RTEMS 6.3
#include <rtems/bspIo.h>
#include <rtems/test-info.h>
#include <rtems/test.h>
#include <rtems/testopts.h>
#include <rtems/score/smpimpl.h>
#include "ts-config.h"
#include "tx-support.h"
#include <rtems/confdefs.h>
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS   0
#define CONFIGURE_MAXIMUM_USER_EXTENSIONS   1
#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
#define CONFIGURE_IDLE_TASK_STORAGE_SIZE   RTEMS_MINIMUM_STACK_SIZE
#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
#define CONFIGURE_IDLE_TASK_BODY   ShutdownIdleBody
#define CONFIGURE_INITIAL_EXTENSIONS   { .fatal = FatalInitialExtension }
void __real_bsp_reset (rtems_fatal_source source, rtems_fatal_code code)
void __wrap_bsp_reset (rtems_fatal_source source, rtems_fatal_code code)
void * __real__CPU_Thread_Idle_body (void *arg)
void * __wrap__CPU_Thread_Idle_body (void *arg)
const char rtems_test_name [] = "TestsuitesBspsFatalExtension"
 Each test must define a test name string.
