40. Linker Sets¶
40.1. Introduction¶
Linker sets are a flexible means to create arrays of items out of a set of object files at link-time. For example its possible to define an item I of type T in object file A and an item J of type T in object file B to be a member of a linker set S. The linker will then collect these two items I and J and place them in consecutive memory locations, so that they can be accessed like a normal array defined in one object file. The size of a linker set is defined by its begin and end markers. A linker set may be empty. It should only contain items of the same type.
The following macros are provided to create, populate and use linker sets.
RTEMS_LINKER_SET_BEGIN - Designator of the linker set begin marker
RTEMS_LINKER_SET_END - Designator of the linker set end marker
RTEMS_LINKER_SET_SIZE - The linker set size in characters
RTEMS_LINKER_SET_ITEM_COUNT - The linker set item count
RTEMS_LINKER_SET_IS_EMPTY - Is the linker set empty?
RTEMS_LINKER_SET_FOREACH - Iterate through the linker set items
RTEMS_LINKER_ROSET_DECLARE - Declares a read-only linker set
RTEMS_LINKER_ROSET - Defines a read-only linker set
RTEMS_LINKER_ROSET_ITEM_DECLARE - Declares a read-only linker set item
RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE - Declares an ordered read-only linker set item
RTEMS_LINKER_ROSET_ITEM_REFERENCE - References a read-only linker set item
RTEMS_LINKER_ROSET_ITEM - Defines a read-only linker set item
RTEMS_LINKER_ROSET_ITEM_ORDERED - Defines an ordered read-only linker set item
RTEMS_LINKER_ROSET_CONTENT - Marks a declaration as a read-only linker set content
RTEMS_LINKER_RWSET_DECLARE - Declares a read-write linker set
RTEMS_LINKER_RWSET - Defines a read-write linker set
RTEMS_LINKER_RWSET_ITEM_DECLARE - Declares a read-write linker set item
RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE - Declares an ordered read-write linker set item
RTEMS_LINKER_RWSET_ITEM_REFERENCE - References a read-write linker set item
RTEMS_LINKER_RWSET_ITEM - Defines a read-write linker set item
RTEMS_LINKER_RWSET_ITEM_ORDERED - Defines an ordered read-write linker set item
RTEMS_LINKER_RWSET_CONTENT - Marks a declaration as a read-write linker set content
40.2. Background¶
Linker sets are used not only in RTEMS, but also for example in Linux, in FreeBSD, for the GNU C constructor extension and for global C++ constructors. They provide a space efficient and flexible means to initialize modules. A linker set consists of
dedicated input sections for the linker (e.g.
.ctorsand.ctors.*in the case of global constructors),a begin marker (e.g. provided by
crtbegin.o, andan end marker (e.g. provided by
ctrend.o).
A module may place a certain data item into the dedicated input section. The linker will collect all such data items in this section and creates a begin and end marker. The initialization code can then use the begin and end markers to find all the collected data items (e.g. pointers to initialization functions).
In the linker command file of the GNU linker we need the following output section descriptions.
/* To be placed in a read-only memory region */
.rtemsroset : {
KEEP (*(SORT(.rtemsroset.*)))
/* To be placed in a read-write memory region */
.rtemsrwset : {
KEEP (*(SORT(.rtemsrwset.*)))
The KEEP() ensures that a garbage collection by the linker will not discard
the content of this section. This would normally be the case since the linker
set items are not referenced directly. The SORT() directive sorts the
input sections lexicographically. Please note the lexicographical order of the
.begin, .content and .end section name parts in the RTEMS linker
sets macros which ensures that the position of the begin and end markers are
right.
So, what is the benefit of using linker sets to initialize modules? It can be
used to initialize and include only those RTEMS managers and other components
which are used by the application. For example, in case an application uses
message queues, it must call rtems_message_queue_create(). In the module
implementing this function, we can place a linker set item and register the
message queue handler constructor. Otherwise, in case the application does not
use message queues, there will be no reference to the
rtems_message_queue_create() function and the constructor is not
registered, thus nothing of the message queue handler will be in the final
executable.
For an example see test program sptests/splinkersets01.
40.3. Directives¶
40.3.1. RTEMS_LINKER_SET_BEGIN - Designator of the linker set begin marker¶
- CALLING SEQUENCE:
type *begin = RTEMS_LINKER_SET_BEGIN( set );
- DESCRIPTION:
This macro generates the designator of the begin marker of the linker set identified by
set. The item at the begin marker address is the first member of the linker set if it exists, e.g. the linker set is not empty. A linker set is empty, if and only if the begin and end markers have the same address.The
setparameter itself must be a valid C designator on which no macro expansion is performed. It uniquely identifies the linker set.- NOTE:
The compiler may try to be smart. In general it will not work to assign linker set begin and end addresses to pointer variables and treat them like ordinary pointers. The compiler may exploit the fact that actually two distinct objects are involved and use this to optimize. To avoid trouble use RTEMS_LINKER_SET_SIZE - The linker set size in characters, RTEMS_LINKER_SET_ITEM_COUNT - The linker set item count, RTEMS_LINKER_SET_IS_EMPTY - Is the linker set empty? and RTEMS_LINKER_SET_FOREACH - Iterate through the linker set items.
40.3.2. RTEMS_LINKER_SET_END - Designator of the linker set end marker¶
- CALLING SEQUENCE:
type *end = RTEMS_LINKER_SET_END( set );
- DESCRIPTION:
This macro generates the designator of the end marker of the linker set identified by
set. The item at the end marker address is not a member of the linker set. Thesetparameter itself must be a valid C designator on which no macro expansion is performed. It uniquely identifies the linker set.
40.3.3. RTEMS_LINKER_SET_SIZE - The linker set size in characters¶
- CALLING SEQUENCE:
size_t size = RTEMS_LINKER_SET_SIZE( set );
- DESCRIPTION:
This macro returns the size of the linker set identified by
setin characters. Thesetparameter itself must be a valid C designator on which no macro expansion is performed. It uniquely identifies the linker set.
40.3.4. RTEMS_LINKER_SET_ITEM_COUNT - The linker set item count¶
- CALLING SEQUENCE:
size_t item_count = RTEMS_LINKER_SET_ITEM_COUNT( set );
- DESCRIPTION:
This macro returns the item count of the linker set identified by
40.3.5. RTEMS_LINKER_SET_IS_EMPTY - Is the linker set empty?¶
- CALLING SEQUENCE:
bool is_empty = RTEMS_LINKER_SET_IS_EMPTY( set );
- DESCRIPTION:
This macro returns true if the linker set identified by
setis empty, otherwise returns false. Thesetparameter itself must be a valid C designator on which no macro expansion is performed. It uniquely identifies the linker set.
40.3.6. RTEMS_LINKER_SET_FOREACH - Iterate through the linker set items¶
- CALLING SEQUENCE:
RTEMS_LINKER_RWSET( myset, int ); int count( void ) { int *item; int n; n = 0; RTEMS_LINKER_SET_FOREACH( myset, item ) { n += *item; } return n; }
- DESCRIPTION:
This macro generates a for loop statement which iterates through each item of a linker set identified by
set. Thesetparameter itself must be a valid C designator on which no macro expansion is performed. It uniquely identifies the linker set. Theitemparameter must be a pointer to an item of the linker set. It iterates through all items of the linker set from begin to end.
40.3.7. RTEMS_LINKER_ROSET_DECLARE - Declares a read-only linker set¶
- CALLING SEQUENCE:
RTEMS_LINKER_ROSET_DECLARE( set, type );
- DESCRIPTION:
This macro generates declarations for the begin and end markers of a read-only linker set identified by
set. Thesetparameter itself must be a valid C designator on which no macro expansion is performed. It uniquely identifies the linker set. Thetypeparameter defines the type of the linker set items. The type must be the same for all macro invocations of a particular linker set.
40.3.8. RTEMS_LINKER_ROSET - Defines a read-only linker set¶
- CALLING SEQUENCE:
RTEMS_LINKER_ROSET( set, type );
- DESCRIPTION:
This macro generates definitions for the begin and end markers of a read-only linker set identified by
40.3.9. RTEMS_LINKER_ROSET_ITEM_DECLARE - Declares a read-only linker set item¶
- CALLING SEQUENCE:
RTEMS_LINKER_ROSET_ITEM_DECLARE( set, type, item );
- DESCRIPTION:
This macro generates a declaration of an item contained in the read-only linker set identified by
set. For a description of theset,type, anditemparameters see RTEMS_LINKER_ROSET_ITEM - Defines a read-only linker set item.
40.3.10. RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE - Declares an ordered read-only linker set item¶
- CALLING SEQUENCE:
RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE( set, type, item, order );
- DESCRIPTION:
This macro generates a declaration of an ordered item contained in the read-only linker set identified by
set. For a description of theset,type,item, andorderparameters see RTEMS_LINKER_ROSET_ITEM_ORDERED - Defines an ordered read-only linker set item.
40.3.11. RTEMS_LINKER_ROSET_ITEM_REFERENCE - References a read-only linker set item¶
- CALLING SEQUENCE:
RTEMS_LINKER_ROSET_ITEM_REFERENCE( set, type, item );
- DESCRIPTION:
This macro generates a reference to an item contained in the read-only linker set identified by
set. Thesetparameter itself must be a valid C designator on which no macro expansion is performed. It uniquely identifies the linker set. Thetypeparameter defines the type of the linker set items. The type must be the same for all macro invocations of a particular linker set. Theitemparameter itself must be a valid C designator on which no macro expansion is performed. It uniquely identifies an item in the linker set.
40.3.12. RTEMS_LINKER_ROSET_ITEM - Defines a read-only linker set item¶
- CALLING SEQUENCE:
RTEMS_LINKER_ROSET_ITEM( set, type, item );
- DESCRIPTION:
This macro generates a definition of an item contained in the read-only linker set identified by
40.3.13. RTEMS_LINKER_ROSET_ITEM_ORDERED - Defines an ordered read-only linker set item¶
- CALLING SEQUENCE:
RTEMS_LINKER_ROSET_ITEM_ORDERED( set, type, item, order );
- DESCRIPTION:
This macro generates a definition of an ordered item contained in the read-only linker set identified by
set. Thesetparameter itself must be a valid C designator on which no macro expansion is performed. It uniquely identifies the linker set. Thetypeparameter defines the type of the linker set items. The type must be the same for all macro invocations of a particular linker set. Theitemparameter itself must be a valid C designator on which no macro expansion is performed. It uniquely identifies an item in the linker set. Theorderparameter must be a valid linker input section name part on which macro expansion is performed. The items are lexicographically ordered according to theorderparameter within a linker set. Ordered items are placed before unordered items in the linker set.- NOTES:
To be resilient to typos in the order parameter, it is recommended to use the following construct in macros defining items for a particular linker set (see enum in
XYZ_ITEM()).#include <rtems/linkersets.h> typedef struct { int foo; } xyz_item; /* The XYZ-order defines */ #define XYZ_ORDER_FIRST 0x00001000 #define XYZ_ORDER_AND_SO_ON 0x00002000 /* Defines an ordered XYZ-item */ #define XYZ_ITEM( item, order ) \ enum { xyz_##item = order }; \ RTEMS_LINKER_ROSET_ITEM_ORDERED( \ xyz, const xyz_item *, item, order \ ) = { &item } /* Example item */ static const xyz_item some_item = { 123 }; XYZ_ITEM( some_item, XYZ_ORDER_FIRST );
40.3.14. RTEMS_LINKER_ROSET_CONTENT - Marks a declaration as a read-only linker set content¶
- CALLING SEQUENCE:
RTEMS_LINKER_ROSET_CONTENT( set, decl );
- DESCRIPTION:
This macro marks a declaration as a read-only linker set content. The linker set is identified by
set. Thesetparameter itself must be a valid C designator on which no macro expansion is performed. It uniquely identifies the linker set. Thedeclparameter must be an arbitrary variable declaration.
40.3.15. RTEMS_LINKER_RWSET_DECLARE - Declares a read-write linker set¶
- CALLING SEQUENCE:
RTEMS_LINKER_RWSET_DECLARE( set, type );
- DESCRIPTION:
This macro generates declarations for the begin and end markers of a read-write linker set identified by
40.3.16. RTEMS_LINKER_RWSET - Defines a read-write linker set¶
- CALLING SEQUENCE:
RTEMS_LINKER_RWSET( set, type );
- DESCRIPTION:
This macro generates definitions for the begin and end markers of a read-write linker set identified by
40.3.17. RTEMS_LINKER_RWSET_ITEM_DECLARE - Declares a read-write linker set item¶
- CALLING SEQUENCE:
RTEMS_LINKER_RWSET_ITEM_DECLARE( set, type, item );
- DESCRIPTION:
This macro generates a declaration of an item contained in the read-write linker set identified by
set. For a description of theset,type, anditemparameters see RTEMS_LINKER_RWSET_ITEM - Defines a read-write linker set item.
40.3.18. RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE - Declares an ordered read-write linker set item¶
- CALLING SEQUENCE:
RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE( set, type, item, order );
- DESCRIPTION:
This macro generates a declaration of an ordered item contained in the read-write linker set identified by
set. For a description of theset,type,item, andorderparameters see RTEMS_LINKER_RWSET_ITEM_ORDERED - Defines an ordered read-write linker set item.
40.3.19. RTEMS_LINKER_RWSET_ITEM_REFERENCE - References a read-write linker set item¶
- CALLING SEQUENCE:
RTEMS_LINKER_RWSET_ITEM_REFERENCE( set, type, item );
- DESCRIPTION:
This macro generates a reference to an item contained in the read-write linker set identified by
40.3.20. RTEMS_LINKER_RWSET_ITEM - Defines a read-write linker set item¶
- CALLING SEQUENCE:
RTEMS_LINKER_RWSET_ITEM( set, type, item );
- DESCRIPTION:
This macro generates a definition of an item contained in the read-write linker set identified by
40.3.21. RTEMS_LINKER_RWSET_ITEM_ORDERED - Defines an ordered read-write linker set item¶
- CALLING SEQUENCE:
RTEMS_LINKER_RWSET_ITEM_ORDERED( set, type, item, order );
- DESCRIPTION:
This macro generates a definition of an ordered item contained in the read-write linker set identified by
XYZ_ITEM()).#include <rtems/linkersets.h> typedef struct { int foo; } xyz_item; /* The XYZ-order defines */ #define XYZ_ORDER_FIRST 0x00001000 #define XYZ_ORDER_AND_SO_ON 0x00002000 /* Defines an ordered XYZ-item */ #define XYZ_ITEM( item, order ) \ enum { xyz_##item = order }; \ RTEMS_LINKER_RWSET_ITEM_ORDERED( \ xyz, const xyz_item *, item, order \ ) = { &item } /* Example item */ static const xyz_item some_item = { 123 }; XYZ_ITEM( some_item, XYZ_ORDER_FIRST );
40.3.22. RTEMS_LINKER_RWSET_CONTENT - Marks a declaration as a read-write linker set content¶
- CALLING SEQUENCE:
RTEMS_LINKER_RWSET_CONTENT( set, decl );
- DESCRIPTION:
This macro marks a declaration as a read-write linker set content. The linker set is identified by
