RTEMS
6.3
Toggle main menu visibility
testsuites
validation
tr-fatal-boot-processor-not-assigned-to-scheduler.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
8
9
10
* Copyright (C) 2021 embedded brains GmbH & Co. KG
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
35
* This file is part of the RTEMS quality process and was automatically
36
* generated. If you find something that needs to be fixed or
37
* worded better please post a report or patch to an RTEMS mailing list
38
* or raise a bug report:
39
40
* https://www.rtems.org/bugs.html
41
42
* For information on updating and regenerating please refer to the How-To
43
* section in the Software Requirements Engineering chapter of the
44
* RTEMS Software Engineering manual. The manual is provided as a part of
45
* a release. For development sources please refer to the online
46
* documentation at:
47
48
* https://docs.rtems.org
49
50
51
#ifndef _TR_FATAL_BOOT_PROCESSOR_NOT_ASSIGNED_TO_SCHEDULER_H
52
#define _TR_FATAL_BOOT_PROCESSOR_NOT_ASSIGNED_TO_SCHEDULER_H
53
54
rtems.h
55
56
#ifdef __cplusplus
57
extern
"C"
58
#endif
59
65
73
void
ScoreSmpValFatalBootProcessorNotAssignedToScheduler_Run
74
rtems_fatal_source
source,
75
rtems_fatal_code
code
76
77
79
80
#ifdef __cplusplus
81
82
#endif
83
84
#endif
/* _TR_FATAL_BOOT_PROCESSOR_NOT_ASSIGNED_TO_SCHEDULER_H */
rtems_fatal_code
Internal_errors_t rtems_fatal_code
This integer type represents system termination codes.
Definition
extension.h:162
rtems_fatal_source
Internal_errors_Source rtems_fatal_source
This enumeration represents system termination sources.
Definition
extension.h:175
void ScoreSmpValFatalBootProcessorNotAssignedToScheduler_Run(rtems_fatal_source source, rtems_fatal_code code)
Runs the parameterized test case.
Definition
tr-fatal-boot-processor-not-assigned-to-scheduler.c:136
rtems.h
code
Definition
inftrees.h:24
