RTEMS 6.3
tx4938.h File Reference
#define TX4938_REG_BASE   0xFF1F0000
#define TX4938_PCI1_PCIID   0x7000
#define TX4938_PCI1_PCISTATUS   0x7004
#define TX4938_PCI1_PCICFG1   0x700c
#define TX4938_PCI1_P2GM1PLBASE   0x7018
#define TX4938_PCI1_P2GCFG   0x7090
#define TX4938_PCI1_PBAREQPORT   0x7100
#define TX4938_PCI1_PBACFG   0x7104
#define TX4938_PCI1_G2PM0GBASE   0x7120
#define TX4938_PCI1_G2PIOGBASE   0x7138
#define TX4938_PCI1_G2PM0MASK   0x7140
#define TX4938_PCI1_G2PIOMASK   0x714c
#define TX4938_PCI1_G2PM0PBASE   0x7150
#define TX4938_PCI1_G2PIOPBASE   0x7168
#define TX4938_PCI1_PCICCFG   0x7170
#define TX4938_PCI1_PCICSTATUS   0x7174
#define TX4938_PCI1_P2GM1GBASE   0x7188
#define TX4938_PCI1_G2PCFGADRS   0x71a0
#define TX4938_PCI1_G2PCFGDATA   0x71a4
#define TX4938_CFG_CCFG   0xE000
#define TX4938_CFG_REVID   0xE008
#define TX4938_CFG_PCFG   0xE010
#define TX4938_CFG_TOEA   0xE018
#define TX4938_CFG_CLKCTR   0xE020
#define TX4938_CFG_GARBC   0xE030
#define TX4938_CFG_RAMP   0xE048
#define SELCHI   0x00100000
#define SELTMR0   0x00000200
#define TX4938_TIMER0_BASE   0xF000
#define TX4938_TIMER1_BASE   0xF100
#define TX4938_TIMER2_BASE   0xF200
#define TX4938_TIMER_TCR   0x00
#define TX4938_TIMER_TISR   0x04
#define TX4938_TIMER_CPRA   0x08
#define TX4938_TIMER_CPRB   0x0C
#define TX4938_TIMER_ITMR   0x10
#define TX4938_TIMER_CCDR   0x20
#define TX4938_TIMER_PGMR   0x30
#define TX4938_TIMER_WTMR   0x40
#define TX4938_TIMER_TRR   0xF0
#define TIMER_CLEAR_ENABLE_MASK   0x1
#define TIMER_INT_ENABLE_MASK   0x8000
#define FFI   0x1
#define TPIAE   0x4000
#define TPIBE   0x8000
#define TIIS   0x1
#define TPIAS   0x2
#define TPIBS   0x4
#define TWIS   0x8
#define TX4938_IRQCTL_DEN   0xF600
#define TX4938_IRQCTL_DM0   0xF604
#define TX4938_IRQCTL_DM1   0xF608
#define TX4938_IRQCTL_LVL0   0xF610
#define TX4938_IRQCTL_LVL1   0xF614
#define TX4938_IRQCTL_LVL2   0xF618
#define TX4938_IRQCTL_LVL3   0xF61C
#define TX4938_IRQCTL_LVL4   0xF620
#define TX4938_IRQCTL_LVL5   0xF624
#define TX4938_IRQCTL_LVL6   0xF628
#define TX4938_IRQCTL_LVL7   0xF62C
#define TX4938_IRQCTL_MSK   0xF640
#define TX4938_IRQCTL_EDC   0xF660
#define TX4938_IRQCTL_PND   0xF680
#define TX4938_IRQCTL_CS   0xF6A0
#define TX4938_IRQCTL_FLAG0   0xF510
#define TX4938_IRQCTL_FLAG1   0xF514
#define TX4938_IRQCTL_POL   0xF518
#define TX4938_IRQCTL_RCNT   0xF51C
#define TX4938_IRQCTL_MASKINT   0xF520
#define TX4938_IRQCTL_MASKEXT   0xF524
#define TX4938_REG_READ(_base, _register)
#define TX4938_REG_WRITE(_base, _register, _value)
#define TX4938_CCFG_SYSSP_SHF   6
#define TX4938_CCFG_SYSSP_MSK   (MSK(2) << TX4938_CCFG_SYSSP_SHF)
#define TX4938_CCFG_PCI1DMD_SHF   8
#define TX4938_CCFG_PCI1DMD_MSK   (MSK(1) << TX4938_CCFG_PCI1DMD_SHF)
#define TX4938_CCFG_PCIDIVMODE_SHF   10
#define TX4938_CCFG_PCIDIVMODE_MSK   (MSK(3) << TX4938_CCFG_PCIDIVMODE_SHF)
#define TX4938_CCFG_PCI166_SHF   21
#define TX4938_CCFG_PCI166_MSK   ((UINT64)MSK(1) << TX4938_CCFG_PCI166_SHF)
#define TX4938_CCFG_PCIMODE_SHF   22
#define TX4938_CCFG_PCIMODE_MSK   ((UINT64)MSK(1) << TX4938_CCFG_PCIMODE_SHF)
#define TX4938_CCFG_BRDTY_SHF   36
#define TX4938_CCFG_RRDTY_MSK   ((UINT64)MSK(4) << TX4938_CCFG_BRDTY_SHF)
#define TX4938_CCFG_BRDRV_SHF   32
#define TX4938_CCFG_BRDRV_MSK   ((UINT64)MSK(4) << TX4938_CCFG_BRDRV_SHF)
#define TX4938_CLKCTR_PCIC1RST_SHF   11
#define TX4938_CLKCTR_PCIC1RST_MSK   (MSK(1) << TX4938_CLKCTR_PCIC1RST_SHF)
#define TX4938_PCI_PCISTATUS_MEMSP_SHF   1
#define TX4938_PCI_PCISTATUS_MEMSP_MSK   (MSK(1) << TX4938_PCI_PCISTATUS_MEMSP_SHF)
#define TX4938_PCI_PCISTATUS_BM_SHF   2
#define TX4938_PCI_PCISTATUS_BM_MSK   (MSK(1) << TX4938_PCI_PCISTATUS_BM_SHF)
#define TX4938_PCI_PBACFG_RPBA_SHF   2
#define TX4938_PCI_PBACFG_RPBA_MSK   (MSK(1) << TX4938_PCI_PBACFG_RPBA_SHF)
#define TX4938_PCI_PBACFG_PBAEN_SHF   1
#define TX4938_PCI_PBACFG_PBAEN_MSK   (MSK(1) << TX4938_PCI_PBACFG_PBAEN_SHF)
#define TX4938_PCI_PCICFG_G2PM0EN_SHF   6
#define TX4938_PCI_PCICFG_G2PM0EN_MSK   (MSK(1) << TX4938_PCI_PCICFG_G2PM0EN_SHF)
#define TX4938_PCI_PCICFG_G2PIOEN_SHF   5
#define TX4938_PCI_PCICFG_G2PIOEN_MSK   (MSK(1) << TX4938_PCI_PCICFG_G2PIOEN_SHF)
#define TX4938_PCI_PCICFG_TCAR_SHF   4
#define TX4938_PCI_PCICFG_TCAR_MSK   (MSK(1) << TX4938_PCI_PCICFG_TCAR_SHF)
MIPS Tx4938 specific information
◆ TX4938_REG_READ
#define TX4938_REG_READ ( _base,
_register )
Value:
*((volatile uint32_t *)((_base) + (_register)))
◆ TX4938_REG_WRITE
#define TX4938_REG_WRITE ( _base,
_register,
_value )
Value:
*((volatile uint32_t *)((_base) + (_register))) = (_value)
