RTEMS 6.3
xdma_hardware_interface.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _XDMAD_IF_H
31#define _XDMAD_IF_H
32
33/*----------------------------------------------------------------------------
34 * Includes
35 *----------------------------------------------------------------------------*/
36
37#include "chip.h"
38/*----------------------------------------------------------------------------
39 * Types
40 *----------------------------------------------------------------------------*/
41
43typedef struct _XdmaHardwareInterface {
44 uint8_t bXdmac;
45 uint32_t bPeriphID;
46 uint8_t bTransfer;
47 uint8_t bIfID;
48} XdmaHardwareInterface;
49
50/*----------------------------------------------------------------------------
51 * Exported functions
52 *----------------------------------------------------------------------------*/
53
54extern uint8_t XDMAIF_IsValidatedPeripherOnDma(uint8_t bPeriphID);
55extern uint8_t XDMAIF_Get_ChannelNumber (uint8_t bPeriphID, uint8_t bTransfer);
56
57#endif //#ifndef _XDMAD_IF_H
58
Definition xdma_hardware_interface.h:43
uint8_t bXdmac
Definition xdma_hardware_interface.h:44
uint8_t bTransfer
Definition xdma_hardware_interface.h:46
uint32_t bPeriphID
Definition xdma_hardware_interface.h:45
uint8_t bIfID
Definition xdma_hardware_interface.h:47
uint8_t XDMAIF_Get_ChannelNumber(uint8_t bPeriphID, uint8_t bTransfer)
Get peripheral identifier coded for hardware handshaking interface.
Definition xdma_hardware_interface.c:119
Check if the given DMAC has associated peripheral identifier coded by the given peripheral.
Definition xdma_hardware_interface.c:143
