RTEMS
6.3
Toggle main menu visibility
include
dev
i2c
xilinx-axi-i2c.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* Copyright (c) 2016-2017 Chris Johns <chrisj@rtems.org> All rights reserved.
5
6
7
* modification, are permitted provided that the following conditions
8
* are met:
9
* 1. Redistributions of source code must retain the above copyright
10
* notice, this list of conditions and the following disclaimer.
11
* 2. Redistributions in binary form must reproduce the above copyright
12
* notice, this list of conditions and the following disclaimer in the
13
* documentation and/or other materials provided with the distribution.
14
15
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25
* POSSIBILITY OF SUCH DAMAGE.
26
27
28
29
* Xilinx AXI IIC Interface v2.0. See PG090.pdf.
30
31
* Note, only master support is provided and no dynamic mode by design.
32
33
* The clock set up is to be handled by the IP integrator. There are too many
34
* factors handling this in software.
35
36
37
38
#ifndef XILINX_AXI_I2C_H
39
#define XILINX_AXI_I2C_H
40
41
dev/i2c/i2c.h
42
43
44
* The PL integrator controls the timing. This interface allows software to
45
* override those settings. It pays to check the timing with ChipScope.
46
47
* If you set the AXI bus frequency you can use the clock speed ioctl call to
48
* change the speed dymanically. The ioctl call overrides the defaults passed
49
* in.
50
51
* Set the valid mask to the values that are to be set.
52
53
#define XILINX_AIX_I2C_AXI_CLOCK (1 << 0)
54
#define XILINX_AIX_I2C_TSUSTA (1 << 1)
55
#define XILINX_AIX_I2C_TSUSTO (1 << 2)
56
#define XILINX_AIX_I2C_THDSTA (1 << 3)
57
#define XILINX_AIX_I2C_TSUDAT (1 << 4)
58
#define XILINX_AIX_I2C_TBUF (1 << 5)
59
#define XILINX_AIX_I2C_THIGH (1 << 6)
60
#define XILINX_AIX_I2C_TLOW (1 << 7)
61
#define XILINX_AIX_I2C_THDDAT (1 << 8)
62
#define XILINX_AIX_I2C_ALL_REGS (XILINX_AIX_I2C_TSUSTA | \
63
XILINX_AIX_I2C_TSUSTO | \
64
XILINX_AIX_I2C_THDSTA | \
65
XILINX_AIX_I2C_TSUDAT | \
66
XILINX_AIX_I2C_TBUF | \
67
XILINX_AIX_I2C_THIGH | \
68
XILINX_AIX_I2C_TLOW | \
69
XILINX_AIX_I2C_THDDAT)
70
typedef
struct
71
72
uint32_t valid_mask;
73
uint32_t AXI_CLOCK;
74
uint32_t SCL_INERTIAL_DELAY;
75
uint32_t TSUSTA;
76
uint32_t TSUSTO;
77
uint32_t THDSTA;
78
uint32_t TSUDAT;
79
uint32_t TBUF;
80
uint32_t THIGH;
81
uint32_t TLOW;
82
uint32_t THDDAT;
83
xilinx_aix_i2c_timing
84
85
86
* Register the driver.
87
88
* The driver can multipex a number of I2C buses (in master mode only) using
89
* the GPO port. The PL designer can use the output pins to select a bus. This
90
* is useful if connecting a number of slave devices that have limit selectable
91
* addresses.
92
93
* @param bus_path The driver's device path.
94
* @param register_base AXI base address.
95
* @param irq AXI FPGA interrupt.
96
* @param gpio_address Bits 12:15 of a slave address it written to the GPO.
97
* @param timing Override the default timing. NULL means no changes.
98
99
int
i2c_bus_register_xilinx_aix_i2c(
const
char
* bus_path,
100
uintptr_t register_base,
101
rtems_vector_number
irq,
102
bool
ten_gpio,
103
const
* timing);
104
105
#endif
i2c.h
Inter-Integrated Circuit (I2C) Driver API.
rtems_vector_number
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition
intr.h:102
Definition
xilinx-axi-i2c.h:71
