RTEMS 6.3
xqspipsu_flash_config.h File Reference
#include "xparameters.h"
#include "xqspipsu.h"
struct  FlashInfo
#define XQSPIPSU_FLASH_CONFIG_H_
#define WRITE_STATUS_CMD   0x01
#define WRITE_CMD   0x02
#define READ_CMD   0x03
#define WRITE_DISABLE_CMD   0x04
#define READ_STATUS_CMD   0x05
#define WRITE_ENABLE_CMD   0x06
#define VOLATILE_WRITE_ENABLE_CMD   0x50
#define QUAD_MODE_ENABLE_BIT   0x06
#define FAST_READ_CMD   0x0B
#define DUAL_READ_CMD   0x3B
#define QUAD_READ_CMD   0x6B
#define BULK_ERASE_CMD   0xC7
#define SEC_ERASE_CMD   0xD8
#define READ_ID   0x9F
#define READ_SFDP   0x5A
#define READ_CONFIG_CMD   0x35
#define WRITE_CONFIG_CMD   0x01
#define ENTER_4B_ADDR_MODE   0xB7
#define EXIT_4B_ADDR_MODE   0xE9
#define EXIT_4B_ADDR_MODE_ISSI   0x29
#define READ_CMD_4B   0x13
#define FAST_READ_CMD_4B   0x0C
#define DUAL_READ_CMD_4B   0x3C
#define QUAD_READ_CMD_4B   0x6C
#define WRITE_CMD_4B   0x12
#define SEC_ERASE_CMD_4B   0xDC
#define BANK_REG_RD   0x16
#define BANK_REG_WR   0x17
#define READ_ECCSR   0x18
#define EXTADD_REG_RD   0xC8
#define EXTADD_REG_WR   0xC5
#define DIE_ERASE_CMD   0xC4
#define READ_FLAG_STATUS_CMD   0x70
#define WRITE_STATUS_REG_2_CMD   0x31
#define READ_STATUS_REG_2_CMD   0x35
#define WB_QUAD_MODE_ENABLE_BIT   0x01
#define COMMAND_OFFSET   0
#define ADDRESS_1_OFFSET   1
#define ADDRESS_2_OFFSET   2
#define ADDRESS_3_OFFSET   3
#define ADDRESS_4_OFFSET   4
#define DATA_OFFSET   5
#define DUMMY_OFFSET   4
#define DUMMY_SIZE   1
#define DUMMY_CLOCKS   8
#define RD_ID_SIZE   4
#define BULK_ERASE_SIZE   1
#define SEC_ERASE_SIZE   4
#define BANK_SEL_SIZE   2
#define RD_CFG_SIZE   2
#define WR_CFG_SIZE   3
#define DIE_ERASE_SIZE   4
#define OVERHEAD_SIZE   4
#define FLASH1BASE   0x0000000
#define SIXTEENMB   0x1000000
#define FLASH_QUAD_EN_MASK   0x02
#define FLASH_SRWD_MASK   0x80
#define BANKMASK   0xF000000
#define BUSWIDTH_SINGLE   0
#define BUSWIDTH_DOUBLE   1
#define MICRON_ID_BYTE0   0x20
#define SPANSION_ID_BYTE0   0x01
#define WINBOND_ID_BYTE0   0xEF
#define MACRONIX_ID_BYTE0   0xC2
#define ISSI_ID_BYTE0   0x9D
FlashInfo Flash_Config_Table []
This file contains flash configuration table and flash related defines. This file should be included in the example files and compiled along with the examples (*.c).
Note
None.
  MODIFICATION HISTORY:
  Ver   Who Date     Changes
  1.12  akm 07/07/20 First release
  1.12  akm 07/07/20 Add support for Macronix flash(MX66U2G45G, MX66L2G45G)
                     and ISSI flash(IS25LP01G, IS25WP01G) parts.
  1.13  akm 12/10/20 Set Read command as per the qspi bus width.
  1.14  akm 07/16/21 Enable Quad Mode for Winbond flashes.
  1.15  akm 11/19/21 Fix read/write failures on Spansion flash parts.
