RTEMS 6.3
wdt.h File Reference
#include "chip.h"
#include <stdint.h>
void WDT_Enable (Wdt *pWDT, uint32_t dwMode)
 Enable watchdog with given mode.
void WDT_Disable (Wdt *pWDT)
 Disable watchdog.
void WDT_Restart (Wdt *pWDT)
 Watchdog restart.
uint32_t WDT_GetStatus (Wdt *pWDT)
 Watchdog get status.
uint32_t WDT_GetPeriod (uint32_t dwMs)
 Watchdog get period.
Purpose
Interface for Watchdog Timer (WDT) controller.
Usage
  1. Enable watchdog with given mode using WDT_Enable().
  2. Disable watchdog using WDT_Disable()
  3. Restart the watchdog using WDT_Restart().
  4. Get watchdog status using WDT_GetStatus().
  5. Calculate watchdog period value using WDT_GetPeriod().
◆ WDT_Disable()
void WDT_Disable ( Wdt * pWDT)
extern
Disable watchdog.
Note
The Watchdog Mode Register (WDT_MR) can be written only once. Only a processor reset resets it.
◆ WDT_Enable()
void WDT_Enable ( Wdt * pWDT,
uint32_t dwMode )
extern
Note
Parameters
dwModeWDT mode to be set
◆ WDT_GetPeriod()
uint32_t WDT_GetPeriod ( uint32_t dwMs)
extern
Parameters
dwMsdesired watchdog period in millisecond.
