RTEMS 6.3
xilinx_zynqmp.h
1
6
7/*
8 * SPDX-License-Identifier: BSD-2-Clause
9 *
10 * Copyright (C) 2023 Reflex Aerospace GmbH
11 *
12 * Written by Philip Kirkpatrick <p.kirkpatrick@reflexaerospace.com>
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_SHARED_PERIPHERAL_MAPS_ZYNQMP
37#define LIBBSP_SHARED_PERIPHERAL_MAPS_ZYNQMP
38
39/* Data derived from https://docs.xilinx.com/r/en-US/ug1085-zynq-ultrascale-trm/PS-I/O-Peripherals-Registers */
40
41/* LPD IO Peripherals */
42#define ZYNQMP_UART0 (0xFF000000)
43#define ZYNQMP_UART1 (0xFF010000)
44#define ZYNQMP_I2C0 (0xFF020000)
45#define ZYNQMP_I2C1 (0xFF030000)
46#define ZYNQMP_SPI0 (0xFF040000)
47#define ZYNQMP_SPI1 (0xFF050000)
48#define ZYNQMP_CAN0 (0xFF060000)
49#define ZYNQMP_CAN1 (0xFF070000)
50#define ZYNQMP_GPIO (0xFF0A0000)
51#define ZYNQMP_GEM0 (0xFF0B0000)
52#define ZYNQMP_GEM1 (0xFF0C0000)
53#define ZYNQMP_GEM2 (0xFF0D0000)
54#define ZYNQMP_GEM3 (0xFF0E0000)
55#define ZYNQMP_QSPI (0xFF0F0000)
56#define ZYNQMP_NAND (0xFF100000)
57#define ZYNQMP_SD0 (0xFF160000)
58#define ZYNQMP_SD1 (0xFF170000)
59#define ZYNQMP_IPI_MSG (0xFF990000)
60#define ZYNQMP_USB0 (0xFF9D0000)
61#define ZYNQMP_USB1 (0xFF9E0000)
62#define ZYNQMP_AMS (0xFFA50000)
63#define ZYNQMP_PSSYSMON (0xFFA50800)
64#define ZYNQMP_PLSYSMON (0xFFA50C00)
65#define ZYNQMP_CSU_SWDT (0xFFCB0000)
66
67/* FPD IO Peripherals */
68#define ZYNQMP_SATA (0xFD0C0000)
69#define ZYNQMP_PCIE (0xFD0E0000)
70#define ZYNQMP_PCIE_IN (0xFD0E0800)
71#define ZYNQMP_PCIE_EG (0xFD0E0C00)
72#define ZYNQMP_PCIE_DMA (0xFD0F0000)
73#define ZYNQMP_SIOU (0xFD3D0000)
74#define ZYNQMP_GTR (0xFD400000)
75#define ZYNQMP_PCIE_ATTR (0xFD480000)
76#define ZYNQMP_DP (0xFD4A0000)
77#define ZYNQMP_GPU (0xFD4B0000)
78#define ZYNQMP_DP_DMA (0xFD4C0000)
79
80/* LPD System Registers */
81#define ZYNQMP_IPI (0xFF300000)
82#define ZYNQMP_TTC0 (0xFF110000)
83#define ZYNQMP_TTC1 (0xFF120000)
84#define ZYNQMP_TTC2 (0xFF130000)
85#define ZYNQMP_TTC3 (0xFF140000)
86#define ZYNQMP_LPD_SWDT (0xFF150000)
87#define ZYNQMP_XPPU (0xFF980000)
88#define ZYNQMP_XPPU_SINK (0xFF9C0000)
89#define ZYNQMP_PL_LPD (0xFF9B0000)
90#define ZYNQMP_OCM (0xFFA00000)
91#define ZYNQMP_LPD_FPD (0xFFA10000)
92#define ZYNQMP_RTC (0xFFA60000)
93#define ZYNQMP_OCM_XMPU (0xFFA70000)
94#define ZYNQMP_LPD_DMA (0xFFA80000)
95#define ZYNQMP_CSU_DMA (0xFFC80000)
96#define ZYNQMP_CSU (0xFFCA0000)
97#define ZYNQMP_BBRAM (0xFFCD0000)
98
99/* System Interrupt Table */
100
101/* SPIs */
102#define ZYNQMP_IRQ_UART_0 53
103#define ZYNQMP_IRQ_UART_1 54
104
105#define ZYNQMP_IRQ_TTC_0_0 68
106#define ZYNQMP_IRQ_TTC_0_1 69
107#define ZYNQMP_IRQ_TTC_0_2 70
108#define ZYNQMP_IRQ_TTC_1_0 71
109#define ZYNQMP_IRQ_TTC_1_1 72
110#define ZYNQMP_IRQ_TTC_1_2 73
111#define ZYNQMP_IRQ_TTC_2_0 74
112#define ZYNQMP_IRQ_TTC_2_1 75
113#define ZYNQMP_IRQ_TTC_2_2 76
114#define ZYNQMP_IRQ_TTC_3_0 77
115#define ZYNQMP_IRQ_TTC_3_1 78
116#define ZYNQMP_IRQ_TTC_3_2 79
117
118#endif /* LIBBSP_SHARED_PERIPHERAL_MAPS_ZYNQMP */
