RTEMS
6.3
Toggle main menu visibility
score
cpu
x86_64
include
score
x86_64.h
1
2
* Copyright (c) 2018 Amaan Cheval <amaan.cheval@gmail.com>
3
4
5
* modification, are permitted provided that the following conditions
6
* are met:
7
* 1. Redistributions of source code must retain the above copyright
8
* notice, this list of conditions and the following disclaimer.
9
* 2. Redistributions in binary form must reproduce the above copyright
10
* notice, this list of conditions and the following disclaimer in the
11
* documentation and/or other materials provided with the distribution.
12
13
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
14
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
15
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
16
* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
17
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
18
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
19
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
20
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
21
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
22
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
23
* SUCH DAMAGE.
24
25
26
#ifndef _RTEMS_SCORE_X86_64_H
27
#define _RTEMS_SCORE_X86_64_H
28
29
#ifdef __cplusplus
30
extern
"C"
31
#endif
32
33
#define CPU_NAME "x86-64"
34
#define CPU_MODEL_NAME "amd64"
35
36
#define COM1_BASE_IO 0x3F8
37
#define COM1_CLOCK_RATE (115200 * 16)
38
39
#define EFLAGS_INTR_ENABLE 0x200
40
41
#define FSBASE_MSR 0xC0000100
42
43
#if DEBUG
44
#define DBG_PRINTF(format, args...) \
45
printf(format, ## args)
46
#else
47
48
#endif
49
50
#ifdef __cplusplus
51
52
#endif
53
54
#endif
/* _RTEMS_SCORE_X86_64_H */
