RTEMS
6.3
Toggle main menu visibility
bsps
include
dev
flash
xnandpsu_flashdev.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2025 On-Line Applications Research (OAR) Corporation
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS AS IS
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef XNANDPSU_FLASHDEV_H
37
#define XNANDPSU_FLASHDEV_H
38
39
dev/flash/flashdev.h
40
dev/nand/xnandpsu.h
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
45
57
rtems_flashdev
xnandpsu_flashdev_init
XNandPsu
*nandpsu );
58
59
#ifdef __cplusplus
60
61
#endif
62
63
#endif
/* XNANDPSU_FLASHDEV_H */
flashdev.h
Generic Flash API.
XNandPsu
Definition
xnandpsu.h:393
rtems_flashdev
Flash device.
Definition
flashdev.h:358
xnandpsu.h
rtems_flashdev * xnandpsu_flashdev_init(XNandPsu *nandpsu)
Initializes a flash device using Xilinx's xnandpsu flash driver.
Definition
xnandpsu_flashdev.c:445
