RTEMS 6.3
This source file contains the selftest support implementation. More...
#include <stdint.h>#include <stdbool.h>#include <stddef.h>#include <bsp/tms570.h>#include <bsp/tms570_selftest.h>#include <bsp/tms570_hwinit.h>Macros | |
| #define | MSTGCR_ENABLE_MEMORY_SELF_TEST 0x0000010a |
| #define | MSTGCR_DISABLE_MEMORY_SELF_TEST 0x00000105 |
| #define | PBIST_RESET_DELAY (32 * 2) |
| bool | tms570_efc_stuck_zero (void) |
| Checks to see if the EFUSE Stuck at zero test is completed successfully (HCG:efcStuckZeroTest). /. | |
| void | tms570_efc_self_test (void) |
| EFUSE module self check Driver (HCG:efcSelfTest). | |
| bool | tms570_efc_check_self_test (void) |
| EFUSE module self check Driver (HCG:checkefcSelfTest). | |
| uint32_t | tms570_efc_check (void) |
| EFUSE module self check Driver (HCG:efcCheck). | |
| void | tms570_pbist_self_check (void) |
| PBIST self test Driver (HCG:pbistSelfCheck). | |
| void | tms570_pbist_run (uint32_t raminfoL, uint32_t algomask) |
| CPU self test Driver (HCG:pbistRun). | |
| void | tms570_pbist_stop (void) |
| Routine to stop PBIST test enabled (HCG:pbistStop). | |
| bool | tms570_pbist_is_test_completed (void) |
| Checks to see if the PBIST test is completed (HCG:pbistIsTestCompleted). | |
| bool | tms570_pbist_is_test_passed (void) |
| Checks to see if the PBIST test is completed successfully (HCG:pbistIsTestPassed). | |
| void | tms570_pbist_run_and_check (uint32_t raminfoL, uint32_t algomask) |
| bool | tms570_pbist_port_test_status (uint32_t port) |
| Checks to see if the PBIST Port test is completed successfully (HCG:pbistPortTestStatus). | |
| void | tms570_pbist_fail (void) |
| Reaction to PBIST failure (HCG:pbistFail). | |
| __attribute__ ((__naked__)) | |
| Memory Initialization Driver (HCG:memoryInit). | |
| void | tms570_esm_channel_sr_clear (unsigned grp, unsigned chan) |
| Routine to clear specified error channel signalling bit. | |
| int | tms570_esm_channel_sr_get (unsigned grp, unsigned chan) |
| Routine to test is specified error channel is signalling error. | |
| void | tms570_enable_parity (void) |
| Enable peripheral RAM parity (HCG:enableParity). | |
| void | tms570_disable_parity (void) |
| Disable peripheral RAM parity (HCG:disableParity). | |
| volatile uint32_t *const | tms570_esm_group_channel_to_sr_table [4][2] |
| __attribute__ | ( | (__naked__) | ) |
This function is called to perform Memory initialization of selected RAM's.
| void tms570_disable_parity | ( | void | ) |
This function disables RAM parity for all peripherals for which RAM parity check is enabled. This function is called after memoryInit in the startup
| uint32_t tms570_efc_check | ( | void | ) |
This function self checks the EFUSE module.
| bool tms570_efc_check_self_test | ( | void | ) |
This function returns the status of efcSelfTest. Note: This function can be called only after calling efcSelfTest
| void tms570_efc_self_test | ( | void | ) |
This function self checks the EFSUE module.
| bool tms570_efc_stuck_zero | ( | void | ) |
Checks to see if the EFUSE Stuck at zero test is completed successfully.
| void tms570_enable_parity | ( | void | ) |
This function enables RAM parity for all peripherals for which RAM parity check is enabled. This function is called before memoryInit in the startup
| void tms570_esm_channel_sr_clear | ( | unsigned | grp, |
| unsigned | chan ) |
| [in] | grp | - ESM error channels group |
| [in] | chan | - ESM error channel number inside specified group |
| int tms570_esm_channel_sr_get | ( | unsigned | grp, |
| unsigned | chan ) |
| void tms570_pbist_fail | ( | void | ) |
| bool tms570_pbist_is_test_completed | ( | void | ) |
Checks to see if the PBIST test is completed.
| bool tms570_pbist_is_test_passed | ( | void | ) |
Checks to see if the PBIST test is completed successfully.
| bool tms570_pbist_port_test_status | ( | uint32_t | port | ) |
| [in] | port | - Select the port to get the status. |
Checks to see if the selected PBIST Port test is completed successfully.
| void tms570_pbist_run | ( | uint32_t | raminfoL, |
| uint32_t | algomask ) |
| [in] | raminfoL | - Select the list of RAM to be tested. |
| [in] | algomask | - Select the list of Algorithm to be run. |
This function performs Memory Built-in Self test using PBIST module.
| void tms570_pbist_run_and_check | ( | uint32_t | raminfoL, |
Helper method that will run a pbist test and blocks until it finishes Reduces code duplication in start system start hooks
| void tms570_pbist_self_check | ( | void | ) |
This function is called to perform PBIST self test.
| void tms570_pbist_stop | ( | void | ) |
This function is called to stop PBIST after test is performed.
| volatile uint32_t* const tms570_esm_group_channel_to_sr_table[4][2] |
