RTEMS 6.3
ts-config.h File Reference
This header file provides the constants used by the test suite configuration. More...
#define TEST_MICROSECONDS_PER_TICK   1000
#define TEST_RUNNER_NAME   rtems_build_name( 'R', 'U', 'N', ' ' )
#define TEST_RUNNER_ARGUMENT   123456789
#define TEST_RUNNER_INITIAL_MODES   RTEMS_NO_ASR
#define TEST_SCHEDULER_A_NAME   rtems_build_name( 'A', ' ', ' ', ' ' )
#define TEST_SCHEDULER_B_NAME   rtems_build_name( 'B', ' ', ' ', ' ' )
#define TEST_SCHEDULER_C_NAME   rtems_build_name( 'C', ' ', ' ', ' ' )
#define TEST_SCHEDULER_D_NAME   rtems_build_name( 'D', ' ', ' ', ' ' )
#define TEST_BASE_STACK_SIZE   ( 4 * RTEMS_MINIMUM_STACK_SIZE )
#define TEST_MAXIMUM_TLS_SIZE   RTEMS_ALIGN_UP( 64, RTEMS_TASK_STORAGE_ALIGNMENT )
#define TEST_MINIMUM_STACK_SIZE   ( TEST_BASE_STACK_SIZE + CPU_STACK_ALIGNMENT )
#define TEST_IDLE_STACK_SIZE   ( TEST_BASE_STACK_SIZE + 2 * CPU_STACK_ALIGNMENT )
#define TEST_INTERRUPT_STACK_SIZE   ( TEST_BASE_STACK_SIZE + 4 * CPU_INTERRUPT_STACK_ALIGNMENT )
#define TEST_MAXIMUM_BARRIERS   7
#define TEST_MAXIMUM_MESSAGE_QUEUES   3
#define TEST_MAXIMUM_PARTITIONS   4
#define TEST_MAXIMUM_PERIODS   2
#define TEST_MAXIMUM_SEMAPHORES   7
#define TEST_MAXIMUM_TASKS   32
#define TEST_MAXIMUM_TIMERS   10
#define TEST_MAXIMUM_USER_EXTENSIONS   5
#define TEST_TICKS_PER_TIMESLICE   2
void * test_task_stack_allocate (size_t size)
void test_task_stack_deallocate (void *stack)
void * test_idle_task_stack_allocate (uint32_t cpu_index, size_t *size)
rtems_task_argument test_runner_argument
rtems_task_priority test_runner_initial_priority
rtems_mode test_runner_initial_modes
