RTEMS
6.3
Toggle main menu visibility
bsps
arm
tms570
include
bsp
tms570-pinmux.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
* Copyright (C) 2015 Premysl Houdek <kom541000@gmail.com>
14
15
* Google Summer of Code 2014 at
16
* Czech Technical University in Prague
17
* Zikova 1903/4
18
* 166 36 Praha 6
19
* Czech Republic
20
21
22
* modification, are permitted provided that the following conditions
23
* are met:
24
* 1. Redistributions of source code must retain the above copyright
25
* notice, this list of conditions and the following disclaimer.
26
* 2. Redistributions in binary form must reproduce the above copyright
27
* notice, this list of conditions and the following disclaimer in the
28
* documentation and/or other materials provided with the distribution.
29
30
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
31
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
32
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
33
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
34
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
35
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
36
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
37
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
38
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
39
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
40
* POSSIBILITY OF SUCH DAMAGE.
41
42
43
#ifndef LIBBSP_ARM_TMS570_PINMUX_H
44
#define LIBBSP_ARM_TMS570_PINMUX_H
45
46
#include <stddef.h>
47
#include <stdint.h>
48
49
#ifdef __cplusplus
50
extern
"C"
51
#endif
/* __cplusplus */
52
53
54
#define TMS570_PIN_NUM_SHIFT 0
55
#define TMS570_PIN_NUM_MASK 0x000007ff
56
57
58
* Request clear of interconnection in setup
59
* to ensure that previous peripheral to pin
60
* connection is not enabled in parallel to other one.
61
* Mask is ored with pin number in such list.
62
63
#define TMS570_PIN_CLEAR_RQ_MASK 0x00008000
64
65
#define TMS570_PIN_FNC_SHIFT 11
66
#define TMS570_PIN_FNC_MASK 0x00007800
67
74
#define TMS570_PIN_FNC_CLEAR 0x10U
75
76
#define TMS570_PIN_NUM_FNC_MASK 0x0000ffff
77
78
#define TMS570_PIN_IN_ALT_SHIFT 16
79
#define TMS570_PIN_IN_ALT_MASK 0xffff0000
80
81
#define TMS570_PIN_FNC_AUTO (-1)
82
92
#define TMS570_PIN_AND_FNC(pin, fnc) \
93
((pin) | ((fnc) << TMS570_PIN_FNC_SHIFT))
94
95
#define TMS570_PIN_WITH_IN_ALT(pin_num_and_fnc, pin_in_alt_num_and_fnc) \
96
((pin_num_and_fnc) | ((pin_in_alt_num_and_fnc) << TMS570_PIN_IN_ALT_SHIFT))
97
98
#define TMS570_BALL_WITH_MMR(mmrx, pos) \
99
((pos) | ((mmrx) << 2))
100
107
void
tms570_pin_config_prepare
void
108
118
void
tms570_pin_config_apply
(uint32_t config);
119
131
void
tms570_pin_config_array_apply
const
uint32_t *config,
size_t
count);
132
136
void
tms570_pin_config_complete
void
137
138
/* Generic functions select pin to peripheral connection */
139
140
void
tms570_bsp_pin_set_function
int
pin_num,
int
pin_fnc);
141
142
void
tms570_bsp_pin_clear_function
int
pin_num,
int
pin_fnc);
143
144
void
tms570_bsp_pin_config_one
(uint32_t pin_num_and_fnc);
145
146
void
tms570_bsp_pinmmr_config
const
uint32_t *pinmmr_values,
int
reg_start,
int
reg_count);
147
148
#define TMS570_PINMMR_REG_SINGLE_VAL_ACTION(reg, pin) \
149
(((((pin) & TMS570_PIN_NUM_MASK) >> 2 != (reg)) || ((pin) & TMS570_PIN_CLEAR_RQ_MASK))? 0: \
150
1 << ((((pin) & TMS570_PIN_FNC_MASK) >> TMS570_PIN_FNC_SHIFT) + \
151
((pin) & 3) * 8) \
152
153
154
#define TMS570_PINMMR_REG_VAL_ACTION(reg, pin) \
155
TMS570_PINMMR_REG_SINGLE_VAL_ACTION(reg, pin) | \
156
((pin) & TMS570_PIN_IN_ALT_MASK? \
157
TMS570_PINMMR_REG_SINGLE_VAL_ACTION(reg, (pin) >> TMS570_PIN_IN_ALT_SHIFT ): \
158
0) |
159
173
#define TMS570_PINMMR_REG_VAL(reg, pin_list) \
174
pin_list(TMS570_PINMMR_REG_VAL_ACTION, reg) 0
175
176
#define TMS570_PINMMR_COMA_LIST_ACTION(reg, pin) \
177
(pin),
178
190
#define TMS570_PINMMR_COMA_LIST(pin_list) \
191
pin_list(TMS570_PINMMR_COMA_LIST_ACTION, 0)
192
194
195
#ifdef __cplusplus
196
197
#endif
/* __cplusplus */
198
199
#endif
/* LIBBSP_ARM_TMS570_IRQ_H */
void tms570_bsp_pinmmr_config(const uint32_t *pinmmr_values, int reg_start, int reg_count)
configure block or whole pin multiplexer
Definition
pinmux.c:170
void tms570_bsp_pin_set_function(int pin_num, int pin_fnc)
select desired function of pin/ball
Definition
pinmux.c:80
void tms570_pin_config_array_apply(const uint32_t *config, size_t count)
Applies a pin configuration array.
Definition
pinmux.c:237
void tms570_bsp_pin_config_one(uint32_t pin_num_and_fnc)
configure one pin according to its function specification
Definition
pinmux.c:141
void tms570_pin_config_apply(uint32_t config)
Applies a pin configuration.
Definition
pinmux.c:222
void tms570_pin_config_complete(void)
Completes a pin configuration sequence.
Definition
pinmux.c:246
void tms570_pin_config_prepare(void)
Prepares a pin configuration sequence.
Definition
pinmux.c:194
void tms570_bsp_pin_clear_function(int pin_num, int pin_fnc)
clear connection between pin and specified peripherals/function
Definition
pinmux.c:105
