78#include <../../../../utils/utility.h>
91#define XDMAC_CONTROLLER_NUM 1
93#define XDMAC_CHANNEL_NUM 24
95#define XDMAC_MAX_BT_SIZE 0xFFFF
101#define XDMA_GET_DATASIZE(size) ((size==0)? XDMAC_CC_DWIDTH_BYTE : \
102 ((size==1)? XDMAC_CC_DWIDTH_HALFWORD : \
103 (XDMAC_CC_DWIDTH_WORD)))
104#define XDMA_GET_CC_SAM(s) ((s==0)? XDMAC_CC_SAM_FIXED_AM : \
105 ((s==1)? XDMAC_CC_SAM_INCREMENTED_AM : \
106 ((s==2)? XDMAC_CC_SAM_UBS_AM : \
107 XDMAC_CC_SAM_UBS_DS_AM)))
108#define XDMA_GET_CC_DAM(d) ((d==0)? XDMAC_CC_DAM_FIXED_AM : \
109 ((d==1)? XDMAC_CC_DAM_INCREMENTED_AM : \
110 ((d==2)? XDMAC_CC_DAM_UBS_AM : \
111 XDMAC_CC_DAM_UBS_DS_AM)))
112#define XDMA_GET_CC_MEMSET(m) ((m==0)? XDMAC_CC_MEMSET_NORMAL_MODE : \
113 XDMAC_CC_MEMSET_HW_MODE)
131static inline uint32_t XDMAC_GetType(
Xdmac *pXdmac)
142static inline uint32_t XDMAC_GetConfig(
Xdmac *pXdmac)
153static inline uint32_t XDMAC_GetArbiter(
Xdmac *pXdmac)
165static inline void XDMAC_EnableGIt (
Xdmac *pXdmac, uint8_t dwInteruptMask)
168 pXdmac->
XDMAC_GIE = (XDMAC_GIE_IE0 << dwInteruptMask);
177static inline void XDMAC_DisableGIt (
180 pXdmac->
XDMAC_GID = (XDMAC_GID_ID0 << dwInteruptMask);
188static inline uint32_t XDMAC_GetGItMask(
Xdmac *pXdmac)
199static inline uint32_t XDMAC_GetGIsr(
Xdmac *pXdmac)
210static inline uint32_t XDMAC_GetMaskedGIsr(
Xdmac *pXdmac)
225static inline void XDMAC_EnableChannel(
Xdmac *pXdmac, uint8_t channel)
229 pXdmac->
XDMAC_GE = (XDMAC_GE_EN0 << channel);
238static inline void XDMAC_EnableChannels(
Xdmac *pXdmac, uint32_t bmChannels)
250static inline void XDMAC_DisableChannel(
254 pXdmac->
XDMAC_GD = (XDMAC_GD_DI0 << channel);
263static inline void XDMAC_DisableChannels(
277static inline uint32_t XDMAC_GetGlobalChStatus(
Xdmac *pXdmac)
289static inline void XDMAC_SuspendReadChannel(
293 pXdmac->
XDMAC_GRS |= XDMAC_GRS_RS0 << channel;
302static inline void XDMAC_SuspendWriteChannel(
306 pXdmac->
XDMAC_GWS |= XDMAC_GWS_WS0 << channel;
315static inline void XDMAC_SuspendReadWriteChannel(
319 pXdmac->
XDMAC_GRWS = (XDMAC_GRWS_RWS0 << channel);
328static inline void XDMAC_ResumeReadWriteChannel(
332 pXdmac->
XDMAC_GRWR = (XDMAC_GRWR_RWR0 << channel);
341static inline void XDMAC_SoftwareTransferReq(
346 pXdmac->
XDMAC_GSWR = (XDMAC_GSWR_SWREQ0 << channel);
354static inline uint32_t XDMAC_GetSoftwareTransferStatus(
Xdmac *pXdmac)
367static inline uint32_t XDMAC_GetChannelIsr (
381static inline void XDMAC_SoftwareFlushReq(
385 pXdmac->
XDMAC_GSWF = (XDMAC_GSWF_SWF0 << channel);
387 while (!(XDMAC_GetChannelIsr(pXdmac, channel) & XDMAC_CIS_FIS));
397static inline void XDMAC_EnableChannelIt (
Xdmac *pXdmac, uint8_t channel,
398 uint8_t dwInteruptMask)
412static inline void XDMAC_DisableChannelIt (
413 uint8_t dwInteruptMask)
426static inline uint32_t XDMAC_GetChannelItMask (
439static inline uint32_t XDMAC_GetMaskChannelIsr (
457static inline void XDMAC_SetSourceAddr(
Xdmac *pXdmac, uint8_t channel, uint32_t addr)
471static inline void XDMAC_SetDestinationAddr(
487static inline void XDMAC_SetDescriptorAddr(
488 uint32_t addr, uint8_t ndaif)
504static inline void XDMAC_SetDescriptorControl(
Xdmac *pXdmac, uint8_t channel, uint8_t config)
518static inline void XDMAC_SetMicroblockControl(
Xdmac *pXdmac, uint8_t channel, uint32_t ublen)
532static inline void XDMAC_SetBlockControl(
Xdmac *pXdmac, uint8_t channel, uint16_t blen)
546static inline void XDMAC_SetChannelConfig(
Xdmac *pXdmac, uint8_t channel, uint32_t config)
559static inline uint32_t XDMAC_GetChannelConfig(
573static inline void XDMAC_SetDataStride_MemPattern(
589static inline void XDMAC_SetSourceMicroBlockStride(
604static inline void XDMAC_SetDestinationMicroBlockStride(
618static inline uint32_t XDMAC_GetChDestinationAddr(
625static inline void XDMAC_StartTransfer(
629 pXdmac->
630 pXdmac->
XDMAC_GIE = (XDMAC_GIE_IE0 << channel);
This header file provides the interfaces of the Assert Handler.
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG and static analysis runs.
Definition assert.h:96
Definition xdmac.h:93
__IO uint32_t XDMAC_CDS_MSP
(XdmacChid Offset: 0x2C) Channel Data Stride Memory Set Pattern
Definition component_xdmac.h:53
__O uint32_t XDMAC_CID
(XdmacChid Offset: 0x4) Channel Interrupt Disable Register
Definition component_xdmac.h:43
__IO uint32_t XDMAC_CC
(XdmacChid Offset: 0x28) Channel Configuration Register
Definition component_xdmac.h:52
__O uint32_t XDMAC_CIE
(XdmacChid Offset: 0x0) Channel Interrupt Enable Register
Definition component_xdmac.h:42
__I uint32_t XDMAC_CIS
(XdmacChid Offset: 0xC) Channel Interrupt Status Register
Definition component_xdmac.h:45
__O uint32_t XDMAC_CIM
(XdmacChid Offset: 0x8) Channel Interrupt Mask Register
Definition component_xdmac.h:44
__IO uint32_t XDMAC_CUBC
(XdmacChid Offset: 0x20) Channel Microblock Control Register
Definition component_xdmac.h:50
__IO uint32_t XDMAC_CSUS
(XdmacChid Offset: 0x30) Channel Source Microblock Stride
Definition component_xdmac.h:54
__IO uint32_t XDMAC_CBC
(XdmacChid Offset: 0x24) Channel Block Control Register
Definition component_xdmac.h:51
__IO uint32_t XDMAC_CDUS
(XdmacChid Offset: 0x34) Channel Destination Microblock Stride
Definition component_xdmac.h:55
__IO uint32_t XDMAC_CNDC
(XdmacChid Offset: 0x1C) Channel Next Descriptor Control Register
Definition component_xdmac.h:49
__IO uint32_t XDMAC_CDA
(XdmacChid Offset: 0x14) Channel Destination Address Register
Definition component_xdmac.h:47
__IO uint32_t XDMAC_CSA
(XdmacChid Offset: 0x10) Channel Source Address Register
Definition component_xdmac.h:46
__IO uint32_t XDMAC_CNDA
(XdmacChid Offset: 0x18) Channel Next Descriptor Address Register
Definition component_xdmac.h:48
Definition component_xdmac.h:60
__IO uint32_t XDMAC_GWS
(Xdmac Offset: 0x2C) Global Channel Write Suspend Register
Definition component_xdmac.h:72
__O uint32_t XDMAC_GSWF
(Xdmac Offset: 0x40) Global Channel Software Flush Request Register
Definition component_xdmac.h:77
__I uint32_t XDMAC_GIM
(Xdmac Offset: 0x14) Global Interrupt Mask Register
Definition component_xdmac.h:66
__O uint32_t XDMAC_GIE
(Xdmac Offset: 0x0C) Global Interrupt Enable Register
Definition component_xdmac.h:64
XdmacChid XDMAC_CHID[XDMACCHID_NUMBER]
(Xdmac Offset: 0x50) chid = 0 .. 23
Definition component_xdmac.h:79
__I uint32_t XDMAC_GSWS
(Xdmac Offset: 0x3C) Global Channel Software Request Status Register
Definition component_xdmac.h:76
__O uint32_t XDMAC_GD
(Xdmac Offset: 0x20) Global Channel Disable Register
Definition component_xdmac.h:69
__O uint32_t XDMAC_GRWS
(Xdmac Offset: 0x30) Global Channel Read Write Suspend Register
Definition component_xdmac.h:73
__O uint32_t XDMAC_GID
(Xdmac Offset: 0x10) Global Interrupt Disable Register
Definition component_xdmac.h:65
__O uint32_t XDMAC_GE
(Xdmac Offset: 0x1C) Global Channel Enable Register
Definition component_xdmac.h:68
__IO uint32_t XDMAC_GTYPE
(Xdmac Offset: 0x00) Global Type Register
Definition component_xdmac.h:61
__O uint32_t XDMAC_GSWR
(Xdmac Offset: 0x38) Global Channel Software Request Register
Definition component_xdmac.h:75
__O uint32_t XDMAC_GRWR
(Xdmac Offset: 0x34) Global Channel Read Write Resume Register
Definition component_xdmac.h:74
__IO uint32_t XDMAC_GRS
(Xdmac Offset: 0x28) Global Channel Read Suspend Register
Definition component_xdmac.h:71
(Xdmac Offset: 0x24) Global Channel Status Register
Definition component_xdmac.h:70
__I uint32_t XDMAC_GCFG
(Xdmac Offset: 0x04) Global Configuration Register
Definition component_xdmac.h:62
__I uint32_t XDMAC_GIS
(Xdmac Offset: 0x18) Global Interrupt Status Register
Definition component_xdmac.h:67
__IO uint32_t XDMAC_GWAC
(Xdmac Offset: 0x08) Global Weighted Arbiter Configuration Register
Definition component_xdmac.h:63
