabled.
424
* 1: IP DSCP field decoding is enabled.
425
* 31:22 Reserved
426
427
#define ETH_EPCXR_IGMP ETH__BIT(0)
428
#define ETH_EPCXR_SPAN ETH__BIT(1)
429
#define ETH_EPCXR_PAR ETH__BIT(2)
430
#define ETH_EPCXR_PRIOtx_GET(v) ETH__EXT(v, 3, 3)
431
#define ETH_EPCXR_PRIOrx_GET(v) ETH__EXT(v, 3, 3)
432
#define ETH_EPCXR_PRIOrx_Override ETH__BIT(8)
433
#define ETH_EPCXR_DLPXen ETH__BIT(9)
434
#define ETH_EPCXR_FCTLen ETH__BIT(10)
435
#define ETH_EPCXR_FLP ETH__BIT(11)
436
#define ETH_EPCXR_FCTL ETH__BIT(12)
437
#define ETH_EPCXR_MFL_GET(v) ETH__EXT(v, 14, 2)
438
#define ETH_EPCXR_MFL_1518 0
439
#define ETH_EPCXR_MFL_1536 1
440
#define ETH_EPCXR_MFL_2048 2
441
#define ETH_EPCXR_MFL_64K 3
442
#define ETH_EPCXR_MIBclrMode ETH__BIT(16)
443
#define ETH_EPCXR_MIBctrMode ETH__BIT(17)
444
#define ETH_EPCXR_Speed ETH__BIT(18)
445
#define ETH_EPCXR_SpeedEn ETH__BIT(19)
446
#define ETH_EPCXR_RMIIEn ETH__BIT(20)
447
#define ETH_EPCXR_DSCPEn ETH__BIT(21)
448
449
450
451
452
* Table 599: Port Command Register (PCMR)
453
* 14:00 Reserved
454
* 15:15 FJ Force Jam / Flow Control
455
* When in half-duplex mode, the CPU uses this bit
456
* to force collisions on the Ethernet segment.
457
* When the CPU recognizes that it is going to run
458
* out of receive buffers, it can force the
459
* transmitter to send jam frames, forcing
460
* collisions on the wire. To allow transmission
461
* on the Ethernet segment, the CPU must clear the
462
* FJ bit when more resources are available. When
463
* in full-duplex and flow-control is enabled, this
464
* bit causes the port's transmitter to send
465
* flow-control PAUSE packets. The CPU must reset
466
* this bit when more resources are available.
467
* 31:16 Reserved
468
469
470
#define ETH_EPCMR_FJ ETH__BIT(15)
471
472
473
474
* Table 600: Port Status Register (PSR) -- Read Only
475
* 00:00 Speed Indicates Port Speed (0: 10Mbs, 1: 100Mbs)
476
* 01:01 Duplex Indicates Port Duplex Mode (0: Half, 1: Full)
477
* 02:02 Fctl Indicates Flow-control Mode
478
* (0: enabled, 1: disabled)
479
* 03:03 Link Indicates Link Status (0: down, 1: up)
480
* 04:04 Pause Indicates that the port is in flow-control
481
* disabled state. This bit is set when an IEEE
482
* 802.3x flow-control PAUSE (XOFF) packet is
483
* received (assuming that flow-control is
484
* enabled and the port is in full-duplex mode).
485
* Reset when XON is received, or when the XOFF
486
* timer has expired.
487
* 05:05 TxLow Tx Low Priority Status
488
* Indicates the status of the low priority
489
* transmit queue: (0: Stopped, 1: Running)
490
* 06:06 TxHigh Tx High Priority Status
491
* Indicates the status of the high priority
492
493
* 07:07 TXinProg TX in Progress
494
* Indicates that the port's transmitter is in an
495
* active transmission state.
496
* 31:08 Reserved
497
498
#define ETH_EPSR_Speed ETH__BIT(0)
499
#define ETH_EPSR_Duplex ETH__BIT(1)
500
#define ETH_EPSR_Fctl ETH__BIT(2)
501
#define ETH_EPSR_Link ETH__BIT(3)
502
#define ETH_EPSR_Pause ETH__BIT(4)
503
#define ETH_EPSR_TxLow ETH__BIT(5)
504
#define ETH_EPSR_TxHigh ETH__BIT(6)
505
#define ETH_EPSR_TXinProg ETH__BIT(7)
506
507
508
509
* Table 601: Serial Parameters Register (SPR)
510
* 01:00 JAM_LENGTH Two bits to determine the JAM Length
511
* (in Backpressure) as follows:
512
* 00 = 12K bit-times
513
* 01 = 24K bit-times
514
* 10 = 32K bit-times
515
* 11 = 48K bit-times
516
* 06:02 JAM_IPG Five bits to determine the JAM IPG.
517
* The step is four bit-times. The value may vary
518
* between 4 bit time to 124.
519
* 11:07 IPG_JAM_TO_DATA Five bits to determine the IPG JAM to DATA.
520
521
522
* 16:12 IPG_DATA Inter-Packet Gap (IPG)
523
524
* between 12 bit time to 124.
525
* NOTE: These bits may be changed only when the
526
* Ethernet ports is disabled.
527
* 21:17 Data_Blind Data Blinder
528
* The number of nibbles from the beginning of the
529
* IPG, in which the IPG counter is restarted when
530
* detecting a carrier activity. Following this
531
* value, the port enters the Data Blinder zone and
532
* does not reset the IPG counter. This ensures
533
* fair access to the medium.
534
* The default is 10 hex (64 bit times - 2/3 of the
535
* default IPG). The step is 4 bit-times. Valid
536
* range is 3 to 1F hex nibbles.
537
* NOTE: These bits may be only changed when the
538
* Ethernet port is disabled.
539
* 22:22 Limit4 The number of consecutive packet collisions that
540
* occur before the collision counter is reset.
541
* 0: The port resets its collision counter after
542
* 16 consecutive retransmit trials and
543
* restarts the Backoff algorithm.
544
* 1: The port resets its collision counter and
545
* restarts the Backoff algorithm after 4
546
* consecutive transmit trials.
547
* 31:23 Reserved
548
549
#define ETH_ESPR_JAM_LENGTH_GET(v) ETH__EXT(v, 0, 2)
550
#define ETH_ESPR_JAM_IPG_GET(v) ETH__EXT(v, 2, 5)
551
#define ETH_ESPR_IPG_JAM_TO_DATA_GET(v) ETH__EXT(v, 7, 5)
552
#define ETH_ESPR_IPG_DATA_GET(v) ETH__EXT(v, 12, 5)
553
#define ETH_ESPR_Data_Bilnd_GET(v) ETH__EXT(v, 17, 5)
554
#define ETH_ESPR_Limit4(v) ETH__BIT(22)
555
556
557
* Table 602: Hash Table Pointer Register (HTPR)
558
* 31:00 HTP 32-bit pointer to the address table.
559
* Bits [2:0] must be set to zero.
560
561
562
563
* Table 603: Flow Control Source Address Low (FCSAL)
564
* 15:0 SA[15:0] Source Address
565
* The least significant bits of the source
566
* address for the port. This address is used for
567
* Flow Control.
568
* 31:16 Reserved
569
570
571
572
* Table 604: Flow Control Source Address High (FCSAH)
573
* 31:0 SA[47:16] Source Address
574
* The most significant bits of the source address
575
* for the port. This address is used for Flow
576
* Control.
577
578
579
580
581
* Table 605: SDMA Configuration Register (SDCR)
582
* 01:00 Reserved
583
* 05:02 RC Retransmit Count
584
* Sets the maximum number of retransmits per
585
* packet. After executing retransmit for RC
586
* times, the TX SDMA closes the descriptor with a
587
* Retransmit Limit error indication and processes
588
* the next packet. When RC is set to 0, the
589
* number of retransmits is unlimited. In this
590
* case, the retransmit process is only terminated
591
* if CPU issues an Abort command.
592
* 06:06 BLMR Big/Little Endian Receive Mode
593
* The DMA supports Big or Little Endian
594
* configurations on a per channel basis. The BLMR
595
* bit only affects data transfer to memory.
596
* 0: Big Endian
597
* 1: Little Endian
598
* 07:07 BLMT Big/Little Endian Transmit Mode
599
600
* configurations on a per channel basis. The BLMT
601
* bit only affects data transfer from memory.
602
* 0: Big Endian
603
* 1: Little Endian
604
* 08:08 POVR PCI Override
605
* When set, causes the SDMA to direct all its
606
* accesses in PCI_0 direction and overrides
607
* normal address decoding process.
608
* 09:09 RIFB Receive Interrupt on Frame Boundaries
609
* When set, the SDMA Rx generates interrupts only
610
* on frame boundaries (i.e. after writing the
611
* frame status to the descriptor).
612
* 11:10 Reserved
613
* 13:12 BSZ Burst Size
614
* Sets the maximum burst size for SDMA
615
* transactions:
616
* 00: Burst is limited to 1 64bit words.
617
* 01: Burst is limited to 2 64bit words.
618
* 10: Burst is limited to 4 64bit words.
619
* 11: Burst is limited to 8 64bit words.
620
* 31:14 Reserved
621
622
#define ETH_ESDCR_RC_GET(v) ETH__EXT(v, 2, 4)
623
#define ETH_ESDCR_BLMR ETH__BIT(6)
624
#define ETH_ESDCR_BLMT ETH__BIT(7)
625
#define ETH_ESDCR_POVR ETH__BIT(8)
626
#define ETH_ESDCR_RIFB ETH__BIT(9)
627
#define ETH_ESDCR_BSZ_GET(v) ETH__EXT(v, 12, 2)
628
#define ETH_ESDCR_BSZ_SET(v, n) (ETH__CLR(v, 12, 2),\
629
(v) |= ETH__INS(n, 12))
630
#define ETH_ESDCR_BSZ_1 0
631
#define ETH_ESDCR_BSZ_2 1
632
#define ETH_ESDCR_BSZ_4 2
633
#define ETH_ESDCR_BSZ_8 3
634
635
#define ETH_ESDCR_BSZ_Strings { "1 64-bit word"
, "2 64-bit words", \
636
"4 64-bit words", "8 64-bit words" }
637
638
639
* Table 606: SDMA Command Register (SDCMR)
640
* 06:00 Reserved
641
* 07:07 ERD Enable RX DMA.
642
* Set to 1 by the CPU to cause the SDMA to start
643
* a receive process. Cleared when the CPU issues
644
* an Abort Receive command.
645
* 14:08 Reserved
646
* 15:15 AR Abort Receive
647
* Set to 1 by the CPU to abort a receive SDMA
648
* operation. When the AR bit is set, the SDMA
649
* aborts its current operation and moves to IDLE.
650
* No descriptor is closed. The AR bit is cleared
651
* upon entering IDLE. After setting the AR bit,
652
* the CPU must poll the bit to verify that the
653
* abort sequence is completed.
654
* 16:16 STDH Stop TX High
655
* Set to 1 by the CPU to stop the transmission
656
* process from the high priority queue at the end
657
* of the current frame. An interrupt is generated
658
* when the stop command has been executed.
659
* Writing 1 to STDH resets TXDH bit.
660
* Writing 0 to this bit has no effect.
661
* 17:17 STDL Stop TX Low
662
663
* process from the low priority queue at the end
664
665
666
* Writing 1 to STDL resets TXDL bit.
667
668
* 22:18 Reserved
669
* 23:23 TXDH Start Tx High
670
* Set to 1 by the CPU to cause the SDMA to fetch
671
* the first descriptor and start a transmit
672
* process from the high priority Tx queue.
673
* Writing 1 to TXDH resets STDH bit.
674
675
* 24:24 TXDL Start Tx Low
676
677
678
* process from the low priority Tx queue.
679
* Writing 1 to TXDL resets STDL bit.
680
681
* 30:25 Reserved
682
* 31:31 AT Abort Transmit
683
* Set to 1 by the CPU to abort a transmit DMA
684
* operation. When the AT bit is set, the SDMA
685
686
* No descriptor is closed. Cleared upon entering
687
* IDLE. After setting AT bit, the CPU must poll
688
* it in order to verify that the abort sequence
689
* is completed.
690
691
#define ETH_ESDCMR_ERD ETH__BIT(7)
692
#define ETH_ESDCMR_AR ETH__BIT(15)
693
#define ETH_ESDCMR_STDH ETH__BIT(16)
694
#define ETH_ESDCMR_STDL ETH__BIT(17)
695
#define ETH_ESDCMR_TXDH ETH__BIT(23)
696
#define ETH_ESDCMR_TXDL ETH__BIT(24)
697
#define ETH_ESDCMR_AT ETH__BIT(31)
698
699
700
* Table 607: Interrupt Cause Register (ICR)
701
* 00:00 RxBuffer Rx Buffer Return
702
* Indicates an Rx buffer returned to CPU ownership
703
* or that the port finished reception of a Rx
704
* frame in either priority queues.
705
* NOTE: In order to get a Rx Buffer return per
706
* priority queue, use bit 19:16. This bit is
707
* set upon closing any Rx descriptor which
708
* has its EI bit set. To limit the
709
* interrupts to frame (rather than buffer)
710
* boundaries, the user must set SDMA
711
* Configuration register's RIFB bit. When
712
* the RIFB bit is set, an interrupt
713
* generates only upon closing the first
714
* descriptor of a received packet, if this
715
* descriptor has it EI bit set.
716
* 01:01 Reserved
717
* 02:02 TxBufferHigh Tx Buffer for High priority Queue
718
* Indicates a Tx buffer returned to CPU ownership
719
* or that the port finished transmission of a Tx
720
* frame.
721
* NOTE: This bit is set upon closing any Tx
722
* descriptor which has its EI bit set. To
723
* limit the interrupts to frame (rather than
724
* buffer) boundaries, the user must set EI
725
* only in the last descriptor.
726
* 03:03 TxBufferLow Tx Buffer for Low Priority Queue
727
728
729
* frame.
730
731
732
733
734
735
* 05:04 Reserved
736
* 06:06 TxEndHigh Tx End for High Priority Queue
737
* Indicates that the Tx DMA stopped processing the
738
* high priority queue after stop command, or that
739
* it reached the end of the high priority
740
* descriptor chain.
741
* 07:07 TxEndLow Tx End for Low Priority Queue
742
743
* low priority queue after stop command, or that
744
* it reached the end of the low priority
745
* descriptor chain.
746
* 08:08 RxError Rx Resource Error
747
* Indicates a Rx resource error event in one of
748
* the priority queues.
749
* NOTE: To get a Rx Resource Error Indication per
750
* priority queue, use bit 23:20.
751
* 09:09 Reserved
752
* 10:10 TxErrorHigh Tx Resource Error for High Priority Queue
753
* Indicates a Tx resource error event during
754
* packet transmission from the high priority queue
755
* 11:11 TxErrorLow Tx Resource Error for Low Priority Queue
756
757
* packet transmission from the low priority queue
758
* 12:12 RxOVR Rx Overrun
759
* Indicates an overrun event that occurred during
760
* reception of a packet.
761
* 13:13 TxUdr Tx Underrun
762
* Indicates an underrun event that occurred during
763
* transmission of packet from either queue.
764
* 15:14 Reserved
765
* 16:16 RxBuffer-Queue[0] Rx Buffer Return in Priority Queue[0]
766
* Indicates a Rx buffer returned to CPU ownership
767
* or that the port completed reception of a Rx
768
* frame in a receive priority queue[0]
769
* 17:17 RxBuffer-Queue[1] Rx Buffer Return in Priority Queue[1]
770
771
772
* frame in a receive priority queue[1].
773
* 18:18 RxBuffer-Queue[2] Rx Buffer Return in Priority Queue[2]
774
775
776
* frame in a receive priority queue[2].
777
* 19:19 RxBuffer-Queue[3] Rx Buffer Return in Priority Queue[3]
778
779
780
* frame in a receive priority queue[3].
781
* 20:20 RxError-Queue[0] Rx Resource Error in Priority Queue[0]
782
* Indicates a Rx resource error event in receive
783
* priority queue[0].
784
* 21:21 RxError-Queue[1] Rx Resource Error in Priority Queue[1]
785
786
* priority queue[1].
787
* 22:22 RxError-Queue[2] Rx Resource Error in Priority Queue[2]
788
789
* priority queue[2].
790
* 23:23 RxError-Queue[3] Rx Resource Error in Priority Queue[3]
791
792
* priority queue[3].
793
* 27:24 Reserved
794
* 28:29 MIIPhySTC MII PHY Status Change
795
* Indicates a status change reported by the PHY
796
* connected to this port. Set when the MII
797
* management interface block identifies a change
798
* in PHY's register 1.
799
* 29:29 SMIdone SMI Command Done
800
* Indicates that the SMI completed a MII
801
* management command (either read or write) that
802
* was initiated by the CPU writing to the SMI
803
* register.
804
* 30:30 Reserved
805
* 31:31 EtherIntSum Ethernet Interrupt Summary
806
* This bit is a logical OR of the (unmasked) bits
807
* [30:04] in the Interrupt Cause register.
808
809
810
#define ETH_IR_RxBuffer ETH__BIT(0)
811
#define ETH_IR_TxBufferHigh ETH__BIT(2)
812
#define ETH_IR_TxBufferLow ETH__BIT(3)
813
#define ETH_IR_TxEndHigh ETH__BIT(6)
814
#define ETH_IR_TxEndLow ETH__BIT(7)
815
#define ETH_IR_RxError ETH__BIT(8)
816
#define ETH_IR_TxErrorHigh ETH__BIT(10)
817
#define ETH_IR_TxErrorLow ETH__BIT(11)
818
#define ETH_IR_RxOVR ETH__BIT(12)
819
#define ETH_IR_TxUdr ETH__BIT(13)
820
#define ETH_IR_RxBuffer_0 ETH__BIT(16)
821
#define ETH_IR_RxBuffer_1 ETH__BIT(17)
822
#define ETH_IR_RxBuffer_2 ETH__BIT(18)
823
#define ETH_IR_RxBuffer_3 ETH__BIT(19)
824
#define ETH_IR_RxBuffer_GET(v) ETH__EXT(v, 16, 4)
825
#define ETH_IR_RxError_0 ETH__BIT(20)
826
#define ETH_IR_RxError_1 ETH__BIT(21)
827
#define ETH_IR_RxError_2 ETH__BIT(22)
828
#define ETH_IR_RxError_3 ETH__BIT(23)
829
#define ETH_IR_RxError_GET(v) ETH__EXT(v, 20, 4)
830
#define ETH_IR_RxBits (ETH_IR_RxBuffer_0|\
831
ETH_IR_RxBuffer_1|\
832
ETH_IR_RxBuffer_2|\
833
ETH_IR_RxBuffer_3|\
834
ETH_IR_RxError_0|\
835
ETH_IR_RxError_1|\
836
ETH_IR_RxError_2|\
837
ETH_IR_RxError_3)
838
#define ETH_IR_MIIPhySTC ETH__BIT(28)
839
#define ETH_IR_SMIdone ETH__BIT(29)
840
#define ETH_IR_EtherIntSum (1<<31)
841
#define ETH_IR_Summary (1<<31)
842
#define ETH_IR_ErrorSum 0x803d00
843
#define INTR_RX_ERROR 0x801100
844
#define INTR_TX_ERROR 0x002c00
845
846
847
* Table 608: Interrupt Mask Register (IMR)
848
* 31:00 Various Mask bits for the Interrupt Cause register.
849
850
851
852
* Table 609: IP Differentiated Services CodePoint to Priority0 low (DSCP2P0L),
853
* 31:00 Priority0_low The LSB priority bits for DSCP[31:0] entries.
854
855
856
857
* Table 610: IP Differentiated Services CodePoint to Priority0 high (DSCP2P0H)
858
* 31:00 Priority0_high The LSB priority bits for DSCP[63:32] entries.
859
860
861
862
* Table 611: IP Differentiated Services CodePoint to Priority1 low (DSCP2P1L)
863
* 31:00 Priority1_low The MSB priority bits for DSCP[31:0] entries.
864
865
866
867
* Table 612: IP Differentiated Services CodePoint to Priority1 high (DSCP2P1H)
868
* 31:00 Priority1_high The MSB priority bit for DSCP[63:32] entries.
869
870
871
872
* Table 613: VLAN Priority Tag to Priority (VPT2P)
873
* 07:00 Priority0 The LSB priority bits for VLAN Priority[7:0]
874
* entries.
875
* 15:08 Priority1 The MSB priority bits for VLAN Priority[7:0]
876
* entries.
877
* 31:16 Reserved
878
879
#endif
/* _DEV_GTETHREG_H_ */
GTeth_desc
Definition:
GT64260ethreg.h:61
